RTEMS 5.2-rc1
mpc8260.h
1/* buggy version of CPU */
2#define REV_0_2
3
4/*
5**************************************************************************
6**************************************************************************
7** **
8** MOTOROLA MPC8260 POWER QUAD INTEGRATED COMMUNICATIONS CONTROLLER **
9** POWERQUICC II **
10** **
11** HARDWARE DECLARATIONS **
12** **
13** **
14** Submitted by: **
15** Andy Dachs ** **
16** Surrey Satellite Technology Limited ** **
17** http://www.sstl.co.uk ** **
18** a.dachs@sstl.co.uk ** **
19** **
20** Based on previous submissions for other PPC variants by: **
21** **
22** Submitted By: **
23** **
24** W. Eric Norum **
25** Saskatchewan Accelerator Laboratory **
26** University of Saskatchewan **
27** 107 North Road **
28** Saskatoon, Saskatchewan, CANADA **
29** S7N 5C6 **
30** **
31** eric@skatter.usask.ca **
32** **
33** Modified for use with the MPC860 (original code was for MC68360) **
34** by **
35** Jay Monkman **
36** Frasca International, Inc. **
37** 906 E. Airport Rd. **
38** Urbana, IL, 61801 **
39** **
40** jmonkman@frasca.com **
41** **
42** **
43**************************************************************************
44**************************************************************************
45*/
46
47#ifndef _MPC8260_H
48#define _MPC8260_H
49
50#ifndef ASM
51/*
52 Macros for SPRs
53*/
54
55
56
57
58/*
59*************************************************************************
60* REGISTER SUBBLOCKS *
61*************************************************************************
62*/
63
64
65/*
66 * Memory controller registers
67 */
68typedef struct m8260MEMCRegisters_ {
69 uint32_t br;
70 uint32_t _or; /* or is a C++ keyword :( */
72
73
74/*
75 * Fast Communication Controller Registers
76*/
77typedef struct m8260FCCRegisters_ {
78 uint32_t gfmr;
79 uint32_t fpsmr;
80 uint16_t ftodr;
81 uint8_t fcc_pad0[2];
82 uint16_t fdsr;
83 uint8_t fcc_pad1[2];
84 uint32_t fcce;
85 uint32_t fccm;
86 uint8_t fccs;
87 uint8_t fcc_pad2[3];
88 uint8_t ftirr_phy0; /* n/a on FCC3 */
89 uint8_t ftirr_phy1; /* n/a on FCC3 */
90 uint8_t ftirr_phy2; /* n/a on FCC3 */
91 uint8_t ftirr_phy3; /* n/a on FCC3 */
93
94
95/*
96 * Serial Communications Controller registers
97 */
98typedef struct m8260SCCRegisters_ {
99 uint32_t gsmr_l;
100 uint32_t gsmr_h;
101 uint16_t psmr;
102 uint8_t scc_pad0[2];
103 uint16_t todr;
104 uint16_t dsr;
105 uint16_t scce;
106 uint8_t scc_pad2[2];
107 uint16_t sccm;
108 uint8_t scc_pad3[1];
109 uint8_t sccs;
110 uint8_t scc_pad1[8];
112
113/*
114 * Serial Management Controller registers
115 */
116typedef struct m8260SMCRegisters_ {
117 uint8_t smc_pad0[2];
118 uint16_t smcmr;
119 uint8_t smc_pad2[2];
120 uint8_t smce;
121 uint8_t smc_pad3[3];
122 uint8_t smcm;
123 uint8_t smc_pad1[5];
125
126
127/*
128 * Serial Interface With Time Slot Assigner Registers
129 */
130typedef struct m8260SIRegisters_ {
131 uint16_t siamr;
132 uint16_t sibmr;
133 uint16_t sicmr;
134 uint16_t sidmr;
135 uint8_t sigmr;
136 uint8_t si_pad0[1];
137 uint8_t sicmdr;
138 uint8_t si_pad1[1];
139 uint8_t sistr;
140 uint8_t si_pad2[1];
141 uint16_t sirsr;
143
144
145/*
146 * Multi Channel Controller registers
147 */
148typedef struct m8260MCCRegisters_ {
149 uint16_t mcce;
150 uint8_t mcc_pad2[2];
151 uint16_t mccm;
152 uint16_t mcc_pad0;
153 uint8_t mccf;
154 uint8_t mcc_pad1[7];
156
157
158/*
159*************************************************************************
160* RISC Timers *
161*************************************************************************
162*/
163/*
164typedef struct m8260TimerParms_ {
165 uint16_t tm_base;
166 uint16_t _tm_ptr;
167 uint16_t _r_tmr;
168 uint16_t _r_tmv;
169 uint32_t tm_cmd;
170 uint32_t tm_cnt;
171} m8260TimerParms_t;
172*/
173
174/*
175 * RISC Controller Configuration Register (RCCR)
176 * All other bits in this register are reserved.
177 */
178#define M8260_RCCR_TIME (1<<31) /* Enable timer */
179#define M8260_RCCR_TIMEP(x) ((x)<<24) /* Timer period */
180#define M8260_RCCR_DR1M (1<<23) /* IDMA Rqst 1 Mode */
181#define M8260_RCCR_DR2M (1<<22) /* IDMA Rqst 2 Mode */
182#define M8260_RCCR_DR1QP(x) ((x)<<20) /* IDMA1 Rqst Priority */
183#define M8260_RCCR_EIE (1<<19) /* External Interrupt Enable */
184#define M8260_RCCR_SCD (1<<18) /* Scheduler Configuration */
185#define M8260_RCCR_DR2QP(x) ((x)<<16) /* IDMA2 Rqst Priority */
186#define M8260_RCCR_ERAM(x) ((x)<<13) /* Enable RAM Microcode */
187#define M8260_RCCR_EDM1 (1<<11) /* DRQ1 Edge detect mode */
188#define M8260_RCCR_EDM2 (1<<10) /* DRQ2 Edge detect mode */
189#define M8260_RCCR_EDM3 (1<<9) /* DRQ3 Edge detect mode */
190#define M8260_RCCR_EDM4 (1<<8) /* DRQ4 Edge detect mode */
191#define M8260_RCCR_DR3M (1<<7) /* IDMA Rqst 1 Mode */
192#define M8260_RCCR_DR4M (1<<6) /* IDMA Rqst 2 Mode */
193#define M8260_RCCR_DR3QP(x) ((x)<<4) /* IDMA3 Rqst Priority */
194#define M8260_RCCR_DEM12 (1<<3) /* DONE1,2 Edge detect mode */
195#define M8260_RCCR_DEM34 (1<<2) /* DONE3,4 Edge detect mode */
196#define M8260_RCCR_DR4QP(x) (x) /* IDMA4 Rqst Priority */
197
198
199
200/*
201 * Command register
202 * Set up this register before issuing a M8260_CR_OP_SET_TIMER command.
