RTEMS 5.2-rc1
mpc5200.h
1/*===============================================================*\
2| Project: RTEMS generic MPC5200 BSP |
3+-----------------------------------------------------------------+
4| Partially based on the code references which are named below. |
5| Adaptions, modifications, enhancements and any recent parts of |
6| the code are: |
7| Copyright (c) 2005 |
8| Embedded Brains GmbH |
9| Obere Lagerstr. 30 |
10| D-82178 Puchheim |
11| Germany |
12| rtems@embedded-brains.de |
13+-----------------------------------------------------------------+
14| The license and distribution terms for this file may be |
15| found in the file LICENSE in this distribution or at |
16| |
17| http://www.rtems.org/license/LICENSE. |
18| |
19+-----------------------------------------------------------------+
20| this file contains definitions for the mpc5200 hw registers |
21\*===============================================================*/
22
23#ifndef __MPC5200_h__
24#define __MPC5200_h__
25
26/* Additional Harpo Core SPR definitions (603le only) */
27#define CSRR0 58 /* Critical Interrupt SRR0 */
28#define CSRR1 59 /* Critical Interrupt SRR1 */
29#define DABR2 1000 /* Data Address Breakpoint #2 */
30#define DBCR 1001 /* Data Address Breakpoint Control */
31#define IBCR 1002 /* Instruction Breakpoint Control */
32#define IABR2 1018 /* Instruction Breakpoint #2 */
33
34/*
35 * Initial post-reset location of MGT5100 module base address register (MBAR)
36 */
37#define MBAR_RESET 0x80000000
38
39/*
40 * Location and size of onchip SRAM (relative to MBAR)
41 */
42#define ONCHIP_SRAM_OFFSET 0x8000
43#define ONCHIP_SRAM_SIZE 0x4000
44
45#ifndef ASM
46#include <rtems.h>
47
48#include <bsp/utility.h>
49
50#ifdef __cplusplus
51extern "C" {
52#endif
53
54#define MPC5200_CAN_NO 2
55#define MPC5200_PSC_NO 6
56 /* XXX: there are only 6 PSCs, but PSC6 has an extra register gap
57 * from PSC5, therefore we instantiate seven(!) PSC register sets
58 */
59#define MPC5200_PSC_REG_SETS 7
60
61#define MPC5200_GPT_NO 8
62#define MPC5200_SLT_NO 2
63
64/*
65 * Bit fields for FEC interrupts, ievent and imask above.
66 */
67#define FEC_INTR_HBERR 0x80000000 /* heartbeat error */
68#define FEC_INTR_BABR 0x40000000 /* babbling receive error */
69#define FEC_INTR_BABT 0x20000000 /* babbling transmit error */
70#define FEC_INTR_GRA 0x10000000 /* graceful stop complete */
71#define FEC_INTR_TFINT 0x08000000 /* transmit frame interrupt */
72/* 0x04000000 reserved */
73/* 0x02000000 reserved */
74/* 0x01000000 reserved */
75#define FEC_INTR_MII 0x00800000 /* MII interrupt */
76/* 0x00400000 reserved */
77#define FEC_INTR_LATE_COL 0x00200000 /* late collision */
78#define FEC_INTR_COL_RETRY 0x00100000 /* collision retry limit */
79#define FEC_INTR_XFIFO_UN 0x00080000 /* transmit FIFO error */
80#define FEC_INTR_XFIFO_ERR 0x00040000 /* transmit FIFO error */
81#define FEC_INTR_RFIFO_ERR 0x00020000 /* receive FIFO error */
82/* 0x00010000 reserved */
83/* 0x0000ffff reserved */
84#define FEC_INTR_HBEEN FEC_INTR_HBERR
85#define FEC_INTR_BREN FEC_INTR_BABR
86#define FEC_INTR_BTEN FEC_INTR_BABT
87#define FEC_INTR_GRAEN FEC_INTR_GRA
88#define FEC_INTR_TFINTEN FEC_INTR_TFINT
89#define FEC_INTR_MIIEN FEC_INTR_MII
90#define FEC_INTR_LCEN FEC_INTR_LATE_COL
91#define FEC_INTR_CRLEN FEC_INTR_COL_RETRY
92#define FEC_INTR_XFUNEN FEC_INTR_XFIFO_UN
93#define FEC_INTR_XFERREN FEC_INTR_XFIFO_ERR
94#define FEC_INTR_RFERREN FEC_INTR_RFIFO_ERR
95#define FEC_INTR_CLEAR_ALL 0xffffffff /* clear all interrupt events */
96#define FEC_INTR_MASK_ALL 0x00000000 /* mask all interrupt events */
97
98/*
99 * Bit fields for FEC ethernet control, ecntrl above.
100 */
101#define FEC_ECNTRL_TAG 0xf0000000 /* TBUS tag bits */
102/* 0x08000000 reserved */
103#define FEC_ECNTRL_TESTMD 0x04000000 /* test mode */
104/* 0x03fffff8 reserved */
105#define FEC_ECNTRL_OE 0x00000004 /* FEC output enable */
106#define FEC_ECNTRL_EN 0x00000002 /* ethernet enable */
107#define FEC_ECNTRL_RESET 0x00000001 /* ethernet controller reset */
108
109/*
110 * Bit fields for FEC receive control, r_cntrl above.
111 */
112/* 0xf1000000 reserved */
113#define FEC_RCNTRL_MAX_FL 0x07ff0000 /* maximum frame length */
114#define FEC_RCNTRL_MAX_FL_SHIFT 16
115/* 0x0000ffc0 reserved */
116#define FEC_RCNTRL_FCE 0x00000020 /* flow control enable */
117#define FEC_RCNTRL_BC_REJ 0x00000010 /* broadcast frame reject */
118#define FEC_RCNTRL_PROM 0x00000008 /* promiscuous mode */
119#define FEC_RCNTRL_MII_MODE 0x00000004 /* select 18-wire (MII) mode */
120#define FEC_RCNTRL_DRT 0x00000002 /* disable receive on transmit */
121#define FEC_RCNTRL_LOOP 0x00000001 /* internal loopback */
122
123/*
124 * Bit fields for FEC transmit control, x_cntrl above.
125 */
126/* 0xffffffe0 reserved */
127#define FEC_XCNTRL_RFC_PAUS 0x00000010 /* FDX flow control pause rx */
128#define FEC_XCNTRL_TFC_PAUS 0x00000008 /* assert a PAUSE frame */
129#define FEC_XCNTRL_FDEN 0x00000004 /* full duplex enable */
130#define FEC_XCNTRL_HBC 0x00000002 /* heartbeat control */
131#define FEC_XCNTRL_GTS 0x00000001 /* graceful transmit stop */
132
133/*
134 * Bit fields for FEC transmit status, x_status above.
135 */
136/* 0xfc000000 reserved */
137#define FEC_XSTAT_DEF 0x02000000 /* defer */
138#define FEC_XSTAT_HB 0x01000000 /* heartbeat error */
139#define FEC_XSTAT_LC 0x00800000 /* late collision */
140#define FEC_XSTAT_RL 0x00400000 /* retry limit */
141#define FEC_XSTAT_RC 0x003c0000 /* retry count */
142#define FEC_XSTAT_UN 0x00020000 /* underrun */
143#define FEX_XSTAT_CSL 0x00010000 /* carrier sense lost */
144/* 0x0000ffff reserved */
145
146/*
147 * Bit fields for FEC transmit FIFO watermark, x_wmrk above.
148 */
149#define FEC_XWMRK_64 0x00000000 /* 64 bytes written to TxFIFO */
150#define FEC_XWMRK_128 0x00000001 /* 128 bytes written to TxFIFO */
151#define FEC_XWMRK_192 0x00000002 /* 192 bytes written to TxFIFO */
152#define FEC_XWMRK_256 0x00000003 /* 256 bytes written to TxFIFO */
153#define FEC_XWMRK_320 0x00000004 /* 320 bytes written to TxFIFO */
154#define FEC_XWMRK_384 0x00000005 /* 384 bytes written to TxFIFO */
155#define FEC_XWMRK_448 0x00000006 /* 448 bytes written to TxFIFO */
156#define FEC_XWMRK_512 0x00000007 /* 512 bytes written to TxFIFO */
157#define FEC_XWMRK_576 0x00000008 /* 576 bytes written to TxFIFO */
158#define FEC_XWMRK_640 0x00000009 /* 640 bytes written to TxFIFO */
159#define FEC_XWMRK_704 0x0000000a /* 704 bytes written to TxFIFO */
160#define FEC_XWMRK_768 0x0000000b /* 768 bytes written to TxFIFO */
161#define FEC_XWMRK_832 0x0000000c /* 832 bytes written to TxFIFO */
162#define FEC_XWMRK_896 0x0000000d /* 896 bytes written to TxFIFO */
163#define FEC_XWMRK_960 0x0000000e /* 960 bytes written to TxFIFO */
164#define FEC_XWMRK_1024 0x0000000f /* 1024 bytes written to TxFIFO */
165
166/*
167 * Bit fields for FEC transmit finite state machine.
168 */
169/* 0xfc000000 reserved */
170#define FEC_FSM_CRC 0x02000000 /* append CRC (typical use) */
171#define FEC_FSM_ENFSM 0x01000000 /* enable CRC FSM (typical use) */
172/* 0x00ffffff reserved */
173
174/*
175 * Bit fields for FEC FIFOs, rfifo_status, rfifo_cntrl, tfifo_status
176 * and tfifo_cntrl.
