RTEMS 5.2-rc1
lm3s69xx.h
1
9/*
10 * Copyright © 2013 Eugeniy Meshcheryakov <eugen@debian.org>
11 *
12 * Copyright (c) 2011 Sebastian Huber. All rights reserved.
13 *
14 * embedded brains GmbH
15 * Obere Lagerstr. 30
16 * 82178 Puchheim
17 * Germany
18 * <rtems@embedded-brains.de>
19 *
20 * The license and distribution terms for this file may be
21 * found in the file LICENSE in this distribution or at
22 * http://www.rtems.org/license/LICENSE.
23 */
24
25#ifndef LIBBSP_ARM_LM3S69XX_LM3S69XX_H
26#define LIBBSP_ARM_LM3S69XX_LM3S69XX_H
27#include <bspopts.h>
28#include <bsp/utility.h>
29
38#define LM3S69XX_SYSCON_BASE 0x400fe000
39
40#define LM3S69XX_UART_0_BASE 0x4000c000
41#define LM3S69XX_UART_1_BASE 0x4000d000
42#define LM3S69XX_UART_2_BASE 0x4000e000
43
44#ifdef LM3S69XX_USE_AHB_FOR_GPIO
45#define LM3S69XX_GPIO_A_BASE 0x40058000
46#define LM3S69XX_GPIO_B_BASE 0x40059000
47#define LM3S69XX_GPIO_C_BASE 0x4005a000
48#define LM3S69XX_GPIO_D_BASE 0x4005b000
49#define LM3S69XX_GPIO_E_BASE 0x4005c000
50#define LM3S69XX_GPIO_F_BASE 0x4005d000
51#if LM3S69XX_NUM_GPIO_BLOCKS > 6
52#define LM3S69XX_GPIO_G_BASE 0x4005e000
53#if LM3S69XX_NUM_GPIO_BLOCKS > 7
54#define LM3S69XX_GPIO_H_BASE 0x4005f000
55#endif
56#endif
57
58#define LM3S69XX_GPIO(port) ((volatile lm3s69xx_gpio *)(LM3S69XX_GPIO_A_BASE + (port) * 0x1000))
59#else /* LM3S69XX_USE_AHB_FOR_GPIO */
60#define LM3S69XX_GPIO_A_BASE 0x40004000
61#define LM3S69XX_GPIO_B_BASE 0x40005000
62#define LM3S69XX_GPIO_C_BASE 0x40006000
63#define LM3S69XX_GPIO_D_BASE 0x40007000
64#define LM3S69XX_GPIO_E_BASE 0x40024000
65#define LM3S69XX_GPIO_F_BASE 0x40025000
66#if LM3S69XX_NUM_GPIO_BLOCKS > 6
67#define LM3S69XX_GPIO_G_BASE 0x40026000
68#if LM3S69XX_NUM_GPIO_BLOCKS > 7
69#define LM3S69XX_GPIO_H_BASE 0x40027000
70#endif
71#endif
72
73#define LM3S69XX_GPIO(port) ((volatile lm3s69xx_gpio *)(((port) < 4) ? \
74 (LM3S69XX_GPIO_A_BASE + (port) * 0x1000) : \
75 (LM3S69XX_GPIO_E_BASE + ((port) - 4) * 0x1000)))
76#endif /* LM3S69XX_USE_AHB_FOR_GPIO */
77
78#define LM3S69XX_SSI_0_BASE 0x40008000
79#if LM3S69XX_NUM_SSI_BLOCKS > 1
80#define LM3S69XX_SSI_1_BASE 0x40009000
81#if LM3S69XX_NUM_SSI_BLOCKS > 2
82#define LM3S69XX_SSI_2_BASE 0x4000A000
83#if LM3S69XX_NUM_SSI_BLOCKS > 3
84#define LM3S69XX_SSI_3_BASE 0x4000B000
85#endif
86#endif
87#endif
88
89#define LM3S69XX_SYSCON ((volatile lm3s69xx_syscon *)LM3S69XX_SYSCON_BASE)
