RTEMS 5.2-rc1
qreslib.h
1
13/*
14 * Copyright (C) 2011 Petr Benes.
15 * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef CONFIGURE_SCHEDULER_CBS
23 #error "qreslib.h available only with CONFIGURE_SCHEDULER_CBS"
24#endif
25
26#ifndef _QRESLIB_H
27#define _QRESLIB_H
28
29#ifdef __cplusplus
30extern "C" {
31#endif
32
33#include <stdint.h>
35
37typedef int qos_rv;
38
39/* Return codes. */
40#define QOS_OK SCHEDULER_CBS_OK
41#define QOS_E_GENERIC SCHEDULER_CBS_ERROR_GENERIC
42#define QOS_E_NO_MEMORY SCHEDULER_CBS_ERROR_NO_MEMORY
43#define QOS_E_INVALID_PARAM SCHEDULER_CBS_ERROR_INVALID_PARAMETER
44#define QOS_E_UNAUTHORIZED SCHEDULER_CBS_ERROR_UNAUTHORIZED
45#define QOS_E_UNIMPLEMENTED SCHEDULER_CBS_ERROR_UNIMPLEMENTED
46#define QOS_E_MISSING_COMPONENT SCHEDULER_CBS_ERROR_MISSING_COMPONENT
47#define QOS_E_INCONSISTENT_STATE SCHEDULER_CBS_ERROR_INCONSISTENT_STATE
48#define QOS_E_SYSTEM_OVERLOAD SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD
49#define QOS_E_INTERNAL_ERROR SCHEDULER_CBS_ERROR_INTERNAL_ERROR
50#define QOS_E_NOT_FOUND SCHEDULER_CBS_ERROR_NOT_FOUND
51#define QOS_E_FULL SCHEDULER_CBS_ERROR_FULL
52#define QOS_E_EMPTY SCHEDULER_CBS_ERROR_EMPTY
53#define QOS_E_NOSERVER SCHEDULER_CBS_ERROR_NOSERVER
54
57
60
62typedef time_t qres_time_t;
63
65typedef time_t qres_atime_t;
66
68typedef struct {
74
83{
85}
86
95{
97}
98
107 qres_params_t *params,
108 qres_sid_t *server_id
109)
110{
112 (Scheduler_CBS_Parameters *) params,
113 NULL,
114 server_id
115 );
116}
117
126 qres_sid_t server_id,
127 pid_t pid,
128 tid_t task_id
129)
130{
131 return _Scheduler_CBS_Attach_thread( server_id, task_id );
132}
133
142 qres_sid_t server_id,
143 pid_t pid,
144 tid_t task_id
145)
146{
147 return _Scheduler_CBS_Detach_thread( server_id, task_id );
148}
149
158 qres_sid_t server_id
159)
160{
161 return _Scheduler_CBS_Destroy_server( server_id );
162}
163
173 pid_t pid,
174 tid_t task_id,
175 qres_sid_t *server_id
176)
177{
178 return _Scheduler_CBS_Get_server_id( task_id, server_id );
179}
180
189 qres_sid_t server_id,
190 qres_params_t *params
191)
192{
194 server_id,
195 (Scheduler_CBS_Parameters *) params
196 );
197}
198
207 qres_sid_t server_id,
208 qres_params_t *params
209)
210{
212 server_id,
213 (Scheduler_CBS_Parameters *) params
214 );
215}
216
225 qres_sid_t server_id,
226 qres_time_t *exec_time,
227 qres_atime_t *abs_time
228)
229{
230 return _Scheduler_CBS_Get_execution_time( server_id, exec_time, abs_time );
231}
232
241 qres_sid_t server_id,
242 qres_time_t *current_budget
243)
244{
245 return _Scheduler_CBS_Get_remaining_budget( server_id, current_budget );
246}
247
257 qres_sid_t server_id,
258 qres_time_t *appr_budget
259)
260{
261 return _Scheduler_CBS_Get_approved_budget( server_id, appr_budget );
262}
263
264#ifdef __cplusplus
265}
266#endif
267
268#endif
269/* end of include file */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
int _Scheduler_CBS_Get_server_id(rtems_id task_id, Scheduler_CBS_Server_id *server_id)
Gets a thread server id.
Definition: schedulercbsgetserverid.c:25
int _Scheduler_CBS_Create_server(Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
Creates a new server with specified parameters.
