RTEMS
5.2-rc1
bsps
m68k
include
mcf5206
mcfuart.h
1
2
* Generic UART Serial driver for Motorola Coldfire processors definitions
3
4
* Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russian Fed.
5
* Author: Victor V. Vengerov <vvv@oktet.ru>
6
7
* The license and distribution terms for this file may be
8
* found in the file LICENSE in this distribution or at
9
* http://www.rtems.org/license/LICENSE.
10
11
12
#ifndef __MCFUART_H__
13
#define __MCFUART_H__
14
15
#include <termios.h>
16
#include "bsp.h"
17
#include "mcf5206e.h"
18
19
20
* The MCF5206e System Clock Frequency; 54MHz default
21
22
#ifndef SYSTEM_CLOCK_FREQUENCY
23
#define SYSTEM_CLOCK_FREQUENCY BSP_SYSTEM_FREQUENCY
24
#endif
25
26
27
* The following structure is a descriptor of single UART channel.
28
* It contains the initialization information about channel and
29
* current operating values
30
31
typedef
struct
mcfuart
32
uint32_t chn;
/* UART channel number */
33
uint8_t intvec;
/* UART interrupt vector number, or
34
0 if polled I/O */
35
void
*tty;
/* termios channel descriptor */
36
37
volatile
const
char
*tx_buf;
/* Transmit buffer from termios */
38
volatile
uint32_t tx_buf_len;
/* Transmit buffer length */
39
volatile
uint32_t tx_ptr;
/* Index of next char to transmit*/
40
rtems_isr_entry old_handler;
/* Saved interrupt handler */
41
42
tcflag_t c_iflag;
/* termios input mode flags */
43
bool
parerr_mark_flag;
/* Parity error processing
44
state */
45
mcfuart
46
47
/* mcfuart_init --
48
* This function verifies the input parameters and perform initialization
49
* of the Motorola Coldfire on-chip UART descriptor structure.
50
51
52
rtems_status_code
53
mcfuart_init(
mcfuart
*uart,
void
*tty, uint8_t intvec,
54
uint32_t chn);
55
56
/* mcfuart_reset --
57
* This function perform the hardware initialization of Motorola
58
* Coldfire processor on-chip UART controller using parameters
59
* filled by the mcfuart_init function.
60
61
rtems_status_code
62
mcfuart_reset(
mcfuart
*uart);
63
64
/* mcfuart_disable --
65
* This function disable the operations on Motorola Coldfire UART
66
* controller
67
68
rtems_status_code
69
mcfuart_disable(
mcfuart
*uart);
70
71
/* mcfuart_set_attributes --
72
* This function parse the termios attributes structure and perform
73
* the appropriate settings in hardware.
74
75
int
76
mcfuart_set_attributes(
mcfuart
*mcf,
const
struct
termios *t);
77
78
/* mcfuart_poll_read --
79
* This function tried to read character from MCF UART and perform
80
* error handling.
81
82
int
83
mcfuart_poll_read(
mcfuart
*uart);
84
85
/* mcfuart_interrupt_write --
86
* This function initiate transmitting of the buffer in interrupt mode.
87
88
ssize_t
89
mcfuart_interrupt_write(
mcfuart
*uart,
const
char
*buf,
size_t
len);
90
91
/* mcfuart_poll_write --
92
* This function transmit buffer byte-by-byte in polling mode.
93
94
ssize_t
95
mcfuart_poll_write(
mcfuart
*uart,
const
char
*buf,
size_t
len);
96
97
/* mcfuart_stop_remote_tx --
98
* This function stop data flow from remote device.
99
100
int
101
mcfuart_stop_remote_tx(
mcfuart
*uart);
102
103
/* mcfuart_start_remote_tx --
104
* This function resume data flow from remote device.
105
106
int
107
mcfuart_start_remote_tx(
mcfuart
*uart);
108
109
#endif
rtems_status_code
rtems_status_code
Classic API Status.
Definition:
status.h:43
mcfuart
Definition:
mcfuart.h:31