90
91#define LM3S69XX_PLL_FREQUENCY 400000000U
92
93typedef struct {
94 uint32_t data[256]; /* Masked data registers are included here. */
95 uint32_t dir;
96 uint32_t is;
97 uint32_t ibe;
98 uint32_t iev;
99 uint32_t im;
100 uint32_t ris;
101 uint32_t mis;
102 uint32_t icr;
103 uint32_t afsel;
104
105 uint32_t reserved_0[55];
106
107 uint32_t dr2r;
108 uint32_t dr4r;
109 uint32_t dr8r;
110 uint32_t odr;
111 uint32_t pur;
112 uint32_t pdr;
113 uint32_t slr;
114 uint32_t den;
115 uint32_t lock;
116 uint32_t cr;
117 uint32_t amsel;
119
120typedef struct {
121 uint32_t did0;
122 uint32_t did1;
123
124 uint32_t dc0;
125 uint32_t reserved_0;
126 uint32_t dc1;
127 uint32_t dc2;
128 uint32_t dc3;
129 uint32_t dc4;
130 uint32_t dc5;
131 uint32_t dc6;
132 uint32_t dc7;
133
134 uint32_t reserved_1;
135
136#define SYSCONPBORCTL_BORIOR BSP_BIT32(1)
137 uint32_t pborctl;
138
139#define SYSCONLDOPCTL_VADJ(val) BSP_FLD32(val, 0, 5)
140#define SYSCONLDOPCTL_VADJ_MASK BSP_MSK32(0, 5)
141 uint32_t ldopctl;
142
143 uint32_t reserved_2[2];
144
145 uint32_t srcr0;
146 uint32_t srcr1;
147 uint32_t srcr2;
148
149 uint32_t reserved_3;
150
151#define SYSCONRIS_MOSCPUPRIS BSP_BIT32(8)
152#define SYSCONRIS_USBPLLRIS BSP_BIT32(7)
153#define SYSCONRIS_PLLLRIS BSP_BIT32(6)
154#define SYSCONRIS_BORRIS BSP_BIT32(1)
155 uint32_t ris;
156
157#define SYSCONIMC_MOSCPUPIM BSP_BIT32(8)
158#define SYSCONIMC_USBPLLLIM BSP_BIT32(7)
159#define SYSCONIMC_PLLLIM BSP_BIT32(6)
160#define SYSCONIMC_BORIM BSP_BIT32(1)
161 uint32_t imc;
162
163#define SYSCONMISC_MOSCPUPMIS BSP_BIT32(8)
164#define SYSCONMISC_USBPLLLMIS BSP_BIT32(7)
165#define SYSCONMISC_PLLLMIS BSP_BIT32(6)
166#define SYSCONMISC_BORMIS BSP_BIT32(1)
167 uint32_t misc;
168
169#define SYSCONRESC_MOSCFAIL BSP_BIT32(16)
170#define SYSCONRESC_SW BSP_BIT32(4)
171#define SYSCONRESC_WDT BSP_BIT32(3)
172#define SYSCONRESC_BOR BSP_BIT32(2)
173#define SYSCONRESC_POR BSP_BIT32(1)
174#define SYSCONRESC_EXT BSP_BIT32(0)
175 uint32_t resc;
176
177#define SYSCONRCC_AGC BSP_BIT32(27)
178#define SYSCONRCC_SYSDIV(val) BSP_FLD32(val, 23, 26)
179#define SYSCONRCC_SYSDIV_MSK BSP_MSK32(23, 26)
180#define SYSCONRCC_USESYSDIV BSP_BIT32(22)
181#define SYSCONRCC_USEPWMDIV BSP_BIT32(20)
182#define SYSCONRCC_PWMDIV(val) BSP_FLD32(val, 17, 19)
183#define SYSCONRCC_PWMDIV_DIV2_VAL 0
184#define SYSCONRCC_PWMDIV_DIV4_VAL 1
