RTEMS 5.2-rc1
occan.h
1
7/*
8 * COPYRIGHT (c) 2007.
9 * Cobham Gaisler AB.
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef __OCCAN_DRIVER_H__
17#define __OCCAN_DRIVER_H__
18
19#ifdef __cplusplus
20extern "C" {
21#endif
22
23/* CAN MESSAGE */
24typedef struct {
25 char extended; /* 1= Extended Frame (29-bit id), 0= STD Frame (11-bit id) */
26 char rtr; /* RTR - Remote Transmission Request */
27 char sshot; /* single shot */
28 unsigned char len;
29 unsigned char data[8];
30 unsigned int id;
31} CANMsg;
32
33typedef struct {
34 /* tx/rx stats */
35 unsigned int rx_msgs;
36 unsigned int tx_msgs;
37
38 /* Error Interrupt counters */
39 unsigned int err_warn;
40 unsigned int err_dovr;
41 unsigned int err_errp;
42 unsigned int err_arb;
43 unsigned int err_bus;
44
45 /**** BUS ERRORS (err_arb) ****/
46
47 /* ALC 4-0 */
48 unsigned int err_arb_bitnum[32]; /* At what bit arbitration is lost */
49
50 /******************************/
51
52 /**** BUS ERRORS (err_bus) ****/
53
54 /* ECC 7-6 */
55 unsigned int err_bus_bit; /* Bit error */
56 unsigned int err_bus_form; /* Form Error */
57 unsigned int err_bus_stuff; /* Stuff Error */
58 unsigned int err_bus_other; /* Other Error */
59
60 /* ECC 5 */
61 unsigned int err_bus_rx; /* Errors during Reception */
62 unsigned int err_bus_tx; /* Errors during Transmission */
63
64 /* ECC 4:0 */
65 unsigned int err_bus_segs[32]; /* Segment (Where in frame error occured)
66 * See OCCAN_SEG_* defines for indexes
67 */
68
69 /******************************/
70
71
72 /* total number of interrupts */
73 unsigned int ints;
74
75 /* software monitoring hw errors */
76 unsigned int tx_buf_error;
77
78 /* Software fifo overrun */
79 unsigned int rx_sw_dovr;
80
82
83/* indexes into occan_stats.err_bus_segs[index] */
84#define OCCAN_SEG_ID28 0x02 /* ID field bit 28:21 */
85#define OCCAN_SEG_ID20 0x06 /* ID field bit 20:18 */
86#define OCCAN_SEG_ID17 0x07 /* ID field bit 17:13 */
87#define OCCAN_SEG_ID12 0x0f /* ID field bit 12:5 */
88#define OCCAN_SEG_ID4 0x0e /* ID field bit 4:0 */
89
90#define OCCAN_SEG_START 0x03 /* Start of Frame */
91#define OCCAN_SEG_SRTR 0x04 /* Bit SRTR */
92#define OCCAN_SEG_IDE 0x05 /* Bit IDE */
93#define OCCAN_SEG_RTR 0x0c /* Bit RTR */
94#define OCCAN_SEG_RSV0 0x09 /* Reserved bit 0 */
95#define OCCAN_SEG_RSV1 0x0d /* Reserved bit 1 */
96
97#define OCCAN_SEG_DLEN 0x0b /* Data Length code */
98#define OCCAN_SEG_DFIELD 0x0a /* Data Field */
99
100#define OCCAN_SEG_CRC_SEQ 0x08 /* CRC Sequence */
101#define OCCAN_SEG_CRC_DELIM 0x18 /* CRC Delimiter */
102
103#define OCCAN_SEG_ACK_SLOT 0x19 /* Acknowledge slot */
104#define OCCAN_SEG_ACK_DELIM 0x1b /* Acknowledge delimiter */
105#define OCCAN_SEG_EOF 0x1a /* End Of Frame */
106#define OCCAN_SEG_INTERMISSION 0x12 /* Intermission */
107#define OCCAN_SEG_ACT_ERR 0x11 /* Active error flag */
108#define OCCAN_SEG_PASS_ERR 0x16 /* Passive error flag */
109#define OCCAN_SEG_DOMINANT 0x13 /* Tolerate dominant bits */
110#define OCCAN_SEG_EDELIM 0x17 /* Error delimiter */
111#define OCCAN_SEG_OVERLOAD 0x1c /* overload flag */
112
113
114#define CANMSG_OPT_RTR 0x40 /* RTR Frame */
115#define CANMSG_OPT_EXTENDED 0x80 /* Exteneded frame */
116#define CANMSG_OPT_SSHOT 0x01 /* Single Shot, no retry */
117
118#define OCCAN_IOC_START 1
119#define OCCAN_IOC_STOP 2
120
121#define OCCAN_IOC_GET_CONF 3
122#define OCCAN_IOC_GET_STATS 4
123#define OCCAN_IOC_GET_STATUS 5
124
125#define OCCAN_IOC_SET_SPEED 6
126#define OCCAN_IOC_SPEED_AUTO 7
127#define OCCAN_IOC_SET_LINK 8
128#define OCCAN_IOC_SET_FILTER 9
129#define OCCAN_IOC_SET_BLK_MODE 10
130#define OCCAN_IOC_SET_BUFLEN 11
131#define OCCAN_IOC_SET_BTRS 12
132
133
135 unsigned char code[4];
136 unsigned char mask[4];
137 int single_mode;
138};
139
140#define OCCAN_STATUS_RESET 0x01
141#define OCCAN_STATUS_OVERRUN 0x02
142#define OCCAN_STATUS_WARN 0x04
143#define OCCAN_STATUS_ERR_PASSIVE 0x08
144#define OCCAN_STATUS_ERR_BUSOFF 0x10
145#define OCCAN_STATUS_QUEUE_ERROR 0x80
146
147#define OCCAN_BLK_MODE_RX 0x1
148#define OCCAN_BLK_MODE_TX 0x2
149
150void occan_register_drv (void);
151
152
153#define OCCAN_SPEED_500K 500000
154#define OCCAN_SPEED_250K 250000
155#define OCCAN_SPEED_125K 125000
156#define OCCAN_SPEED_75K 75000
157#define OCCAN_SPEED_50K 50000
158#define OCCAN_SPEED_25K 25000
159#define OCCAN_SPEED_10K 10000
160
161#ifdef __cplusplus
162}
163#endif
164
165#endif
Definition: grcan.h:123
Definition: inftrees.h:24
Definition: occan.h:134
Definition: occan.h:33
