RTEMS 5.2-rc1
ili9488_spi.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _ILI9488_SPI_H_
38#define _ILI9488_SPI_H_
39
40/*------------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "board.h"
45
46/*------------------------------------------------------------------------------
47 * Exported functions
48 *----------------------------------------------------------------------------*/
49extern uint32_t ILI9488_SpiReadChipId (void);
50extern uint32_t ILI9488_SpiInitialize(sXdmad *dmad);
51extern void ILI9488_SpiSetPixelFormat(uint8_t format);
52extern void ILI9488_SpiNop(void);
53extern void ILI9488_SpiWriteMemory(const uint8_t *pBuf, uint32_t size);
54extern void ILI9488_SpiReadMemory(const uint8_t *pBuf, uint32_t size);
55extern void ILI9488_SpiSetCursor(uint16_t x, uint16_t y);
56extern void ILI9488_SpiSetWindow(
57 uint16_t dwX,
58 uint16_t dwY,
59 uint16_t dwWidth,
60 uint16_t dwHeight);
61
62extern void ILI9488_SpiSetFullWindow(void);
63extern void ILI9488_SpiOn(void);
64extern void ILI9488_SpiOff(void);
65extern void ILI9488_SpiSetDisplayLandscape(
66 uint8_t dwRGB, uint8_t LandscaprMode);
67extern void ILI9488_SetPixelColor(uint32_t x, uint32_t y, uint32_t color);
68
69#endif /* #ifndef ILI9488_SPI */
Definition: xdmad.h:127
Definition: mknod-pack_dev.c:254
unsigned size
Definition: tte.h:1
