RTEMS 5.2-rc1
mcf5282.h
1/*
2 *******************************************
3 * Definitions from Motorola/FreeScale *
4 *******************************************
5 */
6
7/*
8 * File: mcf5282.h
9 * Purpose: MCF5282 definitions
10 *
11 * Notes:
12 */
13
14#ifndef _CPU_MCF5282_H
15#define _CPU_MCF5282_H
16
17/********************************************************************/
18
19/*
20 * File: mcf5xxx.h
21 * Purpose: Definitions common to all ColdFire processors
22 *
23 * Notes:
24 */
25
26#ifndef _CPU_MCF5XXX_H
27#define _CPU_MCF5XXX_H
28
29/***********************************************************************/
30/*
31 * The basic data types
32 *
33 * Those are low-level so we mark them so that they may alias anything
34 */
35
36typedef unsigned char uint8; /* 8 bits */
37typedef unsigned short int uint16 __attribute__((__may_alias__)); /* 16 bits */
38typedef unsigned long int uint32 __attribute__((__may_alias__)); /* 32 bits */
39
40typedef signed char int8; /* 8 bits */
41typedef signed short int int16 __attribute__((__may_alias__)); /* 16 bits */
42typedef signed long int int32 __attribute__((__may_alias__)); /* 32 bits */
43
44typedef volatile uint8 vuint8 __attribute__((__may_alias__)); /* 8 bits */
45typedef volatile uint16 vuint16 __attribute__((__may_alias__)); /* 16 bits */
46typedef volatile uint32 vuint32 __attribute__((__may_alias__)); /* 32 bits */
47
48/***********************************************************************/
49/*
50 * Common M68K & ColdFire definitions
51 */
52
53#define ADDRESS uint32
54#define INSTRUCTION uint16
55#define ILLEGAL 0x4AFC
56#define CPU_WORD_SIZE 16
57
58#define MCF5XXX_SR_T (0x8000)
59#define MCF5XXX_SR_S (0x2000)
60#define MCF5XXX_SR_M (0x1000)
61#define MCF5XXX_SR_IPL (0x0700)
62#define MCF5XXX_SR_IPL_0 (0x0000)
63#define MCF5XXX_SR_IPL_1 (0x0100)
64#define MCF5XXX_SR_IPL_2 (0x0200)
65#define MCF5XXX_SR_IPL_3 (0x0300)
66#define MCF5XXX_SR_IPL_4 (0x0400)
67#define MCF5XXX_SR_IPL_5 (0x0500)
68#define MCF5XXX_SR_IPL_6 (0x0600)
69#define MCF5XXX_SR_IPL_7 (0x0700)
70#define MCF5XXX_SR_X (0x0010)
71#define MCF5XXX_SR_N (0x0008)
72#define MCF5XXX_SR_Z (0x0004)
73#define MCF5XXX_SR_V (0x0002)
74#define MCF5XXX_SR_C (0x0001)
75
76/*
77 * Used to set the initialize the cacr register to the BSP's desired
78 * starting value.
79 */
80void mcf5xxx_initialize_cacr(uint32_t);
81
82#define MCF5XXX_CACR_CENB (0x80000000)
83#define MCF5XXX_CACR_CPDI (0x10000000)
84#define MCF5XXX_CACR_CPD (0x10000000)
85#define MCF5XXX_CACR_CFRZ (0x08000000)
86#define MCF5XXX_CACR_CINV (0x01000000)
87#define MCF5XXX_CACR_DIDI (0x00800000)
88#define MCF5XXX_CACR_DISD (0x00400000)
89#define MCF5XXX_CACR_INVI (0x00200000)
90#define MCF5XXX_CACR_INVD (0x00100000)
91#define MCF5XXX_CACR_CEIB (0x00000400)
92#define MCF5XXX_CACR_DCM_WR (0x00000000)
93#define MCF5XXX_CACR_DCM_CB (0x00000100)
94#define MCF5XXX_CACR_DCM_IP (0x00000200)
95#define MCF5XXX_CACR_DCM (0x00000200)
96#define MCF5XXX_CACR_DCM_II (0x00000300)
97#define MCF5XXX_CACR_DBWE (0x00000100)
98#define MCF5XXX_CACR_DWP (0x00000020)
99#define MCF5XXX_CACR_EUST (0x00000010)
100#define MCF5XXX_CACR_CLNF_00 (0x00000000)
101#define MCF5XXX_CACR_CLNF_01 (0x00000002)
102#define MCF5XXX_CACR_CLNF_10 (0x00000004)
103#define MCF5XXX_CACR_CLNF_11 (0x00000006)
104
105#define MCF5XXX_ACR_AB(a) ((a)&0xFF000000)
106#define MCF5XXX_ACR_AM(a) (((a)&0xFF000000) >> 8)
107#define MCF5XXX_ACR_EN (0x00008000)
108#define MCF5XXX_ACR_SM_USER (0x00000000)
109#define MCF5XXX_ACR_SM_SUPER (0x00002000)
110#define MCF5XXX_ACR_SM_IGNORE (0x00006000)
111#define MCF5XXX_ACR_ENIB (0x00000080)
112#define MCF5XXX_ACR_CM (0x00000040)
113#define MCF5XXX_ACR_DCM_WR (0x00000000)
114#define MCF5XXX_ACR_DCM_CB (0x00000020)
115#define MCF5XXX_ACR_DCM_IP (0x00000040)
116#define MCF5XXX_ACR_DCM_II (0x00000060)
117#define MCF5XXX_ACR_CM (0x00000040)
118#define MCF5XXX_ACR_BWE (0x00000020)
119#define MCF5XXX_ACR_WP (0x00000004)
120
121#define MCF5XXX_RAMBAR_BA(a) ((a)&0xFFFFC000)
122#define MCF5XXX_RAMBAR_PRI_00 (0x00000000)
123#define MCF5XXX_RAMBAR_PRI_01 (0x00004000)
124#define MCF5XXX_RAMBAR_PRI_10 (0x00008000)
125#define MCF5XXX_RAMBAR_PRI_11 (0x0000C000)
126#define MCF5XXX_RAMBAR_WP (0x00000100)
127#define MCF5XXX_RAMBAR_CI (0x00000020)
128#define MCF5XXX_RAMBAR_SC (0x00000010)
129#define MCF5XXX_RAMBAR_SD (0x00000008)
130#define MCF5XXX_RAMBAR_UC (0x00000004)
131#define MCF5XXX_RAMBAR_UD (0x00000002)
132#define MCF5XXX_RAMBAR_V (0x00000001)
133
134/***********************************************************************/
135/*
136 * The ColdFire family of processors has a simplified exception stack
137 * frame that looks like the following:
138 *
139 * 3322222222221111 111111
140 * 1098765432109876 5432109876543210
141 * 8 +----------------+----------------+
142 * | Program Counter |
143 * 4 +----------------+----------------+
144 * |FS/Fmt/Vector/FS| SR |
145 * SP --> 0 +----------------+----------------+
146 *
147 * The stack self-aligns to a 4-byte boundary at an exception, with
148 * the FS/Fmt/Vector/FS field indicating the size of the adjustment
149 * (SP += 0,1,2,3 bytes).
150 */
151
152#define MCF5XXX_RD_SF_FORMAT(PTR) \
153 ((*((uint16 *)(PTR)) >> 12) & 0x00FF)
154
155#define MCF5XXX_RD_SF_VECTOR(PTR) \
156 ((*((uint16 *)(PTR)) >> 2) & 0x00FF)
157
158#define MCF5XXX_RD_SF_FS(PTR) \
159 ( ((*((uint16 *)(PTR)) & 0x0C00) >> 8) | (*((uint16 *)(PTR)) & 0x0003) )
160
161#define MCF5XXX_SF_SR(PTR) *((uint16 *)(PTR)+1)
162#define MCF5XXX_SF_PC(PTR) *((uint32 *)(PTR)+1)
163
164/********************************************************************/
165/*
166 * Functions provided by mcf5xxx.s
167 */
168
169int asm_set_ipl (uint32);
170void mcf5xxx_wr_cacr (uint32);
171void mcf5xxx_wr_acr0 (uint32);
172void mcf5xxx_wr_acr1 (uint32);
173void mcf5xxx_wr_acr2 (uint32);
174void mcf5xxx_wr_acr3 (uint32);
175void mcf5xxx_wr_other_a7 (uint32);
176void mcf5xxx_wr_other_sp (uint32);
177void mcf5xxx_wr_vbr (uint32);
178void mcf5xxx_wr_macsr (uint32);
179void mcf5xxx_wr_mask (uint32);
180void mcf5xxx_wr_acc0 (uint32);
181void mcf5xxx_wr_accext01 (uint32);
182void mcf5xxx_wr_accext23 (uint32);
183void mcf5xxx_wr_acc1 (uint32);
184void mcf5xxx_wr_acc2 (uint32);
185void mcf5xxx_wr_acc3 (uint32);
186void mcf5xxx_wr_sr (uint32);
187void mcf5xxx_wr_rambar0 (uint32);
188void mcf5xxx_wr_rambar1 (uint32);
189void mcf5xxx_wr_mbar (uint32);
190void mcf5xxx_wr_mbar0 (uint32);
191void mcf5xxx_wr_mbar1 (uint32);
192
193/********************************************************************/
194
195#endif /* _CPU_MCF5XXX_H */
196
197
198/********************************************************************/
199/*
200 * Memory map definitions from linker command files
201 */
202extern uint8 __IPSBAR[];
203
204/*********************************************************************
205*
206* System Control Module (SCM)
207*
208*********************************************************************/
209
210/* Read/Write access macros for general use */
211#define MCF5282_SCM_IPSBAR (*(vuint32 *)(&__IPSBAR[0x0000]))
212#define MCF5282_SCM_RAMBAR (*(vuint32 *)(&__IPSBAR[0x0008]))
213#define MCF5282_SCM_CRSR (*(vuint8 *)(&__IPSBAR[0x0010]))
214#define MCF5282_SCM_CWCR (*(vuint8 *)(&__IPSBAR[0x0011]))
215#define MCF5282_SCM_LPICR (*(vuint8 *)(&__IPSBAR[0x0012]))
216#define MCF5282_SCM_CWSR (*(vuint8 *)(&__IPSBAR[0x0013]))
217#define MCF5282_SCM_DMAREQC (*(vuint32 *)(&__IPSBAR[0x0014]))
218#define MCF5282_SCM_MPARK (*(vuint32 *)(&__IPSBAR[0x001C]))
219#define MCF5282_SCM_MPR (*(vuint8 *)(&__IPSBAR[0x0020]))
220#define MCF5282_SCM_PACR0 (*(vuint8 *)(&__IPSBAR[0x0024]))
221#define MCF5282_SCM_PACR1 (*(vuint8 *)(&__IPSBAR[0x0025]))
222#define MCF5282_SCM_PACR2 (*(vuint8 *)(&__IPSBAR[0x0026]))
223#define MCF5282_SCM_PACR3 (*(vuint8 *)(&__IPSBAR[0x0027]))
224#define MCF5282_SCM_PACR4 (*(vuint8 *)(&__IPSBAR[0x0028]))
225#define MCF5282_SCM_PACR5 (*(vuint8 *)(&__IPSBAR[0x002A]))
226#define MCF5282_SCM_PACR6 (*(vuint8 *)(&__IPSBAR[0x002B]))
227#define MCF5282_SCM_PACR7 (*(vuint8 *)(&__IPSBAR[0x002C]))
228#define MCF5282_SCM_PACR8 (*(vuint8 *)(&__IPSBAR[0x002E]))
229#define MCF5282_SCM_GPACR0 (*(vuint8 *)(&__IPSBAR[0x0030]))
230#define MCF5282_SCM_GPACR1 (*(vuint8 *)(&__IPSBAR[0x0031]))
231
232/* Bit level definitions and macros */
233#define MCF5282_SCM_IPSBAR_BA(x) ((x)&0xC0000000)
234#define MCF5282_SCM_IPSBAR_V (0x00000001)
235
236#define MCF5282_SCM_RAMBAR_BA(x) ((x)&0xFFFF0000)
237#define MCF5282_SCM_RAMBAR_BDE (0x00000200)
238
239#define MCF5282_SCM_CRSR_EXT (0x80)
240#define MCF5282_SCM_CRSR_CWDR (0x20)
241
242#define MCF5282_SCM_CWCR_CWE (0x80)
243#define MCF5282_SCM_CWCR_CWRI (0x40)
244#define MCF5282_SCM_CWCR_CWT(x) (((x)&0x03)<<3)
245#define MCF5282_SCM_CWCR_CWTA (0x04)
246#define MCF5282_SCM_CWCR_CWTAVAL (0x02)
247#define MCF5282_SCM_CWCR_CWTIC (0x01)
248
249#define MCF5282_SCM_LPICR_ENBSTOP (0x80)
250#define MCF5282_SCM_LPICR_XSTOP_IPL(x) (((x)&0x07)<<4)
251
252#define MCF5282_SCM_CWSR_SEQ1 (0x55)
253#define MCF5282_SCM_CWSR_SEQ2 (0xAA)
254
255#define MCF5282_SCM_DMAREQC_DMAC3(x) (((x)&0x000F)<<12)
256#define MCF5282_SCM_DMAREQC_DMAC2(x) (((x)&0x000F)<<8)
257#define MCF5282_SCM_DMAREQC_DMAC1(x) (((x)&0x000F)<<4)
258#define MCF5282_SCM_DMAREQC_DMAC0(x) (((x)&0x000F))
259#define MCF5282_SCM_DMAREQC_DMATIMER0 (0x4)
260#define MCF5282_SCM_DMAREQC_DMATIMER1 (0x5)
261#define MCF5282_SCM_DMAREQC_DMATIMER2 (0x6)
262#define MCF5282_SCM_DMAREQC_DMATIMER3 (0x7)
263#define MCF5282_SCM_DMAREQC_UART0 (0x8)
264#define MCF5282_SCM_DMAREQC_UART1 (0x9)
265#define MCF5282_SCM_DMAREQC_UART2 (0xA)
266
267#define MCF5282_SCM_MPARK_M2_P_EN (0x02000000)
268#define MCF5282_SCM_MPARK_BCR24BIT (0x01000000)
269#define MCF5282_SCM_MPARK_M3_PRTY(x) (((x)&0x03)<<22)
270#define MCF5282_SCM_MPARK_M2_PRTY(x) (((x)&0x03)<<20)
271#define MCF5282_SCM_MPARK_M0_PRTY(x) (((x)&0x03)<<18)
272#define MCF5282_SCM_MPARK_M1_PRTY(x) (((x)&0x03)<<16)
273#define MCF5282_SCM_MPARK_FIXED (0x00040000)
274#define MCF5282_SCM_MPARK_TIMEOUT (0x00020000)
275#define MCF5282_SCM_MPARK_PRK_LAST (0x00010000)
276#define MCF5282_SCM_MPARK_LCKOUT_TIME(x) (((x)&0x000F)<<8)
277
278#define MCF5282_SCM_MPARK_MX_PRTY_FIRST (0x3)
279#define MCF5282_SCM_MPARK_MX_PRTY_SECOND (0x2)
280#define MCF5282_SCM_MPARK_MX_PRTY_THIRD (0x1)
281#define MCF5282_SCM_MPARK_MX_PRTY_FOURTH (0x0)
282
283#define MCF5282_SCM_MPR_MPR(x) (((x)&0x0F))
284
285#define MCF5282_SCM_PACR_LOCK1 (0x80)
286#define MCF5282_SCM_PACR_ACCESSCTRL1(x) (((x)&0x07)<<4)
287#define MCF5282_SCM_PACR_LOCK0 (0x08)
288#define MCF5282_SCM_PACR_ACCESSCTRL0(x) (((x)&0x07))
289#define MCF5282_SCM_PACR_RW_NA (0x0)
290#define MCF5282_SCM_PACR_R_NA (0x1)
291#define MCF5282_SCM_PACR_R_R (0x2)
292#define MCF5282_SCM_PACR_RW_RW (0x4)
293#define MCF5282_SCM_PACR_RW_R (0x5)
294#define MCF5282_SCM_PACR_NA_NA (0x7)
295
296#define MCF5282_SCM_GPACR_LOCK (0x80)
297#define MCF5282_SCM_GPACR_ACCESSCTRL(x) (((x)&0x0F))
298#define MCF5282_SCM_GPACR_ACCESSCTRL_RW_NA (0x0)
299#define MCF5282_SCM_GPACR_ACCESSCTRL_R_NA (0x1)
300#define MCF5282_SCM_GPACR_ACCESSCTRL_R_R (0x2)
301#define MCF5282_SCM_GPACR_ACCESSCTRL_RW_RW (0x4)
302#define MCF5282_SCM_GPACR_ACCESSCTRL_RW_R (0x5)
303#define MCF5282_SCM_GPACR_ACCESSCTRL_NA_NA (0x7)
304#define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_NA (0x8)
305#define MCF5282_SCM_GPACR_ACCESSCTRL_RE_NA (0x9)
306#define MCF5282_SCM_GPACR_ACCESSCTRL_RE_RE (0xA)
307#define MCF5282_SCM_GPACR_ACCESSCTRL_E_NA (0xB)
308#define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_RWE (0xC)
309#define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_RE (0xD)
310#define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_E (0xF)
311
312/*********************************************************************
313*
314* SDRAM Controller Module
315*
316*********************************************************************/
317
318/* Read/Write access macros for general use */
319#define MCF5282_SDRAMC_DCR (*(vuint16 *)(&__IPSBAR[0x0040]))
320#define MCF5282_SDRAMC_DACR0 (*(vuint32 *)(&__IPSBAR[0x0048]))
321#define MCF5282_SDRAMC_DMR0 (*(vuint32 *)(&__IPSBAR[0x004C]))
322#define MCF5282_SDRAMC_DACR1 (*(vuint32 *)(&__IPSBAR[0x0050]))
323#define MCF5282_SDRAMC_DMR1 (*(vuint32 *)(&__IPSBAR[0x0054]))
324
325/* Bit level definitions and macros */
326#define MCF5282_SDRAMC_DCR_NAM (0x2000)
327#define MCF5282_SDRAMC_DCR_COC (0x1000)
328#define MCF5282_SDRAMC_DCR_IS (0x0800)
329#define MCF5282_SDRAMC_DCR_RTIM_3 (0x0000)
330#define MCF5282_SDRAMC_DCR_RTIM_6 (0x0200)
331#define MCF5282_SDRAMC_DCR_RTIM_9 (0x0400)
332#define MCF5282_SDRAMC_DCR_RC(x) ((x)&0x01FF)
333
334#define MCF5282_SDRAMC_DACR_BASE(x) ((x)&0xFFFC0000)
335#define MCF5282_SDRAMC_DACR_RE (0x00008000)
336#define MCF5282_SDRAMC_DACR_CASL(x) (((x)&0x03)<<12)
337#define MCF5282_SDRAMC_DACR_CBM(x) (((x)&0x07)<<8)
338#define MCF5282_SDRAMC_DACR_PS_32 (0x00000000)
339#define MCF5282_SDRAMC_DACR_PS_8 (0x00000010)
340#define MCF5282_SDRAMC_DACR_PS_16 (0x00000020)
341#define MCF5282_SDRAMC_DACR_IMRS (0x00000040)
342#define MCF5282_SDRAMC_DACR_IP (0x00000008)
343
344#define MCF5282_SDRAMC_DMR_BAM_4G (0xFFFC0000)
345#define MCF5282_SDRAMC_DMR_BAM_2G (0x7FFC0000)
346#define MCF5282_SDRAMC_DMR_BAM_1G (0x3FFC0000)
347#define MCF5282_SDRAMC_DMR_BAM_1024M (0x3FFC0000)
348#define MCF5282_SDRAMC_DMR_BAM_512M (0x1FFC0000)
349#define MCF5282_SDRAMC_DMR_BAM_256M (0x0FFC0000)
350#define MCF5282_SDRAMC_DMR_BAM_128M (0x07FC0000)
351#define MCF5282_SDRAMC_DMR_BAM_64M (0x03FC0000)
352#define MCF5282_SDRAMC_DMR_BAM_32M (0x01FC0000)
353#define MCF5282_SDRAMC_DMR_BAM_16M (0x00FC0000)
354#define MCF5282_SDRAMC_DMR_BAM_8M (0x007C0000)
355#define MCF5282_SDRAMC_DMR_BAM_4M (0x003C0000)
356#define MCF5282_SDRAMC_DMR_BAM_2M (0x001C0000)
357#define MCF5282_SDRAMC_DMR_BAM_1M (0x000C0000)
358#define MCF5282_SDRAMC_DMR_BAM_1024K (0x000C0000)
359#define MCF5282_SDRAMC_DMR_BAM_512K (0x00040000)
360#define MCF5282_SDRAMC_DMR_BAM_256K (0x00000000)
361#define MCF5282_SDRAMC_DMR_WP (0x00000100)
362#define MCF5282_SDRAMC_DMR_CI (0x00000040)
363#define MCF5282_SDRAMC_DMR_AM (0x00000020)
364#define MCF5282_SDRAMC_DMR_SC (0x00000010)
365#define MCF5282_SDRAMC_DMR_SD (0x00000008)
366#define MCF5282_SDRAMC_DMR_UC (0x00000004)
367#define MCF5282_SDRAMC_DMR_UD (0x00000002)
368#define MCF5282_SDRAMC_DMR_V (0x00000001)
369
370/*********************************************************************
371*
372* Chip Select Module
373*
374*********************************************************************/
375
376/* Read/Write access macros for general use */
377#define MCF5282_CS0_CSAR (*(vuint16 *)(&__IPSBAR[0x0080]))
378#define MCF5282_CS0_CSMR (*(vuint32 *)(&__IPSBAR[0x0084]))
379#define MCF5282_CS0_CSCR (*(vuint16 *)(&__IPSBAR[0x008A]))
380
381#define MCF5282_CS1_CSAR (*(vuint16 *)(&__IPSBAR[0x008C]))
382#define MCF5282_CS1_CSMR (*(vuint32 *)(&__IPSBAR[0x0090]))
383#define MCF5282_CS1_CSCR (*(vuint16 *)(&__IPSBAR[0x0096]))
384
385#define MCF5282_CS2_CSAR (*(vuint16 *)(&__IPSBAR[0x0098]))
386#define MCF5282_CS2_CSMR (*(vuint32 *)(&__IPSBAR[0x009C]))
387#define MCF5282_CS2_CSCR (*(vuint16 *)(&__IPSBAR[0x00A2]))
