RTEMS 5.2-rc1
gt_timer.h
1#ifndef BSP_GT_TIMER_H
2#define BSP_GT_TIMER_H
3
4/* Support for hardware timers in the discovery bridge */
5
6/*
7 * Authorship
8 * ----------
9 * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
10 * created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
11 * Stanford Linear Accelerator Center, Stanford University.
12 *
13 * Acknowledgement of sponsorship
14 * ------------------------------
15 * The 'beatnik' BSP was produced by
16 * the Stanford Linear Accelerator Center, Stanford University,
17 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
18 *
19 * Government disclaimer of liability
20 * ----------------------------------
21 * Neither the United States nor the United States Department of Energy,
22 * nor any of their employees, makes any warranty, express or implied, or
23 * assumes any legal liability or responsibility for the accuracy,
24 * completeness, or usefulness of any data, apparatus, product, or process
25 * disclosed, or represents that its use would not infringe privately owned
26 * rights.
27 *
28 * Stanford disclaimer of liability
29 * --------------------------------
30 * Stanford University makes no representations or warranties, express or
31 * implied, nor assumes any liability for the use of this software.
32 *
33 * Stanford disclaimer of copyright
34 * --------------------------------
35 * Stanford University, owner of the copyright, hereby disclaims its
36 * copyright and all other rights in this software. Hence, anyone may
37 * freely use it for any purpose without restriction.
38 *
39 * Maintenance of notices
40 * ----------------------
41 * In the interest of clarity regarding the origin and status of this
42 * SLAC software, this and all the preceding Stanford University notices
43 * are to remain affixed to any copy or derivative of this software made
44 * or distributed by the recipient and are to be affixed to any copy of
45 * software made or distributed by the recipient that contains a copy or
46 * derivative of this software.
47 *
48 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
49 */
50
51#include <stdint.h>
52
53#ifdef __cplusplus
54 extern "C" {
55#endif
56
57/* Obtain the number of hardware timers present
58 * The 'timer' argument in the routines below addresses
59 * one of 0..(BSP_timer_instances()-1)
60 */
61int BSP_timer_instances(void);
62
63/* Setup timer but don't start yet; interrupts are enabled if an isr argument is passed
64 * no interrupts are generated otherwise.
65 *
66 * If 'reload' is nonzero then the period is automatically restarted.
67 *
68 * RETURNS: 0 on success, nonzero on error (argument error)
69 *
70 * NOTE: If an ISR is already connected, it must be removed by passing a NULL isr first.
71 */
72int BSP_timer_setup(uint32_t timer, void (*isr)(void *arg), void *arg, int reload);
73
74/* Stop timer;
75 *
76 * RETURNS: 0 on success, nonzero on argument error
77 */
78int BSP_timer_stop(uint32_t timer);
79
80/* Start timer with 'period' (in ticks)
81 *
82 * RETURNS: 0 on success, nonzero on argument error
83 */
84int BSP_timer_start(uint32_t timer, uint32_t period);
85
86/* read decrementing timer on the fly
87 *
88 * RETURNS: current count in ticks
89 */
90uint32_t BSP_timer_read(uint32_t timer);
91
92/* get clock rate in Hz */
93uint32_t BSP_timer_clock_get(uint32_t timer);
94
95/* Initialize timer facility -- to be used by BSP implementors only
96 *
97 * RETURNS: 0 on success, nonzero if ISR wrapper couldn't be installed
98 */
99int BSP_timers_initialize(void);
100
101/* WATCHDOG TIMER (resets board if enabled and not 'petted' for
102 * some time).
103 */
104
105/* Enable watchdog and set a timeout (in us)
106 * RETURNS 0 on success
107 */
108int BSP_watchdog_enable(uint32_t timeout_us);
109
110/* Disable watchdog
111 * RETURNS 0 on success
112 */
113int BSP_watchdog_disable(void);
114
115/* Check status -- unfortunately there seems to be no way
116 * to read the running value...
117 *
118 * RETURNS nonzero if enabled/running, zero if disabled/stopped
119 */
120int BSP_watchdog_status(void);
121
122/* Pet the watchdog (rearm to configured timeout)
123 * RETURNS: 0 on success, nonzero on failure (watchdog
124 * currently not running).
125 */
126int BSP_watchdog_pet(void);
127
128
129#ifdef __cplusplus
130 }
131#endif
132
133#endif
