RTEMS 5.2-rc1
mpc5200mbus.h
1/*===============================================================*\
2| Project: RTEMS generic MPC5200 BSP |
3+-----------------------------------------------------------------+
4| Copyright (c) 2005 |
5| Embedded Brains GmbH |
6| Obere Lagerstr. 30 |
7| D-82178 Puchheim |
8| Germany |
9| rtems@embedded-brains.de |
10+-----------------------------------------------------------------+
11| The license and distribution terms for this file may be |
12| found in the file LICENSE in this distribution or at |
13| |
14| http://www.rtems.org/license/LICENSE. |
15| |
16+-----------------------------------------------------------------+
17| MBUS module (I2C bus) definitions |
18+-----------------------------------------------------------------+
19| This file has been adapted from an existing source code file, |
20| see the original file header below for reference |
21\*===============================================================*/
22/*
23 * MCF5206e MBUS module (I2C bus) driver header file
24 *
25 * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
26 * Author: Victor V. Vengerov <vvv@oktet.ru>
27 *
28 * The license and distribution terms for this file may be
29 * found in the file LICENSE in this distribution or at
30 *
31 * http://www.rtems.org/license/LICENSE.
32 */
33
34#ifndef __MPC5200BSP_MPC5200MBUS_H__
35#define __MPC5200BSP_MPC5200MBUS_H__
36
37#include <bsp/mpc5200.h>
38#include <bsp/i2c.h>
39
40
41/* States of I2C machine */
42typedef enum mpc5200mbus_i2c_state {
43 STATE_UNINITIALIZED,
44 STATE_IDLE,
45 STATE_ADDR_7,
46 STATE_ADDR_1_W,
47 STATE_ADDR_1_R,
48 STATE_SENDING,
49 STATE_RECEIVING
50} mpc5200mbus_i2c_state;
51
52typedef struct mpc5200_mbus {
53 enum mpc5200mbus_i2c_state state;/* State of I2C machine */
54 i2c_message *msg; /* Pointer to the first message in transfer */
55 int nmsg; /* Number of messages in transfer */
56 i2c_message *cmsg; /* Current message */
57 int byte; /* Byte number in current message */
58 rtems_id sema; /* MBUS semaphore */
59 i2c_transfer_done done; /* Transfer done function */
60 void * done_arg_ptr; /* Done function argument pointer */
61 int bus_idx; /* bus index: 0 or 1 */
63
64/* mpc5200mbus_initialize --
65 * Initialize ColdFire MBUS I2C bus controller.
66 *
67 * PARAMETERS:
68 * i2c_bus - pointer to the bus descriptor structure
69 *
70 * RETURNS:
71 * RTEMS_SUCCESSFUL, or RTEMS error code when initialization failed.
72 */
74mpc5200mbus_initialize(mpc5200mbus *i2c_bus);
75
76/* mpc5200mbus_select_clock_divider --
77 * Select divider for system clock which is used for I2C bus clock
78 * generation. Not each divider can be selected for I2C bus; this
79 * function select nearest larger or equal divider, or maximum
80 * possible divider, if passed value greater.
81 *
82 * PARAMETERS:
83 * i2c_bus - pointer to the bus descriptor structure
84 * divider - system frequency divider for I2C serial clock.
85 *
86 * RETURNS:
87 * RTEMS_SUCCESSFUL, if operation performed successfully, or
88 * RTEMS error code when failed.
89 */
91mpc5200mbus_select_clock_divider(mpc5200mbus *i2c_bus, int divider);
92
93/* mpc5200mbus_i2c_transfer --
94 * Initiate multiple-messages transfer over I2C bus via ColdFire MBUS
95 * controller.
96 *
97 * PARAMETERS:
98 * bus - pointer to MBUS controller descriptor
99 * nmsg - number of messages
100 * msg - pointer to messages array
101 * done - function which is called when transfer is finished
102 * done_arg_ptr - arbitrary argument ptr passed to done funciton
103 *
104 * RETURNS:
105 * RTEMS_SUCCESSFUL if transfer initiated successfully, or error
106 * code when failed.
107 */
109mpc5200mbus_i2c_transfer(mpc5200mbus *bus, int nmsg, i2c_message *msg,
110 i2c_transfer_done done, void * done_arg_ptr);
111
112/* mpc5200mbus_i2c_done --
113 * Close ColdFire MBUS I2C bus controller and release all resources.
114 *
115 * PARAMETERS:
116 * bus - pointer to MBUS controller descriptor
117 *
118 * RETURNS:
119 * RTEMS_SUCCESSFUL, if transfer initiated successfully, or error
120 * code when failed.
121 */
123mpc5200mbus_i2c_done(mpc5200mbus *i2c_bus);
124
125/* mpc5200mbus_i2c_interrupt_handler --
126 * ColdFire MBUS I2C bus controller interrupt handler. This function
127 * called from real interrupt handler, and pointer to MBUS descriptor
128 * structure passed to this function.
129 *
130 * PARAMETERS:
131 * bus - pointert to the bus descriptor structure
132 *
133 * RETURNS:
134 * none
135 */
136void mpc5200mbus_i2c_interrupt_handler(mpc5200mbus *bus);
137
138/* mpc5200mbus_poll --
139 * MBUS module poll routine; used to poll events when I2C driver
140 * operates in poll-driven mode.
141 *
142 * PARAMETERS:
143 * none
144 *
145 * RETURNS:
146 * none
147 */
148void mpc5200mbus_poll(mpc5200mbus *bus);
149
150#endif /* __MPC5200BSP_MPC5200MBUS_H__ */
rtems_status_code
Classic API Status.
Definition: status.h:43
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
I2C bus control.
Definition: i2c.h:110
Definition: i2c.h:53
Definition: mpc5200mbus.h:52
Definition: b1553brm.c:75
