RTEMS 5.2-rc1
openpic.h
1/*
2 * openpic.h -- OpenPIC definitions
3 *
4 * Copyright (C) 1997 Geert Uytterhoeven
5 *
6 * This file is based on the following documentation:
7 *
8 * The Open Programmable Interrupt Controller (PIC)
9 * Register Interface Specification Revision 1.2
10 *
11 * Issue Date: October 1995
12 *
13 * Issued jointly by Advanced Micro Devices and Cyrix Corporation
14 *
15 * AMD is a registered trademark of Advanced Micro Devices, Inc.
16 * Copyright (C) 1995, Advanced Micro Devices, Inc. and Cyrix, Inc.
17 * All Rights Reserved.
18 *
19 * To receive a copy of this documentation, send an email to openpic@amd.com.
20 *
21 * This file is subject to the terms and conditions of the GNU General Public
22 * License. See the file COPYING in the main directory of this archive
23 * for more details.
24 *
25 * Modified to compile in RTEMS development environment
26 * by Eric Valette
27 *
28 * Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
29 *
30 * The license and distribution terms for this file may be
31 * found in the file LICENSE in this distribution or at
32 * http://www.rtems.org/license/LICENSE.
33 */
34
35#ifndef _RTEMS_OPENPIC_H
36#define _RTEMS_OPENPIC_H
37
38 /*
39 * OpenPIC supports up to 2048 interrupt sources and up to 32 processors
40 */
41#define OPENPIC_MAX_SOURCES 2048
42#define OPENPIC_MAX_PROCESSORS 32
43
44#define OPENPIC_NUM_TIMERS 4
45#define OPENPIC_NUM_IPI 4
46#define OPENPIC_NUM_PRI 16
47#define OPENPIC_NUM_VECTORS 256
48
49 /*
50 * Vector numbers
51 */
52
53#define OPENPIC_VEC_SOURCE 0x10 /* and up */
54#define OPENPIC_VEC_TIMER 0x40 /* and up */
55#define OPENPIC_VEC_IPI 0x50 /* and up */
56#define OPENPIC_VEC_SPURIOUS 99
57
58 /*
59 * OpenPIC Registers are 32 bits and aligned on 128 bit boundaries
60 */
61
62typedef struct _OpenPIC_Reg {
63 unsigned int Reg; /* Little endian! */
64 char Pad[0xc];
66
67 /*
68 * Per Processor Registers
69 */
70
71typedef struct _OpenPIC_Processor {
72 /*
73 * Private Shadow Registers (for SLiC backwards compatibility)
74 */
75 unsigned int IPI0_Dispatch_Shadow; /* Write Only */
76 char Pad1[0x4];
77 unsigned int IPI0_Vector_Priority_Shadow; /* Read/Write */
78 char Pad2[0x34];
79 /*
80 * Interprocessor Interrupt Command Ports
81 */
82 OpenPIC_Reg _IPI_Dispatch[OPENPIC_NUM_IPI]; /* Write Only */
83 /*
84 * Current Task Priority Register
85 */
86 OpenPIC_Reg _Current_Task_Priority; /* Read/Write */
87 char Pad3[0x10];
88 /*
89 * Interrupt Acknowledge Register
90 */
91 OpenPIC_Reg _Interrupt_Acknowledge; /* Read Only */
92 /*
93 * End of Interrupt (EOI) Register
94 */
95 OpenPIC_Reg _EOI; /* Read/Write */
96 char Pad5[0xf40];
98
99 /*
100 * Timer Registers
101 */
102
103typedef struct _OpenPIC_Timer {
104 OpenPIC_Reg _Current_Count; /* Read Only */
105 OpenPIC_Reg _Base_Count; /* Read/Write */
106 OpenPIC_Reg _Vector_Priority; /* Read/Write */
107 OpenPIC_Reg _Destination; /* Read/Write */
109
110 /*
111 * Global Registers
112 */
113
114typedef struct _OpenPIC_Global {
115 /*
116 * Feature Reporting Registers
117 */
118 OpenPIC_Reg _Feature_Reporting0; /* Read Only */
119 OpenPIC_Reg _Feature_Reporting1; /* Future Expansion */
120 /*
121 * Global Configuration Registers
122 */
123 OpenPIC_Reg _Global_Configuration0; /* Read/Write */
124 OpenPIC_Reg _Global_Configuration1; /* Future Expansion */
125 /*
126 * Vendor Specific Registers
127 */
128 OpenPIC_Reg _Vendor_Specific[4];
129 /*
130 * Vendor Identification Register
131 */
132 OpenPIC_Reg _Vendor_Identification; /* Read Only */
133 /*
134 * Processor Initialization Register
135 */
136 OpenPIC_Reg _Processor_Initialization; /* Read/Write */
137 /*
138 * IPI Vector/Priority Registers
139 */
140 OpenPIC_Reg _IPI_Vector_Priority[OPENPIC_NUM_IPI]; /* Read/Write */
141 /*
142 * Spurious Vector Register
143 */
144 OpenPIC_Reg _Spurious_Vector; /* Read/Write */
145 /*
146 * Global Timer Registers
147 */
148 OpenPIC_Reg _Timer_Frequency; /* Read/Write */
149 OpenPIC_Timer Timer[OPENPIC_NUM_TIMERS];
150 char Pad1[0xee00];
152
153 /*
