RTEMS 5.2-rc1
linkersets.h
1/*
2 * Copyright (c) 2015, 2020 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <rtems@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef _RTEMS_LINKERSET_H
16#define _RTEMS_LINKERSET_H
17
19
20#ifdef __cplusplus
21extern "C" {
22#endif /* __cplusplus */
23
24#define RTEMS_LINKER_SET_BEGIN( set ) \
25 _Linker_set_##set##_begin
26
27#define RTEMS_LINKER_SET_END( set ) \
28 _Linker_set_##set##_end
29
30#define RTEMS_LINKER_ROSET_DECLARE( set, type ) \
31 extern type const RTEMS_LINKER_SET_BEGIN( set )[]; \
32 extern type const RTEMS_LINKER_SET_END( set )[]
33
34#define RTEMS_LINKER_ROSET( set, type ) \
35 type const RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
36 RTEMS_SECTION( ".rtemsroset." #set ".begin" ) RTEMS_USED; \
37 type const RTEMS_LINKER_SET_END( set )[ 0 ] \
38 RTEMS_SECTION( ".rtemsroset." #set ".end" ) RTEMS_USED
39
40#define RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE( set, type, item, order ) \
41 extern type const _Linker_set_##set##_##item \
42 RTEMS_SECTION( ".rtemsroset." #set ".content.0." RTEMS_XSTRING( order ) )
43
44#define RTEMS_LINKER_ROSET_ITEM_DECLARE( set, type, item ) \
45 extern type const _Linker_set_##set##_##item \
46 RTEMS_SECTION( ".rtemsroset." #set ".content.1" )
47
48#define RTEMS_LINKER_ROSET_ITEM_REFERENCE( set, type, item ) \
49 static type const * const _Set_reference_##set##_##item \
50 RTEMS_SECTION( ".rtemsroset.reference" ) RTEMS_USED = \
51 &_Linker_set_##set##_##item
52
53#define RTEMS_LINKER_ROSET_ITEM_ORDERED( set, type, item, order ) \
54 type const _Linker_set_##set##_##item \
55 RTEMS_SECTION( ".rtemsroset." #set ".content.0." RTEMS_XSTRING( order ) ) \
56 RTEMS_USED
57
58#define RTEMS_LINKER_ROSET_ITEM( set, type, item ) \
59 type const _Linker_set_##set##_##item \
60 RTEMS_SECTION( ".rtemsroset." #set ".content.1" ) RTEMS_USED
61
62#define RTEMS_LINKER_ROSET_CONTENT( set, decl ) \
63 decl \
64 RTEMS_SECTION( ".rtemsroset." #set ".content" )
65
66#define RTEMS_LINKER_RWSET_DECLARE( set, type ) \
67 extern type RTEMS_LINKER_SET_BEGIN( set )[]; \
68 extern type RTEMS_LINKER_SET_END( set )[]
69
70#define RTEMS_LINKER_RWSET( set, type ) \
71 type RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
72 RTEMS_SECTION( ".rtemsrwset." #set ".begin" ) RTEMS_USED; \
73 type RTEMS_LINKER_SET_END( set )[ 0 ] \
74 RTEMS_SECTION( ".rtemsrwset." #set ".end" ) RTEMS_USED
75
76#define RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE( set, type, item, order ) \
77 extern type _Linker_set_##set##_##item \
78 RTEMS_SECTION( ".rtemsrwset." #set ".content.0." RTEMS_XSTRING( order ) )
79
80#define RTEMS_LINKER_RWSET_ITEM_DECLARE( set, type, item ) \
81 extern type _Linker_set_##set##_##item \
82 RTEMS_SECTION( ".rtemsrwset." #set ".content.1" )
83
84/*
85 * The .rtemsroset is here not a typo. We must ensure that the references are
86 * not a victim of the garbage collection of the linker. Thus, we place them
87 * in a dedicated area of the RTEMS read-only linker set section.
88 */
89#define RTEMS_LINKER_RWSET_ITEM_REFERENCE( set, type, item ) \
90 static type * const _Set_reference_##set##_##item \
91 RTEMS_SECTION( ".rtemsroset.reference" ) RTEMS_USED = \
92 &_Linker_set_##set##_##item
93
94#define RTEMS_LINKER_RWSET_ITEM_ORDERED( set, type, item, order ) \
95 type _Linker_set_##set##_##item \
96 RTEMS_SECTION( ".rtemsrwset." #set ".content.0." RTEMS_XSTRING( order ) ) \
97 RTEMS_USED
98
99#define RTEMS_LINKER_RWSET_ITEM( set, type, item ) \
100 type _Linker_set_##set##_##item \
101 RTEMS_SECTION( ".rtemsrwset." #set ".content.1" ) RTEMS_USED
102
103#define RTEMS_LINKER_RWSET_CONTENT( set, decl ) \
104 decl \
105 RTEMS_SECTION( ".rtemsrwset." #set ".content" )
106
107RTEMS_INLINE_ROUTINE uintptr_t _Linker_set_Obfuscate( const void *ptr )
108{
109 uintptr_t addr;
110
111 addr = (uintptr_t) ptr;
113
114 return addr;
115}
116
117#define RTEMS_LINKER_SET_SIZE( set ) \
118 ( _Linker_set_Obfuscate( RTEMS_LINKER_SET_END( set ) ) \
119 - _Linker_set_Obfuscate( RTEMS_LINKER_SET_BEGIN( set ) ) )
120
121#define RTEMS_LINKER_SET_ITEM_COUNT( set ) \
122 ( RTEMS_LINKER_SET_SIZE( set ) \
123 / sizeof( RTEMS_LINKER_SET_BEGIN( set )[ 0 ] ) )
124
125#define RTEMS_LINKER_SET_IS_EMPTY( set ) \
126 ( RTEMS_LINKER_SET_SIZE( set ) == 0 )
127
128#define RTEMS_LINKER_SET_FOREACH( set, item ) \
129 for ( \
130 item = (void *) _Linker_set_Obfuscate( RTEMS_LINKER_SET_BEGIN( set ) ) ; \
131 item != RTEMS_LINKER_SET_END( set ) ; \
132 ++item \
133 )
134
135#ifdef __cplusplus
136}
137#endif /* __cplusplus */
138
139#endif /* _RTEMS_LINKERSET_H */
Basic Definitions.
#define RTEMS_OBFUSCATE_VARIABLE(_var)
Obfuscates the variable so that the compiler cannot perform optimizations based on the variable value...
Definition: basedefs.h:311
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
