RTEMS 5.2-rc1
powerpc-utility.h
1
10/*
11 * Copyright (c) 2008-2015 embedded brains GmbH.
12 *
13 * embedded brains GmbH
14 * Dornierstr. 4
15 * 82178 Puchheim
16 * Germany
17 * <rtems@embedded-brains.de>
18 *
19 * access function for Device Control Registers inspired by "ppc405common.h"
20 * from Michael Hamel ADInstruments May 2008
21 *
22 * The license and distribution terms for this file may be
23 * found in the file LICENSE in this distribution or at
24 * http://www.rtems.org/license/LICENSE.
25 */
26
37#ifndef __LIBCPU_POWERPC_UTILITY_H
38#define __LIBCPU_POWERPC_UTILITY_H
39
40#if !defined(ASM)
41 #include <rtems.h>
42#endif
43
44#include <rtems/score/cpu.h>
47
48#ifdef __cplusplus
49extern "C" {
50#endif
51
52#if !defined(ASM)
53
54#include <rtems/bspIo.h>
55
56#include <libcpu/cpuIdent.h>
57
58#define LINKER_SYMBOL(sym) extern char sym [];
59
63static inline uint8_t ppc_read_byte(const volatile void *src)
64{
65 uint8_t value;
66
67 __asm__ volatile (
68 "lbz %0, 0(%1)"
69 : "=r" (value)
70 : "b" (src)
71 );
72
73 return value;
74}
75
79static inline uint16_t ppc_read_half_word(const volatile void *src)
80{
81 uint16_t value;
82
83 __asm__ volatile (
84 "lhz %0, 0(%1)"
85 : "=r" (value)
86 : "b" (src)
87 );
88
89 return value;
90}
91
95static inline uint32_t ppc_read_word(const volatile void *src)
96{
97 uint32_t value;
98
99 __asm__ volatile (
100 "lwz %0, 0(%1)"
101 : "=r" (value)
102 : "b" (src)
103 );
104
105 return value;
106}
107
111static inline void ppc_write_byte(uint8_t value, volatile void *dest)
112{
113 __asm__ volatile (
114 "stb %0, 0(%1)"
115 :
116 : "r" (value), "b" (dest)
117 );
118}
119
123static inline void ppc_write_half_word(uint16_t value, volatile void *dest)
124{
125 __asm__ volatile (
126 "sth %0, 0(%1)"
127 :
128 : "r" (value), "b" (dest)
129 );
130}
131
135static inline void ppc_write_word(uint32_t value, volatile void *dest)
136{
137 __asm__ volatile (
138 "stw %0, 0(%1)" :
139 : "r" (value), "b" (dest)
140 );
141}
142
143
144static inline void *ppc_stack_pointer(void)
145{
146 void *sp;
147
148 __asm__ volatile (
149 "mr %0, 1"
150 : "=r" (sp)
151 );
152
153 return sp;
154}
155
156static inline void ppc_set_stack_pointer(void *sp)
157{
158 __asm__ volatile (
159 "mr 1, %0"
160 :
161 : "r" (sp)
162 );
163}
164
165static inline void *ppc_link_register(void)
166{
167 void *lr;
168
169 __asm__ volatile (
170 "mflr %0"
171 : "=r" (lr)
172 );
173
174 return lr;
175}
176
177static inline void ppc_set_link_register(void *lr)
178{
179 __asm__ volatile (
180 "mtlr %0"
181 :
182 : "r" (lr)
183 );
184}
185
186static inline uint32_t ppc_machine_state_register(void)
187{
188 uint32_t msr;
189
190 __asm__ volatile (
191 "mfmsr %0"
192 : "=r" (msr)
193 );
194
195 return msr;
196}
197
198static inline void ppc_set_machine_state_register(uint32_t msr)
199{
200 __asm__ volatile (
201 "mtmsr %0"
202 :
203 : "r" (msr)
204 );
205}
206
207static inline void ppc_synchronize_data(void)
208{
210
211 __asm__ volatile ("sync");
212}
213
214static inline void ppc_light_weight_synchronize(void)
215{
217
218 __asm__ volatile ("lwsync");
219}
220
221static inline void ppc_synchronize_instructions(void)
222{
224
225 __asm__ volatile ("isync");
226}
227
228static inline void ppc_enforce_in_order_execution_of_io(void)
229{
231