177 */
178#define FEC_FIFO_STAT_IP 0x80000000 /* illegal pointer, sticky */
179/* 0x70000000 reserved */
180#define FEC_FIFO_STAT_FRAME 0x0f000000 /* frame indicator */
181#define FEC_FIFO_STAT_FAE 0x00800000 /* frame accept error */
182#define FEC_FIFO_STAT_RXW 0x00400000 /* receive wait condition */
183#define FEC_FIFO_STAT_UF 0x00200000 /* underflow */
184#define FEC_FIFO_STAT_OF 0x00100000 /* overflow */
185#define FEC_FIFO_STAT_FR 0x00080000 /* frame ready, read-only */
186#define FEC_FIFO_STAT_FULL 0x00040000 /* full alarm, read-only */
187#define FEC_FIFO_STAT_ALARM 0x00020000 /* fifo alarm */
188#define FEC_FIFO_STAT_EMPTY 0x00010000 /* empty, read-only */
189/* 0x0000ffff reserved */
190#define FEC_FIFO_STAT_ERROR ( FEC_FIFO_STAT_IP \
191 | FEC_FIFO_STAT_FAE \
192 | FEC_FIFO_STAT_RXW \
193 | FEC_FIFO_STAT_UF \
194 | FEC_FIFO_STAT_OF \
195 )
196
197/* 0x80000000 reserved */
198#define FEC_FIFO_CNTRL_WCTL 0x40000000 /* write control */
199#define FEC_FIFO_CNTRL_WFR 0x20000000 /* write frame */
200/* 0x10000000 reserved */
201#define FEC_FIFO_CNTRL_FRAME 0x08000000 /* frame mode enable */
202#define FEC_FIFO_CNTRL_GR 0x07000000 /* last transfer granularity */
203#define FEC_FIFO_CNTRL_GR_SHIFT 24
204#define FEC_FIFO_CNTRL_IP_MASK 0x00800000 /* illegal pointer mask */
205#define FEC_FIFO_CNTRL_FAE_MASK 0x00400000 /* frame accept mask */
206#define FEC_FIFO_CNTRL_RXW_MASK 0x00200000 /* receive wait mask */
207#define FEC_FIFO_CNTRL_UF_MASK 0x00100000 /* underflow mask */
208#define FEC_FIFO_CNTRL_OF_MASK 0x00080000 /* overflow mask */
209/* 0x0007ffff reserved */
210
211#define SDMA_TCR_EN BSP_BBIT16(0)
212#define SDMA_TCR_VAL BSP_BBIT16(1)
213#define SDMA_TCR_ALW_INIT BSP_BBIT16(2)
214#define SDMA_TCR_IN(val) BSP_BFLD16(val, 3, 7)
215#define SDMA_TCR_AUTO_START BSP_BBIT16(8)
216#define SDMA_TCR_HIGH_EN BSP_BBIT16(9)
217#define SDMA_TCR_HOLD BSP_BBIT16(10)
218#define SDMA_TCR_AS(val) BSP_BFLD16(val, 12, 15)
219
220#define SDMA_IPR_HOLD BSP_BBIT8(0)
221#define SDMA_IPR_PRIOR(val) BSP_BFLD8(val, 5, 7)
222
223#define SDMA_REQMUX_SET_31(reg, val) BSP_BFLD32SET(reg, val, 0, 1)
224#define SDMA_REQMUX_SET_30(reg, val) BSP_BFLD32SET(reg, val, 2, 3)
225#define SDMA_REQMUX_SET_29(reg, val) BSP_BFLD32SET(reg, val, 4, 5)
226#define SDMA_REQMUX_SET_28(reg, val) BSP_BFLD32SET(reg, val, 6, 7)
227#define SDMA_REQMUX_SET_27(reg, val) BSP_BFLD32SET(reg, val, 8, 9)
228#define SDMA_REQMUX_SET_26(reg, val) BSP_BFLD32SET(reg, val, 10, 11)
229#define SDMA_REQMUX_SET_25(reg, val) BSP_BFLD32SET(reg, val, 12, 13)
230#define SDMA_REQMUX_SET_24(reg, val) BSP_BFLD32SET(reg, val, 14, 15)
231#define SDMA_REQMUX_SET_23(reg, val) BSP_BFLD32SET(reg, val, 16, 17)
232#define SDMA_REQMUX_SET_22(reg, val) BSP_BFLD32SET(reg, val, 18, 19)
233#define SDMA_REQMUX_SET_21(reg, val) BSP_BFLD32SET(reg, val, 20, 21)
234#define SDMA_REQMUX_SET_20(reg, val) BSP_BFLD32SET(reg, val, 22, 23)
235#define SDMA_REQMUX_SET_19(reg, val) BSP_BFLD32SET(reg, val, 24, 25)
236#define SDMA_REQMUX_SET_18(reg, val) BSP_BFLD32SET(reg, val, 26, 27)
237#define SDMA_REQMUX_SET_17(reg, val) BSP_BFLD32SET(reg, val, 28, 29)
238#define SDMA_REQMUX_SET_16(reg, val) BSP_BFLD32SET(reg, val, 30, 31)
239
240/* SDMA / BestComm */
241typedef struct {
242 uint32_t taskBar;
243 uint32_t currentPointer;
244 uint32_t endPointer;
245 uint32_t variablePointer;
246 uint8_t IntVect1;
247 uint8_t IntVect2;
248 uint16_t PtdCntrl;
249 uint32_t IntPend;
250 uint32_t IntMask;
251 uint16_t tcr [16];
252 uint8_t ipr [32];
253 uint32_t cReqSelect;
254 uint32_t task_size0;
255 uint32_t task_size1;
256 uint32_t reserved_0;
257 uint32_t reserved_1;
258 uint32_t Value1;
259 uint32_t Value2;
260 uint32_t Control;
261 uint32_t Status;
263
264typedef struct {
265#define CSC_CFG_WAITP(val) BSP_BFLD32(val, 0, 7)
266#define CSC_CFG_WAITX(val) BSP_BFLD32(val, 8, 15)
267#define CSC_CFG_MX BSP_BBIT32(16)
268#define CSC_CFG_AA BSP_BBIT32(18)
269#define CSC_CFG_CE BSP_BBIT32(19)
270#define CSC_CFG_AS(val) BSP_BFLD32(val, 20, 21)
271#define CSC_CFG_DS(val) BSP_BFLD32(val, 22, 23)
272#define CSC_CFG_BANK(val) BSP_BFLD32(val, 24, 25)
273#define CSC_CFG_WTYP(val) BSP_BFLD32(val, 26, 27)
274#define CSC_CFG_WS BSP_BBIT32(28)
275#define CSC_CFG_RS BSP_BBIT32(29)
276#define CSC_CFG_WO BSP_BBIT32(30)
277#define CSC_CFG_RO BSP_BBIT32(31)
278 uint32_t config_0;
279 uint32_t config_1;
280 uint32_t config_2;
281 uint32_t config_3;
282 uint32_t config_4;
283 uint32_t config_5;
284
285#define CSC_CTRL_ME BSP_BBIT32(7)
286 uint32_t control;
287
288#define CSC_STAT_WOERR BSP_BBIT32(2)
289#define CSC_STAT_ROERR BSP_BBIT32(3)
290#define CSC_STAT_GET_CSXERR(reg) BSP_BFLD32GET(reg, 5, 7)
291 uint32_t status;
292
293 uint32_t config_6;
294 uint32_t config_7;
295
296#define CSC_BST_CTRL_CW7 BSP_BBIT32(0)
297#define CSC_BST_CTRL_SLB7 BSP_BBIT32(1)
298#define CSC_BST_CTRL_BRE7 BSP_BBIT32(3)
299#define CSC_BST_CTRL_CW6 BSP_BBIT32(4)
300#define CSC_BST_CTRL_SLB6 BSP_BBIT32(5)
301#define CSC_BST_CTRL_BRE6 BSP_BBIT32(7)
302#define CSC_BST_CTRL_CW5 BSP_BBIT32(8)
303#define CSC_BST_CTRL_SLB5 BSP_BBIT32(9)
304#define CSC_BST_CTRL_BRE5 BSP_BBIT32(11)
305#define CSC_BST_CTRL_CW4 BSP_BBIT32(12)
306#define CSC_BST_CTRL_SLB4 BSP_BBIT32(13)
307#define CSC_BST_CTRL_BRE4 BSP_BBIT32(15)
308#define CSC_BST_CTRL_CW3 BSP_BBIT32(16)
309#define CSC_BST_CTRL_SLB3 BSP_BBIT32(17)
310#define CSC_BST_CTRL_BRE3 BSP_BBIT32(19)
311#define CSC_BST_CTRL_CW2 BSP_BBIT32(20)
312#define CSC_BST_CTRL_SLB2 BSP_BBIT32(21)
313#define CSC_BST_CTRL_BRE2 BSP_BBIT32(23)
314#define CSC_BST_CTRL_CW1 BSP_BBIT32(24)
315#define CSC_BST_CTRL_SLB1 BSP_BBIT32(25)
316#define CSC_BST_CTRL_BRE1 BSP_BBIT32(27)
317#define CSC_BST_CTRL_CW0 BSP_BBIT32(28)
318#define CSC_BST_CTRL_SLB0 BSP_BBIT32(29)
319#define CSC_BST_CTRL_BRE0 BSP_BBIT32(31)
320 uint32_t burst_control;
321
322#define CSC_DCYC_CTRL_DC7(val) BSP_BFLD32(val, 2, 3)
323#define CSC_DCYC_CTRL_SET_DC7(reg, val) BSP_BFLD32SET(reg, val, 2, 3)
324#define CSC_DCYC_CTRL_DC6(val) BSP_BFLD32(val, 6, 7)
325#define CSC_DCYC_CTRL_SET_DC6(reg, val) BSP_BFLD32SET(reg, val, 6, 7)
326#define CSC_DCYC_CTRL_DC5(val) BSP_BFLD32(val, 10, 11)
327#define CSC_DCYC_CTRL_SET_DC5(reg, val) BSP_BFLD32SET(reg, val, 10, 11)
328#define CSC_DCYC_CTRL_DC4(val) BSP_BFLD32(val, 14, 15)
329#define CSC_DCYC_CTRL_SET_DC4(reg, val) BSP_BFLD32SET(reg, val, 14, 15)
330#define CSC_DCYC_CTRL_DC3(val) BSP_BFLD32(val, 18, 19)
331#define CSC_DCYC_CTRL_SET_DC3(reg, val) BSP_BFLD32SET(reg, val, 18, 19)
332#define CSC_DCYC_CTRL_DC2(val) BSP_BFLD32(val, 22, 23)
333#define CSC_DCYC_CTRL_SET_DC2(reg, val) BSP_BFLD32SET(reg, val, 22, 23)
334#define CSC_DCYC_CTRL_DC1(val) BSP_BFLD32(val, 26, 27)
335#define CSC_DCYC_CTRL_SET_DC1(reg, val) BSP_BFLD32SET(reg, val, 26, 27)
336#define CSC_DCYC_CTRL_DC0(val) BSP_BFLD32(val, 30, 31)
