RTEMS 5.2-rc1
MDOS Date Conversion. More...
| void | msdos_date_unix2dos (unsigned int t, uint16_t *ddp, uint16_t *dtp) |
| unsigned int | msdos_date_dos2unix (unsigned int dd, unsigned int dt) |
| ssize_t | msdos_filename_utf8_to_long_name_for_compare (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, uint8_t *long_name, const size_t long_name_size) |
| ssize_t | msdos_filename_utf8_to_long_name_for_save (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, uint16_t *long_name, const size_t long_name_size) |
| ssize_t | msdos_filename_utf8_to_short_name_for_compare (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, void *short_name, const size_t short_name_size) |
| ssize_t | msdos_filename_utf8_to_short_name_for_save (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, void *short_name, const size_t short_name_size) |
