RTEMS 5.2-rc1
intr.h
1
10/* COPYRIGHT (c) 1989-2013.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_RTEMS_INTR_H
19#define _RTEMS_RTEMS_INTR_H
20
21#include <rtems/rtems/status.h>
22#include <rtems/score/isr.h>
23#include <rtems/score/isrlock.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
43
48
53
54#if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
55
56typedef ISR_Handler_entry rtems_isr_entry;
57
58#else
64typedef rtems_isr ( *rtems_isr_entry )(
66 );
67
82rtems_status_code rtems_interrupt_catch(
83 rtems_isr_entry new_isr_handler,
85 rtems_isr_entry *old_isr_handler
86);
87#endif
88
89#if !defined(RTEMS_SMP)
90
99#define rtems_interrupt_disable( _isr_cookie ) \
100 _ISR_Local_disable(_isr_cookie)
101
110#define rtems_interrupt_enable( _isr_cookie ) \
111 _ISR_Local_enable(_isr_cookie)
112
122#define rtems_interrupt_flash( _isr_cookie ) \
123 _ISR_Local_flash(_isr_cookie)
124
125#endif /* RTEMS_SMP */
126
138#define rtems_interrupt_local_disable( _isr_cookie ) \
139 _ISR_Local_disable( _isr_cookie )
140
148#define rtems_interrupt_local_enable( _isr_cookie ) \
149 _ISR_Local_enable( _isr_cookie )
150
158#define rtems_interrupt_is_in_progress() \
159 _ISR_Is_in_progress()
160
166#define rtems_interrupt_cause( _interrupt_to_cause )
167
173#define rtems_interrupt_clear( _interrupt_to_clear )
174
196
201
209#define RTEMS_INTERRUPT_LOCK_MEMBER( _designator ) \
210 ISR_LOCK_MEMBER( _designator )
211
220#define RTEMS_INTERRUPT_LOCK_DECLARE( _qualifier, _designator ) \
221 ISR_LOCK_DECLARE( _qualifier, _designator )
222
233#define RTEMS_INTERRUPT_LOCK_DEFINE( _qualifier, _designator, _name ) \
234 ISR_LOCK_DEFINE( _qualifier, _designator, _name )
235
244#define RTEMS_INTERRUPT_LOCK_REFERENCE( _designator, _target ) \
245 ISR_LOCK_REFERENCE( _designator, _target )
246
253#define RTEMS_INTERRUPT_LOCK_INITIALIZER( _name ) ISR_LOCK_INITIALIZER( _name )
254
265#define rtems_interrupt_lock_initialize( _lock, _name ) \
266 _ISR_lock_Initialize( _lock, _name )
267
275#define rtems_interrupt_lock_destroy( _lock ) \
276 _ISR_lock_Destroy( _lock )
277
288#define rtems_interrupt_lock_interrupt_disable( _lock_context ) \
289 _ISR_lock_ISR_disable( _lock_context )
290
305#define rtems_interrupt_lock_acquire( _lock, _lock_context ) \
306 _ISR_lock_ISR_disable_and_acquire( _lock, _lock_context )
307
322#define rtems_interrupt_lock_release( _lock, _lock_context ) \
323 _ISR_lock_Release_and_ISR_enable( _lock, _lock_context )
324
342#if defined(RTEMS_SMP)
343 #define rtems_interrupt_lock_acquire_isr( _lock, _lock_context ) \
344 _SMP_lock_Acquire( \
345 &( _lock )->Lock, \
346 &( _lock_context )->Lock_context \
347 )
348#else
349 #define rtems_interrupt_lock_acquire_isr( _lock, _lock_context ) \
350 do { (void) _lock_context; } while ( 0 )
351#endif
352
366#if defined(RTEMS_SMP)
367 #define rtems_interrupt_lock_release_isr( _lock, _lock_context ) \
368 _SMP_lock_Release( \
369 &( _lock )->Lock, \
370 &( _lock_context )->Lock_context \
371 )
372#else
373 #define rtems_interrupt_lock_release_isr( _lock, _lock_context ) \
374 do { (void) _lock_context; } while ( 0 )
375#endif
376
379#ifdef __cplusplus
380}
381#endif
382
385#endif
386/* end of include file */
ISR_lock_Control rtems_interrupt_lock
Interrupt lock control.
Definition: intr.h:195
ISR_lock_Context rtems_interrupt_lock_context
Local interrupt lock context for acquire and release pairs.
Definition: intr.h:200
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
ISR_Level rtems_interrupt_level
Interrupt level type.
Definition: intr.h:42
rtems_status_code
Classic API Status.
Definition: status.h:43
void ISR_Handler
Definition: isr.h:56
uint32_t ISR_Level
Definition: isrlevel.h:41
uint32_t ISR_Vector_number
Definition: isr.h:51
Data Related to the Management of Processor Interrupt Levels.
ISR Locks.
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
ISR lock control.
Definition: isrlock.h:56