337#define CSC_DCYC_CTRL_SET_DC0(reg, val) BSP_BFLD32SET(reg, val, 30, 31)
338 uint32_t deadcycle_control;
339
340 uint8_t reserved [208];
342
343typedef struct {
344 uint32_t memory_address_base;
345 uint32_t cs0_start_address;
346 uint32_t cs0_stop_address;
347 uint32_t cs1_start_address;
348 uint32_t cs1_stop_address;
349 uint32_t cs2_start_address;
350 uint32_t cs2_stop_address;
351 uint32_t cs3_start_address;
352 uint32_t cs3_stop_address;
353 uint32_t cs4_start_address;
354 uint32_t cs4_stop_address;
355 uint32_t cs5_start_address;
356 uint32_t cs5_stop_address;
357 uint32_t sdram_chip_select_0;
358 uint32_t sdram_chip_select_1;
359 uint8_t reserved_0 [16];
360 uint32_t boot_start_address;
361 uint32_t boot_stop_address;
362
363#define MM_IPBI_CTRL_CS7ENA BSP_BBIT16(4)
364#define MM_IPBI_CTRL_CS6ENA BSP_BBIT16(5)
365#define MM_IPBI_CTRL_BOOTENA BSP_BBIT16(6)
366#define MM_IPBI_CTRL_CS5ENA BSP_BBIT16(10)
367#define MM_IPBI_CTRL_CS4ENA BSP_BBIT16(11)
368#define MM_IPBI_CTRL_CS3ENA BSP_BBIT16(12)
369#define MM_IPBI_CTRL_CS2ENA BSP_BBIT16(13)
370#define MM_IPBI_CTRL_CS1ENA BSP_BBIT16(14)
371#define MM_IPBI_CTRL_CS0ENA BSP_BBIT16(15)
372 uint16_t ipbi_control;
373
374 uint16_t wait_state_enable;
375 uint32_t cs6_start_address;
376 uint32_t cs6_stop_address;
377 uint32_t cs7_start_address;
378 uint32_t cs7_stop_address;
379 uint8_t reserved_1 [152];
380} mpc5200_mm;
381
382/*
383*************************************************************************
384* MPC5x00 internal register memory map *
385*************************************************************************
386*/
387typedef struct mpc5200_ {
388 /*
389 * memory map registers (MBAR + 0)
390 */
391 volatile mpc5200_mm mm;
392
393 /*
394 * SDRAM memory controller registers (MBAR + 0x100)
395 */
396 volatile uint8_t mc[0x100];
397
398 /*
399 * clock distribution module registers (MBAR + 0x200)
400 */
401 volatile uint8_t cdm[0x100];
402
403 /*
404 * chip selct controller registers(MBAR + 0x300)
405 */
406 volatile mpc5200_csc csc;
407
408 /*
409 * SmartComm timer registers (MBAR + 0x400)
410 */
411 volatile uint8_t sct[0x100];
412
413 /*
414 * interrupt controller registers (MBAR + 0x500)
415 */
416 volatile uint32_t per_mask; /* + 0x00 */
417 volatile uint32_t per_pri_1; /* + 0x04 */
418 volatile uint32_t per_pri_2; /* + 0x08 */
419 volatile uint32_t per_pri_3; /* + 0x0C */
420
421#define ICTL_EET_ECLR0 BSP_BBIT32(4)
422#define ICTL_EET_ECLR1 BSP_BBIT32(5)
423#define ICTL_EET_ECLR2 BSP_BBIT32(6)
424#define ICTL_EET_ECLR3 BSP_BBIT32(7)
425#define ICTL_EET_ETYPE0(val) BSP_BFLD32(val, 8, 9)
426#define ICTL_EET_ETYPE1(val) BSP_BFLD32(val, 10, 11)
427#define ICTL_EET_ETYPE2(val) BSP_BFLD32(val, 12, 13)
428#define ICTL_EET_ETYPE3(val) BSP_BFLD32(val, 14, 15)
429#define ICTL_EET_SET_ETYPE0(reg, val) BSP_BFLD32SET(reg, val, 8, 9)
430#define ICTL_EET_SET_ETYPE1(reg, val) BSP_BFLD32SET(reg, val, 10, 11)
431#define ICTL_EET_SET_ETYPE2(reg, val) BSP_BFLD32SET(reg, val, 12, 13)
432#define ICTL_EET_SET_ETYPE3(reg, val) BSP_BFLD32SET(reg, val, 14, 15)
433#define ICTL_EET_MEE BSP_BBIT32(19)
434#define ICTL_EET_EENA0 BSP_BBIT32(20)
435#define ICTL_EET_EENA1 BSP_BBIT32(21)
436#define ICTL_EET_EENA2 BSP_BBIT32(22)
437#define ICTL_EET_EENA3 BSP_BBIT32(23)
438#define ICTL_EET_CEB BSP_BBIT32(31)
439
440 volatile uint32_t ext_en_type; /* + 0x10 */
441 volatile uint32_t crit_pri_main_mask;/* + 0x14 */
442 volatile uint32_t main_pri_1; /* + 0x18 */
443 volatile uint32_t main_pri_2; /* + 0x1C */
444 volatile uint32_t res1; /* + 0x20 */
445 volatile uint32_t pmce; /* + 0x24 */
446 volatile uint32_t csa; /* + 0x28 */
447 volatile uint32_t msa; /* + 0x2C */
448 volatile uint32_t psa; /* + 0x30 */
449 volatile uint32_t res2; /* + 0x34 */
450 volatile uint32_t psa_be; /* + 0x38 */
451 volatile uint8_t res3[0xC4]; /* + 0x3C */
452
453 /*
454 * general pupose timer registers (MBAR + 0x600/+ 0x610/+ 0x620/+ 0x630/+ 0x640/+ 0x650/+ 0x660/+ 0x670)
455 */
456 struct mpc5200_gpt {
457 volatile uint32_t emsel; /* + 0x00 */
458 volatile uint32_t count_in; /* + 0x04 */
459 volatile uint32_t pwm_conf; /* + 0x08 */
460 volatile uint32_t status; /* + 0x0C */
461 } gpt[MPC5200_GPT_NO];
462
463#define GPT_STATUS_RESET 0x0000000F
464#define GPT_STATUS_TEXP (1 << 3)
465#define GPT_STATUS_PIN (1 << 8)
466#define GPT_EMSEL_GPIO_DIR (2 << 4)
467#define GPT_EMSEL_GPIO_OUT (1 << 4)
468#define GPT_EMSEL_GPIO_OUT_HIGH (3 << 4)
469#define GPT_EMSEL_TIMER_MS_GPIO (4 << 0)
470#define GPT_EMSEL_GPIO_IN (0 << 0)
471#define GPT_EMSEL_CE (1 << 12)
472#define GPT_EMSEL_ST_CONT (1 << 10)
473#define GPT_EMSEL_INTEN (1 << 8)
474#define GPT_EMSEL_WDEN (1 << 15)
475
476#define GPT0 0
477#define GPT1 1
478#define GPT2 2
479#define GPT3 3
480#define GPT4 4
481#define GPT5 5
482#define GPT6 6
483#define GPT7 7
484
485 volatile uint8_t gpt_res[0x80];
486
487 /*
488 * slice time registers (MBAR + 0x700/+ 0x710)
489 */
490 struct mpc5200_slt {
491 volatile uint32_t tcr; /* + 0x00 */
492 volatile uint32_t cntrl; /* + 0x04 */
493 volatile uint32_t cvr; /* + 0x08 */
494 volatile uint32_t tsr; /* + 0x0C */
495 } slt[MPC5200_SLT_NO];
496
497 volatile uint8_t slt_res[0xE0];
498
499 /*
500 * real time clock registers (MBAR + 0x800)
501 */
502 volatile uint8_t rtc[0x100];
503
504
505 /*
506 * MSCAN registers (MBAR + 0x900 /+ 0x980)
507 */
509 volatile uint8_t ctl0; /* + 0x0 */
510 volatile uint8_t ctl1; /* + 0x1 */
511 volatile uint8_t res1; /* + 0x2 */
512 volatile uint8_t res2; /* + 0x3 */
513 volatile uint8_t btr0; /* + 0x4 */
514 volatile uint8_t btr1; /* + 0x5 */
515 volatile uint8_t res3; /* + 0x6 */
516 volatile uint8_t res4; /* + 0x7 */
517 volatile uint8_t rflg; /* + 0x8 */
518 volatile uint8_t rier; /* + 0x9 */
519 volatile uint8_t res5; /* + 0xA */
520 volatile uint8_t res6; /* + 0xB */
521 volatile uint8_t tflg; /* + 0xC */
522 volatile uint8_t tier; /* + 0xD */
523 volatile uint8_t res7; /* + 0xE */
524 volatile uint8_t res8; /* + 0xF */
525 volatile uint8_t tarq; /* + 0x10 */
526 volatile uint8_t taak; /* + 0x11 */
527 volatile uint8_t res9; /* + 0x12 */
528 volatile uint8_t res10; /* + 0x13 */
529 volatile uint8_t bsel; /* + 0x14 */
530 volatile uint8_t idac; /* + 0x15 */
531 volatile uint8_t res11; /* + 0x16 */
532 volatile uint8_t res12; /* + 0x17 */
533 volatile uint8_t res13; /* + 0x18 */
534 volatile uint8_t res14; /* + 0x19 */
535 volatile uint8_t res15; /* + 0x1A */
536 volatile uint8_t res16; /* + 0x1B */
537 volatile uint8_t rxerr; /* + 0x1C */
538 volatile uint8_t txerr; /* + 0x1D */
539 volatile uint8_t res17; /* + 0x1E */
540 volatile uint8_t res18; /* + 0x1F */
541 volatile uint8_t idar0; /* + 0x20 */
542 volatile uint8_t idar1; /* + 0x21 */
543 volatile uint8_t res19; /* + 0x22 */
544 volatile uint8_t res20; /* + 0x23 */
545 volatile uint8_t idar2; /* + 0x24 */
546 volatile uint8_t idar3; /* + 0x25 */
