RTEMS 5.2-rc1
reg_crc.h
1/* The header file is generated by make_header.py from CRC.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_CRC
40#define LIBBSP_ARM_TMS570_CRC
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t CTRL0; /*CRC Global Control Register*/
46 uint8_t reserved1 [4];
47 uint32_t CTRL1; /*CRC Global Control Register 1*/
48 uint8_t reserved2 [4];
49 uint32_t CTRL2; /*CRC Global Control Register 2*/
50 uint8_t reserved3 [4];
51 uint32_t INTS; /*CRC Interrupt Enable Set Register*/
52 uint8_t reserved4 [4];
53 uint32_t INTR; /*CRC Interrupt Enable Reset Register*/
54 uint8_t reserved5 [4];
55 uint32_t STATUS; /*CRC Interrupt Status Register*/
56 uint8_t reserved6 [4];
57 uint32_t INT_OFFS_REG; /*CRC Interrupt Offset Register*/
58 uint8_t reserved7 [4];
59 uint32_t BUSY; /*CRC Busy Register*/
60 uint8_t reserved8 [4];
61 uint32_t PCOUNT_REG1; /*CRC Channel 1 Pattern Counter Preload Register*/
62 uint32_t SCOUNT_REG1; /*CRC Channel 1 Sector Counter Preload Register*/
63 uint32_t CURSEC_REG1; /*CRC Channel 1 Current Sector Register*/
64 uint32_t WDTOPLD1; /*CRC Channel 1 Watchdog Timeout Preload Register*/
65 uint32_t BCTOPLD1; /*CRC Channel 1 Block Complete Timeout Preload Register*/
66 uint8_t reserved9 [12];
67 uint32_t PSA_SIGREGL1; /*Channel 1 PSA Signature Low Register*/
68 uint32_t PSA_SIGREGH1; /*Channel 1 PSA Signature High Register*/
69 uint32_t REGL1; /*Channel 1 CRC Value Low Register*/
70 uint32_t REGH1; /*Channel 1 CRC Value High Register*/
71 uint32_t PSA_SECSIGREGL1; /*Channel 1 PSA Sector Signature Low Register*/
72 uint32_t PSA_SECSIGREGH1; /*Channel 1 PSA Sector Signature High Register*/
73 uint32_t RAW_DATAREGL1; /*Channel 1 Raw Data Low Register*/
74 uint32_t RAW_DATAREGH1; /*Channel 1 Raw Data High Register*/
75 uint32_t PCOUNT_REG2; /*CRC Channel 2 Pattern Counter Preload Register*/
76 uint32_t SCOUNT_REG2; /*CRC Channel 2 Sector Counter Preload Register*/
77 uint32_t CURSEC_REG2; /*CRC Current Sector Register 2*/
78 uint32_t WDTOPLD2; /*CRC Channel 2 Watchdog Timeout Preload Register A*/
79 uint32_t BCTOPLD2; /*CRC Channel 2 Block Complete Timeout Preload Register B*/
80 uint8_t reserved10 [12];
81 uint32_t PSA_SIGREGL2; /*Channel 2 PSA Signature Low Register*/
82 uint32_t PSA_SIGREGH2; /*Channel 2 PSA Signature High Register*/
83 uint32_t REGL2; /*Channel 2 CRC Value Low Register*/
84 uint32_t REGH2; /*Channel 2 CRC Value High Register*/
85 uint32_t PSA_SECSIGREGL2; /*Channel 2 PSA Sector Signature Low Register*/
86 uint32_t PSA_SECSIGREGH2; /*Channel 2 PSA Sector Signature High Register*/
87 uint32_t RAW_DATAREGL2; /*Channel 2 Raw Data Low Register*/
88 uint32_t RAW_DATAREGH2; /*Channel 2 Raw Data High Register*/
89 uint8_t reserved11 [128];
90 uint32_t BUS_SEL; /*Data Bus Selection Register*/
92
93
94/*----------------------TMS570_CRC_CTRL0----------------------*/
95/* field: CH2_PSA_SWREST - Channel 2 PSA Software Reset. When set, the PSA Signature Register is reset to all zero. */
96#define TMS570_CRC_CTRL0_CH2_PSA_SWREST BSP_BIT32(8)
97
98/* field: CH1_PSA_SWREST - Channel 1 PSA Software Reset. When set, the PSA Signature Register is reset to all zero. */
99#define TMS570_CRC_CTRL0_CH1_PSA_SWREST BSP_BIT32(0)
100
101
102/*----------------------TMS570_CRC_CTRL1----------------------*/
