RTEMS
5.2-rc1
bsps
arm
include
bsp
lpc-lcd.h
1
9
10
* Copyright (c) 2011 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Obere Lagerstr. 30
14
* 82178 Puchheim
15
* Germany
16
* <rtems@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef LIBBSP_ARM_SHARED_LPC_LCD_H
24
#define LIBBSP_ARM_SHARED_LPC_LCD_H
25
26
bsp/utility.h
27
28
#ifdef __cplusplus
29
extern
"C"
30
#endif
31
43
typedef
struct
44
uint8_t img [1024];
45
uint32_t ctrl;
46
uint32_t cfg;
47
uint32_t pal0;
48
uint32_t pal1;
49
uint32_t xy;
50
uint32_t clip;
51
uint32_t intmsk;
52
uint32_t intclr;
53
uint32_t intraw;
54
uint32_t intstat;
55
lpc_cursor
56
57
typedef
struct
58
uint32_t timh;
59
uint32_t timv;
60
uint32_t pol;
61
uint32_t le;
62
uint32_t upbase;
63
uint32_t lpbase;
64
uint32_t ctrl;
65
uint32_t intmsk;
66
uint32_t intraw;
67
uint32_t intstat;
68
uint32_t intclr;
69
uint32_t upcurr;
70
uint32_t lpcurr;
71
uint8_t reserved_0 [0x200 - 0x034];
72
uint16_t pal [256];
73
uint8_t reserved_1 [0x800 - 0x400];
74
lpc_cursor
crsr;
75
lpc_lcd
76
83
#define LCD_CFG_CLKDIV(val) BSP_FLD32(val, 0, 4)
84
#define LCD_CFG_HCLK_ENABLE BSP_BIT32(5)
85
#define LCD_CFG_MODE_SELECT(val) BSP_FLD32(val, 6, 7)
86
#define LCD_CFG_DISPLAY_TYPE BSP_BIT32(8)
87
96
#define LCD_TIMH_PPL(val) BSP_FLD32(val, 2, 7)
97
#define LCD_TIMH_PPL_GET(reg) BSP_FLD32GET(reg, 2, 7)
98
#define LCD_TIMH_HSW(val) BSP_FLD32(val, 8, 15)
99
#define LCD_TIMH_HSW_GET(reg) BSP_FLD32GET(reg, 8, 15)
100
#define LCD_TIMH_HFP(val) BSP_FLD32(val, 16, 23)
101
#define LCD_TIMH_HFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
102
#define LCD_TIMH_HBP(val) BSP_FLD32(val, 24, 31)
103
#define LCD_TIMH_HBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
104
113
#define LCD_TIMV_LPP(val) BSP_FLD32(val, 0, 9)
114
#define LCD_TIMV_LPP_GET(reg) BSP_FLD32GET(reg, 0, 9)
115
#define LCD_TIMV_VSW(val) BSP_FLD32(val, 10, 15)
116
#define LCD_TIMV_VSW_GET(reg) BSP_FLD32GET(reg, 10, 15)
117
#define LCD_TIMV_VFP(val) BSP_FLD32(val, 16, 23)
118
#define LCD_TIMV_VFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
119
#define LCD_TIMV_VBP(val) BSP_FLD32(val, 24, 31)
120
#define LCD_TIMV_VBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
121
130
#define LCD_POL_PCD_LO(val) BSP_FLD32(val, 0, 4)
131
#define LCD_POL_PCD_LO_GET(reg) BSP_FLD32GET(reg, 0, 4)
132
#define LCD_POL_CLKSEL BSP_BIT32(5)
133
#define LCD_POL_ACB(val) BSP_FLD32(val, 6, 10)
134
#define LCD_POL_ACB_GET(reg) BSP_FLD32GET(reg, 6, 10)
135
#define LCD_POL_IVS BSP_BIT32(11)
136
#define LCD_POL_IHS BSP_BIT32(12)
137
#define LCD_POL_IPC BSP_BIT32(13)
138
#define LCD_POL_IOE BSP_BIT32(14)
139
#define LCD_POL_CPL(val) BSP_FLD32(val, 16, 25)
140
#define LCD_POL_CPL_GET(reg) BSP_FLD32GET(reg, 16, 25)
141
#define LCD_POL_BCD BSP_BIT32(26)
142
#define LCD_POL_PCD_HI(val) BSP_FLD32(val, 27, 31)
143
#define LCD_POL_PCD_HI_GET(reg) BSP_FLD32GET(reg, 27, 31)
144
153
#define LCD_LE_LED(val) BSP_FLD32(val, 0, 6)
154
#define LCD_LE_LEE BSP_BIT32(16)
155
164
#define LCD_CTRL_LCDEN BSP_BIT32(0)
165
#define LCD_CTRL_LCDBPP(val) BSP_FLD32(val, 1, 3)
166
#define LCD_CTRL_LCDBPP_GET(reg) BSP_FLD32GET(reg, 1, 3)
167
#define LCD_CTRL_LCDBW BSP_BIT32(4)
168
#define LCD_CTRL_LCDTFT BSP_BIT32(5)
169
#define LCD_CTRL_LCDMONO8 BSP_BIT32(6)
170
#define LCD_CTRL_LCDDUAL BSP_BIT32(7)
171
#define LCD_CTRL_BGR BSP_BIT32(8)
172
#define LCD_CTRL_BEBO BSP_BIT32(9)
173
#define LCD_CTRL_BEPO BSP_BIT32(10)
174
#define LCD_CTRL_LCDPWR BSP_BIT32(11)
175
#define LCD_CTRL_LCDVCOMP(val) BSP_FLD32(val, 12, 13)
176
#define LCD_CTRL_LCDVCOMP_GET(reg) BSP_FLD32GET(reg, 12, 13)
177
#define LCD_CTRL_WATERMARK BSP_BIT32(16)
178
187
#define LCD_INT_FUF BSP_BIT32(1)
188
#define LCD_INT_LNBU BSP_BIT32(2)
189
#define LCD_INT_VCOMP BSP_BIT32(3)
190
#define LCD_INT_BER BSP_BIT32(4)
191
200
#define LCD_PAL_R(val) BSP_FLD16(val, 0, 4)
201
#define LCD_PAL_G(val) BSP_FLD16(val, 5, 9)
202
#define LCD_PAL_B(val) BSP_FLD16(val, 10, 14)
203
#define LCD_PAL_I BSP_BIT16(15)
204
209
#ifdef __cplusplus
210
211
#endif
/* __cplusplus */
212
213
#endif
/* LIBBSP_ARM_SHARED_LPC_LCD_H */
utility.h
Utility macros.
lpc_cursor
Definition:
lpc-lcd.h:43
lpc_lcd
Definition:
lpc-lcd.h:57
