RTEMS 5.2-rc1
nios2-utility.h
1
6/*
7 * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
8 *
9 * embedded brains GmbH
10 * Obere Lagerstr. 30
11 * 82178 Puchheim
12 * Germany
13 * <rtems@embedded-brains.de>
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef _RTEMS_SCORE_NIOS2_UTILITY_H
21#define _RTEMS_SCORE_NIOS2_UTILITY_H
22
23#define NIOS2_CTLREG_INDEX_STATUS 0
24#define NIOS2_CTLREG_INDEX_ESTATUS 1
25#define NIOS2_CTLREG_INDEX_BSTATUS 2
26#define NIOS2_CTLREG_INDEX_IENABLE 3
27#define NIOS2_CTLREG_INDEX_IPENDING 4
28#define NIOS2_CTLREG_INDEX_CPUID 5
29#define NIOS2_CTLREG_INDEX_EXCEPTION 7
30#define NIOS2_CTLREG_INDEX_PTEADDR 8
31#define NIOS2_CTLREG_INDEX_TLBACC 9
32#define NIOS2_CTLREG_INDEX_TLBMISC 10
33#define NIOS2_CTLREG_INDEX_BADADDR 12
34#define NIOS2_CTLREG_INDEX_CONFIG 13
35#define NIOS2_CTLREG_INDEX_MPUBASE 14
36#define NIOS2_CTLREG_INDEX_MPUACC 15
37
38#define NIOS2_CONTEXT_OFFSET_R16 0
39#define NIOS2_CONTEXT_OFFSET_R17 4
40#define NIOS2_CONTEXT_OFFSET_R18 8
41#define NIOS2_CONTEXT_OFFSET_R19 12
42#define NIOS2_CONTEXT_OFFSET_R20 16
43#define NIOS2_CONTEXT_OFFSET_R21 20
44#define NIOS2_CONTEXT_OFFSET_R22 24
45#define NIOS2_CONTEXT_OFFSET_R23 28
46#define NIOS2_CONTEXT_OFFSET_FP 32
47#define NIOS2_CONTEXT_OFFSET_STATUS 36
48#define NIOS2_CONTEXT_OFFSET_SP 40
49#define NIOS2_CONTEXT_OFFSET_RA 44
50#define NIOS2_CONTEXT_OFFSET_THREAD_DISPATCH_DISABLED 48
51#define NIOS2_CONTEXT_OFFSET_STACK_MPUBASE 52
52#define NIOS2_CONTEXT_OFFSET_STACK_MPUACC 56
53
54#define NIOS2_ISR_STATUS_MASK_IIC 0xfffffffe
55#define NIOS2_ISR_STATUS_BITS_IIC 0x00000000
56
57#define NIOS2_ISR_STATUS_MASK_EIC_IL 0xfffffc0f
58#define NIOS2_ISR_STATUS_BITS_EIC_IL 0x000003f0
59
60#define NIOS2_ISR_STATUS_MASK_EIC_RSIE 0xf7ffffff
61#define NIOS2_ISR_STATUS_BITS_EIC_RSIE 0x00000000
62
63#define NIOS2_STATUS_RSIE (1 << 23)
64#define NIOS2_STATUS_NMI (1 << 22)
65#define NIOS2_STATUS_PRS_OFFSET 16
66#define NIOS2_STATUS_PRS_MASK (0x3f << NIOS2_STATUS_PRS_OFFSET)
67#define NIOS2_STATUS_CRS_OFFSET 10
68#define NIOS2_STATUS_CRS_MASK (0x3f << NIOS2_STATUS_CRS_OFFSET)
69#define NIOS2_STATUS_IL_OFFSET 4
70#define NIOS2_STATUS_IL_MASK (0x3f << NIOS2_STATUS_IL_OFFSET)
71#define NIOS2_STATUS_IH (1 << 3)
72#define NIOS2_STATUS_EH (1 << 2)
73#define NIOS2_STATUS_U (1 << 1)
74#define NIOS2_STATUS_PIE (1 << 0)
75
76#define NIOS2_EXCEPTION_CAUSE_OFFSET 2
77#define NIOS2_EXCEPTION_CAUSE_MASK (0x1f << NIOS2_EXCEPTION_CAUSE_OFFSET)
78
79#define NIOS2_PTEADDR_PTBASE_OFFSET 22
80#define NIOS2_PTEADDR_PTBASE_MASK (0x3ff << NIOS2_PTEADDR_PTBASE_OFFSET)
81#define NIOS2_PTEADDR_VPN_OFFSET 2
82#define NIOS2_PTEADDR_VPN_MASK (0xfffff << NIOS2_PTEADDR_VPN_OFFSET)
83
84#define NIOS2_TLBACC_IG_OFFSET 25
85#define NIOS2_TLBACC_IG_MASK (0x3ff << NIOS2_TLBACC_IG_OFFSET)
86#define NIOS2_TLBACC_C (1 << 24)
87#define NIOS2_TLBACC_R (1 << 23)
88#define NIOS2_TLBACC_W (1 << 22)
89#define NIOS2_TLBACC_X (1 << 21)
90#define NIOS2_TLBACC_G (1 << 20)
91#define NIOS2_TLBACC_PFN_OFFSET 2
92#define NIOS2_TLBACC_PFN_MASK (0xfffff << NIOS2_TLBACC_PFN_OFFSET)
93
94#define NIOS2_TLBMISC_WAY_OFFSET 20
95#define NIOS2_TLBMISC_WAY_MASK (0xf << NIOS2_TLBMISC_WAY_OFFSET)
96#define NIOS2_TLBMISC_RD (1 << 19)
97#define NIOS2_TLBMISC_WE (1 << 18)
98#define NIOS2_TLBMISC_PID_OFFSET 5
99#define NIOS2_TLBMISC_PID_MASK (0x3fff << NIOS2_TLBMISC_PID_OFFSET)
100#define NIOS2_TLBMISC_DBL (1 << 3)
101#define NIOS2_TLBMISC_BAD (1 << 2)
102#define NIOS2_TLBMISC_PERM (1 << 1)
103#define NIOS2_TLBMISC_D (1 << 0)
104
105#define NIOS2_CONFIG_ANI (1 << 1)
106#define NIOS2_CONFIG_PE (1 << 0)
107
108#define NIOS2_MPUBASE_BASE_OFFSET 6