388
389#define MCF5282_CS3_CSAR (*(vuint16 *)(&__IPSBAR[0x00A4]))
390#define MCF5282_CS3_CSMR (*(vuint32 *)(&__IPSBAR[0x00A8]))
391#define MCF5282_CS3_CSCR (*(vuint16 *)(&__IPSBAR[0x00AE]))
392
393#define MCF5282_CS4_CSAR (*(vuint16 *)(&__IPSBAR[0x00B0]))
394#define MCF5282_CS4_CSMR (*(vuint32 *)(&__IPSBAR[0x00B4]))
395#define MCF5282_CS4_CSCR (*(vuint16 *)(&__IPSBAR[0x00BA]))
396
397#define MCF5282_CS5_CSAR (*(vuint16 *)(&__IPSBAR[0x00BC]))
398#define MCF5282_CS5_CSMR (*(vuint32 *)(&__IPSBAR[0x00C0]))
399#define MCF5282_CS5_CSCR (*(vuint16 *)(&__IPSBAR[0x00C6]))
400
401#define MCF5282_CS6_CSAR (*(vuint16 *)(&__IPSBAR[0x00C8]))
402#define MCF5282_CS6_CSMR (*(vuint32 *)(&__IPSBAR[0x00CC]))
403#define MCF5282_CS6_CSCR (*(vuint16 *)(&__IPSBAR[0x00D2]))
404
405#define MCF5282_CS_CSAR(x) (*(vuint16 *)(&__IPSBAR[0x0080+((x)*0x0C)]))
406#define MCF5282_CS_CSMR(x) (*(vuint32 *)(&__IPSBAR[0x0084+((x)*0x0C)]))
407#define MCF5282_CS_CSCR(x) (*(vuint16 *)(&__IPSBAR[0x008A+((x)*0x0C)]))
408
409/* Bit level definitions and macros */
410#define MCF5282_CS_CSAR_BA(a) (uint16)(((a)&0xFFFF0000)>>16)
411
412#define MCF5282_CS_CSMR_BAM_4G (0xFFFF0000)
413#define MCF5282_CS_CSMR_BAM_2G (0x7FFF0000)
414#define MCF5282_CS_CSMR_BAM_1G (0x3FFF0000)
415#define MCF5282_CS_CSMR_BAM_1024M (0x3FFF0000)
416#define MCF5282_CS_CSMR_BAM_512M (0x1FFF0000)
417#define MCF5282_CS_CSMR_BAM_256M (0x0FFF0000)
418#define MCF5282_CS_CSMR_BAM_128M (0x07FF0000)
419#define MCF5282_CS_CSMR_BAM_64M (0x03FF0000)
420#define MCF5282_CS_CSMR_BAM_32M (0x01FF0000)
421#define MCF5282_CS_CSMR_BAM_16M (0x00FF0000)
422#define MCF5282_CS_CSMR_BAM_8M (0x007F0000)
423#define MCF5282_CS_CSMR_BAM_4M (0x003F0000)
424#define MCF5282_CS_CSMR_BAM_2M (0x001F0000)
425#define MCF5282_CS_CSMR_BAM_1M (0x000F0000)
426#define MCF5282_CS_CSMR_BAM_1024K (0x000F0000)
427#define MCF5282_CS_CSMR_BAM_512K (0x00070000)
428#define MCF5282_CS_CSMR_BAM_256K (0x00030000)
429#define MCF5282_CS_CSMR_BAM_128K (0x00010000)
430#define MCF5282_CS_CSMR_BAM_64K (0x00000000)
431#define MCF5282_CS_CSMR_WP (0x00000100)
432#define MCF5282_CS_CSMR_AM (0x00000040)
433#define MCF5282_CS_CSMR_CI (0x00000020)
434#define MCF5282_CS_CSMR_SC (0x00000010)
435#define MCF5282_CS_CSMR_SD (0x00000008)
436#define MCF5282_CS_CSMR_UC (0x00000004)
437#define MCF5282_CS_CSMR_UD (0x00000002)
438#define MCF5282_CS_CSMR_V (0x00000001)
439
440#define MCF5282_CS_CSCR_WS(x) (((x)&0x0F)<<10)
441#define MCF5282_CS_CSCR_AA (0x0100)
442#define MCF5282_CS_CSCR_PS_8 (0x0040)
443#define MCF5282_CS_CSCR_PS_16 (0x0080)
444#define MCF5282_CS_CSCR_PS_32 (0x0000)
445#define MCF5282_CS_CSCR_BEM (0x0020)
446#define MCF5282_CS_CSCR_BSTR (0x0010)
447#define MCF5282_CS_CSCR_BSTW (0x0008)
448
449/*********************************************************************
450*
451* Direct Memory Access (DMA) Module
452*
453*********************************************************************/
454
455/* Read/Write access macros for general use */
456#define MCF5282_DMA0_SAR (*(vuint32 *)(&__IPSBAR[0x0100]))
457#define MCF5282_DMA0_DAR (*(vuint32 *)(&__IPSBAR[0x0104]))
458#define MCF5282_DMA0_DCR (*(vuint32 *)(&__IPSBAR[0x0108]))
459#define MCF5282_DMA0_BCR (*(vuint32 *)(&__IPSBAR[0x010C]))
460#define MCF5282_DMA0_DSR (*(vuint8 *)(&__IPSBAR[0x0110]))
461
462#define MCF5282_DMA1_SAR (*(vuint32 *)(&__IPSBAR[0x0140]))
463#define MCF5282_DMA1_DAR (*(vuint32 *)(&__IPSBAR[0x0144]))
464#define MCF5282_DMA1_DCR (*(vuint32 *)(&__IPSBAR[0x0148]))
465#define MCF5282_DMA1_BCR (*(vuint32 *)(&__IPSBAR[0x014C]))
466#define MCF5282_DMA1_DSR (*(vuint8 *)(&__IPSBAR[0x0150]))
467
468#define MCF5282_DMA2_SAR (*(vuint32 *)(&__IPSBAR[0x0180]))
469#define MCF5282_DMA2_DAR (*(vuint32 *)(&__IPSBAR[0x0184]))
470#define MCF5282_DMA2_DCR (*(vuint32 *)(&__IPSBAR[0x0188]))
471#define MCF5282_DMA2_BCR (*(vuint32 *)(&__IPSBAR[0x018C]))
472#define MCF5282_DMA2_DSR (*(vuint8 *)(&__IPSBAR[0x0190]))
473
474#define MCF5282_DMA3_SAR (*(vuint32 *)(&__IPSBAR[0x01C0]))
475#define MCF5282_DMA3_DAR (*(vuint32 *)(&__IPSBAR[0x01C4]))
476#define MCF5282_DMA3_DCR (*(vuint32 *)(&__IPSBAR[0x01C8]))
477#define MCF5282_DMA3_BCR (*(vuint32 *)(&__IPSBAR[0x01CC]))
478#define MCF5282_DMA3_DSR (*(vuint8 *)(&__IPSBAR[0x01D0]))
479
480#define MCF5282_DMA_SAR(x) (*(vuint32 *)(&__IPSBAR[0x0100+((x)*0x40)]))
481#define MCF5282_DMA_DAR(x) (*(vuint32 *)(&__IPSBAR[0x0104+((x)*0x40)]))
482#define MCF5282_DMA_DCR(x) (*(vuint32 *)(&__IPSBAR[0x0108+((x)*0x40)]))
483#define MCF5282_DMA_BCR(x) (*(vuint32 *)(&__IPSBAR[0x010C+((x)*0x40)]))
484#define MCF5282_DMA_DSR(x) (*(vuint8 *)(&__IPSBAR[0x0110+((x)*0x40)]))
485
486/* Bit level definitions and macros */
487#define MCF5282_DMA_DCR_INT (0x80000000)
488#define MCF5282_DMA_DCR_EEXT (0x40000000)
489#define MCF5282_DMA_DCR_CS (0x20000000)
490#define MCF5282_DMA_DCR_AA (0x10000000)
491#define MCF5282_DMA_DCR_BWC_DMA (0x00000000)
492#define MCF5282_DMA_DCR_BWC_512 (0x02000000)
493#define MCF5282_DMA_DCR_BWC_1024 (0x04000000)
494#define MCF5282_DMA_DCR_BWC_2048 (0x06000000)
495#define MCF5282_DMA_DCR_BWC_4096 (0x08000000)
496#define MCF5282_DMA_DCR_BWC_8192 (0x0A000000)
497#define MCF5282_DMA_DCR_BWC_16384 (0x0C000000)
498#define MCF5282_DMA_DCR_BWC_32768 (0x0E000000)
499#define MCF5282_DMA_DCR_SINC (0x00400000)
500#define MCF5282_DMA_DCR_SSIZE_LONG (0x00000000)
501#define MCF5282_DMA_DCR_SSIZE_BYTE (0x00100000)
502#define MCF5282_DMA_DCR_SSIZE_WORD (0x00200000)
503#define MCF5282_DMA_DCR_SSIZE_LINE (0x00300000)
504#define MCF5282_DMA_DCR_DINC (0x00080000)
505#define MCF5282_DMA_DCR_DSIZE_LONG (0x00000000)
506#define MCF5282_DMA_DCR_DSIZE_BYTE (0x00020000)
507#define MCF5282_DMA_DCR_DSIZE_WORD (0x00040000)
508#define MCF5282_DMA_DCR_START (0x00010000)
509#define MCF5282_DMA_DCR_AT (0x00008000)
510
511#define MCF5282_DMA_DSR_CE (0x40)
512#define MCF5282_DMA_DSR_BES (0x20)
513#define MCF5282_DMA_DSR_BED (0x10)
514#define MCF5282_DMA_DSR_REQ (0x04)
515#define MCF5282_DMA_DSR_BSY (0x02)
516#define MCF5282_DMA_DSR_DONE (0x01)
517
518/*********************************************************************
519*
520* Universal Asychronous Receiver/Transmitter (UART) Module
521*
522*********************************************************************/
523
524/* Read/Write access macros for general use */
525#define MCF5282_UART0_UMR (*(vuint8 *)(&__IPSBAR[0x0200]))
526#define MCF5282_UART0_USR (*(vuint8 *)(&__IPSBAR[0x0204]))
527#define MCF5282_UART0_UCSR (*(vuint8 *)(&__IPSBAR[0x0204]))
528#define MCF5282_UART0_UCR (*(vuint8 *)(&__IPSBAR[0x0208]))
529#define MCF5282_UART0_URB (*(vuint8 *)(&__IPSBAR[0x020C]))
530#define MCF5282_UART0_UTB (*(vuint8 *)(&__IPSBAR[0x020C]))
531#define MCF5282_UART0_UIPCR (*(vuint8 *)(&__IPSBAR[0x0210]))
532#define MCF5282_UART0_UACR (*(vuint8 *)(&__IPSBAR[0x0210]))
533#define MCF5282_UART0_UISR (*(vuint8 *)(&__IPSBAR[0x0214]))
534#define MCF5282_UART0_UIMR (*(vuint8 *)(&__IPSBAR[0x0214]))
535#define MCF5282_UART0_UBG1 (*(vuint8 *)(&__IPSBAR[0x0218]))
536#define MCF5282_UART0_UBG2 (*(vuint8 *)(&__IPSBAR[0x021C]))
537#define MCF5282_UART0_UIP (*(vuint8 *)(&__IPSBAR[0x0234]))
538#define MCF5282_UART0_UOP1 (*(vuint8 *)(&__IPSBAR[0x0238]))
539#define MCF5282_UART0_UOP0 (*(vuint8 *)(&__IPSBAR[0x023C]))
540
541#define MCF5282_UART1_UMR (*(vuint8 *)(&__IPSBAR[0x0240]))
542#define MCF5282_UART1_USR (*(vuint8 *)(&__IPSBAR[0x0244]))
543#define MCF5282_UART1_UCSR (*(vuint8 *)(&__IPSBAR[0x0244]))
544#define MCF5282_UART1_UCR (*(vuint8 *)(&__IPSBAR[0x0248]))
545#define MCF5282_UART1_URB (*(vuint8 *)(&__IPSBAR[0x024C]))
546#define MCF5282_UART1_UTB (*(vuint8 *)(&__IPSBAR[0x024C]))
547#define MCF5282_UART1_UIPCR (*(vuint8 *)(&__IPSBAR[0x0250]))
548#define MCF5282_UART1_UACR (*(vuint8 *)(&__IPSBAR[0x0250]))
549#define MCF5282_UART1_UISR (*(vuint8 *)(&__IPSBAR[0x0254]))
550#define MCF5282_UART1_UIMR (*(vuint8 *)(&__IPSBAR[0x0254]))
551#define MCF5282_UART1_UBG1 (*(vuint8 *)(&__IPSBAR[0x0258]))
552#define MCF5282_UART1_UBG2 (*(vuint8 *)(&__IPSBAR[0x025C]))
553#define MCF5282_UART1_UIP (*(vuint8 *)(&__IPSBAR[0x0274]))
554#define MCF5282_UART1_UOP1 (*(vuint8 *)(&__IPSBAR[0x0278]))
555#define MCF5282_UART1_UOP0 (*(vuint8 *)(&__IPSBAR[0x027C]))
556
557#define MCF5282_UART2_UMR (*(vuint8 *)(&__IPSBAR[0x0280]))
558#define MCF5282_UART2_USR (*(vuint8 *)(&__IPSBAR[0x0284]))
559#define MCF5282_UART2_UCSR (*(vuint8 *)(&__IPSBAR[0x0284]))
560#define MCF5282_UART2_UCR (*(vuint8 *)(&__IPSBAR[0x0288]))
561#define MCF5282_UART2_URB (*(vuint8 *)(&__IPSBAR[0x028C]))
562#define MCF5282_UART2_UTB (*(vuint8 *)(&__IPSBAR[0x028C]))
563#define MCF5282_UART2_UIPCR (*(vuint8 *)(&__IPSBAR[0x0290]))
564#define MCF5282_UART2_UACR (*(vuint8 *)(&__IPSBAR[0x0290]))
565#define MCF5282_UART2_UISR (*(vuint8 *)(&__IPSBAR[0x0294]))
566#define MCF5282_UART2_UIMR (*(vuint8 *)(&__IPSBAR[0x0294]))
567#define MCF5282_UART2_UBG1 (*(vuint8 *)(&__IPSBAR[0x0298]))
568#define MCF5282_UART2_UBG2 (*(vuint8 *)(&__IPSBAR[0x029C]))
569#define MCF5282_UART2_UIP (*(vuint8 *)(&__IPSBAR[0x02B4]))
570#define MCF5282_UART2_UOP1 (*(vuint8 *)(&__IPSBAR[0x02B8]))
571#define MCF5282_UART2_UOP0 (*(vuint8 *)(&__IPSBAR[0x02BC]))
572
573#define MCF5282_UART_UMR(x) (*(vuint8 *)(&__IPSBAR[0x0200+((x)*0x40)]))
574#define MCF5282_UART_USR(x) (*(vuint8 *)(&__IPSBAR[0x0204+((x)*0x40)]))
575#define MCF5282_UART_UCSR(x) (*(vuint8 *)(&__IPSBAR[0x0204+((x)*0x40)]))
576#define MCF5282_UART_UCR(x) (*(vuint8 *)(&__IPSBAR[0x0208+((x)*0x40)]))
577#define MCF5282_UART_URB(x) (*(vuint8 *)(&__IPSBAR[0x020C+((x)*0x40)]))
578#define MCF5282_UART_UTB(x) (*(vuint8 *)(&__IPSBAR[0x020C+((x)*0x40)]))
579#define MCF5282_UART_UIPCR(x) (*(vuint8 *)(&__IPSBAR[0x0210+((x)*0x40)]))
580#define MCF5282_UART_UACR(x) (*(vuint8 *)(&__IPSBAR[0x0210+((x)*0x40)]))
581#define MCF5282_UART_UISR(x) (*(vuint8 *)(&__IPSBAR[0x0214+((x)*0x40)]))
582#define MCF5282_UART_UIMR(x) (*(vuint8 *)(&__IPSBAR[0x0214+((x)*0x40)]))
583#define MCF5282_UART_UBG1(x) (*(vuint8 *)(&__IPSBAR[0x0218+((x)*0x40)]))
584#define MCF5282_UART_UBG2(x) (*(vuint8 *)(&__IPSBAR[0x021C+((x)*0x40)]))
585#define MCF5282_UART_UIP(x) (*(vuint8 *)(&__IPSBAR[0x0234+((x)*0x40)]))
586#define MCF5282_UART_UOP1(x) (*(vuint8 *)(&__IPSBAR[0x0238+((x)*0x40)]))
587#define MCF5282_UART_UOP0(x) (*(vuint8 *)(&__IPSBAR[0x023C+((x)*0x40)]))
588
589/* Bit level definitions and macros */
590#define MCF5282_UART_UMR1_RXRTS (0x80)
591#define MCF5282_UART_UMR1_RXIRQ (0x40)
592#define MCF5282_UART_UMR1_ERR (0x20)
593#define MCF5282_UART_UMR1_PM_MULTI_ADDR (0x1C)
594#define MCF5282_UART_UMR1_PM_MULTI_DATA (0x18)
595#define MCF5282_UART_UMR1_PM_NONE (0x10)
596#define MCF5282_UART_UMR1_PM_FORCE_HI (0x0C)
597#define MCF5282_UART_UMR1_PM_FORCE_LO (0x08)
598#define MCF5282_UART_UMR1_PM_ODD (0x04)
599#define MCF5282_UART_UMR1_PM_EVEN (0x00)
600#define MCF5282_UART_UMR1_BC_5 (0x00)
601#define MCF5282_UART_UMR1_BC_6 (0x01)
602#define MCF5282_UART_UMR1_BC_7 (0x02)
603#define MCF5282_UART_UMR1_BC_8 (0x03)
604
605#define MCF5282_UART_UMR2_CM_NORMAL (0x00)
606#define MCF5282_UART_UMR2_CM_ECHO (0x40)
607#define MCF5282_UART_UMR2_CM_LOCAL_LOOP (0x80)
608#define MCF5282_UART_UMR2_CM_REMOTE_LOOP (0xC0)
609#define MCF5282_UART_UMR2_TXRTS (0x20)
610#define MCF5282_UART_UMR2_TXCTS (0x10)
611#define MCF5282_UART_UMR2_STOP_BITS_1 (0x07)
612#define MCF5282_UART_UMR2_STOP_BITS_15 (0x08)
613#define MCF5282_UART_UMR2_STOP_BITS_2 (0x0F)
614#define MCF5282_UART_UMR2_STOP_BITS(a) ((a)&0x0f)
615
616#define MCF5282_UART_USR_RB (0x80)
617#define MCF5282_UART_USR_FE (0x40)
618#define MCF5282_UART_USR_PE (0x20)
619#define MCF5282_UART_USR_OE (0x10)
620#define MCF5282_UART_USR_TXEMP (0x08)
621#define MCF5282_UART_USR_TXRDY (0x04)
622#define MCF5282_UART_USR_FFULL (0x02)
623#define MCF5282_UART_USR_RXRDY (0x01)
624
625#define MCF5282_UART_UCSR_RCS_SYS_CLK (0xD0)
626#define MCF5282_UART_UCSR_RCS_DTIN16 (0xE0)
627#define MCF5282_UART_UCSR_RCS_DTIN (0xF0)
628#define MCF5282_UART_UCSR_TCS_SYS_CLK (0x0D)
629#define MCF5282_UART_UCSR_TCS_DTIN16 (0x0E)
630#define MCF5282_UART_UCSR_TCS_DTIN (0x0F)
631
632#define MCF5282_UART_UCR_NONE (0x00)
633#define MCF5282_UART_UCR_STOP_BREAK (0x70)
634#define MCF5282_UART_UCR_START_BREAK (0x60)
635#define MCF5282_UART_UCR_RESET_BKCHGINT (0x50)
636#define MCF5282_UART_UCR_RESET_ERROR (0x40)
637#define MCF5282_UART_UCR_RESET_TX (0x30)
638#define MCF5282_UART_UCR_RESET_RX (0x20)
639#define MCF5282_UART_UCR_RESET_MR (0x10)
640#define MCF5282_UART_UCR_TX_DISABLED (0x08)
641#define MCF5282_UART_UCR_TX_ENABLED (0x04)
642#define MCF5282_UART_UCR_RX_DISABLED (0x02)
643#define MCF5282_UART_UCR_RX_ENABLED (0x01)
644
645#define MCF5282_UART_UIPCR_COS (0x10)
646#define MCF5282_UART_UIPCR_CTS (0x01)
647
648#define MCF5282_UART_UACR_IEC (0x01)
649
650#define MCF5282_UART_UISR_COS (0x80)
651#define MCF5282_UART_UISR_ABC (0x40)
652#define MCF5282_UART_UISR_RXFIFO (0x20)
653#define MCF5282_UART_UISR_TXFIFO (0x10)
654#define MCF5282_UART_UISR_RXFTO (0x08)
655#define MCF5282_UART_UISR_DB (0x04)
656#define MCF5282_UART_UISR_RXRDY (0x02)
657#define MCF5282_UART_UISR_TXRDY (0x01)
658
659#define MCF5282_UART_UIMR_COS (0x80)
660#define MCF5282_UART_UIMR_DB (0x04)
661#define MCF5282_UART_UIMR_FFULL (0x02)
662#define MCF5282_UART_UIMR_TXRDY (0x01)
663
664#define MCF5282_UART_UIP_CTS (0x01)
665
666#define MCF5282_UART_UOP_RTS (0x01)
667
668/*********************************************************************
669*
670* Inter-IC (I2C) Module
671*
672*********************************************************************/
673
674/* Read/Write access macros for general use */
675#define MCF5282_I2C_I2ADR (*(vuint8 *)(&__IPSBAR[0x0300]))
676#define MCF5282_I2C_I2FDR (*(vuint8 *)(&__IPSBAR[0x0304]))
677#define MCF5282_I2C_I2CR (*(vuint8 *)(&__IPSBAR[0x0308]))
678#define MCF5282_I2C_I2SR (*(vuint8 *)(&__IPSBAR[0x030C]))
679#define MCF5282_I2C_I2DR (*(vuint8 *)(&__IPSBAR[0x0310]))
680
681/* Bit level definitions and macros */
682#define MCF5282_I2C_I2ADR_ADDR(x) (((x)&0x7F)<<0x01)
683
684#define MCF5282_I2C_I2FDR_IC(x) (((x)&0x3F))
685
686#define MCF5282_I2C_I2CR_IEN (0x80)
687#define MCF5282_I2C_I2CR_IIEN (0x40)
688#define MCF5282_I2C_I2CR_MSTA (0x20)
689#define MCF5282_I2C_I2CR_MTX (0x10)
690#define MCF5282_I2C_I2CR_TXAK (0x08)
691#define MCF5282_I2C_I2CR_RSTA (0x04)
692
693#define MCF5282_I2C_I2SR_ICF (0x80)
694#define MCF5282_I2C_I2SR_IAAS (0x40)
695#define MCF5282_I2C_I2SR_IBB (0x20)
696#define MCF5282_I2C_I2SR_IAL (0x10)
697#define MCF5282_I2C_I2SR_SRW (0x04)
698#define MCF5282_I2C_I2SR_IIF (0x02)
699#define MCF5282_I2C_I2SR_RXAK (0x01)
700
701/*********************************************************************
702*
703* Queued Serial Peripheral Interface (QSPI) Module
704*
705*********************************************************************/
706
707/* Read/Write access macros for general use */
708#define MCF5282_QSPI_QMR (*(vuint16 *)(&__IPSBAR[0x0340]))
709#define MCF5282_QSPI_QDLYR (*(vuint16 *)(&__IPSBAR[0x0344]))
710#define MCF5282_QSPI_QWR (*(vuint16 *)(&__IPSBAR[0x0348]))
711#define MCF5282_QSPI_QIR (*(vuint16 *)(&__IPSBAR[0x034C]))
712#define MCF5282_QSPI_QAR (*(vuint16 *)(&__IPSBAR[0x0350]))
