RTEMS
5.2-rc1
include
score
percpudata.h
1
9
10
* Copyright (c) 2018 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Dornierstr. 4
14
* 82178 Puchheim
15
* Germany
16
* <rtems@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _RTEMS_SCORE_PERCPUDATA_H
24
#define _RTEMS_SCORE_PERCPUDATA_H
25
26
rtems/score/percpu.h
27
#include <rtems/linkersets.h>
28
29
#ifdef __cplusplus
30
extern
"C"
31
#endif
/* __cplusplus */
32
49
RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data,
char
50
59
#define PER_CPU_DATA_ITEM_DECLARE( type, item ) \
60
RTEMS_LINKER_RWSET_ITEM_DECLARE( _Per_CPU_Data, type, item )
61
68
#define PER_CPU_DATA_ITEM( type, item ) \
69
RTEMS_LINKER_RWSET_ITEM( _Per_CPU_Data, type, item )
70
77
#define PER_CPU_DATA_OFFSET( item ) \
78
( (uintptr_t) &_Linker_set__Per_CPU_Data_##item \
79
- (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) )
80
89
#ifdef RTEMS_SMP
90
#define PER_CPU_DATA_GET_BY_OFFSET( cpu, type, offset ) \
91
(type *) ( cpu->data + offset )
92
#else
93
94
(type *) ( (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) + offset ), \
95
(void) cpu
96
#endif
97
106
#ifdef RTEMS_SMP
107
#define PER_CPU_DATA_GET( cpu, type, item ) \
108
PER_CPU_DATA_GET_BY_OFFSET( cpu, type, PER_CPU_DATA_OFFSET( item ) )
109
#else
110
111
&_Linker_set__Per_CPU_Data_##item, (void) cpu
112
#endif
113
116
#ifdef __cplusplus
117
118
#endif
/* __cplusplus */
119
120
#endif
/* _RTEMS_SCORE_PERCPUDATA_H */
percpu.h
