RTEMS 5.2-rc1
i82586var.h
1/* $NetBSD: i82586var.h,v 1.15 2001/01/22 22:28:45 bjh21 Exp $ */
2
3/*-
4 * Copyright (c) 1998 The NetBSD Foundation, Inc.
5 * All rights reserved.
6 *
7 * This code is derived from software contributed to The NetBSD Foundation
8 * by Paul Kranenburg and Charles M. Hannum.
9 *
10 * Redistribution and use in source and binary forms, with or without
11 * modification, are permitted provided that the following conditions
12 * are met:
13 * 1. Redistributions of source code must retain the above copyright
14 * notice, this list of conditions and the following disclaimer.
15 * 2. Redistributions in binary form must reproduce the above copyright
16 * notice, this list of conditions and the following disclaimer in the
17 * documentation and/or other materials provided with the distribution.
18 * 3. All advertising materials mentioning features or use of this software
19 * must display the following acknowledgement:
20 * This product includes software developed by the NetBSD
21 * Foundation, Inc. and its contributors.
22 * 4. Neither the name of The NetBSD Foundation nor the names of its
23 * contributors may be used to endorse or promote products derived
24 * from this software without specific prior written permission.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
27 * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
28 * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
29 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
30 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39/*-
40 * Copyright (c) 1992, 1993, University of Vermont and State
41 * Agricultural College.
42 * Copyright (c) 1992, 1993, Garrett A. Wollman.
43 *
44 * Portions:
45 * Copyright (c) 1994, 1995, Rafal K. Boni
46 * Copyright (c) 1990, 1991, William F. Jolitz
47 * Copyright (c) 1990, The Regents of the University of California
48 *
49 * All rights reserved.
50 *
51 * Redistribution and use in source and binary forms, with or without
52 * modification, are permitted provided that the following conditions
53 * are met:
54 * 1. Redistributions of source code must retain the above copyright
55 * notice, this list of conditions and the following disclaimer.
56 * 2. Redistributions in binary form must reproduce the above copyright
57 * notice, this list of conditions and the following disclaimer in the
58 * documentation and/or other materials provided with the distribution.
59 * 3. All advertising materials mentioning features or use of this software
60 * must display the following acknowledgement:
61 * This product includes software developed by the University of Vermont
62 * and State Agricultural College and Garrett A. Wollman, by William F.
63 * Jolitz, and by the University of California, Berkeley, Lawrence
64 * Berkeley Laboratory, and its contributors.
65 * 4. Neither the names of the Universities nor the names of the authors
66 * may be used to endorse or promote products derived from this software
67 * without specific prior written permission.
68 *
69 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
70 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
71 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
72 * ARE DISCLAIMED. IN NO EVENT SHALL THE UNIVERSITY OR AUTHORS BE LIABLE
73 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
74 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
75 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
76 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
77 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
78 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
79 * SUCH DAMAGE.
80 */
81
82/*
83 * Intel 82586 Ethernet chip
84 * Register, bit, and structure definitions.
85 *
86 * Original StarLAN driver written by Garrett Wollman with reference to the
87 * Clarkson Packet Driver code for this chip written by Russ Nelson and others.
88 *
89 * BPF support code taken from hpdev/if_le.c, supplied with tcpdump.
90 *
91 * 3C507 support is loosely based on code donated to NetBSD by Rafal Boni.
92 *
93 * Majorly cleaned up and 3C507 code merged by Charles Hannum.
94 *
95 * Converted to SUN ie driver by Charles D. Cranor,
96 * October 1994, January 1995.
97 * This sun version based on i386 version 1.30.