103/* field: PWDN - Power Down. */
104#define TMS570_CRC_CTRL1_PWDN BSP_BIT32(0)
105
106
107/*----------------------TMS570_CRC_CTRL2----------------------*/
108/* field: CH2_MODE - Channel 2 Mode Selection */
109#define TMS570_CRC_CTRL2_CH2_MODE(val) BSP_FLD32(val,8, 9)
110#define TMS570_CRC_CTRL2_CH2_MODE_GET(reg) BSP_FLD32GET(reg,8, 9)
111#define TMS570_CRC_CTRL2_CH2_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
112
113/* field: CH1_TRACEEN - Channel 1 Data Trace Enable. When set, the channel is put into data trace mode. */
114#define TMS570_CRC_CTRL2_CH1_TRACEEN BSP_BIT32(4)
115
116/* field: CH1_MODE - Channel 1 Mode Selection */
117#define TMS570_CRC_CTRL2_CH1_MODE(val) BSP_FLD32(val,0, 1)
118#define TMS570_CRC_CTRL2_CH1_MODE_GET(reg) BSP_FLD32GET(reg,0, 1)
119#define TMS570_CRC_CTRL2_CH1_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
120
121
122/*----------------------TMS570_CRC_INTS----------------------*/
123/* field: CH2_TIMEOUTENS - Channel 2 Timeout Interrupt Enable Bit. */
124#define TMS570_CRC_INTS_CH2_TIMEOUTENS BSP_BIT32(12)
125
126/* field: CH2_UNDERENS - Channel 2 Underrun Interrupt Enable Bit. */
127#define TMS570_CRC_INTS_CH2_UNDERENS BSP_BIT32(11)
128
129/* field: CH2_OVERENS - Channel 2 Overrun Interrupt Enable Bit. */
130#define TMS570_CRC_INTS_CH2_OVERENS BSP_BIT32(10)
131
132/* field: CH2_CRCFAILENS - Channel 2 CRC Fail Interrupt Enable Bit. */
133#define TMS570_CRC_INTS_CH2_CRCFAILENS BSP_BIT32(9)
134
135/* field: CH2_CCITENS - Channel 2 Compression Complete Interrupt Enable Bit. */
136#define TMS570_CRC_INTS_CH2_CCITENS BSP_BIT32(8)
137
138/* field: CH1_TIMEOUTENS - Channel 1 Timeout Interrupt Enable Bit. */
139#define TMS570_CRC_INTS_CH1_TIMEOUTENS BSP_BIT32(4)
140
141/* field: CH1_UNDERENS - Channel 1 Underrun Interrupt Enable Bit. */
142#define TMS570_CRC_INTS_CH1_UNDERENS BSP_BIT32(3)
143
144/* field: CH1_OVERENS - CH1_OVERENS Channel 1 Overrun Interrupt Enable Bit. */
145#define TMS570_CRC_INTS_CH1_OVERENS BSP_BIT32(2)
146
147/* field: CH1_CRCFAILENS - Channel 1 CRC Fail Interrupt Enable Bit. */
148#define TMS570_CRC_INTS_CH1_CRCFAILENS BSP_BIT32(1)
149
150/* field: CH1_CCITENS - Channel 1 Compression Complete Interrupt Enable Bit. */
151#define TMS570_CRC_INTS_CH1_CCITENS BSP_BIT32(0)
152
153
154/*----------------------TMS570_CRC_INTR----------------------*/
155/* field: CH2_TIMEOUTENR - Channel 2 Timeout Interrupt Enable Bit. */
156#define TMS570_CRC_INTR_CH2_TIMEOUTENR BSP_BIT32(12)
157
158/* field: CH2_UNDERENR - Channel 2 Underrun Interrupt Enable Bit. */
159#define TMS570_CRC_INTR_CH2_UNDERENR BSP_BIT32(11)
160
161/* field: CH2_OVERENR - Channel 2 Overrun Interrupt Enable Bit. */
162#define TMS570_CRC_INTR_CH2_OVERENR BSP_BIT32(10)
163
164/* field: CH2_CRCFAILENR - Channel 2 CRC Fail Interrupt Enable Bit. */
165#define TMS570_CRC_INTR_CH2_CRCFAILENR BSP_BIT32(9)
166
167/* field: CH2_CCITENR - Channel 2 Compression Complete Interrupt Enable Bit. */
168#define TMS570_CRC_INTR_CH2_CCITENR BSP_BIT32(8)
169
170/* field: CH1_TIMEOUTENR - Channel 1 Timeout Interrupt Enable Bit. */
171#define TMS570_CRC_INTR_CH1_TIMEOUTENR BSP_BIT32(4)
172
173/* field: CH1_UNDERENR - interrupt. Writing a zero has no effect. */
174#define TMS570_CRC_INTR_CH1_UNDERENR BSP_BIT32(3)
