RTEMS 5.2-rc1
reg_dma.h
1/* The header file is generated by make_header.py from DMA.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_DMA
40#define LIBBSP_ARM_TMS570_DMA
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t STARTADD; /*DMA Memory Protection Region start Address Register*/
46 uint32_t ENDADD; /*DMA Memory Protection Region End Address Register*/
48
49typedef struct{
50 uint32_t GCTRL; /*Global Control Register*/
51 uint32_t PEND; /*Channel Pending Register*/
52 uint8_t reserved1 [4];
53 uint32_t DMASTAT; /*DMA Status Register*/
54 uint8_t reserved2 [4];
55 uint32_t HWCHENAS; /*HW Channel Enable Set and Status Register*/
56 uint8_t reserved3 [4];
57 uint32_t HWCHENAR; /*HW Channel Enable Reset and Status Register*/
58 uint8_t reserved4 [4];
59 uint32_t SWCHENAS; /*SW Channel Enable Set and Status Register*/
60 uint8_t reserved5 [4];
61 uint32_t SWCHENAR; /*SW Channel Enable Reset and Status Register*/
62 uint8_t reserved6 [4];
63 uint32_t CHPRIOS; /*Channel Priority Set Register*/
64 uint8_t reserved7 [4];
65 uint32_t CHPRIOR; /*Channel Priority Reset Register*/
66 uint8_t reserved8 [4];
67 uint32_t GCHIENAS; /*Global Channel Interrupt Enable Set Register*/
68 uint8_t reserved9 [4];
69 uint32_t GCHIENAR; /*Global Channel Interrupt Enable Reset Register*/
70 uint8_t reserved10 [4];
71 uint32_t DREQASI[4]; /*DMA Request Assignment Register 0*/
72 uint8_t reserved11 [48];
73 uint32_t PAR0; /*Port Assignment Register 0*/
74 uint32_t PAR1; /*Port Assignment Register 1*/
75 uint8_t reserved12 [24];
76 uint32_t FTCMAP; /*FTC Interrupt Mapping Register*/
77 uint8_t reserved13 [4];
78 uint32_t LFSMAP; /*LFS Interrupt Mapping Register*/
79 uint8_t reserved14 [4];
80 uint32_t HBCMAP; /*HBC Interrupt Mapping Register*/
81 uint8_t reserved15 [4];
82 uint32_t BTCMAP; /*BTC Interrupt Mapping Register*/
83 uint8_t reserved16 [4];
84 uint32_t BERMAP; /*BER Interrupt Mapping Register*/
85 uint8_t reserved17 [4];
86 uint32_t FTCINTENAS; /*FTC Interrupt Enable Set*/
87 uint8_t reserved18 [4];
88 uint32_t FTCINTENAR; /*FTC Interrupt Enable Reset*/
89 uint8_t reserved19 [4];
90 uint32_t LFSINTENAS; /*LFS Interrupt Enable Set*/
91 uint8_t reserved20 [4];
92 uint32_t LFSINTENAR; /*LFS Interrupt Enable Reset*/
93 uint8_t reserved21 [4];
94 uint32_t HBCINTENAS; /*HBC Interrupt Enable Set*/
95 uint8_t reserved22 [4];
96 uint32_t HBCINTENAR; /*HBC Interrupt Enable Reset*/
97 uint8_t reserved23 [4];
98 uint32_t BTCINTENAS; /*BTC Interrupt Enable Set*/
99 uint8_t reserved24 [4];
100 uint32_t BTCINTENAR; /*BTC Interrupt Enable Reset*/
101 uint8_t reserved25 [4];
102 uint32_t GINTFLAG; /*Global Interrupt Flag Register*/
103 uint8_t reserved26 [4];
104 uint32_t FTCFLAG; /*FTC Interrupt Flag Register*/
105 uint8_t reserved27 [4];
106 uint32_t LFSFLAG; /*LFS Interrupt Flag Register*/
107 uint8_t reserved28 [4];
108 uint32_t HBCFLAG; /*HBC Interrupt Flag Register*/
109 uint8_t reserved29 [4];
110 uint32_t BTCFLAG; /*BTC Interrupt Flag Register*/
111 uint8_t reserved30 [4];
112 uint32_t BERFLAG; /*BER Interrupt Flag Register*/
113 uint8_t reserved31 [4];
114 uint32_t FTCAOFFSET; /*FTCA Interrupt Channel Offset Register*/
115 uint32_t LFSAOFFSET; /*LFSA Interrupt Channel Offset Register*/
116 uint32_t HBCAOFFSET; /*HBCA Interrupt Channel Offset Register*/
117 uint32_t BTCAOFFSET; /*BTCA Interrupt Channel Offset Register*/
118 uint32_t BERAOFFSET; /*BERA Interrupt Channel Offset Register*/
119 uint32_t FTCBOFFSET; /*FTCB Interrupt Channel Offset Register*/
120 uint32_t LFSBOFFSET; /*LFSB Interrupt Channel Offset Register*/
121 uint32_t HBCBOFFSET; /*HBCB Interrupt Channel Offset Register*/
122 uint32_t BTCBOFFSET; /*BTCB Interrupt Channel Offset Register*/
123 uint32_t BERBOFFSET; /*BERB Interrupt Channel Offset Register*/
124 uint8_t reserved32 [4];
125 uint32_t PTCRL; /*Port Control Register*/
126 uint32_t RTCTRL; /*RAM Test Control Register*/
127 uint32_t DCTRL; /*Debug Control*/
128 uint32_t WPR; /*Watch Point Register*/
129 uint32_t WMR; /*Watch Mask Register*/
130 uint8_t reserved33 [12];
131 uint32_t PBACSADDR; /*Port B Active Channel Source Address Register*/
132 uint32_t PBACDADDR; /*Port B Active Channel Destination Address Register*/
133 uint32_t PBACTC; /*Port B Active Channel Transfer Count Register*/