203 */
204#if 0
205#define M8260_TM_CMD_V (1<<31) /* Set to enable timer */
206#define M8260_TM_CMD_R (1<<30) /* Set for automatic restart */
207#define M8260_TM_CMD_PWM (1<<29) /* Set for PWM operation */
208#define M8260_TM_CMD_TIMER(x) ((x)<<16) /* Select timer */
209#define M8260_TM_CMD_PERIOD(x) (x) /* Timer period (16 bits) */
210#endif
211
212/*
213*************************************************************************
214* DMA Controllers *
215*************************************************************************
216*/
217typedef struct m8260IDMAparms_ {
218 uint16_t ibase;
219 uint16_t dcm;
220 uint16_t ibdptr;
221 uint16_t dpr_buf;
222 uint16_t _buf_inv;
223 uint16_t ssmax;
224 uint16_t _dpr_in_ptr;
225 uint16_t sts;
226 uint16_t _dpr_out_ptr;
227 uint16_t seob;
228 uint16_t deob;
229 uint16_t dts;
230 uint16_t _ret_add;
231 uint16_t reserved;
232 uint32_t _bd_cnt;
233 uint32_t _s_ptr;
234 uint32_t _d_ptr;
235 uint32_t istate;
237
238
239/*
240*************************************************************************
241* Serial Communication Controllers *
242*************************************************************************
243*/
244
245
246typedef struct m8260SCCparms_ {
247 uint16_t rbase;
248 uint16_t tbase;
249 uint8_t rfcr;
250 uint8_t tfcr;
251 uint16_t mrblr;
252 uint32_t _rstate;
253 uint32_t _pad0;
254 uint16_t _rbptr;
255 uint16_t _pad1;
256 uint32_t _pad2;
257 uint32_t _tstate;
258 uint32_t _pad3;
259 uint16_t _tbptr;
260 uint16_t _pad4;
261 uint32_t _pad5;
262 uint32_t _rcrc;
263 uint32_t _tcrc;
264 union {
265 struct {
266 uint32_t _res0;
267 uint32_t _res1;
268 uint16_t max_idl;
269 uint16_t idlc;
270 uint16_t brkcr;
271 uint16_t parec;
272 uint16_t frmec;
273 uint16_t nosec;
274 uint16_t brkec;
275 uint16_t brklen;
276 uint16_t uaddr[2];
277 uint16_t rtemp;
278 uint16_t toseq;
279 uint16_t character[8];
280 uint16_t rccm;
281 uint16_t rccr;
282 uint16_t rlbc;
283 } uart;
284 struct {
285 uint32_t _pad0;
286 uint32_t c_mask;
287 uint32_t c_pres;
288 uint16_t disfc;
289 uint16_t crcec;
290 uint16_t abtsc;
291 uint16_t nmarc;
292 uint16_t retrc;
293 uint16_t mflr;
294 uint16_t _max_cnt;
295 uint16_t rfthr;
296 uint16_t _rfcnt;
297 uint16_t hmask;
298 uint16_t haddr1;
299 uint16_t haddr2;
300 uint16_t haddr3;
301 uint16_t haddr4;
302 uint16_t _tmp;
303 uint16_t _tmp_mb;
304 } hdlc;
305 struct {
306 uint32_t _pad0;
307 uint32_t crcc;
308 uint16_t prcrc;
309 uint16_t ptcrc;
310 uint16_t parec;
311 uint16_t bsync;
312 uint16_t bdle;
313 uint16_t character[8];
314 uint16_t rccm;
315 } bisync;
316 struct {
317 uint32_t _crc_p;
318 uint32_t _crc_c;
319 } transparent;
320 struct {
321 uint32_t c_pres;
322 uint32_t c_mask;
323 uint32_t crcec;
324 uint32_t alec;
325 uint32_t disfc;
326 uint16_t pads;
327 uint16_t ret_lim;
328 uint16_t _ret_cnt;
329 uint16_t mflr;
330 uint16_t minflr;
331 uint16_t maxd1;
332 uint16_t maxd2;
333 uint16_t _maxd;
334 uint16_t _dma_cnt;
335 uint16_t _max_b;
336 uint16_t gaddr1;
337 uint16_t gaddr2;
338 uint16_t gaddr3;
339 uint16_t gaddr4;
340 uint32_t _tbuf0data0;
341 uint32_t _tbuf0data1;
342 uint32_t _tbuf0rba0;
343 uint32_t _tbuf0crc;
344 uint16_t _tbuf0bcnt;
345 uint16_t paddr_h;
346 uint16_t paddr_m;
347 uint16_t paddr_l;
348 uint16_t p_per;
349 uint16_t _rfbd_ptr;
350 uint16_t _tfbd_ptr;
351 uint16_t _tlbd_ptr;
352 uint32_t _tbuf1data0;
353 uint32_t _tbuf1data1;
354 uint32_t _tbuf1rba0;
355 uint32_t _tbuf1crc;
356 uint16_t _tbuf1bcnt;
357 uint16_t _tx_len;
358 uint16_t iaddr1;
359 uint16_t iaddr2;
360 uint16_t iaddr3;
361 uint16_t iaddr4;
362 uint16_t _boff_cnt;
363 uint16_t taddr_l;
364 uint16_t taddr_m;
365 uint16_t taddr_h;
366 } ethernet;
367 } un;
369
370
371/*
372 * Event and mask registers (SCCE, SCCM)
373 */
374#define M8260_SCCE_BRKE (1<<6)
375#define M8260_SCCE_BRK (1<<5)
376#define M8260_SCCE_TXE (1<<4)
377#define M8260_SCCE_RXF (1<<3)
378#define M8260_SCCE_BSY (1<<2)
379#define M8260_SCCE_TX (1<<1)
380#define M8260_SCCE_RX (1<<0)
381
382
383/*
384*************************************************************************
385* Fast Serial Communication Controllers *
386*************************************************************************
387*/
388
389
390typedef struct m8260FCCparms_ {
391 uint16_t riptr;
392 uint16_t tiptr;
393 uint16_t _pad0;
394 uint16_t mrblr;
395 uint32_t rstate;
396 uint32_t rbase;
397 uint16_t _rbdstat;
398 uint16_t _rbdlen;
399 uint32_t _rdptr;
400 uint32_t tstate;
401 uint32_t tbase;
402 uint16_t _tbdstat;
403 uint16_t _tbdlen;
404 uint32_t _tdptr;
405 uint32_t _rbptr;
406 uint32_t _tbptr;
407 uint32_t _rcrc;
408 uint32_t _pad1;
409 uint32_t _tcrc;
410
411 union {
412 struct {
413 uint32_t _pad0;
414 uint32_t _pad1;
415 uint32_t c_mask;
416 uint32_t c_pres;
417 uint16_t disfc;
418 uint16_t crcec;
419 uint16_t abtsc;
420 uint16_t nmarc;
421 uint32_t _max_cnt;
422 uint16_t mflr;
423 uint16_t rfthr;
424 uint16_t rfcnt;
425 uint16_t hmask;
426 uint16_t haddr1;
427 uint16_t haddr2;
428 uint16_t haddr3;
429 uint16_t haddr4;
430 uint16_t _ts_tmp;
431 uint16_t _tmp_mb;
432 } hdlc;
433 struct {
434 uint32_t _pad0;
435 uint32_t _pad1;
436 uint32_t c_mask;
437 uint32_t c_pres;
438 uint16_t disfc;
439 uint16_t crcec;
440 uint16_t abtsc;
441 uint16_t nmarc;
442 uint32_t _max_cnt;
443 uint16_t mflr;
444 uint16_t rfthr;
445 uint16_t rfcnt;
446 uint16_t hmask;
447 uint16_t haddr1;
448 uint16_t haddr2;
449 uint16_t haddr3;
450 uint16_t haddr4;
451 uint16_t _ts_tmp;
452 uint16_t _tmp_mb;
453 } transparent;
454 struct {
455 uint32_t _stat_buf;
456 uint32_t cam_ptr;
457 uint32_t c_mask;
458 uint32_t c_pres;
459 uint32_t crcec;
460 uint32_t alec;
461 uint32_t disfc;
462 uint16_t ret_lim;
463 uint16_t _ret_cnt;
464 uint16_t p_per;
465 uint16_t _boff_cnt;
466 uint32_t gaddr_h;
467 uint32_t gaddr_l;
468 uint16_t tfcstat;
469 uint16_t tfclen;
470 uint32_t tfcptr;
471 uint16_t mflr;
472 uint16_t paddr1_h;
473 uint16_t paddr1_m;
474 uint16_t paddr1_l;
475 uint16_t _ibd_cnt;
476 uint16_t _ibd_start;
477 uint16_t _ibd_end;
478 uint16_t _tx_len;
479 uint16_t _ibd_base;
480 uint32_t iaddr_h;
481 uint32_t iaddr_l;
482 uint16_t minflr;
483 uint16_t taddr_h;
484 uint16_t taddr_m;
485 uint16_t taddr_l;
486 uint16_t pad_ptr;
487 uint16_t _pad0;
488 uint16_t _cf_range;
489 uint16_t _max_b;
490 uint16_t maxd1;
491 uint16_t maxd2;
492 uint16_t _maxd;
493 uint16_t _dma_cnt;
494 uint32_t octc;
495 uint32_t colc;
496 uint32_t broc;
497 uint32_t mulc;
498 uint32_t uspc;
499 uint32_t frgc;
500 uint32_t ospc;
501 uint32_t jbrc;
502 uint32_t p64c;
503 uint32_t p65c;
504 uint32_t p128c;
505 uint32_t p256c;
506 uint32_t p512c;
507 uint32_t p1024c;
508 uint32_t _cam_buf;
509 uint32_t _pad1;
510 } ethernet;
511 } un;
513
514
515/*
516 * Receive and transmit function code register bits
517 * These apply to the function code registers of all devices, not just SCC.