185#define SYSCONRCC_PWMDIV_DIV8_VAL 2
186#define SYSCONRCC_PWMDIV_DIV16_VAL 3
187#define SYSCONRCC_PWMDIV_DIV32_VAL 4
188#define SYSCONRCC_PWMDIV_DIV64_VAL 5
189#define SYSCONRCC_PWMDIV_MSK BSP_MSK32(17, 19)
190#define SYSCONRCC_PWRDN BSP_BIT32(13)
191#define SYSCONRCC_BYPASS BSP_BIT32(11)
192#define SYSCONRCC_XTAL(val) BSP_FLD32(val, 6, 10)
193#define SYSCONRCC_XTAL_MSK BSP_MSK32(6, 10)
194#define SYSCONRCC_OSCSRC(val) BSP_FLD32(val, 4, 5)
195#define SYSCONRCC_OSCSRC_MOSC SYSCONRCC_OSCSRC(0x0)
196#define SYSCONRCC_OSCSRC_IOSC SYSCONRCC_OSCSRC(0x1)
197#define SYSCONRCC_OSCSRC_IOSC_DIV_4 SYSCONRCC_OSCSRC(0x2)
198#define SYSCONRCC_OSCSRC_30KHZ SYSCONRCC_OSCSRC(0x3)
199#define SYSCONRCC_OSCSRC_MSK BSP_MSK32(4, 5)
200#define SYSCONRCC_IOSCDIS BSP_BIT32(1)
201#define SYSCONRCC_MOSCDIS BSP_BIT32(0)
202 uint32_t rcc;
203
204#define SYSCONPLLCFG_F(val) BSP_FLD32(val, 5, 13)
205#define SYSCONPLLCFG_F_MSK BSP_MSK32(5, 13)
206#define SYSCONPLLCFG_R(val) BSP_FLD32(val, 0, 4)
207#define SYSCONPLLCFG_R_MSK BSP_MSK32(0, 4)
208 uint32_t pllcfg;
209
210 uint32_t reserved_4;
211
212#define SYSCONGPIOHBCTL_PORTH BSP_BIT32(7)
213#define SYSCONGPIOHBCTL_PORTG BSP_BIT32(6)
214#define SYSCONGPIOHBCTL_PORTF BSP_BIT32(5)
215#define SYSCONGPIOHBCTL_PORTE BSP_BIT32(4)
216#define SYSCONGPIOHBCTL_PORTD BSP_BIT32(3)
217#define SYSCONGPIOHBCTL_PORTC BSP_BIT32(2)
218#define SYSCONGPIOHBCTL_PORTB BSP_BIT32(1)
219#define SYSCONGPIOHBCTL_PORTA BSP_BIT32(0)
220 uint32_t gpiohbctl;
221
222#define SYSCONRCC2_USERCC2 BSP_BIT32(31)
223#define SYSCONRCC2_DIV400 BSP_BIT32(30)
224#define SYSCONRCC2_SYSDIV2(val) BSP_FLD32(val, 23, 28)
225#define SYSCONRCC2_SYSDIV2_MSK BSP_MSK32(23, 28)
226#define SYSCONRCC2_SYSDIV2EXT(val) BSP_FLD32(val, 22, 28)
227#define SYSCONRCC2_SYSDIV2EXT_MSK BSP_MSK32(22, 28)
228#define SYSCONRCC2_USBPWRDN BSP_BIT32(14)
229#define SYSCONRCC2_PWRDN2 BSP_BIT32(13)
230#define SYSCONRCC2_BYPASS2 BSP_BIT32(11)
231#define SYSCONRCC2_OSCSRC2(val) BSP_FLD32(val, 4, 6)
232#define SYSCONRCC2_OSCSRC2_MSK BSP_MSK32(4, 6)
233 uint32_t rcc2;
234
235 uint32_t reserved_5[2];
236
237#define SYSCONMOSCCTL_CVAL BSP_BIT32(0)
238 uint32_t moscctl;
239
240 uint32_t reserved_6[32];
241
242#define SYSCONRCGC0_PWM BSP_BIT32(20)
243#define SYSCONRCGC0_ADC BSP_BIT32(16)
244#define SYSCONRCGC0_MAXADCSPD(val) BSP_FLD32(val, 8, 9)
245#define SYSCONRCGC0_MAXADCSPD_MSK BSP_MSK32(8, 9)