98 */
99
100#ifndef I82586_DEBUG
101#define I82586_DEBUG 0
102#endif
103
104/* Debug elements */
105#define IED_RINT 0x01
106#define IED_TINT 0x02
107#define IED_RNR 0x04
108#define IED_CNA 0x08
109#define IED_READFRAME 0x10
110#define IED_ENQ 0x20
111#define IED_XMIT 0x40
112#define IED_ALL 0x7f
113
114#define B_PER_F 3 /* recv buffers per frame */
115#define IE_RBUF_SIZE 256 /* size of each receive buffer;
116 MUST BE POWER OF TWO */
117#define NTXBUF 2 /* number of transmit commands */
118#define IE_TBUF_SIZE ETHER_MAX_LEN /* length of transmit buffer */
119
120#define IE_MAXMCAST (IE_TBUF_SIZE/6)/* must fit in transmit buffer */
121
122
123#define INTR_ENTER 0 /* intr hook called on ISR entry */
124#define INTR_EXIT 1 /* intr hook called on ISR exit */
125#define INTR_LOOP 2 /* intr hook called on ISR loop */
126#define INTR_ACK 3 /* intr hook called on ie_ack */
127
128#define CHIP_PROBE 0 /* reset called from chip probe */
129#define CARD_RESET 1 /* reset called from card reset */
130
131#if I82586_DEBUG
132#define I82586_INTS_REQ 0
133#define I82586_INTS_IN 1
134#define I82586_INTS_LOOPS 2
135#define I82586_INTS_OUT 3
136#define I82586_RX_INT 4
137#define I82586_RX_DROP 5
138#define I82586_RX_ERR 6
139#define I82586_RX_OK 7
140#define I82586_RX_START 8
141#define I82586_START_TX 9
142#define I82586_TX_START 10
143#define I82586_TX_INT 11
144#define I82586_TX_REQ 12
145#define I82586_TX_EVT 13
146#define I82586_TX_EMIT 14
147#define I82586_TX_BAD 15
148#define I82586_TX_ACTIVE 16
149#define I82586_TRACE_CNT 17
150
151#define I82586_TRACE_FLOW (10000)
152#endif
153
154/*
155 * Ethernet status, per interface.
156 *
157 * The chip uses two types of pointers: 16 bit and 24 bit
158 * 24 bit pointers cover the board's memory.
159 * 16 bit pointers are offsets from the ISCP's `ie_base'
160 *
161 * The board's memory is represented by the bus handle `bh'. The MI
162 * i82586 driver deals exclusively with offsets relative to the
163 * board memory bus handle. The `ie_softc' fields below that are marked
164 * `MD' are in the domain of the front-end driver; they opaque to the
165 * MI driver part.
166 *
167 * The front-end is required to manage the SCP and ISCP structures. i.e.
168 * allocate room for them on the board's memory, and arrange to point the
169 * chip at the SCB stucture, the offset of which is passed to the MI
170 * driver in `sc_scb'.
171 *
172 * The following functions provide the glue necessary to deal with
173 * host and bus idiosyncracies:
174 *
175 * hwreset - board reset
176 * hwinit - board initialization
177 * chan_attn - get chip to look at prepared commands
178 * intrhook - board dependent interrupt processing
179 *
180 * All of the following shared-memory access function use an offset
181 * relative to the bus handle to indicate the shared memory location.
182 * The bus_{read/write}N function take or return offset into the
183 * shared memory in the host's byte-order.
184 *
185 * memcopyin - copy device memory: board to KVA
186 * memcopyout - copy device memory: KVA to board
187 * bus_read16 - read a 16-bit i82586 pointer
188 `offset' argument will be 16-bit aligned
189 * bus_write16 - write a 16-bit i82586 pointer
190 `offset' argument will be 16-bit aligned
191 * bus_write24 - write a 24-bit i82586 pointer
192 `offset' argument will be 32-bit aligned
193 * bus_barrier - perform a bus barrier operation, forcing
194 all outstanding reads/writes to complete
195 *
196 */
198struct ie_softc {
199 struct arpcom arpcom;
200
201 /*
202 * For RTEMS we run the tx and rx handlers under a task due to the
203 * network semaphore stuff.
204 */
205
206 rtems_id intr_task;
207 rtems_id tx_task;
208
209 void *sc_iobase; /* (MD) KVA of base of 24 bit addr space */
210 void *sc_maddr; /* (MD) KVA of base of chip's RAM
211 (16bit addr space) */
212 u_int sc_msize; /* (MD) how much RAM we have/use */
213
214 /* Bus glue */
215 void (*hwreset) (struct ie_softc *, int);
216 void (*hwinit) (struct ie_softc *);
217 void (*chan_attn) (struct ie_softc *, int);
218 int (*intrhook) (struct ie_softc *, int where);
219
220 void (*memcopyin) (struct ie_softc *, void *, int, size_t);
221 void (*memcopyout) (struct ie_softc *, const void *,
222 int, size_t);
223 u_int16_t (*ie_bus_read16) (struct ie_softc *, int offset);
224 void (*ie_bus_write16) (struct ie_softc *, int offset,
225 u_int16_t value);
226 void (*ie_bus_write24) (struct ie_softc *, int offset,
227 int addr);
228 void (*ie_bus_barrier) (struct ie_softc *, int offset,
229 int length, int flags);
230
231 /* Media management */
232 int (*sc_mediachange) (struct ie_softc *);
233 /* card dependent media change */
234 void (*sc_mediastatus) (struct ie_softc *, struct ifmediareq *);
235 /* card dependent media status */
236
237 /*
238 * Offsets (relative to bus handle) of the i82586 SYSTEM structures.
