RTEMS 5.2-rc1
lpc-i2s.h
1
9/*
10 * Copyright (c) 2010 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_SHARED_LPC_I2S_H
24#define LIBBSP_ARM_SHARED_LPC_I2S_H
25
26#include <bsp/utility.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
46typedef struct {
47 uint32_t dao;
48 uint32_t dai;
49 uint32_t txfifo;
50 uint32_t rxfifo;
51 uint32_t state;
52 uint32_t dma [2];
53 uint32_t irq;
54 uint32_t txrate;
55 uint32_t rxrate;
56} lpc_i2s;
57
64#define I2S_DAIO_WORDWIDTH(val) BSP_FLD32(val, 0, 1)
65#define I2S_DAIO_MONO BSP_BIT32(2)
66#define I2S_DAIO_STOP BSP_BIT32(3)
67#define I2S_DAIO_RESET BSP_BIT32(4)
68#define I2S_DAIO_WS_SEL BSP_BIT32(5)
69#define I2S_DAIO_WS_HALFPERIOD(val) BSP_FLD32(val, 6, 14)
70#define I2S_DAIO_MUTE BSP_BIT32(15)
71
80#define I2S_STATE_IRQ BSP_BIT32(0)
81#define I2S_STATE_DMAREQ_0 BSP_BIT32(1)
82#define I2S_STATE_DMAREQ_1 BSP_BIT32(2)
83#define I2S_STATE_RX_LEVEL_GET(reg) BSP_FLD32GET(reg, 8, 11)
84#define I2S_STATE_TX_LEVEL_GET(reg) BSP_FLD32GET(reg, 16, 19)
85
94#define I2S_DMA_RX_ENABLE BSP_BIT32(0)
95#define I2S_DMA_TX_ENABLE BSP_BIT32(1)
96#define I2S_DMA_RX_DEPTH(val) BSP_FLD32(val, 8, 11)
97#define I2S_DMA_TX_DEPTH(val) BSP_FLD32(val, 16, 19)
98
107#define I2S_IRQ_RX BSP_BIT32(0)
108#define I2S_IRQ_TX BSP_BIT32(1)
109#define I2S_IRQ_RX_DEPTH(val) BSP_FLD32(val, 8, 11)
110#define I2S_IRQ_TX_DEPTH(val) BSP_FLD32(val, 16, 19)
111
120#define LPC24XX_I2S_RATE(val) BSP_FLD32(val, 0, 9)
121#define LPC32XX_I2S_RATE_X_DIVIDER(val) BSP_FLD32(val, 0, 7)
122#define LPC32XX_I2S_RATE_Y_DIVIDER(val) BSP_FLD32(val, 8, 15)
123
128#ifdef __cplusplus
129}
130#endif /* __cplusplus */
131
132#endif /* LIBBSP_ARM_SHARED_LPC_I2S_H */
Utility macros.
I2S control block.
Definition: lpc-i2s.h:46