246#define SYSCONRCGC0_HIB BSP_BIT32(6)
247#define SYSCONRCGC0_WDT BSP_BIT32(3)
248 uint32_t rcgc0;
249
250#define SYSCONRCGC1_COMP1 BSP_BIT32(25)
251#define SYSCONRCGC1_COMP0 BSP_BIT32(24)
252#define SYSCONRCGC1_TIMER3 BSP_BIT32(19)
253#define SYSCONRCGC1_TIMER2 BSP_BIT32(18)
254#define SYSCONRCGC1_TIMER1 BSP_BIT32(17)
255#define SYSCONRCGC1_TIMER0 BSP_BIT32(16)
256#define SYSCONRCGC1_I2C1 BSP_BIT32(14)
257#define SYSCONRCGC1_I2C0 BSP_BIT32(12)
258#define SYSCONRCGC1_QEI0 BSP_BIT32(8)
259#if LM3S69XX_NUM_SSI_BLOCKS > 1
260#define SYSCONRCGC1_SSI1 BSP_BIT32(5)
261#endif
262#define SYSCONRCGC1_SSI0 BSP_BIT32(4)
263#define SYSCONRCGC1_UART2 BSP_BIT32(2)
264#define SYSCONRCGC1_UART1 BSP_BIT32(1)
265#define SYSCONRCGC1_UART0 BSP_BIT32(0)
266 uint32_t rcgc1;
267
268#define SYSCONRCGC2_USB0 BSP_BIT32(16)
269#define SYSCONRCGC2_UDMA BSP_BIT32(13)
270#if LM3S69XX_NUM_GPIO_BLOCKS > 7
271#define SYSCONRCGC2_GPIOH BSP_BIT32(7)
272#endif
273#define SYSCONRCGC2_GPIOG BSP_BIT32(6)
274#define SYSCONRCGC2_GPIOF BSP_BIT32(5)
275#define SYSCONRCGC2_GPIOE BSP_BIT32(4)
276#define SYSCONRCGC2_GPIOD BSP_BIT32(3)
277#define SYSCONRCGC2_GPIOC BSP_BIT32(2)
278#define SYSCONRCGC2_GPIOB BSP_BIT32(1)
279#define SYSCONRCGC2_GPIOA BSP_BIT32(0)
280 uint32_t rcgc2;
281
282 uint32_t reserved_7;
283
284 uint32_t scgc0;
285 uint32_t scgc1;
286 uint32_t scgc2;
287
288 uint32_t reserved_8;
289
290 uint32_t dcgc0;
291 uint32_t dcgc1;
292 uint32_t dcgc2;
293
294 uint32_t reserved_9[6];
295
296#define SYSCONDSLPCLKCFG_DSDIVORIDE(val) BSP_FLD32(val, 23, 28)
297#define SYSCONDSLPCLKCFG_DSDIVORIDE_MSK BSP_MSK32(23, 28)
298#define SYSCONDSLPCLKCFG_DSOSCSRC(val) BSP_FLD32(val, 4, 6)
299#define SYSCONDSLPCLKCFG_DSOSCSRC_MSK BSP_MSK32(4, 6)
300 uint32_t dslpclkcfg;
302
303typedef struct {
304#define UARTDR_OE BSP_BIT32(11)
305#define UARTDR_BE BSP_BIT32(10)
306#define UARTDR_PE BSP_BIT32(9)
307#define UARTDR_FE BSP_BIT32(8)
308#define UARTDR_ERROR_MSK BSP_MSK32(8, 11)
309#define UARTDR_DATA(val) BSP_FLD32(val, 0, 7)
310#define UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
311 uint32_t dr;
312
313 uint32_t rsr_ecr;
314 uint32_t reserved_0[4];
315
316#define UARTFR_TXFE BSP_BIT32(7)
317#define UARTFR_RXFF BSP_BIT32(6)
318#define UARTFR_TXFF BSP_BIT32(5)
319#define UARTFR_RXFE BSP_BIT32(4)
320#define UARTFR_BUSY BSP_BIT32(3)
321 uint32_t fr;
322
323 uint32_t reserved_1;
