RTEMS
5.2-rc1
bsps
powerpc
beatnik
net
if_gfe
gtethreg.h
1
/* $NetBSD: gtethreg.h,v 1.2.10.1 2005/04/29 11:28:55 kent Exp $ */
2
3
4
* Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5
* All rights reserved.
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
* 3. All advertising materials mentioning features or use of this software
16
* must display the following acknowledgement:
17
* This product includes software developed for the NetBSD Project by
18
* Allegro Networks, Inc., and Wasabi Systems, Inc.
19
* 4. The name of Allegro Networks, Inc. may not be used to endorse
20
* or promote products derived from this software without specific prior
21
* written permission.
22
* 5. The name of Wasabi Systems, Inc. may not be used to endorse
23
24
25
26
* THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27
* WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29
* AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30
* IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31
* BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
* POSSIBILITY OF SUCH DAMAGE.
38
39
40
#ifndef _DEV_GTETHREG_H_
41
#define _DEV_GTETHREG_H_
42
43
#define ETH__BIT(bit) (1U << (bit))
44
#define ETH__LLBIT(bit) (1LLU << (bit))
45
#define ETH__MASK(bit) (ETH__BIT(bit) - 1)
46
#define ETH__LLMASK(bit) (ETH__LLBIT(bit) - 1)
47
#define ETH__GEN(n, off) (0x2400+((n) << 10)+(ETH__ ## off))
48
#define ETH__EXT(data, bit, len) (((data) >> (bit)) & ETH__MASK(len))
49
#define ETH__LLEXT(data, bit, len) (((data) >> (bit)) & ETH__LLMASK(len))
50
#define ETH__CLR(data, bit, len) ((data) &= ~(ETH__MASK(len) << (bit)))
51
#define ETH__INS(new, bit) ((new) << (bit))
52
#define ETH__LLINS(new, bit) ((uint64_t)(new) << (bit))
53
54
55
* Descriptors used for both receive & transmit data. Note that the descriptor
56
* must start on a 4LW boundary. Since the GT accesses the descriptor as
57
* two 64-bit quantities, we must present them 32bit quantities in the right
58
* order based on endianess.
59
60
61
struct
gt_eth_desc
62
#if defined(BYTE_ORDER) && BYTE_ORDER == BIG_ENDIAN
63
u_int32_t ed_lencnt;
/* length is hi 16 bits; count (rx) is lo 16 */
64
u_int32_t ed_cmdsts;
/* command (hi16)/status (lo16) bits */
65
u_int32_t ed_nxtptr;
/* next descriptor (must be 4LW aligned) */
66
u_int32_t ed_bufptr;
/* pointer to packet buffer */
67
#endif
68
#if defined(BYTE_ORDER) && BYTE_ORDER == LITTLE_ENDIAN
69
70
71
72
73
#endif
74
75
76
/* Table 578: Ethernet TX Descriptor - Command/Status word
77
* All bits except F, EI, AM, O are only valid if TX_CMD_L is also set,
78
* otherwise should be 0 (tx).
79
80
#define TX_STS_LC ETH__BIT(5)
/* Late Collision */
81
#define TX_STS_UR ETH__BIT(6)
/* Underrun error */
82
#define TX_STS_RL ETH__BIT(8)
/* Retransmit Limit (excession coll) */
83
#define TX_STS_COL ETH__BIT(9)
/* Collision Occurred */
84
#define TX_STS_RC(v) ETH__GETBITS(v, 10, 4)
/* Retransmit Count */
85
#define TX_STS_ES ETH__BIT(15)
/* Error Summary (LC|UR|RL) */
86
#define TX_CMD_L ETH__BIT(16)
/* Last - End Of Packet */
87
#define TX_CMD_F ETH__BIT(17)
/* First - Start Of Packet */
88
#define TX_CMD_P ETH__BIT(18)
/* Pad Packet */
89
#define TX_CMD_GC ETH__BIT(22)
/* Generate CRC */
90
#define TX_CMD_EI ETH__BIT(23)
/* Enable Interrupt */
91
#define TX_CMD_AM ETH__BIT(30)
/* Auto Mode */
92
#define TX_CMD_O ETH__BIT(31)
/* Ownership (1=GT 0=CPU) */
93
94
#define TX_CMD_FIRST (TX_CMD_F|TX_CMD_O)
95
#define TX_CMD_LAST (TX_CMD_L|TX_CMD_GC|TX_CMD_P|TX_CMD_O)
96
97
/* Table 582: Ethernet RX Descriptor - Command/Status Word
98
* All bits except F, EI, AM, O are only valid if RX_CMD_L is also set,
99
* otherwise should be ignored (rx).