232 __asm__ volatile ("eieio");
233}
234
235static inline void ppc_data_cache_block_flush(void *addr)
236{
237 __asm__ volatile (
238 "dcbf 0, %0"
239 :
240 : "r" (addr)
241 : "memory"
242 );
243}
244
245static inline void ppc_data_cache_block_flush_2(
246 void *base,
247 uintptr_t offset
248)
249{
250 __asm__ volatile (
251 "dcbf %0, %1"
252 :
253 : "b" (base), "r" (offset)
254 : "memory"
255 );
256}
257
258static inline void ppc_data_cache_block_invalidate(void *addr)
259{
260 __asm__ volatile (
261 "dcbi 0, %0"
262 :
263 : "r" (addr)
264 : "memory"
265 );
266}
267
268static inline void ppc_data_cache_block_invalidate_2(
269 void *base,
270 uintptr_t offset
271)
272{
273 __asm__ volatile (
274 "dcbi %0, %1"
275 :
276 : "b" (base), "r" (offset)
277 : "memory"
278 );
279}
280
281static inline void ppc_data_cache_block_store(const void *addr)
282{
283 __asm__ volatile (
284 "dcbst 0, %0"
285 :
286 : "r" (addr)
287 );
288}
289
290static inline void ppc_data_cache_block_store_2(
291 const void *base,
292 uintptr_t offset
293)
294{
295 __asm__ volatile (
296 "dcbst %0, %1"
297 :
298 : "b" (base), "r" (offset)
299 );
300}
301
302static inline void ppc_data_cache_block_touch(const void *addr)
303{
304 __asm__ volatile (
305 "dcbt 0, %0"
306 :
307 : "r" (addr)
308 );
309}
310
311static inline void ppc_data_cache_block_touch_2(
312 const void *base,
313 uintptr_t offset
314)
315{
316 __asm__ volatile (
317 "dcbt %0, %1"
318 :
319 : "b" (base), "r" (offset)
320 );
321}
322
323static inline void ppc_data_cache_block_touch_for_store(const void *addr)
324{
325 __asm__ volatile (
326 "dcbtst 0, %0"
327 :
328 : "r" (addr)
329 );
330}
331
332static inline void ppc_data_cache_block_touch_for_store_2(
333 const void *base,
334 uintptr_t offset
335)
336{
337 __asm__ volatile (
338 "dcbtst %0, %1"
339 :
340 : "b" (base), "r" (offset)
341 );
342}
343
344static inline void ppc_data_cache_block_clear_to_zero(void *addr)
345{
346 __asm__ volatile (
347 "dcbz 0, %0"
348 :
349 : "r" (addr)
350 : "memory"
351 );
352}
353
354static inline void ppc_data_cache_block_clear_to_zero_2(
355 void *base,
356 uintptr_t offset
357)
358{
359 __asm__ volatile (
360 "dcbz %0, %1"
361 :
362 : "b" (base), "r" (offset)
363 : "memory"
364 );
365}
366
367static inline void ppc_instruction_cache_block_invalidate(void *addr)
368{
369 __asm__ volatile (
370 "icbi 0, %0"
371 :
372 : "r" (addr)
373 );
374}
375
376static inline void ppc_instruction_cache_block_invalidate_2(
377 void *base,
378 uintptr_t offset
379)
380{
381 __asm__ volatile (
382 "icbi %0, %1"
383 :
384 : "b" (base), "r" (offset)
385 );
386}
387
394static inline uint32_t ppc_external_exceptions_enable(void)
395{
396 uint32_t current_msr;
397 uint32_t new_msr;
398
400
401 __asm__ volatile (
402 "mfmsr %0;"
403 "ori %1, %0, 0x8000;"
404 "mtmsr %1"
405 : "=r" (current_msr), "=r" (new_msr)
406 );
407
408 return current_msr;
409}
410
416static inline void ppc_external_exceptions_disable(uint32_t msr)
417{
418 ppc_set_machine_state_register(msr);
419
421}
422
423static inline uint32_t ppc_count_leading_zeros(uint32_t value)
424{
425 uint32_t count;
426
427 __asm__ (
428 "cntlzw %0, %1;"
429 : "=r" (count)
430 : "r" (value)
431 );
432
433 return count;
434}
435
436/*
437 * Simple spin delay in microsecond units for device drivers.