518 */
519#define M8260_RFCR_BO(x) ((x)<<3)
520#define M8260_RFCR_MOT (2<<3)
521#define M8260_RFCR_LOCAL_BUS (2)
522#define M8260_RFCR_60X_BUS (0)
523#define M8260_TFCR_BO(x) ((x)<<3)
524#define M8260_TFCR_MOT (2<<3)
525#define M8260_TFCR_LOCAL_BUS (2)
526#define M8260_TFCR_60X_BUS (0)
527
528/*
529*************************************************************************
530* Serial Management Controllers *
531*************************************************************************
532*/
533typedef struct m8260SMCparms_ {
534 uint16_t rbase;
535 uint16_t tbase;
536 uint8_t rfcr;
537 uint8_t tfcr;
538 uint16_t mrblr;
539 uint32_t _rstate;
540 uint32_t _pad0;
541 uint16_t _rbptr;
542 uint16_t _pad1;
543 uint32_t _pad2;
544 uint32_t _tstate;
545 uint32_t _pad3;
546 uint16_t _tbptr;
547 uint16_t _pad4;
548 uint32_t _pad5;
549 union {
550 struct {
551 uint16_t max_idl;
552 uint16_t _idlc;
553 uint16_t _brkln;
554 uint16_t brkec;
555 uint16_t brkcr;
556 uint16_t _r_mask;
557 } uart;
558 struct {
559 uint16_t _pad0[6];
560 } transparent;
561 } un;
562 uint32_t _pad6;
564
565/*
566 * Mode register
567 */
568#define M8260_SMCMR_CLEN(x) ((x)<<11) /* Character length */
569#define M8260_SMCMR_2STOP (1<<10) /* 2 stop bits */
570#define M8260_SMCMR_PARITY (1<<9) /* Enable parity */
571#define M8260_SMCMR_EVEN (1<<8) /* Even parity */
572#define M8260_SMCMR_SM_GCI (0<<4) /* GCI Mode */
573#define M8260_SMCMR_SM_UART (2<<4) /* UART Mode */
574#define M8260_SMCMR_SM_TRANSPARENT (3<<4) /* Transparent Mode */
575#define M8260_SMCMR_DM_LOOPBACK (1<<2) /* Local loopback mode */
576#define M8260_SMCMR_DM_ECHO (2<<2) /* Echo mode */
577#define M8260_SMCMR_TEN (1<<1) /* Enable transmitter */
578#define M8260_SMCMR_REN (1<<0) /* Enable receiver */
579
580/*
581 * Event and mask registers (SMCE, SMCM)
582 */
583#define M8260_SMCE_TXE (1<<4)
584#define M8260_SMCE_BSY (1<<2)
585#define M8260_SMCE_TX (1<<1)
586#define M8260_SMCE_RX (1<<0)
587
588/*
589*************************************************************************
590* Serial Peripheral Interface *
591*************************************************************************
592*/
593typedef struct m8260SPIparms_ {
594 uint16_t rbase;
595 uint16_t tbase;
596 uint8_t rfcr;
597 uint8_t tfcr;
598 uint16_t mrblr;
599 uint32_t _rstate;
600 uint32_t _pad0;
601 uint16_t _rbptr;
602 uint16_t _pad1;
603 uint32_t _pad2;
604 uint32_t _tstate;
605 uint32_t _pad3;
606 uint16_t _tbptr;
607 uint16_t _pad4;
608 uint32_t _pad5;
610
611/*
612 * Mode register (SPMODE)
613 */
614#define M8260_SPMODE_LOOP (1<<14) /* Local loopback mode */
615#define M8260_SPMODE_CI (1<<13) /* Clock invert */
616#define M8260_SPMODE_CP (1<<12) /* Clock phase */
617#define M8260_SPMODE_DIV16 (1<<11) /* Divide BRGCLK by 16 */
618#define M8260_SPMODE_REV (1<<10) /* Reverse data */
619#define M8260_SPMODE_MASTER (1<<9) /* SPI is master */
620#define M8260_SPMODE_EN (1<<8) /* Enable SPI */
621#define M8260_SPMODE_CLEN(x) ((x)<<4) /* Character length */
622#define M8260_SPMODE_PM(x) (x) /* Prescaler modulus */
623
624/*
625 * Mode register (SPCOM)
626 */
627#define M8260_SPCOM_STR (1<<7) /* Start transmit */
628
629/*
630 * Event and mask registers (SPIE, SPIM)
631 */
632#define M8260_SPIE_MME (1<<5) /* Multi-master error */
633#define M8260_SPIE_TXE (1<<4) /* Tx error */
634#define M8260_SPIE_BSY (1<<2) /* Busy condition*/
635#define M8260_SPIE_TXB (1<<1) /* Tx buffer */
636#define M8260_SPIE_RXB (1<<0) /* Rx buffer */
637
638/*
639*************************************************************************
640* SDMA (SCC, SMC, SPI) Buffer Descriptors *
641*************************************************************************
642*/
644 uint16_t status;
645 uint16_t length;
646 volatile void *buffer;
648
649/*
650 * Bits in receive buffer descriptor status word
651 */
652#define M8260_BD_EMPTY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
653#define M8260_BD_WRAP (1<<13) /* Ethernet, SCC UART, SMC UART, SPI */
654#define M8260_BD_INTERRUPT (1<<12) /* Ethernet, SCC UART, SMC UART, SPI */
655#define M8260_BD_LAST (1<<11) /* Ethernet, SPI */
656#define M8260_BD_CONTROL_CHAR (1<<11) /* SCC UART */
657#define M8260_BD_FIRST_IN_FRAME (1<<10) /* Ethernet */
658#define M8260_BD_ADDRESS (1<<10) /* SCC UART */
659#define M8260_BD_CONTINUOUS (1<<9) /* SCC UART, SMC UART, SPI */
660#define M8260_BD_MISS (1<<8) /* Ethernet */
661#define M8260_BD_IDLE (1<<8) /* SCC UART, SMC UART */
662#define M8260_BD_ADDRSS_MATCH (1<<7) /* SCC UART */
663#define M8260_BD_LONG (1<<5) /* Ethernet, SCC HDLC */
664#define M8260_BD_BREAK (1<<5) /* SCC UART, SMC UART */
665#define M8260_BD_NONALIGNED (1<<4) /* Ethernet, SCC HDLC */
666#define M8260_BD_FRAMING_ERROR (1<<4) /* SCC UART, SMC UART */
667#define M8260_BD_SHORT (1<<3) /* Ethernet */
668#define M8260_BD_PARITY_ERROR (1<<3) /* SCC UART, SMC UART */
669#define M8260_BD_ABORT (1<<3) /* SCC HDLC */
670#define M8260_BD_CRC_ERROR (1<<2) /* Ethernet, SCC HDLC */
671#define M8260_BD_OVERRUN (1<<1) /* Ethernet, SCC UART, SMC UART, SPI */
672#define M8260_BD_COLLISION (1<<0) /* Ethernet */
673#define M8260_BD_CARRIER_LOST (1<<0) /* SCC UART, SMC UART */
674#define M8260_BD_MASTER_ERROR (1<<0) /* SPI */
675
676#define M8xx_BD_EMPTY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
677#define M8xx_BD_WRAP (1<<13) /* Ethernet, SCC UART, SMC UART, SPI */
678#define M8xx_BD_INTERRUPT (1<<12) /* Ethernet, SCC UART, SMC UART, SPI */
679#define M8xx_BD_LAST (1<<11) /* Ethernet, SPI */
680#define M8xx_BD_CONTROL_CHAR (1<<11) /* SCC UART */
681#define M8xx_BD_FIRST_IN_FRAME (1<<10) /* Ethernet */
682#define M8xx_BD_ADDRESS (1<<10) /* SCC UART */
683#define M8xx_BD_CONTINUOUS (1<<9) /* SCC UART, SMC UART, SPI */
684#define M8xx_BD_MISS (1<<8) /* Ethernet */
685#define M8xx_BD_IDLE (1<<8) /* SCC UART, SMC UART */
686#define M8xx_BD_ADDRSS_MATCH (1<<7) /* SCC UART */
687#define M8xx_BD_LONG (1<<5) /* Ethernet, SCC HDLC */
688#define M8xx_BD_BREAK (1<<5) /* SCC UART, SMC UART */
689#define M8xx_BD_NONALIGNED (1<<4) /* Ethernet, SCC HDLC */
690#define M8xx_BD_FRAMING_ERROR (1<<4) /* SCC UART, SMC UART */
691#define M8xx_BD_SHORT (1<<3) /* Ethernet */
692#define M8xx_BD_PARITY_ERROR (1<<3) /* SCC UART, SMC UART */
693#define M8xx_BD_ABORT (1<<3) /* SCC HDLC */
694#define M8xx_BD_CRC_ERROR (1<<2) /* Ethernet, SCC HDLC */
695#define M8xx_BD_OVERRUN (1<<1) /* Ethernet, SCC UART, SMC UART, SPI */
696#define M8xx_BD_COLLISION (1<<0) /* Ethernet */
697#define M8xx_BD_CARRIER_LOST (1<<0) /* SCC UART, SMC UART */
698#define M8xx_BD_MASTER_ERROR (1<<0) /* SPI */
699
700/*
701 * Bits in transmit buffer descriptor status word
702 * Many bits have the same meaning as those in receiver buffer descriptors.