100
101
#define RX_STS_CE ETH__BIT(0)
/* CRC Error */
102
#define RX_STS_COL ETH__BIT(1)
/* Collision sensed during reception */
103
#define RX_STS_LC ETH__BIT(5)
/* Late Collision (Reserved) */
104
#define RX_STS_OR ETH__BIT(6)
/* Overrun Error */
105
#define RX_STS_MFL ETH__BIT(7)
/* Max Frame Len Error */
106
#define RX_STS_SF ETH__BIT(8)
/* Short Frame Error (< 64 bytes) */
107
#define RX_STS_FT ETH__BIT(11)
/* Frame Type (1 = 802.3) */
108
#define RX_STS_M ETH__BIT(12)
/* Missed Frame */
109
#define RX_STS_HE ETH__BIT(13)
/* Hash Expired (manual match) */
110
#define RX_STS_IGMP ETH__BIT(14)
/* IGMP Packet */
111
#define RX_STS_ES ETH__BIT(15)
/* Error Summary (CE|COL|LC|OR|MFL|SF) */
112
#define RX_CMD_L ETH__BIT(16)
113
#define RX_CMD_F ETH__BIT(17)
114
#define RX_CMD_EI ETH__BIT(23)
115
#define RX_CMD_AM ETH__BIT(30)
/* Auto Mode */
116
#define RX_CMD_O ETH__BIT(31)
117
118
/* Table 586: Hash Table Entry Fields
119
120
#define HSH_V ETH__LLBIT(0)
/* Entry is valid */
121
#define HSH_S ETH__LLBIT(1)
/* Skip this entry */
122
#define HSH_RD ETH__LLBIT(2)
/* Receive(1) / Discard (0) */
123
#define HSH_R ETH__LLBIT(2)
/* Receive(1) */
124
#define HSH_PRIO_GET(v) ETH__LLEXT(v, 51, 2)
125
#define HSH_PRIO_INS(v) ETH__LLINS(v, 51)
126
#define HSH_ADDR_MASK 0x7fffff8LLU
127
#define HSH_LIMIT 12
128
129
130
#define ETH_EPAR 0x2000
/* PHY Address Register */
131
#define ETH_ESMIR 0x2010
/* SMI Register */
132
133
#define ETH_BASE_ETH0 0x2400
/* Ethernet0 Register Base */
134
#define ETH_BASE_ETH1 0x2800
/* Ethernet1 Register Base */
135
#define ETH_BASE_ETH2 0x2c00
/* Ethernet2 Register Base */
136
#define ETH_SIZE 0x0400
/* Register Space */
137
138
#define ETH__EBASE 0x0000
/* Base of Registers */
139
#define ETH__EPCR 0x0000
/* Port Config. Register */
140
#define ETH__EPCXR 0x0008
/* Port Config. Extend Reg */
141
#define ETH__EPCMR 0x0010
/* Port Command Register */
142
#define ETH__EPSR 0x0018
/* Port Status Register */
143
#define ETH__ESPR 0x0020
/* Port Serial Parameters Reg */
144
#define ETH__EHTPR 0x0028
/* Port Hash Table Pointer Reg*/
145
#define ETH__EFCSAL 0x0030
/* Flow Control Src Addr Low */
146
#define ETH__EFCSAH 0x0038
/* Flow Control Src Addr High */
147
#define ETH__ESDCR 0x0040
/* SDMA Configuration Reg */
148
#define ETH__ESDCMR 0x0048
/* SDMA Command Register */
149
#define ETH__EICR 0x0050
/* Interrupt Cause Register */
150
#define ETH__EIMR 0x0058
/* Interrupt Mask Register */
151
#define ETH__EFRDP0 0x0080
/* First Rx Desc Pointer 0 */
152
#define ETH__EFRDP1 0x0084
/* First Rx Desc Pointer 1 */
153
#define ETH__EFRDP2 0x0088
/* First Rx Desc Pointer 2 */
154
#define ETH__EFRDP3 0x008c
/* First Rx Desc Pointer 3 */
155
#define ETH__ECRDP0 0x00a0
/* Current Rx Desc Pointer 0 */
156
#define ETH__ECRDP1 0x00a4
/* Current Rx Desc Pointer 1 */
157
#define ETH__ECRDP2 0x00a8
/* Current Rx Desc Pointer 2 */
158
#define ETH__ECRDP3 0x00ac
/* Current Rx Desc Pointer 3 */
159
#define ETH__ECTDP0 0x00e0
/* Current Tx Desc Pointer 0 */
160
#define ETH__ECTDP1 0x00e4
/* Current Tx Desc Pointer 1 */
161
#define ETH__EDSCP2P0L 0x0060
/* IP Differentiated Services
162
CodePoint to Priority0 low */
163
#define ETH__EDSCP2P0H 0x0064
164
CodePoint to Priority0 high*/
165
#define ETH__EDSCP2P1L 0x0068
166
CodePoint to Priority1 low */
167
#define ETH__EDSCP2P1H 0x006c
168
CodePoint to Priority1 high*/
169
#define ETH__EVPT2P 0x0068
/* VLAN Prio. Tag to Priority */
170
#define ETH__EMIBCTRS 0x0100
/* MIB Counters */
171
172
#define ETH_BASE(n) ETH__GEN(n, EBASE)
173
#define ETH_EPCR(n) ETH__GEN(n, EPCR)
174
#define ETH_EPCXR(n) ETH__GEN(n, EPCXR)
175
#define ETH_EPCMR(n) ETH__GEN(n, EPCMR)
176
#define ETH_EPSR(n) ETH__GEN(n, EPSR)