134 uint8_t reserved34 [4];
135 uint32_t DMAPCR; /*Parity Control Register*/
136 uint32_t DMAPAR; /*DMA Parity Error Address Register*/
137 uint32_t DMAMPCTRL; /*DMA Memory Protection Control Register*/
138 uint32_t DMAMPST; /*DMA Memory Protection Status Register*/
139 tms570_memory_prot_t DMAMPROS[4];/*DMA Memory Protection Regions*/
141
142
143/*--------------------TMS570_DMA_STARTADD--------------------*/
144/* field: STARTADDRESS - Start Address defines the address at which the region begins. */
145/* Whole 32 bits */
146
147/*---------------------TMS570_DMA_ENDADD---------------------*/
148/* field: ENDADDRESS - End Address defines the address at which the region ends. */
149/* Whole 32 bits */
150
151/*----------------------TMS570_DMA_GCTRL----------------------*/
152/* field: DMA_EN - DMA enable bit. */
153#define TMS570_DMA_GCTRL_DMA_EN BSP_BIT32(16)
154
155/* field: BUS_BUSY - This bit indicates status of DMA external AHB bus status. */
156#define TMS570_DMA_GCTRL_BUS_BUSY BSP_BIT32(14)
157
158/* field: DEBUG_MODE - Debug Mode. */
159#define TMS570_DMA_GCTRL_DEBUG_MODE(val) BSP_FLD32(val,8, 9)
160#define TMS570_DMA_GCTRL_DEBUG_MODE_GET(reg) BSP_FLD32GET(reg,8, 9)
161#define TMS570_DMA_GCTRL_DEBUG_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
162
163/* field: DMA_RES - DMA software reset */
164#define TMS570_DMA_GCTRL_DMA_RES BSP_BIT32(0)
165
166
167/*----------------------TMS570_DMA_PEND----------------------*/
168/* field: PEND - Channel pending register. */
169#define TMS570_DMA_PEND_PEND(val) BSP_FLD32(val,0, 15)
170#define TMS570_DMA_PEND_PEND_GET(reg) BSP_FLD32GET(reg,0, 15)
171#define TMS570_DMA_PEND_PEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
172
173
174/*---------------------TMS570_DMA_DMASTAT---------------------*/
175/* field: STCH - Status of DMA channels. */
176#define TMS570_DMA_DMASTAT_STCH(val) BSP_FLD32(val,0, 15)
177#define TMS570_DMA_DMASTAT_STCH_GET(reg) BSP_FLD32GET(reg,0, 15)
178#define TMS570_DMA_DMASTAT_STCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
179
180
181/*--------------------TMS570_DMA_HWCHENAS--------------------*/
182/* field: HWCHENA - Hardware channel enable bit. */
183#define TMS570_DMA_HWCHENAS_HWCHENA(val) BSP_FLD32(val,0, 15)
184#define TMS570_DMA_HWCHENAS_HWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15)
185#define TMS570_DMA_HWCHENAS_HWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
186
187
188/*--------------------TMS570_DMA_HWCHENAR--------------------*/
189/* field: HWCHDIS - HW channel disable bit. */
190#define TMS570_DMA_HWCHENAR_HWCHDIS(val) BSP_FLD32(val,0, 15)
191#define TMS570_DMA_HWCHENAR_HWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
192#define TMS570_DMA_HWCHENAR_HWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
193
194
195/*--------------------TMS570_DMA_SWCHENAS--------------------*/
196/* field: SWCHENA - SW channel enable bit. */
197#define TMS570_DMA_SWCHENAS_SWCHENA(val) BSP_FLD32(val,0, 15)
198#define TMS570_DMA_SWCHENAS_SWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15)
199#define TMS570_DMA_SWCHENAS_SWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
200
201
202/*--------------------TMS570_DMA_SWCHENAR--------------------*/
203/* field: SWCHDIS - SW channel disable bit. */
204#define TMS570_DMA_SWCHENAR_SWCHDIS(val) BSP_FLD32(val,0, 15)
205#define TMS570_DMA_SWCHENAR_SWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
206#define TMS570_DMA_SWCHENAR_SWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
207
208
209/*---------------------TMS570_DMA_CHPRIOS---------------------*/
210/* field: CPS - Channel priority set bit. */
211#define TMS570_DMA_CHPRIOS_CPS(val) BSP_FLD32(val,0, 15)
212#define TMS570_DMA_CHPRIOS_CPS_GET(reg) BSP_FLD32GET(reg,0, 15)
213#define TMS570_DMA_CHPRIOS_CPS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
214
215
216/*---------------------TMS570_DMA_CHPRIOR---------------------*/
217/* field: CPR - Channel priority reset bit. */
218#define TMS570_DMA_CHPRIOR_CPR(val) BSP_FLD32(val,0, 15)
219#define TMS570_DMA_CHPRIOR_CPR_GET(reg) BSP_FLD32GET(reg,0, 15)
220#define TMS570_DMA_CHPRIOR_CPR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
221
222