703 */
704#define M8260_BD_READY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
705#define M8260_BD_PAD (1<<14) /* Ethernet */
706#define M8260_BD_CTS_REPORT (1<<11) /* SCC UART */
707#define M8260_BD_TX_CRC (1<<10) /* Ethernet */
708#define M8260_BD_DEFER (1<<9) /* Ethernet */
709#define M8260_BD_HEARTBEAT (1<<8) /* Ethernet */
710#define M8260_BD_PREAMBLE (1<<8) /* SCC UART, SMC UART */
711#define M8260_BD_LATE_COLLISION (1<<7) /* Ethernet */
712#define M8260_BD_NO_STOP_BIT (1<<7) /* SCC UART */
713#define M8260_BD_RETRY_LIMIT (1<<6) /* Ethernet */
714#define M8260_BD_RETRY_COUNT(x) (((x)&0x3C)>>2) /* Ethernet */
715#define M8260_BD_UNDERRUN (1<<1) /* Ethernet, SPI, SCC HDLC */
716#define M8260_BD_CARRIER_LOST (1<<0) /* Ethernet */
717#define M8260_BD_CTS_LOST (1<<0) /* SCC UART, SCC HDLC */
718
719#define M8xx_BD_READY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
720#define M8xx_BD_PAD (1<<14) /* Ethernet */
721#define M8xx_BD_CTS_REPORT (1<<11) /* SCC UART */
722#define M8xx_BD_TX_CRC (1<<10) /* Ethernet */
723#define M8xx_BD_DEFER (1<<9) /* Ethernet */
724#define M8xx_BD_HEARTBEAT (1<<8) /* Ethernet */
725#define M8xx_BD_PREAMBLE (1<<8) /* SCC UART, SMC UART */
726#define M8xx_BD_LATE_COLLISION (1<<7) /* Ethernet */
727#define M8xx_BD_NO_STOP_BIT (1<<7) /* SCC UART */
728#define M8xx_BD_RETRY_LIMIT (1<<6) /* Ethernet */
729#define M8xx_BD_RETRY_COUNT(x) (((x)&0x3C)>>2) /* Ethernet */
730#define M8xx_BD_UNDERRUN (1<<1) /* Ethernet, SPI, SCC HDLC */
731#define M8xx_BD_CARRIER_LOST (1<<0) /* Ethernet */
732#define M8xx_BD_CTS_LOST (1<<0) /* SCC UART, SCC HDLC */
733
734/*
735*************************************************************************
736* IDMA Buffer Descriptors *
737*************************************************************************
738*/
740 uint16_t status;
741 uint8_t dfcr;
742 uint8_t sfcr;
743 uint32_t length;
744 void *source;
745 void *destination;
747
748/*
749*************************************************************************
750* RISC Communication Processor Module Command Register (CR) *
751*************************************************************************
752*/
753#define M8260_CR_RST (1<<31) /* Reset communication processor */
754
755#define M8260_CR_FCC1 ((4<<26)|(16<<21)) /* FCC1 page and code */
756#define M8260_CR_FCC1_ATM ((4<<26)|(14<<21)) /* FCC1 ATM mode page and code */
757#define M8260_CR_FCC2 ((5<<26)|(17<<21)) /* FCC2 page and code */
758#define M8260_CR_FCC2_ATM ((5<<26)|(14<<21)) /* FCC2 ATM mode page and code */
759#define M8260_CR_FCC3 ((6<<26)|(18<<21)) /* FCC3 page and code */
760#define M8260_CR_SCC1 ((0<<26)|(4<<21)) /* SCC1 page and code */
761#define M8260_CR_SCC2 ((1<<26)|(5<<21)) /* SCC2 page and code */
762#define M8260_CR_SCC3 ((2<<26)|(6<<21)) /* SCC3 page and code */
763#define M8260_CR_SCC4 ((3<<26)|(7<<21)) /* SCC4 page and code */
764#define M8260_CR_SMC1 ((7<<26)|(8<<21)) /* SMC1 page and code */
765#define M8260_CR_SMC2 ((8<<26)|(9<<21)) /* SMC2 page and code */
766#define M8260_CR_RAND ((10<<26)|(14<<21)) /* SMC2 page and code */
767#define M8260_CR_SPI ((9<<26)|(10<<21)) /* SPI page and code */
768#define M8260_CR_I2C ((10<<26)|(11<<21)) /* I2C page and code */
769#define M8260_CR_TMR ((10<<26)|(15<<21)) /* Timer page and code */
770#define M8260_CR_MCC1 ((7<<26)|(28<<21)) /* MCC1 page and code */
771#define M8260_CR_MCC2 ((8<<26)|(29<<21)) /* MCC2 page and code */
772#define M8260_CR_IDMA1 ((7<<26)|(20<<21)) /* IDMA1 page and code */
773#define M8260_CR_IDMA2 ((8<<26)|(21<<21)) /* IDMA2 page and code */
774#define M8260_CR_IDMA3 ((9<<26)|(22<<21)) /* IDMA3 page and code */
775#define M8260_CR_IDMA4 ((10<<26)|(23<<21)) /* IDMA4 page and code */
776
777#define M8260_CR_FLG (1<<16) /* Command sempahore flag */
778
779#define M8260_CR_MCC_CHAN(x) ((x)<<6) /* MCC channel number */
780#define M8260_CR_FCC_HDLC (0<<6) /* FCC HDLC/Transparent protocol code */
781#define M8260_CR_FCC_ATM (10<<6) /* FCC ATM protocol code */
782#define M8260_CR_FCC_ETH (12<<6) /* FCC Ethernet protocol code */
783
784#define M8260_CR_OP_INIT_RX_TX (0) /* FCC, SCC, SMC UART, SMC GCI, SPI, I2C, MCC */
785#define M8260_CR_OP_INIT_RX (1) /* FCC, SCC, SMC UART, SPI, I2C, MCC */
786#define M8260_CR_OP_INIT_TX (2) /* FCC, SCC, SMC UART, SPI, I2C, MCC */
787#define M8260_CR_OP_INIT_HUNT (3) /* FCC, SCC, SMC UART */
788#define M8260_CR_OP_STOP_TX (4) /* FCC, SCC, SMC UART, MCC */
789#define M8260_CR_OP_GR_STOP_TX (5) /* FCC, SCC */
790#define M8260_CR_OP_RESTART_TX (6) /* FCC, SCC, SMC UART */
791#define M8260_CR_OP_CLOSE_RX_BD (7) /* FCC, SCC, SMC UART, SPI, I2C */
792#define M8260_CR_OP_SET_GRP_ADDR (8) /* FCC, SCC */
793#define M8260_CR_OP_SET_TIMER (8) /* Timer */
794#define M8260_CR_OP_GCI_TIMEOUT (9) /* SMC GCI */
795#define M8260_CR_OP_START_IDMA (9) /* IDMA */
796#define M8260_CR_OP_STOP_RX (9) /* MCC */
797#define M8260_CR_OP_ATM_TX (10) /* FCC */
798#define M8260_CR_OP_RESET_BCS (10) /* SCC */
799#define M8260_CR_OP_GCI_ABORT (10) /* SMC GCI */
800#define M8260_CR_OP_STOP_IDMA (11) /* IDMA */
801#define M8260_CR_OP_RANDOM (12) /* RAND */
802
803/*
804*************************************************************************
805* System Protection Control Register (SYPCR) *
806*************************************************************************
807*/
808#define M8260_SYPCR_SWTC(x) ((x)<<16) /* Software watchdog timer count */
809#define M8260_SYPCR_BMT(x) ((x)<<8) /* Bus monitor timing */
