RTEMS 5.2-rc1
if_em_osdep.h
1/**************************************************************************
2
3Copyright (c) 2001-2005, Intel Corporation
4All rights reserved.
5
6Redistribution and use in source and binary forms, with or without
7modification, are permitted provided that the following conditions are met:
8
9 1. Redistributions of source code must retain the above copyright notice,
10 this list of conditions and the following disclaimer.
11
12 2. Redistributions in binary form must reproduce the above copyright
13 notice, this list of conditions and the following disclaimer in the
14 documentation and/or other materials provided with the distribution.
15
16 3. Neither the name of the Intel Corporation nor the names of its
17 contributors may be used to endorse or promote products derived from
18 this software without specific prior written permission.
19
20THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30POSSIBILITY OF SUCH DAMAGE.
31
32***************************************************************************/
33
34/*$FreeBSD: /repoman/r/ncvs/src/sys/dev/em/if_em_osdep.h,v 1.14 2005/05/26 23:32:02 tackerman Exp $*/
35
36#ifndef _RTEMS_OS_H_
37#define _RTEMS_OS_H_
38
39#include <rtems.h>
40#include "../porting/rtemscompat.h"
41
42#include <sys/types.h>
43#include <sys/param.h>
44#include <sys/systm.h>
45#include <sys/mbuf.h>
46#include <sys/protosw.h>
47#include <sys/socket.h>
48#include <sys/malloc.h>
49#include <sys/kernel.h>
50#include <bsp/pci.h>
51
52/* Eventually, we should include this
53#include <rtems/rtems-mii-ioctl.h>
54*/
55#define IFM_LINK_OK IFM_FLAG0
56#define IFM_ANEG_DIS IFM_FLAG1
57
58#define ASSERT(x) if(!(x)) panic("EM: x")
59
60/* The happy-fun DELAY macro is defined in /usr/src/sys/i386/include/clock.h */
61#define usec_delay(x) DELAY(x)
62#define msec_delay(x) DELAY(1000*(x))
63/* TODO: Should we be paranoid about delaying in interrupt context? */
64#define msec_delay_irq(x) DELAY(1000*(x))
65
66#define MSGOUT(S, A, B) printf(S "\n", A, B)
67#define DEBUGFUNC(F) DEBUGOUT(F);
68#if DBG
69 #define DEBUGOUT(S) printf(S "\n")
70 #define DEBUGOUT1(S,A) printf(S "\n",A)
71 #define DEBUGOUT2(S,A,B) printf(S "\n",A,B)
72 #define DEBUGOUT3(S,A,B,C) printf(S "\n",A,B,C)
73 #define bootverbose (1)
74 #define DEBUGOUT7(S,A,B,C,D,E,F,G) printf(S "\n",A,B,C,D,E,F,G)
75#else
76 #define DEBUGOUT(S)
77 #define DEBUGOUT1(S,A)
78 #define DEBUGOUT2(S,A,B)
79 #define DEBUGOUT3(S,A,B,C)
80 #define bootverbose (0)
81 #define DEBUGOUT7(S,A,B,C,D,E,F,G)
82#endif
83
84#define CMD_MEM_WRT_INVALIDATE 0x0010 /* BIT_4 */
85#define PCI_COMMAND_REGISTER PCIR_COMMAND
86
88{
89 unsigned mem_bus_space_handle;
90 device_t dev;
91};
92
94 int ifm_media;
95};
96
97#define E1000_WRITE_FLUSH(hw) E1000_READ_REG(hw, STATUS)
98
99/* Read from an absolute offset in the adapter's memory space */
100#define E1000_READ_OFFSET(hw, offset) \
101 bus_space_read_4( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
102 ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
103 offset)
104
105/* Write to an absolute offset in the adapter's memory space */
106#define E1000_WRITE_OFFSET(hw, offset, value) \
107 bus_space_write_4( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
108 ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
109 offset, \
110 value)
111
112/* Convert a register name to its offset in the adapter's memory space */
113#define E1000_REG_OFFSET(hw, reg) \
114 ((hw)->mac_type >= em_82543 ? E1000_##reg : E1000_82542_##reg)
115
116#define E1000_READ_REG(hw, reg) \
117 E1000_READ_OFFSET(hw, E1000_REG_OFFSET(hw, reg))
118
119#define E1000_WRITE_REG(hw, reg, value) \
120 E1000_WRITE_OFFSET(hw, E1000_REG_OFFSET(hw, reg), value)
121
122#define E1000_READ_REG_ARRAY(hw, reg, index) \
123 E1000_READ_OFFSET(hw, E1000_REG_OFFSET(hw, reg) + ((index) << 2))
124
125#define E1000_READ_REG_ARRAY_DWORD E1000_READ_REG_ARRAY
126
127#define E1000_WRITE_REG_ARRAY(hw, reg, index, value) \
128 E1000_WRITE_OFFSET(hw, E1000_REG_OFFSET(hw, reg) + ((index) << 2), value)
129
130#define E1000_WRITE_REG_ARRAY_BYTE(hw, reg, index, value) \
131 bus_space_write_1( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
132 ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
133 E1000_REG_OFFSET(hw, reg) + (index), \
134 value)
135
136#define E1000_WRITE_REG_ARRAY_WORD(hw, reg, index, value) \
137 bus_space_write_2( ((struct em_osdep *)(hw)->back)->mem_bus_space_tag, \
138 ((struct em_osdep *)(hw)->back)->mem_bus_space_handle, \
139 E1000_REG_OFFSET(hw, reg) + (index), \
140 value)
141
142#define E1000_WRITE_REG_ARRAY_DWORD(hw, reg, index, value) \
143 E1000_WRITE_OFFSET(hw, E1000_REG_OFFSET(hw, reg) + ((index) << 2), value)
144
145#endif /* _FREEBSD_OS_H_ */
146
Definition: rtemscompat1.h:15
Definition: if_em_osdep.h:88
Definition: if_em_osdep.h:93