223/*--------------------TMS570_DMA_GCHIENAS--------------------*/
224/* field: GCHIE - Global channel interrupt enable bit. */
225#define TMS570_DMA_GCHIENAS_GCHIE(val) BSP_FLD32(val,0, 15)
226#define TMS570_DMA_GCHIENAS_GCHIE_GET(reg) BSP_FLD32GET(reg,0, 15)
227#define TMS570_DMA_GCHIENAS_GCHIE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
228
229
230/*--------------------TMS570_DMA_GCHIENAR--------------------*/
231/* field: GCHID - Global channel interrupt disable bit. */
232#define TMS570_DMA_GCHIENAR_GCHID(val) BSP_FLD32(val,0, 15)
233#define TMS570_DMA_GCHIENAR_GCHID_GET(reg) BSP_FLD32GET(reg,0, 15)
234#define TMS570_DMA_GCHIENAR_GCHID_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
235
236
237/*---------------------TMS570_DMA_DREQASI---------------------*/
238/* field: CH0ASI - Channel 0 assignment. This bit field chooses the DMA request assignment for channel 0. */
239#define TMS570_DMA_DREQASI_CH0ASI(val) BSP_FLD32(val,24, 29)
240#define TMS570_DMA_DREQASI_CH0ASI_GET(reg) BSP_FLD32GET(reg,24, 29)
241#define TMS570_DMA_DREQASI_CH0ASI_SET(reg,val) BSP_FLD32SET(reg, val,24, 29)
242
243/* field: CH1ASI - Channel 1 assignment. This bit field chooses the DMA request assignment for channel 1. */
244#define TMS570_DMA_DREQASI_CH1ASI(val) BSP_FLD32(val,16, 21)
245#define TMS570_DMA_DREQASI_CH1ASI_GET(reg) BSP_FLD32GET(reg,16, 21)
246#define TMS570_DMA_DREQASI_CH1ASI_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
247
248/* field: CH2ASI - Channel 2 assignment. This bit field chooses the DMA request assignment for channel 2. */
249#define TMS570_DMA_DREQASI_CH2ASI(val) BSP_FLD32(val,8, 13)
250#define TMS570_DMA_DREQASI_CH2ASI_GET(reg) BSP_FLD32GET(reg,8, 13)
251#define TMS570_DMA_DREQASI_CH2ASI_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
252
253/* field: CH3ASI - Channel 3 assignment. This bit field chooses the DMA request assignment for channel 3. */
254#define TMS570_DMA_DREQASI_CH3ASI(val) BSP_FLD32(val,0, 5)
255#define TMS570_DMA_DREQASI_CH3ASI_GET(reg) BSP_FLD32GET(reg,0, 5)
256#define TMS570_DMA_DREQASI_CH3ASI_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
257
258
259/*----------------------TMS570_DMA_PAR0----------------------*/
260/* field: CH0PA - These bit fields determine to which port channel 0 is assigned. */
261#define TMS570_DMA_PAR0_CH0PA(val) BSP_FLD32(val,28, 30)
262#define TMS570_DMA_PAR0_CH0PA_GET(reg) BSP_FLD32GET(reg,28, 30)
263#define TMS570_DMA_PAR0_CH0PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30)
264
265/* field: CH1PA - These bit fields determine to which port channel 1 is assigned. */
266#define TMS570_DMA_PAR0_CH1PA(val) BSP_FLD32(val,24, 26)
267#define TMS570_DMA_PAR0_CH1PA_GET(reg) BSP_FLD32GET(reg,24, 26)
268#define TMS570_DMA_PAR0_CH1PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
269
270/* field: CH2PA - These bit fields determine to which port channel 2 is assigned. */
271#define TMS570_DMA_PAR0_CH2PA(val) BSP_FLD32(val,20, 22)
272#define TMS570_DMA_PAR0_CH2PA_GET(reg) BSP_FLD32GET(reg,20, 22)
273#define TMS570_DMA_PAR0_CH2PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
274
275/* field: CH3PA - These bit fields determine to which port channel 3 is assigned. */
276#define TMS570_DMA_PAR0_CH3PA(val) BSP_FLD32(val,16, 18)
277#define TMS570_DMA_PAR0_CH3PA_GET(reg) BSP_FLD32GET(reg,16, 18)
278#define TMS570_DMA_PAR0_CH3PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
279
280/* field: CH4PA - These bit fields determine to which port channel 4 is assigned. */
281#define TMS570_DMA_PAR0_CH4PA(val) BSP_FLD32(val,12, 14)
282#define TMS570_DMA_PAR0_CH4PA_GET(reg) BSP_FLD32GET(reg,12, 14)
283#define TMS570_DMA_PAR0_CH4PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
284
285/* field: CH5PA - These bit fields determine to which port channel 5 is assigned. */
286#define TMS570_DMA_PAR0_CH5PA(val) BSP_FLD32(val,8, 10)
287#define TMS570_DMA_PAR0_CH5PA_GET(reg) BSP_FLD32GET(reg,8, 10)
288#define TMS570_DMA_PAR0_CH5PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
289
290/* field: CH6PA - These bit fields determine to which port channel 6 is assigned. */
291#define TMS570_DMA_PAR0_CH6PA(val) BSP_FLD32(val,4, 6)
292#define TMS570_DMA_PAR0_CH6PA_GET(reg) BSP_FLD32GET(reg,4, 6)