810#define M8260_SYPCR_BME (1<<7) /* Bus monitor enable */
811#define M8260_SYPCR_SWF (1<<3) /* Software watchdog freeze */
812#define M8260_SYPCR_SWE (1<<2) /* Software watchdog enable */
813#define M8260_SYPCR_SWRI (1<<1) /* Watchdog reset/interrupt sel. */
814#define M8260_SYPCR_SWP (1<<0) /* Software watchdog prescale */
815
816/*
817*************************************************************************
818* Memory Control Registers *
819*************************************************************************
820*/
821#define M8260_UPM_AMX_8col (0<<20) /* 8 column DRAM */
822#define M8260_UPM_AMX_9col (1<<20) /* 9 column DRAM */
823#define M8260_UPM_AMX_10col (2<<20) /* 10 column DRAM */
824#define M8260_UPM_AMX_11col (3<<20) /* 11 column DRAM */
825#define M8260_UPM_AMX_12col (4<<20) /* 12 column DRAM */
826#define M8260_UPM_AMX_13col (5<<20) /* 13 column DRAM */
827#define M8260_MSR_PER(x) (0x100<<(7-x)) /* Perity error bank (x) */
828#define M8260_MSR_WPER (1<<7) /* Write protection error */
829#define M8260_MPTPR_PTP(x) ((x)<<8) /* Periodic timer prescaler */
830#define M8260_BR_BA(x) ((x)&0xffff8000) /* Base address */
831#define M8260_BR_AT(x) ((x)<<12) /* Address type */
832#define M8260_BR_PS8 (1<<10) /* 8 bit port */
833#define M8260_BR_PS16 (2<<10) /* 16 bit port */
834#define M8260_BR_PS32 (0<<10) /* 32 bit port */
835#define M8260_BR_PARE (1<<9) /* Parity checking enable */
836#define M8260_BR_WP (1<<8) /* Write protect */
837#define M8260_BR_MS_GPCM (0<<6) /* GPCM */
838#define M8260_BR_MS_UPMA (2<<6) /* UPM A */
839#define M8260_BR_MS_UPMB (3<<6) /* UPM B */
840#define M8260_MEMC_BR_V (1<<0) /* Base/Option register are valid */
841
842#define M8260_MEMC_OR_32K 0xffff8000 /* Address range */
843#define M8260_MEMC_OR_64K 0xffff0000
844#define M8260_MEMC_OR_128K 0xfffe0000
845#define M8260_MEMC_OR_256K 0xfffc0000
846#define M8260_MEMC_OR_512K 0xfff80000
847#define M8260_MEMC_OR_1M 0xfff00000
848#define M8260_MEMC_OR_2M 0xffe00000
849#define M8260_MEMC_OR_4M 0xffc00000
850#define M8260_MEMC_OR_8M 0xff800000
851#define M8260_MEMC_OR_16M 0xff000000
852#define M8260_MEMC_OR_32M 0xfe000000
853#define M8260_MEMC_OR_64M 0xfc000000
854#define M8260_MEMC_OR_128 0xf8000000
855#define M8260_MEMC_OR_256M 0xf0000000
856#define M8260_MEMC_OR_512M 0xe0000000
857#define M8260_MEMC_OR_1G 0xc0000000
858#define M8260_MEMC_OR_2G 0x80000000
859#define M8260_MEMC_OR_4G 0x00000000
860#define M8260_MEMC_OR_ATM(x) ((x)<<12) /* Address type mask */
861#define M8260_MEMC_OR_CSNT (1<<11) /* Chip select is negated early */
862#define M8260_MEMC_OR_SAM (1<<11) /* Address lines are multiplexed */
863#define M8260_MEMC_OR_ACS_NORM (0<<9) /* *CS asserted with addr lines */
864#define M8260_MEMC_OR_ACS_QRTR (2<<9) /* *CS asserted 1/4 after addr */
865#define M8260_MEMC_OR_ACS_HALF (3<<9) /* *CS asserted 1/2 after addr */
866#define M8260_MEMC_OR_BI (1<8) /* Burst inhibit */
867#define M8260_MEMC_OR_SCY(x) ((x)<<4) /* Cycle length in clocks */
868#define M8260_MEMC_OR_SETA (1<<3) /* *TA generated externally */
869#define M8260_MEMC_OR_TRLX (1<<2) /* Relaxed timing in GPCM */
870#define M8260_MEMC_OR_EHTR (1<<1) /* Extended hold time on reads */
871
872/*
873*************************************************************************
874* UPM Registers (MxMR) *
875*************************************************************************
876*/
877#define M8260_MEMC_MMR_PTP(x) ((x)<<24) /* Periodic timer period */
878#define M8260_MEMC_MMR_PTE (1<<23) /* Periodic timer enable */
879#define M8260_MEMC_MMR_DSP(x) ((x)<<17) /* Disable timer period */
880#define M8260_MEMC_MMR_G0CL(x) ((x)<<13) /* General line 0 control */
881#define M8260_MEMC_MMR_UPWAIT (1<<12) /* GPL_x4 is UPWAITx */
882#define M8260_MEMC_MMR_RLF(x) ((x)<<8) /* Read loop field */
883#define M8260_MEMC_MMR_WLF(x) ((x)<<4) /* Write loop field */
884#define M8260_MEMC_MMR_TLF(x) ((x)<<0) /* Timer loop field */
885/*
886*************************************************************************
887* Memory Command Register (MCR) *
888*************************************************************************
889*/
890#define M8260_MEMC_MCR_WRITE (0<<30) /* WRITE command */
891#define M8260_MEMC_MCR_READ (1<<30) /* READ command */
892#define M8260_MEMC_MCR_RUN (2<<30) /* RUN command */
893#define M8260_MEMC_MCR_UPMA (0<<23) /* Cmd is for UPMA */
894#define M8260_MEMC_MCR_UPMB (1<<23) /* Cmd is for UPMB */
895#define M8260_MEMC_MCR_MB(x) ((x)<<13) /* Memory bank when RUN cmd */
896#define M8260_MEMC_MCR_MCLF(x) ((x)<<8) /* Memory command loop field */
897#define M8260_MEMC_MCR_MAD(x) (x) /* Machine address */
898
899
900
901/*
902*************************************************************************
903* SI Mode Register (SIMODE) *
904*************************************************************************
905*/
906#define M8260_SI_SMC2_BITS 0xFFFF0000 /* All SMC2 bits */
907#define M8260_SI_SMC2_TDM (1<<31) /* Multiplexed SMC2 */
908#define M8260_SI_SMC2_BRG1 (0<<28) /* SMC2 clock souce */
909#define M8260_SI_SMC2_BRG2 (1<<28)
910#define M8260_SI_SMC2_BRG3 (2<<28)
911#define M8260_SI_SMC2_BRG4 (3<<28)
912#define M8260_SI_SMC2_CLK5 (0<<28)
913#define M8260_SI_SMC2_CLK6 (1<<28)
914#define M8260_SI_SMC2_CLK7 (2<<28)
915#define M8260_SI_SMC2_CLK8 (3<<28)
916#define M8260_SI_SMC1_BITS 0x0000FFFF /* All SMC1 bits */
917#define M8260_SI_SMC1_TDM (1<<15) /* Multiplexed SMC1 */
918#define M8260_SI_SMC1_BRG1 (0<<12) /* SMC1 clock souce */
919#define M8260_SI_SMC1_BRG2 (1<<12)