175
176/* field: CH1_OVERENR - CH1_OVERENR */
177#define TMS570_CRC_INTR_CH1_OVERENR BSP_BIT32(2)
178
179/* field: CH1_CRCFAILENR - Channel 1 CRC Fail Interrupt Enable Bit. */
180#define TMS570_CRC_INTR_CH1_CRCFAILENR BSP_BIT32(1)
181
182/* field: CH1_CCITENR - Channel 1 Compression Complete Interrupt Enable Bit. */
183#define TMS570_CRC_INTR_CH1_CCITENR BSP_BIT32(0)
184
185
186/*---------------------TMS570_CRC_STATUS---------------------*/
187/* field: CH2_TIMEOUT - Channel 2 CRC Timeout Status Flag. This bit is cleared by writing a '1' to it only. */
188#define TMS570_CRC_STATUS_CH2_TIMEOUT BSP_BIT32(12)
189
190/* field: CH2_UNDER - Channel 2 CRC Underrun Status Flag. This bit is cleared by writing a '1' to it only. */
191#define TMS570_CRC_STATUS_CH2_UNDER BSP_BIT32(11)
192
193/* field: CH2_OVER - Channel 2 CRC Overrun Status Flag. This bit is cleared by writing a '1' to it only. */
194#define TMS570_CRC_STATUS_CH2_OVER BSP_BIT32(10)
195
196/* field: CH2_CRCFAIL - Channel 2 CRC Compare Fail Status Flag. This bit is cleared by writing a '1' to it only. */
197#define TMS570_CRC_STATUS_CH2_CRCFAIL BSP_BIT32(9)
198
199/* field: CH2_CCIT - Channel 2 CRC Pattern Compression Complete Status Flag. */
200#define TMS570_CRC_STATUS_CH2_CCIT BSP_BIT32(8)
201
202/* field: CH1_TIMEOUT - Writing a zero has no effect. Reading from this bit gives the status (interrupt enable/disable). */
203#define TMS570_CRC_STATUS_CH1_TIMEOUT BSP_BIT32(4)
204
205/* field: CH1_UNDER - Channel 1 Underrun Interrupt Enable Bit. */
206#define TMS570_CRC_STATUS_CH1_UNDER BSP_BIT32(3)
207
208/* field: CH1_OVER - Channel 1 Overrun Interrupt Enable Bit. Writing a one to this bit disable the overrun interrupt. */
209#define TMS570_CRC_STATUS_CH1_OVER BSP_BIT32(2)
210
211/* field: CH1_CRCFAIL - Channel 1 CRC Fail Interrupt Enable Bit. */
212#define TMS570_CRC_STATUS_CH1_CRCFAIL BSP_BIT32(1)
213
214/* field: CH1_CCIT - Channel 1 CRC Pattern Compression Complete Status Flag. */
215#define TMS570_CRC_STATUS_CH1_CCIT BSP_BIT32(0)
216
217
218/*------------------TMS570_CRC_INT_OFFS_REG------------------*/
219/* field: OFSTREG - CRC Interrupt Offset. This register indicates the highest priority pending interrupt vector address. */
220#define TMS570_CRC_INT_OFFS_REG_OFSTREG(val) BSP_FLD32(val,0, 7)
221#define TMS570_CRC_INT_OFFS_REG_OFSTREG_GET(reg) BSP_FLD32GET(reg,0, 7)
222#define TMS570_CRC_INT_OFFS_REG_OFSTREG_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
223
224
225/*----------------------TMS570_CRC_BUSY----------------------*/
226/* field: CH2_BUSY - CH2_BUSY. */
227#define TMS570_CRC_BUSY_CH2_BUSY BSP_BIT32(8)
228
229/* field: CH1_BUSY - CH1_BUSY. */
230#define TMS570_CRC_BUSY_CH1_BUSY BSP_BIT32(0)
231
232
233/*-------------------TMS570_CRC_PCOUNT_REG1-------------------*/
234/* field: CRC_PAT_COUNT1 - Channel 1 Pattern Counter Preload Register. */
235#define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1(val) BSP_FLD32(val,0, 19)
236#define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
237#define TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
238
239
240/*-------------------TMS570_CRC_SCOUNT_REG1-------------------*/
241/* field: CRC_SEC_COUNT1 - Channel 1 Sector Counter Preload Register. */