547 volatile uint8_t res21; /* + 0x26 */
548 volatile uint8_t res22; /* + 0x27 */
549 volatile uint8_t idmr0; /* + 0x28 */
550 volatile uint8_t idmr1; /* + 0x29 */
551 volatile uint8_t res23; /* + 0x2A */
552 volatile uint8_t res24; /* + 0x2B */
553 volatile uint8_t idmr2; /* + 0x2C */
554 volatile uint8_t idmr3; /* + 0x2D */
555 volatile uint8_t res25; /* + 0x2E */
556 volatile uint8_t res26; /* + 0x2F */
557 volatile uint8_t idar4; /* + 0x30 */
558 volatile uint8_t idar5; /* + 0x31 */
559 volatile uint8_t res27; /* + 0x32 */
560 volatile uint8_t res28; /* + 0x33 */
561 volatile uint8_t idar6; /* + 0x34 */
562 volatile uint8_t idar7; /* + 0x35 */
563 volatile uint8_t res29; /* + 0x36 */
564 volatile uint8_t res30; /* + 0x37 */
565 volatile uint8_t idmr4; /* + 0x38 */
566 volatile uint8_t idmr5; /* + 0x39 */
567 volatile uint8_t res31; /* + 0x3A */
568 volatile uint8_t res32; /* + 0x3B */
569 volatile uint8_t idmr6; /* + 0x3C */
570 volatile uint8_t idmr7; /* + 0x3D */
571 volatile uint8_t res33; /* + 0x3E */
572 volatile uint8_t res34; /* + 0x3F */
573 volatile uint8_t rxidr0; /* + 0x40 */
574 volatile uint8_t rxidr1; /* + 0x41 */
575 volatile uint8_t res35; /* + 0x42 */
576 volatile uint8_t res36; /* + 0x43 */
577 volatile uint8_t rxidr2; /* + 0x44 */
578 volatile uint8_t rxidr3; /* + 0x45 */
579 volatile uint8_t res37; /* + 0x46 */
580 volatile uint8_t res38; /* + 0x47 */
581 volatile uint8_t rxdsr0; /* + 0x48 */
582 volatile uint8_t rxdsr1; /* + 0x49 */
583 volatile uint8_t res39; /* + 0x4A */
584 volatile uint8_t res40; /* + 0x4B */
585 volatile uint8_t rxdsr2; /* + 0x4C */
586 volatile uint8_t rxdsr3; /* + 0x4D */
587 volatile uint8_t res41; /* + 0x4E */
588 volatile uint8_t res42; /* + 0x4F */
589 volatile uint8_t rxdsr4; /* + 0x50 */
590 volatile uint8_t rxdsr5; /* + 0x51 */
591 volatile uint8_t res43; /* + 0x52 */
592 volatile uint8_t res44; /* + 0x53 */
593 volatile uint8_t rxdsr6; /* + 0x54 */
594 volatile uint8_t rxdsr7; /* + 0x55 */
595 volatile uint8_t res45; /* + 0x56 */
596 volatile uint8_t res46; /* + 0x57 */
597 volatile uint8_t rxdlr; /* + 0x58 */
598 volatile uint8_t res47; /* + 0x59 */
599 volatile uint8_t res48; /* + 0x5A */
600 volatile uint8_t res49; /* + 0x5B */
601 volatile uint8_t rxtimh; /* + 0x5C */
602 volatile uint8_t rxtiml; /* + 0x5D */
603 volatile uint8_t res50; /* + 0x5E */
604 volatile uint8_t res51; /* + 0x5F */
605 volatile uint8_t txidr0; /* + 0x60 */
606 volatile uint8_t txidr1; /* + 0x61 */
607 volatile uint8_t res52; /* + 0x62 */
608 volatile uint8_t res53; /* + 0x63 */
609 volatile uint8_t txidr2; /* + 0x64 */
610 volatile uint8_t txidr3; /* + 0x65 */
611 volatile uint8_t res54; /* + 0x66 */
612 volatile uint8_t res55; /* + 0x67 */
613 volatile uint8_t txdsr0; /* + 0x68 */
614 volatile uint8_t txdsr1; /* + 0x69 */
615 volatile uint8_t res56; /* + 0x6A */
616 volatile uint8_t res57; /* + 0x6B */
617 volatile uint8_t txdsr2; /* + 0x6C */
618 volatile uint8_t txdsr3; /* + 0x6D */
619 volatile uint8_t res58; /* + 0x6E */
620 volatile uint8_t res59; /* + 0x6F */
621 volatile uint8_t txdsr4; /* + 0x70 */
622 volatile uint8_t txdsr5; /* + 0x71 */
623 volatile uint8_t res60; /* + 0x72 */
624 volatile uint8_t res61; /* + 0x73 */
625 volatile uint8_t txdsr6; /* + 0x74 */
626 volatile uint8_t txdsr7; /* + 0x75 */
627 volatile uint8_t res62; /* + 0x76 */
628 volatile uint8_t res63; /* + 0x77 */
629 volatile uint8_t txdlr; /* + 0x78 */
630 volatile uint8_t txtbpr; /* + 0x79 */
631 volatile uint8_t res64; /* + 0x7A */
632 volatile uint8_t res65; /* + 0x7B */
633 volatile uint8_t txtimh; /* + 0x7C */
634 volatile uint8_t txtiml; /* + 0x7D */
635 volatile uint8_t res66; /* + 0x7E */
636 volatile uint8_t res67; /* + 0x7F */
637 } mscan[MPC5200_CAN_NO];
638
639 volatile uint8_t res[0x100];
640
641 /*
642 * GPIO standard registers (MBAR + 0xB00)
643 */
644 volatile uint32_t gpiopcr; /* + 0x00 */
645 #define GPIO_PCR_CHIP_SELECT_1 0x80000000
646 #define GPIO_PCR_CHIP_ALTS 0x30000000
647 #define GPIO_PCR_CHIP_ALTS_NONE 0x00000000
648 #define GPIO_PCR_CHIP_ALTS_CAN 0x10000000
649 #define GPIO_PCR_CHIP_ALTS_SPI 0x20000000
650 #define GPIO_PCR_CHIP_ALTS_BOTH 0x30000000
651 #define GPIO_PCR_CHIP_SELECT_7 0x08000000
652 #define GPIO_PCR_CHIP_SELECT_6 0x04000000
653 #define GPIO_PCR_CHIP_SELECT_ATA 0x03000000
654 #define GPIO_PCR_CHIP_SELECT_IR_USB_CLK 0x00800000
655 #define GPIO_PCR_IRDA 0x00700000
656 #define GPIO_PCR_ETHERNET 0x000F0000
657 #define GPIO_PCR_PCI_DIS 0x00008000
658 #define GPIO_PCR_USB_SE 0x00004000
659 #define GPIO_PCR_USB_GPIO 0x00003000
660 #define GPIO_PCR_PSC3 0x00000F00
661 #define GPIO_PCR_PSC2 0x00000070
662 #define GPIO_PCR_PSC1 0x00000007
663
664 #define GPIO_S_PIN_IR_USB_CLK BSP_BBIT32(2)
665 #define GPIO_S_PIN_IRDA_TX BSP_BBIT32(3)
666 #define GPIO_S_PIN_ETH_11 BSP_BBIT32(4)
667 #define GPIO_S_PIN_ETH_10 BSP_BBIT32(5)
668 #define GPIO_S_PIN_ETH_9 BSP_BBIT32(6)
669 #define GPIO_S_PIN_ETH_8 BSP_BBIT32(7)
670 #define GPIO_S_PIN_USB1_8 BSP_BBIT32(12)
671 #define GPIO_S_PIN_USB1_7 BSP_BBIT32(13)
672 #define GPIO_S_PIN_USB1_6 BSP_BBIT32(14)
673 #define GPIO_S_PIN_USB1_0 BSP_BBIT32(15)
674 #define GPIO_S_PIN_PSC3_7 BSP_BBIT32(18)
675 #define GPIO_S_PIN_PSC3_6 BSP_BBIT32(19)
676 #define GPIO_S_PIN_PSC3_3 BSP_BBIT32(20)
677 #define GPIO_S_PIN_PSC3_2 BSP_BBIT32(21)
678 #define GPIO_S_PIN_PSC3_1 BSP_BBIT32(22)
679 #define GPIO_S_PIN_PSC3_0 BSP_BBIT32(23)
680 #define GPIO_S_PIN_PSC2_3 BSP_BBIT32(24)
681 #define GPIO_S_PIN_PSC2_2 BSP_BBIT32(25)
682 #define GPIO_S_PIN_PSC2_1 BSP_BBIT32(26)
683 #define GPIO_S_PIN_PSC2_0 BSP_BBIT32(27)
684 #define GPIO_S_PIN_PSC1_3 BSP_BBIT32(28)
685 #define GPIO_S_PIN_PSC1_2 BSP_BBIT32(29)
686 #define GPIO_S_PIN_PSC1_1 BSP_BBIT32(30)
687 #define GPIO_S_PIN_PSC1_0 BSP_BBIT32(31)
688
689 volatile uint32_t gpiosen; /* + 0x04 */
690 volatile uint32_t gpiosod; /* + 0x08 */
691 volatile uint32_t gpiosdd; /* + 0x0C */
692 volatile uint32_t gpiosdo; /* + 0x10 */
693 volatile uint32_t gpiosdi; /* + 0x14 */
694
695 #define GPIO_O_PIN_ETH_7 BSP_BBIT32(0)
696 #define GPIO_O_PIN_ETH_6 BSP_BBIT32(1)
697 #define GPIO_O_PIN_ETH_5 BSP_BBIT32(2)
698 #define GPIO_O_PIN_ETH_4 BSP_BBIT32(3)
699 #define GPIO_O_PIN_ETH_3 BSP_BBIT32(4)
700 #define GPIO_O_PIN_ETH_2 BSP_BBIT32(5)
701 #define GPIO_O_PIN_ETH_1 BSP_BBIT32(6)
702 #define GPIO_O_PIN_ETH_0 BSP_BBIT32(7)
703 #define GPIO_O_PIN_I2C_3 BSP_BBIT32(13)
704 #define GPIO_O_PIN_I2C_0 BSP_BBIT32(14)
705 #define GPIO_O_PIN_I2C_1 BSP_BBIT32(15)
706
707 volatile uint32_t gpiooe; /* + 0x18 */
708 volatile uint32_t gpioodo; /* + 0x1C */
709
710 #define GPIO_I_PIN_ETH_16 BSP_BBIT32(0)
711 #define GPIO_I_PIN_ETH_15 BSP_BBIT32(1)
712 #define GPIO_I_PIN_ETH_14 BSP_BBIT32(2)
713 #define GPIO_I_PIN_ETH_13 BSP_BBIT32(3)
714 #define GPIO_I_PIN_USB1_9 BSP_BBIT32(4)
715 #define GPIO_I_PIN_PSC3_8 BSP_BBIT32(5)
