RTEMS 5.2-rc1
grpci2dma.h
1/*
2 * GRPCI2 DMA Driver
3 *
4 * COPYRIGHT (c) 2017
5 * Cobham Gaisler AB
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 *
11 * OVERVIEW
12 * ========
13 * This driver controls the DMA on the GRPCI2 device, located
14 * at an on-chip AMBA.
15 */
16
17#ifndef __GRPCI2DMA_H__
18#define __GRPCI2DMA_H__
19
20#include <stdint.h>
21#include <stdio.h>
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
27/* Error return codes */
28#define GRPCI2DMA_ERR_OK 0
29#define GRPCI2DMA_ERR_WRONGPTR -1
30#define GRPCI2DMA_ERR_NOINIT -2
31#define GRPCI2DMA_ERR_TOOMANY -3
32#define GRPCI2DMA_ERR_ERROR -4
33#define GRPCI2DMA_ERR_STOPDMA -5
34#define GRPCI2DMA_ERR_NOTFOUND -6
35
36/* Size of a dma descriptors */
37#define GRPCI2DMA_BD_CHAN_SIZE 0x10
38#define GRPCI2DMA_BD_DATA_SIZE 0x10
39
40/* Alignment of dma descriptors */
41#define GRPCI2DMA_BD_CHAN_ALIGN 0x10
42#define GRPCI2DMA_BD_DATA_ALIGN 0x10
43
44/* User-helper functions to allocate/deallocate
45 * channel and data descriptors
46 */
47extern void * grpci2dma_channel_new(int number);
48extern void grpci2dma_channel_delete(void * chanbd);
49extern void * grpci2dma_data_new(int number);
50extern void grpci2dma_data_delete(void * databd);
51
52/* Function:
53 * -grpci2dma_prepare
54 * Description:
55 * -Prepare a transfer, initializing the required data descriptors
56 * Parameters:
57 * -pci_start: Where in PCI/remote starts the transfer
58 * -ahb_start: Where in AHB/local starts the transfer
59 * -dir: Direction of the transfer (AHBTOPCI or PCITOAHB)
60 * -endianness: Endianness of the transfer (LITTLEENDIAN or BIGENDIAN)
61 * -size: Size in bytes of the transfer (the function will calculate if there
62 * are enough descriptors)
63 * -databd: Pointer to the data descriptor buffer
64 * -bdindex: Where in the buffer to start the transfer
65 * -bdmax: Maximum index for the data descriptor buffer
66 * -block_size: Size in bytes for each PCI transaction (or block). Guaranteed
67 * to be at least smaller that this value. Put 0 to use default.
68 * Default is maximum, which is 0x10000*4 bytes.
69 * Returns:
70 * -WRONGPTR: Wrong input parameters
71 * -TOOMANY: Not enough data descriptors in the buffer
72 * -value > 0: A positive return value means the number of data descriptors
73 * prepared/used in the buffer, starting from index.
74 */
75#define GRPCI2DMA_AHBTOPCI 1
76#define GRPCI2DMA_PCITOAHB 0
77#define GRPCI2DMA_LITTLEENDIAN 1
78#define GRPCI2DMA_BIGENDIAN 0
79extern int grpci2dma_prepare(
80 uint32_t pci_start, uint32_t ahb_start, int dir, int endianness,
81 int size, void * databd, int bdindex, int bdmax, int block_size);
82
83/* Function:
84 * -grpci2dma_status
85 * Description:
86 * -Status of an transfer:
87 * Parameters:
88 * -databd: Pointer to the data descriptor buffer
89 * -bdindex: Where in the buffer starts the transfer
90 * -bdsize: Number of descriptors used by the transfer
91 * Returns:
92 * -WRONGPTR: Wrong input parameters
93 * -GRPCI2DMA_BD_DATA_STATUS_ERR: If at least one of the descriptors has an
94 * error
95 * -GRPCI2DMA_BD_DATA_STATUS_ENABLED: If at least one of the descriptors is
96 * enabled, which means that the transfer is still not finished.
97 * -GRPCI2DMA_BD_DATA_STATUS_DISABLED: If all the descriptors are disabled,
98 * which means that either the transfer finished or it was never prepared.
99 */
100#define GRPCI2DMA_BD_STATUS_DISABLED 0
101#define GRPCI2DMA_BD_STATUS_ENABLED 1
102#define GRPCI2DMA_BD_STATUS_ERR 2
103extern int grpci2dma_status(void *databd, int bdindex, int bdsize);
104
105/* Function Interrupt-Code ISR callback prototype.