109#define NIOS2_MPUBASE_BASE_MASK (0x1ffffff << NIOS2_MPUBASE_BASE_OFFSET)
110#define NIOS2_MPUBASE_INDEX_OFFSET 1
111
112/* Avoid redefines with Altera HAL */
113#define NIOS2_MPUBASE_INDEX_MASK (0x0000003e)
114
115#define NIOS2_MPUBASE_D (1 << 0)
116
117#define NIOS2_MPUACC_MASK_OFFSET 6
118
119/* Avoid redefines with Altera HAL */
120#define NIOS2_MPUACC_MASK_MASK (0x7fffffc0)
121
122#define NIOS2_MPUACC_LIMIT_OFFSET 6
123
124/* Avoid redefines with Altera HAL */
125#define NIOS2_MPUACC_LIMIT_MASK (0xffffffc0)
126
127#define NIOS2_MPUACC_C (1 << 5)
128#define NIOS2_MPUACC_PERM_OFFSET 2
129
130/* Avoid redefines with Altera HAL */
131#define NIOS2_MPUACC_PERM_MASK (0x0000001c)
132
133#define NIOS2_MPUACC_RD (1 << 1)
134#define NIOS2_MPUACC_WR (1 << 0)
135
136#ifndef ASM
137
138#include <stddef.h>
139#include <stdint.h>
140#include <stdbool.h>
141
142#ifdef __cplusplus
143extern "C" {
144#endif /* __cplusplus */
145
155extern uint32_t _Nios2_Thread_dispatch_disabled;
156
164extern char _Nios2_ISR_Status_mask [];
165
173extern char _Nios2_ISR_Status_bits [];
174
175static inline void _Nios2_Flush_pipeline( void )
176{
177 __asm__ volatile ("flushp");
178}
179
180static inline uint32_t _Nios2_Get_ctlreg_status( void )
181{
182 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_STATUS );
183}
184
185static inline void _Nios2_Set_ctlreg_status( uint32_t value )
186{
187 __builtin_wrctl( NIOS2_CTLREG_INDEX_STATUS, (int) value );
188}
189
190static inline uint32_t _Nios2_Get_ctlreg_estatus( void )
191{
192 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_ESTATUS );
193}
194
195static inline void _Nios2_Set_ctlreg_estatus( uint32_t value )
196{
197 __builtin_wrctl( NIOS2_CTLREG_INDEX_ESTATUS, (int) value );
198}
199
200static inline uint32_t _Nios2_Get_ctlreg_bstatus( void )
201{
202 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_BSTATUS );
203}
204
205static inline void _Nios2_Set_ctlreg_bstatus( uint32_t value )
206{
207 __builtin_wrctl( NIOS2_CTLREG_INDEX_BSTATUS, (int) value );
208}
209
210static inline uint32_t _Nios2_Get_ctlreg_ienable( void )
211{
212 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_IENABLE );
213}
214
215static inline void _Nios2_Set_ctlreg_ienable( uint32_t value )
216{
217 __builtin_wrctl( NIOS2_CTLREG_INDEX_IENABLE, (int) value );
218}
219
220static inline uint32_t _Nios2_Get_ctlreg_ipending( void )
221{
222 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_IPENDING );
223}
224
225static inline uint32_t _Nios2_Get_ctlreg_cpuid( void )
226{
227 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_CPUID );
228}
229
230static inline uint32_t _Nios2_Get_ctlreg_exception( void )
231{
232 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_EXCEPTION );
233}
234
235static inline uint32_t _Nios2_Get_ctlreg_pteaddr( void )
236{
237 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_PTEADDR );
238}
239
240static inline void _Nios2_Set_ctlreg_pteaddr( uint32_t value )
241{
242 __builtin_wrctl( NIOS2_CTLREG_INDEX_PTEADDR, (int) value );
243}
244
245static inline uint32_t _Nios2_Get_ctlreg_tlbacc( void )
246{
247 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_TLBACC );
248}
249
250static inline void _Nios2_Set_ctlreg_tlbacc( uint32_t value )
251{
252 __builtin_wrctl( NIOS2_CTLREG_INDEX_TLBACC, (int) value );
253}
254
255static inline uint32_t _Nios2_Get_ctlreg_tlbmisc( void )
256{
257 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_TLBMISC );
258}
259
260static inline void _Nios2_Set_ctlreg_tlbmisc( uint32_t value )
261{
262 __builtin_wrctl( NIOS2_CTLREG_INDEX_TLBMISC, (int) value );
263}
