RTEMS 5.2-rc1
mscan-base.h
1
9/*
10 * Copyright (c) 2008
11 * Embedded Brains GmbH
12 * Obere Lagerstr. 30
13 * D-82178 Puchheim
14 * Germany
15 * rtems@embedded-brains.de
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef LIBBSP_MSCAN_BASE_H
23#define LIBBSP_MSCAN_BASE_H
24
25#include <stdbool.h>
26
27#include <bsp/mpc5200.h>
28
37#define MSCAN_BIT_RATE_MIN 10000
38
39#define MSCAN_BIT_RATE_MAX 1000000
40
41#define MSCAN_BIT_RATE_DEFAULT 125000
42
43#define MSCAN_FILTER_NUMBER_MIN 0
44
45#define MSCAN_FILTER_NUMBER_2 2
46
47#define MSCAN_FILTER_NUMBER_4 4
48
49#define MSCAN_FILTER_NUMBER_MAX 8
50
51#define MSCAN_FILTER_ID_DEFAULT 0U
52
53#define MSCAN_FILTER_MASK_DEFAULT 0xffffffffU
54
55#define MSCAN_TRANSMIT_BUFFER_NUMBER 3
56
63#define CTL0_RXFRM (1 << 7)
64#define CTL0_RXACT (1 << 6)
65#define CTL0_CSWAI (1 << 5)
66#define CTL0_SYNCH (1 << 4)
67#define CTL0_TIME (1 << 3)
68#define CTL0_WUPE (1 << 2)
69#define CTL0_SLPRQ (1 << 1)
70#define CTL0_INITRQ (1 << 0)
71
80#define CTL1_CANE (1 << 7)
81#define CTL1_CLKSRC (1 << 6)
82#define CTL1_LOOPB (1 << 5)
83#define CTL1_LISTEN (1 << 4)
84#define CTL1_WUPM (1 << 2)
85#define CTL1_SLPAK (1 << 1)
86#define CTL1_INITAK (1 << 0)
87
96#define BTR0_SJW_MASK 0xc0
97#define BTR0_BRP_MASK 0x3f
98
99#define BTR0_SJW( btr0) ((btr0) << 6)
100#define BTR0_BRP( btr0) ((btr0) << 0)
101
102#define BTR0_GET_SJW( btr0) (((btr0) & BTR0_SJW_MASK) >> 6)
103#define BTR0_GET_BRP( btr0) (((btr0) & BTR0_BRP_MASK) >> 0)
104
113#define BTR1_SAMP_MASK 0x80
114#define BTR1_TSEG1_MASK 0x0f
115#define BTR1_TSEG2_MASK 0x70
116
117#define BTR1_SAMP (1 << 7)
118#define BTR1_TSEG1( btr1) ((btr1) << 0)
119#define BTR1_TSEG2( btr1) ((btr1) << 4)
120
121#define BTR1_GET_TSEG1( btr0) (((btr0) & BTR1_TSEG1_MASK) >> 0)
122#define BTR1_GET_TSEG2( btr0) (((btr0) & BTR1_TSEG2_MASK) >> 4)
123
132#define RFLG_WUPIF (1 << 7)
133#define RFLG_CSCIF (1 << 6)
134#define RFLG_RSTAT_MASK (3 << 4)
135#define RFLG_RSTAT_OK (0 << 4)
136#define RFLG_RSTAT_WRN (1 << 4)
137#define RFLG_RSTAT_ERR (2 << 4)
138#define RFLG_RSTAT_OFF (3 << 4)
139#define RFLG_TSTAT_MASK (3 << 2)
140#define RFLG_TSTAT_OK (0 << 2)
141#define RFLG_TSTAT_WRN (1 << 2)
142#define RFLG_TSTAT_ERR (2 << 2)
143#define RFLG_TSTAT_OFF (3 << 2)
144#define RFLG_OVRIF (1 << 1)
145#define RFLG_RXF (1 << 0)
146#define RFLG_GET_RX_STATE(rflg) (((rflg) >> 4) & 0x03)
147#define RFLG_GET_TX_STATE(rflg) (((rflg) >> 2) & 0x03)
148
157#define RIER_WUPIE (1 << 7)
158#define RIER_CSCIE (1 << 6)
159#define RIER_RSTAT(rier) ((rier) << 4)
160#define RIER_TSTAT(rier) ((rier) << 2)
161#define RIER_OVRIE (1 << 1)
162#define RIER_RXFIE (1 << 0)
163
172#define TFLG_TXE2 (1 << 2)
173#define TFLG_TXE1 (1 << 1)
174#define TFLG_TXE0 (1 << 0)
175
184#define TIER_TXEI2 (1 << 2)
185#define TIER_TXEI1 (1 << 1)
186#define TIER_TXEI0 (1 << 0)
187
196#define TARQ_ABTRQ2 (1 << 2)
197#define TARQ_ABTRQ1 (1 << 1)
198#define TARQ_ABTRQ0 (1 << 0)
199
208#define TAAK_ABTRQ2 (1 << 2)
209#define TAAK_ABTRQ1 (1 << 1)
210#define TAAK_ABTRQ0 (1 << 0)
211
220#define BSEL_TX2 (1 << 2)
221#define BSEL_TX1 (1 << 1)
222#define BSEL_TX0 (1 << 0)
223
232#define IDAC_IDAM1 (1 << 5)
233#define IDAC_IDAM0 (1 << 4)
234#define IDAC_IDAM (IDAC_IDAM1 | IDAC_IDAM0)
235#define IDAC_IDHIT( idac) ((idac) & 0x7)
236
242typedef struct mpc5200_mscan mscan;
243
248typedef struct {
249 uint8_t ctl0;
250 uint8_t rier;
251 uint8_t tier;
253
254bool mscan_enable( volatile mscan *m, unsigned bit_rate);