177
#define ETH_ESPR(n) ETH__GEN(n, ESPR)
178
#define ETH_EHTPR(n) ETH__GEN(n, EHPTR)
179
#define ETH_EFCSAL(n) ETH__GEN(n, EFCSAL)
180
#define ETH_EFCSAH(n) ETH__GEN(n, EFCSAH)
181
#define ETH_ESDCR(n) ETH__GEN(n, ESDCR)
182
#define ETH_ESDCMR(n) ETH__GEN(n, ESDCMR)
183
#define ETH_EICR(n) ETH__GEN(n, EICR)
184
#define ETH_EIMR(n) ETH__GEN(n, EIMR)
185
#define ETH_EFRDP0(n) ETH__GEN(n, EFRDP0)
186
#define ETH_EFRDP1(n) ETH__GEN(n, EFRDP1)
187
#define ETH_EFRDP2(n) ETH__GEN(n, EFRDP2)
188
#define ETH_EFRDP3(n) ETH__GEN(n, EFRDP3)
189
#define ETH_ECRDP0(n) ETH__GEN(n, ECRDP0)
190
#define ETH_ECRDP1(n) ETH__GEN(n, ECRDP1)
191
#define ETH_ECRDP2(n) ETH__GEN(n, ECRDP2)
192
#define ETH_ECRDP3(n) ETH__GEN(n, ECRDP3)
193
#define ETH_ECTDP0(n) ETH__GEN(n, ECTDP0)
194
#define ETH_ECTDP1(n) ETH__GEN(n, ECTDP1)
195
#define ETH_EDSCP2P0L(n) ETH__GEN(n, EDSCP2P0L)
196
197
#define ETH_EDSCP2P0H(n) ETH__GEN(n, EDSCP2P0H)
198
199
#define ETH_EDSCP2P1L(n) ETH__GEN(n, EDSCP2P1L)
200
201
#define ETH_EDSCP2P1H(n) ETH__GEN(n, EDSCP1P1H)
202
203
#define ETH_EVPT2P(n) ETH__GEN(n, EVPT2P)
204
#define ETH_EMIBCTRS(n) ETH__GEN(n, EMIBCTRS)
/* MIB Counters */
205
206
#define ETH_EPAR_PhyAD_GET(v, n) (((v) >> ((n) * 5)) & 0x1f)
207
208
#define ETH_ESMIR_READ(phy, reg) (ETH__INS(phy, 16)|\
209
ETH__INS(reg, 21)|\
210
ETH_ESMIR_ReadOpcode)
211
#define ETH_ESMIR_WRITE(phy, reg, val) (ETH__INS(phy, 16)|\
212
ETH__INS(reg, 21)|\
213
ETH__INS(val, 0)|\
214
ETH_ESMIR_WriteOpcode)
215
#define ETH_ESMIR_Value_GET(v) ETH__EXT(v, 0, 16)
216
#define ETH_ESMIR_WriteOpcode 0
217
#define ETH_ESMIR_ReadOpcode ETH__BIT(26)
218
#define ETH_ESMIR_ReadValid ETH__BIT(27)
219
#define ETH_ESMIR_Busy ETH__BIT(28)
220
221
222
* Table 597: Port Configuration Register (PCR)
223
* 00:00 PM Promiscuous mode
224
* 0: Normal mode (Frames are only received if the
225
* destination address is found in the hash
226
* table)
227
* 1: Promiscuous mode (Frames are received
228
* regardless of their destination address.
229
* Errored frames are discarded unless the Port
230
* Configuration register's PBF bit is set)
231
* 01:01 RBM Reject Broadcast Mode
232
* 0: Receive broadcast address
233
* 1: Reject frames with broadcast address
234
* Overridden by the promiscuous mode.
235
* 02:02 PBF Pass Bad Frames
236
* (0: Normal mode, 1: Pass bad Frames)
237
* The Ethernet receiver passes to the CPU errored
238
* frames (like fragments and collided packets)
239
* that are normally rejected.
240
* NOTE: Frames are only passed if they
241
* successfully pass address filtering.
242
* 06:03 Reserved
243
* 07:07 EN Enable (0: Disabled, 1: Enable)
244
* When enabled, the ethernet port is ready to
245
* transmit/receive.
246
* 09:08 LPBK Loop Back Mode
247
* 00: Normal mode
248
* 01: Internal loop back mode (TX data is looped
249
* back to the RX lines. No transition is seen
250
* on the interface pins)
251
* 10: External loop back mode (TX data is looped
252
* back to the RX lines and also transmitted
253
* out to the MII interface pins)
254
* 11: Reserved
255
* 10:10 FC Force Collision
256
* 0: Normal mode.
257
* 1: Force Collision on any TX frame.
258
* For RXM test (in Loopback mode).
259
* 11:11 Reserved.
260
* 12:12 HS Hash Size
261
* 0: 8K address filtering
262
* (256KB of memory space required).
263
* 1: 512 address filtering
264
* ( 16KB of memory space required).
265
* 13:13 HM Hash Mode (0: Hash Func. 0; 1: Hash Func. 1)
266
* 14:14 HDM Hash Default Mode
267
* 0: Discard addresses not found in address table
268
* 1: Pass addresses not found in address table
269
* 15:15 HD Duplex Mode (0: Half Duplex, 1: Full Duplex)
270
* NOTE: Valid only when auto-negotiation for
271
* duplex mode is disabled.
