RTEMS 5.2-rc1
icm.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _ICM_
31#define _ICM_
32
33/*------------------------------------------------------------------------------
34 * Headers
35 *------------------------------------------------------------------------------*/
36
37#include "chip.h"
38
39
40/*------------------------------------------------------------------------------*/
41/* Definition */
42/*------------------------------------------------------------------------------*/
43#define ICM_RCFG_CDWBN (0x1u << 0)
45#define ICM_RCFG_WRAP (0x1u << 1)
47#define ICM_RCFG_EOM (0x1u << 2)
49#define ICM_RCFG_RHIEN (0x1u << 4)
51#define ICM_RCFG_DMIEN (0x1u << 5)
53#define ICM_RCFG_BEIEN (0x1u << 6)
55#define ICM_RCFG_WCIEN (0x1u << 7)
57#define ICM_RCFG_ECIEN (0x1u << 8)
59#define ICM_RCFG_SUIEN (0x1u << 9)
61#define ICM_RCFG_PROCDLY (0x1u << 10)
63#define ICM_RCFG_UALGO_Pos 12
64#define ICM_RCFG_UALGO_Msk (0x7u << ICM_RCFG_UALGO_Pos)
66#define ICM_RCFG_ALGO_SHA1 (0x0u << 12)
68#define ICM_RCFG_ALGO_SHA256 (0x1u << 12)
70#define ICM_RCFG_ALGO_SHA224 (0x4u << 12)
72#define ICM_RCFG_MRPROT_Pos 24
73#define ICM_RCFG_MRPROT_Msk (0x3fu << ICM_RCFG_MRPROT_Pos)
75#define ICM_RCFG_MRPROT(value) \
76 ((ICM_RCFG_MRPROT_Msk & ((value) << ICM_RCFG_MRPROT_Pos)))
77
78/*----------------------------------------------------------------------------*/
79/* Type */
80/*----------------------------------------------------------------------------*/
81
85 uint32_t icm_raddr;
87 uint32_t icm_rcfg;
89 uint32_t icm_rctrl;
91 uint32_t icm_rnext;
93
94/*----------------------------------------------------------------------------*/
95/* Exported functions */
96/*----------------------------------------------------------------------------*/
97extern void ICM_Enable(void);
98extern void ICM_Disable(void);
99extern void ICM_SoftReset(void);
100extern void ICM_ReComputeHash(uint8_t region);
101extern void ICM_EnableMonitor(uint8_t region);
102extern void ICM_DisableMonitor(uint8_t region);
103extern void ICM_Configure(uint32_t mode);
104extern void ICM_EnableIt(uint32_t sources);
105extern void ICM_DisableIt(uint32_t sources);
106extern uint32_t ICM_GetIntStatus(void);
107extern uint32_t ICM_GetStatus(void);
108extern uint32_t ICM_GetUStatus(void);
109extern void ICM_SetDescStartAddress(uint32_t addr);
110extern void ICM_SetHashStartAddress(uint32_t addr);
111extern void ICM_SetInitHashValue(uint32_t val);
112#endif /* #ifndef _ICM_ */
Resets the ICM controller.
Definition: icm.c:113
Disable ICM, if a region is active, this region is terminated.
Definition: icm.c:105
Set hash area start address register.
Definition: icm.c:221
Disable region monitoring for given region.
Definition: icm.c:144
Enables the selected interrupts sources on a ICM peripheral.
Definition: icm.c:162
Get the undefined access status register of the given ICM peripheral.
Definition: icm.c:199
Recompute Internal hash.
Definition: icm.c:124
Set ICM user initial Hash value register.
Definition: icm.c:230
Enable ICM, the ICM controller is activated.
Definition: icm.c:97
Disables the selected interrupts sources on a ICM peripheral.
Definition: icm.c:171
Get the current status register of the given ICM peripheral.
Definition: icm.c:189
Enable region monitoring for given region.
Definition: icm.c:134
Get the current interrupt status register of the given ICM peripheral.
Definition: icm.c:180
Set descriptor area start address register.
Definition: icm.c:210
Configures an ICM peripheral with the specified parameters.
Definition: icm.c:153
Structure ICM region descriptor area.
Definition: icm.h:83
uint32_t icm_raddr
Definition: icm.h:85
uint32_t icm_rcfg
Definition: icm.h:87
uint32_t icm_rctrl
Definition: icm.h:89
uint32_t icm_rnext
Definition: icm.h:91