438 * This is very dependent on the clock speed of the target.
439 */
440
441#if defined(mpx8xx) || defined(mpc860) || defined(mpc821)
442/* Wonderful bookE doesn't have mftb/mftbu; they only
443 * define the TBRU/TBRL SPRs so we use these. Luckily,
444 * we run in supervisory mode so that should work on
445 * all CPUs. In user mode we'd have a problem...
446 * 2007/11/30, T.S.
447 *
448 * OTOH, PSIM currently lacks support for reading
449 * SPRs 268/269. You need GDB patch sim/2376 to avoid
450 * a crash...
451 * OTOH, the MPC8xx do not allow to read the timebase registers via mfspr.
452 * we NEED a mftb to access the time base.
453 * 2009/10/30 Th. D.
454 */
455#define CPU_Get_timebase_low( _value ) \
456 __asm__ volatile( "mftb %0" : "=r" (_value) )
457#else
458#define CPU_Get_timebase_low( _value ) \
459 __asm__ volatile( "mfspr %0,268" : "=r" (_value) )
460#endif
461
462/* Must be provided for rtems_bsp_delay to work */
463extern uint32_t bsp_clicks_per_usec;
464
465#define rtems_bsp_delay( _microseconds ) \
466 do { \
467 uint32_t start, ticks, now; \
468 CPU_Get_timebase_low( start ) ; \
469 ticks = (_microseconds) * bsp_clicks_per_usec; \
470 do \
471 CPU_Get_timebase_low( now ) ; \
472 while (now - start < ticks); \
473 } while (0)
474
475#define rtems_bsp_delay_in_bus_cycles( _cycles ) \
476 do { \
477 uint32_t start, now; \
478 CPU_Get_timebase_low( start ); \
479 do \
480 CPU_Get_timebase_low( now ); \
481 while (now - start < (_cycles)); \
482 } while (0)
483
484/*
485 * Routines to access the decrementer register
486 */
487
488#define PPC_Set_decrementer( _clicks ) \
489 do { \
490 __asm__ volatile( "mtdec %0" : : "r" ((_clicks)) ); \
491 } while (0)
492
493#define PPC_Get_decrementer( _clicks ) \
494 __asm__ volatile( "mfdec %0" : "=r" (_clicks) )
495
496/*
497 * Routines to access the time base register
498 */
499
500static inline uint64_t PPC_Get_timebase_register( void )
501{
502 uint32_t tbr_low;
503 uint32_t tbr_high;
504 uint32_t tbr_high_old;
505 uint64_t tbr;
506
507 do {
508#if defined(mpx8xx) || defined(mpc860) || defined(mpc821)
509/* See comment above (CPU_Get_timebase_low) */
510 __asm__ volatile( "mftbu %0" : "=r" (tbr_high_old));
511 __asm__ volatile( "mftb %0" : "=r" (tbr_low));
512 __asm__ volatile( "mftbu %0" : "=r" (tbr_high));
513#else
514 __asm__ volatile( "mfspr %0, 269" : "=r" (tbr_high_old));
515 __asm__ volatile( "mfspr %0, 268" : "=r" (tbr_low));
516 __asm__ volatile( "mfspr %0, 269" : "=r" (tbr_high));
517#endif
518 } while ( tbr_high_old != tbr_high );
519
520 tbr = tbr_high;
521 tbr <<= 32;
522 tbr |= tbr_low;
523 return tbr;
524}
525
526static inline void PPC_Set_timebase_register (uint64_t tbr)
527{
528 uint32_t tbr_low;
529 uint32_t tbr_high;
530
531 tbr_low = (uint32_t) tbr;
532 tbr_high = (uint32_t) (tbr >> 32);
533 __asm__ volatile( "mtspr 284, %0" : : "r" (tbr_low));
534 __asm__ volatile( "mtspr 285, %0" : : "r" (tbr_high));
535
536}
537
538static inline uint32_t ppc_decrementer_register(void)
539{
540 uint32_t dec;
541
542 PPC_Get_decrementer(dec);
543
544 return dec;
545}
546
547static inline void ppc_set_decrementer_register(uint32_t dec)
548{
549 PPC_Set_decrementer(dec);
550}
551
555#define PPC_STRINGOF(x) #x
556
562#define PPC_SPECIAL_PURPOSE_REGISTER(spr) \
563 ({ \
564 uint32_t val; \
565 __asm__ volatile (\
566 "mfspr %0, " PPC_STRINGOF(spr) \
567 : "=r" (val) \