242#define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1(val) BSP_FLD32(val,0, 15)
243#define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 15)
244#define TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
245
246
247/*-------------------TMS570_CRC_CURSEC_REG1-------------------*/
248/* field: CRC_CURSEC1 - Channel 1 Current Sector ID Register. */
249#define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1(val) BSP_FLD32(val,0, 15)
250#define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_GET(reg) BSP_FLD32GET(reg,0, 15)
251#define TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
252
253
254/*--------------------TMS570_CRC_WDTOPLD1--------------------*/
255/* field: CRC_WDTOPLD1 - CRC_WDTOPLD1 */
256#define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1(val) BSP_FLD32(val,0, 23)
257#define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23)
258#define TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
259
260
261/*--------------------TMS570_CRC_BCTOPLD1--------------------*/
262/* field: CRC_BCTOPLD1 - Channel 1 Block Complete Timeout Counter Preload Register. */
263#define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1(val) BSP_FLD32(val,0, 23)
264#define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23)
265#define TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
266
267
268/*------------------TMS570_CRC_PSA_SIGREGL1------------------*/
269/* field: PSASIG1 - Channel 1 PSA Signature Low Register. */
270/* Whole 32 bits */
271
272/*------------------TMS570_CRC_PSA_SIGREGH1------------------*/
273/* field: PSASIG1 - register. */
274/* Whole 32 bits */
275
276/*----------------------TMS570_CRC_REGL1----------------------*/
277/* field: CRC1 - Channel 1 CRC Value Low Register. */
278/* Whole 32 bits */
279
280/*----------------------TMS570_CRC_REGH1----------------------*/
281/* field: CRC1 - Channel 1 CRC Value Low Register. */
282/* Whole 32 bits */
283
284/*-----------------TMS570_CRC_PSA_SECSIGREGL1-----------------*/
285/* field: PSASECSIG1 - Channel 1 PSA Sector Signature Low Register. */
286/* Whole 32 bits */
287
288/*-----------------TMS570_CRC_PSA_SECSIGREGH1-----------------*/
289/* field: PSASECSIG1 - Channel 1 PSA Sector Signature High Register. */
290/* Whole 32 bits */
291
292/*------------------TMS570_CRC_RAW_DATAREGL1------------------*/
293/* field: RAW_DATA1 - hannel 1 Raw Data Low Register.This register contains bits 31:0 of the uncompressed raw data. */
294/* Whole 32 bits */
295
296/*------------------TMS570_CRC_RAW_DATAREGH1------------------*/
297/* field: RAW_DATA1 - Channel 1 Raw Data High Register. This register contains bits 63:32 of the uncompressed raw data. */
298/* Whole 32 bits */
299
300/*-------------------TMS570_CRC_PCOUNT_REG2-------------------*/
301/* field: CRC_PAT_COUNT2 - Channel 2 Pattern Counter Preload Register. */
302#define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2(val) BSP_FLD32(val,0, 19)
303#define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 19)
304#define TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
305
306
307/*-------------------TMS570_CRC_SCOUNT_REG2-------------------*/
308/* field: CRC_SEC_COUNT2 - Channel 2 Sector Counter Preload Register. */
309#define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2(val) BSP_FLD32(val,0, 15)