920#define M8260_SI_SMC1_BRG3 (2<<12)
921#define M8260_SI_SMC1_BRG4 (3<<12)
922#define M8260_SI_SMC1_CLK1 (0<<12)
923#define M8260_SI_SMC1_CLK2 (1<<12)
924#define M8260_SI_SMC1_CLK3 (2<<12)
925#define M8260_SI_SMC1_CLK4 (3<<12)
926
927/*
928*************************************************************************
929* SDMA Configuration Register (SDCR) *
930*************************************************************************
931*/
932#define M8260_SDCR_FREEZE (2<<13) /* Freeze on next bus cycle */
933#define M8260_SDCR_RAID_5 (1<<0) /* Normal arbitration ID */
934
935/*
936*************************************************************************
937* SDMA Status Register (SDSR) *
938*************************************************************************
939*/
940#define M8260_SDSR_SBER (1<<7) /* SDMA Channel bus error */
941#define M8260_SDSR_DSP2 (1<<1) /* DSP Chain 2 interrupt */
942#define M8260_SDSR_DSP1 (1<<0) /* DSP Chain 1 interrupt */
943
944/*
945*************************************************************************
946* Baud (sic) Rate Generators *
947*************************************************************************
948*/
949#define M8260_BRG_RST (1<<17) /* Reset generator */
950#define M8260_BRG_EN (1<<16) /* Enable generator */
951#define M8260_BRG_EXTC_BRGCLK (0<<14) /* Source is BRGCLK */
952#define M8260_BRG_EXTC_CLK2 (1<<14) /* Source is CLK2 pin */
953#define M8260_BRG_EXTC_CLK6 (2<<14) /* Source is CLK6 pin */
954#define M8260_BRG_ATB (1<<13) /* Autobaud */
955#define M8260_BRG_115200 (21<<1) /* Assume 40 MHz clock */
956#define M8260_BRG_57600 (32<<1)
957#define M8260_BRG_38400 (64<<1)
958#define M8260_BRG_19200 (129<<1)
959#define M8260_BRG_9600 (259<<1)
960#define M8260_BRG_4800 (520<<1)
961#define M8260_BRG_2400 (1040<<1)
962#define M8260_BRG_1200 (2082<<1)
963#define M8260_BRG_600 ((259<<1) | 1)
964#define M8260_BRG_300 ((520<<1) | 1)
965#define M8260_BRG_150 ((1040<<1) | 1)
966#define M8260_BRG_75 ((2080<<1) | 1)
967
968#define M8xx_BRG_RST (1<<17) /* Reset generator */
969#define M8xx_BRG_EN (1<<16) /* Enable generator */
970#define M8xx_BRG_EXTC_BRGCLK (0<<14) /* Source is BRGCLK */
971
972#define M8260_BRG1 (1<<7)
973#define M8260_BRG2 (1<<6)
974#define M8260_BRG3 (1<<5)
975#define M8260_BRG4 (1<<4)
976#define M8260_BRG5 (1<<3)
977#define M8260_BRG6 (1<<2)
978#define M8260_BRG7 (1<<1)
979#define M8260_BRG8 (1<<0)
980
981
982
983#define M8260_TGCR_CAS4 (1<<15) /* Cascade timers 3 and 4 */
984#define M8260_TGCR_CAS2 (1<<7) /* Cascade timers 1 and 2 */
985#define M8260_TGCR_FRZ1 (1<<2) /* Halt timer if FREEZE asserted */
986#define M8260_TGCR_FRZ2 (1<<6) /* Halt timer if FREEZE asserted */
987#define M8260_TGCR_FRZ3 (1<<10) /* Halt timer if FREEZE asserted */
988#define M8260_TGCR_FRZ4 (1<<14) /* Halt timer if FREEZE asserted */
989#define M8260_TGCR_STP1 (1<<1) /* Stop timer */
990#define M8260_TGCR_STP2 (1<<5) /* Stop timer */
991#define M8260_TGCR_STP3 (1<<9) /* Stop timer */
992#define M8260_TGCR_STP4 (1<<13) /* Stop timer */
993#define M8260_TGCR_RST1 (1<<0) /* Enable timer */
994#define M8260_TGCR_RST2 (1<<4) /* Enable timer */
995#define M8260_TGCR_RST3 (1<<8) /* Enable timer */
996#define M8260_TGCR_RST4 (1<<12) /* Enable timer */
997#define M8260_TGCR_GM1 (1<<3) /* Gate Mode 1 for TMR1 or TMR2 */
998#define M8260_TGCR_GM2 (1<<11) /* Gate Mode 2 for TMR3 or TMR4 */
999
1000#define M8260_TMR_PS(x) ((x)<<8) /* Timer prescaler */
1001#define M8260_TMR_CE_RISE (1<<6) /* Capture on rising edge */
1002#define M8260_TMR_CE_FALL (2<<6) /* Capture on falling edge */
1003#define M8260_TMR_CE_ANY (3<<6) /* Capture on any edge */
1004#define M8260_TMR_OM_TOGGLE (1<<5) /* Toggle TOUTx pin */
1005#define M8260_TMR_ORI (1<<4) /* Interrupt on reaching reference */
1006#define M8260_TMR_RESTART (1<<3) /* Restart timer after reference */
1007#define M8260_TMR_ICLK_INT (1<<1) /* Internal clock is timer source */
1008#define M8260_TMR_ICLK_INT16 (2<<1) /* Internal clock/16 is tmr src */
1009#define M8260_TMR_ICLK_TIN (3<<1) /* TIN pin is timer source */
1010#define M8260_TMR_TGATE (1<<0) /* TGATE controls timer */
1011
1012#ifdef REV_0_2
1013#define M8260_PISCR_PS (1<<6) /* PIT Interrupt state */
1014#else
1015#define M8260_PISCR_PS (1<<7) /* PIT Interrupt state */
1016#endif
1017#define M8260_PISCR_PIE (1<<2) /* PIT interrupt enable */
1018#define M8260_PISCR_PTF (1<<1) /* Stop timer when freeze asserted */
1019#define M8260_PISCR_PTE (1<<0) /* PIT enable */
1020
1021#if 0
1022#define M8260_TBSCR_TBIRQ(x) (1<<(15-x)) /* TB interrupt level */
1023#define M8260_TBSCR_REFA (1<<7) /* TB matches TBREFF0 */
1024#define M8260_TBSCR_REFB (1<<6) /* TB matches TBREFF1 */
1025#define M8260_TBSCR_REFAE (1<<3) /* Enable ints for REFA */
1026#define M8260_TBSCR_REFBE (1<<2) /* Enable ints for REFB */
1027#define M8260_TBSCR_TBF (1<<1) /* TB stops on FREEZE */
1028#define M8260_TBSCR_TBE (1<<0) /* enable TB and decrementer */
1029#endif
1030
1031#define M8260_TMCNTSC_SEC (1<<7) /* per second flag */
1032#define M8260_TMCNTSC_ALR (1<<6) /* Alarm interrupt flag */
1033#define M8260_TMCNTSC_SIE (1<<3) /* per second interrupt enable */
1034#define M8260_TMCNTSC_ALE (1<<2) /* Alarm interrupt enable */
1035#define M8260_TMCNTSC_TCF (1<<1) /* Time count frequency */
1036#define M8260_TMCNTSC_TCE (1<<0) /* Time count enable */
1037
1038#define M8260_SIMASK_PC0 (1<<31)
1039#define M8260_SIMASK_PC1 (1<<30)
1040#define M8260_SIMASK_PC2 (1<<29)