568 ); \
569 val;\
570 } )
571
576#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val) \
577 do { \
578 __asm__ volatile (\
579 "mtspr " PPC_STRINGOF(spr) ", %0" \
580 : \
581 : "r" (val) \
582 ); \
583 } while (0)
584
591#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits) \
592 do { \
593 ISR_Level level; \
594 uint32_t val; \
595 uint32_t mybits = bits; \
596 _ISR_Local_disable(level); \
597 val = PPC_SPECIAL_PURPOSE_REGISTER(spr); \
598 val |= mybits; \
599 PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
600 _ISR_Local_enable(level); \
601 } while (0)
602
610#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED(spr, bits, mask) \
611 do { \
612 ISR_Level level; \
613 uint32_t val; \
614 uint32_t mybits = bits; \
615 uint32_t mymask = mask; \
616 _ISR_Local_disable(level); \
617 val = PPC_SPECIAL_PURPOSE_REGISTER(spr); \
618 val &= ~mymask; \
619 val |= mybits; \
620 PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
621 _ISR_Local_enable(level); \
622 } while (0)
623
630#define PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits) \
631 do { \
632 ISR_Level level; \
633 uint32_t val; \
634 uint32_t mybits = bits; \
635 _ISR_Local_disable(level); \
636 val = PPC_SPECIAL_PURPOSE_REGISTER(spr); \
637 val &= ~mybits; \
638 PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
639 _ISR_Local_enable(level); \
640 } while (0)
641
647#define PPC_THREAD_MGMT_REGISTER(tmr) \
648 ({ \
649 uint32_t val; \
650 __asm__ volatile (\
651 "mftmr %0, " PPC_STRINGOF(tmr) \
652 : "=r" (val) \
653 ); \
654 val;\
655 } )
656
661#define PPC_SET_THREAD_MGMT_REGISTER(tmr, val) \
662 do { \
663 __asm__ volatile (\
664 "mttmr " PPC_STRINGOF(tmr) ", %0" \
665 : \
666 : "r" (val) \
667 ); \
668 } while (0)
669
677#define PPC_DEVICE_CONTROL_REGISTER(dcr) \
678 ({ \
679 uint32_t val; \
680 __asm__ volatile (\
681 "mfdcr %0, " PPC_STRINGOF(dcr) \
682 : "=r" (val) \
683 ); \
684 val;\
685 } )
686
693#define PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val) \
694 do { \
695 __asm__ volatile (\
696 "mtdcr " PPC_STRINGOF(dcr) ", %0" \
697 : \
698 : "r" (val) \
699 ); \
700 } while (0)
701
708#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS(dcr, bits) \
709 do { \
710 ISR_Level level; \
711 uint32_t val; \
712 uint32_t mybits = bits; \
713 _ISR_Local_disable(level); \
714 val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
715 val |= mybits; \
716 PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
717 _ISR_Local_enable(level); \
718 } while (0)
719
727#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED(dcr, bits, mask) \
728 do { \
729 ISR_Level level; \
730 uint32_t val; \
731 uint32_t mybits = bits; \
732 uint32_t mymask = mask; \
733 _ISR_Local_disable(level); \
734 val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
735 val &= ~mymask; \
736 val |= mybits; \
737 PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
738 _ISR_Local_enable(level); \
739 } while (0)
740
747#define PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS(dcr, bits) \
748 do { \
749 ISR_Level level; \
750 uint32_t val; \
751 uint32_t mybits = bits; \
752 _ISR_Local_disable(level); \
753 val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
754 val &= ~mybits; \
755 PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
756 _ISR_Local_enable(level); \
757 } while (0)
758
759static inline uint32_t ppc_time_base(void)