713#define MCF5282_QSPI_QDR (*(vuint16 *)(&__IPSBAR[0x0354]))
714#define MCF5282_QSPI_QCR (*(vuint16 *)(&__IPSBAR[0x0354]))
715
716/* Bit level definitions and macros */
717#define MCF5282_QSPI_QMR_MSTR (0x8000)
718#define MCF5282_QSPI_QMR_DOHIE (0x4000)
719#define MCF5282_QSPI_QMR_BITS_16 (0x0000)
720#define MCF5282_QSPI_QMR_BITS_8 (0x2000)
721#define MCF5282_QSPI_QMR_BITS_9 (0x2400)
722#define MCF5282_QSPI_QMR_BITS_10 (0x2800)
723#define MCF5282_QSPI_QMR_BITS_11 (0x2C00)
724#define MCF5282_QSPI_QMR_BITS_12 (0x3000)
725#define MCF5282_QSPI_QMR_BITS_13 (0x3400)
726#define MCF5282_QSPI_QMR_BITS_14 (0x3800)
727#define MCF5282_QSPI_QMR_BITS_15 (0x3C00)
728#define MCF5282_QSPI_QMR_CPOL (0x0200)
729#define MCF5282_QSPI_QMR_CPHA (0x0100)
730#define MCF5282_QSPI_QMR_BAUD(x) (((x)&0x00FF))
731
732#define MCF5282_QSPI_QDLYR_SPE (0x8000)
733#define MCF5282_QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8)
734#define MCF5282_QSPI_QDLYR_DTL(x) (((x)&0x00FF))
735
736#define MCF5282_QSPI_QWR_HALT (0x8000)
737#define MCF5282_QSPI_QWR_WREN (0x4000)
738#define MCF5282_QSPI_QWR_WRTO (0x2000)
739#define MCF5282_QSPI_QWR_CSIV (0x1000)
740#define MCF5282_QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8)
741#define MCF5282_QSPI_QWR_CPTQP(x) (((x)&0x000F)<<4)
742#define MCF5282_QSPI_QWR_NEWQP(x) (((x)&0x000F))
743
744#define MCF5282_QSPI_QIR_WCEFB (0x8000)
745#define MCF5282_QSPI_QIR_ABRTB (0x4000)
746#define MCF5282_QSPI_QIR_ABRTL (0x1000)
747#define MCF5282_QSPI_QIR_WCEFE (0x0800)
748#define MCF5282_QSPI_QIR_ABRTE (0x0400)
749#define MCF5282_QSPI_QIR_SPIFE (0x0100)
750#define MCF5282_QSPI_QIR_WCEF (0x0008)
751#define MCF5282_QSPI_QIR_ABRT (0x0004)
752#define MCF5282_QSPI_QIR_SPIF (0x0001)
753
754#define MCF5282_QSPI_QAR_ADDR(x) (((x)&0x003F))
755
756#define MCF5282_QSPI_QDR_COMMAND(x) (((x)&0xFF00))
757
758#define MCF5282_QSPI_QCR_DATA(x) (((x)&0x00FF)<<8)
759#define MCF5282_QSPI_QCR_CONT (0x8000)
760#define MCF5282_QSPI_QCR_BITSE (0x4000)
761#define MCF5282_QSPI_QCR_DT (0x2000)
762#define MCF5282_QSPI_QCR_DSCK (0x1000)
763#define MCF5282_QSPI_QCR_CS(x) (((x)&0x000F)<<8)
764
765/*********************************************************************
766*
767* DMA Timer Module
768*
769*********************************************************************/
770
771/* Read/Write access macros for general use */
772#define MCF5282_TIMER0_DTMR (*(vuint16 *)(&__IPSBAR[0x0400]))
773#define MCF5282_TIMER0_DTXMR (*(vuint8 *)(&__IPSBAR[0x0402]))
774#define MCF5282_TIMER0_DTER (*(vuint8 *)(&__IPSBAR[0x0403]))
775#define MCF5282_TIMER0_DTRR (*(vuint32 *)(&__IPSBAR[0x0404]))
776#define MCF5282_TIMER0_DTCR (*(vuint32 *)(&__IPSBAR[0x0408]))
777#define MCF5282_TIMER0_DTCN (*(vuint32 *)(&__IPSBAR[0x040C]))
778
779#define MCF5282_TIMER1_DTMR (*(vuint16 *)(&__IPSBAR[0x0440]))
780#define MCF5282_TIMER1_DTXMR (*(vuint8 *)(&__IPSBAR[0x0442]))
781#define MCF5282_TIMER1_DTER (*(vuint8 *)(&__IPSBAR[0x0443]))
782#define MCF5282_TIMER1_DTRR (*(vuint32 *)(&__IPSBAR[0x0444]))
783#define MCF5282_TIMER1_DTCR (*(vuint32 *)(&__IPSBAR[0x0448]))
784#define MCF5282_TIMER1_DTCN (*(vuint32 *)(&__IPSBAR[0x044C]))
785
786#define MCF5282_TIMER2_DTMR (*(vuint16 *)(&__IPSBAR[0x0480]))
787#define MCF5282_TIMER2_DTXMR (*(vuint8 *)(&__IPSBAR[0x0482]))
788#define MCF5282_TIMER2_DTER (*(vuint8 *)(&__IPSBAR[0x0483]))
789#define MCF5282_TIMER2_DTRR (*(vuint32 *)(&__IPSBAR[0x0484]))
790#define MCF5282_TIMER2_DTCR (*(vuint32 *)(&__IPSBAR[0x0488]))
791#define MCF5282_TIMER2_DTCN (*(vuint32 *)(&__IPSBAR[0x048C]))
792
793#define MCF5282_TIMER3_DTMR (*(vuint16 *)(&__IPSBAR[0x04C0]))
794#define MCF5282_TIMER3_DTXMR (*(vuint8 *)(&__IPSBAR[0x04C2]))
795#define MCF5282_TIMER3_DTER (*(vuint8 *)(&__IPSBAR[0x04C3]))
796#define MCF5282_TIMER3_DTRR (*(vuint32 *)(&__IPSBAR[0x04C4]))
797#define MCF5282_TIMER3_DTCR (*(vuint32 *)(&__IPSBAR[0x04C8]))
798#define MCF5282_TIMER3_DTCN (*(vuint32 *)(&__IPSBAR[0x04CC]))
799
800#define MCF5282_TIMER_DTMR(x) (*(vuint16 *)(&__IPSBAR[0x0400+((x)*0x40)]))
801#define MCF5282_TIMER_DTXMR(x) (*(vuint8 *)(&__IPSBAR[0x0402+((x)*0x40)]))
802#define MCF5282_TIMER_DTER(x) (*(vuint8 *)(&__IPSBAR[0x0403+((x)*0x40)]))
803#define MCF5282_TIMER_DTRR(x) (*(vuint32 *)(&__IPSBAR[0x0404+((x)*0x40)]))
804#define MCF5282_TIMER_DTCR(x) (*(vuint32 *)(&__IPSBAR[0x0408+((x)*0x40)]))
805#define MCF5282_TIMER_DTCN(x) (*(vuint32 *)(&__IPSBAR[0x040C+((x)*0x40)]))
806
807/* Bit level definitions and macros */
808#define MCF5282_TIMER_DTMR_PS(a) (((a)&0x00FF)<<8)
809#define MCF5282_TIMER_DTMR_CE_ANY (0x00C0)
810#define MCF5282_TIMER_DTMR_CE_FALL (0x0080)
811#define MCF5282_TIMER_DTMR_CE_RISE (0x0040)
812#define MCF5282_TIMER_DTMR_CE_NONE (0x0000)
813#define MCF5282_TIMER_DTMR_OM (0x0020)
814#define MCF5282_TIMER_DTMR_ORRI (0x0010)
815#define MCF5282_TIMER_DTMR_FRR (0x0008)
816#define MCF5282_TIMER_DTMR_CLK_DTIN (0x0006)
817#define MCF5282_TIMER_DTMR_CLK_DIV16 (0x0004)
818#define MCF5282_TIMER_DTMR_CLK_DIV1 (0x0002)
819#define MCF5282_TIMER_DTMR_CLK_STOP (0x0000)
820#define MCF5282_TIMER_DTMR_RST (0x0001)
821
822#define MCF5282_TIMER_DTXMR_DMAEN (0x80)
823#define MCF5282_TIMER_DTXMR_MODE16 (0x01)
824
825#define MCF5282_TIMER_DTER_REF (0x02)
826#define MCF5282_TIMER_DTER_CAP (0x01)
827
828/*********************************************************************
829*
830* Interrupt Controller (INTC) Module
831*
832*********************************************************************/
833
834/* Read/Write access macros for general use */
835#define MCF5282_INTC0_IPRH (*(vuint32 *)(&__IPSBAR[0x0C00]))
836#define MCF5282_INTC0_IPRL (*(vuint32 *)(&__IPSBAR[0x0C04]))
837#define MCF5282_INTC0_IMRH (*(vuint32 *)(&__IPSBAR[0x0C08]))
838#define MCF5282_INTC0_IMRL (*(vuint32 *)(&__IPSBAR[0x0C0C]))
839#define MCF5282_INTC0_INTFRCH (*(vuint32 *)(&__IPSBAR[0x0C10]))
840#define MCF5282_INTC0_INTFRCL (*(vuint32 *)(&__IPSBAR[0x0C14]))
841#define MCF5282_INTC0_IRLR (*(vuint8 *)(&__IPSBAR[0x0C18]))
842#define MCF5282_INTC0_IACKLPR (*(vuint8 *)(&__IPSBAR[0x0C19]))
843#define MCF5282_INTC0_ICR1 (*(vuint8 *)(&__IPSBAR[0x0C41]))
844#define MCF5282_INTC0_ICR2 (*(vuint8 *)(&__IPSBAR[0x0C42]))
845#define MCF5282_INTC0_ICR3 (*(vuint8 *)(&__IPSBAR[0x0C43]))
846#define MCF5282_INTC0_ICR4 (*(vuint8 *)(&__IPSBAR[0x0C44]))
847#define MCF5282_INTC0_ICR5 (*(vuint8 *)(&__IPSBAR[0x0C45]))
848#define MCF5282_INTC0_ICR6 (*(vuint8 *)(&__IPSBAR[0x0C46]))
849#define MCF5282_INTC0_ICR7 (*(vuint8 *)(&__IPSBAR[0x0C47]))
850#define MCF5282_INTC0_ICR8 (*(vuint8 *)(&__IPSBAR[0x0C48]))
851#define MCF5282_INTC0_ICR9 (*(vuint8 *)(&__IPSBAR[0x0C49]))
852#define MCF5282_INTC0_ICR10 (*(vuint8 *)(&__IPSBAR[0x0C4A]))
853#define MCF5282_INTC0_ICR11 (*(vuint8 *)(&__IPSBAR[0x0C4B]))
854#define MCF5282_INTC0_ICR12 (*(vuint8 *)(&__IPSBAR[0x0C4C]))
855#define MCF5282_INTC0_ICR13 (*(vuint8 *)(&__IPSBAR[0x0C4D]))
856#define MCF5282_INTC0_ICR14 (*(vuint8 *)(&__IPSBAR[0x0C4E]))
857#define MCF5282_INTC0_ICR15 (*(vuint8 *)(&__IPSBAR[0x0C4F]))
858#define MCF5282_INTC0_ICR17 (*(vuint8 *)(&__IPSBAR[0x0C51]))
859#define MCF5282_INTC0_ICR18 (*(vuint8 *)(&__IPSBAR[0x0C52]))
860#define MCF5282_INTC0_ICR19 (*(vuint8 *)(&__IPSBAR[0x0C53]))
861#define MCF5282_INTC0_ICR20 (*(vuint8 *)(&__IPSBAR[0x0C54]))
862#define MCF5282_INTC0_ICR21 (*(vuint8 *)(&__IPSBAR[0x0C55]))
863#define MCF5282_INTC0_ICR22 (*(vuint8 *)(&__IPSBAR[0x0C56]))
864#define MCF5282_INTC0_ICR23 (*(vuint8 *)(&__IPSBAR[0x0C57]))
865#define MCF5282_INTC0_ICR24 (*(vuint8 *)(&__IPSBAR[0x0C58]))
866#define MCF5282_INTC0_ICR25 (*(vuint8 *)(&__IPSBAR[0x0C59]))
867#define MCF5282_INTC0_ICR26 (*(vuint8 *)(&__IPSBAR[0x0C5A]))
868#define MCF5282_INTC0_ICR27 (*(vuint8 *)(&__IPSBAR[0x0C5B]))
869#define MCF5282_INTC0_ICR28 (*(vuint8 *)(&__IPSBAR[0x0C5C]))
870#define MCF5282_INTC0_ICR29 (*(vuint8 *)(&__IPSBAR[0x0C5D]))
871#define MCF5282_INTC0_ICR30 (*(vuint8 *)(&__IPSBAR[0x0C5E]))
872#define MCF5282_INTC0_ICR31 (*(vuint8 *)(&__IPSBAR[0x0C5F]))
873#define MCF5282_INTC0_ICR32 (*(vuint8 *)(&__IPSBAR[0x0C60]))
874#define MCF5282_INTC0_ICR33 (*(vuint8 *)(&__IPSBAR[0x0C61]))
875#define MCF5282_INTC0_ICR34 (*(vuint8 *)(&__IPSBAR[0x0C62]))
876#define MCF5282_INTC0_ICR35 (*(vuint8 *)(&__IPSBAR[0x0C63]))
877#define MCF5282_INTC0_ICR36 (*(vuint8 *)(&__IPSBAR[0x0C64]))
878#define MCF5282_INTC0_ICR37 (*(vuint8 *)(&__IPSBAR[0x0C65]))
879#define MCF5282_INTC0_ICR38 (*(vuint8 *)(&__IPSBAR[0x0C66]))
880#define MCF5282_INTC0_ICR39 (*(vuint8 *)(&__IPSBAR[0x0C67]))
881#define MCF5282_INTC0_ICR40 (*(vuint8 *)(&__IPSBAR[0x0C68]))
882#define MCF5282_INTC0_ICR41 (*(vuint8 *)(&__IPSBAR[0x0C69]))
883#define MCF5282_INTC0_ICR42 (*(vuint8 *)(&__IPSBAR[0x0C6A]))
884#define MCF5282_INTC0_ICR43 (*(vuint8 *)(&__IPSBAR[0x0C6B]))
885#define MCF5282_INTC0_ICR44 (*(vuint8 *)(&__IPSBAR[0x0C6C]))
886#define MCF5282_INTC0_ICR45 (*(vuint8 *)(&__IPSBAR[0x0C6D]))
887#define MCF5282_INTC0_ICR46 (*(vuint8 *)(&__IPSBAR[0x0C6E]))
888#define MCF5282_INTC0_ICR47 (*(vuint8 *)(&__IPSBAR[0x0C6F]))
889#define MCF5282_INTC0_ICR48 (*(vuint8 *)(&__IPSBAR[0x0C70]))
890#define MCF5282_INTC0_ICR49 (*(vuint8 *)(&__IPSBAR[0x0C71]))
891#define MCF5282_INTC0_ICR50 (*(vuint8 *)(&__IPSBAR[0x0C72]))
892#define MCF5282_INTC0_ICR51 (*(vuint8 *)(&__IPSBAR[0x0C73]))
893#define MCF5282_INTC0_ICR52 (*(vuint8 *)(&__IPSBAR[0x0C74]))
894#define MCF5282_INTC0_ICR53 (*(vuint8 *)(&__IPSBAR[0x0C75]))
895#define MCF5282_INTC0_ICR54 (*(vuint8 *)(&__IPSBAR[0x0C76]))
896#define MCF5282_INTC0_ICR55 (*(vuint8 *)(&__IPSBAR[0x0C77]))
897#define MCF5282_INTC0_ICR56 (*(vuint8 *)(&__IPSBAR[0x0C78]))
898#define MCF5282_INTC0_ICR57 (*(vuint8 *)(&__IPSBAR[0x0C79]))
899#define MCF5282_INTC0_ICR58 (*(vuint8 *)(&__IPSBAR[0x0C7A]))
900#define MCF5282_INTC0_ICR59 (*(vuint8 *)(&__IPSBAR[0x0C7B]))
901#define MCF5282_INTC0_ICR60 (*(vuint8 *)(&__IPSBAR[0x0C7C]))
902#define MCF5282_INTC0_ICR61 (*(vuint8 *)(&__IPSBAR[0x0C7D]))
903#define MCF5282_INTC0_ICR62 (*(vuint8 *)(&__IPSBAR[0x0C7E]))
904#define MCF5282_INTC0_SWIACK (*(vuint8 *)(&__IPSBAR[0x0CE0]))
905#define MCF5282_INTC0_L1IACK (*(vuint8 *)(&__IPSBAR[0x0CE4]))
906#define MCF5282_INTC0_L2IACK (*(vuint8 *)(&__IPSBAR[0x0CE8]))
907#define MCF5282_INTC0_L3IACK (*(vuint8 *)(&__IPSBAR[0x0CEC]))
908#define MCF5282_INTC0_L4IACK (*(vuint8 *)(&__IPSBAR[0x0CF0]))
909#define MCF5282_INTC0_L5IACK (*(vuint8 *)(&__IPSBAR[0x0CF4]))
910#define MCF5282_INTC0_L6IACK (*(vuint8 *)(&__IPSBAR[0x0CF8]))
911#define MCF5282_INTC0_L7IACK (*(vuint8 *)(&__IPSBAR[0x0CFC]))
912
913#define MCF5282_INTC1_IPRH (*(vuint32 *)(&__IPSBAR[0x0D00]))
914#define MCF5282_INTC1_IPRL (*(vuint32 *)(&__IPSBAR[0x0D04]))
915#define MCF5282_INTC1_IMRH (*(vuint32 *)(&__IPSBAR[0x0D08]))
916#define MCF5282_INTC1_IMRL (*(vuint32 *)(&__IPSBAR[0x0D0C]))
917#define MCF5282_INTC1_INTFRCH (*(vuint32 *)(&__IPSBAR[0x0D10]))
918#define MCF5282_INTC1_INTFRCL (*(vuint32 *)(&__IPSBAR[0x0D14]))
919#define MCF5282_INTC1_IRLR (*(vuint8 *)(&__IPSBAR[0x0D18]))
920#define MCF5282_INTC1_IACKLPR (*(vuint8 *)(&__IPSBAR[0x0D19]))
921#define MCF5282_INTC1_ICR08 (*(vuint8 *)(&__IPSBAR[0x0D48]))
922#define MCF5282_INTC1_ICR09 (*(vuint8 *)(&__IPSBAR[0x0D49]))
923#define MCF5282_INTC1_ICR10 (*(vuint8 *)(&__IPSBAR[0x0D4A]))
924#define MCF5282_INTC1_ICR11 (*(vuint8 *)(&__IPSBAR[0x0D4B]))
925#define MCF5282_INTC1_ICR12 (*(vuint8 *)(&__IPSBAR[0x0D4C]))
926#define MCF5282_INTC1_ICR13 (*(vuint8 *)(&__IPSBAR[0x0D4D]))
927#define MCF5282_INTC1_ICR14 (*(vuint8 *)(&__IPSBAR[0x0D4E]))
928#define MCF5282_INTC1_ICR15 (*(vuint8 *)(&__IPSBAR[0x0D4F]))
929#define MCF5282_INTC1_ICR16 (*(vuint8 *)(&__IPSBAR[0x0D50]))
930#define MCF5282_INTC1_ICR17 (*(vuint8 *)(&__IPSBAR[0x0D51]))
931#define MCF5282_INTC1_ICR18 (*(vuint8 *)(&__IPSBAR[0x0D52]))
932#define MCF5282_INTC1_ICR19 (*(vuint8 *)(&__IPSBAR[0x0D53]))
933#define MCF5282_INTC1_ICR20 (*(vuint8 *)(&__IPSBAR[0x0D54]))
934#define MCF5282_INTC1_ICR21 (*(vuint8 *)(&__IPSBAR[0x0D55]))
935#define MCF5282_INTC1_ICR22 (*(vuint8 *)(&__IPSBAR[0x0D56]))
936#define MCF5282_INTC1_ICR23 (*(vuint8 *)(&__IPSBAR[0x0D57]))
937#define MCF5282_INTC1_ICR24 (*(vuint8 *)(&__IPSBAR[0x0D58]))
938#define MCF5282_INTC1_ICR25 (*(vuint8 *)(&__IPSBAR[0x0D59]))
939#define MCF5282_INTC1_ICR26 (*(vuint8 *)(&__IPSBAR[0x0D5A]))
940#define MCF5282_INTC1_SWIACK (*(vuint8 *)(&__IPSBAR[0x0DE0]))
941#define MCF5282_INTC1_L1IACK (*(vuint8 *)(&__IPSBAR[0x0DE4]))
942#define MCF5282_INTC1_L2IACK (*(vuint8 *)(&__IPSBAR[0x0DE8]))
943#define MCF5282_INTC1_L3IACK (*(vuint8 *)(&__IPSBAR[0x0DEC]))
944#define MCF5282_INTC1_L4IACK (*(vuint8 *)(&__IPSBAR[0x0DF0]))
945#define MCF5282_INTC1_L5IACK (*(vuint8 *)(&__IPSBAR[0x0DF4]))
946#define MCF5282_INTC1_L6IACK (*(vuint8 *)(&__IPSBAR[0x0DF8]))
947#define MCF5282_INTC1_L7IACK (*(vuint8 *)(&__IPSBAR[0x0DFC]))
948
949/* Bit level definitions and macros */
950#define MCF5282_INTC_IPRH_INT63 (0x80000000)
951#define MCF5282_INTC_IPRH_INT62 (0x40000000)
952#define MCF5282_INTC_IPRH_INT61 (0x20000000)
953#define MCF5282_INTC_IPRH_INT60 (0x10000000)
954#define MCF5282_INTC_IPRH_INT59 (0x08000000)
955#define MCF5282_INTC_IPRH_INT58 (0x04000000)
956#define MCF5282_INTC_IPRH_INT57 (0x02000000)
957#define MCF5282_INTC_IPRH_INT56 (0x01000000)
958#define MCF5282_INTC_IPRH_INT55 (0x00800000)
959#define MCF5282_INTC_IPRH_INT54 (0x00400000)
960#define MCF5282_INTC_IPRH_INT53 (0x00200000)
961#define MCF5282_INTC_IPRH_INT52 (0x00100000)
962#define MCF5282_INTC_IPRH_INT51 (0x00080000)
963#define MCF5282_INTC_IPRH_INT50 (0x00040000)
964#define MCF5282_INTC_IPRH_INT49 (0x00020000)
965#define MCF5282_INTC_IPRH_INT48 (0x00010000)
966#define MCF5282_INTC_IPRH_INT47 (0x00008000)
967#define MCF5282_INTC_IPRH_INT46 (0x00004000)
968#define MCF5282_INTC_IPRH_INT45 (0x00002000)
969#define MCF5282_INTC_IPRH_INT44 (0x00001000)
970#define MCF5282_INTC_IPRH_INT43 (0x00000800)
971#define MCF5282_INTC_IPRH_INT42 (0x00000400)
972#define MCF5282_INTC_IPRH_INT41 (0x00000200)
973#define MCF5282_INTC_IPRH_INT40 (0x00000100)
974#define MCF5282_INTC_IPRH_INT39 (0x00000080)
975#define MCF5282_INTC_IPRH_INT38 (0x00000040)
976#define MCF5282_INTC_IPRH_INT37 (0x00000020)
977#define MCF5282_INTC_IPRH_INT36 (0x00000010)
978#define MCF5282_INTC_IPRH_INT35 (0x00000008)
979#define MCF5282_INTC_IPRH_INT34 (0x00000004)
980#define MCF5282_INTC_IPRH_INT33 (0x00000002)
981#define MCF5282_INTC_IPRH_INT32 (0x00000001)
982
983#define MCF5282_INTC_IPRL_INT31 (0x80000000)
984#define MCF5282_INTC_IPRL_INT30 (0x40000000)
985#define MCF5282_INTC_IPRL_INT29 (0x20000000)
986#define MCF5282_INTC_IPRL_INT28 (0x10000000)
987#define MCF5282_INTC_IPRL_INT27 (0x08000000)
988#define MCF5282_INTC_IPRL_INT26 (0x04000000)
989#define MCF5282_INTC_IPRL_INT25 (0x02000000)
990#define MCF5282_INTC_IPRL_INT24 (0x01000000)
991#define MCF5282_INTC_IPRL_INT23 (0x00800000)
992#define MCF5282_INTC_IPRL_INT22 (0x00400000)
993#define MCF5282_INTC_IPRL_INT21 (0x00200000)
994#define MCF5282_INTC_IPRL_INT20 (0x00100000)
995#define MCF5282_INTC_IPRL_INT19 (0x00080000)
996#define MCF5282_INTC_IPRL_INT18 (0x00040000)
997#define MCF5282_INTC_IPRL_INT17 (0x00020000)
998#define MCF5282_INTC_IPRL_INT16 (0x00010000)
999#define MCF5282_INTC_IPRL_INT15 (0x00008000)