293#define TMS570_DMA_PAR0_CH6PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
294
295/* field: CH7PA - These bit fields determine to which port channel 7 is assigned. */
296#define TMS570_DMA_PAR0_CH7PA(val) BSP_FLD32(val,0, 2)
297#define TMS570_DMA_PAR0_CH7PA_GET(reg) BSP_FLD32GET(reg,0, 2)
298#define TMS570_DMA_PAR0_CH7PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
299
300
301/*----------------------TMS570_DMA_PAR1----------------------*/
302/* field: CH8PA - These bit fields determine to which port channel 8 is assigned. */
303#define TMS570_DMA_PAR1_CH8PA(val) BSP_FLD32(val,28, 30)
304#define TMS570_DMA_PAR1_CH8PA_GET(reg) BSP_FLD32GET(reg,28, 30)
305#define TMS570_DMA_PAR1_CH8PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30)
306
307/* field: CH9PA - These bit fields determine to which port channel 9 is assigned. */
308#define TMS570_DMA_PAR1_CH9PA(val) BSP_FLD32(val,24, 26)
309#define TMS570_DMA_PAR1_CH9PA_GET(reg) BSP_FLD32GET(reg,24, 26)
310#define TMS570_DMA_PAR1_CH9PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
311
312/* field: CH10PA - These bit fields determine to which port channel 10 is assigned. */
313#define TMS570_DMA_PAR1_CH10PA(val) BSP_FLD32(val,20, 22)
314#define TMS570_DMA_PAR1_CH10PA_GET(reg) BSP_FLD32GET(reg,20, 22)
315#define TMS570_DMA_PAR1_CH10PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
316
317/* field: CH11PA - These bit fields determine to which port channel 11 is assigned. */
318#define TMS570_DMA_PAR1_CH11PA(val) BSP_FLD32(val,16, 18)
319#define TMS570_DMA_PAR1_CH11PA_GET(reg) BSP_FLD32GET(reg,16, 18)
320#define TMS570_DMA_PAR1_CH11PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
321
322/* field: CH12PA - These bit fields determine to which port channel 12 is assigned. */
323#define TMS570_DMA_PAR1_CH12PA(val) BSP_FLD32(val,12, 14)
324#define TMS570_DMA_PAR1_CH12PA_GET(reg) BSP_FLD32GET(reg,12, 14)
325#define TMS570_DMA_PAR1_CH12PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
326
327/* field: CH13PA - These bit fields determine to which port channel 13 is assigned. */
328#define TMS570_DMA_PAR1_CH13PA(val) BSP_FLD32(val,8, 10)
329#define TMS570_DMA_PAR1_CH13PA_GET(reg) BSP_FLD32GET(reg,8, 10)
330#define TMS570_DMA_PAR1_CH13PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
331
332/* field: CH14PA - These bit fields determine to which port channel 14 is assigned. */
333#define TMS570_DMA_PAR1_CH14PA(val) BSP_FLD32(val,4, 6)
334#define TMS570_DMA_PAR1_CH14PA_GET(reg) BSP_FLD32GET(reg,4, 6)
335#define TMS570_DMA_PAR1_CH14PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
336
337/* field: CH15PA - These bit fields determine to which port channel 15 is assigned. */
338#define TMS570_DMA_PAR1_CH15PA(val) BSP_FLD32(val,0, 2)
339#define TMS570_DMA_PAR1_CH15PA_GET(reg) BSP_FLD32GET(reg,0, 2)
340#define TMS570_DMA_PAR1_CH15PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
341
342
343/*---------------------TMS570_DMA_FTCMAP---------------------*/
344/* field: FTCAB - Frame transfer complete (FTC) interrupt to Group A or Group B. */
345#define TMS570_DMA_FTCMAP_FTCAB(val) BSP_FLD32(val,0, 15)
346#define TMS570_DMA_FTCMAP_FTCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
347#define TMS570_DMA_FTCMAP_FTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
348
349
350/*---------------------TMS570_DMA_LFSMAP---------------------*/
351/* field: LFSAB - Last frame started (LFS) interrupt to Group A or Group B. */
352#define TMS570_DMA_LFSMAP_LFSAB(val) BSP_FLD32(val,0, 15)
353#define TMS570_DMA_LFSMAP_LFSAB_GET(reg) BSP_FLD32GET(reg,0, 15)
354#define TMS570_DMA_LFSMAP_LFSAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
355
356
357/*---------------------TMS570_DMA_HBCMAP---------------------*/
358/* field: HBCAB - Half block complete (HBC) interrupt to Group A or Group B. */
359#define TMS570_DMA_HBCMAP_HBCAB(val) BSP_FLD32(val,0, 15)
360#define TMS570_DMA_HBCMAP_HBCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
361#define TMS570_DMA_HBCMAP_HBCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
362
363
364/*---------------------TMS570_DMA_BTCMAP---------------------*/
365/* field: BTCAB - Block transfer complete (BTC) interrupt to Group A or Group B */