1041#define M8260_SIMASK_PC3 (1<<28)
1042#define M8260_SIMASK_PC4 (1<<27)
1043#define M8260_SIMASK_PC5 (1<<26)
1044#define M8260_SIMASK_PC6 (1<<25)
1045#define M8260_SIMASK_PC7 (1<<24)
1046#define M8260_SIMASK_PC8 (1<<23)
1047#define M8260_SIMASK_PC9 (1<<22)
1048#define M8260_SIMASK_PC10 (1<<21)
1049#define M8260_SIMASK_PC11 (1<<20)
1050#define M8260_SIMASK_PC12 (1<<19)
1051#define M8260_SIMASK_PC13 (1<<18)
1052#define M8260_SIMASK_PC14 (1<<17)
1053#define M8260_SIMASK_PC15 (1<<16)
1054#define M8260_SIMASK_IRQ1 (1<<14)
1055#define M8260_SIMASK_IRQ2 (1<<13)
1056#define M8260_SIMASK_IRQ3 (1<<12)
1057#define M8260_SIMASK_IRQ4 (1<<11)
1058#define M8260_SIMASK_IRQ5 (1<<10)
1059#define M8260_SIMASK_IRQ6 (1<<9)
1060#define M8260_SIMASK_IRQ7 (1<<8)
1061#define M8260_SIMASK_TMCNT (1<<2)
1062#define M8260_SIMASK_PIT (1<<1)
1063
1064#define M8260_SIMASK_FCC1 (1<<31)
1065#define M8260_SIMASK_FCC2 (1<<30)
1066#define M8260_SIMASK_FCC3 (1<<29)
1067#define M8260_SIMASK_MCC1 (1<<27)
1068#define M8260_SIMASK_MCC2 (1<<26)
1069#define M8260_SIMASK_SCC1 (1<<23)
1070#define M8260_SIMASK_SCC2 (1<<22)
1071#define M8260_SIMASK_SCC3 (1<<21)
1072#define M8260_SIMASK_SCC4 (1<<20)
1073#define M8260_SIMASK_I2C (1<<15)
1074#define M8260_SIMASK_SPI (1<<14)
1075#define M8260_SIMASK_RTT (1<<13)
1076#define M8260_SIMASK_SMC1 (1<<12)
1077#define M8260_SIMASK_SMC2 (1<<11)
1078#define M8260_SIMASK_IDMA1 (1<<10)
1079#define M8260_SIMASK_IDMA2 (1<<9)
1080#define M8260_SIMASK_IDMA3 (1<<8)
1081#define M8260_SIMASK_IDMA4 (1<<7)
1082#define M8260_SIMASK_SDMA (1<<6)
1083#define M8260_SIMASK_TIMER1 (1<<4)
1084#define M8260_SIMASK_TIMER2 (1<<3)
1085#define M8260_SIMASK_TIMER3 (1<<2)
1086#define M8260_SIMASK_TIMER4 (1<<1)
1087
1088#define M8260_SIUMCR_EARB (1<<31)
1089#define M8260_SIUMCR_EARP0 (0<<28)
1090#define M8260_SIUMCR_EARP1 (1<<28)
1091#define M8260_SIUMCR_EARP2 (2<<28)
1092#define M8260_SIUMCR_EARP3 (3<<28)
1093#define M8260_SIUMCR_EARP4 (4<<28)
1094#define M8260_SIUMCR_EARP5 (5<<28)
1095#define M8260_SIUMCR_EARP6 (6<<28)
1096#define M8260_SIUMCR_EARP7 (7<<28)
1097#define M8260_SIUMCR_DSHW (1<<23)
1098#define M8260_SIUMCR_DBGC0 (0<<21)
1099#define M8260_SIUMCR_DBGC1 (1<<21)
1100#define M8260_SIUMCR_DBGC2 (2<<21)
1101#define M8260_SIUMCR_DBGC3 (3<<21)
1102#define M8260_SIUMCR_DBPC0 (0<<19)
1103#define M8260_SIUMCR_DBPC1 (1<<19)
1104#define M8260_SIUMCR_DBPC2 (2<<19)
1105#define M8260_SIUMCR_DBPC3 (3<<19)
1106#define M8260_SIUMCR_FRC (1<<17)
1107#define M8260_SIUMCR_DLK (1<<16)
1108#define M8260_SIUMCR_PNCS (1<<15)
1109#define M8260_SIUMCR_OPAR (1<<14)
1110#define M8260_SIUMCR_DPC (1<<13)
1111#define M8260_SIUMCR_MPRE (1<<12)
1112#define M8260_SIUMCR_MLRC0 (0<<10)
1113#define M8260_SIUMCR_MLRC1 (1<<10)
1114#define M8260_SIUMCR_MLRC2 (2<<10)
1115#define M8260_SIUMCR_MLRC3 (3<<10)
1116#define M8260_SIUMCR_AEME (1<<9)
1117#define M8260_SIUMCR_SEME (1<<8)
1118#define M8260_SIUMCR_BSC (1<<7)
1119#define M8260_SIUMCR_GB5E (1<<6)
1120#define M8260_SIUMCR_B2DD (1<<5)
1121#define M8260_SIUMCR_B3DD (1<<4)
1122
1123/*
1124*************************************************************************
1125* MPC8260 DUAL-PORT RAM AND REGISTERS *
1126*************************************************************************
1127*/
1128typedef struct m8260_ {
1129
1130 /*
1131 * CPM Dual-Port RAM
1132 */
1133 uint8_t dpram1[16384]; /* 0x0000 - 0x3FFF BD/data/ucode */
1134 uint8_t cpm_pad0[16384]; /* 0x4000 - 0x7FFF Reserved */
1135
1136 m8260SCCparms_t scc1p;
1137 uint8_t pad_scc1[256-sizeof(m8260SCCparms_t)];
1138 m8260SCCparms_t scc2p;
1139 uint8_t pad_scc2[256-sizeof(m8260SCCparms_t)];
1140 m8260SCCparms_t scc3p;
1141 uint8_t pad_scc3[256-sizeof(m8260SCCparms_t)];
1142 m8260SCCparms_t scc4p;
1143 uint8_t pad_scc4[256-sizeof(m8260SCCparms_t)];
1144
1145 m8260FCCparms_t fcc1p;
1146 uint8_t pad_fcc1[256-sizeof(m8260FCCparms_t)];
1147 m8260FCCparms_t fcc2p;
1148 uint8_t pad_fcc2[256-sizeof(m8260FCCparms_t)];
1149 m8260FCCparms_t fcc3p;
1150 uint8_t pad_fcc3[256-sizeof(m8260FCCparms_t)];
1151
1152 uint8_t mcc1p[128];
1153 uint8_t pad_mcc1[124];
1154 uint16_t smc1_base;
1155 uint16_t idma1_base;
1156 uint8_t mcc2p[128];
1157 uint8_t pad_mcc2[124];
1158 uint16_t smc2_base;
1159 uint16_t idma2_base;
1160 uint8_t pad_spi[252];
1161 uint16_t spi_base;
1162 uint16_t idma3_base;
1163 uint8_t pad_risc[224];
1164 uint8_t risc_timers[16];
1165 uint16_t rev_num;
1166 uint16_t cpm_pad7;
1167 uint32_t cpm_pad8;
1168 uint16_t rand;
1169 uint16_t i2c_base;
1170 uint16_t idma4_base;
1171 uint8_t cpm_pad9[1282];
1172
1173 uint8_t cpm_pad1[8192]; /* 0x9000 - 0xAFFF Reserved */
1174
1175 m8260SMCparms_t smc1p;
1176 m8260SMCparms_t smc2p;
1177 uint8_t dpram3[4096-2*sizeof(m8260SMCparms_t)];
1178
1179 uint8_t cpm_pad2[16384]; /* 0xC000 - 0xFFFF Reserved */
1180
1181
1182 /*
1183 * General SIU Block
1184 */
1185 uint32_t siumcr;
1186 uint32_t sypcr;
1187 uint8_t siu_pad0[6];
1188 uint16_t swsr;
1189 uint8_t siu_pad1[20];
1190 uint32_t bcr;
1191 uint8_t ppc_acr;
1192 uint8_t siu_pad4[3];
1193 uint32_t ppc_alrh;
1194 uint32_t ppc_alr1;
1195 uint8_t lcl_acr;
1196 uint8_t siu_pad5[3];
1197 uint32_t lcl_alrh;
1198 uint32_t lcl_alr1;
1199 uint32_t tescr1;
1200 uint32_t tescr2;
1201 uint32_t l_tescr1;
1202 uint32_t l_tescr2;
1203 uint32_t pdtea;
1204 uint8_t pdtem;
1205 uint8_t siu_pad2[3];
1206 uint32_t ldtea;
1207 uint8_t ldtem;
1208 uint8_t siu_pad3[163];
1209
1210
1211 /*
1212 * Memory Controller Block
1213 */
1214 m8260MEMCRegisters_t memc[12];
1215 uint8_t mem_pad0[8];