1000#define MCF5282_INTC_IPRL_INT14 (0x00004000)
1001#define MCF5282_INTC_IPRL_INT13 (0x00002000)
1002#define MCF5282_INTC_IPRL_INT12 (0x00001000)
1003#define MCF5282_INTC_IPRL_INT11 (0x00000800)
1004#define MCF5282_INTC_IPRL_INT10 (0x00000400)
1005#define MCF5282_INTC_IPRL_INT9 (0x00000200)
1006#define MCF5282_INTC_IPRL_INT8 (0x00000100)
1007#define MCF5282_INTC_IPRL_INT7 (0x00000080)
1008#define MCF5282_INTC_IPRL_INT6 (0x00000040)
1009#define MCF5282_INTC_IPRL_INT5 (0x00000020)
1010#define MCF5282_INTC_IPRL_INT4 (0x00000010)
1011#define MCF5282_INTC_IPRL_INT3 (0x00000008)
1012#define MCF5282_INTC_IPRL_INT2 (0x00000004)
1013#define MCF5282_INTC_IPRL_INT1 (0x00000002)
1014
1015#define MCF5282_INTC_IMRH_INT63 (0x80000000)
1016#define MCF5282_INTC_IMRH_INT62 (0x40000000)
1017#define MCF5282_INTC_IMRH_INT61 (0x20000000)
1018#define MCF5282_INTC_IMRH_INT60 (0x10000000)
1019#define MCF5282_INTC_IMRH_INT59 (0x08000000)
1020#define MCF5282_INTC_IMRH_INT58 (0x04000000)
1021#define MCF5282_INTC_IMRH_INT57 (0x02000000)
1022#define MCF5282_INTC_IMRH_INT56 (0x01000000)
1023#define MCF5282_INTC_IMRH_INT55 (0x00800000)
1024#define MCF5282_INTC_IMRH_INT54 (0x00400000)
1025#define MCF5282_INTC_IMRH_INT53 (0x00200000)
1026#define MCF5282_INTC_IMRH_INT52 (0x00100000)
1027#define MCF5282_INTC_IMRH_INT51 (0x00080000)
1028#define MCF5282_INTC_IMRH_INT50 (0x00040000)
1029#define MCF5282_INTC_IMRH_INT49 (0x00020000)
1030#define MCF5282_INTC_IMRH_INT48 (0x00010000)
1031#define MCF5282_INTC_IMRH_INT47 (0x00008000)
1032#define MCF5282_INTC_IMRH_INT46 (0x00004000)
1033#define MCF5282_INTC_IMRH_INT45 (0x00002000)
1034#define MCF5282_INTC_IMRH_INT44 (0x00001000)
1035#define MCF5282_INTC_IMRH_INT43 (0x00000800)
1036#define MCF5282_INTC_IMRH_INT42 (0x00000400)
1037#define MCF5282_INTC_IMRH_INT41 (0x00000200)
1038#define MCF5282_INTC_IMRH_INT40 (0x00000100)
1039#define MCF5282_INTC_IMRH_INT39 (0x00000080)
1040#define MCF5282_INTC_IMRH_INT38 (0x00000040)
1041#define MCF5282_INTC_IMRH_INT37 (0x00000020)
1042#define MCF5282_INTC_IMRH_INT36 (0x00000010)
1043#define MCF5282_INTC_IMRH_INT35 (0x00000008)
1044#define MCF5282_INTC_IMRH_INT34 (0x00000004)
1045#define MCF5282_INTC_IMRH_INT33 (0x00000002)
1046#define MCF5282_INTC_IMRH_INT32 (0x00000001)
1047
1048#define MCF5282_INTC_IMRL_INT31 (0x80000000)
1049#define MCF5282_INTC_IMRL_INT30 (0x40000000)
1050#define MCF5282_INTC_IMRL_INT29 (0x20000000)
1051#define MCF5282_INTC_IMRL_INT28 (0x10000000)
1052#define MCF5282_INTC_IMRL_INT27 (0x08000000)
1053#define MCF5282_INTC_IMRL_INT26 (0x04000000)
1054#define MCF5282_INTC_IMRL_INT25 (0x02000000)
1055#define MCF5282_INTC_IMRL_INT24 (0x01000000)
1056#define MCF5282_INTC_IMRL_INT23 (0x00800000)
1057#define MCF5282_INTC_IMRL_INT22 (0x00400000)
1058#define MCF5282_INTC_IMRL_INT21 (0x00200000)
1059#define MCF5282_INTC_IMRL_INT20 (0x00100000)
1060#define MCF5282_INTC_IMRL_INT19 (0x00080000)
1061#define MCF5282_INTC_IMRL_INT18 (0x00040000)
1062#define MCF5282_INTC_IMRL_INT17 (0x00020000)
1063#define MCF5282_INTC_IMRL_INT16 (0x00010000)
1064#define MCF5282_INTC_IMRL_INT15 (0x00008000)
1065#define MCF5282_INTC_IMRL_INT14 (0x00004000)
1066#define MCF5282_INTC_IMRL_INT13 (0x00002000)
1067#define MCF5282_INTC_IMRL_INT12 (0x00001000)
1068#define MCF5282_INTC_IMRL_INT11 (0x00000800)
1069#define MCF5282_INTC_IMRL_INT10 (0x00000400)
1070#define MCF5282_INTC_IMRL_INT9 (0x00000200)
1071#define MCF5282_INTC_IMRL_INT8 (0x00000100)
1072#define MCF5282_INTC_IMRL_INT7 (0x00000080)
1073#define MCF5282_INTC_IMRL_INT6 (0x00000040)
1074#define MCF5282_INTC_IMRL_INT5 (0x00000020)
1075#define MCF5282_INTC_IMRL_INT4 (0x00000010)
1076#define MCF5282_INTC_IMRL_INT3 (0x00000008)
1077#define MCF5282_INTC_IMRL_INT2 (0x00000004)
1078#define MCF5282_INTC_IMRL_INT1 (0x00000002)
1079#define MCF5282_INTC_IMRL_MASKALL (0x00000001)
1080
1081#define MCF5282_INTC_INTFRCH_INT63 (0x80000000)
1082#define MCF5282_INTC_INTFRCH_INT62 (0x40000000)
1083#define MCF5282_INTC_INTFRCH_INT61 (0x20000000)
1084#define MCF5282_INTC_INTFRCH_INT60 (0x10000000)
1085#define MCF5282_INTC_INTFRCH_INT59 (0x08000000)
1086#define MCF5282_INTC_INTFRCH_INT58 (0x04000000)
1087#define MCF5282_INTC_INTFRCH_INT57 (0x02000000)
1088#define MCF5282_INTC_INTFRCH_INT56 (0x01000000)
1089#define MCF5282_INTC_INTFRCH_INT55 (0x00800000)
1090#define MCF5282_INTC_INTFRCH_INT54 (0x00400000)
1091#define MCF5282_INTC_INTFRCH_INT53 (0x00200000)
1092#define MCF5282_INTC_INTFRCH_INT52 (0x00100000)
1093#define MCF5282_INTC_INTFRCH_INT51 (0x00080000)
1094#define MCF5282_INTC_INTFRCH_INT50 (0x00040000)
1095#define MCF5282_INTC_INTFRCH_INT49 (0x00020000)
1096#define MCF5282_INTC_INTFRCH_INT48 (0x00010000)
1097#define MCF5282_INTC_INTFRCH_INT47 (0x00008000)
1098#define MCF5282_INTC_INTFRCH_INT46 (0x00004000)
1099#define MCF5282_INTC_INTFRCH_INT45 (0x00002000)
1100#define MCF5282_INTC_INTFRCH_INT44 (0x00001000)
1101#define MCF5282_INTC_INTFRCH_INT43 (0x00000800)
1102#define MCF5282_INTC_INTFRCH_INT42 (0x00000400)
1103#define MCF5282_INTC_INTFRCH_INT41 (0x00000200)
1104#define MCF5282_INTC_INTFRCH_INT40 (0x00000100)
1105#define MCF5282_INTC_INTFRCH_INT39 (0x00000080)
1106#define MCF5282_INTC_INTFRCH_INT38 (0x00000040)
1107#define MCF5282_INTC_INTFRCH_INT37 (0x00000020)
1108#define MCF5282_INTC_INTFRCH_INT36 (0x00000010)
1109#define MCF5282_INTC_INTFRCH_INT35 (0x00000008)
1110#define MCF5282_INTC_INTFRCH_INT34 (0x00000004)
1111#define MCF5282_INTC_INTFRCH_INT33 (0x00000002)
1112#define MCF5282_INTC_INTFRCH_INT32 (0x00000001)
1113
1114#define MCF5282_INTC_INTFRCL_INT31 (0x80000000)
1115#define MCF5282_INTC_INTFRCL_INT30 (0x40000000)
1116#define MCF5282_INTC_INTFRCL_INT29 (0x20000000)
1117#define MCF5282_INTC_INTFRCL_INT28 (0x10000000)
1118#define MCF5282_INTC_INTFRCL_INT27 (0x08000000)
1119#define MCF5282_INTC_INTFRCL_INT26 (0x04000000)
1120#define MCF5282_INTC_INTFRCL_INT25 (0x02000000)
1121#define MCF5282_INTC_INTFRCL_INT24 (0x01000000)
1122#define MCF5282_INTC_INTFRCL_INT23 (0x00800000)
1123#define MCF5282_INTC_INTFRCL_INT22 (0x00400000)
1124#define MCF5282_INTC_INTFRCL_INT21 (0x00200000)
1125#define MCF5282_INTC_INTFRCL_INT20 (0x00100000)
1126#define MCF5282_INTC_INTFRCL_INT19 (0x00080000)
1127#define MCF5282_INTC_INTFRCL_INT18 (0x00040000)
1128#define MCF5282_INTC_INTFRCL_INT17 (0x00020000)
1129#define MCF5282_INTC_INTFRCL_INT16 (0x00010000)
1130#define MCF5282_INTC_INTFRCL_INT15 (0x00008000)
1131#define MCF5282_INTC_INTFRCL_INT14 (0x00004000)
1132#define MCF5282_INTC_INTFRCL_INT13 (0x00002000)
1133#define MCF5282_INTC_INTFRCL_INT12 (0x00001000)
1134#define MCF5282_INTC_INTFRCL_INT11 (0x00000800)
1135#define MCF5282_INTC_INTFRCL_INT10 (0x00000400)
1136#define MCF5282_INTC_INTFRCL_INT9 (0x00000200)
1137#define MCF5282_INTC_INTFRCL_INT8 (0x00000100)
1138#define MCF5282_INTC_INTFRCL_INT7 (0x00000080)
1139#define MCF5282_INTC_INTFRCL_INT6 (0x00000040)
1140#define MCF5282_INTC_INTFRCL_INT5 (0x00000020)
1141#define MCF5282_INTC_INTFRCL_INT4 (0x00000010)
1142#define MCF5282_INTC_INTFRCL_INT3 (0x00000008)
1143#define MCF5282_INTC_INTFRCL_INT2 (0x00000004)
1144#define MCF5282_INTC_INTFRCL_INT1 (0x00000002)
1145
1146#define MCF5282_INTC_IRLR_IRQ7 (0x80)
1147#define MCF5282_INTC_IRLR_IRQ6 (0x40)
1148#define MCF5282_INTC_IRLR_IRQ5 (0x20)
1149#define MCF5282_INTC_IRLR_IRQ4 (0x10)
1150#define MCF5282_INTC_IRLR_IRQ3 (0x08)
1151#define MCF5282_INTC_IRLR_IRQ2 (0x04)
1152#define MCF5282_INTC_IRLR_IRQ1 (0x02)
1153
1154#define MCF5282_INTC_ICR_IL(x) (((x)&0x07)<<3)
1155#define MCF5282_INTC_ICR_IP(x) (((x)&0x07)<<0)
1156
1157/*********************************************************************
1158*
1159* Global Interrupt Acknowledge Cycle (GIAC) Registers
1160*
1161*********************************************************************/
1162
1163/* Read/Write access macros for general use */
1164#define MCF5282_GIAC_GSWIACK (*(vuint8 *)(&__IPSBAR[0x0FE0]))
1165#define MCF5282_GIAC_GL1IACK (*(vuint8 *)(&__IPSBAR[0x0FE4]))
1166#define MCF5282_GIAC_GL2IACK (*(vuint8 *)(&__IPSBAR[0x0FE8]))
1167#define MCF5282_GIAC_GL3IACK (*(vuint8 *)(&__IPSBAR[0x0FEC]))
1168#define MCF5282_GIAC_GL4IACK (*(vuint8 *)(&__IPSBAR[0x0FF0]))
1169#define MCF5282_GIAC_GL5IACK (*(vuint8 *)(&__IPSBAR[0x0FF4]))
1170#define MCF5282_GIAC_GL6IACK (*(vuint8 *)(&__IPSBAR[0x0FF8]))
1171#define MCF5282_GIAC_GL7IACK (*(vuint8 *)(&__IPSBAR[0x0FFC]))
1172
1173/* Bit level definitions and macros */
1174
1175/* To do - add bit level definintions */
1176
1177/*********************************************************************
1178*
1179* Fast Ethernet Controller (FEC) Module
1180*
1181*********************************************************************/
1182
1183/* Read/Write access macros for general use */
1184#define MCF5282_FEC_EIR (*(vuint32 *)(&__IPSBAR[0x1004]))
1185#define MCF5282_FEC_EIMR (*(vuint32 *)(&__IPSBAR[0x1008]))
1186#define MCF5282_FEC_RDAR (*(vuint32 *)(&__IPSBAR[0x1010]))
1187#define MCF5282_FEC_TDAR (*(vuint32 *)(&__IPSBAR[0x1014]))
1188#define MCF5282_FEC_ECR (*(vuint32 *)(&__IPSBAR[0x1024]))
1189#define MCF5282_FEC_MMFR (*(vuint32 *)(&__IPSBAR[0x1040]))
1190#define MCF5282_FEC_MSCR (*(vuint32 *)(&__IPSBAR[0x1044]))
1191#define MCF5282_FEC_MIBC (*(vuint32 *)(&__IPSBAR[0x1064]))
1192#define MCF5282_FEC_RCR (*(vuint32 *)(&__IPSBAR[0x1084]))
1193#define MCF5282_FEC_TCR (*(vuint32 *)(&__IPSBAR[0x10C4]))
1194#define MCF5282_FEC_PALR (*(vuint32 *)(&__IPSBAR[0x10E4]))
1195#define MCF5282_FEC_PAUR (*(vuint32 *)(&__IPSBAR[0x10E8]))
1196#define MCF5282_FEC_OPD (*(vuint32 *)(&__IPSBAR[0x10EC]))
1197#define MCF5282_FEC_IAUR (*(vuint32 *)(&__IPSBAR[0x1118]))
1198#define MCF5282_FEC_IALR (*(vuint32 *)(&__IPSBAR[0x111C]))
1199#define MCF5282_FEC_GAUR (*(vuint32 *)(&__IPSBAR[0x1120]))
1200#define MCF5282_FEC_GALR (*(vuint32 *)(&__IPSBAR[0x1124]))
1201#define MCF5282_FEC_TFWR (*(vuint32 *)(&__IPSBAR[0x1144]))
1202#define MCF5282_FEC_FRBR (*(vuint32 *)(&__IPSBAR[0x114C]))
1203#define MCF5282_FEC_FRSR (*(vuint32 *)(&__IPSBAR[0x1150]))
1204#define MCF5282_FEC_ERDSR (*(vuint32 *)(&__IPSBAR[0x1180]))
1205#define MCF5282_FEC_ETDSR (*(vuint32 *)(&__IPSBAR[0x1184]))
1206#define MCF5282_FEC_EMRBR (*(vuint32 *)(&__IPSBAR[0x1188]))
1207
1208#define MCF5282_FEC_RMON_T_DROP (*(vuint32 *)(&__IPSBAR[0x1200]))
1209#define MCF5282_FEC_RMON_T_PACKETS (*(vuint32 *)(&__IPSBAR[0x1204]))
1210#define MCF5282_FEC_RMON_T_BC_PKT (*(vuint32 *)(&__IPSBAR[0x1208]))
1211#define MCF5282_FEC_RMON_T_MC_PKT (*(vuint32 *)(&__IPSBAR[0x120C]))
1212#define MCF5282_FEC_RMON_T_CRC_ALIGN (*(vuint32 *)(&__IPSBAR[0x1210]))
1213#define MCF5282_FEC_RMON_T_UNDERSIZE (*(vuint32 *)(&__IPSBAR[0x1214]))
1214#define MCF5282_FEC_RMON_T_OVERSIZE (*(vuint32 *)(&__IPSBAR[0x1218]))
1215#define MCF5282_FEC_RMON_T_FRAG (*(vuint32 *)(&__IPSBAR[0x121C]))
1216#define MCF5282_FEC_RMON_T_JAB (*(vuint32 *)(&__IPSBAR[0x1220]))
1217#define MCF5282_FEC_RMON_T_COL (*(vuint32 *)(&__IPSBAR[0x1224]))
1218#define MCF5282_FEC_RMON_T_P64 (*(vuint32 *)(&__IPSBAR[0x1228]))
1219#define MCF5282_FEC_RMON_T_P65TO127 (*(vuint32 *)(&__IPSBAR[0x122C]))
1220#define MCF5282_FEC_RMON_T_P128TO255 (*(vuint32 *)(&__IPSBAR[0x1230]))
1221#define MCF5282_FEC_RMON_T_P256TO511 (*(vuint32 *)(&__IPSBAR[0x1234]))
1222#define MCF5282_FEC_RMON_T_P512TO1023 (*(vuint32 *)(&__IPSBAR[0x1238]))
1223#define MCF5282_FEC_RMON_T_P1024TO2047 (*(vuint32 *)(&__IPSBAR[0x123C]))
1224#define MCF5282_FEC_RMON_T_P_GTE2048 (*(vuint32 *)(&__IPSBAR[0x1240]))
1225#define MCF5282_FEC_RMON_T_OCTETS (*(vuint32 *)(&__IPSBAR[0x1244]))
1226#define MCF5282_FEC_IEEE_T_DROP (*(vuint32 *)(&__IPSBAR[0x1248]))
1227#define MCF5282_FEC_IEEE_T_FRAME_OK (*(vuint32 *)(&__IPSBAR[0x124C]))
1228#define MCF5282_FEC_IEEE_T_1COL (*(vuint32 *)(&__IPSBAR[0x1250]))
1229#define MCF5282_FEC_IEEE_T_MCOL (*(vuint32 *)(&__IPSBAR[0x1254]))
1230#define MCF5282_FEC_IEEE_T_DEF (*(vuint32 *)(&__IPSBAR[0x1258]))
1231#define MCF5282_FEC_IEEE_T_LCOL (*(vuint32 *)(&__IPSBAR[0x125C]))
1232#define MCF5282_FEC_IEEE_T_EXCOL (*(vuint32 *)(&__IPSBAR[0x1260]))
1233#define MCF5282_FEC_IEEE_T_MACERR (*(vuint32 *)(&__IPSBAR[0x1264]))
1234#define MCF5282_FEC_IEEE_T_CSERR (*(vuint32 *)(&__IPSBAR[0x1268]))
1235#define MCF5282_FEC_IEEE_T_SQE (*(vuint32 *)(&__IPSBAR[0x126C]))
1236#define MCF5282_FEC_IEEE_T_FDXFC (*(vuint32 *)(&__IPSBAR[0x1270]))
1237#define MCF5282_FEC_IEEE_T_OCTETS_OK (*(vuint32 *)(&__IPSBAR[0x1274]))
1238#define MCF5282_FEC_RMON_R_PACKETS (*(vuint32 *)(&__IPSBAR[0x1284]))
1239#define MCF5282_FEC_RMON_R_BC_PKT (*(vuint32 *)(&__IPSBAR[0x1288]))
1240#define MCF5282_FEC_RMON_R_MC_PKT (*(vuint32 *)(&__IPSBAR[0x128C]))
1241#define MCF5282_FEC_RMON_R_CRC_ALIGN (*(vuint32 *)(&__IPSBAR[0x1290]))
1242#define MCF5282_FEC_RMON_R_UNDERSIZE (*(vuint32 *)(&__IPSBAR[0x1294]))
1243#define MCF5282_FEC_RMON_R_OVERSIZE (*(vuint32 *)(&__IPSBAR[0x1298]))
1244#define MCF5282_FEC_RMON_R_FRAG (*(vuint32 *)(&__IPSBAR[0x129C]))
1245#define MCF5282_FEC_RMON_R_JAB (*(vuint32 *)(&__IPSBAR[0x12A0]))
1246#define MCF5282_FEC_RMON_R_RESVD_0 (*(vuint32 *)(&__IPSBAR[0x12A4]))
1247#define MCF5282_FEC_RMON_R_P64 (*(vuint32 *)(&__IPSBAR[0x12A8]))
1248#define MCF5282_FEC_RMON_R_P65T0127 (*(vuint32 *)(&__IPSBAR[0x12AC]))
1249#define MCF5282_FEC_RMON_R_P128TO255 (*(vuint32 *)(&__IPSBAR[0x12B0]))
1250#define MCF5282_FEC_RMON_R_P256TO511 (*(vuint32 *)(&__IPSBAR[0x12B4]))
1251#define MCF5282_FEC_RMON_R_P512TO1023 (*(vuint32 *)(&__IPSBAR[0x12B8]))
1252#define MCF5282_FEC_RMON_R_P1024TO2047 (*(vuint32 *)(&__IPSBAR[0x12BC]))
1253#define MCF5282_FEC_RMON_R_GTE2048 (*(vuint32 *)(&__IPSBAR[0x12C0]))
1254#define MCF5282_FEC_RMON_R_OCTETS (*(vuint32 *)(&__IPSBAR[0x12C4]))
1255#define MCF5282_FEC_IEEE_R_DROP (*(vuint32 *)(&__IPSBAR[0x12C8]))
1256#define MCF5282_FEC_IEEE_R_FRAME_OK (*(vuint32 *)(&__IPSBAR[0x12CC]))
1257#define MCF5282_FEC_IEEE_R_CRC (*(vuint32 *)(&__IPSBAR[0x12D0]))
1258#define MCF5282_FEC_IEEE_R_ALIGN (*(vuint32 *)(&__IPSBAR[0x12D4]))
1259#define MCF5282_FEC_IEEE_R_MACERR (*(vuint32 *)(&__IPSBAR[0x12D8]))
1260#define MCF5282_FEC_IEEE_R_FDXFC (*(vuint32 *)(&__IPSBAR[0x12DC]))
1261#define MCF5282_FEC_IEEE_R_OCTETS_OK (*(vuint32 *)(&__IPSBAR[0x12E0]))
1262
1263/* Bit level definitions and macros */
1264#define MCF5282_FEC_EIR_HBERR (0x80000000)
1265#define MCF5282_FEC_EIR_BABR (0x40000000)
1266#define MCF5282_FEC_EIR_BABT (0x20000000)
1267#define MCF5282_FEC_EIR_GRA (0x10000000)
1268#define MCF5282_FEC_EIR_TXF (0x08000000)
1269#define MCF5282_FEC_EIR_TXB (0x04000000)
1270#define MCF5282_FEC_EIR_RXF (0x02000000)
1271#define MCF5282_FEC_EIR_RXB (0x01000000)
1272#define MCF5282_FEC_EIR_MII (0x00800000)
1273#define MCF5282_FEC_EIR_EBERR (0x00400000)
1274#define MCF5282_FEC_EIR_LC (0x00200000)
1275#define MCF5282_FEC_EIR_RL (0x00100000)
1276#define MCF5282_FEC_EIR_UN (0x00080000)
1277
1278#define MCF5282_FEC_EIMR_HBERR (0x80000000)
1279#define MCF5282_FEC_EIMR_BABR (0x40000000)
1280#define MCF5282_FEC_EIMR_BABT (0x20000000)
1281#define MCF5282_FEC_EIMR_GRA (0x10000000)
1282#define MCF5282_FEC_EIMR_TXF (0x08000000)
1283#define MCF5282_FEC_EIMR_TXB (0x04000000)
1284#define MCF5282_FEC_EIMR_RXF (0x02000000)
1285#define MCF5282_FEC_EIMR_RXB (0x01000000)