310#define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 15)
311#define TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
312
313
314/*-------------------TMS570_CRC_CURSEC_REG2-------------------*/
315/* field: CRC_CURSEC2 - Channel 2 Current Sector ID Register. */
316#define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2(val) BSP_FLD32(val,0, 15)
317#define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_GET(reg) BSP_FLD32GET(reg,0, 15)
318#define TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
319
320
321/*--------------------TMS570_CRC_WDTOPLD2--------------------*/
322/* field: CRC_WDTOPLD2 - Channel 2 Watchdog Timeout Counter Preload Register. */
323#define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2(val) BSP_FLD32(val,0, 23)
324#define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23)
325#define TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
326
327
328/*--------------------TMS570_CRC_BCTOPLD2--------------------*/
329/* field: CRC_BCTOPLD2 - Channel 2 Block Complete Timeout Counter Preload Register. */
330#define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2(val) BSP_FLD32(val,0, 23)
331#define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23)
332#define TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
333
334
335/*------------------TMS570_CRC_PSA_SIGREGL2------------------*/
336/* field: PSASIG2 - Channel 2 PSA Signature Low Register. */
337/* Whole 32 bits */
338
339/*------------------TMS570_CRC_PSA_SIGREGH2------------------*/
340/* field: PSASIG2 - Channel 2 PSA Signature High Register. */
341/* Whole 32 bits */
342
343/*----------------------TMS570_CRC_REGL2----------------------*/
344/* field: CRC2 - stored at CRC2[31:0] register. */
345/* Whole 32 bits */
346
347/*----------------------TMS570_CRC_REGH2----------------------*/
348/* field: CRC2 - Channel 2 CRC Value High Register. */
349/* Whole 32 bits */
350
351/*-----------------TMS570_CRC_PSA_SECSIGREGL2-----------------*/
352/* field: PSASECSIG2 - Channel 2 PSA Sector Signature Low Register. */
353/* Whole 32 bits */
354
355/*-----------------TMS570_CRC_PSA_SECSIGREGH2-----------------*/
356/* field: PSASECSIG2 - Channel 2 PSA Sector Signature High Register. */
357/* Whole 32 bits */
358
359/*------------------TMS570_CRC_RAW_DATAREGL2------------------*/
360/* field: RAW_DATA2 - Channel 2 Raw Data Low Register. This register contains bits 31:0 of the uncompressed raw data.. */
361/* Whole 32 bits */
362
363/*------------------TMS570_CRC_RAW_DATAREGH2------------------*/
364/* field: RAW_DATA2 - Channel 2 Raw Data High Register. This register contains bits 63:32 of the uncompressed raw data.. */
365/* Whole 32 bits */
366
367/*---------------------TMS570_CRC_BUS_SEL---------------------*/
368/* field: MEn - Enable/disables the tracing of Peripheral Bus Master */
369#define TMS570_CRC_BUS_SEL_MEn BSP_BIT32(2)
370
371/* field: DTCMEn - Enable/disables the tracing of data TCM */
372#define TMS570_CRC_BUS_SEL_DTCMEn BSP_BIT32(1)
373
374/* field: ITCMEn - Enable/disables the tracing of instruction TCM */
375#define TMS570_CRC_BUS_SEL_ITCMEn BSP_BIT32(0)
376
377
378
379#endif /* LIBBSP_ARM_TMS570_CRC */
Utility macros.
Definition: reg_crc.h:44