760{
761 uint32_t val;
762
763 CPU_Get_timebase_low(val);
764
765 return val;
766}
767
768static inline void ppc_set_time_base(uint32_t val)
769{
771}
772
773static inline uint32_t ppc_time_base_upper(void)
774{
775 return PPC_SPECIAL_PURPOSE_REGISTER(TBRU);
776}
777
778static inline void ppc_set_time_base_upper(uint32_t val)
779{
781}
782
783static inline uint64_t ppc_time_base_64(void)
784{
785 return PPC_Get_timebase_register();
786}
787
788static inline void ppc_set_time_base_64(uint64_t val)
789{
790 PPC_Set_timebase_register(val);
791}
792
793static inline uint32_t ppc_alternate_time_base(void)
794{
795 return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBL);
796}
797
798static inline uint32_t ppc_alternate_time_base_upper(void)
799{
800 return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBU);
801}
802
803static inline uint64_t ppc_alternate_time_base_64(void)
804{
805 uint32_t atbl;
806 uint32_t atbu_0;
807 uint32_t atbu_1;
808
809 do {
810 atbu_0 = ppc_alternate_time_base_upper();
811 atbl = ppc_alternate_time_base();
812 atbu_1 = ppc_alternate_time_base_upper();
813 } while (atbu_0 != atbu_1);
814
815 return (((uint64_t) atbu_1) << 32) | ((uint64_t) atbl);
816}
817
818static inline uint32_t ppc_processor_id(void)
819{
820 return PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_PIR);
821}
822
823static inline void ppc_set_processor_id(uint32_t val)
824{
825 PPC_SET_SPECIAL_PURPOSE_REGISTER(BOOKE_PIR, val);
826}
827
828static inline uint32_t ppc_fsl_system_version(void)
829{
830 return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_SVR);
831}
832
833static inline uint32_t ppc_fsl_system_version_cid(uint32_t svr)
834{
835 return (svr >> 28) & 0xf;
836}
837
838static inline uint32_t ppc_fsl_system_version_sid(uint32_t svr)
839{
840 return (svr >> 16) & 0xfff;
841}
842
843static inline uint32_t ppc_fsl_system_version_proc(uint32_t svr)
844{
845 return (svr >> 12) & 0xf;
846}
847
848static inline uint32_t ppc_fsl_system_version_mfg(uint32_t svr)
849{
850 return (svr >> 8) & 0xf;
851}
852
853static inline uint32_t ppc_fsl_system_version_mjrev(uint32_t svr)
854{
855 return (svr >> 4) & 0xf;
856}
857
858static inline uint32_t ppc_fsl_system_version_mnrev(uint32_t svr)
859{
860 return (svr >> 0) & 0xf;
861}
862
863void ppc_code_copy(void *dest, const void *src, size_t n);
864
865/* FIXME: Do not use this function */
866void printBAT(int bat, uint32_t upper, uint32_t lower);
867
868/* FIXME: Do not use this function */
869void ShowBATS(void);
870
871#endif /* ifndef ASM */
872
873#if defined(ASM)
874#include <rtems/asm.h>
875
876.macro LA reg, addr
877#if defined(__powerpc64__)
878 lis \reg, (\addr)@highest
879 ori \reg, \reg, (\addr)@higher
880 rldicr \reg, \reg, 32, 31
881 oris \reg, \reg, (\addr)@h
882 ori \reg, \reg, (\addr)@l
883#else
884 lis \reg, (\addr)@h
885 ori \reg, \reg, (\addr)@l
886#endif
887.endm
888
889.macro LA32 reg, addr
890 lis \reg, (\addr)@h
891 ori \reg, \reg, (\addr)@l
892.endm
893
894.macro LWI reg, value
895 lis \reg, (\value)@h
896 ori \reg, \reg, (\value)@l
897.endm
898
899.macro LW reg, addr
900 lis \reg, \addr@ha
901 lwz \reg, \addr@l(\reg)
902.endm
903
904/*
905 * Tests the bits in reg1 against the bits set in mask. A match is indicated
906 * by EQ = 0 in CR0. A mismatch is indicated by EQ = 1 in CR0. The register
907 * reg2 is used to load the mask.