366#define TMS570_DMA_BTCMAP_BTCAB(val) BSP_FLD32(val,0, 15)
367#define TMS570_DMA_BTCMAP_BTCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
368#define TMS570_DMA_BTCMAP_BTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
369
370
371/*---------------------TMS570_DMA_BERMAP---------------------*/
372/* field: BERAB - Bus error (BER) interrupt to Group A or Group B. */
373#define TMS570_DMA_BERMAP_BERAB(val) BSP_FLD32(val,0, 15)
374#define TMS570_DMA_BERMAP_BERAB_GET(reg) BSP_FLD32GET(reg,0, 15)
375#define TMS570_DMA_BERMAP_BERAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
376
377
378/*-------------------TMS570_DMA_FTCINTENAS-------------------*/
379/* field: FTCINTENA - Frame transfer complete (FTC) interrupt enable. */
380#define TMS570_DMA_FTCINTENAS_FTCINTENA(val) BSP_FLD32(val,0, 15)
381#define TMS570_DMA_FTCINTENAS_FTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
382#define TMS570_DMA_FTCINTENAS_FTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
383
384
385/*-------------------TMS570_DMA_FTCINTENAR-------------------*/
386/* field: FTCINTDIS - Frame transfer complete (FTC) interrupt disable. */
387#define TMS570_DMA_FTCINTENAR_FTCINTDIS(val) BSP_FLD32(val,0, 15)
388#define TMS570_DMA_FTCINTENAR_FTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
389#define TMS570_DMA_FTCINTENAR_FTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
390
391
392/*-------------------TMS570_DMA_LFSINTENAS-------------------*/
393/* field: LFSINTENA - Last frame started (LFS) interrupt enable. */
394#define TMS570_DMA_LFSINTENAS_LFSINTENA(val) BSP_FLD32(val,0, 15)
395#define TMS570_DMA_LFSINTENAS_LFSINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
396#define TMS570_DMA_LFSINTENAS_LFSINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
397
398
399/*-------------------TMS570_DMA_LFSINTENAR-------------------*/
400/* field: LFSINTDIS - Last frame started (LFS) interrupt disable. */
401#define TMS570_DMA_LFSINTENAR_LFSINTDIS(val) BSP_FLD32(val,0, 15)
402#define TMS570_DMA_LFSINTENAR_LFSINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
403#define TMS570_DMA_LFSINTENAR_LFSINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
404
405
406/*-------------------TMS570_DMA_HBCINTENAS-------------------*/
407/* field: HBCINTENA - Half block complete (HBC) interrupt enable. */
408#define TMS570_DMA_HBCINTENAS_HBCINTENA(val) BSP_FLD32(val,0, 15)
409#define TMS570_DMA_HBCINTENAS_HBCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
410#define TMS570_DMA_HBCINTENAS_HBCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
411
412
413/*-------------------TMS570_DMA_HBCINTENAR-------------------*/
414/* field: HBCINTDIS - Half block complete (HBC) interrupt disable. */
415#define TMS570_DMA_HBCINTENAR_HBCINTDIS(val) BSP_FLD32(val,0, 15)
416#define TMS570_DMA_HBCINTENAR_HBCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
417#define TMS570_DMA_HBCINTENAR_HBCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
418
419
420/*-------------------TMS570_DMA_BTCINTENAS-------------------*/
421/* field: BTCINTENA - Block transfer complete (BTC) interrupt enable. */
422#define TMS570_DMA_BTCINTENAS_BTCINTENA(val) BSP_FLD32(val,0, 15)
423#define TMS570_DMA_BTCINTENAS_BTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
424#define TMS570_DMA_BTCINTENAS_BTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
425
426
427/*-------------------TMS570_DMA_BTCINTENAR-------------------*/
428/* field: BTCINTDIS - Block transfer complete (BTC) interurpt disable. */
429#define TMS570_DMA_BTCINTENAR_BTCINTDIS(val) BSP_FLD32(val,0, 15)
430#define TMS570_DMA_BTCINTENAR_BTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
431#define TMS570_DMA_BTCINTENAR_BTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
432
433
434/*--------------------TMS570_DMA_GINTFLAG--------------------*/
435/* field: GINT - Global interrupt flags. */
436#define TMS570_DMA_GINTFLAG_GINT(val) BSP_FLD32(val,0, 15)
437#define TMS570_DMA_GINTFLAG_GINT_GET(reg) BSP_FLD32GET(reg,0, 15)
438#define TMS570_DMA_GINTFLAG_GINT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
439
440
441/*---------------------TMS570_DMA_FTCFLAG---------------------*/
442/* field: FTCI - Frame transfer complete (FTC) flags. */