272
* 30:16 Reserved
273
* 31:31 ACCS Accelerate Slot Time
274
* (0: Normal mode, 1: Reserved)
275
276
#define ETH_EPCR_PM ETH__BIT(0)
277
#define ETH_EPCR_RBM ETH__BIT(1)
278
#define ETH_EPCR_PBF ETH__BIT(2)
279
#define ETH_EPCR_EN ETH__BIT(7)
280
#define ETH_EPCR_LPBK_GET(v) ETH__BIT(v, 8, 2)
281
#define ETH_EPCR_LPBK_Normal 0
282
#define ETH_EPCR_LPBK_Internal 1
283
#define ETH_EPCR_LPBK_External 2
284
#define ETH_EPCR_FC ETH__BIT(10)
285
286
#define ETH_EPCR_HS ETH__BIT(12)
287
#define ETH_EPCR_HS_8K 0
288
#define ETH_EPCR_HS_512 ETH_EPCR_HS
289
290
#define ETH_EPCR_HM ETH__BIT(13)
291
#define ETH_EPCR_HM_0 0
292
#define ETH_EPCR_HM_1 ETH_EPCR_HM
293
294
#define ETH_EPCR_HDM ETH__BIT(14)
295
#define ETH_EPCR_HDM_Discard 0
296
#define ETH_EPCR_HDM_Pass ETH_EPCR_HDM
297
298
#define ETH_EPCR_HD_Half 0
299
#define ETH_EPCR_HD_Full ETH_EPCR_HD_Full
300
301
#define ETH_EPCR_ACCS ETH__BIT(31)
302
303
304
305
306
* Table 598: Port Configuration Extend Register (PCXR)
307
* 00:00 IGMP IGMP Packets Capture Enable
308
* 0: IGMP packets are treated as normal Multicast
309
* packets.
310
* 1: IGMP packets on IPv4/Ipv6 over Ethernet/802.3
311
* are trapped and sent to high priority RX
312
* queue.
313
* 01:01 SPAN Spanning Tree Packets Capture Enable
314
* 0: BPDU (Bridge Protocol Data Unit) packets are
315
* treated as normal Multicast packets.
316
* 1: BPDU packets are trapped and sent to high
317
* priority RX queue.
318
* 02:02 PAR Partition Enable (0: Normal, 1: Partition)
319
* When more than 61 collisions occur while
320
* transmitting, the port enters Partition mode.
321
* It waits for the first good packet from the
322
* wire and then goes back to Normal mode. Under
323
* Partition mode it continues transmitting, but
324
* it does not receive.
325
* 05:03 PRIOtx Priority weight in the round-robin between high
326
* and low priority TX queues.
327
* 000: 1 pkt from HIGH, 1 pkt from LOW.
328
* 001: 2 pkt from HIGH, 1 pkt from LOW.
329
* 010: 4 pkt from HIGH, 1 pkt from LOW.
330
* 011: 6 pkt from HIGH, 1 pkt from LOW.
331
* 100: 8 pkt from HIGH, 1 pkt from LOW.
332
* 101: 10 pkt from HIGH, 1 pkt from LOW.
333
* 110: 12 pkt from HIGH, 1 pkt from LOW.
334
* 111: All pkt from HIGH, 0 pkt from LOW. LOW is
335
* served only if HIGH is empty.
336
* NOTE: If the HIGH queue is emptied before
337
* finishing the count, the count is reset
338
* until the next first HIGH comes in.
339
* 07:06 PRIOrx Default Priority for Packets Received on this
340
* Port (00: Lowest priority, 11: Highest priority)
341
* 08:08 PRIOrx_Override Override Priority for Packets Received on this
342
* Port (0: Do not override, 1: Override with
343
* <PRIOrx> field)
344
* 09:09 DPLXen Enable Auto-negotiation for Duplex Mode
345
* (0: Enable, 1: Disable)
346
* 11:10 FCTLen Enable Auto-negotiation for 802.3x Flow-control
347
* 0: Enable; When enabled, 1 is written (through
348
* SMI access) to the PHY's register 4 bit 10
349
* to advertise flow-control capability.
350
* 1: Disable; Only enables flow control after the
351
* PHY address is set by the CPU. When changing
352
* the PHY address the flow control
353
* auto-negotiation must be disabled.
354
* 11:11 FLP Force Link Pass
355
* (0: Force Link Pass, 1: Do NOT Force Link pass)
356
* 12:12 FCTL 802.3x Flow-Control Mode (0: Enable, 1: Disable)
357
* NOTE: Only valid when auto negotiation for flow
358
* control is disabled.
359
* 13:13 Reserved
360
* 15:14 MFL Max Frame Length
361
* Maximum packet allowed for reception (including
362
* CRC): 00: 1518 bytes, 01: 1536 bytes,
363
* 10: 2048 bytes, 11: 64K bytes
364
* 16:16 MIBclrMode MIB Counters Clear Mode (0: Clear, 1: No effect)
365
* 17:17 MIBctrMode Reserved. (MBZ)
366
* 18:18 Speed Port Speed (0: 10Mbit/Sec, 1: 100Mbit/Sec)
367
* NOTE: Only valid if SpeedEn bit is set.
368
* 19:19 SpeedEn Enable Auto-negotiation for Speed
369
370
* 20:20 RMIIen RMII enable
371
* 0: Port functions as MII port
372
* 1: Port functions as RMII port
373
* 21:21 DSCPen DSCP enable
374
* 0: IP DSCP field decoding is disabled.
375
* 1: IP DSCP field decoding is enabled.