716 #define GPIO_I_PIN_PSC3_5 BSP_BBIT32(6)
717 #define GPIO_I_PIN_PSC3_4 BSP_BBIT32(7)
718
719 volatile uint32_t gpiosie; /* + 0x20 */
720 #define GPIO_SIE_SINT_7_ETH_16_PIN 0x80000000
721 #define GPIO_SIE_SINT_6_ETH_15_PIN 0x40000000
722 #define GPIO_SIE_SINT_5_ETH_14_PIN 0x20000000
723 #define GPIO_SIE_SINT_4_ETH_13_PIN 0x10000000
724 #define GPIO_SIE_SINT_3_USB1_9_PIN 0x08000000
725 #define GPIO_SIE_SINT_2_PSC3_8_PIN 0x04000000
726 #define GPIO_SIE_SINT_1_PSC3_5_PIN 0x02000000
727 #define GPIO_SIE_SINT_0_PSC3_4_PIN 0x01000000
728
729 volatile uint32_t gpiosiod; /* + 0x24 */
730
731 volatile uint32_t gpiosidd; /* + 0x28 */
732 #define GPIO_SIDD_SINT_7_ETH_16_PIN 0x80000000
733 #define GPIO_SIDD_SINT_6_ETH_15_PIN 0x40000000
734 #define GPIO_SIDD_SINT_5_ETH_14_PIN 0x20000000
735 #define GPIO_SIDD_SINT_4_ETH_13_PIN 0x10000000
736 #define GPIO_SIDD_SINT_3_USB1_9_PIN 0x08000000
737 #define GPIO_SIDD_SINT_2_PSC3_8_PIN 0x04000000
738 #define GPIO_SIDD_SINT_1_PSC3_5_PIN 0x02000000
739 #define GPIO_SIDD_SINT_0_PSC3_4_PIN 0x01000000
740
741 volatile uint32_t gpiosido; /* + 0x2C */
742
743 volatile uint32_t gpiosiie; /* + 0x30 */
744 #define GPIO_SIIE_SINT_7_ETH_16_PIN 0x80000000
745 #define GPIO_SIIE_SINT_6_ETH_15_PIN 0x40000000
746 #define GPIO_SIIE_SINT_5_ETH_14_PIN 0x20000000
747 #define GPIO_SIIE_SINT_4_ETH_13_PIN 0x10000000
748 #define GPIO_SIIE_SINT_3_USB1_9_PIN 0x08000000
749 #define GPIO_SIIE_SINT_2_PSC3_8_PIN 0x04000000
750 #define GPIO_SIIE_SINT_1_PSC3_5_PIN 0x02000000
751 #define GPIO_SIIE_SINT_0_PSC3_4_PIN 0x01000000
752
753 volatile uint32_t gpiosiit; /* + 0x34 */
754 #define GPIO_SIIT_SET_ETH_16_PIN(reg, val) BSP_BFLD32SET(reg, val, 0, 1)
755 #define GPIO_SIIT_SET_ETH_15_PIN(reg, val) BSP_BFLD32SET(reg, val, 2, 3)
756 #define GPIO_SIIT_SET_ETH_14_PIN(reg, val) BSP_BFLD32SET(reg, val, 4, 5)
757 #define GPIO_SIIT_SET_ETH_13_PIN(reg, val) BSP_BFLD32SET(reg, val, 6, 7)
758 #define GPIO_SIIT_SET_USB1_9_PIN(reg, val) BSP_BFLD32SET(reg, val, 8, 9)
759 #define GPIO_SIIT_SET_PSC3_8_PIN(reg, val) BSP_BFLD32SET(reg, val, 10, 11)
760 #define GPIO_SIIT_SET_PSC3_5_PIN(reg, val) BSP_BFLD32SET(reg, val, 12, 13)
761 #define GPIO_SIIT_SET_PSC3_4_PIN(reg, val) BSP_BFLD32SET(reg, val, 14, 15)
762
763 #define GPIO_SIIT_SINT_7_ETH_16_PIN_MASK 0xc0000000
764 #define GPIO_SIIT_SINT_6_ETH_15_PIN_MASK 0x30000000
765 #define GPIO_SIIT_SINT_5_ETH_14_PIN_MASK 0x0c000000
766 #define GPIO_SIIT_SINT_4_ETH_13_PIN_MASK 0x03000000
767 #define GPIO_SIIT_SINT_3_USB1_9_PIN_MASK 0x00c00000
768 #define GPIO_SIIT_SINT_2_PSC3_8_PIN_MASK 0x00300000
769 #define GPIO_SIIT_SINT_1_PSC3_5_PIN_MASK 0x000c0000
770 #define GPIO_SIIT_SINT_0_PSC3_4_PIN_MASK 0x00030000
771
772 #define GPIO_SIIT_ON_ANY_TRANSITION 0x00000000
773 #define GPIO_SIIT_ON_RISING_EDGE 0x00000001
774 #define GPIO_SIIT_ON_FALLING_EDGE 0x00000002
775 #define GPIO_SIIT_ON_PULSE 0x00000003
776
777 #define GPIO_SIIT_SINT_7_ETH_16_PIN_SHIFT 16
778 #define GPIO_SIIT_SINT_6_ETH_15_PIN_SHIFT 18
779 #define GPIO_SIIT_SINT_5_ETH_14_PIN_SHIFT 20
780 #define GPIO_SIIT_SINT_4_ETH_13_PIN_SHIFT 22
781 #define GPIO_SIIT_SINT_3_USB1_9_PIN_SHIFT 24
782 #define GPIO_SIIT_SINT_2_PSC3_8_PIN_SHIFT 26
783 #define GPIO_SIIT_SINT_1_PSC3_5_PIN_SHIFT 28
784 #define GPIO_SIIT_SINT_0_PSC3_4_PIN_SHIFT 30
785
786 volatile uint32_t gpiosime; /* + 0x38 */
787 #define GPIO_SIME_MASTER_ENABLE 0x10000000
788
789 volatile uint32_t gpiosist; /* + 0x3C */
790 #define GPIO_SIST_SINT_7_ETH_16_PIN_STATUS 0x80000000
791 #define GPIO_SIST_SINT_6_ETH_15_PIN_STATUS 0x40000000
792 #define GPIO_SIST_SINT_5_ETH_14_PIN_STATUS 0x20000000
793 #define GPIO_SIST_SINT_4_ETH_13_PIN_STATUS 0x10000000
794 #define GPIO_SIST_SINT_3_USB1_9_PIN_STATUS 0x08000000
795 #define GPIO_SIST_SINT_2_PSC3_8_PIN_STATUS 0x04000000
796 #define GPIO_SIST_SINT_1_PSC3_5_PIN_STATUS 0x02000000
797 #define GPIO_SIST_SINT_0_PSC3_4_PIN_STATUS 0x01000000
798 #define GPIO_SIST_SINT_7_ETH_16_PIN_VALUE 0x00800000
799 #define GPIO_SIST_SINT_6_ETH_15_PIN_VALUE 0x00400000
800 #define GPIO_SIST_SINT_5_ETH_14_PIN_VALUE 0x00200000
801 #define GPIO_SIST_SINT_4_ETH_13_PIN_VALUE 0x00100000
802 #define GPIO_SIST_SINT_3_USB1_9_PIN_VALUE 0x00080000
803 #define GPIO_SIST_SINT_2_PSC3_8_PIN_VALUE 0x00040000
804 #define GPIO_SIST_SINT_1_PSC3_5_PIN_VALUE 0x00020000
805 #define GPIO_SIST_SINT_0_PSC3_4_PIN_VALUE 0x00010000
806
807 #define GPIO_SIST_SINT_CLEAR_ALL 0xff000000
808
809 volatile uint8_t res4[0xC0];
810
811 /*
812 * GPIO wakeup registers (MBAR + 0xC00)
813 */
814
815 #define GPIO_W_PIN_GPIO_WKUP_7 BSP_BBIT32(0)
816 #define GPIO_W_PIN_GPIO_WKUP_6 BSP_BBIT32(1)
817 #define GPIO_W_PIN_PSC6_1 BSP_BBIT32(2)
818 #define GPIO_W_PIN_PSC6_0 BSP_BBIT32(3)
819 #define GPIO_W_PIN_ETH_17 BSP_BBIT32(4)
820 #define GPIO_W_PIN_PSC3_9 BSP_BBIT32(5)
821 #define GPIO_W_PIN_PSC2_4 BSP_BBIT32(6)
822 #define GPIO_W_PIN_PSC1_4 BSP_BBIT32(7)
823
824 volatile uint32_t gpiowe; /* + 0x00 */
825 volatile uint32_t gpiowod; /* + 0x04 */
826 volatile uint32_t gpiowdd; /* + 0x08 */
827 volatile uint32_t gpiowdo; /* + 0x0C */
828 volatile uint32_t gpiowue; /* + 0x10 */
829 volatile uint32_t gpiowsie; /* + 0x14 */
830 volatile uint32_t gpiowt; /* + 0x18 */
831 volatile uint32_t gpiowme; /* + 0x1C */
832 volatile uint32_t gpiowi; /* + 0x20 */
833 volatile uint32_t gpiows; /* + 0x24 */
834 volatile uint8_t gpiow_res[0xD8];
835
836 /*
837 * PPC PCI registers (MBAR + 0xD00)
838 */
839 volatile uint8_t ppci[0x100];
840
841 /*
842 * consumer infrared registers (MBAR + 0xE00)
843 */
844 volatile uint8_t ir[0x100];
845
846 /*
847 * serial peripheral interface registers (MBAR + 0xF00)
848 */
849 volatile uint8_t spi[0x100];
850
851 /*
852 * universal serial bus registers (MBAR + 0x1000)
853 */
854 volatile uint8_t usb[0x200];
855
856 /*
857 * SmartComm DMA registers (MBAR + 0x1200)
858 */
859 volatile mpc5200_sdma sdma;
860
861 volatile uint32_t EU00; /* + 0x80 sdMac macer reg */
862 volatile uint32_t EU01; /* + 0x84 sdMac macemr reg */
863 volatile uint32_t EU02; /* + 0x88 unused */
864 volatile uint32_t EU03; /* + 0x8c unused */
865 volatile uint32_t EU04; /* + 0x90 unused */
866 volatile uint32_t EU05; /* + 0x94 unused */
867 volatile uint32_t EU06; /* + 0x98 unused */
868 volatile uint32_t EU07; /* + 0x9c unused */
869 volatile uint32_t EU10; /* + 0xa0 unused */
870 volatile uint32_t EU11; /* + 0xa4 unused */
871 volatile uint32_t EU12; /* + 0xa8 unused */
872 volatile uint32_t EU13; /* + 0xac unused */
873 volatile uint32_t EU14; /* + 0xb0 unused */
874 volatile uint32_t EU15; /* + 0xb4 unused */
875 volatile uint32_t EU16; /* + 0xb8 unused */
876 volatile uint32_t EU17; /* + 0xbc unused */
877 volatile uint32_t EU20; /* + 0xc0 unused */
878 volatile uint32_t EU21; /* + 0xc4 unused */
879 volatile uint32_t EU22; /* + 0xc8 unused */
880 volatile uint32_t EU23; /* + 0xcc unused */