1286#define MCF5282_FEC_EIMR_MII (0x00800000)
1287#define MCF5282_FEC_EIMR_EBERR (0x00400000)
1288#define MCF5282_FEC_EIMR_LC (0x00200000)
1289#define MCF5282_FEC_EIMR_RL (0x00100000)
1290#define MCF5282_FEC_EIMR_UN (0x00080000)
1291
1292#define MCF5282_FEC_RDAR_R_DES_ACTIVE (0x01000000)
1293
1294#define MCF5282_FEC_TDAR_X_DES_ACTIVE (0x01000000)
1295
1296#define MCF5282_FEC_ECR_ETHER_EN (0x00000002)
1297#define MCF5282_FEC_ECR_RESET (0x00000001)
1298
1299#define MCF5282_FEC_MMFR_ST (0x40000000)
1300#define MCF5282_FEC_MMFR_OP_RD (0x20000000)
1301#define MCF5282_FEC_MMFR_OP_WR (0x10000000)
1302#define MCF5282_FEC_MMFR_PA(x) (((x)&0x1F)<<23)
1303#define MCF5282_FEC_MMFR_RA(x) (((x)&0x1F)<<18)
1304#define MCF5282_FEC_MMFR_TA (0x00020000)
1305#define MCF5282_FEC_MMFR_DATA(x) (((x)&0xFFFF))
1306
1307#define MCF5282_FEC_MSCR_DIS_PREAMBLE (0x00000008)
1308#define MCF5282_FEC_MSCR_MII_SPEED(x) (((x)&0x1F)<<1)
1309
1310#define MCF5282_FEC_MIBC_MIB_DISABLE (0x80000000)
1311#define MCF5282_FEC_MIBC_MIB_IDLE (0x40000000)
1312
1313#define MCF5282_FEC_RCR_MAX_FL(x) (((x)&0x07FF)<<16)
1314#define MCF5282_FEC_RCR_FCE (0x00000020)
1315#define MCF5282_FEC_RCR_BC_REJ (0x00000010)
1316#define MCF5282_FEC_RCR_PROM (0x00000008)
1317#define MCF5282_FEC_RCR_MII_MODE (0x00000004)
1318#define MCF5282_FEC_RCR_DRT (0x00000002)
1319#define MCF5282_FEC_RCR_LOOP (0x00000001)
1320
1321#define MCF5282_FEC_TCR_RFC_PAUSE (0x00000010)
1322#define MCF5282_FEC_TCR_TFC_PAUSE (0x00000008)
1323#define MCF5282_FEC_TCR_FDEN (0x00000004)
1324#define MCF5282_FEC_TCR_HBC (0x00000002)
1325#define MCF5282_FEC_TCR_GTS (0x00000001)
1326
1327#define MCF5282_FEC_PALR_BYTE0(x) (((x)&0xFF)<<24)
1328#define MCF5282_FEC_PALR_BYTE1(x) (((x)&0xFF)<<16)
1329#define MCF5282_FEC_PALR_BYTE2(x) (((x)&0xFF)<<8)
1330#define MCF5282_FEC_PALR_BYTE3(x) (((x)&0xFF))
1331
1332#define MCF5282_FEC_PAUR_BYTE4(x) (((x)&0xFF)<<24)
1333#define MCF5282_FEC_PAUR_BYTE5(x) (((x)&0xFF)<<16)
1334
1335#define MCF5282_FEC_OPD_PAUSE_DUR(x) (((x)&0xFFFF))
1336
1337#define MCF5282_FEC_TFWR_X_WMRK_64 (0x00000001)
1338#define MCF5282_FEC_TFWR_X_WMRK_128 (0x00000002)
1339#define MCF5282_FEC_TFWR_X_WMRK_192 (0x00000003)
1340
1341#define MCF5282_FEC_EMRBR_R_BUF_SIZE(x) (((x)&0x7F)<<4)
1342
1343#define MCF5282_FEC_TxBD_R 0x8000
1344#define MCF5282_FEC_TxBD_BUSY 0x4000
1345#define MCF5282_FEC_TxBD_TO1 0x4000
1346#define MCF5282_FEC_TxBD_W 0x2000
1347#define MCF5282_FEC_TxBD_TO2 0x1000
1348#define MCF5282_FEC_TxBD_FIRST 0x1000
1349#define MCF5282_FEC_TxBD_L 0x0800
1350#define MCF5282_FEC_TxBD_TC 0x0400
1351#define MCF5282_FEC_TxBD_DEF 0x0200
1352#define MCF5282_FEC_TxBD_HB 0x0100
1353#define MCF5282_FEC_TxBD_LC 0x0080
1354#define MCF5282_FEC_TxBD_RL 0x0040
1355#define MCF5282_FEC_TxBD_UN 0x0002
1356#define MCF5282_FEC_TxBD_CSL 0x0001
1357
1358#define MCF5282_FEC_RxBD_E 0x8000
1359#define MCF5282_FEC_RxBD_INUSE 0x4000
1360#define MCF5282_FEC_RxBD_R01 0x4000
1361#define MCF5282_FEC_RxBD_W 0x2000
1362#define MCF5282_FEC_RxBD_R02 0x1000
1363#define MCF5282_FEC_RxBD_L 0x0800
1364#define MCF5282_FEC_RxBD_M 0x0100
1365#define MCF5282_FEC_RxBD_BC 0x0080
1366#define MCF5282_FEC_RxBD_MC 0x0040
1367#define MCF5282_FEC_RxBD_LG 0x0020
1368#define MCF5282_FEC_RxBD_NO 0x0010
1369#define MCF5282_FEC_RxBD_CR 0x0004
1370#define MCF5282_FEC_RxBD_OV 0x0002
1371#define MCF5282_FEC_RxBD_TR 0x0001
1372
1373/*********************************************************************
1374*
1375* General Purpose I/O (GPIO) Module
1376*
1377*********************************************************************/
1378
1379/* Read/Write access macros for general use */
1380#define MCF5282_GPIO_PORTA (*(vuint8 *)(&__IPSBAR[0x100000]))
1381#define MCF5282_GPIO_PORTB (*(vuint8 *)(&__IPSBAR[0x100001]))
1382#define MCF5282_GPIO_PORTC (*(vuint8 *)(&__IPSBAR[0x100002]))
1383#define MCF5282_GPIO_PORTD (*(vuint8 *)(&__IPSBAR[0x100003]))
1384#define MCF5282_GPIO_PORTE (*(vuint8 *)(&__IPSBAR[0x100004]))
1385#define MCF5282_GPIO_PORTF (*(vuint8 *)(&__IPSBAR[0x100005]))
1386#define MCF5282_GPIO_PORTG (*(vuint8 *)(&__IPSBAR[0x100006]))
1387#define MCF5282_GPIO_PORTH (*(vuint8 *)(&__IPSBAR[0x100007]))
1388#define MCF5282_GPIO_PORTJ (*(vuint8 *)(&__IPSBAR[0x100008]))
1389#define MCF5282_GPIO_PORTDD (*(vuint8 *)(&__IPSBAR[0x100009]))
1390#define MCF5282_GPIO_PORTEH (*(vuint8 *)(&__IPSBAR[0x10000A]))
1391#define MCF5282_GPIO_PORTEL (*(vuint8 *)(&__IPSBAR[0x10000B]))
1392#define MCF5282_GPIO_PORTAS (*(vuint8 *)(&__IPSBAR[0x10000C]))
1393#define MCF5282_GPIO_PORTQS (*(vuint8 *)(&__IPSBAR[0x10000D]))
1394#define MCF5282_GPIO_PORTSD (*(vuint8 *)(&__IPSBAR[0x10000E]))
1395#define MCF5282_GPIO_PORTTC (*(vuint8 *)(&__IPSBAR[0x10000F]))
1396#define MCF5282_GPIO_PORTTD (*(vuint8 *)(&__IPSBAR[0x100010]))
1397#define MCF5282_GPIO_PORTUA (*(vuint8 *)(&__IPSBAR[0x100011]))
1398
1399#define MCF5282_GPIO_DDRA (*(vuint8 *)(&__IPSBAR[0x100014]))
1400#define MCF5282_GPIO_DDRB (*(vuint8 *)(&__IPSBAR[0x100015]))
1401#define MCF5282_GPIO_DDRC (*(vuint8 *)(&__IPSBAR[0x100016]))
1402#define MCF5282_GPIO_DDRD (*(vuint8 *)(&__IPSBAR[0x100017]))
1403#define MCF5282_GPIO_DDRE (*(vuint8 *)(&__IPSBAR[0x100018]))
1404#define MCF5282_GPIO_DDRF (*(vuint8 *)(&__IPSBAR[0x100019]))
1405#define MCF5282_GPIO_DDRG (*(vuint8 *)(&__IPSBAR[0x10001A]))
1406#define MCF5282_GPIO_DDRH (*(vuint8 *)(&__IPSBAR[0x10001B]))
1407#define MCF5282_GPIO_DDRJ (*(vuint8 *)(&__IPSBAR[0x10001C]))
1408#define MCF5282_GPIO_DDRDD (*(vuint8 *)(&__IPSBAR[0x10001D]))
1409#define MCF5282_GPIO_DDREH (*(vuint8 *)(&__IPSBAR[0x10001E]))
1410#define MCF5282_GPIO_DDREL (*(vuint8 *)(&__IPSBAR[0x10001F]))
1411#define MCF5282_GPIO_DDRAS (*(vuint8 *)(&__IPSBAR[0x100020]))
1412#define MCF5282_GPIO_DDRQS (*(vuint8 *)(&__IPSBAR[0x100021]))
1413#define MCF5282_GPIO_DDRSD (*(vuint8 *)(&__IPSBAR[0x100022]))
1414#define MCF5282_GPIO_DDRTC (*(vuint8 *)(&__IPSBAR[0x100023]))
1415#define MCF5282_GPIO_DDRTD (*(vuint8 *)(&__IPSBAR[0x100024]))
1416#define MCF5282_GPIO_DDRUA (*(vuint8 *)(&__IPSBAR[0x100025]))
1417
1418#define MCF5282_GPIO_PORTAP (*(vuint8 *)(&__IPSBAR[0x100028]))
1419#define MCF5282_GPIO_PORTBP (*(vuint8 *)(&__IPSBAR[0x100029]))
1420#define MCF5282_GPIO_PORTCP (*(vuint8 *)(&__IPSBAR[0x10002A]))
1421#define MCF5282_GPIO_PORTDP (*(vuint8 *)(&__IPSBAR[0x10002B]))
1422#define MCF5282_GPIO_PORTEP (*(vuint8 *)(&__IPSBAR[0x10002C]))
1423#define MCF5282_GPIO_PORTFP (*(vuint8 *)(&__IPSBAR[0x10002D]))
1424#define MCF5282_GPIO_PORTGP (*(vuint8 *)(&__IPSBAR[0x10002E]))
1425#define MCF5282_GPIO_PORTHP (*(vuint8 *)(&__IPSBAR[0x10002F]))
1426#define MCF5282_GPIO_PORTJP (*(vuint8 *)(&__IPSBAR[0x100030]))
1427#define MCF5282_GPIO_PORTDDP (*(vuint8 *)(&__IPSBAR[0x100031]))
1428#define MCF5282_GPIO_PORTEHP (*(vuint8 *)(&__IPSBAR[0x100032]))
1429#define MCF5282_GPIO_PORTELP (*(vuint8 *)(&__IPSBAR[0x100033]))
1430#define MCF5282_GPIO_PORTASP (*(vuint8 *)(&__IPSBAR[0x100034]))
1431#define MCF5282_GPIO_PORTQSP (*(vuint8 *)(&__IPSBAR[0x100035]))
1432#define MCF5282_GPIO_PORTSDP (*(vuint8 *)(&__IPSBAR[0x100036]))
1433#define MCF5282_GPIO_PORTTCP (*(vuint8 *)(&__IPSBAR[0x100037]))
1434#define MCF5282_GPIO_PORTTDP (*(vuint8 *)(&__IPSBAR[0x100038]))
1435#define MCF5282_GPIO_PORTUAP (*(vuint8 *)(&__IPSBAR[0x100039]))
1436
1437#define MCF5282_GPIO_SETA (*(vuint8 *)(&__IPSBAR[0x100028]))
1438#define MCF5282_GPIO_SETB (*(vuint8 *)(&__IPSBAR[0x100029]))
1439#define MCF5282_GPIO_SETC (*(vuint8 *)(&__IPSBAR[0x10002A]))
1440#define MCF5282_GPIO_SETD (*(vuint8 *)(&__IPSBAR[0x10002B]))
1441#define MCF5282_GPIO_SETE (*(vuint8 *)(&__IPSBAR[0x10002C]))
1442#define MCF5282_GPIO_SETF (*(vuint8 *)(&__IPSBAR[0x10002D]))
1443#define MCF5282_GPIO_SETG (*(vuint8 *)(&__IPSBAR[0x10002E]))
1444#define MCF5282_GPIO_SETH (*(vuint8 *)(&__IPSBAR[0x10002F]))
1445#define MCF5282_GPIO_SETJ (*(vuint8 *)(&__IPSBAR[0x100030]))
1446#define MCF5282_GPIO_SETDD (*(vuint8 *)(&__IPSBAR[0x100031]))
1447#define MCF5282_GPIO_SETEH (*(vuint8 *)(&__IPSBAR[0x100032]))
1448#define MCF5282_GPIO_SETEL (*(vuint8 *)(&__IPSBAR[0x100033]))
1449#define MCF5282_GPIO_SETAS (*(vuint8 *)(&__IPSBAR[0x100034]))
1450#define MCF5282_GPIO_SETQS (*(vuint8 *)(&__IPSBAR[0x100035]))
1451#define MCF5282_GPIO_SETSD (*(vuint8 *)(&__IPSBAR[0x100036]))
1452#define MCF5282_GPIO_SETTC (*(vuint8 *)(&__IPSBAR[0x100037]))
1453#define MCF5282_GPIO_SETTD (*(vuint8 *)(&__IPSBAR[0x100038]))
1454#define MCF5282_GPIO_SETUA (*(vuint8 *)(&__IPSBAR[0x100039]))
1455
1456#define MCF5282_GPIO_CLRA (*(vuint8 *)(&__IPSBAR[0x10003C]))
1457#define MCF5282_GPIO_CLRB (*(vuint8 *)(&__IPSBAR[0x10003D]))
1458#define MCF5282_GPIO_CLRC (*(vuint8 *)(&__IPSBAR[0x10003E]))
1459#define MCF5282_GPIO_CLRD (*(vuint8 *)(&__IPSBAR[0x10003F]))
1460#define MCF5282_GPIO_CLRE (*(vuint8 *)(&__IPSBAR[0x100040]))
1461#define MCF5282_GPIO_CLRF (*(vuint8 *)(&__IPSBAR[0x100041]))
1462#define MCF5282_GPIO_CLRG (*(vuint8 *)(&__IPSBAR[0x100042]))
1463#define MCF5282_GPIO_CLRH (*(vuint8 *)(&__IPSBAR[0x100043]))
1464#define MCF5282_GPIO_CLRJ (*(vuint8 *)(&__IPSBAR[0x100044]))
1465#define MCF5282_GPIO_CLRDD (*(vuint8 *)(&__IPSBAR[0x100045]))
1466#define MCF5282_GPIO_CLREH (*(vuint8 *)(&__IPSBAR[0x100046]))
1467#define MCF5282_GPIO_CLREL (*(vuint8 *)(&__IPSBAR[0x100047]))
1468#define MCF5282_GPIO_CLRAS (*(vuint8 *)(&__IPSBAR[0x100048]))
1469#define MCF5282_GPIO_CLRQS (*(vuint8 *)(&__IPSBAR[0x100049]))
1470#define MCF5282_GPIO_CLRSD (*(vuint8 *)(&__IPSBAR[0x10004A]))
1471#define MCF5282_GPIO_CLRTC (*(vuint8 *)(&__IPSBAR[0x10004B]))
1472#define MCF5282_GPIO_CLRTD (*(vuint8 *)(&__IPSBAR[0x10004C]))
1473#define MCF5282_GPIO_CLRUA (*(vuint8 *)(&__IPSBAR[0x10004D]))
1474
1475#define MCF5282_GPIO_PBCDPAR (*(vuint8 *)(&__IPSBAR[0x100050]))
1476#define MCF5282_GPIO_PFPAR (*(vuint8 *)(&__IPSBAR[0x100051]))
1477#define MCF5282_GPIO_PEPAR (*(vuint16 *)(&__IPSBAR[0x100052]))
1478#define MCF5282_GPIO_PJPAR (*(vuint8 *)(&__IPSBAR[0x100054]))
1479#define MCF5282_GPIO_PSDPAR (*(vuint8 *)(&__IPSBAR[0x100055]))
1480#define MCF5282_GPIO_PASPAR (*(vuint16 *)(&__IPSBAR[0x100056]))
1481#define MCF5282_GPIO_PEHLPAR (*(vuint8 *)(&__IPSBAR[0x100058]))
1482#define MCF5282_GPIO_PQSPAR (*(vuint8 *)(&__IPSBAR[0x100059]))
1483#define MCF5282_GPIO_PTCPAR (*(vuint8 *)(&__IPSBAR[0x10005A]))
1484#define MCF5282_GPIO_PTDPAR (*(vuint8 *)(&__IPSBAR[0x10005B]))
1485#define MCF5282_GPIO_PUAPAR (*(vuint8 *)(&__IPSBAR[0x10005C]))
1486
1487/* Bit level definitions and macros */
1488#define MCF5282_GPIO_PORTx7 (0x80)
1489#define MCF5282_GPIO_PORTx6 (0x40)
1490#define MCF5282_GPIO_PORTx5 (0x20)
1491#define MCF5282_GPIO_PORTx4 (0x10)
1492#define MCF5282_GPIO_PORTx3 (0x08)
1493#define MCF5282_GPIO_PORTx2 (0x04)
1494#define MCF5282_GPIO_PORTx1 (0x02)
1495#define MCF5282_GPIO_PORTx0 (0x01)
1496#define MCF5282_GPIO_PORTx(x) (0x01<<(x))
1497
1498#define MCF5282_GPIO_DDRx7 (0x80)
1499#define MCF5282_GPIO_DDRx6 (0x40)
1500#define MCF5282_GPIO_DDRx5 (0x20)
1501#define MCF5282_GPIO_DDRx4 (0x10)
1502#define MCF5282_GPIO_DDRx3 (0x08)
1503#define MCF5282_GPIO_DDRx2 (0x04)
1504#define MCF5282_GPIO_DDRx1 (0x02)
1505#define MCF5282_GPIO_DDRx0 (0x01)
1506#define MCF5282_GPIO_DDRx(x) (0x01<<(x))
1507
1508#define MCF5282_GPIO_PORTxP7 (0x80)
1509#define MCF5282_GPIO_PORTxP6 (0x40)
1510#define MCF5282_GPIO_PORTxP5 (0x20)
1511#define MCF5282_GPIO_PORTxP4 (0x10)
1512#define MCF5282_GPIO_PORTxP3 (0x08)
1513#define MCF5282_GPIO_PORTxP2 (0x04)
1514#define MCF5282_GPIO_PORTxP1 (0x02)
1515#define MCF5282_GPIO_PORTxP0 (0x01)
1516#define MCF5282_GPIO_PORTxP(x) (0x01<<(x))
1517
1518#define MCF5282_GPIO_SETx7 (0x80)
1519#define MCF5282_GPIO_SETx6 (0x40)
1520#define MCF5282_GPIO_SETx5 (0x20)
1521#define MCF5282_GPIO_SETx4 (0x10)
1522#define MCF5282_GPIO_SETx3 (0x08)
1523#define MCF5282_GPIO_SETx2 (0x04)
1524#define MCF5282_GPIO_SETx1 (0x02)
1525#define MCF5282_GPIO_SETx0 (0x01)
1526#define MCF5282_GPIO_SETx(x) (0x01<<(x))
1527
1528#define MCF5282_GPIO_CLRx7 (0x80)
1529#define MCF5282_GPIO_CLRx6 (0x40)
1530#define MCF5282_GPIO_CLRx5 (0x20)
1531#define MCF5282_GPIO_CLRx4 (0x10)
1532#define MCF5282_GPIO_CLRx3 (0x08)
1533#define MCF5282_GPIO_CLRx2 (0x04)
1534#define MCF5282_GPIO_CLRx1 (0x02)
1535#define MCF5282_GPIO_CLRx0 (0x01)
1536#define MCF5282_GPIO_CLRx(x) (0x01<<(x))
1537
1538#define MCF5282_GPIO_PBCDPAR_PBPA (0x80)
1539#define MCF5282_GPIO_PBCDPAR_PCDPA (0x40)
1540
1541#define MCF5282_GPIO_PEPAR_PEPA7 (0x4000)
1542#define MCF5282_GPIO_PEPAR_PEPA6 (0x1000)
1543#define MCF5282_GPIO_PEPAR_PEPA5 (0x0400)
1544#define MCF5282_GPIO_PEPAR_PEPA4 (0x0100)
1545#define MCF5282_GPIO_PEPAR_PEPA3 (0x0040)
1546#define MCF5282_GPIO_PEPAR_PEPA2 (0x0010)
1547#define MCF5282_GPIO_PEPAR_PEPA1(x) (((x)&0x3)<<2)
1548#define MCF5282_GPIO_PEPAR_PEPA0(x) (((x)&0x3))
1549
1550#define MCF5282_GPIO_PFPAR_PFPA7 (0x80)
1551#define MCF5282_GPIO_PFPAR_PFPA6 (0x40)
1552#define MCF5282_GPIO_PFPAR_PFPA5 (0x20)
1553
1554#define MCF5282_GPIO_PJPAR_PJPA7 (0x80)
1555#define MCF5282_GPIO_PJPAR_PJPA6 (0x40)
1556#define MCF5282_GPIO_PJPAR_PJPA5 (0x20)
1557#define MCF5282_GPIO_PJPAR_PJPA4 (0x10)
1558#define MCF5282_GPIO_PJPAR_PJPA3 (0x08)
1559#define MCF5282_GPIO_PJPAR_PJPA2 (0x04)
1560#define MCF5282_GPIO_PJPAR_PJPA1 (0x02)
1561#define MCF5282_GPIO_PJPAR_PJPA0 (0x01)
1562#define MCF5282_GPIO_PJPAR_PJPA(x) (0x01<<(x))
1563
1564#define MCF5282_GPIO_PSDPAR_PSDPA (0x80)
1565
1566#define MCF5282_GPIO_PASPAR_PASPA5(x) (((x)&0x3)<<10)
1567#define MCF5282_GPIO_PASPAR_PASPA4(x) (((x)&0x3)<<8)
1568#define MCF5282_GPIO_PASPAR_PASPA3(x) (((x)&0x3)<<6)
1569#define MCF5282_GPIO_PASPAR_PASPA2(x) (((x)&0x3)<<4)
1570#define MCF5282_GPIO_PASPAR_PASPA1(x) (((x)&0x3)<<2)
1571#define MCF5282_GPIO_PASPAR_PASPA0(x) (((x)&0x3))
1572
1573#define MCF5282_GPIO_PEHLPAR_PEHPA (0x80)
1574#define MCF5282_GPIO_PEHLPAR_PELPA (0x40)
1575
1576#define MCF5282_GPIO_PQSPAR_PQSPA6 (0x40)
1577#define MCF5282_GPIO_PQSPAR_PQSPA5 (0x20)
1578#define MCF5282_GPIO_PQSPAR_PQSPA4 (0x10)
1579#define MCF5282_GPIO_PQSPAR_PQSPA3 (0x08)
1580#define MCF5282_GPIO_PQSPAR_PQSPA2 (0x04)
1581#define MCF5282_GPIO_PQSPAR_PQSPA1 (0x02)
1582#define MCF5282_GPIO_PQSPAR_PQSPA0 (0x01)
1583#define MCF5282_GPIO_PQSPAR_PQSPA(x) (0x01<<(x))
1584
1585#define MCF5282_GPIO_PTCPAR_PTCPA3(x) (((x)&0x3)<<6)
1586#define MCF5282_GPIO_PTCPAR_PTCPA2(x) (((x)&0x3)<<4)
1587#define MCF5282_GPIO_PTCPAR_PTCPA1(x) (((x)&0x3)<<2)
1588#define MCF5282_GPIO_PTCPAR_PTCPA0(x) (((x)&0x3))
1589
1590#define MCF5282_GPIO_PTDPAR_PTDPA3(x) (((x)&0x3)<<6)
1591#define MCF5282_GPIO_PTDPAR_PTDPA2(x) (((x)&0x3)<<4)
1592#define MCF5282_GPIO_PTDPAR_PTDPA1(x) (((x)&0x3)<<2)
1593#define MCF5282_GPIO_PTDPAR_PTDPA0(x) (((x)&0x3))
1594
1595#define MCF5282_GPIO_PUAPAR_PUAPA3 (0x08)
1596#define MCF5282_GPIO_PUAPAR_PUAPA2 (0x04)
1597#define MCF5282_GPIO_PUAPAR_PUAPA1 (0x02)
1598#define MCF5282_GPIO_PUAPAR_PUAPA0 (0x01)
1599
1600/*********************************************************************
1601*
1602* Reset Controller Module
1603*
1604*********************************************************************/
1605
1606/* Read/Write access macros for general use */
1607#define MCF5282_RESET_RCR (*(vuint8 *)(&__IPSBAR[0x110000]))
1608#define MCF5282_RESET_RSR (*(vuint8 *)(&__IPSBAR[0x110001]))