376
* 31:22 Reserved
377
378
#define ETH_EPCXR_IGMP ETH__BIT(0)
379
#define ETH_EPCXR_SPAN ETH__BIT(1)
380
#define ETH_EPCXR_PAR ETH__BIT(2)
381
#define ETH_EPCXR_PRIOtx_GET(v) ETH__EXT(v, 3, 3)
382
#define ETH_EPCXR_PRIOrx_GET(v) ETH__EXT(v, 3, 3)
383
#define ETH_EPCXR_PRIOrx_Override ETH__BIT(8)
384
#define ETH_EPCXR_DLPXen ETH__BIT(9)
385
#define ETH_EPCXR_FCTLen ETH__BIT(10)
386
#define ETH_EPCXR_FLP ETH__BIT(11)
387
#define ETH_EPCXR_FCTL ETH__BIT(12)
388
#define ETH_EPCXR_MFL_GET(v) ETH__EXT(v, 14, 2)
389
#define ETH_EPCXR_MFL_1518 0
390
#define ETH_EPCXR_MFL_1536 1
391
#define ETH_EPCXR_MFL_2084 2
392
#define ETH_EPCXR_MFL_64K 3
393
#define ETH_EPCXR_MIBclrMode ETH__BIT(16)
394
#define ETH_EPCXR_MIBctrMode ETH__BIT(17)
395
#define ETH_EPCXR_Speed ETH__BIT(18)
396
#define ETH_EPCXR_SpeedEn ETH__BIT(19)
397
#define ETH_EPCXR_RMIIEn ETH__BIT(20)
398
#define ETH_EPCXR_DSCPEn ETH__BIT(21)
399
400
401
402
403
* Table 599: Port Command Register (PCMR)
404
* 14:00 Reserved
405
* 15:15 FJ Force Jam / Flow Control
406
* When in half-duplex mode, the CPU uses this bit
407
* to force collisions on the Ethernet segment.
408
* When the CPU recognizes that it is going to run
409
* out of receive buffers, it can force the
410
* transmitter to send jam frames, forcing
411
* collisions on the wire. To allow transmission
412
* on the Ethernet segment, the CPU must clear the
413
* FJ bit when more resources are available. When
414
* in full-duplex and flow-control is enabled, this
415
* bit causes the port's transmitter to send
416
* flow-control PAUSE packets. The CPU must reset
417
* this bit when more resources are available.
418
* 31:16 Reserved
419
420
421
#define ETH_EPCMR_FJ ETH__BIT(15)
422
423
424
425
* Table 600: Port Status Register (PSR) -- Read Only
426
* 00:00 Speed Indicates Port Speed (0: 10Mbs, 1: 100Mbs)
427
* 01:01 Duplex Indicates Port Duplex Mode (0: Half, 1: Full)
428
* 02:02 Fctl Indicates Flow-control Mode
429
* (0: enabled, 1: disabled)
430
* 03:03 Link Indicates Link Status (0: down, 1: up)
431
* 04:04 Pause Indicates that the port is in flow-control
432
* disabled state. This bit is set when an IEEE
433
* 802.3x flow-control PAUSE (XOFF) packet is
434
* received (assuming that flow-control is
435
* enabled and the port is in full-duplex mode).
436
* Reset when XON is received, or when the XOFF
437
* timer has expired.
438
* 05:05 TxLow Tx Low Priority Status
439
* Indicates the status of the low priority
440
* transmit queue: (0: Stopped, 1: Running)
441
* 06:06 TxHigh Tx High Priority Status
442
* Indicates the status of the high priority
443
444
* 07:07 TXinProg TX in Progress
445
* Indicates that the port's transmitter is in an
446
* active transmission state.
447
* 31:08 Reserved
448
449
#define ETH_EPSR_Speed ETH__BIT(0)
450
#define ETH_EPSR_Duplex ETH__BIT(1)
451
#define ETH_EPSR_Fctl ETH__BIT(2)
452
#define ETH_EPSR_Link ETH__BIT(3)
453
#define ETH_EPSR_Pause ETH__BIT(4)
454
#define ETH_EPSR_TxLow ETH__BIT(5)
455
#define ETH_EPSR_TxHigh ETH__BIT(6)
456
#define ETH_EPSR_TXinProg ETH__BIT(7)
457
458
459
460
* Table 601: Serial Parameters Register (SPR)
461
* 01:00 JAM_LENGTH Two bits to determine the JAM Length
462
* (in Backpressure) as follows:
463
* 00 = 12K bit-times
464
* 01 = 24K bit-times
465
* 10 = 32K bit-times
466
* 11 = 48K bit-times
467
* 06:02 JAM_IPG Five bits to determine the JAM IPG.
468
* The step is four bit-times. The value may vary
469
* between 4 bit time to 124.
470
* 11:07 IPG_JAM_TO_DATA Five bits to determine the IPG JAM to DATA.
471
472
473
* 16:12 IPG_DATA Inter-Packet Gap (IPG)
474
475
* between 12 bit time to 124.
476
* NOTE: These bits may be changed only when the
477
* Ethernet ports is disabled.
478
* 21:17 Data_Blind Data Blinder
479
* The number of nibbles from the beginning of the
480
* IPG, in which the IPG counter is restarted when
481
* detecting a carrier activity. Following this
482
* value, the port enters the Data Blinder zone and
483
* does not reset the IPG counter. This ensures
484
* fair access to the medium.
485
* The default is 10 hex (64 bit times - 2/3 of the
486
* default IPG). The step is 4 bit-times. Valid
487
* range is 3 to 1F hex nibbles.
488
* NOTE: These bits may be only changed when the
489
* Ethernet port is disabled.
490
* 22:22 Limit4 The number of consecutive packet collisions that
491
* occur before the collision counter is reset.
492
* 0: The port resets its collision counter after
493
* 16 consecutive retransmit trials and
494
* restarts the Backoff algorithm.