881 volatile uint32_t EU24; /* + 0xd0 unused */
882 volatile uint32_t EU25; /* + 0xd4 unused */
883 volatile uint32_t EU26; /* + 0xd8 unused */
884 volatile uint32_t EU27; /* + 0xdc unused */
885 volatile uint32_t EU30; /* + 0xe0 unused */
886 volatile uint32_t EU31; /* + 0xe4 unused */
887 volatile uint32_t EU32; /* + 0xe8 unused */
888 volatile uint32_t EU33; /* + 0xec unused */
889 volatile uint32_t EU34; /* + 0xf0 unused */
890 volatile uint32_t EU35; /* + 0xf4 unused */
891 volatile uint32_t EU36; /* + 0xf8 unused */
892 volatile uint32_t EU37; /* + 0xfc unused */
893#if 0
894 volatile uint32_t res8[0x340];
895#else
896 volatile uint8_t res_1300[0xc00];
897
898 volatile uint32_t reserved0; /* MBAR_XLB_ARB + 0x0000 reserved */
899 volatile uint32_t reserved1; /* MBAR_XLB_ARB + 0x0004 reserved */
900 volatile uint32_t reserved2; /* MBAR_XLB_ARB + 0x0008 reserved */
901 volatile uint32_t reserved3; /* MBAR_XLB_ARB + 0x000c reserved */
902 volatile uint32_t reserved4; /* MBAR_XLB_ARB + 0x0010 reserved */
903 volatile uint32_t reserved5; /* MBAR_XLB_ARB + 0x0014 reserved */
904 volatile uint32_t reserved6; /* MBAR_XLB_ARB + 0x0018 reserved */
905 volatile uint32_t reserved7; /* MBAR_XLB_ARB + 0x001c reserved */
906 volatile uint32_t reserved8; /* MBAR_XLB_ARB + 0x0020 reserved */
907 volatile uint32_t reserved9; /* MBAR_XLB_ARB + 0x0024 reserved */
908 volatile uint32_t reserved10; /* MBAR_XLB_ARB + 0x0028 reserved */
909 volatile uint32_t reserved11; /* MBAR_XLB_ARB + 0x002c reserved */
910 volatile uint32_t reserved12; /* MBAR_XLB_ARB + 0x0030 reserved */
911 volatile uint32_t reserved13; /* MBAR_XLB_ARB + 0x0034 reserved */
912 volatile uint32_t reserved14; /* MBAR_XLB_ARB + 0x0038 reserved */
913 volatile uint32_t reserved15; /* MBAR_XLB_ARB + 0x003c reserved */
914
915#define XLB_CFG_PLDIS BSP_BBIT32(0)
916#define XLB_CFG_BSDIS BSP_BBIT32(15)
917#define XLB_CFG_SE BSP_BBIT32(16)
918#define XLB_CFG_USE_WWF BSP_BBIT32(17)
919#define XLB_CFG_TBEN BSP_BBIT32(18)
920#define XLB_CFG_WS BSP_BBIT32(20)
921#define XLB_CFG_SP(val) BSP_BFLD32(val, 21, 23)
922#define XLB_CFG_SET_SP(reg, val) BSP_BFLD32SET(reg, val, 21, 23)
923#define XLB_CFG_PM(val) BSP_BFLD32(val, 25, 26)
924#define XLB_CFG_SET_PM(reg, val) BSP_BFLD32SET(reg, val, 25, 26)
925#define XLB_CFG_BA BSP_BBIT32(28)
926#define XLB_CFG_DT BSP_BBIT32(29)
927#define XLB_CFG_AT BSP_BBIT32(30)
928
929 volatile uint32_t config; /* MBAR_XLB_ARB + 0x0040 */
930 volatile uint32_t version; /* MBAR_XLB_ARB + 0x0044 */
931
932#define XLB_ST_SEA BSP_BBIT32(23)
933#define XLB_ST_MM BSP_BBIT32(24)
934#define XLB_ST_TTA BSP_BBIT32(25)
935#define XLB_ST_TTR BSP_BBIT32(26)
936#define XLB_ST_ECW BSP_BBIT32(27)
937#define XLB_ST_TTM BSP_BBIT32(28)
938#define XLB_ST_BA BSP_BBIT32(29)
939#define XLB_ST_DT BSP_BBIT32(30)
940#define XLB_ST_AT BSP_BBIT32(31)
941 /* read only = 0x0001 */
942 volatile uint32_t xlb_status; /* MBAR_XLB_ARB + 0x0048 */
943 volatile uint32_t int_enable; /* MBAR_XLB_ARB + 0x004c */
944 volatile uint32_t add_capture; /* MBAR_XLB_ARB + 0x0050 read only */
945 volatile uint32_t bus_sig_capture; /* MBAR_XLB_ARB + 0x0054 read only */
946 volatile uint32_t add_time_out; /* MBAR_XLB_ARB + 0x0058 */
947 volatile uint32_t data_time_out; /* MBAR_XLB_ARB + 0x005c */
948 volatile uint32_t bus_time_out; /* MBAR_XLB_ARB + 0x0060 */
949 volatile uint32_t priority_enable; /* MBAR_XLB_ARB + 0x0064 */
950 volatile uint32_t priority; /* MBAR_XLB_ARB + 0x0068 */
951 volatile uint32_t arb_base_addr2; /* MBAR_XLB_ARB + 0x006c */
952 volatile uint32_t snoop_window; /* MBAR_XLB_ARB + 0x0070 */
953
954 volatile uint32_t reserved16; /* MBAR_XLB_ARB + 0x0074 reserved */
955 volatile uint32_t reserved17; /* MBAR_XLB_ARB + 0x0078 reserved */
956 volatile uint32_t reserved18; /* MBAR_XLB_ARB + 0x007c reserved */
957
958 volatile uint32_t control; /* MBAR_XLB_ARB + 0x0080 */
959 volatile uint32_t init_total_count; /* MBAR_XLB_ARB + 0x0084 */
960 volatile uint32_t int_total_count; /* MBAR_XLB_ARB + 0x0088 */
961
962 volatile uint32_t reserved19; /* MBAR_XLB_ARB + 0x008c reserved */
963
964 volatile uint32_t lower_address; /* MBAR_XLB_ARB + 0x0090 */
965 volatile uint32_t higher_address; /* MBAR_XLB_ARB + 0x0094 */
966 volatile uint32_t int_window_count; /* MBAR_XLB_ARB + 0x0098 */
967 volatile uint32_t window_ter_count; /* MBAR_XLB_ARB + 0x009c */
968 volatile uint8_t res_0x1fa0[0x60];
969
970
971#endif
972 /*
973 * programmable serial controller 1 (MBAR + 0x2000)
974 */
975
976 struct mpc5200_psc {
977 volatile uint8_t mr; /* + 0x00 */
978 volatile uint8_t res1[3];
979 volatile uint16_t sr_csr; /* + 0x04 */
980 volatile uint16_t res2[1];
981 volatile uint16_t cr; /* + 0x08 */
982 volatile uint16_t res3[1];
983 volatile uint32_t rb_tb; /* + 0x0c */
984 volatile uint16_t ipcr_acr; /* + 0x10 */
985 volatile uint16_t res4[1];
986 volatile uint16_t isr_imr; /* + 0x14 */
987#define ISR_TX_RDY (1 << 8)
988#define ISR_RX_RDY_FULL (1 << 9)
989#define ISR_RB (1 << 15)
990#define ISR_FE (1 << 14)
991#define ISR_PE (1 << 13)
992#define ISR_OE (1 << 12)
993#define ISR_ERROR (ISR_FE | ISR_PE | ISR_OE)
994
995#define IMR_TX_RDY (1 << 8)
996#define IMR_RX_RDY_FULL (1 << 9)
997 volatile uint16_t res5[1];
998 volatile uint8_t ctur; /* + 0x18 */
999 volatile uint8_t res6[3];
1000 volatile uint8_t ctlr; /* + 0x1C */
1001 volatile uint8_t res7[0x13];
1002 volatile uint8_t ivr; /* + 0x30 */
1003 volatile uint8_t res8[3];
1004 volatile uint8_t ip; /* + 0x34 */
1005 volatile uint8_t res9[3];
1006 volatile uint8_t op1; /* + 0x38 */
1007 volatile uint8_t res10[3];
1008 volatile uint8_t op0; /* + 0x3C */
1009 volatile uint8_t res11[3];
1010 volatile uint8_t sicr; /* + 0x40 */
1011 volatile uint8_t res12[0x17];
1012 volatile uint16_t rfnum; /* + 0x58 */
1013 volatile uint16_t res13[1];
1014 volatile uint16_t tfnum; /* + 0x5C */
1015 volatile uint16_t res14[1];
1016 volatile uint16_t rfdata; /* + 0x60 */
1017 volatile uint16_t res15[1];
1018 volatile uint16_t rfstat; /* + 0x64 */
1019 volatile uint16_t res16[1];
1020 volatile uint8_t rfcntl; /* + 0x68 */
1021 volatile uint8_t res17[5];
1022 volatile uint16_t rfalarm; /* + 0x6E */
1023 volatile uint8_t res18[2];
1024 volatile uint16_t rfrptr; /* + 0x72 */
1025 volatile uint16_t res19[1];
1026 volatile uint16_t rfwptr; /* + 0x76 */
1027 volatile uint16_t res20[1];
1028 volatile uint16_t rflrfptr; /* + 0x7A */
1029 volatile uint16_t rflwfptr; /* + 0x7C */
1030 volatile uint16_t res21[1];
1031 volatile uint16_t tfdata; /* + 0x80 */
1032 volatile uint16_t res22[1];
1033 volatile uint16_t tfstat; /* + 0x84 */
1034 volatile uint16_t res23[1];
1035 volatile uint8_t tfcntl; /* + 0x88 */
1036 volatile uint8_t res24[5];
1037 volatile uint16_t tfalarm; /* + 0x8E */
1038 volatile uint8_t res25[2];
1039 volatile uint16_t tfrptr; /* + 0x92 */
