RTEMS 5.2-rc1
grtc.h
1/* GRTC Telecommand (TC) decoder driver interface
2 *
3 * COPYRIGHT (c) 2007.
4 * Cobham Gaisler AB.
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef __GRTC_H__
12#define __GRTC_H__
13
14#ifdef __cplusplus
15extern "C" {
16#endif
17
18#define GRTC_IOC_UNUSED 0
19
20/* Driver operation controlling commands */
21#define GRTC_IOC_START 1
22#define GRTC_IOC_STOP 2
23#define GRTC_IOC_ISSTARTED 3
24#define GRTC_IOC_SET_BLOCKING_MODE 4 /* Raw mode only */
25#define GRTC_IOC_SET_TIMEOUT 5 /* Raw mode only */
26
27#define GRTC_IOC_ADD_BUFF 16 /* Frame mode only */
28#define GRTC_IOC_RECV 17 /* Frame mode only */
29
30/* Available only in STOPPED mode */
31#define GRTC_IOC_SET_MODE 32 /* Set frame mode (ioctl) or raw mode (read) */
32#define GRTC_IOC_SET_BUF_PARAM 33
33#define GRTC_IOC_SET_CONFIG 34
34#define GRTC_IOC_POOLS_SETUP 35 /* Frame mode only */
35
36/* Available in both running and stopped mode */
37#define GRTC_IOC_GET_CONFIG 64
38#define GRTC_IOC_GET_BUF_PARAM 65
39#define GRTC_IOC_GET_HW_STATUS 66
40#define GRTC_IOC_ASSIGN_FRM_POOL 67
41#define GRTC_IOC_GET_CLCW_ADR 68 /* Get address of CLCWRx1 */
42#define GRTC_IOC_GET_STATS 69 /* Get statistics, note that most of the stats are only avilable in FRAME mode */
43#define GRTC_IOC_CLR_STATS 70 /* Clear statistics */
44
45/* Available only in RUNNING mode */
46
47/* Args to GRTC_IOC_GET_BUF_PARAMS */
48#define GRTC_BUF_MAXLEN (0x100*1024)
49#define GRTC_BUF_MASK 0xfffffc00
51 unsigned int length; /* Length of new buffer in multiples of 1kbyte blocks */
52 void *custom_buffer; /* If set zero driver will allocate with malloc, set LSB to 1 to indicate remote address */
53};
54
55/* Args to GRTC_IOC_SET_BLOCKING_MODE */
56enum {
57 GRTC_BLKMODE_POLL = 0, /* Never block (polling mode) */
58 GRTC_BLKMODE_BLK = 1, /* Block until at least 1 byte can be read */
59 GRTC_BLKMODE_COMPLETE = 2 /* Block until all data requested has be read */
60};
61
62/* Argument of GRTC_IOC_SET_CONFIG and GRTC_IOC_GET_CONFIG
63 * Pointer to:
64 */
66 int psr_enable;
67 int nrzm_enable;
68 int pss_enable;
69 int crc_calc; /* Enable Software CRC calculation (only Frame mode) */
70};
71
72/* Argument of GRTC_IOC_GET_HW_STATUS:
73 * Pointer to a grtc_ioc_hw_status structure that will be filled
74 * in by driver.
75 */
77 unsigned int sir;
78 unsigned int far;
79 unsigned int clcw1;
80 unsigned int clcw2;
81 unsigned int phir;
82 unsigned int str;
83};
84
85struct grtc_hdr {
86 unsigned short flags_scid;
87 unsigned short vc_len;
88 unsigned char seqnum;
89} __attribute__((packed));
90
91/* Frame pool, all frames in pool have the same buffer length (frame mode only) */
92struct grtc_frame {
93 struct grtc_frame *next; /* Next frame in list */
94 unsigned short len; /* Length of frame extracted */
95 unsigned short reserved; /* Reserved */
96 struct grtc_frame_pool *pool; /* The frame pool this frame belongs to */
97
98 /* The Frame content */
99 struct grtc_hdr hdr; /* Primary Header */
100 unsigned char data[3]; /* Frame payload */
101} __attribute__((packed));
102
103/* GRTC_IOC_RECV argument, single linked list of received frames */
104struct grtc_list {
105 struct grtc_frame *head; /* First frame in list */
106 struct grtc_frame *tail; /* Last frame in list */
107 int cnt; /* Number of frames in list */
108};
109
111 unsigned int pool_cnt; /* Number of pools */
112 unsigned int pool_frame_len[1]; /* Array of 'pool_cnt' length: Frame length of frames in a pool
113 * Lengths must be sorted, starting with the smallest frame pool.
114 */
115};
116
118 unsigned int frame_len; /* The length of the pool to insert the frame into */
119 struct grtc_frame *frames; /* Frames to assign to a pool */
120};
121
122enum {
123 GRTC_MODE_RAW = 0,
124 GRTC_MODE_FRAME = 1
125};
126
127/* TC driver stats collected during receiving. The statistics is only available
128 * in FRAME mode. In RAW mode the user interprets the incoming frames and is
129 * therefore responsible for generating the staticstics.
130 */
132 unsigned long long frames_recv; /* Total number of non-erroneous frames received */
133 /* Errors related to incoming data */
134 unsigned int err; /* total number of errors */
135 unsigned int err_hdr; /* number of errors in Header */
136 unsigned int err_payload; /* Number of errors in payload */
137 unsigned int err_ending; /* Number of errors in end (Filler, end marker) */
138 unsigned int err_abandoned; /* Number of abandoned frames, NOT IMPLEMENTED */
139 /* Errors related to the handling of incoming frames */
140 unsigned int dropped; /* Number of dropped frames TC driver */
141 unsigned int dropped_no_buf; /* Number of dropped frame caused by no buffers were available */
142 unsigned int dropped_too_long; /* Number of dropped frames that was larger than any buffer available for driver */
143};
144
145/* Register GRTC driver at driver manager */
146void grtc_register_drv(void);
147
148/* Register GRTC RMAP driver at driver manager */
149void grtc_rmap_register_drv (void);
150
151#ifdef __cplusplus
152}
153#endif
154
155#endif /* __GRTC_H__ */
unsigned short int uint16 __attribute__((__may_alias__))
Disable IRQ Interrupts.
Definition: mcf5282.h:37
Definition: grtc.c:217
Definition: grtc.h:92
Definition: grtc.h:85
Definition: grtc.h:117
Definition: grtc.h:50
Definition: grtc.h:65
Definition: grtc.h:76
Definition: grtc.h:110
Definition: grtc.h:131
Definition: grtc.h:104