255
256void mscan_disable( volatile mscan *m);
257
258void mscan_interrupts_disable( volatile mscan *m);
259
260bool mscan_set_bit_rate( volatile mscan *m, unsigned bit_rate);
261
263
265
266void mscan_sleep_mode_enter( volatile mscan *m);
267
268void mscan_sleep_mode_leave( volatile mscan *m);
269
270volatile uint8_t *mscan_id_acceptance_register( volatile mscan *m, unsigned i);
271
272volatile uint8_t *mscan_id_mask_register( volatile mscan *m, unsigned i);
273
274unsigned mscan_filter_number( volatile mscan *m);
275
276bool mscan_set_filter_number( volatile mscan *m, unsigned number);
277
278bool mscan_filter_operation( volatile mscan *m, bool set, unsigned index, uint32_t *id, uint32_t *mask);
279
280void mscan_filter_clear( volatile mscan *m);
281
282void mscan_get_error_counters( volatile mscan *m, unsigned *rec, unsigned *tec);
283
286#endif /* LIBBSP_MSCAN_BASE_H */
void mscan_get_error_counters(volatile mscan *m, unsigned *rec, unsigned *tec)
Returns the receiver and transmitter error counter values in rec and tec of MSCAN module m.
Definition: mscan-base.c:536
void mscan_sleep_mode_leave(volatile mscan *m)
Leave sleep mode for the MSCAN module m.
Definition: mscan-base.c:271
void mscan_initialization_mode_leave(volatile mscan *m, const mscan_context *context)
Leave initialization mode for the MSCAN module m.
Definition: mscan-base.c:240
volatile uint8_t * mscan_id_acceptance_register(volatile mscan *m, unsigned i)
Returns the address of the CANIDAR register with index i of the MSCAN module m.
Definition: mscan-base.c:435
void mscan_initialization_mode_enter(volatile mscan *m, mscan_context *context)
Enter initialization mode for the MSCAN module m.
Definition: mscan-base.c:219
bool mscan_enable(volatile mscan *m, unsigned bit_rate)
Enables and initializes the MSCAN module m.
Definition: mscan-base.c:287
volatile uint8_t * mscan_id_mask_register(volatile mscan *m, unsigned i)
Returns the address of the CANIDMR register with index i of the MSCAN module m.
Definition: mscan-base.c:457
bool mscan_set_bit_rate(volatile mscan *m, unsigned bit_rate)
Sets the bit rate for the MSCAN module m to can_bit_rate in [bits/s].
Definition: mscan-base.c:143
bool mscan_set_filter_number(volatile mscan *m, unsigned number)
Sets the number of active filters of the MSCAN module m to number and returns true if number is valid...
Definition: mscan-base.c:396
MSCAN registers.
Definition: mscan-base.h:242
void mscan_interrupts_disable(volatile mscan *m)
Disables all interrupts for the MSCAN module m.
Definition: mscan-base.c:208
void mscan_sleep_mode_enter(volatile mscan *m)
Enter sleep mode for the MSCAN module m.
Definition: mscan-base.c:262
void mscan_disable(volatile mscan *m)
Disables the MSCAN module m.
Definition: mscan-base.c:320
unsigned mscan_filter_number(volatile mscan *m)
Returns the number of active filters of the MSCAN module m.
Definition: mscan-base.c:373
void mscan_filter_clear(volatile mscan *m)
Sets the filter ID and mask registers of the MSCAN module m to default values.
Definition: mscan-base.c:338
bool mscan_filter_operation(volatile mscan *m, bool set, unsigned index, uint32_t *id, uint32_t *mask)
Sets or gets the filter ID and mask in id and mask depending on set of MSCAN module m....
Definition: mscan-base.c:480
MSCAN context that has to be saved throughout the initialization mode.
Definition: mscan-base.h:248
unsigned context
Definition: tlb.h:1