443#define TMS570_DMA_FTCFLAG_FTCI(val) BSP_FLD32(val,0, 15)
444#define TMS570_DMA_FTCFLAG_FTCI_GET(reg) BSP_FLD32GET(reg,0, 15)
445#define TMS570_DMA_FTCFLAG_FTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
446
447
448/*---------------------TMS570_DMA_LFSFLAG---------------------*/
449/* field: LFSI - Last frame started (LFS) flags. */
450#define TMS570_DMA_LFSFLAG_LFSI(val) BSP_FLD32(val,0, 15)
451#define TMS570_DMA_LFSFLAG_LFSI_GET(reg) BSP_FLD32GET(reg,0, 15)
452#define TMS570_DMA_LFSFLAG_LFSI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
453
454
455/*---------------------TMS570_DMA_HBCFLAG---------------------*/
456/* field: HBCI - Half block transfer (HBC) complete flags. */
457#define TMS570_DMA_HBCFLAG_HBCI(val) BSP_FLD32(val,0, 15)
458#define TMS570_DMA_HBCFLAG_HBCI_GET(reg) BSP_FLD32GET(reg,0, 15)
459#define TMS570_DMA_HBCFLAG_HBCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
460
461
462/*---------------------TMS570_DMA_BTCFLAG---------------------*/
463/* field: BTCI - Block transfer complete (BTC) flags. */
464#define TMS570_DMA_BTCFLAG_BTCI(val) BSP_FLD32(val,0, 15)
465#define TMS570_DMA_BTCFLAG_BTCI_GET(reg) BSP_FLD32GET(reg,0, 15)
466#define TMS570_DMA_BTCFLAG_BTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
467
468
469/*---------------------TMS570_DMA_BERFLAG---------------------*/
470/* field: BERI - Bus error (BER) flags. */
471#define TMS570_DMA_BERFLAG_BERI(val) BSP_FLD32(val,0, 15)
472#define TMS570_DMA_BERFLAG_BERI_GET(reg) BSP_FLD32GET(reg,0, 15)
473#define TMS570_DMA_BERFLAG_BERI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
474
475
476/*-------------------TMS570_DMA_FTCAOFFSET-------------------*/
477/* field: sbz - These bits should always be programmed as zero. */
478#define TMS570_DMA_FTCAOFFSET_sbz(val) BSP_FLD32(val,6, 7)
479#define TMS570_DMA_FTCAOFFSET_sbz_GET(reg) BSP_FLD32GET(reg,6, 7)
480#define TMS570_DMA_FTCAOFFSET_sbz_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
481
482/* field: FTCA - Channel causing FTC interrupt Group A. */
483#define TMS570_DMA_FTCAOFFSET_FTCA(val) BSP_FLD32(val,0, 5)
484#define TMS570_DMA_FTCAOFFSET_FTCA_GET(reg) BSP_FLD32GET(reg,0, 5)
485#define TMS570_DMA_FTCAOFFSET_FTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
486
487
488/*-------------------TMS570_DMA_LFSAOFFSET-------------------*/
489/* field: LFSA - Channel causing LFS interrupt Group A. */
490#define TMS570_DMA_LFSAOFFSET_LFSA(val) BSP_FLD32(val,0, 5)
491#define TMS570_DMA_LFSAOFFSET_LFSA_GET(reg) BSP_FLD32GET(reg,0, 5)
492#define TMS570_DMA_LFSAOFFSET_LFSA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
493
494
495/*-------------------TMS570_DMA_HBCAOFFSET-------------------*/
496/* field: HBCA - Channel causing HBC interrupt Group A. */
497#define TMS570_DMA_HBCAOFFSET_HBCA(val) BSP_FLD32(val,0, 5)
498#define TMS570_DMA_HBCAOFFSET_HBCA_GET(reg) BSP_FLD32GET(reg,0, 5)
499#define TMS570_DMA_HBCAOFFSET_HBCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
500
501
502/*-------------------TMS570_DMA_BTCAOFFSET-------------------*/
503/* field: BTCA - Channel causing BTC interrupt Group A. */
504#define TMS570_DMA_BTCAOFFSET_BTCA(val) BSP_FLD32(val,0, 5)
505#define TMS570_DMA_BTCAOFFSET_BTCA_GET(reg) BSP_FLD32GET(reg,0, 5)
506#define TMS570_DMA_BTCAOFFSET_BTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
507
508
509/*-------------------TMS570_DMA_BERAOFFSET-------------------*/
510/* field: BERA - Channel causing BER interrupt Group A. */
511#define TMS570_DMA_BERAOFFSET_BERA(val) BSP_FLD32(val,0, 5)
512#define TMS570_DMA_BERAOFFSET_BERA_GET(reg) BSP_FLD32GET(reg,0, 5)
513#define TMS570_DMA_BERAOFFSET_BERA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
514
515
516/*-------------------TMS570_DMA_FTCBOFFSET-------------------*/
517/* field: FTCB - Channel causing FTC interrupt Group B. */
518#define TMS570_DMA_FTCBOFFSET_FTCB(val) BSP_FLD32(val,0, 5)
519#define TMS570_DMA_FTCBOFFSET_FTCB_GET(reg) BSP_FLD32GET(reg,0, 5)
520#define TMS570_DMA_FTCBOFFSET_FTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
521
522
523/*-------------------TMS570_DMA_LFSBOFFSET-------------------*/
524/* field: LFSB - Channel causing LFS interrupt Group B. */
525#define TMS570_DMA_LFSBOFFSET_LFSB(val) BSP_FLD32(val,0, 5)
