RTEMS 5.2-rc1
19extern void grpwm_register_drv (
void);
21#define GRPWM_IOCTL_GET_CAP 1
22#define GRPWM_IOCTL_SET_CONFIG 2
23#define GRPWM_IOCTL_SET_SCALER 3
24#define GRPWM_IOCTL_UPDATE 4
25#define GRPWM_IOCTL_IRQ 5
44 unsigned char dbscaler;
45 unsigned char scaler_index;
48 unsigned char irqscaler;
50 void (*isr)(
int channel,
void *arg);
54 unsigned int wave_synccfg;
55 unsigned int wave_sync;
56 unsigned int *wave_data;
57 unsigned int wave_data_length;
60#define GRPWM_CONFIG_OPTION_FLIP 0x04000000
61#define GRPWM_CONFIG_OPTION_DEAD_BAND 0x00200000
62#define GRPWM_CONFIG_OPTION_SYMMETRIC 0x00000040
63#define GRPWM_CONFIG_OPTION_ASYMMERTIC 0
64#define GRPWM_CONFIG_OPTION_DUAL 0x00000020
65#define GRPWM_CONFIG_OPTION_PAIR 0x00000004
66#define GRPWM_CONFIG_OPTION_SINGLE 0x00000000
67#define GRPWM_CONFIG_OPTION_POLARITY_HIGH 0x00000002
68#define GRPWM_CONFIG_OPTION_POLARITY_LOW 0x00000000
70#define GRPWM_CONFIG_OPTION_MASK ( \
71 GRPWM_CONFIG_OPTION_DEAD_BAND | GRPWM_CONFIG_OPTION_SYMMETRIC | \
72 GRPWM_CONFIG_OPTION_DUAL | GRPWM_CONFIG_OPTION_PAIR | \
73 GRPWM_CONFIG_OPTION_POLARITY_HIGH \
79 unsigned int index_mask;
80 unsigned int values[8];
85#define GRPWM_UPDATE_OPTION_ENABLE 0x01
86#define GRPWM_UPDATE_OPTION_DISABLE 0x02
87#define GRPWM_UPDATE_OPTION_PERIOD 0x04
88#define GRPWM_UPDATE_OPTION_COMP 0x08
89#define GRPWM_UPDATE_OPTION_DBCOMP 0x10
90#define GRPWM_UPDATE_OPTION_FIX 0x20
93#define GRPWM_UPDATE_FIX_ENABLE 1
94#define GRPWM_UPDATE_FIX_DISABLE 0
95#define GRPWM_UPDATE_FIX_0_LOW 0
96#define GRPWM_UPDATE_FIX_0_HIGH 2
97#define GRPWM_UPDATE_FIX_1_LOW 0
98#define GRPWM_UPDATE_FIX_1_HIGH 4
101 unsigned int options;
103 unsigned int compare;
110 unsigned char chanmask;
116#define GRPWM_IRQ_DISABLE 0
117#define GRPWM_IRQ_PERIOD 1
118#define GRPWM_IRQ_COMPARE 3
119#define GRPWM_IRQ_CLEAR 0x10
121#define GRPWM_IRQ_CHAN 0x100