1609
1610/* Bit level definitions and macros */
1611#define MCF5282_RESET_RCR_SOFTRST (0x80)
1612#define MCF5282_RESET_RCR_FRCRSTOUT (0x40)
1613#define MCF5282_RESET_RCR_LVDF (0x10)
1614#define MCF5282_RESET_RCR_LVDIE (0x08)
1615#define MCF5282_RESET_RCR_LVDRE (0x04)
1616#define MCF5282_RESET_RCR_LVDE (0x01)
1617
1618#define MCF5282_RESET_RSR_LVD (0x40)
1619#define MCF5282_RESET_RSR_SOFT (0x20)
1620#define MCF5282_RESET_RSR_WDR (0x10)
1621#define MCF5282_RESET_RSR_POR (0x08)
1622#define MCF5282_RESET_RSR_EXT (0x04)
1623#define MCF5282_RESET_RSR_LOC (0x02)
1624#define MCF5282_RESET_RSR_LOL (0x01)
1625
1626/*********************************************************************
1627*
1628* Chip Configuration Module (CCM)
1629*
1630*********************************************************************/
1631
1632/* Read/Write access macros for general use */
1633#define MCF5282_CCM_CCR (*(vuint16 *)(&__IPSBAR[0x110004]))
1634#define MCF5282_CCM_RCON (*(vuint16 *)(&__IPSBAR[0x110008]))
1635#define MCF5282_CCM_CIR (*(vuint16 *)(&__IPSBAR[0x11000A]))
1636
1637/* Bit level definitions and macros */
1638#define MCF5282_CCM_CCR_LOAD (0x8000)
1639#define MCF5282_CCM_CCR_MODE(x) (((x)&0x0007)<<8)
1640#define MCF5282_CCM_CCR_SZEN (0x0040)
1641#define MCF5282_CCM_CCR_PSTEN (0x0020)
1642#define MCF5282_CCM_CCR_BME (0x0008)
1643#define MCF5282_CCM_CCR_BMT(x) (((x)&0x0007))
1644
1645/*********************************************************************
1646*
1647* Power Management Module (PMM)
1648*
1649*********************************************************************/
1650
1651/* Read/Write access macros for general use */
1652#define MCF5282_PMM_LPICR (*(vuint8 *)(&__IPSBAR[0x000012]))
1653#define MCF5282_PMM_LPCR (*(vuint8 *)(&__IPSBAR[0x110007]))
1654
1655/* Bit level definitions and macros */
1656#define MCF5282_PMM_LPICR_ENBSTOP (0x80)
1657#define MCF5282_PMM_LPICR_XLMP_IPL(x) (((x)&0x07)<<4)
1658
1659#define MCF5282_PMM_LPCR_LPMD_STOP (0xC0)
1660#define MCF5282_PMM_LPCR_LPMD_WAIT (0x80)
1661#define MCF5282_PMM_LPCR_LPMD_DOZE (0x40)
1662#define MCF5282_PMM_LPCR_LPMD_RUN (0x00)
1663#define MCF5282_PMM_LPCR_STPMD(x) (((x)&0x03)<<3)
1664#define MCF5282_PMM_LPCR_LVDSE (0x02)
1665
1666/*********************************************************************
1667*
1668* Clock Module
1669*
1670*********************************************************************/
1671
1672/* Read/Write access macros for general use */
1673#define MCF5282_CLOCK_SYNCR (*(vuint16 *)(&__IPSBAR[0x120000]))
1674#define MCF5282_CLOCK_SYNSR (*(vuint8 *)(&__IPSBAR[0x120002]))
1675
1676/* Bit level definitions and macros */
1677#define MCF5282_CLOCK_SYNCR_LOLRE (0x8000)
1678#define MCF5282_CLOCK_SYNCR_MFD(x) (((x)&0x0007)<<12)
1679#define MCF5282_CLOCK_SYNCR_LOCRE (0x0800)
1680#define MCF5282_CLOCK_SYNCR_RFD(x) (((x)&0x0007)<<8)
1681#define MCF5282_CLOCK_SYNCR_LOCEN (0x0080)
1682#define MCF5282_CLOCK_SYNCR_DISCLK (0x0040)
1683#define MCF5282_CLOCK_SYNCR_FWKUP (0x0020)
1684#define MCF5282_CLOCK_SYNCR_STPMD(x) (((x)&0x0003)<<2)
1685
1686#define MCF5282_CLOCK_SYNSR_PLLMODE (0x80)
1687#define MCF5282_CLOCK_SYNSR_PLLSEL (0x40)
1688#define MCF5282_CLOCK_SYNSR_PLLREF (0x20)
1689#define MCF5282_CLOCK_SYNSR_LOCKS (0x10)
1690#define MCF5282_CLOCK_SYNSR_LOCK (0x08)
1691#define MCF5282_CLOCK_SYNSR_LOCS (0x04)
1692
1693/*********************************************************************
1694*
1695* Edge Port (EPORT) Module
1696*
1697*********************************************************************/
1698
1699/* Read/Write access macros for general use */
1700#define MCF5282_EPORT_EPPAR (*(vuint16 *)(&__IPSBAR[0x130000]))
1701#define MCF5282_EPORT_EPDDR (*(vuint8 *)(&__IPSBAR[0x130002]))
1702#define MCF5282_EPORT_EPIER (*(vuint8 *)(&__IPSBAR[0x130003]))
1703#define MCF5282_EPORT_EPDR (*(vuint8 *)(&__IPSBAR[0x130004]))
1704#define MCF5282_EPORT_EPPDR (*(vuint8 *)(&__IPSBAR[0x130005]))
1705#define MCF5282_EPORT_EPFR (*(vuint8 *)(&__IPSBAR[0x130006]))
1706
1707/* Bit level definitions and macros */
1708#define MCF5282_EPORT_EPPAR_EPPA7_LEVEL (0x0000)
1709#define MCF5282_EPORT_EPPAR_EPPA7_RISING (0x4000)
1710#define MCF5282_EPORT_EPPAR_EPPA7_FALLING (0x8000)
1711#define MCF5282_EPORT_EPPAR_EPPA7_BOTHEDGE (0xC000)
1712#define MCF5282_EPORT_EPPAR_EPPA6_LEVEL (0x0000)
1713#define MCF5282_EPORT_EPPAR_EPPA6_RISING (0x1000)
1714#define MCF5282_EPORT_EPPAR_EPPA6_FALLING (0x2000)
1715#define MCF5282_EPORT_EPPAR_EPPA6_BOTHEDGE (0x3000)
1716#define MCF5282_EPORT_EPPAR_EPPA5_LEVEL (0x0000)
1717#define MCF5282_EPORT_EPPAR_EPPA5_RISING (0x0400)
1718#define MCF5282_EPORT_EPPAR_EPPA5_FALLING (0x0800)
1719#define MCF5282_EPORT_EPPAR_EPPA5_BOTHEDGE (0x0C00)
1720#define MCF5282_EPORT_EPPAR_EPPA4_LEVEL (0x0000)
1721#define MCF5282_EPORT_EPPAR_EPPA4_RISING (0x0100)
1722#define MCF5282_EPORT_EPPAR_EPPA4_FALLING (0x0200)
1723#define MCF5282_EPORT_EPPAR_EPPA4_BOTHEDGE (0x0300)
1724#define MCF5282_EPORT_EPPAR_EPPA3_LEVEL (0x0000)
1725#define MCF5282_EPORT_EPPAR_EPPA3_RISING (0x0040)
1726#define MCF5282_EPORT_EPPAR_EPPA3_FALLING (0x0080)
1727#define MCF5282_EPORT_EPPAR_EPPA3_BOTHEDGE (0x00C0)
1728#define MCF5282_EPORT_EPPAR_EPPA2_LEVEL (0x0000)
1729#define MCF5282_EPORT_EPPAR_EPPA2_RISING (0x0010)
1730#define MCF5282_EPORT_EPPAR_EPPA2_FALLING (0x0020)
1731#define MCF5282_EPORT_EPPAR_EPPA2_BOTHEDGE (0x0030)
1732#define MCF5282_EPORT_EPPAR_EPPA1_LEVEL (0x0000)
1733#define MCF5282_EPORT_EPPAR_EPPA1_RISING (0x0004)
1734#define MCF5282_EPORT_EPPAR_EPPA1_FALLING (0x0008)
1735#define MCF5282_EPORT_EPPAR_EPPA1_BOTHEDGE (0x000C)
1736
1737
1738#define MCF5282_EPORT_EPDDR_EPDD7 (0x80)
1739#define MCF5282_EPORT_EPDDR_EPDD6 (0x40)
1740#define MCF5282_EPORT_EPDDR_EPDD5 (0x20)
1741#define MCF5282_EPORT_EPDDR_EPDD4 (0x10)
1742#define MCF5282_EPORT_EPDDR_EPDD3 (0x08)
1743#define MCF5282_EPORT_EPDDR_EPDD2 (0x04)
1744#define MCF5282_EPORT_EPDDR_EPDD1 (0x02)
1745#define MCF5282_EPORT_EPDDR_EPDD(x) (0x01<<(x))
1746
1747#define MCF5282_EPORT_EPIER_EPIE7 (0x80)
1748#define MCF5282_EPORT_EPIER_EPIE6 (0x40)
1749#define MCF5282_EPORT_EPIER_EPIE5 (0x20)
1750#define MCF5282_EPORT_EPIER_EPIE4 (0x10)
1751#define MCF5282_EPORT_EPIER_EPIE3 (0x08)
1752#define MCF5282_EPORT_EPIER_EPIE2 (0x04)
1753#define MCF5282_EPORT_EPIER_EPIE1 (0x02)
1754#define MCF5282_EPORT_EPIER_EPIE(x) (0x01<<(x))
1755
1756#define MCF5282_EPORT_EPDR_EPD7 (0x80)
1757#define MCF5282_EPORT_EPDR_EPD6 (0x40)
1758#define MCF5282_EPORT_EPDR_EPD5 (0x20)
1759#define MCF5282_EPORT_EPDR_EPD4 (0x10)
1760#define MCF5282_EPORT_EPDR_EPD3 (0x08)
1761#define MCF5282_EPORT_EPDR_EPD2 (0x04)
1762#define MCF5282_EPORT_EPDR_EPD1 (0x02)
1763#define MCF5282_EPORT_EPDR_EPD(x) (0x01<<(x))
1764
1765#define MCF5282_EPORT_EPPDR_EPPD7 (0x80)
1766#define MCF5282_EPORT_EPPDR_EPPD6 (0x40)
1767#define MCF5282_EPORT_EPPDR_EPPD5 (0x20)
1768#define MCF5282_EPORT_EPPDR_EPPD4 (0x10)
1769#define MCF5282_EPORT_EPPDR_EPPD3 (0x08)
1770#define MCF5282_EPORT_EPPDR_EPPD2 (0x04)
1771#define MCF5282_EPORT_EPPDR_EPPD1 (0x02)
1772#define MCF5282_EPORT_EPPDR_EPPD(x) (0x01<<(x))
1773
1774#define MCF5282_EPORT_EPFR_EPF7 (0x80)
1775#define MCF5282_EPORT_EPFR_EPF6 (0x40)
1776#define MCF5282_EPORT_EPFR_EPF5 (0x20)
1777#define MCF5282_EPORT_EPFR_EPF4 (0x10)
1778#define MCF5282_EPORT_EPFR_EPF3 (0x08)
1779#define MCF5282_EPORT_EPFR_EPF2 (0x04)
1780#define MCF5282_EPORT_EPFR_EPF1 (0x02)
1781#define MCF5282_EPORT_EPFR_EPF(x) (0x01<<(x))
1782
1783/*********************************************************************
1784*
1785* Watchdog Timer Module (WTM)
1786*
1787*********************************************************************/
1788
1789/* Read/Write access macros for general use */
1790#define MCF5282_WTM_WCR (*(vuint16 *)(&__IPSBAR[0x140000]))
1791#define MCF5282_WTM_WMR (*(vuint16 *)(&__IPSBAR[0x140002]))
1792#define MCF5282_WTM_WCNTR (*(vuint16 *)(&__IPSBAR[0x140004]))
1793#define MCF5282_WTM_WSR (*(vuint16 *)(&__IPSBAR[0x140006]))
1794
1795/* Bit level definitions and macros */
1796#define MCF5282_WTM_WCR_WAIT (0x0008)
1797#define MCF5282_WTM_WCR_DOZE (0x0004)
1798#define MCF5282_WTM_WCR_HALTED (0x0002)
1799#define MCF5282_WTM_WCR_EN (0x0001)
1800
1801#define MCF5282_WTM_WSR_SEQ1 (0x5555)
1802#define MCF5282_WTM_WSR_SEQ2 (0xAAAA)
1803
1804/*********************************************************************
1805*
1806* Programmable Interrupt Timer (PIT) Module
1807*
1808*********************************************************************/
1809
1810/* Read/Write access macros for general use */
1811#define MCF5282_PIT0_PCSR (*(vuint16 *)(&__IPSBAR[0x150000]))
1812#define MCF5282_PIT0_PMR (*(vuint16 *)(&__IPSBAR[0x150002]))
1813#define MCF5282_PIT0_PCNTR (*(vuint16 *)(&__IPSBAR[0x150004]))
1814
1815#define MCF5282_PIT1_PCSR (*(vuint16 *)(&__IPSBAR[0x160000]))
1816#define MCF5282_PIT1_PMR (*(vuint16 *)(&__IPSBAR[0x160002]))
1817#define MCF5282_PIT1_PCNTR (*(vuint16 *)(&__IPSBAR[0x160004]))
1818
1819#define MCF5282_PIT2_PCSR (*(vuint16 *)(&__IPSBAR[0x170000]))
1820#define MCF5282_PIT2_PMR (*(vuint16 *)(&__IPSBAR[0x170002]))
1821#define MCF5282_PIT2_PCNTR (*(vuint16 *)(&__IPSBAR[0x170004]))
1822
1823#define MCF5282_PIT3_PCSR (*(vuint16 *)(&__IPSBAR[0x180000]))
1824#define MCF5282_PIT3_PMR (*(vuint16 *)(&__IPSBAR[0x180002]))
1825#define MCF5282_PIT3_PCNTR (*(vuint16 *)(&__IPSBAR[0x180004]))
1826
1827#define MCF5282_PIT_PCSR(x) (*(vuint16 *)(&__IPSBAR[0x150000+(0x1000*(x))]))
1828#define MCF5282_PIT_PMR(x) (*(vuint16 *)(&__IPSBAR[0x150002+(0x1000*(x))]))
1829#define MCF5282_PIT_PCNTR(x) (*(vuint16 *)(&__IPSBAR[0x150004+(0x1000*(x))]))
1830
1831/* Bit level definitions and macros */
1832#define MCF5282_PIT_PCSR_PRE(x) (((x)&0x000F)<<8)
1833#define MCF5282_PIT_PCSR_DOZE (0x0040)
1834#define MCF5282_PIT_PCSR_HALTED (0x0020)
1835#define MCF5282_PIT_PCSR_OVW (0x0010)
1836#define MCF5282_PIT_PCSR_PIE (0x0008)
1837#define MCF5282_PIT_PCSR_PIF (0x0004)
1838#define MCF5282_PIT_PCSR_RLD (0x0002)
1839#define MCF5282_PIT_PCSR_EN (0x0001)
1840
1841/*********************************************************************
1842*
1843* Queued Analog to Digital Converter (QADC) Module
1844*
1845*********************************************************************/
1846
1847/* Read/Write access macros for general use */
1848#define MCF5282_QADC_QADCMCR (*(vuint16 *)(&__IPSBAR[0x190000]))
1849#define MCF5282_QADC_PORTQA (*(vuint8 *)(&__IPSBAR[0x190006]))
1850#define MCF5282_QADC_PORTQB (*(vuint8 *)(&__IPSBAR[0x190007]))
1851#define MCF5282_QADC_DDRQA (*(vuint8 *)(&__IPSBAR[0x190008]))
1852#define MCF5282_QADC_DDRQB (*(vuint8 *)(&__IPSBAR[0x190009]))
1853#define MCF5282_QADC_QACR0 (*(vuint16 *)(&__IPSBAR[0x19000A]))
1854#define MCF5282_QADC_QACR1 (*(vuint16 *)(&__IPSBAR[0x19000C]))
1855#define MCF5282_QADC_QACR2 (*(vuint16 *)(&__IPSBAR[0x19000E]))
1856#define MCF5282_QADC_QASR0 (*(vuint16 *)(&__IPSBAR[0x190010]))
1857#define MCF5282_QADC_QASR1 (*(vuint16 *)(&__IPSBAR[0x190012]))
1858#define MCF5282_QADC_CCW(x) (*(vuint16 *)(&__IPSBAR[0x190200+((x)*2)]))
1859#define MCF5282_QADC_RJURR(x) (*(vuint16 *)(&__IPSBAR[0x190280+((x)*2)]))
1860#define MCF5282_QADC_LJSRR(x) (*(vuint16 *)(&__IPSBAR[0x190300+((x)*2)]))
1861#define MCF5282_QADC_LJURR(x) (*(vuint16 *)(&__IPSBAR[0x190380+((x)*2)]))
1862
1863/* Bit level definitions and macros */
1864#define MCF5282_QADC_QADCMCR_QSTOP (0x8000)
1865#define MCF5282_QADC_QADCMCR_QDBG (0x4000)
1866#define MCF5282_QADC_QADCMCR_SUPV (0x0080)
1867
1868#define MCF5282_QADC_PORTQA_PQA4 (0x10)
1869#define MCF5282_QADC_PORTQA_PQA3 (0x08)
1870#define MCF5282_QADC_PORTQA_PQA1 (0x02)
1871#define MCF5282_QADC_PORTQA_PQA0 (0x01)
1872#define MCF5282_QADC_PORTQA_AN56 (0x10)
1873#define MCF5282_QADC_PORTQA_AN55 (0x08)
1874#define MCF5282_QADC_PORTQA_ETRIG2 (0x10)
1875#define MCF5282_QADC_PORTQA_ETRIG1 (0x08)
1876#define MCF5282_QADC_PORTQA_AN53 (0x02)
1877#define MCF5282_QADC_PORTQA_AN52 (0x01)
1878#define MCF5282_QADC_PORTQA_MA1 (0x02)
1879#define MCF5282_QADC_PORTQA_MA0 (0x01)
1880
1881#define MCF5282_QADC_PORTQB_PQB3 (0x08)
1882#define MCF5282_QADC_PORTQB_PQB2 (0x04)
1883#define MCF5282_QADC_PORTQB_PQB1 (0x02)
1884#define MCF5282_QADC_PORTQB_PQB0 (0x01)
1885#define MCF5282_QADC_PORTQB_AN3 (0x08)
1886#define MCF5282_QADC_PORTQB_AN2 (0x04)
1887#define MCF5282_QADC_PORTQB_AN1 (0x02)
1888#define MCF5282_QADC_PORTQB_AN0 (0x01)
1889#define MCF5282_QADC_PORTQB_ANZ (0x08)
1890#define MCF5282_QADC_PORTQB_ANY (0x04)
1891#define MCF5282_QADC_PORTQB_ANX (0x02)
1892#define MCF5282_QADC_PORTQB_ANW (0x01)
1893
1894#define MCF5282_QADC_DDRQA_DDQA4 (0x10)
1895#define MCF5282_QADC_DDRQA_DDQA3 (0x08)
1896#define MCF5282_QADC_DDRQA_DDQA1 (0x02)
1897#define MCF5282_QADC_DDRQA_DDQA0 (0x01)
1898
1899#define MCF5282_QADC_DDRQB_DDQB3 (0x08)
1900#define MCF5282_QADC_DDRQB_DDQB2 (0x04)
1901#define MCF5282_QADC_DDRQB_DDQB1 (0x02)
1902#define MCF5282_QADC_DDRQB_DDQB0 (0x01)
1903
1904#define MCF5282_QADC_QACR0_MUX (0x8000)
1905#define MCF5282_QADC_QACR0_TRG (0x1000)
1906#define MCF5282_QADC_QACR0_QPR(x) (((x)&0x007F))
1907
1908#define MCF5282_QADC_QACRx_CIE (0x8000)
1909#define MCF5282_QADC_QACRx_PIE (0x4000)
1910#define MCF5282_QADC_QACRx_SSE (0x2000)
1911#define MCF5282_QADC_QACRx_MQ(x) (((x)&0x001F)<<8)
1912#define MCF5282_QADC_QACRx_RESUME (0x0080)
1913#define MCF5282_QADC_QACRx_BQ(x) (((x)&0x007F))
1914
1915#define MCF5282_QADC_QASR0_CF1 (0x8000)
1916#define MCF5282_QADC_QASR0_PF1 (0x4000)
1917#define MCF5282_QADC_QASR0_CF2 (0x2000)
1918#define MCF5282_QADC_QASR0_PF2 (0x1000)
1919#define MCF5282_QADC_QASR0_TOR1 (0x0800)
1920#define MCF5282_QADC_QASR0_TOR2 (0x0400)
1921
1922#define MCF5282_QADC_CCW_P (0x0200)
1923#define MCF5282_QADC_CCW_BYP (0x0100)
1924#define MCF5282_QADC_CCW_IST(x) (((x)&0x0003)<<14)
1925#define MCF5282_QADC_CCW_CHAN(x) (((x)&0x003F))
1926
1927/*********************************************************************
1928*
1929* General Purpose Timer (GPT) Module
1930*
1931*********************************************************************/
1932
1933/* Read/Write access macros for general use */
1934#define MCF5282_GPTA_GPTIOS (*(vuint8 *)(&__IPSBAR[0x1A0000]))
1935#define MCF5282_GPTA_GPTCFORC (*(vuint8 *)(&__IPSBAR[0x1A0001]))
1936#define MCF5282_GPTA_GPTOC3M (*(vuint8 *)(&__IPSBAR[0x1A0002]))
1937#define MCF5282_GPTA_GPTOC3D (*(vuint8 *)(&__IPSBAR[0x1A0003]))
1938#define MCF5282_GPTA_GPTCNT (*(vuint16 *)(&__IPSBAR[0x1A0004]))
1939#define MCF5282_GPTA_GPTSCR1 (*(vuint8 *)(&__IPSBAR[0x1A0006]))
1940#define MCF5282_GPTA_GPTTOV (*(vuint8 *)(&__IPSBAR[0x1A0008]))
1941#define MCF5282_GPTA_GPTCTL1 (*(vuint8 *)(&__IPSBAR[0x1A0009]))
1942#define MCF5282_GPTA_GPTCTL2 (*(vuint8 *)(&__IPSBAR[0x1A000B]))
1943#define MCF5282_GPTA_GPTIE (*(vuint8 *)(&__IPSBAR[0x1A000C]))
1944#define MCF5282_GPTA_GPTSCR2 (*(vuint8 *)(&__IPSBAR[0x1A000D]))
1945#define MCF5282_GPTA_GPTFLG1 (*(vuint8 *)(&__IPSBAR[0x1A000E]))
1946#define MCF5282_GPTA_GPTFLG2 (*(vuint8 *)(&__IPSBAR[0x1A000F]))
1947#define MCF5282_GPTA_GPTC0 (*(vuint16 *)(&__IPSBAR[0x1A0010]))
1948#define MCF5282_GPTA_GPTC1 (*(vuint16 *)(&__IPSBAR[0x1A0012]))
1949#define MCF5282_GPTA_GPTC2 (*(vuint16 *)(&__IPSBAR[0x1A0014]))
