RTEMS 5.2-rc1
grspw.h
1
6/*
7 * COPYRIGHT (c) 2007.
8 * Cobham Gaisler AB.
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef __GRSPW_H__
16#define __GRSPW_H__
17
28#include <grlib/ambapp.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif
33
34#define SPW_LINKERR_EVENT RTEMS_EVENT_0
35
36typedef struct {
37 unsigned int rxsize;
38 unsigned int txdsize;
39 unsigned int txhsize;
41
42#define GRSPW_PKTSEND_OPTION_HDR_CRC 0x1
43#define GRSPW_PKTSEND_OPTION_DATA_CRC 0x2
44#define GRSPW_PKTSEND_OPTION_NOCRCLEN(len) ((len & 0xf) << 8)
45#define GRSPW_PKTSEND_OPTION_NOCRCLEN_MASK 0xf00
46
47typedef struct {
48 unsigned int hlen;
49 char *hdr;
50 unsigned int dlen;
51 char *data;
52 unsigned int sent;
53 unsigned int options;
55
56typedef struct {
57 unsigned int tx_link_err;
58 unsigned int rx_rmap_header_crc_err;
59 unsigned int rx_rmap_data_crc_err;
60 unsigned int rx_eep_err;
61 unsigned int rx_truncated;
62 unsigned int parity_err;
63 unsigned int escape_err;
64 unsigned int credit_err;
65 unsigned int write_sync_err;
66 unsigned int disconnect_err;
67 unsigned int early_ep;
68 unsigned int invalid_address;
69 unsigned int packets_sent;
70 unsigned int packets_received;
71} spw_stats;
72
73typedef struct {
74 unsigned int nodeaddr;
75 unsigned int destkey;
76 unsigned int clkdiv; /* Note: contain both CLKDIVSTART and CLKDIVRUN, but IOCTL_SET_CLKDIV* commands are split into two */
77 unsigned int rxmaxlen;
78 unsigned int timer;
79 unsigned int disconnect;
80 unsigned int promiscuous;
81 unsigned int rmapen;
82 unsigned int rmapbufdis;
83 unsigned int linkdisabled;
84 unsigned int linkstart;
85
86 unsigned int check_rmap_err; /* check incoming packets for rmap errors */
87 unsigned int rm_prot_id; /* remove protocol id from incoming packets */
88 unsigned int tx_blocking; /* use blocking tx */
89 unsigned int tx_block_on_full; /* block when all tx_buffers are used */
90 unsigned int rx_blocking; /* block when no data is available */
91 unsigned int disable_err; /* disable link automatically when link error is detected */
92 unsigned int link_err_irq; /* generate an interrupt when link error occurs */
93 rtems_id event_id; /* task id that should receive link err irq event */
94
95 unsigned int is_rmap;
96 unsigned int is_rxunaligned;
97 unsigned int is_rmapcrc;
98
99 unsigned int nodemask;
100 unsigned int keep_source; /* copy source address to user-buffer in read() operations
101 * Note that rm_prot_id has no effect when keep_source is
102 * set.
103 */
104 unsigned int rtimeout; /* Read timeout if != 0 */
105} spw_config;
106
107#define SPACEWIRE_IOCTRL_SET_NODEADDR 1
108#define SPACEWIRE_IOCTRL_SET_RXBLOCK 2
109#define SPACEWIRE_IOCTRL_SET_DESTKEY 4
110#define SPACEWIRE_IOCTRL_SET_CLKDIV 5
111#define SPACEWIRE_IOCTRL_SET_TIMER 6
112#define SPACEWIRE_IOCTRL_SET_DISCONNECT 7
113#define SPACEWIRE_IOCTRL_SET_PROMISCUOUS 8
114#define SPACEWIRE_IOCTRL_SET_RMAPEN 9
115#define SPACEWIRE_IOCTRL_SET_RMAPBUFDIS 10
116#define SPACEWIRE_IOCTRL_SET_CHECK_RMAP 11
117#define SPACEWIRE_IOCTRL_SET_RM_PROT_ID 12
118#define SPACEWIRE_IOCTRL_SET_TXBLOCK 14
119#define SPACEWIRE_IOCTRL_SET_DISABLE_ERR 15
120#define SPACEWIRE_IOCTRL_SET_LINK_ERR_IRQ 16
121#define SPACEWIRE_IOCTRL_SET_EVENT_ID 17
122#define SPACEWIRE_IOCTRL_SET_PACKETSIZE 20
123#define SPACEWIRE_IOCTRL_GET_LINK_STATUS 23
124#define SPACEWIRE_IOCTRL_GET_CONFIG 25
125#define SPACEWIRE_IOCTRL_GET_STATISTICS 26
126#define SPACEWIRE_IOCTRL_CLR_STATISTICS 27
127#define SPACEWIRE_IOCTRL_SEND 28
128#define SPACEWIRE_IOCTRL_LINKDISABLE 29
129#define SPACEWIRE_IOCTRL_LINKSTART 30
130#define SPACEWIRE_IOCTRL_SET_TXBLOCK_ON_FULL 31
131#define SPACEWIRE_IOCTRL_SET_COREFREQ 32
132#define SPACEWIRE_IOCTRL_SET_CLKDIVSTART 33
133#define SPACEWIRE_IOCTRL_SET_NODEMASK 34
134#define SPACEWIRE_IOCTRL_SET_KEEP_SOURCE 35
135#define SPACEWIRE_IOCTRL_SET_TCODE_CTRL 36
136#define SPACEWIRE_IOCTRL_SET_TCODE 37
137#define SPACEWIRE_IOCTRL_GET_TCODE 38
138#define SPACEWIRE_IOCTRL_SET_READ_TIMEOUT 39
139
140#define SPACEWIRE_IOCTRL_START 64
141#define SPACEWIRE_IOCTRL_STOP 65
142
143/* Defines what register bits that will be touched
144 * for SPACEWIRE_IOCTRL_SET_TCODE_CTRL
145 */
146#define SPACEWIRE_TCODE_CTRL_IE_MSK 0x001
147#define SPACEWIRE_TCODE_CTRL_TT_MSK 0x004
148#define SPACEWIRE_TCODE_CTRL_TR_MSK 0x008
149
150/* Defines what register bits that should be set
151 * for SPACEWIRE_IOCTRL_SET_TCODE_CTRL
152 */
153#define SPACEWIRE_TCODE_CTRL_IE 0x100
154#define SPACEWIRE_TCODE_CTRL_TT 0x400
155#define SPACEWIRE_TCODE_CTRL_TR 0x800
156
157/* SPACEWIRE_IOCTRL_SET_TCODE argument mask */
158#define SPACEWIRE_TCODE_TCODE 0x0ff
159#define SPACEWIRE_TCODE_SET 0x100 /* Set Timecode register */
160#define SPACEWIRE_TCODE_TX 0x400
161
162void grspw_register_drv (void);
163
164void grspw_print(int options);
165
166/* Global GRSPW Function pointer called upon timecode receive interrupt */
167extern void (*grspw_timecode_callback)
168 (void *pDev, void *regs, int minor, unsigned int tc);
169
170
171#ifdef __cplusplus
172}
173#endif
174
177#endif /* __GRSPW_H__ */
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: grspw.h:73
Definition: grspw.h:36
Definition: grspw.h:47
Definition: grspw.h:56