908 */
909.macro TSTBITS reg1, reg2, mask
910 LWI \reg2, \mask
911 and \reg1, \reg1, \reg2
912 cmplw \reg1, \reg2
913.endm
914
915.macro SETBITS reg1, reg2, mask
916 LWI \reg2, \mask
917 or \reg1, \reg1, \reg2
918.endm
919
920.macro CLRBITS reg1, reg2, mask
921 LWI \reg2, \mask
922 andc \reg1, \reg1, \reg2
923.endm
924
925.macro GLOBAL_FUNCTION name
926 .global \name
927 .type \name, @function
928\name:
929.endm
930
931/*
932 * Obtain interrupt mask
933 */
934.macro GET_INTERRUPT_MASK mask
935 lis \mask, _PPC_INTERRUPT_DISABLE_MASK@h
936 ori \mask, \mask, _PPC_INTERRUPT_DISABLE_MASK@l
937.endm
938
939/*
940 * Disables all asynchronous exeptions (interrupts) which may cause a context
941 * switch.
942 */
943.macro INTERRUPT_DISABLE level, mask
944 mfmsr \level
945 GET_INTERRUPT_MASK mask=\mask
946 andc \mask, \level, \mask
947 mtmsr \mask
948.endm
949
950/*
951 * Restore previous machine state.
952 */
953.macro INTERRUPT_ENABLE level
954 mtmsr \level
955.endm
956
957.macro SET_SELF_CPU_CONTROL reg_0, reg_1
958#if defined(RTEMS_SMP)
959 /* Use Book E Processor ID Register (PIR) */
960 mfspr \reg_0, 286
961 slwi \reg_0, \reg_0, PER_CPU_CONTROL_SIZE_LOG2
962#if defined(__powerpc64__)
963 LA \reg_1, _Per_CPU_Information
964 add \reg_0, \reg_0, \reg_1
965#else
966 addis \reg_0, \reg_0, _Per_CPU_Information@ha
967 addi \reg_0, \reg_0, _Per_CPU_Information@l
968#endif
969 mtspr PPC_PER_CPU_CONTROL_REGISTER, \reg_0
970#endif
971.endm
972
973.macro GET_SELF_CPU_CONTROL reg
974#if defined(RTEMS_SMP)
975 mfspr \reg, PPC_PER_CPU_CONTROL_REGISTER
976#else
977 lis \reg, _Per_CPU_Information@h
978 ori \reg, \reg, _Per_CPU_Information@l
979#endif
980.endm
981
982.macro SHIFT_RIGHT_IMMEDIATE rd, rs, imm
983#if defined(__powerpc64__)
984 srdi \rd, \rs, \imm
985#else
986 srwi \rd, \rs, \imm
987#endif
988.endm
989
990.macro COMPARE_LOGICAL cr, ra, rb
991#if defined(__powerpc64__)
992 cmpld \cr, \ra, \rb
993#else
994 cmplw \cr, \ra, \rb
995#endif
996.endm
997
998.macro CLEAR_RIGHT_IMMEDIATE rd, rs, imm
999#if defined(__powerpc64__)
1000 clrrdi \rd, \rs, \imm
1001#else
1002 clrrwi \rd, \rs, \imm
1003#endif
1004.endm
1005
1006#define LINKER_SYMBOL(sym) .extern sym
1007
1008#endif /* ASM */
1009
1010#ifdef __cplusplus
1011}
1012#endif
1013
1016#endif /* __LIBCPU_POWERPC_UTILITY_H */
Interface to Kernel Print Methods.
Time base clicks per micro second.
Definition: bspstart.c:99
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:576
Returns the value of the Special Purpose Register with number spr.
Definition: powerpc-utility.h:562
#define RTEMS_COMPILER_MEMORY_BARRIER()
Definition: basedefs.h:77
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
#define ra
return address *‍/
Definition: regs.h:66
#define sp
stack-pointer *‍/
Definition: regs.h:64
char _PPC_INTERRUPT_DISABLE_MASK[]
A global symbol used to disable interrupts in the MSR.
unsigned l
Definition: tte.h:13