1950#define MCF5282_GPTA_GPTC3 (*(vuint16 *)(&__IPSBAR[0x1A0016]))
1951#define MCF5282_GPTA_GPTPACTL (*(vuint8 *)(&__IPSBAR[0x1A0018]))
1952#define MCF5282_GPTA_GPTPAFLG (*(vuint8 *)(&__IPSBAR[0x1A0019]))
1953#define MCF5282_GPTA_GPTPACNT (*(vuint16 *)(&__IPSBAR[0x1A001A]))
1954#define MCF5282_GPTA_GPTPORT (*(vuint8 *)(&__IPSBAR[0x1A001D]))
1955#define MCF5282_GPTA_GPTDDR (*(vuint8 *)(&__IPSBAR[0x1A001E]))
1956
1957#define MCF5282_GPTB_GPTIOS (*(vuint8 *)(&__IPSBAR[0x1B0000]))
1958#define MCF5282_GPTB_GPTCFORC (*(vuint8 *)(&__IPSBAR[0x1B0001]))
1959#define MCF5282_GPTB_GPTOC3M (*(vuint8 *)(&__IPSBAR[0x1B0002]))
1960#define MCF5282_GPTB_GPTOC3D (*(vuint8 *)(&__IPSBAR[0x1B0003]))
1961#define MCF5282_GPTB_GPTCNT (*(vuint16 *)(&__IPSBAR[0x1B0004]))
1962#define MCF5282_GPTB_GPTSCR1 (*(vuint8 *)(&__IPSBAR[0x1B0006]))
1963#define MCF5282_GPTB_GPTTOV (*(vuint8 *)(&__IPSBAR[0x1B0008]))
1964#define MCF5282_GPTB_GPTCTL1 (*(vuint8 *)(&__IPSBAR[0x1B0009]))
1965#define MCF5282_GPTB_GPTCTL2 (*(vuint8 *)(&__IPSBAR[0x1B000B]))
1966#define MCF5282_GPTB_GPTIE (*(vuint8 *)(&__IPSBAR[0x1B000C]))
1967#define MCF5282_GPTB_GPTSCR2 (*(vuint8 *)(&__IPSBAR[0x1B000D]))
1968#define MCF5282_GPTB_GPTFLG1 (*(vuint8 *)(&__IPSBAR[0x1B000E]))
1969#define MCF5282_GPTB_GPTFLG2 (*(vuint8 *)(&__IPSBAR[0x1B000F]))
1970#define MCF5282_GPTB_GPTC0 (*(vuint16 *)(&__IPSBAR[0x1B0010]))
1971#define MCF5282_GPTB_GPTC1 (*(vuint16 *)(&__IPSBAR[0x1B0012]))
1972#define MCF5282_GPTB_GPTC2 (*(vuint16 *)(&__IPSBAR[0x1B0014]))
1973#define MCF5282_GPTB_GPTC3 (*(vuint16 *)(&__IPSBAR[0x1B0016]))
1974#define MCF5282_GPTB_GPTPACTL (*(vuint8 *)(&__IPSBAR[0x1B0018]))
1975#define MCF5282_GPTB_GPTPAFLG (*(vuint8 *)(&__IPSBAR[0x1B0019]))
1976#define MCF5282_GPTB_GPTPACNT (*(vuint16 *)(&__IPSBAR[0x1B001A]))
1977#define MCF5282_GPTB_GPTPORT (*(vuint8 *)(&__IPSBAR[0x1B001D]))
1978#define MCF5282_GPTB_GPTDDR (*(vuint8 *)(&__IPSBAR[0x1B001E]))
1979
1980/* Bit level definitions and macros */
1981#define MCF5282_GPT_GPTIOS_IOS3 (0x08)
1982#define MCF5282_GPT_GPTIOS_IOS2 (0x04)
1983#define MCF5282_GPT_GPTIOS_IOS1 (0x02)
1984#define MCF5282_GPT_GPTIOS_IOS0 (0x01)
1985
1986#define MCF5282_GPT_GPTCFORC_FOC3 (0x08)
1987#define MCF5282_GPT_GPTCFORC_FOC2 (0x04)
1988#define MCF5282_GPT_GPTCFORC_FOC1 (0x02)
1989#define MCF5282_GPT_GPTCFORC_FOC0 (0x01)
1990
1991#define MCF5282_GPT_GPTOC3M_OC3M3 (0x08)
1992#define MCF5282_GPT_GPTOC3M_OC3M2 (0x04)
1993#define MCF5282_GPT_GPTOC3M_OC3M1 (0x02)
1994#define MCF5282_GPT_GPTOC3M_OC3M0 (0x01)
1995
1996#define MCF5282_GPT_GPTOC3M_OC3D(x) (((x)&0x04))
1997
1998#define MCF5282_GPT_GPTSCR1_GPTEN (0x80)
1999#define MCF5282_GPT_GPTSCR1_TFFCA (0x10)
2000
2001#define MCF5282_GPT_GPTTOV3 (0x08)
2002#define MCF5282_GPT_GPTTOV2 (0x04)
2003#define MCF5282_GPT_GPTTOV1 (0x02)
2004#define MCF5282_GPT_GPTTOV0 (0x01)
2005
2006#define MCF5282_GPT_GPTCTL_OMOL3(x) (((x)&0x03)<<6)
2007#define MCF5282_GPT_GPTCTL_OMOL2(x) (((x)&0x03)<<4)
2008#define MCF5282_GPT_GPTCTL_OMOL1(x) (((x)&0x03)<<2)
2009#define MCF5282_GPT_GPTCTL_OMOL0(x) (((x)&0x03))
2010
2011#define MCF5282_GPT_GPTCTL2_EDG3(x) (((x)&0x03)<<6)
2012#define MCF5282_GPT_GPTCTL2_EDG2(x) (((x)&0x03)<<4)
2013#define MCF5282_GPT_GPTCTL2_EDG1(x) (((x)&0x03)<<2)
2014#define MCF5282_GPT_GPTCTL2_EDG0(x) (((x)&0x03))
2015
2016#define MCF5282_GPT_GPTIE_C3I (0x08)
2017#define MCF5282_GPT_GPTIE_C2I (0x04)
2018#define MCF5282_GPT_GPTIE_C1I (0x02)
2019#define MCF5282_GPT_GPTIE_C0I (0x01)
2020
2021#define MCF5282_GPT_GPTSCR2_TOI (0x80)
2022#define MCF5282_GPT_GPTSCR2_PUPT (0x20)
2023#define MCF5282_GPT_GPTSCR2_RDPT (0x10)
2024#define MCF5282_GPT_GPTSCR2_TCRE (0x08)
2025#define MCF5282_GPT_GPTSCR2_PR(x) (((x)&0x07))
2026
2027#define MCF5282_GPT_GPTFLG1_C3F (0x08)
2028#define MCF5282_GPT_GPTFLG1_C2F (0x04)
2029#define MCF5282_GPT_GPTFLG1_C1F (0x02)
2030#define MCF5282_GPT_GPTFLG1_C0F (0x01)
2031
2032#define MCF5282_GPT_GPTFLG2_TOF (0x80)
2033#define MCF5282_GPT_GPTFLG2_C3F (0x08)
2034#define MCF5282_GPT_GPTFLG2_C2F (0x04)
2035#define MCF5282_GPT_GPTFLG2_C1F (0x02)
2036#define MCF5282_GPT_GPTFLG2_C0F (0x01)
2037
2038#define MCF5282_GPT_GPTPACTL_PAE (0x40)
2039#define MCF5282_GPT_GPTPACTL_PAMOD (0x20)
2040#define MCF5282_GPT_GPTPACTL_PEDGE (0x10)
2041#define MCF5282_GPT_GPTPACTL_CLK_PACLK (0x04)
2042#define MCF5282_GPT_GPTPACTL_CLK_PACLK256 (0x08)
2043#define MCF5282_GPT_GPTPACTL_CLK_PACLK65536 (0x0C)
2044#define MCF5282_GPT_GPTPACTL_CLK(x) (((x)&0x03)<<2)
2045#define MCF5282_GPT_GPTPACTL_PAOVI (0x02)
2046#define MCF5282_GPT_GPTPACTL_PAI (0x01)
2047
2048#define MCF5282_GPT_GPTPAFLG_PAOVF (0x02)
2049#define MCF5282_GPT_GPTPAFLG_PAIF (0x01)
2050
2051#define MCF5282_GPT_GPTPORT_PORTT3 (0x08)
2052#define MCF5282_GPT_GPTPORT_PORTT2 (0x04)
2053#define MCF5282_GPT_GPTPORT_PORTT1 (0x02)
2054#define MCF5282_GPT_GPTPORT_PORTT0 (0x01)
2055
2056#define MCF5282_GPT_GPTDDR_DDRT3 (0x08)
2057#define MCF5282_GPT_GPTDDR_DDRT2 (0x04)
2058#define MCF5282_GPT_GPTDDR_DDRT1 (0x02)
2059#define MCF5282_GPT_GPTDDR_DDRT0 (0x01)
2060
2061/*********************************************************************
2062*
2063* FlexCAN Module
2064*
2065*********************************************************************/
2066
2067/* Read/Write access macros for general use */
2068#define MCF5282_FLEXCAN_CANMCR (*(vuint16 *)(&__IPSBAR[0x1C0000]))
2069#define MCF5282_FLEXCAN_CANCTRL0 (*(vuint8 *)(&__IPSBAR[0x1C0006]))
2070#define MCF5282_FLEXCAN_CANCTRL1 (*(vuint8 *)(&__IPSBAR[0x1C0007]))
2071#define MCF5282_FLEXCAN_PRESDIV (*(vuint8 *)(&__IPSBAR[0x1C0008]))
2072#define MCF5282_FLEXCAN_CANCTRL2 (*(vuint8 *)(&__IPSBAR[0x1C0009]))
2073#define MCF5282_FLEXCAN_TIMER (*(vuint16 *)(&__IPSBAR[0x1C000A]))
2074#define MCF5282_FLEXCAN_RXGMASK (*(vuint32 *)(&__IPSBAR[0x1C0010]))
2075#define MCF5282_FLEXCAN_RX14MASK (*(vuint32 *)(&__IPSBAR[0x1C0014]))
2076#define MCF5282_FLEXCAN_RX15MASK (*(vuint32 *)(&__IPSBAR[0x1C0018]))
2077#define MCF5282_FLEXCAN_ESTAT (*(vuint16 *)(&__IPSBAR[0x1C0020]))
2078#define MCF5282_FLEXCAN_IMASK (*(vuint16 *)(&__IPSBAR[0x1C0022]))
2079#define MCF5282_FLEXCAN_IFLAG (*(vuint16 *)(&__IPSBAR[0x1C0024]))
2080#define MCF5282_FLEXCAN_RXECTR (*(vuint8 *)(&__IPSBAR[0x1C0026]))
2081#define MCF5282_FLEXCAN_TXECTR (*(vuint8 *)(&__IPSBAR[0x1C0027]))
2082#define MCF5282_FLEXCAN_MBUF0_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0081]))
2083#define MCF5282_FLEXCAN_MBUF0_IDH (*(vuint16 *)(&__IPSBAR[0x1C0082]))
2084#define MCF5282_FLEXCAN_MBUF0_IDL (*(vuint16 *)(&__IPSBAR[0x1C0084]))
2085#define MCF5282_FLEXCAN_MBUF0_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0086]))
2086#define MCF5282_FLEXCAN_MBUF0_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0087]))
2087#define MCF5282_FLEXCAN_MBUF0_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0088]))
2088#define MCF5282_FLEXCAN_MBUF0_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0089]))
2089#define MCF5282_FLEXCAN_MBUF0_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C008A]))
2090#define MCF5282_FLEXCAN_MBUF0_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C008B]))
2091#define MCF5282_FLEXCAN_MBUF0_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C008C]))
2092#define MCF5282_FLEXCAN_MBUF0_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C008D]))
2093#define MCF5282_FLEXCAN_MBUF1_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0091]))
2094#define MCF5282_FLEXCAN_MBUF1_IDH (*(vuint16 *)(&__IPSBAR[0x1C0092]))
2095#define MCF5282_FLEXCAN_MBUF1_IDL (*(vuint16 *)(&__IPSBAR[0x1C0094]))
2096#define MCF5282_FLEXCAN_MBUF1_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0096]))
2097#define MCF5282_FLEXCAN_MBUF1_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0097]))
2098#define MCF5282_FLEXCAN_MBUF1_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0098]))
2099#define MCF5282_FLEXCAN_MBUF1_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0099]))
2100#define MCF5282_FLEXCAN_MBUF1_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C009A]))
2101#define MCF5282_FLEXCAN_MBUF1_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C009B]))
2102#define MCF5282_FLEXCAN_MBUF1_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C009C]))
2103#define MCF5282_FLEXCAN_MBUF1_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C009D]))
2104#define MCF5282_FLEXCAN_MBUF2_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00A1]))
2105#define MCF5282_FLEXCAN_MBUF2_IDH (*(vuint16 *)(&__IPSBAR[0x1C00A2]))
2106#define MCF5282_FLEXCAN_MBUF2_IDL (*(vuint16 *)(&__IPSBAR[0x1C00A4]))
2107#define MCF5282_FLEXCAN_MBUF2_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00A6]))
2108#define MCF5282_FLEXCAN_MBUF2_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00A7]))
2109#define MCF5282_FLEXCAN_MBUF2_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00A8]))
2110#define MCF5282_FLEXCAN_MBUF2_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00A9]))
2111#define MCF5282_FLEXCAN_MBUF2_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00AA]))
2112#define MCF5282_FLEXCAN_MBUF2_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00AB]))
2113#define MCF5282_FLEXCAN_MBUF2_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00AC]))
2114#define MCF5282_FLEXCAN_MBUF2_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00AD]))
2115#define MCF5282_FLEXCAN_MBUF3_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00B1]))
2116#define MCF5282_FLEXCAN_MBUF3_IDH (*(vuint16 *)(&__IPSBAR[0x1C00B2]))
2117#define MCF5282_FLEXCAN_MBUF3_IDL (*(vuint16 *)(&__IPSBAR[0x1C00B4]))
2118#define MCF5282_FLEXCAN_MBUF3_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00B6]))
2119#define MCF5282_FLEXCAN_MBUF3_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00B7]))
2120#define MCF5282_FLEXCAN_MBUF3_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00B8]))
2121#define MCF5282_FLEXCAN_MBUF3_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00B9]))
2122#define MCF5282_FLEXCAN_MBUF3_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00BA]))
2123#define MCF5282_FLEXCAN_MBUF3_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00BB]))
2124#define MCF5282_FLEXCAN_MBUF3_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00BC]))
2125#define MCF5282_FLEXCAN_MBUF3_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00BD]))
2126#define MCF5282_FLEXCAN_MBUF4_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00C1]))
2127#define MCF5282_FLEXCAN_MBUF4_IDH (*(vuint16 *)(&__IPSBAR[0x1C00C2]))
2128#define MCF5282_FLEXCAN_MBUF4_IDL (*(vuint16 *)(&__IPSBAR[0x1C00C4]))
2129#define MCF5282_FLEXCAN_MBUF4_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00C6]))
2130#define MCF5282_FLEXCAN_MBUF4_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00C7]))
2131#define MCF5282_FLEXCAN_MBUF4_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00C8]))
2132#define MCF5282_FLEXCAN_MBUF4_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00C9]))
2133#define MCF5282_FLEXCAN_MBUF4_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00CA]))
2134#define MCF5282_FLEXCAN_MBUF4_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00CB]))
2135#define MCF5282_FLEXCAN_MBUF4_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00CC]))
2136#define MCF5282_FLEXCAN_MBUF4_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00CD]))
2137#define MCF5282_FLEXCAN_MBUF5_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00D1]))
2138#define MCF5282_FLEXCAN_MBUF5_IDH (*(vuint16 *)(&__IPSBAR[0x1C00D2]))
2139#define MCF5282_FLEXCAN_MBUF5_IDL (*(vuint16 *)(&__IPSBAR[0x1C00D4]))
2140#define MCF5282_FLEXCAN_MBUF5_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00D6]))
2141#define MCF5282_FLEXCAN_MBUF5_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00D7]))
2142#define MCF5282_FLEXCAN_MBUF5_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00D8]))
2143#define MCF5282_FLEXCAN_MBUF5_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00D9]))
2144#define MCF5282_FLEXCAN_MBUF5_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00DA]))
2145#define MCF5282_FLEXCAN_MBUF5_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00DB]))
2146#define MCF5282_FLEXCAN_MBUF5_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00DC]))
2147#define MCF5282_FLEXCAN_MBUF5_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00DD]))
2148#define MCF5282_FLEXCAN_MBUF6_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00E1]))
2149#define MCF5282_FLEXCAN_MBUF6_IDH (*(vuint16 *)(&__IPSBAR[0x1C00E2]))
2150#define MCF5282_FLEXCAN_MBUF6_IDL (*(vuint16 *)(&__IPSBAR[0x1C00E4]))
2151#define MCF5282_FLEXCAN_MBUF6_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00E6]))
2152#define MCF5282_FLEXCAN_MBUF6_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00E7]))
2153#define MCF5282_FLEXCAN_MBUF6_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00E8]))
2154#define MCF5282_FLEXCAN_MBUF6_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00E9]))
2155#define MCF5282_FLEXCAN_MBUF6_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00EA]))
2156#define MCF5282_FLEXCAN_MBUF6_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00EB]))
2157#define MCF5282_FLEXCAN_MBUF6_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00EC]))
2158#define MCF5282_FLEXCAN_MBUF6_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00ED]))
2159#define MCF5282_FLEXCAN_MBUF7_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00F1]))
2160#define MCF5282_FLEXCAN_MBUF7_IDH (*(vuint16 *)(&__IPSBAR[0x1C00F2]))
2161#define MCF5282_FLEXCAN_MBUF7_IDL (*(vuint16 *)(&__IPSBAR[0x1C00F4]))
2162#define MCF5282_FLEXCAN_MBUF7_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00F6]))
2163#define MCF5282_FLEXCAN_MBUF7_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00F7]))
2164#define MCF5282_FLEXCAN_MBUF7_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00F8]))
2165#define MCF5282_FLEXCAN_MBUF7_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00F9]))
2166#define MCF5282_FLEXCAN_MBUF7_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00FA]))
2167#define MCF5282_FLEXCAN_MBUF7_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00FB]))
2168#define MCF5282_FLEXCAN_MBUF7_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00FC]))
2169#define MCF5282_FLEXCAN_MBUF7_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00FD]))
2170#define MCF5282_FLEXCAN_MBUF8_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0101]))
2171#define MCF5282_FLEXCAN_MBUF8_IDH (*(vuint16 *)(&__IPSBAR[0x1C0102]))
2172#define MCF5282_FLEXCAN_MBUF8_IDL (*(vuint16 *)(&__IPSBAR[0x1C0104]))
2173#define MCF5282_FLEXCAN_MBUF8_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0106]))
2174#define MCF5282_FLEXCAN_MBUF8_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0107]))
2175#define MCF5282_FLEXCAN_MBUF8_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0108]))
2176#define MCF5282_FLEXCAN_MBUF8_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0109]))
2177#define MCF5282_FLEXCAN_MBUF8_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C010A]))
2178#define MCF5282_FLEXCAN_MBUF8_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C010B]))