1216 uint32_t mar;
1217 uint8_t mem_pad1[4];
1218 uint32_t mamr;
1219 uint32_t mbmr;
1220 uint32_t mcmr;
1221 uint32_t mdmr;
1222 uint8_t mem_pad2[4];
1223 uint16_t mptpr;
1224 uint8_t mem_pad5[2];
1225 uint32_t mdr;
1226 uint8_t mem_pad3[4];
1227 uint32_t psdmr;
1228 uint32_t lsdmr;
1229 uint8_t purt;
1230 uint8_t mem_pad6[3];
1231 uint8_t psrt;
1232 uint8_t mem_pad7[3];
1233 uint8_t lurt;
1234 uint8_t mem_pad8[3];
1235 uint8_t lsrt;
1236 uint8_t mem_pad9[3];
1237 uint32_t immr;
1238 uint8_t mem_pad4[84];
1239
1240
1241 /*
1242 * System integration timers
1243 */
1244 uint8_t sit_pad0[32];
1245 uint16_t tmcntsc;
1246 uint8_t sit_pad6[2];
1247 uint32_t tmcnt;
1248 uint32_t tmcntsec;
1249 uint32_t tmcntal;
1250 uint8_t sit_pad2[16];
1251 uint16_t piscr;
1252 uint8_t sit_pad5[2];
1253 uint32_t pitc;
1254 uint32_t pitr;
1255 uint8_t sit_pad3[94];
1256 uint8_t sit_pad4[2390];
1257
1258
1259 /*
1260 * Interrupt Controller
1261 */
1262 uint16_t sicr;
1263 uint8_t ict_pad1[2];
1264 uint32_t sivec;
1265 uint32_t sipnr_h;
1266 uint32_t sipnr_l;
1267 uint32_t siprr;
1268 uint32_t scprr_h;
1269 uint32_t scprr_l;
1270 uint32_t simr_h;
1271 uint32_t simr_l;
1272 uint32_t siexr;
1273 uint8_t ict_pad0[88];
1274
1275
1276 /*
1277 * Clocks and Reset
1278 */
1279 uint32_t sccr;
1280 uint8_t clr_pad1[4];
1281 uint32_t scmr;
1282 uint8_t clr_pad2[4];
1283 uint32_t rsr;
1284 uint32_t rmr;
1285 uint8_t clr_pad0[104];
1286
1287
1288 /*
1289 * Input/ Output Port
1290 */
1291 uint32_t pdira;
1292 uint32_t ppara;
1293 uint32_t psora;
1294 uint32_t podra;
1295 uint32_t pdata;
1296 uint8_t iop_pad0[12];
1297 uint32_t pdirb;
1298 uint32_t pparb;
1299 uint32_t psorb;
1300 uint32_t podrb;
1301 uint32_t pdatb;
1302 uint8_t iop_pad1[12];
1303 uint32_t pdirc;
1304 uint32_t pparc;
1305 uint32_t psorc;
1306 uint32_t podrc;
1307 uint32_t pdatc;
1308 uint8_t iop_pad2[12];
1309 uint32_t pdird;
1310 uint32_t ppard;
1311 uint32_t psord;
1312 uint32_t podrd;
1313 uint32_t pdatd;
1314 uint8_t iop_pad3[12];
1315
1316
1317 /*
1318 * CPM Timers
1319 */
1320 uint8_t tgcr1;
1321 uint8_t cpt_pad0[3];
1322 uint8_t tgcr2;
1323 uint8_t cpt_pad1[11];
1324 uint16_t tmr1;
1325 uint16_t tmr2;
1326 uint16_t trr1;
1327 uint16_t trr2;
1328 uint16_t tcr1;
1329 uint16_t tcr2;
1330 uint16_t tcn1;
1331 uint16_t tcn2;
1332 uint16_t tmr3;
1333 uint16_t tmr4;
1334 uint16_t trr3;
1335 uint16_t trr4;
1336 uint16_t tcr3;
1337 uint16_t tcr4;
1338 uint16_t tcn3;
1339 uint16_t tcn4;
1340 uint16_t ter1;
1341 uint16_t ter2;
1342 uint16_t ter3;
1343 uint16_t ter4;
1344 uint8_t cpt_pad2[608];
1345
1346
1347 /*
1348 * DMA Block
1349 */
1350 uint8_t sdsr;
1351 uint8_t dma_pad0[3];
1352 uint8_t sdmr;
1353 uint8_t dma_pad1[3];
1354
1355 uint8_t idsr1;
1356 uint8_t dma_pad2[3];
1357 uint8_t idmr1;
1358 uint8_t dma_pad3[3];
1359 uint8_t idsr2;
1360 uint8_t dma_pad4[3];
1361 uint8_t idmr2;
1362 uint8_t dma_pad5[3];
1363 uint8_t idsr3;
1364 uint8_t dma_pad6[3];
1365 uint8_t idmr3;
1366 uint8_t dma_pad7[3];
1367 uint8_t idsr4;
1368 uint8_t dma_pad8[3];
1369 uint8_t idmr4;
1370 uint8_t dma_pad9[707];
1371
1372
1373 /*
1374 * FCC Block
1375 */
1379
1380 uint8_t fcc_pad0[656];
1381
1382 /*
1383 * BRG 5-8 Block
1384 */
1385 uint32_t brgc5;
1386 uint32_t brgc6;
1387 uint32_t brgc7;
1388 uint32_t brgc8;
1389 uint8_t brg_pad0[608];
1390
1391
1392 /*
1393 * I2C
1394 */
1395 uint8_t i2mod;
1396 uint8_t i2m_pad0[3];
1397 uint8_t i2add;
1398 uint8_t i2m_pad1[3];
1399 uint8_t i2brg;
1400 uint8_t i2m_pad2[3];
1401 uint8_t i2com;
1402 uint8_t i2m_pad3[3];
1403 uint8_t i2cer;
1404 uint8_t i2m_pad4[3];
1405 uint8_t i2cmr;
1406 uint8_t i2m_pad5[331];
1407
1408
1409 /*
1410 * CPM Block
1411 */
1412 uint32_t cpcr;
1413 uint32_t rccr;
1414 uint8_t cpm_pad3[14];
1415 uint16_t rter;
1416 uint8_t cpm_pad[2];
1417 uint16_t rtmr;
1418 uint16_t rtscr;
1419 uint8_t cpm_pad4[2];
1420 uint32_t rtsr;
1421 uint8_t cpm_pad5[12];
1422
1423
1424 /*
1425 * BRG 1-4 Block
1426 */
1427 uint32_t brgc1;
1428 uint32_t brgc2;
1429 uint32_t brgc3;
1430 uint32_t brgc4;
1431
1432
1433 /*
1434 * SCC Block
1435 */
1440
1441
1442 /*
1443 * SMC Block
1444 */
1447
1448
1449 /*
1450 * SPI Block
1451 */
1452 uint16_t spmode;
1453 uint8_t spi_pad0[4];
1454 uint8_t spie;
1455 uint8_t spi_pad1[3];
1456 uint8_t spim;
1457 uint8_t spi_pad2[2];
1458 uint8_t spcom;
1459 uint8_t spi_pad3[82];
1460
1461
1462 /*
1463 * CPM Mux Block
1464 */
1465 uint8_t cmxsi1cr;
1466 uint8_t cmx_pad0[1];
1467 uint8_t cmxsi2cr;
1468 uint8_t cmx_pad1[1];
1469 uint32_t cmxfcr;
1470 uint32_t cmxscr;
1471 uint8_t cmxsmr;
1472 uint8_t cmx_pad2[1];
1473 uint16_t cmxuar;
1474 uint8_t cmx_pad3[16];
1475
1476
1477 /*
1478 * SI & MCC Blocks
1479 */
1484
1485 uint8_t mcc_pad0[1152];
1486
1487 /*
1488 * SI1 RAM
1489 */
1490 uint8_t si1txram[512];
1491 uint8_t ram_pad0[512];
1492 uint8_t si1rxram[512];
1493 uint8_t ram_pad1[512];
1494
1495
1496 /*
1497 * SI2 RAM
1498 */
1499 uint8_t si2txram[512];
1500 uint8_t ram_pad2[512];
1501 uint8_t si2rxram[512];
1502 uint8_t ram_pad3[512];
1503
1504
1505} m8260_t;
1506
1507extern volatile m8260_t m8260;
1508#endif /* ASM */
1509
1510#endif /* _MPC8260_H */
Definition: mpc8260.h:643
Definition: mpc8260.h:77
Definition: mpc8260.h:390
Definition: mpc8260.h:739
Definition: mpc8260.h:217
Definition: mpc8260.h:148
Definition: mpc8260.h:68
Definition: mpc8260.h:98
Definition: mpc8260.h:246
Definition: mpc8260.h:130
Definition: mpc8260.h:116
Definition: mpc8260.h:533
Definition: mpc8260.h:593
Definition: mpc8260.h:1128