154 * Interrupt Source Registers
155 */
156
157typedef struct _OpenPIC_Source {
158 OpenPIC_Reg _Vector_Priority; /* Read/Write */
159 OpenPIC_Reg _Destination; /* Read/Write */
161
162 /*
163 * OpenPIC Register Map
164 */
165
166struct OpenPIC {
167 char Pad1[0x1000];
168 /*
169 * Global Registers
170 */
171 OpenPIC_Global Global;
172 /*
173 * Interrupt Source Configuration Registers
174 */
175 OpenPIC_Source Source[OPENPIC_MAX_SOURCES];
176 /*
177 * Per Processor Registers
178 */
179 OpenPIC_Processor Processor[OPENPIC_MAX_PROCESSORS];
180};
181
182extern volatile struct OpenPIC *OpenPIC;
183
184 /*
185 * Current Task Priority Register
186 */
187
188#define OPENPIC_CURRENT_TASK_PRIORITY_MASK 0x0000000f
189
190 /*
191 * Who Am I Register
192 */
193
194#define OPENPIC_WHO_AM_I_ID_MASK 0x0000001f
195
196 /*
197 * Feature Reporting Register 0
198 */
199
200#define OPENPIC_FEATURE_LAST_SOURCE_MASK 0x07ff0000
201#define OPENPIC_FEATURE_LAST_SOURCE_SHIFT 16
202#define OPENPIC_FEATURE_LAST_PROCESSOR_MASK 0x00001f00
203#define OPENPIC_FEATURE_LAST_PROCESSOR_SHIFT 8
204#define OPENPIC_FEATURE_VERSION_MASK 0x000000ff
205
206 /*
207 * Global Configuration Register 0
208 */
209
210#define OPENPIC_CONFIG_RESET 0x80000000
211#define OPENPIC_CONFIG_8259_PASSTHROUGH_DISABLE 0x20000000
212#define OPENPIC_CONFIG_BASE_MASK 0x000fffff
213
214 /*
215 * Vendor Identification Register
216 */
217
218#define OPENPIC_VENDOR_ID_STEPPING_MASK 0x00ff0000
219#define OPENPIC_VENDOR_ID_STEPPING_SHIFT 16
220#define OPENPIC_VENDOR_ID_DEVICE_ID_MASK 0x0000ff00
221#define OPENPIC_VENDOR_ID_DEVICE_ID_SHIFT 8
222#define OPENPIC_VENDOR_ID_VENDOR_ID_MASK 0x000000ff
223
224 /*
225 * Vector/Priority Registers
226 */
227
228#define OPENPIC_MASK 0x80000000
229#define OPENPIC_ACTIVITY 0x40000000 /* Read Only */
230#define OPENPIC_PRIORITY_MASK 0x000f0000
231#define OPENPIC_PRIORITY_SHIFT 16
232#define OPENPIC_VECTOR_MASK 0x000000ff
233
234 /*
235 * Interrupt Source Registers
236 */
237
238#define OPENPIC_SENSE_POLARITY 0x00800000 /* Undoc'd */
239#define OPENPIC_SENSE_LEVEL 0x00400000
240
241 /*
242 * Timer Registers
243 */
244
245#define OPENPIC_COUNT_MASK 0x7fffffff
246#define OPENPIC_TIMER_TOGGLE 0x80000000
247#define OPENPIC_TIMER_COUNT_INHIBIT 0x80000000
248
249 /*
250 * Aliases to make life simpler
251 */
252
253/* Per Processor Registers */
254#define IPI_Dispatch(i) _IPI_Dispatch[i].Reg
255#define Current_Task_Priority _Current_Task_Priority.Reg
256#define Interrupt_Acknowledge _Interrupt_Acknowledge.Reg
257#define EOI _EOI.Reg
258
259/* Global Registers */
260#define Feature_Reporting0 _Feature_Reporting0.Reg
261#define Feature_Reporting1 _Feature_Reporting1.Reg
262#define Global_Configuration0 _Global_Configuration0.Reg
263#define Global_Configuration1 _Global_Configuration1.Reg
264#define Vendor_Specific(i) _Vendor_Specific[i].Reg
265#define Vendor_Identification _Vendor_Identification.Reg
266#define Processor_Initialization _Processor_Initialization.Reg
267#define IPI_Vector_Priority(i) _IPI_Vector_Priority[i].Reg
268#define Spurious_Vector _Spurious_Vector.Reg
269#define Timer_Frequency _Timer_Frequency.Reg
270
271/* Timer Registers */
272#define Current_Count _Current_Count.Reg
273#define Base_Count _Base_Count.Reg
274#define Vector_Priority _Vector_Priority.Reg
275#define Destination _Destination.Reg
276
277/* Interrupt Source Registers */
278#define Vector_Priority _Vector_Priority.Reg
279#define Destination _Destination.Reg
280
281 /*
282 * Vendor and Device IDs
283 */
284
285#define OPENPIC_VENDOR_ID_APPLE 0x14
286#define OPENPIC_DEVICE_ID_APPLE_HYDRA 0x46
287
288 /*
289 * OpenPIC Operations
290 */
291
292/*
293 * Handle EPIC differences. Unfortunately, I don't know of an easy
294 * way to tell an EPIC from a normal PIC at run-time. Therefore,
295 * the BSP must enable a few quirks if it knows that an EPIC is being
296 * used:
297 * - If the BSP uses the serial interrupt mode / 'multiplexer' then
298 * EOI must be delayed by at least 16 SRAM_CLK cycles to avoid
299 * spurious interrupts.