2179#define MCF5282_FLEXCAN_MBUF8_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C010C]))
2180#define MCF5282_FLEXCAN_MBUF8_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C010D]))
2181#define MCF5282_FLEXCAN_MBUF9_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0111]))
2182#define MCF5282_FLEXCAN_MBUF9_IDH (*(vuint16 *)(&__IPSBAR[0x1C0112]))
2183#define MCF5282_FLEXCAN_MBUF9_IDL (*(vuint16 *)(&__IPSBAR[0x1C0114]))
2184#define MCF5282_FLEXCAN_MBUF9_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0116]))
2185#define MCF5282_FLEXCAN_MBUF9_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0117]))
2186#define MCF5282_FLEXCAN_MBUF9_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0118]))
2187#define MCF5282_FLEXCAN_MBUF9_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0119]))
2188#define MCF5282_FLEXCAN_MBUF9_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C011A]))
2189#define MCF5282_FLEXCAN_MBUF9_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C011B]))
2190#define MCF5282_FLEXCAN_MBUF9_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C011C]))
2191#define MCF5282_FLEXCAN_MBUF9_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C011D]))
2192#define MCF5282_FLEXCAN_MBUF10_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0121]))
2193#define MCF5282_FLEXCAN_MBUF10_IDH (*(vuint16 *)(&__IPSBAR[0x1C0122]))
2194#define MCF5282_FLEXCAN_MBUF10_IDL (*(vuint16 *)(&__IPSBAR[0x1C0124]))
2195#define MCF5282_FLEXCAN_MBUF10_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0126]))
2196#define MCF5282_FLEXCAN_MBUF10_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0127]))
2197#define MCF5282_FLEXCAN_MBUF10_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0128]))
2198#define MCF5282_FLEXCAN_MBUF10_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0129]))
2199#define MCF5282_FLEXCAN_MBUF10_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C012A]))
2200#define MCF5282_FLEXCAN_MBUF10_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C012B]))
2201#define MCF5282_FLEXCAN_MBUF10_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C012C]))
2202#define MCF5282_FLEXCAN_MBUF10_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C012D]))
2203#define MCF5282_FLEXCAN_MBUF11_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0131]))
2204#define MCF5282_FLEXCAN_MBUF11_IDH (*(vuint16 *)(&__IPSBAR[0x1C0132]))
2205#define MCF5282_FLEXCAN_MBUF11_IDL (*(vuint16 *)(&__IPSBAR[0x1C0134]))
2206#define MCF5282_FLEXCAN_MBUF11_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0136]))
2207#define MCF5282_FLEXCAN_MBUF11_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0137]))
2208#define MCF5282_FLEXCAN_MBUF11_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0138]))
2209#define MCF5282_FLEXCAN_MBUF11_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0139]))
2210#define MCF5282_FLEXCAN_MBUF11_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C013A]))
2211#define MCF5282_FLEXCAN_MBUF11_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C013B]))
2212#define MCF5282_FLEXCAN_MBUF11_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C013C]))
2213#define MCF5282_FLEXCAN_MBUF11_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C013D]))
2214#define MCF5282_FLEXCAN_MBUF12_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0141]))
2215#define MCF5282_FLEXCAN_MBUF12_IDH (*(vuint16 *)(&__IPSBAR[0x1C0142]))
2216#define MCF5282_FLEXCAN_MBUF12_IDL (*(vuint16 *)(&__IPSBAR[0x1C0144]))
2217#define MCF5282_FLEXCAN_MBUF12_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0146]))
2218#define MCF5282_FLEXCAN_MBUF12_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0147]))
2219#define MCF5282_FLEXCAN_MBUF12_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0148]))
2220#define MCF5282_FLEXCAN_MBUF12_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0149]))
2221#define MCF5282_FLEXCAN_MBUF12_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C014A]))
2222#define MCF5282_FLEXCAN_MBUF12_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C014B]))
2223#define MCF5282_FLEXCAN_MBUF12_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C014C]))
2224#define MCF5282_FLEXCAN_MBUF12_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C014D]))
2225#define MCF5282_FLEXCAN_MBUF13_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0151]))
2226#define MCF5282_FLEXCAN_MBUF13_IDH (*(vuint16 *)(&__IPSBAR[0x1C0152]))
2227#define MCF5282_FLEXCAN_MBUF13_IDL (*(vuint16 *)(&__IPSBAR[0x1C0154]))
2228#define MCF5282_FLEXCAN_MBUF13_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0156]))
2229#define MCF5282_FLEXCAN_MBUF13_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0157]))
2230#define MCF5282_FLEXCAN_MBUF13_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0158]))
2231#define MCF5282_FLEXCAN_MBUF13_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0159]))
2232#define MCF5282_FLEXCAN_MBUF13_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C015A]))
2233#define MCF5282_FLEXCAN_MBUF13_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C015B]))
2234#define MCF5282_FLEXCAN_MBUF13_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C015C]))
2235#define MCF5282_FLEXCAN_MBUF13_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C015D]))
2236#define MCF5282_FLEXCAN_MBUF14_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0161]))
2237#define MCF5282_FLEXCAN_MBUF14_IDH (*(vuint16 *)(&__IPSBAR[0x1C0162]))
2238#define MCF5282_FLEXCAN_MBUF14_IDL (*(vuint16 *)(&__IPSBAR[0x1C0164]))
2239#define MCF5282_FLEXCAN_MBUF14_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0166]))
2240#define MCF5282_FLEXCAN_MBUF14_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0167]))
2241#define MCF5282_FLEXCAN_MBUF14_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0168]))
2242#define MCF5282_FLEXCAN_MBUF14_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0169]))
2243#define MCF5282_FLEXCAN_MBUF14_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C016A]))
2244#define MCF5282_FLEXCAN_MBUF14_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C016B]))
2245#define MCF5282_FLEXCAN_MBUF14_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C016C]))
2246#define MCF5282_FLEXCAN_MBUF14_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C016D]))
2247#define MCF5282_FLEXCAN_MBUF15_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0171]))
2248#define MCF5282_FLEXCAN_MBUF15_IDH (*(vuint16 *)(&__IPSBAR[0x1C0172]))
2249#define MCF5282_FLEXCAN_MBUF15_IDL (*(vuint16 *)(&__IPSBAR[0x1C0174]))
2250#define MCF5282_FLEXCAN_MBUF15_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0176]))
2251#define MCF5282_FLEXCAN_MBUF15_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0177]))
2252#define MCF5282_FLEXCAN_MBUF15_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0178]))
2253#define MCF5282_FLEXCAN_MBUF15_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0179]))
2254#define MCF5282_FLEXCAN_MBUF15_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C017A]))
2255#define MCF5282_FLEXCAN_MBUF15_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C017B]))
2256#define MCF5282_FLEXCAN_MBUF15_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C017C]))
2257#define MCF5282_FLEXCAN_MBUF15_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C017D]))
2258
2259#define MCF5282_FLEXCAN_MBUF0_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0086+(x))]))
2260#define MCF5282_FLEXCAN_MBUF1_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0096+(x))]))
2261#define MCF5282_FLEXCAN_MBUF2_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00A6+(x))]))
2262#define MCF5282_FLEXCAN_MBUF3_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00B6+(x))]))
2263#define MCF5282_FLEXCAN_MBUF4_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00C6+(x))]))
2264#define MCF5282_FLEXCAN_MBUF5_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00D6+(x))]))
2265#define MCF5282_FLEXCAN_MBUF6_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00E6+(x))]))
2266#define MCF5282_FLEXCAN_MBUF7_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00F6+(x))]))
2267#define MCF5282_FLEXCAN_MBUF8_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0106+(x))]))
2268#define MCF5282_FLEXCAN_MBUF9_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0116+(x))]))
2269#define MCF5282_FLEXCAN_MBUF10_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0126+(x))]))
2270#define MCF5282_FLEXCAN_MBUF11_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0136+(x))]))
2271#define MCF5282_FLEXCAN_MBUF12_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0146+(x))]))
2272#define MCF5282_FLEXCAN_MBUF13_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0156+(x))]))
2273#define MCF5282_FLEXCAN_MBUF14_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0166+(x))]))
2274#define MCF5282_FLEXCAN_MBUF15_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0176+(x))]))
2275
2276#define MCF5282_FLEXCAN_MBUF_BYTE(x,y) (*(vuint8 *)(&__IPSBAR[((0x1C0086+(0x10*(x))+(y))]))
2277
2278/* Bit level definitions and macros */
2279#define MCF5282_FLEXCAN_CANMCR_STOP (0x8000)
2280#define MCF5282_FLEXCAN_CANMCR_FRZ (0x4000)
2281#define MCF5282_FLEXCAN_CANMCR_HALT (0x1000)
2282#define MCF5282_FLEXCAN_CANMCR_NOTRDY (0x0800)
2283#define MCF5282_FLEXCAN_CANMCR_WAKEMSK (0x0400)
2284#define MCF5282_FLEXCAN_CANMCR_SOFTRST (0x0200)
2285#define MCF5282_FLEXCAN_CANMCR_FRZACK (0x0100)
2286#define MCF5282_FLEXCAN_CANMCR_SUPV (0x0080)
2287#define MCF5282_FLEXCAN_CANMCR_SELFWAKE (0x0040)
2288#define MCF5282_FLEXCAN_CANMCR_APS (0x0020)
2289
2290#define MCF5282_FLEXCAN_CANCTRL0_BOFFMSK (0x80)
2291#define MCF5282_FLEXCAN_CANCTRL0_ERRMSK (0x40)
2292#define MCF5282_FLEXCAN_CANCTRL0_RXMODE (0x04)
2293#define MCF5282_FLEXCAN_CANCTRL0_TXMODE_CMOSPOS (0x00)
2294#define MCF5282_FLEXCAN_CANCTRL0_TXMODE_CMOSNEG (0x01)
2295#define MCF5282_FLEXCAN_CANCTRL0_TXMODE_OPENDRAIN (0x02)
2296
2297#define MCF5282_FLEXCAN_CANCTRL1_SAMP (0x80)
2298#define MCF5282_FLEXCAN_CANCTRL1_TSYNC (0x20)
2299#define MCF5282_FLEXCAN_CANCTRL1_LBUF (0x10)
2300#define MCF5282_FLEXCAN_CANCTRL1_LOM (0x08)
2301#define MCF5282_FLEXCAN_CANCTRL1_PROPSEG(x) (((x)&0x07))
2302
2303#define MCF5282_FLEXCAN_CANCTRL2_RJW(x) (((x)&0x03)<<6)
2304#define MCF5282_FLEXCAN_CANCTRL2_PSEG1(x) (((x)&0x07)<<3)
2305#define MCF5282_FLEXCAN_CANCTRL2_PSEG2(x) (((x)&0x07)<<0)
2306
2307#define MCF5282_FLEXCAN_ESTAT_BITERR(x) (((x)&0x03)<<14)
2308#define MCF5282_FLEXCAN_ESTAT_ACKERR (0x2000)
2309#define MCF5282_FLEXCAN_ESTAT_CRCERR (0x1000)
2310#define MCF5282_FLEXCAN_ESTAT_FORMERR (0x0800)
2311#define MCF5282_FLEXCAN_ESTAT_STUFFERR (0x0400)
2312#define MCF5282_FLEXCAN_ESTAT_TXWARN (0x0200)
2313#define MCF5282_FLEXCAN_ESTAT_RXWARN (0x0100)
2314#define MCF5282_FLEXCAN_ESTAT_IDLE (0x0080)
2315#define MCF5282_FLEXCAN_ESTAT_TXRX (0x0040)
2316#define MCF5282_FLEXCAN_ESTAT_FCS(x) (((x)&0x03)<<4)
2317#define MCF5282_FLEXCAN_ESTAT_BOFFINT (0x0004)
2318#define MCF5282_FLEXCAN_ESTAT_ERRINT (0x0002)
2319#define MCF5282_FLEXCAN_ESTAT_WAKEINT (0x0001)
2320
2321#define MCF5282_FLEXCAN_IMASK_BUF15M (0x8000)
2322#define MCF5282_FLEXCAN_IMASK_BUF14M (0x4000)
2323#define MCF5282_FLEXCAN_IMASK_BUF13M (0x2000)
2324#define MCF5282_FLEXCAN_IMASK_BUF12M (0x1000)
2325#define MCF5282_FLEXCAN_IMASK_BUF11M (0x0800)
2326#define MCF5282_FLEXCAN_IMASK_BUF10M (0x0400)
2327#define MCF5282_FLEXCAN_IMASK_BUF9M (0x0200)
2328#define MCF5282_FLEXCAN_IMASK_BUF8M (0x0100)
2329#define MCF5282_FLEXCAN_IMASK_BUF7M (0x0080)
2330#define MCF5282_FLEXCAN_IMASK_BUF6M (0x0040)
2331#define MCF5282_FLEXCAN_IMASK_BUF5M (0x0020)
2332#define MCF5282_FLEXCAN_IMASK_BUF4M (0x0010)
2333#define MCF5282_FLEXCAN_IMASK_BUF3M (0x0008)
2334#define MCF5282_FLEXCAN_IMASK_BUF2M (0x0004)
2335#define MCF5282_FLEXCAN_IMASK_BUF1M (0x0002)
2336#define MCF5282_FLEXCAN_IMASK_BUF0M (0x0001)
2337
2338#define MCF5282_FLEXCAN_IFLAG_BUF15I (0x8000)
2339#define MCF5282_FLEXCAN_IFLAG_BUF14I (0x4000)
2340#define MCF5282_FLEXCAN_IFLAG_BUF13I (0x2000)
2341#define MCF5282_FLEXCAN_IFLAG_BUF12I (0x1000)
2342#define MCF5282_FLEXCAN_IFLAG_BUF11I (0x0800)
2343#define MCF5282_FLEXCAN_IFLAG_BUF10I (0x0400)
2344#define MCF5282_FLEXCAN_IFLAG_BUF9I (0x0200)
2345#define MCF5282_FLEXCAN_IFLAG_BUF8I (0x0100)
2346#define MCF5282_FLEXCAN_IFLAG_BUF7I (0x0080)
2347#define MCF5282_FLEXCAN_IFLAG_BUF6I (0x0040)
2348#define MCF5282_FLEXCAN_IFLAG_BUF5I (0x0020)
2349#define MCF5282_FLEXCAN_IFLAG_BUF4I (0x0010)
2350#define MCF5282_FLEXCAN_IFLAG_BUF3I (0x0008)
2351#define MCF5282_FLEXCAN_IFLAG_BUF2I (0x0004)
2352#define MCF5282_FLEXCAN_IFLAG_BUF1I (0x0002)
2353#define MCF5282_FLEXCAN_IFLAG_BUF0I (0x0001)
2354
2355/*********************************************************************
2356*
2357* ColdFire Flash Module (CFM)
2358*
2359*********************************************************************/
2360
2361/* Read/Write access macros for general use */
2362#define MCF5282_CFM_CFMMCR (*(vuint16 *)(&__IPSBAR[0x1D0000]))
2363#define MCF5282_CFM_CFMCLKD (*(vuint8 *)(&__IPSBAR[0x1D0002]))
2364#define MCF5282_CFM_CFMSEC (*(vuint32 *)(&__IPSBAR[0x1D0008]))
2365#define MCF5282_CFM_CFMPROT (*(vuint32 *)(&__IPSBAR[0x1D0010]))
2366#define MCF5282_CFM_CFMSACC (*(vuint32 *)(&__IPSBAR[0x1D0014]))
2367#define MCF5282_CFM_CFMDACC (*(vuint32 *)(&__IPSBAR[0x1D0018]))
2368#define MCF5282_CFM_CFMUSTAT (*(vuint8 *)(&__IPSBAR[0x1D0020]))
2369#define MCF5282_CFM_CFMCMD (*(vuint8 *)(&__IPSBAR[0x1D0024]))
2370#define MCF5282_CFM_CFMDISU (*(vuint16 *)(&__IPSBAR[0x1D0042]))
2371
2372/* Bit level definitions and macros */
2373#define MCF5282_CFM_FLASHBAR_BA(a) ((a)&0xFFF8000)
2374#define MCF5282_CFM_FLASHBAR_WP (0x00000100)
2375#define MCF5282_CFM_FLASHBAR_CI (0x00000020)
2376#define MCF5282_CFM_FLASHBAR_SC (0x00000010)
2377#define MCF5282_CFM_FLASHBAR_SD (0x00000008)
2378#define MCF5282_CFM_FLASHBAR_UC (0x00000004)
2379#define MCF5282_CFM_FLASHBAR_UD (0x00000002)
2380#define MCF5282_CFM_FLASHBAR_V (0x00000001)
2381
2382#define MCF5282_CFM_CFMMCR_LOCK (0x0400)
2383#define MCF5282_CFM_CFMMCR_PVIE (0x0200)
2384#define MCF5282_CFM_CFMMCR_AEIE (0x0100)
2385#define MCF5282_CFM_CFMMCR_CBEIE (0x0080)
2386#define MCF5282_CFM_CFMMCR_CCIE (0x0040)
2387#define MCF5282_CFM_CFMMCR_KEYACC (0x0020)
2388
2389#define MCF5282_CFM_CFMCLKD_DIVLD (0x80)
2390#define MCF5282_CFM_CFMCLKD_PRDIV8 (0x40)
2391#define MCF5282_CFM_CFMCLKD_DIV(x) (((x)&0x3F))
2392
2393#define MCF5282_CFM_CFMSEC_KEYEN (0x80000000)
2394#define MCF5282_CFM_CFMSEC_SECSTAT (0x40000000)
2395#define MCF5282_CFM_CFMSEC_SEC(x) (((x)&0xFFFF))
2396
2397#define MCF5282_CFM_CFMUSTAT_CBEIF (0x80)
2398#define MCF5282_CFM_CFMUSTAT_CCIF (0x40)
2399#define MCF5282_CFM_CFMUSTAT_PVIOL (0x20)
2400#define MCF5282_CFM_CFMUSTAT_ACCERR (0x10)
2401#define MCF5282_CFM_CFMUSTAT_BLANK (0x04)
2402
2403#define MCF5282_CFM_CFMCMD_CMD(x) (((x)&0x7F))
2404
2405/********************************************************************/
2406
2407#endif /* _CPU_MCF5282_H */
unsigned short int uint16 __attribute__((__may_alias__))
Disable IRQ Interrupts.
Definition: mcf5282.h:37
#define __IPSBAR
Definition: bsp.h:40