526#define TMS570_DMA_LFSBOFFSET_LFSB_GET(reg) BSP_FLD32GET(reg,0, 5)
527#define TMS570_DMA_LFSBOFFSET_LFSB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
528
529
530/*-------------------TMS570_DMA_HBCBOFFSET-------------------*/
531/* field: HBCB - Channel causing HBC interrupt Group B. */
532#define TMS570_DMA_HBCBOFFSET_HBCB(val) BSP_FLD32(val,0, 5)
533#define TMS570_DMA_HBCBOFFSET_HBCB_GET(reg) BSP_FLD32GET(reg,0, 5)
534#define TMS570_DMA_HBCBOFFSET_HBCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
535
536
537/*-------------------TMS570_DMA_BTCBOFFSET-------------------*/
538/* field: BTCB - interrupt for Group B if the corresponding interrupt enable is set. */
539#define TMS570_DMA_BTCBOFFSET_BTCB(val) BSP_FLD32(val,0, 5)
540#define TMS570_DMA_BTCBOFFSET_BTCB_GET(reg) BSP_FLD32GET(reg,0, 5)
541#define TMS570_DMA_BTCBOFFSET_BTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
542
543
544/*-------------------TMS570_DMA_BERBOFFSET-------------------*/
545/* field: BERB - Channel causing BER interrupt Group B. */
546#define TMS570_DMA_BERBOFFSET_BERB(val) BSP_FLD32(val,0, 5)
547#define TMS570_DMA_BERBOFFSET_BERB_GET(reg) BSP_FLD32GET(reg,0, 5)
548#define TMS570_DMA_BERBOFFSET_BERB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
549
550
551/*----------------------TMS570_DMA_PTCRL----------------------*/
552/* field: PENDB - Transfers pending for Port B. This flag determines if transfers are ongoing on port B. */
553#define TMS570_DMA_PTCRL_PENDB BSP_BIT32(24)
554
555/* field: BYB - Bypass FIFO B. */
556#define TMS570_DMA_PTCRL_BYB BSP_BIT32(18)
557
558/* field: PSFRHQPB - Priority scheme fix or rotate for high priority queue of Port B. */
559#define TMS570_DMA_PTCRL_PSFRHQPB BSP_BIT32(17)
560
561/* field: PSFRLQPB - Priority scheme fix or rotate for low priority queue of Port B. */
562#define TMS570_DMA_PTCRL_PSFRLQPB BSP_BIT32(16)
563
564
565/*---------------------TMS570_DMA_RTCTRL---------------------*/
566/* field: RTC - RAM Test Control. */
567#define TMS570_DMA_RTCTRL_RTC BSP_BIT32(0)
568
569
570/*----------------------TMS570_DMA_DCTRL----------------------*/
571/* field: CHNUM - Channel Number. */
572#define TMS570_DMA_DCTRL_CHNUM(val) BSP_FLD32(val,24, 28)
573#define TMS570_DMA_DCTRL_CHNUM_GET(reg) BSP_FLD32GET(reg,24, 28)
574#define TMS570_DMA_DCTRL_CHNUM_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
575
576/* field: DMADBGS - DMA debug status. */
577#define TMS570_DMA_DCTRL_DMADBGS BSP_BIT32(16)
578
579/* field: DBGEN - Debug Enable. */
580#define TMS570_DMA_DCTRL_DBGEN BSP_BIT32(0)
581
582
583/*-----------------------TMS570_DMA_WPR-----------------------*/
584/* field: WP - Watch point. */
585/* Whole 32 bits */
586
587/*-----------------------TMS570_DMA_WMR-----------------------*/
588/* field: WM - Watch mask. */
589/* Whole 32 bits */
590
591/*--------------------TMS570_DMA_PBACSADDR--------------------*/
592/* field: PBACSA - Port B Active Channel Source Address. */
593/* Whole 32 bits */
594
595/*--------------------TMS570_DMA_PBACDADDR--------------------*/
596/* field: PBACDA - address of the active channel as broadcasted in Section 16.3.1.3 for Port B. */
597/* Whole 32 bits */
598
599/*---------------------TMS570_DMA_PBACTC---------------------*/
600/* field: PBFTCOUNT - Port B active channel frame count. */
601#define TMS570_DMA_PBACTC_PBFTCOUNT(val) BSP_FLD32(val,16, 28)
602#define TMS570_DMA_PBACTC_PBFTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 28)
603#define TMS570_DMA_PBACTC_PBFTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 28)
604
605/* field: PBETCOUNT - Port B active channel element count. */
606#define TMS570_DMA_PBACTC_PBETCOUNT(val) BSP_FLD32(val,0, 12)
607#define TMS570_DMA_PBACTC_PBETCOUNT_GET(reg) BSP_FLD32GET(reg,0, 12)
608#define TMS570_DMA_PBACTC_PBETCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
609
610
611/*---------------------TMS570_DMA_DMAPCR---------------------*/
612/* field: ERRA - Error action. */
613#define TMS570_DMA_DMAPCR_ERRA BSP_BIT32(16)
614
615/* field: TEST - When this bit is set, the parity bits are memory mapped to make them accessible by the CPU. */
616#define TMS570_DMA_DMAPCR_TEST BSP_BIT32(8)
617
618/* field: PARITY_ENA - Parity error detection enable. */
