RTEMS 5.2-rc1
jffs2.h
1/*
2 * Copyright (c) 2013, 2016 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <rtems@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef RTEMS_JFFS2_H
16#define RTEMS_JFFS2_H
17
18#include <rtems/fs.h>
19#include <sys/param.h>
20#include <sys/ioccom.h>
21#include <zlib.h>
22
23#ifdef __cplusplus
24extern "C" {
25#endif /* __cplusplus */
26
28
178 uint32_t offset,
179 unsigned char *buffer,
180 size_t size_of_buffer
181);
182
197 uint32_t offset,
198 const unsigned char *buffer,
199 size_t size_of_buffer
200);
201
216 uint32_t offset
217);
218
230);
231
244);
245
253 uint32_t block_size;
254
261 uint32_t flash_size;
262
267
272
277
284
292
301};
302
304
322 unsigned char *data_in,
323 unsigned char *cdata_out,
324 uint32_t *datalen,
325 uint32_t *cdatalen
326);
327
344 uint16_t comprtype,
345 unsigned char *cdata_in,
346 unsigned char *data_out,
347 uint32_t cdatalen,
348 uint32_t datalen
349);
350
362);
363
372
377
384
388 unsigned char buffer[PAGE_SIZE];
389};
390
396 unsigned char *data_in,
397 unsigned char *cdata_out,
398 uint32_t *datalen,
399 uint32_t *cdatalen
400);
401
407 uint16_t comprtype,
408 unsigned char *cdata_in,
409 unsigned char *data_out,
410 uint32_t cdatalen,
411 uint32_t datalen
412);
413
417typedef struct {
419 z_stream stream;
421
427 unsigned char *data_in,
428 unsigned char *cdata_out,
429 uint32_t *datalen,
430 uint32_t *cdatalen
431);
432
438 uint16_t comprtype,
439 unsigned char *cdata_in,
440 unsigned char *data_out,
441 uint32_t cdatalen,
442 uint32_t datalen
443);
444
450typedef struct {
455
463
479 const void *data
480);
481
487typedef struct {
491 uint32_t flash_size;
492
496 uint32_t flash_blocks;
497
502
508 uint32_t used_size;
509
515 uint32_t dirty_size;
516
522 uint32_t wasted_size;
523
529 uint32_t free_size;
530
536 uint32_t bad_size;
537
543 uint32_t clean_blocks;
544
550 uint32_t dirty_blocks;
551
558
564 uint32_t free_blocks;
565
571 uint32_t bad_blocks;
573
579#define RTEMS_JFFS2_GET_INFO _IOR('F', 1, rtems_jffs2_info)
580
588#define RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION _IO('F', 2)
589
596#define RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION _IO('F', 3)
597
600#ifdef __cplusplus
601}
602#endif /* __cplusplus */
603
604#endif /* RTEMS_JFFS2_H */
int rtems_jffs2_compressor_rtime_decompress(rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
RTIME compressor decompress operation.
Definition: compr_rtime.c:80
int(* rtems_jffs2_flash_erase)(rtems_jffs2_flash_control *self, uint32_t offset)
Flash erase operation.
Definition: jffs2.h:214
int(* rtems_jffs2_flash_read)(rtems_jffs2_flash_control *self, uint32_t offset, unsigned char *buffer, size_t size_of_buffer)
Read from flash operation.
Definition: jffs2.h:176
uint16_t rtems_jffs2_compressor_rtime_compress(rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
RTIME compressor compress operation.
Definition: compr_rtime.c:33
uint16_t(* rtems_jffs2_compressor_compress)(rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
Compress operation.
Definition: jffs2.h:320
void(* rtems_jffs2_trigger_garbage_collection)(rtems_jffs2_flash_control *self)
Trigger garbage collection operation.
Definition: jffs2.h:242
uint16_t rtems_jffs2_compressor_zlib_compress(rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
ZLIB compressor compress operation.
Definition: compr_zlib.c:46
void(* rtems_jffs2_compressor_destroy)(rtems_jffs2_compressor_control *self)
Compressor destroy operation.
Definition: jffs2.h:360
int rtems_jffs2_initialize(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Initialization handler of the JFFS2 file system.
Definition: fs-rtems.c:1216
int(* rtems_jffs2_compressor_decompress)(rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
Decompress operation.
Definition: jffs2.h:342
void(* rtems_jffs2_flash_destroy)(rtems_jffs2_flash_control *self)
Flash destroy operation.
Definition: jffs2.h:228
int rtems_jffs2_compressor_zlib_decompress(rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
ZLIB compressor decompress operation.
Definition: compr_zlib.c:121
int(* rtems_jffs2_flash_write)(rtems_jffs2_flash_control *self, uint32_t offset, const unsigned char *buffer, size_t size_of_buffer)
Write to flash operation.
Definition: jffs2.h:195
Basic Filesystem Types.
Mount table entry.
Definition: libio.h:1604
JFFS2 compressor control.
Definition: jffs2.h:367
rtems_jffs2_compressor_compress compress
Compress operation.
Definition: jffs2.h:371
rtems_jffs2_compressor_destroy destroy
Definition: jffs2.h:383
Compression buffer.
Definition: jffs2.h:388
rtems_jffs2_compressor_decompress decompress
Definition: jffs2.h:376
ZLIB compressor control structure.
Definition: jffs2.h:417
JFFS2 flash device control.
Definition: jffs2.h:249
rtems_jffs2_trigger_garbage_collection trigger_garbage_collection
Definition: jffs2.h:300
uint32_t flash_size
The size in bytes of the flash device.
Definition: jffs2.h:261
rtems_jffs2_flash_erase erase
Definition: jffs2.h:276
rtems_jffs2_flash_read read
Definition: jffs2.h:266
rtems_jffs2_flash_destroy destroy
Definition: jffs2.h:283
rtems_jffs2_flash_write write
Definition: jffs2.h:271
uint32_t block_size
The size in bytes of the erasable unit of the flash device.
Definition: jffs2.h:253
dev_t device_identifier
The device identifier of the flash device.
Definition: jffs2.h:291
JFFS2 filesystem instance information.
Definition: jffs2.h:487
uint32_t flash_block_size
Size of a flash block in bytes.
Definition: jffs2.h:501
Count of flash blocks (erasable units).
Definition: jffs2.h:496
Count of dirty blocks.
Definition: jffs2.h:550
Count of clean blocks.
Definition: jffs2.h:543
uint32_t bad_blocks
Count of bad blocks.
Definition: jffs2.h:571
uint32_t flash_size
Flash size in bytes.
Definition: jffs2.h:491
Wasted size in bytes.
Definition: jffs2.h:522
uint32_t used_size
Used size in bytes.
Definition: jffs2.h:508
uint32_t erasable_blocks
Count of erasable blocks.
Definition: jffs2.h:557
uint32_t free_size
Free size in bytes.
Definition: jffs2.h:529
Count of free blocks.
Definition: jffs2.h:564
uint32_t dirty_size
Dirty size in bytes.
Definition: jffs2.h:515
uint32_t bad_size
Bad size in bytes.
Definition: jffs2.h:536
JFFS2 mount options.
Definition: jffs2.h:450
rtems_jffs2_compressor_control * compressor_control
Compressor control.
Definition: jffs2.h:461
rtems_jffs2_flash_control * flash_control
Flash control.
Definition: jffs2.h:454
Definition: zlib.h:170
