RTEMS 5.2-rc1
36#ifndef _RTEMS_CONFDEFS_OBSOLETE_H
37#define _RTEMS_CONFDEFS_OBSOLETE_H
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
60#ifdef CONFIGURE_BDBUF_BUFFER_SIZE
61 #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is obsolete since RTEMS 4.10.0"
64#ifdef CONFIGURE_BDBUF_BUFFER_COUNT
65 #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is obsolete since RTEMS 4.10.0"
68#ifdef CONFIGURE_MAXIMUM_DEVICES
69 #warning "The CONFIGURE_MAXIMUM_DEVICES configuration option is obsolete since RTEMS 5.1"
72#ifdef CONFIGURE_ENABLE_GO
73 #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
76#ifdef CONFIGURE_GNAT_RTEMS
77 #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
80#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
81 #error "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
84#ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE
85 #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete since RTEMS 4.10.0"
88#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
89 #error "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
92#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
93 #error "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
96#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
97 #error "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
100#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
101 #error "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
104#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
105 #error "The CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE configuration option is obsolete since RTEMS 5.1"
108#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
109 #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
110 #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
113#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
114 #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
117#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
118 #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
121#ifdef CONFIGURE_MAXIMUM_FIFOS
122 #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
123 #if CONFIGURE_MAXIMUM_FIFOS > 0
124 #define CONFIGURE_IMFS_ENABLE_MKFIFO
128#ifdef CONFIGURE_MAXIMUM_GOROUTINES
129 #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
132#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
133 #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
136#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
137 #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
140#ifdef CONFIGURE_MAXIMUM_PIPES
141 #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
142 #if CONFIGURE_MAXIMUM_PIPES > 0
143 #define CONFIGURE_IMFS_ENABLE_MKFIFO
147#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
148 #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
151#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
152 #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
155#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
156 #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
159#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
160 #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
163#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
164 #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
167#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
168 #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
171#ifdef CONFIGURE_MAXIMUM_PTYS
172 #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
175#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
176 #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
179#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
180 #error "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
183#ifdef CONFIGURE_SCHEDULER_CONTEXT
184 #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
185 #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
188#ifdef CONFIGURE_SCHEDULER_CONTROLS
189 #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
190 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
193#ifdef CONFIGURE_SMP_APPLICATION
194 #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
197#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
198 #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
199 #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
202#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
203 #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
204 #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
207#ifdef CONFIGURE_TERMIOS_DISABLED
208 #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
211#ifdef CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
212 #error "The CONFIGURE_TEST_NEEDS_CLOCK_DRIVER configuration option is obsolete since at least RTEMS 4.5.0"
215#ifdef CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
216 #error "The CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
219#ifdef CONFIGURE_TEST_NEEDS_RTC_DRIVER
220 #error "The CONFIGURE_TEST_NEEDS_RTC_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
223#ifdef CONFIGURE_TEST_NEEDS_STUB_DRIVER
224 #error "The CONFIGURE_TEST_NEEDS_STUB_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
227#ifdef CONFIGURE_TEST_NEEDS_TIMER_DRIVER
228 #error "The CONFIGURE_TEST_NEEDS_TIMER_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
231#ifdef STACK_CHECKER_ON
232 #warning "STACK_CHECKER_ON has been renamed to CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10.0"
233 #define CONFIGURE_STACK_CHECKER_ENABLED