1040 volatile uint16_t res26[1];
1041 volatile uint16_t tfwptr; /* + 0x96 */
1042 volatile uint16_t res27[1];
1043 volatile uint16_t tflrfptr; /* + 0x96 */
1044 volatile uint16_t tflwfptr; /* + 0x9C */
1045 volatile uint16_t res28[1]; /* end at offset 0x9F */
1046 volatile uint8_t res29[0x160];
1047 } psc[MPC5200_PSC_REG_SETS];
1048 /* XXX: there are only 6 PSCs, but PSC6 has an extra register gap
1049 * from PSC5, therefore we instantiate seven(!) PSC register sets
1050 */
1051
1052#define TX_FIFO_SIZE 256
1053#define RX_FIFO_SIZE 512
1054
1055
1056 volatile uint8_t irda[0x200];
1057
1058 /*
1059 * ethernet registers (MBAR + 0x3000)
1060 */
1061
1062 /* Control and status Registers (offset 000-1FF) */
1063
1064 volatile uint32_t fec_id; /* + 0x000 */
1065 volatile uint32_t ievent; /* + 0x004 */
1066 volatile uint32_t imask; /* + 0x008 */
1067
1068 volatile uint32_t res9[1]; /* + 0x00C */
1069 volatile uint32_t r_des_active; /* + 0x010 */
1070 volatile uint32_t x_des_active; /* + 0x014 */
1071 volatile uint32_t r_des_active_cl; /* + 0x018 */
1072 volatile uint32_t x_des_active_cl; /* + 0x01C */
1073 volatile uint32_t ivent_set; /* + 0x020 */
1074 volatile uint32_t ecntrl; /* + 0x024 */
1075
1076 volatile uint32_t res10[6]; /* + 0x028-03C */
1077 volatile uint32_t mii_data; /* + 0x040 */
1078 volatile uint32_t mii_speed; /* + 0x044 */
1079 volatile uint32_t mii_status; /* + 0x048 */
1080
1081 volatile uint32_t res11[5]; /* + 0x04C-05C */
1082 volatile uint32_t mib_data; /* + 0x060 */
1083 volatile uint32_t mib_control; /* + 0x064 */
1084
1085 volatile uint32_t res12[6]; /* + 0x068-7C */
1086 volatile uint32_t r_activate; /* + 0x080 */
1087 volatile uint32_t r_cntrl; /* + 0x084 */
1088 volatile uint32_t r_hash; /* + 0x088 */
1089 volatile uint32_t r_data; /* + 0x08C */
1090 volatile uint32_t ar_done; /* + 0x090 */
1091 volatile uint32_t r_test; /* + 0x094 */
1092 volatile uint32_t r_mib; /* + 0x098 */
1093 volatile uint32_t r_da_low; /* + 0x09C */
1094 volatile uint32_t r_da_high; /* + 0x0A0 */
1095
1096 volatile uint32_t res13[7]; /* + 0x0A4-0BC */
1097 volatile uint32_t x_activate; /* + 0x0C0 */
1098 volatile uint32_t x_cntrl; /* + 0x0C4 */
1099 volatile uint32_t backoff; /* + 0x0C8 */
1100 volatile uint32_t x_data; /* + 0x0CC */
1101 volatile uint32_t x_status; /* + 0x0D0 */
1102 volatile uint32_t x_mib; /* + 0x0D4 */
1103 volatile uint32_t x_test; /* + 0x0D8 */
1104 volatile uint32_t fdxfc_da1; /* + 0x0DC */
1105 volatile uint32_t fdxfc_da2; /* + 0x0E0 */
1106 volatile uint32_t paddr1; /* + 0x0E4 */
1107 volatile uint32_t paddr2; /* + 0x0E8 */
1108 volatile uint32_t op_pause; /* + 0x0EC */
1109
1110 volatile uint32_t res14[4]; /* + 0x0F0-0FC */
1111 volatile uint32_t instr_reg; /* + 0x100 */
1112 volatile uint32_t context_reg; /* + 0x104 */
1113 volatile uint32_t test_cntrl; /* + 0x108 */
1114 volatile uint32_t acc_reg; /* + 0x10C */
1115 volatile uint32_t ones; /* + 0x110 */
1116 volatile uint32_t zeros; /* + 0x114 */
1117 volatile uint32_t iaddr1; /* + 0x118 */
1118 volatile uint32_t iaddr2; /* + 0x11C */
1119 volatile uint32_t gaddr1; /* + 0x120 */
1120 volatile uint32_t gaddr2; /* + 0x124 */
1121 volatile uint32_t random; /* + 0x128 */
1122 volatile uint32_t rand1; /* + 0x12C */
1123 volatile uint32_t tmp; /* + 0x130 */
1124
1125 volatile uint32_t res15[3]; /* + 0x134-13C */
1126 volatile uint32_t fifo_id; /* + 0x140 */
1127 volatile uint32_t x_wmrk; /* + 0x144 */
1128 volatile uint32_t fcntrl; /* + 0x148 */
1129 volatile uint32_t r_bound; /* + 0x14C */
1130 volatile uint32_t r_fstart; /* + 0x150 */
1131 volatile uint32_t r_count; /* + 0x154 */
1132 volatile uint32_t r_lag; /* + 0x158 */
1133 volatile uint32_t r_read; /* + 0x15C */
1134 volatile uint32_t r_write; /* + 0x160 */
1135 volatile uint32_t x_count; /* + 0x164 */
1136 volatile uint32_t x_lag; /* + 0x168 */
1137 volatile uint32_t x_retry; /* + 0x16C */
1138 volatile uint32_t x_write; /* + 0x170 */
1139 volatile uint32_t x_read; /* + 0x174 */
1140
1141 volatile uint32_t res16[2]; /* + 0x178-17C */
1142 volatile uint32_t fm_cntrl; /* + 0x180 */
1143 volatile uint32_t rfifo_data; /* + 0x184 */
1144 volatile uint32_t rfifo_status; /* + 0x188 */
1145 volatile uint32_t rfifo_cntrl; /* + 0x18C */
1146 volatile uint32_t rfifo_lrf_ptr; /* + 0x190 */
1147 volatile uint32_t rfifo_lwf_ptr; /* + 0x194 */
1148 volatile uint32_t rfifo_alarm; /* + 0x198 */
1149 volatile uint32_t rfifo_rdptr; /* + 0x19C */
1150 volatile uint32_t rfifo_wrptr; /* + 0x1A0 */
1151 volatile uint32_t tfifo_data; /* + 0x1A4 */
1152 volatile uint32_t tfifo_status; /* + 0x1A8 */
1153 volatile uint32_t tfifo_cntrl; /* + 0x1AC */
1154 volatile uint32_t tfifo_lrf_ptr; /* + 0x1B0 */
1155 volatile uint32_t tfifo_lwf_ptr; /* + 0x1B4 */
1156 volatile uint32_t tfifo_alarm; /* + 0x1B8 */
1157 volatile uint32_t tfifo_rdptr; /* + 0x1BC */
1158 volatile uint32_t tfifo_wrptr; /* + 0x1C0 */
1159
1160 volatile uint32_t reset_cntrl; /* + 0x1C4 */
1161 volatile uint32_t xmit_fsm; /* + 0x1C8 */
1162
1163 volatile uint32_t res17[3]; /* + 0x1CC-1D4 */
1164 volatile uint32_t rdes_data0; /* + 0x1D8 */
1165 volatile uint32_t rdes_data1; /* + 0x1DC */
1166 volatile uint32_t r_length; /* + 0x1E0 */
1167 volatile uint32_t x_length; /* + 0x1E4 */
1168 volatile uint32_t x_addr; /* + 0x1E8 */
1169 volatile uint32_t cdes_data; /* + 0x1EC */
1170 volatile uint32_t status; /* + 0x1F0 */
1171 volatile uint32_t dma_control; /* + 0x1F4 */
1172 volatile uint32_t des_cmnd; /* + 0x1F8 */
1173 volatile uint32_t data; /* + 0x1FC */
1174
1175 volatile uint8_t RES[0x600];
1176
1177
1178#if 0
1179 /* MIB COUNTERS (Offset 200-2FF) */
1180
1181 volatile uint32_t rmon_t_drop; /* + 0x200 */
1182 volatile uint32_t rmon_t_packets; /* + 0x204 */
1183 volatile uint32_t rmon_t_bc_pkt; /* + 0x208 */
1184 volatile uint32_t rmon_t_mc_pkt; /* + 0x20C */
1185 volatile uint32_t rmon_t_crc_align; /* + 0x210 */
1186 volatile uint32_t rmon_t_undersize; /* + 0x214 */
1187 volatile uint32_t rmon_t_oversize; /* + 0x218 */
1188 volatile uint32_t rmon_t_frag; /* + 0x21C */
1189 volatile uint32_t rmon_t_jab; /* + 0x220 */
1190 volatile uint32_t rmon_t_col; /* + 0x224 */
1191 volatile uint32_t rmon_t_p64; /* + 0x228 */
1192 volatile uint32_t rmon_t_p65to127; /* + 0x22C */
1193 volatile uint32_t rmon_t_p128to255; /* + 0x230 */
1194 volatile uint32_t rmon_t_p256to511; /* + 0x234 */
1195 volatile uint32_t rmon_t_p512to1023; /* + 0x238 */
1196 volatile uint32_t rmon_t_p1024to2047; /* + 0x23C */
1197 volatile uint32_t rmon_t_p_gte2048; /* + 0x240 */
1198 volatile uint32_t rmon_t_octets; /* + 0x244 */
1199 volatile uint32_t ieee_t_drop; /* + 0x248 */
1200 volatile uint32_t ieee_t_frame_ok; /* + 0x24C */
1201 volatile uint32_t ieee_t_1col; /* + 0x250 */
1202 volatile uint32_t ieee_t_mcol; /* + 0x254 */
1203 volatile uint32_t ieee_t_def; /* + 0x258 */
