RTEMS 5.2-rc1
mcid.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
64#ifndef MCID_H
65#define MCID_H
70/*----------------------------------------------------------------------------
71 * Headers
72 *----------------------------------------------------------------------------*/
73
74#include "chip.h"
75
76#include <stdint.h>
77#include <stdio.h>
78
82/*----------------------------------------------------------------------------
83 * Constants
84 *----------------------------------------------------------------------------*/
85
87#define MCID_IDLE 0
88#define MCID_LOCKED 1
89#define MCID_CMD 2
90#define MCID_ERROR 3
93#define MCI_INITIAL_SPEED 400000
94
97/*----------------------------------------------------------------------------
98 * Types
99 *----------------------------------------------------------------------------*/
103#ifdef __cplusplus
104extern "C" {
105#endif
106
110typedef struct _Mcid {
116 void *pCmd;
118 uint32_t dwMck;
120 uint32_t dwDmaCh;
122 uint32_t dwXfrNdx;
124 uint32_t dwXSize;
126 uint8_t bID;
128 uint8_t bPolling;
130 uint8_t reserved;
132 volatile uint8_t bState;
134
136/*----------------------------------------------------------------------------
137 * Exported functions
138 *----------------------------------------------------------------------------*/
141extern void MCID_Init(sMcid *pMcid,
142 Hsmci *pMci, uint8_t bID, uint32_t dwMck,
143 sXdmad *pXdmad,
144 uint8_t bPolling);
145
146extern void MCID_Reset(sMcid *pMcid);
147
148extern void MCID_SetSlot(Hsmci *pMci, uint8_t slot);
149
150extern uint32_t MCID_Lock(sMcid *pMcid, uint8_t bSlot);
151
152extern uint32_t MCID_Release(sMcid *pMcid);
153
154extern void MCID_Handler(sMcid *pMcid);
155
156extern uint32_t MCID_SendCmd(sMcid *pMcid, void *pCmd);
157
158extern uint32_t MCID_CancelCmd(sMcid *pMcid);
159
160extern uint32_t MCID_IsCmdCompleted(sMcid *pMcid);
161
162extern uint32_t MCID_IOCtrl(sMcid *pMcid, uint32_t bCtl, uint32_t param);
163
164#ifdef __cplusplus
165}
166#endif
169#endif //#ifndef HSMCID_H
170
struct _Mcid sMcid
MCI Driver.
Hsmci hardware registers.
Definition: component_hsmci.h:41
MCI Driver.
Definition: mcid.h:110
uint32_t dwDmaCh
Definition: mcid.h:120
uint8_t reserved
Definition: mcid.h:130
sXdmad * pXdmad
Definition: mcid.h:114
uint8_t bID
Definition: mcid.h:126
void * pCmd
Definition: mcid.h:116
uint32_t dwXfrNdx
Definition: mcid.h:122
uint32_t dwXSize
Definition: mcid.h:124
uint32_t dwMck
Definition: mcid.h:118
Hsmci * pMciHw
Definition: mcid.h:112
Definition: mcid.h:132
uint8_t bPolling
Definition: mcid.h:128
Definition: xdmad.h:127