495
* 1: The port resets its collision counter and
496
* restarts the Backoff algorithm after 4
497
* consecutive transmit trials.
498
* 31:23 Reserved
499
500
#define ETH_ESPR_JAM_LENGTH_GET(v) ETH__EXT(v, 0, 2)
501
#define ETH_ESPR_JAM_IPG_GET(v) ETH__EXT(v, 2, 5)
502
#define ETH_ESPR_IPG_JAM_TO_DATA_GET(v) ETH__EXT(v, 7, 5)
503
#define ETH_ESPR_IPG_DATA_GET(v) ETH__EXT(v, 12, 5)
504
#define ETH_ESPR_Data_Bilnd_GET(v) ETH__EXT(v, 17, 5)
505
#define ETH_ESPR_Limit4(v) ETH__BIT(22)
506
507
508
* Table 602: Hash Table Pointer Register (HTPR)
509
* 31:00 HTP 32-bit pointer to the address table.
510
* Bits [2:0] must be set to zero.
511
512
513
514
* Table 603: Flow Control Source Address Low (FCSAL)
515
* 15:0 SA[15:0] Source Address
516
* The least significant bits of the source
517
* address for the port. This address is used for
518
* Flow Control.
519
* 31:16 Reserved
520
521
522
523
* Table 604: Flow Control Source Address High (FCSAH)
524
* 31:0 SA[47:16] Source Address
525
* The most significant bits of the source address
526
* for the port. This address is used for Flow
527
* Control.
528
529
530
531
532
* Table 605: SDMA Configuration Register (SDCR)
533
* 01:00 Reserved
534
* 05:02 RC Retransmit Count
535
* Sets the maximum number of retransmits per
536
* packet. After executing retransmit for RC
537
* times, the TX SDMA closes the descriptor with a
538
* Retransmit Limit error indication and processes
539
* the next packet. When RC is set to 0, the
540
* number of retransmits is unlimited. In this
541
* case, the retransmit process is only terminated
542
* if CPU issues an Abort command.
543
* 06:06 BLMR Big/Little Endian Receive Mode
544
* The DMA supports Big or Little Endian
545
* configurations on a per channel basis. The BLMR
546
* bit only affects data transfer to memory.
547
* 0: Big Endian
548
* 1: Little Endian
549
* 07:07 BLMT Big/Little Endian Transmit Mode
550
551
* configurations on a per channel basis. The BLMT
552
* bit only affects data transfer from memory.
553
* 0: Big Endian
554
* 1: Little Endian
555
* 08:08 POVR PCI Override
556
* When set, causes the SDMA to direct all its
557
* accesses in PCI_0 direction and overrides
558
* normal address decoding process.
559
* 09:09 RIFB Receive Interrupt on Frame Boundaries
560
* When set, the SDMA Rx generates interrupts only
561
* on frame boundaries (i.e. after writing the
562
* frame status to the descriptor).
563
* 11:10 Reserved
564
* 13:12 BSZ Burst Size
565
* Sets the maximum burst size for SDMA
566
* transactions:
567
* 00: Burst is limited to 1 64bit words.
568
* 01: Burst is limited to 2 64bit words.
569
* 10: Burst is limited to 4 64bit words.
570
* 11: Burst is limited to 8 64bit words.
571
* 31:14 Reserved
572
573
#define ETH_ESDCR_RC_GET(v) ETH__EXT(v, 2, 4)
574
#define ETH_ESDCR_BLMR ETH__BIT(6)
575
#define ETH_ESDCR_BLMT ETH__BIT(7)
576
#define ETH_ESDCR_POVR ETH__BIT(8)
577
#define ETH_ESDCR_RIFB ETH__BIT(9)
578
#define ETH_ESDCR_BSZ_GET(v) ETH__EXT(v, 12, 2)
579
#define ETH_ESDCR_BSZ_SET(v, n) (ETH__CLR(v, 12, 2),\
580
(v) |= ETH__INS(n, 12))
581
#define ETH_ESDCR_BSZ_1 0
582
#define ETH_ESDCR_BSZ_2 1
583
#define ETH_ESDCR_BSZ_4 2
584
#define ETH_ESDCR_BSZ_8 3
585
586
#define ETH_ESDCR_BSZ_Strings { "1 64-bit word"
, "2 64-bit words", \
587
"4 64-bit words", "8 64-bit words" }
588
589
590
* Table 606: SDMA Command Register (SDCMR)
591
* 06:00 Reserved
592
* 07:07 ERD Enable RX DMA.
593
* Set to 1 by the CPU to cause the SDMA to start
594
* a receive process. Cleared when the CPU issues
595
* an Abort Receive command.
596
* 14:08 Reserved
597
* 15:15 AR Abort Receive
598
* Set to 1 by the CPU to abort a receive SDMA
599
* operation. When the AR bit is set, the SDMA
600
* aborts its current operation and moves to IDLE.
601
* No descriptor is closed. The AR bit is cleared
602
* upon entering IDLE. After setting the AR bit,
603
* the CPU must poll the bit to verify that the
604
* abort sequence is completed.
605
* 16:16 STDH Stop TX High
606
* Set to 1 by the CPU to stop the transmission
607
* process from the high priority queue at the end
608
* of the current frame. An interrupt is generated
609
* when the stop command has been executed.
610
* Writing 1 to STDH resets TXDH bit.
611
* Writing 0 to this bit has no effect.