264
265static inline uint32_t _Nios2_Get_ctlreg_badaddr( void )
266{
267 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_BADADDR );
268}
269
270static inline uint32_t _Nios2_Get_ctlreg_config( void )
271{
272 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_CONFIG );
273}
274
275static inline void _Nios2_Set_ctlreg_config( uint32_t value )
276{
277 __builtin_wrctl( NIOS2_CTLREG_INDEX_CONFIG, (int) value );
278}
279
280static inline uint32_t _Nios2_Get_ctlreg_mpubase( void )
281{
282 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_MPUBASE );
283}
284
285static inline void _Nios2_Set_ctlreg_mpubase( uint32_t value )
286{
287 __builtin_wrctl( NIOS2_CTLREG_INDEX_MPUBASE, (int) value );
288}
289
290static inline uint32_t _Nios2_Get_ctlreg_mpuacc( void )
291{
292 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_MPUACC );
293}
294
295static inline void _Nios2_Set_ctlreg_mpuacc( uint32_t value )
296{
297 __builtin_wrctl( NIOS2_CTLREG_INDEX_MPUACC, (int) value );
298}
299
300static inline uint32_t _Nios2_ISR_Get_status_mask( void )
301{
302 return (uint32_t) &_Nios2_ISR_Status_mask [0];
303}
304
305static inline uint32_t _Nios2_ISR_Get_status_bits( void )
306{
307 return (uint32_t) &_Nios2_ISR_Status_bits [0];
308}
309
310static inline bool _Nios2_Has_internal_interrupt_controller( void )
311{
312 return _Nios2_ISR_Get_status_mask() == NIOS2_ISR_STATUS_MASK_IIC;
313}
314
315uint32_t _Nios2_ISR_Set_level( uint32_t new_level, uint32_t status );
316
317typedef struct {
318 int data_address_width;
319 int instruction_address_width;
320 int data_region_size_log2;
321 int instruction_region_size_log2;
322 int data_region_count;
323 int instruction_region_count;
324 int data_index_for_stack_protection;
325 bool region_uses_limit;
326 bool enable_data_cache_for_stack;
328
329void _Nios2_MPU_Set_configuration( const Nios2_MPU_Configuration *config );
330
331const Nios2_MPU_Configuration *_Nios2_MPU_Get_configuration( void );
332
333typedef enum {
334 NIOS2_MPU_INST_PERM_SVR_NONE_USER_NONE = 0,
335 NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_NONE,
336 NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_EXECUTE,
337 NIOS2_MPU_DATA_PERM_SVR_NONE_USER_NONE = 0,
338 NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_NONE,
339 NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_READONLY,
340 NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE = 4,
341 NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_READONLY,
342 NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_READWRITE
343} Nios2_MPU_Region_permissions;
344
345typedef struct {
346 int index;
347 const void *base;
348 const void *end;
349 Nios2_MPU_Region_permissions perm;
350 bool data;
351 bool cacheable;
352 bool read;
353 bool write;
355
356#define NIOS2_MPU_REGION_DESC_INST( index, base, end ) \
357 { \
358 (index), (base), (end), NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_NONE, \
359 false, false, false, true \
360 }
361
362#define NIOS2_MPU_REGION_DESC_DATA_RO( index, base, end ) \
363 { \
364 (index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_NONE, \
365 true, true, false, true \
366 }
367
368#define NIOS2_MPU_REGION_DESC_DATA_RW( index, base, end ) \
369 { \
370 (index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE, \
371 true, true, false, true \
372 }
373
374#define NIOS2_MPU_REGION_DESC_DATA_IO( index, base, end ) \
375 { \
376 (index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE, \
377 true, false, false, true \
378 }
379
380static inline int _Nios2_MPU_Get_region_count(
382 bool data
383)
384{
385 return data ?