619#define TMS570_DMA_DMAPCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
620#define TMS570_DMA_DMAPCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
621#define TMS570_DMA_DMAPCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
622
623
624/*---------------------TMS570_DMA_DMAPAR---------------------*/
625/* field: EDFLAG - Parity Error Detection Flag. */
626#define TMS570_DMA_DMAPAR_EDFLAG BSP_BIT32(24)
627
628/* field: ERRORADDRESS - Error address. These bits hold the address of the first parity error generated in the RAM. */
629#define TMS570_DMA_DMAPAR_ERRORADDRESS(val) BSP_FLD32(val,0, 11)
630#define TMS570_DMA_DMAPAR_ERRORADDRESS_GET(reg) BSP_FLD32GET(reg,0, 11)
631#define TMS570_DMA_DMAPAR_ERRORADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
632
633
634/*--------------------TMS570_DMA_DMAMPCTRL--------------------*/
635/* field: INT3AB - Interrupt assignment of region 3 to Group A or Group B. */
636#define TMS570_DMA_DMAMPCTRL_INT3AB BSP_BIT32(28)
637
638/* field: INT3ENA - Interrupt enable of region 3. */
639#define TMS570_DMA_DMAMPCTRL_INT3ENA BSP_BIT32(27)
640
641/* field: REG3AP - Region 3 access permission. */
642#define TMS570_DMA_DMAMPCTRL_REG3AP(val) BSP_FLD32(val,25, 26)
643#define TMS570_DMA_DMAMPCTRL_REG3AP_GET(reg) BSP_FLD32GET(reg,25, 26)
644#define TMS570_DMA_DMAMPCTRL_REG3AP_SET(reg,val) BSP_FLD32SET(reg, val,25, 26)
645
646/* field: REG3ENA - Region 3 enable. */
647#define TMS570_DMA_DMAMPCTRL_REG3ENA BSP_BIT32(24)
648
649/* field: INT2AB - Interrupt assignment of region 2 to Group A or Group B. */
650#define TMS570_DMA_DMAMPCTRL_INT2AB BSP_BIT32(20)
651
652/* field: INT2ENA - Interrupt enable of region 2. */
653#define TMS570_DMA_DMAMPCTRL_INT2ENA BSP_BIT32(19)
654
655/* field: REG2AP - Region 2 access permission. These bits determine the access permission for region 2. */
656#define TMS570_DMA_DMAMPCTRL_REG2AP(val) BSP_FLD32(val,17, 18)
657#define TMS570_DMA_DMAMPCTRL_REG2AP_GET(reg) BSP_FLD32GET(reg,17, 18)
658#define TMS570_DMA_DMAMPCTRL_REG2AP_SET(reg,val) BSP_FLD32SET(reg, val,17, 18)
659
660/* field: REG2ENA - Region 2 enable. */
661#define TMS570_DMA_DMAMPCTRL_REG2ENA BSP_BIT32(16)
662
663/* field: INT1AB - Interrupt assignment of region 1 to Group A or Group B. */
664#define TMS570_DMA_DMAMPCTRL_INT1AB BSP_BIT32(12)
665
666/* field: INT1ENA - Interrupt enable of region 1. */
667#define TMS570_DMA_DMAMPCTRL_INT1ENA BSP_BIT32(11)
668
669/* field: REG1AP - Region 1 access permission. */
670#define TMS570_DMA_DMAMPCTRL_REG1AP(val) BSP_FLD32(val,9, 10)
671#define TMS570_DMA_DMAMPCTRL_REG1AP_GET(reg) BSP_FLD32GET(reg,9, 10)
672#define TMS570_DMA_DMAMPCTRL_REG1AP_SET(reg,val) BSP_FLD32SET(reg, val,9, 10)
673
674/* field: REG1ENA - Region 1 enable. */
675#define TMS570_DMA_DMAMPCTRL_REG1ENA BSP_BIT32(8)
676
677/* field: INT0AB - Interrupt assignment of region 0 to Group A or Group B. */
678#define TMS570_DMA_DMAMPCTRL_INT0AB BSP_BIT32(4)
679
680/* field: INT0ENA - Interrupt enable of region 0. */
681#define TMS570_DMA_DMAMPCTRL_INT0ENA BSP_BIT32(3)
682
683/* field: REG0AP - Region 0 access permission. These bits determine the access permission for region 0. */
684#define TMS570_DMA_DMAMPCTRL_REG0AP(val) BSP_FLD32(val,1, 2)
685#define TMS570_DMA_DMAMPCTRL_REG0AP_GET(reg) BSP_FLD32GET(reg,1, 2)
686#define TMS570_DMA_DMAMPCTRL_REG0AP_SET(reg,val) BSP_FLD32SET(reg, val,1, 2)
687
688/* field: REG0ENA - Region 0 enable. */
689#define TMS570_DMA_DMAMPCTRL_REG0ENA BSP_BIT32(0)
690
691
692/*---------------------TMS570_DMA_DMAMPST---------------------*/
693/* field: REG3FT - Region 3 fault. */
694#define TMS570_DMA_DMAMPST_REG3FT BSP_BIT32(24)
695
696/* field: REG2FT - Region 2 fault. */
697#define TMS570_DMA_DMAMPST_REG2FT BSP_BIT32(16)
698
699/* field: REG1FT - Region 1 fault. */
700#define TMS570_DMA_DMAMPST_REG1FT BSP_BIT32(8)
701
702/* field: REG0FT - Region 0 fault. */
703#define TMS570_DMA_DMAMPST_REG0FT BSP_BIT32(0)
704
705
706/*--------------------TMS570_DMA_DMAMPROS--------------------*/
707/* field: STARTADDRESS - Start Address defines the address at which the region begins. */
708/* Whole 32 bits */
709
710
711#endif /* LIBBSP_ARM_TMS570_DMA */
Utility macros.
Definition: reg_dma.h:49
Definition: reg_dma.h:44