324
325 uint32_t ilpr;
326 uint32_t ibrd;
327 uint32_t fbrd;
328
329#define UARTLCRH_SPS BSP_BIT32(7)
330#define UARTLCRH_WLEN(val) BSP_FLD32(val, 5, 6)
331#define UARTLCRH_FEN BSP_BIT32(4)
332#define UARTLCRH_STP2 BSP_BIT32(3)
333#define UARTLCRH_EPS BSP_BIT32(2)
334#define UARTLCRH_PEN BSP_BIT32(1)
335#define UARTLCRH_BRK BSP_BIT32(0)
336 uint32_t lcrh;
337
338#define UARTCTL_RXE BSP_BIT32(9)
339#define UARTCTL_TXE BSP_BIT32(8)
340#define UARTCTL_LBE BSP_BIT32(7)
341#define UARTCTL_SIRLP BSP_BIT32(2)
342#define UARTCTL_SIREN BSP_BIT32(1)
343#define UARTCTL_UARTEN BSP_BIT32(0)
344 uint32_t ctl;
345
346#define UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)
347#define UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)
348 uint32_t ifls;
349
350#define UARTI_OE BSP_BIT32(10)
351#define UARTI_BE BSP_BIT32(9)
352#define UARTI_PE BSP_BIT32(8)
353#define UARTI_FE BSP_BIT32(7)
354#define UARTI_RT BSP_BIT32(6)
355#define UARTI_TX BSP_BIT32(5)
356#define UARTI_RX BSP_BIT32(4)
357 uint32_t im;
358 uint32_t ris;
359 uint32_t mis;
360 uint32_t icr;
361#if LM3S69XX_HAS_UDMA
362 uint32_t dmactl;
363#endif
365
366typedef struct {
367#define SSICR0_SCR(val) BSP_FLD32(val, 8, 15)
368#define SSICR0_SPH BSP_BIT32(7)
369#define SSICR0_SPO BSP_BIT32(6)
370#define SSICR0_FRF(val) BSP_FLD32(val, 4, 5)
371#define SSICR0_DSS(val) BSP_FLD32(val, 0, 3)
372 uint32_t cr0;
373
374#define SSICR1_SOD BSP_BIT32(3)
375#define SSICR1_MS BSP_BIT32(2)
376#define SSICR1_SSE BSP_BIT32(1)
377#define SSICR1_LBM BSP_BIT32(0)
378 uint32_t cr1;
379 uint32_t dr;
380
381#define SSISR_BSY BSP_BIT32(4)
382#define SSISR_RFF BSP_BIT32(3)
383#define SSISR_RNE BSP_BIT32(2)
384#define SSISR_TNF BSP_BIT32(1)
385#define SSISR_TFE BSP_BIT32(0)
386 uint32_t sr;
387
388#define SSI_CPSRDIV(val) BSP_FLD32(val, 0, 7)
389 uint32_t cpsr;
390
391#define SSII_TX BSP_BIT32(3)
392#define SSII_RX BSP_BIT32(2)
393#define SSII_RT BSP_BIT32(1)
394#define SSII_ROR BSP_BIT32(0)
395 uint32_t im;
396 uint32_t ris;
397 uint32_t mis;
398 uint32_t icr;
399
400#if LM3S69XX_HAS_UDMA
401#define SSIDMACTL_TXDMAE BSP_BIT32(1)
402#define SSIDMACTL_RXDMAE BSP_BIT32(0)
403 uint32_t dmactl;
404#endif /* LM3S69XX_HAS_UDMA */
406
407#endif /* LIBBSP_ARM_LM3S69XX_LM3S69XX_H */
Utility macros.
Definition: lm3s69xx.h:93
Definition: lm3s69xx.h:366
Definition: lm3s69xx.h:120
Definition: lm3s69xx.h:303
