RTEMS 5.2-rc1
pcf8563.h
1/*===============================================================*\
2| Project: RTEMS generic MPC5200 BSP |
3+-----------------------------------------------------------------+
4| Partially based on the code references which are named below. |
5| Adaptions, modifications, enhancements and any recent parts of |
6| the code are: |
7| Copyright (c) 2005 |
8| Embedded Brains GmbH |
9| Obere Lagerstr. 30 |
10| D-82178 Puchheim |
11| Germany |
12| rtems@embedded-brains.de |
13+-----------------------------------------------------------------+
14| The license and distribution terms for this file may be |
15| found in the file LICENSE in this distribution or at |
16| |
17| http://www.rtems.org/license/LICENSE. |
18| |
19+-----------------------------------------------------------------+
20| this file contains declarations for the pcf8563 RTC driver |
21\*===============================================================*/
22/*
23 * This file contains the definitions for Dallas Semiconductor
24 * DS1307/DS1308 serial real-time clock/NVRAM.
25 *
26 * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
27 * Author: Victor V. Vengerov <vvv@oktet.ru>
28 *
29 * The license and distribution terms for this file may be
30 * found in the file LICENSE in this distribution or at
31 *
32 * http://www.rtems.org/license/LICENSE.
33 */
34
35#ifndef __RTC_PCF8563__
36#define __RTC_PCF8563__
37
38#define PCF8563_I2C_ADDRESS (0xA2) /* I2C bus address assigned to PCF8563 */
39
40#define PCF8563_CONTROL1_ADR (0x00)
41#define PCF8563_CONTROL1_TEST1 (0x80) /* EXT_CLK test mode */
42#define PCF8563_CONTROL1_STOP (0x20) /* stop RTC source clock, clear divider*/
43#define PCF8563_CONTROL1_TESTC (0x08) /* enable power-on reset override */
44 /***********/
45#define PCF8563_CONTROL2_ADR (0x01)
46#define PCF8563_CONTROL2_TITP (0x10) /* 0: int output is level */
47#define PCF8563_CONTROL2_AF (0x08) /* alarm flag */
48#define PCF8563_CONTROL2_TF (0x04) /* timer flag */
49#define PCF8563_CONTROL2_AIE (0x02) /* alarm interrupt enable */
50#define PCF8563_CONTROL2_TIE (0x01) /* timer interrupt enable */
51 /***********/
52
53#define PCF8563_SECOND_ADR (0x02)
54#define PCF8563_SECOND_VL (0x80) /* clock integrity no longer guaranteed */
55#define PCF8563_SECOND_MASK (0x7f)
56 /***********/
57
58#define PCF8563_MINUTE_ADR (0x03)
59#define PCF8563_MINUTE_MASK (0x7f)
60 /***********/
61
62#define PCF8563_HOUR_ADR (0x04)
63#define PCF8563_HOUR_MASK (0x3f)
64 /***********/
65
66#define PCF8563_DAY_ADR (0x05)
67#define PCF8563_DAY_MASK (0x3f)
68
69#define PCF8563_DAY_OF_WEEK_ADR (0x06)
70#define PCF8563_DAY_OF_WEEK_MASK (0x07)
71
72#define PCF8563_MONTH_ADR (0x07)
73#define PCF8563_MONTH_MASK (0x1f)
74#define PCF8563_MONTH_CENTURY (0x80)
75 /***********/
76
77#define PCF8563_YEAR_ADR (0x08)
78#define PCF8563_YEAR_MASK (0xff)
79
80#define PCF8563_MINUTE_ALARM_ADR (0x09)
81#define PCF8563_HOUR_ALARM_ADR (0x0A)
82#define PCF8563_DAY_ALARM_ADR (0x0B)
83#define PCF8563_DAY_OF_WEEK_ALARM_ADR (0x0C)
84#define PCF8563_XXX_ALARM_AE (0x80)
85 /***********/
86
87#define PCF8563_CLKOUTCTL_ADR (0x0D)
88#define PCF8563_CLKOUTCTL_FE (0x80) /* */
89#define PCF8563_CLKOUTCTL_FD (0x03) /* */
90 /***********/
91
92#define PCF8563_TIMERCTL_ADR (0x0E)
93#define PCF8563_TIMERCTL_FE (0x80) /* */
94#define PCF8563_TIMERCTL_FD (0x03) /* */
95 /***********/
96
97#define PCF8563_TIMER_ADR (0x0F)
98
99#endif /* __RTC_PCF8563__ */