Definition: schedulercbscreateserver.c:24
int _Scheduler_CBS_Cleanup(void)
Cleans up resources associated to the CBS Library.
Definition: schedulercbscleanup.c:24
int _Scheduler_CBS_Get_remaining_budget(Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
Retrieves remaining budget for the current server instance.
Definition: schedulercbsgetremainingbudget.c:24
int _Scheduler_CBS_Get_approved_budget(Scheduler_CBS_Server_id server_id, time_t *approved_budget)
Retrieves the approved budget.
Definition: schedulercbsgetapprovedbudget.c:25
int _Scheduler_CBS_Detach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Detaches from the CBS Server.
Definition: schedulercbsdetachthread.c:25
int _Scheduler_CBS_Destroy_server(Scheduler_CBS_Server_id server_id)
Detaches all tasks from a server and destroys it.
Definition: schedulercbsdestroyserver.c:25
int _Scheduler_CBS_Get_execution_time(Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
Gets relative time info.
Definition: schedulercbsgetexecutiontime.c:25
int _Scheduler_CBS_Attach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Attaches a task to an already existing server.
Definition: schedulercbsattachthread.c:24
int _Scheduler_CBS_Initialize(void)
Definition: schedulercbs.c:54
int _Scheduler_CBS_Get_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
Retrieves CBS scheduling parameters.
Definition: schedulercbsgetparameters.c:26
uint32_t Scheduler_CBS_Server_id
Definition: schedulercbs.h:95
int _Scheduler_CBS_Set_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
Sets parameters for CBS scheduling.
Definition: schedulercbssetparameters.c:25
Scheduler_CBS_Server_id qres_sid_t
Definition: qreslib.h:56
RTEMS_INLINE_ROUTINE qos_rv qres_get_appr_budget(qres_sid_t server_id, qres_time_t *appr_budget)
qres get approved budget
Definition: qreslib.h:256
RTEMS_INLINE_ROUTINE qos_rv qres_get_exec_time(qres_sid_t server_id, qres_time_t *exec_time, qres_atime_t *abs_time)
qres get execution time
Definition: qreslib.h:224
RTEMS_INLINE_ROUTINE qos_rv qres_detach_thread(qres_sid_t server_id, pid_t pid, tid_t task_id)
qres detach thread
Definition: qreslib.h:141
int qos_rv
Definition: qreslib.h:37
time_t qres_time_t
Definition: qreslib.h:62
RTEMS_INLINE_ROUTINE qos_rv qres_destroy_server(qres_sid_t server_id)
qres destroy server
Definition: qreslib.h:157
RTEMS_INLINE_ROUTINE qos_rv qres_get_curr_budget(qres_sid_t server_id, qres_time_t *current_budget)
qres get current budget
Definition: qreslib.h:240
RTEMS_INLINE_ROUTINE qos_rv qres_set_params(qres_sid_t server_id, qres_params_t *params)
qres set params
Definition: qreslib.h:206
time_t qres_atime_t
Definition: qreslib.h:65
RTEMS_INLINE_ROUTINE qos_rv qres_cleanup(void)
qres cleanup
Definition: qreslib.h:94
rtems_id tid_t
Definition: qreslib.h:59
RTEMS_INLINE_ROUTINE qos_rv qres_attach_thread(qres_sid_t server_id, pid_t pid, tid_t task_id)
qres attach thread
Definition: qreslib.h:125
RTEMS_INLINE_ROUTINE qos_rv qres_create_server(qres_params_t *params, qres_sid_t *server_id)
qres create server
Definition: qreslib.h:106
RTEMS_INLINE_ROUTINE qos_rv qres_get_sid(pid_t pid, tid_t task_id, qres_sid_t *server_id)
qres get server id
Definition: qreslib.h:172
RTEMS_INLINE_ROUTINE qos_rv qres_init(void)
qres init
Definition: qreslib.h:82
RTEMS_INLINE_ROUTINE qos_rv qres_get_params(qres_sid_t server_id, qres_params_t *params)
qres get params
Definition: qreslib.h:188
Thread manipulation for the CBS scheduler.
Definition: schedulercbs.h:105
Definition: qreslib.h:68
qres_time_t Q
Definition: qreslib.h:72
qres_time_t P
Definition: qreslib.h:70