1204 volatile uint32_t ieee_t_lcol; /* + 0x25C */
1205 volatile uint32_t ieee_t_excol; /* + 0x260 */
1206 volatile uint32_t ieee_t_macerr; /* + 0x264 */
1207 volatile uint32_t ieee_t_cserr; /* + 0x268 */
1208 volatile uint32_t ieee_t_sqe; /* + 0x26C */
1209 volatile uint32_t t_fdxfc; /* + 0x270 */
1210 volatile uint32_t ieee_t_octets_ok; /* + 0x274 */
1211
1212 volatile uint32_t res18[2]; /* + 0x278-27C */
1213 volatile uint32_t rmon_r_drop; /* + 0x280 */
1214 volatile uint32_t rmon_r_packets; /* + 0x284 */
1215 volatile uint32_t rmon_r_bc_pkt; /* + 0x288 */
1216 volatile uint32_t rmon_r_mc_pkt; /* + 0x28C */
1217 volatile uint32_t rmon_r_crc_align; /* + 0x290 */
1218 volatile uint32_t rmon_r_undersize; /* + 0x294 */
1219 volatile uint32_t rmon_r_oversize; /* + 0x298 */
1220 volatile uint32_t rmon_r_frag; /* + 0x29C */
1221 volatile uint32_t rmon_r_jab; /* + 0x2A0 */
1222
1223 volatile uint32_t rmon_r_resvd_0; /* + 0x2A4 */
1224
1225 volatile uint32_t rmon_r_p64; /* + 0x2A8 */
1226 volatile uint32_t rmon_r_p65to127; /* + 0x2AC */
1227 volatile uint32_t rmon_r_p128to255; /* + 0x2B0 */
1228 volatile uint32_t rmon_r_p256to511; /* + 0x2B4 */
1229 volatile uint32_t rmon_r_p512to1023; /* + 0x2B8 */
1230 volatile uint32_t rmon_r_p1024to2047; /* + 0x2BC */
1231 volatile uint32_t rmon_r_p_gte2048; /* + 0x2C0 */
1232 volatile uint32_t rmon_r_octets; /* + 0x2C4 */
1233 volatile uint32_t ieee_r_drop; /* + 0x2C8 */
1234 volatile uint32_t ieee_r_frame_ok; /* + 0x2CC */
1235 volatile uint32_t ieee_r_crc; /* + 0x2D0 */
1236 volatile uint32_t ieee_r_align; /* + 0x2D4 */
1237 volatile uint32_t r_macerr; /* + 0x2D8 */
1238 volatile uint32_t r_fdxfc; /* + 0x2DC */
1239 volatile uint32_t ieee_r_octets_ok; /* + 0x2E0 */
1240
1241 volatile uint32_t res19[6]; /* + 0x2E4-2FC */
1242
1243 volatile uint32_t res20[64]; /* + 0x300-3FF */
1244
1245 volatile uint32_t res21[256]; /* + 0x400-800 */
1246#endif
1247
1248 /*
1249 * SmartComm DMA PCI registers (MBAR + 0x3800)
1250 */
1251 volatile uint8_t pci[0x200];
1252
1253 /*
1254 * advanced technology attachment registers (MBAR + 0x3A00)
1255 */
1256
1257 /* ATA host registers (offset 0x00-0x28) */
1258 volatile uint32_t ata_hcfg; /* + 0x00 */
1259 volatile uint32_t ata_hsr; /* + 0x04 */
1260 volatile uint32_t ata_pio1; /* + 0x08 */
1261 volatile uint32_t ata_pio2; /* + 0x0C */
1262 volatile uint32_t ata_dma1; /* + 0x10 */
1263 volatile uint32_t ata_dma2; /* + 0x14 */
1264 volatile uint32_t ata_udma1; /* + 0x18 */
1265 volatile uint32_t ata_udma2; /* + 0x1C */
1266 volatile uint32_t ata_udma3; /* + 0x20 */
1267 volatile uint32_t ata_udma4; /* + 0x24 */
1268 volatile uint32_t ata_udma5; /* + 0x28 */
1269 volatile uint32_t ata_res1[4]; /* + 0x2C-0x3C */
1270
1271 /* ATA FIFO registers (offset 0x3C-0x50) */
1272 volatile uint32_t ata_rtfdwr; /* + 0x3C */
1273
1274#define ATA_RTFSR_ERR BSP_BBIT32(9)
1275#define ATA_RTFSR_UF BSP_BBIT32(10)
1276#define ATA_RTFSR_OF BSP_BBIT32(11)
1277#define ATA_RTFSR_FULL BSP_BBIT32(12)
1278#define ATA_RTFSR_HI BSP_BBIT32(13)
1279#define ATA_RTFSR_LO BSP_BBIT32(14)
1280#define ATA_RTFSR_EMPTY BSP_BBIT32(15)
1281
1282 volatile uint32_t ata_rtfsr; /* + 0x40 */
1283
1284#define ATA_RTFCR_WFR BSP_BBIT32(2)
1285#define ATA_RTFCR_GR(val) BSP_BFLD32(val, 5, 7)
1286
1287 volatile uint32_t ata_rtfcr; /* + 0x44 */
1288 volatile uint32_t ata_rtfar; /* + 0x48 */
1289 volatile uint32_t ata_rtfrpr; /* + 0x4C */
1290 volatile uint32_t ata_rtfwpr; /* + 0x50 */
1291 volatile uint32_t ata_res2[2]; /* + 0x54-0x5C */
1292
1293 /* ATA drive registers (offset 0x5C-0x80) */
1294 volatile uint32_t ata_dctr_dasr; /* + 0x5C */
1295 volatile uint32_t ata_ddr; /* + 0x60 */
1296 volatile uint32_t ata_dfr_der; /* + 0x64 */
1297 volatile uint32_t ata_dscr; /* + 0x68 */
1298 volatile uint32_t ata_dsnr; /* + 0x6C */
1299 volatile uint32_t ata_dclr; /* + 0x70 */
1300 volatile uint32_t ata_dchr; /* + 0x74 */
1301 volatile uint32_t ata_ddhr; /* + 0x78 */
1302 volatile uint32_t ata_dcr_dsr; /* + 0x7C */
1303 volatile uint32_t ata_res3[0xA0]; /* + 0x80-0x200 */
1304
1305 /*
1306 * inter-integrated circuit registers (MBAR + 0x3D00)
1307 */
1309 volatile uint8_t madr; /* i2c address reg. + 0x00 */
1310 volatile uint8_t res_1[3];
1311 volatile uint8_t mfdr; /* i2c freq. divider reg. + 0x04 */
1312 volatile uint8_t res_5[3];
1313 volatile uint8_t mcr; /* i2c control reg. + 0x08 */
1314 volatile uint8_t res_9[3];
1315
1316#define MPC5200_I2C_MCR_MEN (1 << (7-0))
1317#define MPC5200_I2C_MCR_MIEN (1 << (7-1))
1318#define MPC5200_I2C_MCR_MSTA (1 << (7-2))
1319#define MPC5200_I2C_MCR_MTX (1 << (7-3))
1320#define MPC5200_I2C_MCR_TXAK (1 << (7-4))
1321#define MPC5200_I2C_MCR_RSTA (1 << (7-5))
1322
1323 volatile uint8_t msr; /* i2c status reg. + 0x0C */
1324 volatile uint8_t res_d[3];
1325#define MPC5200_I2C_MSR_CF (1 << (7-0))
1326#define MPC5200_I2C_MSR_MAAS (1 << (7-1))
1327#define MPC5200_I2C_MSR_BB (1 << (7-2))
1328#define MPC5200_I2C_MSR_MAL (1 << (7-3))
1329#define MPC5200_I2C_MSR_SRW (1 << (7-5))
1330#define MPC5200_I2C_MSR_MIF (1 << (7-6))
1331#define MPC5200_I2C_MSR_RXAK (1 << (7-7))
1332 volatile uint8_t mdr; /* i2c data I/O reg. + 0x10 */
1333 volatile uint8_t res_11[3];
1334 volatile uint8_t res_14[12]; /* reserved + 0x14 */
1335 volatile uint8_t icr; /* i2c irq ctrl reg. + 0x20 */
1336#define MPC5200_I2C_ICR_BNBE2 (1 << (7-0))
1337#define MPC5200_I2C_ICR_TE2 (1 << (7-1))
1338#define MPC5200_I2C_ICR_RE2 (1 << (7-2))
1339#define MPC5200_I2C_ICR_IE2 (1 << (7-3))
1340#define MPC5200_I2C_ICR_MASK2 (MPC5200_I2C_ICR_BNBE2|MPC5200_I2C_ICR_TE2\
1341 |MPC5200_I2C_ICR_RE2|MPC5200_I2C_ICR_IE2)
1342#define MPC5200_I2C_ICR_BNBE1 (1 << (7-4))
1343#define MPC5200_I2C_ICR_TE1 (1 << (7-5))
1344#define MPC5200_I2C_ICR_RE1 (1 << (7-6))
1345#define MPC5200_I2C_ICR_IE1 (1 << (7-7))
1346#define MPC5200_I2C_ICR_MASK1 (MPC5200_I2C_ICR_BNBE1|MPC5200_I2C_ICR_TE1\
1347 |MPC5200_I2C_ICR_RE1|MPC5200_I2C_ICR_IE1)
1348 volatile uint8_t res_21[3];
1349 volatile uint32_t res_24[7]; /* reserved + 0x24 */
1350 } i2c_regs[2];
1351 volatile uint8_t res_3d80[0x280];
1352
1353 /*
1354 * on-chip static RAM memory locations (MBAR + 0x4000)
1355 */
1356 volatile uint8_t sram_res0x4000[0x4000];
1357 volatile uint8_t sram[0x4000];
1358
1359} mpc5200_t;
1360
1361extern volatile mpc5200_t mpc5200;
1362
1363#ifdef __cplusplus
1364}
1365#endif
1366
1367#endif /*ASM*/
1368
1369#endif /* __MPC5200_h__ */
struct mpc5200_mscan mscan
MSCAN registers.
Definition: mscan-base.h:242
Utility macros.
Definition: deflate.c:115
Definition: intercom.c:74
Definition: i2c.h:52
Definition: mpc5200.h:456
Definition: mpc5200.h:1308
Definition: mpc5200.h:508
Definition: mpc5200.h:976
Definition: mpc5200.h:490
Definition: mpc5200.h:387
Definition: mpc5200.h:264
Definition: mpc5200.h:343
Definition: mpc5200.h:241