239 */
240 int scp; /* Offset to the SCP (set by front-end) */
241 int iscp; /* Offset to the ISCP (set by front-end) */
242 int scb; /* Offset to SCB (set by front-end) */
243
244 /*
245 * Offset and size of a block of board memory where the buffers
246 * are to be allocated from (initialized by front-end).
247 */
248 int buf_area; /* Start of descriptors and buffers */
249 int buf_area_sz; /* Size of above */
250
251 /*
252 * The buffers & descriptors (recv and xmit)
253 */
254 int rframes; /* Offset to `nrxbuf' frame descriptors */
255 int rbds; /* Offset to `nrxbuf' buffer descriptors */
256 int rbufs; /* Offset to `nrxbuf' receive buffers */
257#define IE_RBUF_ADDR(sc, i) (sc->rbufs + ((i) * IE_RBUF_SIZE))
258 int rfhead, rftail;
259 int rbhead, rbtail;
260 int nframes; /* number of frames in use */
261 int nrxbuf; /* number of recv buffs in use */
262 int rnr_expect; /* XXX - expect a RCVR not ready interrupt */
263
264 int nop_cmds; /* Offset to NTXBUF no-op commands */
265 int xmit_cmds; /* Offset to NTXBUF transmit commands */
266 int xbds; /* Offset to NTXBUF buffer descriptors */
267 int xbufs; /* Offset to NTXBUF transmit buffers */
268#define IE_XBUF_ADDR(sc, i) (sc->xbufs + ((i) * IE_TBUF_SIZE))
269
270 int xchead, xctail;
271 int xmit_busy;
272 int do_xmitnopchain; /* Controls use of xmit NOP chains */
273 int xmit_req;
274
275 /* Multicast addresses */
276 char *mcast_addrs; /* Current MC filter addresses */
277 int mcast_addrs_size; /* Current size of MC buffer */
278 int mcast_count; /* Current # of addrs in buffer */
279 int want_mcsetup; /* run mcsetup at next opportunity */
280
281 int promisc; /* are we in promisc mode? */
282 int async_cmd_inprogress; /* we didn't wait for 586 to accept
283 a command */
284
285#if I82586_DEBUG
286#define I82586_TRACE(s, e, d) \
287do { rtems_interrupt_level level; rtems_interrupt_disable (level); \
288 (s)->trace_flow[(s)->trace_flow_in++] = (e); \
289 (s)->trace_flow[(s)->trace_flow_in++] = (unsigned int)(d); \
290 if ((s)->trace_flow_in >= I82586_TRACE_FLOW) { \
291 (s)->trace_flow_in = 0; \
292 (s)->trace_flow_wrap = 1; \
293 } \
294 rtems_interrupt_enable (level); \
295 } while (0)
296
297 int sc_debug;
298 unsigned int trace_flow[I82586_TRACE_FLOW * 2];
299 unsigned int trace_flow_wrap;
300#endif
301 unsigned int trace_flow_in;
302};
303
304/* Exported functions */
305rtems_isr i82586_intr (rtems_vector_number , void *);
306int i82586_proberam (struct ie_softc *);
307int i82586_attach (struct rtems_bsdnet_ifconfig *config, int attaching);
308
309/* Shortcut macros to optional (driver uses default if unspecified) callbacks */
310#define xIE_BUS_BARRIER(sc, offset, length, flags) \
311do { \
312 if ((sc)->ie_bus_barrier) \
313 ((sc)->ie_bus_barrier)((sc), (offset), (length), (flags));\
314 else \
315 bus_space_barrier((sc)->bt, (sc)->bh, (offset), (length), \
316 (flags)); \
317} while (0)
318
319#define IE_BUS_BARRIER(sc, offset, length, flags)
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: deflate.c:115
Definition: i82586var.h:197