300 * It is the BSP's responsibility to set up an appropriate delay
301 * (in timebase-clock cycles) at init time using
302 * 'openpic_set_eoi_delay()'. This is ONLY necessary when using
303 * an EPIC in serial mode.
304 * - The EPIC sources start at an offset of 16 in the register
305 * map, i.e., on an EPIC you'd say Sources[ x + 16 ] where
306 * on a PIC you would say Sources[ x ].
307 * Again, the BSP can set an offset that is used by the
308 * calls dealing with 'Interrupt Sources'
309 * openpic_enable_irq()
310 * openpic_disable_irq()
311 * openpic_initirq()
312 * openpic_mapirq()
313 * openpic_set_sense()
314 * openpic_get_source_priority()
315 * openpic_set_source_priority()
316 * the desired source offset parameter is passed to openpic_init().
317 *
318 * The routine 'openpic_set_eoi_delay()' returns the previous/old
319 * value of the delay parameter.
320 */
321extern unsigned openpic_set_eoi_delay(unsigned tb_cycles);
322
323
324/* Global Operations */
325
326/* num_sources: number of sources to use; if zero this value
327 * is read from the device, if nonzero the value read from
328 * the device is overridden.
329 * 'polarities' and 'senses' are arrays defining the desired
330 * polarities (active hi [nonzero]/lo [zero]) and
331 * senses (level [nonzero]/edge [zero]).
332 * Either of the two array pointers may be NULL resulting
333 * in the driver choosing default values of: 'active low'
334 * and 'level sensitive', respectively.
335 * NOTE: if you do pass arrays then their size must either
336 * match the number of sources read from the device or
337 * that value must be overridden by specifying
338 * a non-zero 'num_sources' parameter.
339 *
340 * Nonzero 'epic_freq' activates the EOI delay if the EPIC is
341 * configured in serial mode (driver assumes firmware performs initial
342 * EPIC setup). The BSP must pass the clock frequency of the EPIC
343 * serial interface here.
344 */
345extern void openpic_init(int main_pic, unsigned char *polarities, unsigned char *senses, int num_sources, int source_offset, unsigned long epic_freq);
346
347extern void openpic_reset(void);
348extern void openpic_enable_8259_pass_through(void);
349extern void openpic_disable_8259_pass_through(void);
350extern unsigned int openpic_irq(unsigned int cpu);
351extern void openpic_eoi(unsigned int cpu);
352extern unsigned int openpic_get_priority(unsigned int cpu);
353extern void openpic_set_priority(unsigned int cpu, unsigned int pri);
354extern unsigned int openpic_get_spurious(void);
355extern void openpic_set_spurious(unsigned int vector);
356extern void openpic_init_processor(unsigned int cpumask);
357
358/* Interprocessor Interrupts */
359extern void openpic_initipi(unsigned int ipi, unsigned int pri, unsigned int vector);
360extern void openpic_cause_IPI(unsigned int cpu, unsigned int ipi, unsigned int cpumask);
361
362/* Timer Interrupts */
363extern void openpic_inittimer(unsigned int timer, unsigned int pri, unsigned int vector);
364extern void openpic_settimer(unsigned int timer, unsigned int base_count, int irq_enable);
365extern unsigned int openpic_gettimer(unsigned int timer);
366extern void openpic_maptimer(unsigned int timer, unsigned int cpumask);
367
368/* Interrupt Sources */
369extern void openpic_enable_irq(unsigned int irq);
370extern int openpic_disable_irq(unsigned int irq);
371extern void openpic_initirq(unsigned int irq, unsigned int pri, unsigned int vector, int polarity,
372 int is_level);
373extern void openpic_mapirq(unsigned int irq, unsigned int cpumask);
374extern void openpic_set_sense(unsigned int irq, int sense);
375extern unsigned int openpic_get_source_priority(unsigned int irq);
376extern void openpic_set_source_priority(unsigned int irq, unsigned int pri);
377
378#endif /* RTEMS_OPENPIC_H */
Definition: openpic.h:166
Definition: openpic.h:114
Definition: openpic.h:71
Definition: openpic.h:62
Definition: openpic.h:157
Definition: openpic.h:103