612
* 17:17 STDL Stop TX Low
613
614
* process from the low priority queue at the end
615
616
617
* Writing 1 to STDL resets TXDL bit.
618
619
* 22:18 Reserved
620
* 23:23 TXDH Start Tx High
621
* Set to 1 by the CPU to cause the SDMA to fetch
622
* the first descriptor and start a transmit
623
* process from the high priority Tx queue.
624
* Writing 1 to TXDH resets STDH bit.
625
626
* 24:24 TXDL Start Tx Low
627
628
629
* process from the low priority Tx queue.
630
* Writing 1 to TXDL resets STDL bit.
631
632
* 30:25 Reserved
633
* 31:31 AT Abort Transmit
634
* Set to 1 by the CPU to abort a transmit DMA
635
* operation. When the AT bit is set, the SDMA
636
637
* No descriptor is closed. Cleared upon entering
638
* IDLE. After setting AT bit, the CPU must poll
639
* it in order to verify that the abort sequence
640
* is completed.
641
642
#define ETH_ESDCMR_ERD ETH__BIT(7)
643
#define ETH_ESDCMR_AR ETH__BIT(15)
644
#define ETH_ESDCMR_STDH ETH__BIT(16)
645
#define ETH_ESDCMR_STDL ETH__BIT(17)
646
#define ETH_ESDCMR_TXDH ETH__BIT(23)
647
#define ETH_ESDCMR_TXDL ETH__BIT(24)
648
#define ETH_ESDCMR_AT ETH__BIT(31)
649
650
651
* Table 607: Interrupt Cause Register (ICR)
652
* 00:00 RxBuffer Rx Buffer Return
653
* Indicates an Rx buffer returned to CPU ownership
654
* or that the port finished reception of a Rx
655
* frame in either priority queues.
656
* NOTE: In order to get a Rx Buffer return per
657
* priority queue, use bit 19:16. This bit is
658
* set upon closing any Rx descriptor which
659
* has its EI bit set. To limit the
660
* interrupts to frame (rather than buffer)
661
* boundaries, the user must set SDMA
662
* Configuration register's RIFB bit. When
663
* the RIFB bit is set, an interrupt
664
* generates only upon closing the first
665
* descriptor of a received packet, if this
666
* descriptor has it EI bit set.
667
* 01:01 Reserved
668
* 02:02 TxBufferHigh Tx Buffer for High priority Queue
669
* Indicates a Tx buffer returned to CPU ownership
670
* or that the port finished transmission of a Tx
671
* frame.
672
* NOTE: This bit is set upon closing any Tx
673
* descriptor which has its EI bit set. To
674
* limit the interrupts to frame (rather than
675
* buffer) boundaries, the user must set EI
676
* only in the last descriptor.
677
* 03:03 TxBufferLow Tx Buffer for Low Priority Queue
678
679
680
* frame.
681
682
683
684
685
686
* 05:04 Reserved
687
* 06:06 TxEndHigh Tx End for High Priority Queue
688
* Indicates that the Tx DMA stopped processing the
689
* high priority queue after stop command, or that
690
* it reached the end of the high priority
691
* descriptor chain.
692
* 07:07 TxEndLow Tx End for Low Priority Queue
693
694
* low priority queue after stop command, or that
695
* it reached the end of the low priority
696
* descriptor chain.
697
* 08:08 RxError Rx Resource Error
698
* Indicates a Rx resource error event in one of
699
* the priority queues.
700
* NOTE: To get a Rx Resource Error Indication per
701
* priority queue, use bit 23:20.
702
* 09:09 Reserved
703
* 10:10 TxErrorHigh Tx Resource Error for High Priority Queue
704
* Indicates a Tx resource error event during
705
* packet transmission from the high priority queue
706
* 11:11 TxErrorLow Tx Resource Error for Low Priority Queue
707
708
* packet transmission from the low priority queue
709
* 12:12 RxOVR Rx Overrun
710
* Indicates an overrun event that occurred during
711
* reception of a packet.
712
* 13:13 TxUdr Tx Underrun
713
* Indicates an underrun event that occurred during
714
* transmission of packet from either queue.
715
* 15:14 Reserved
716
* 16:16 RxBuffer-Queue[0] Rx Buffer Return in Priority Queue[0]
717
* Indicates a Rx buffer returned to CPU ownership
718
* or that the port completed reception of a Rx
719
* frame in a receive priority queue[0]
720
* 17:17 RxBuffer-Queue[1] Rx Buffer Return in Priority Queue[1]
721
722
723
* frame in a receive priority queue[1].
724
* 18:18 RxBuffer-Queue[2] Rx Buffer Return in Priority Queue[2]
725
726
727
* frame in a receive priority queue[2].
728
* 19:19 RxBuffer-Queue[3] Rx Buffer Return in Priority Queue[3]
729
730
731
* frame in a receive priority queue[3].
732
* 20:20 RxError-Queue[0] Rx Resource Error in Priority Queue[0]
733
* Indicates a Rx resource error event in receive
734
* priority queue[0].
735
* 21:21 RxError-Queue[1] Rx Resource Error in Priority Queue[1]
736
737
* priority queue[1].
738
* 22:22 RxError-Queue[2] Rx Resource Error in Priority Queue[2]
739
740
* priority queue[2].
741
* 23:23 RxError-Queue[3] Rx Resource Error in Priority Queue[3]
742
743
* priority queue[3].