386 config->data_region_count
387 : config->instruction_region_count;
388}
389
390static inline bool _Nios2_MPU_Is_valid_index(
392 int index,
393 bool data
394)
395{
396 return 0 <= index
397 && index < _Nios2_MPU_Get_region_count( config, data );
398}
399
400bool _Nios2_MPU_Setup_region_registers(
402 const Nios2_MPU_Region_descriptor *desc,
403 uint32_t *mpubase,
404 uint32_t *mpuacc
405);
406
407bool _Nios2_MPU_Get_region_descriptor(
409 int index,
410 bool data,
412);
413
427 bool data,
428 int begin,
429 int end
430);
431
442 const Nios2_MPU_Region_descriptor *desc,
443 bool force
444);
445
446static inline void _Nios2_MPU_Get_region_registers(
447 int index,
448 bool data,
449 uint32_t *mpubase,
450 uint32_t *mpuacc
451)
452{
453 uint32_t base = (uint32_t)
454 (((index << NIOS2_MPUBASE_INDEX_OFFSET) & NIOS2_MPUBASE_INDEX_MASK)
455 | (data ? NIOS2_MPUBASE_D : 0));
456
457 _Nios2_Set_ctlreg_mpubase( base );
458 _Nios2_Set_ctlreg_mpuacc( NIOS2_MPUACC_RD );
459 _Nios2_Flush_pipeline();
460 *mpubase = _Nios2_Get_ctlreg_mpubase() | base;
461 *mpuacc = _Nios2_Get_ctlreg_mpuacc();
462}
463
464static inline void _Nios2_MPU_Set_region_registers(
465 uint32_t mpubase,
466 uint32_t mpuacc
467)
468{
469 _Nios2_Set_ctlreg_mpubase( mpubase );
470 _Nios2_Set_ctlreg_mpuacc( mpuacc );
471 _Nios2_Flush_pipeline();
472}
473
474static inline void _Nios2_MPU_Enable( void )
475{
476 uint32_t config = _Nios2_Get_ctlreg_config();
477
478 _Nios2_Set_ctlreg_config( config | NIOS2_CONFIG_PE );
479}
480
481static inline uint32_t _Nios2_MPU_Disable( void )
482{
483 uint32_t config = _Nios2_Get_ctlreg_config();
484 uint32_t config_pe = NIOS2_CONFIG_PE;
485
486 _Nios2_Set_ctlreg_config( config & ~config_pe );
487
488 return config;
489}
490
491static inline void _Nios2_MPU_Restore( uint32_t config )
492{
493 _Nios2_Set_ctlreg_config( config );
494}
495
496uint32_t _Nios2_MPU_Disable_protected( void );
497
498void _Nios2_MPU_Reset( const Nios2_MPU_Configuration *config );
499
500#ifdef __cplusplus
501}
502#endif /* __cplusplus */
503
504#else /* ASM */
505
506 .macro NIOS2_ASM_DISABLE_INTERRUPTS new_status, current_status
507 movhi \new_status, %hiadj(_Nios2_ISR_Status_mask)
508 addi \new_status, \new_status, %lo(_Nios2_ISR_Status_mask)
509 and \new_status, \current_status, \new_status
510 ori \new_status, \new_status, %lo(_Nios2_ISR_Status_bits)
511 wrctl status, \new_status
512 .endm
513
514#endif /* ASM */
515
516#endif /* _RTEMS_SCORE_NIOS2_UTILITY_H */
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:27
ssize_t write(int fd, const void *buffer, size_t count)
Definition: write.c:30
bool _Nios2_MPU_Add_region(const Nios2_MPU_Configuration *config, const Nios2_MPU_Region_descriptor *desc, bool force)
Adds a region according to region descriptor desc.
Definition: nios2-mpu-add-region.c:71
char _Nios2_ISR_Status_bits[]
This symbol specifies the status register bits used to disable interrupts.
char _Nios2_ISR_Status_mask[]
This global symbol specifies the status register mask used to disable interrupts.
int _Nios2_MPU_Get_disabled_region_index(const Nios2_MPU_Configuration *config, bool data, int begin, int end)
Searches the region table part for a disabled region.
Definition: nios2-mpu-add-region.c:39
Nios II specific thread dispatch disabled indicator.
Definition: nios2-thread-dispatch-disabled.c:50
Definition: nios2-utility.h:317
Definition: nios2-utility.h:345
Definition: deflate.c:115