744
* 27:24 Reserved
745
* 28:29 MIIPhySTC MII PHY Status Change
746
* Indicates a status change reported by the PHY
747
* connected to this port. Set when the MII
748
* management interface block identifies a change
749
* in PHY's register 1.
750
* 29:29 SMIdone SMI Command Done
751
* Indicates that the SMI completed a MII
752
* management command (either read or write) that
753
* was initiated by the CPU writing to the SMI
754
* register.
755
* 30:30 Reserved
756
* 31:31 EtherIntSum Ethernet Interrupt Summary
757
* This bit is a logical OR of the (unmasked) bits
758
* [30:04] in the Interrupt Cause register.
759
760
761
#define ETH_IR_RxBuffer ETH__BIT(0)
762
#define ETH_IR_TxBufferHigh ETH__BIT(2)
763
#define ETH_IR_TxBufferLow ETH__BIT(3)
764
#define ETH_IR_TxEndHigh ETH__BIT(6)
765
#define ETH_IR_TxEndLow ETH__BIT(7)
766
#define ETH_IR_RxError ETH__BIT(8)
767
#define ETH_IR_TxErrorHigh ETH__BIT(10)
768
#define ETH_IR_TxErrorLow ETH__BIT(11)
769
#define ETH_IR_RxOVR ETH__BIT(12)
770
#define ETH_IR_TxUdr ETH__BIT(13)
771
#define ETH_IR_RxBuffer_0 ETH__BIT(16)
772
#define ETH_IR_RxBuffer_1 ETH__BIT(17)
773
#define ETH_IR_RxBuffer_2 ETH__BIT(18)
774
#define ETH_IR_RxBuffer_3 ETH__BIT(19)
775
#define ETH_IR_RxBuffer_GET(v) ETH__EXT(v, 16, 4)
776
#define ETH_IR_RxError_0 ETH__BIT(20)
777
#define ETH_IR_RxError_1 ETH__BIT(21)
778
#define ETH_IR_RxError_2 ETH__BIT(22)
779
#define ETH_IR_RxError_3 ETH__BIT(23)
780
#define ETH_IR_RxError_GET(v) ETH__EXT(v, 20, 4)
781
#define ETH_IR_RxBits (ETH_IR_RxBuffer_0|\
782
ETH_IR_RxBuffer_1|\
783
ETH_IR_RxBuffer_2|\
784
ETH_IR_RxBuffer_3|\
785
ETH_IR_RxError_0|\
786
ETH_IR_RxError_1|\
787
ETH_IR_RxError_2|\
788
ETH_IR_RxError_3)
789
#define ETH_IR_MIIPhySTC ETH__BIT(28)
790
#define ETH_IR_SMIdone ETH__BIT(29)
791
#define ETH_IR_EtherIntSum ETH__BIT(31)
792
#define ETH_IR_Summary ETH__BIT(31)
793
794
795
* Table 608: Interrupt Mask Register (IMR)
796
* 31:00 Various Mask bits for the Interrupt Cause register.
797
798
799
800
* Table 609: IP Differentiated Services CodePoint to Priority0 low (DSCP2P0L),
801
* 31:00 Priority0_low The LSB priority bits for DSCP[31:0] entries.
802
803
804
805
* Table 610: IP Differentiated Services CodePoint to Priority0 high (DSCP2P0H)
806
* 31:00 Priority0_high The LSB priority bits for DSCP[63:32] entries.
807
808
809
810
* Table 611: IP Differentiated Services CodePoint to Priority1 low (DSCP2P1L)
811
* 31:00 Priority1_low The MSB priority bits for DSCP[31:0] entries.
812
813
814
815
* Table 612: IP Differentiated Services CodePoint to Priority1 high (DSCP2P1H)
816
* 31:00 Priority1_high The MSB priority bit for DSCP[63:32] entries.
817
818
819
820
* Table 613: VLAN Priority Tag to Priority (VPT2P)
821
* 07:00 Priority0 The LSB priority bits for VLAN Priority[7:0]
822
* entries.
823
* 15:08 Priority1 The MSB priority bits for VLAN Priority[7:0]
824
* entries.
825
* 31:16 Reserved
826
827
828
/* Address control registers -- these are offsets from the GT base
829
* and NOT from the ethernet port base. <tss>
830
831
#define ETH_ACTL_0_LO 0xf200
832
833
/* Enable hardware cache snooping;
834
* Copyright Shuchen K. Feng <feng1@bnl.gov>, 2004
835
836
837
/* Ethernet address control (Low) snoop bits */
838
#define RxBSnoopEn ETH__BIT(6)
/* Rx buffer snoop enable,1=enable*/
839
#define TxBSnoopEn ETH__BIT(14)
/* Tx buffer snoop enable */
840
#define RxDSnoopEn ETH__BIT(22)
/* Rx descriptor snoop enable */
841
#define TxDSnoopEn ETH__BIT(30)
/* Tx descriptor snoop enable */
842
843
#define ETH_ACTL_0_HI 0xf204
844
/* Ethernet address control (High), snoop bits */
845
#define HashSnoopEn ETH__BIT(6)
/* Hash Table snoop enable */
846
847
848
#define ETH_ACTL_1_LO 0xf220
849
#define ETH_ACTL_1_HI 0xf224
850
#define ETH_ACTL_2_LO 0xf240
851
#define ETH_ACTL_2_HI 0xf244
852
853
854
#endif
/* _DEV_GTETHREG_H_ */
gt_eth_desc
Definition:
gtethreg.h:61