106 * arg - Custom arg provided by user
107 * cid - Channel ID that got the interrupt
108 * status - Error status of the DMA core
109 */
110typedef void (*grpci2dma_isr_t)(void *arg, int cid, unsigned int status);
111
112/* Function:
113 * -grpci2dma_isr_register
114 * Description:
115 * -Register an ISR for a channel (and enable interrupts if disabled)
116 * Parameters:
117 * -chan_no: ID of the channel
118 * -dmaisr: ISR
119 * -arg: Argument to pass to the ISR when called
120 * Returns:
121 * -NOINIT: GRPCI2 DMA not initialized
122 * -WRONGPTR: Wrong input parameters
123 * -OK (=0): Done
124 */
125extern int grpci2dma_isr_register(
126 int chan_no, grpci2dma_isr_t dmaisr, void *arg);
127
128/* Function:
129 * -grpci2dma_isr_unregister
130 * Description:
131 * -Unregister an ISR for a channel (and enable interrupts if disabled)
132 * Parameters:
133 * -chan_no: ID of the channel
134 * Returns:
135 * -NOINIT: GRPCI2 DMA not initialized
136 * -WRONGPTR: Wrong input parameters
137 * -OK (=0): Done
138 */
139extern int grpci2dma_isr_unregister(int chan_no);
140
141/* Function:
142 * -grpci2dma_open
143 * Description:
144 * -Open a channel (and allocate the descriptor if the user does not provide
145 * one).
146 * Parameters:
147 * -chan: Descriptor for the channel (must be aligned to 0x10)
148 * Returns:
149 * -NOINIT: GRPCI2 DMA not initialized
150 * -TOOMANY: Maximum number of channels already opened.
151 * -WRONGPTR: Wrong input parameters
152 * -ERROR: Inconsistent state found in driver
153 * -value > 0: A positive return value means the id for the channel.
154 */
155extern int grpci2dma_open(void * chan);
156
157/* Function:
158 * -grpci2dma_close
159 * Description:
160 * -Stop and close a channel (and deallocate it if the user did not provide a
161 * pointer when opening it)
162 * Parameters:
163 * -chan_no: Id of the channel
164 * Returns:
165 * -NOINIT: GRPCI2 DMA not initialized
166 * -NOTFOUND: Channel not opened.
167 * -STOPDMA: Cannot stop channel.
168 * -WRONGPTR: Wrong input parameters
169 * -OK (=0): Done.
170 */
171extern int grpci2dma_close(int chan_no);
172
173/* Function:
174 * -grpci2dma_start
175 * Description:
176 * -Start a channel
177 * Parameters:
178 * -chan_no: Id of the channel
179 * -options: Maximum number of data descriptors to be executed before moving
180 * to next channel (up to 0x10000)
181 * Returns:
182 * -NOINIT: GRPCI2 DMA not initialized
183 * -WRONGPTR: Wrong input parameters
184 * -ERROR: Inconsistent state found in driver
185 * -OK (=0): Done.
186 */
187extern int grpci2dma_start(int chan_no, int options);
188
189/* Function:
190 * -grpci2dma_stop
191 * Description:
192 * -Start a channel
193 * Parameters:
194 * -chan_no: Id of the channel
195 * Returns:
196 * -NOINIT: GRPCI2 DMA not initialized
197 * -WRONGPTR: Wrong input parameters
198 * -ERROR: Inconsistent state found in driver
199 * -OK (=0): Done.
200 */
201extern int grpci2dma_stop(int chan_no);
202
203/* Function:
204 * -grpci2dma_push
205 * Description:
206 * -Push a transfer into a channel (already started or not)
207 * Parameters:
208 * -chan_no: Id of the channel
209 * -databd: Pointer to the data descriptor buffer
210 * -bdindex: Where in the buffer starts the transfer
211 * -bdsize: Number of descriptors used by the transfer
212 * Returns:
213 * -NOINIT: GRPCI2 DMA not initialized
214 * -WRONGPTR: Wrong input parameters
215 * -NOTFOUND: Channel not opened.
216 * -OK (=0): Done.
217 */
218extern int grpci2dma_push(int chan_no, void *databd, int bdindex, int bdsize);
219
220/* Function:
221 * -grpci2dma_active
222 * Description:
223 * -Check if dma is active
224 * Parameters:
225 * Returns:
226 * -(!=0): Active.
227 * -(=0): Not active.
228 */
229extern int grpci2dma_active(void);
230
231/* Function:
232 * -grpci2dma_interrupt_enable
233 * Description:
234 * -Enable interrupt for a transfer
235 * Parameters:
236 * -databd: Pointer to the data descriptor buffer
237 * -bdindex: Where in the buffer starts the transfer
238 * -bdmax: Upper limit for index. index < bdmax
239 * -options:
240 * (=GRPCI2DMA_OPTIONS_ALL)=Enable interrupt on all transfer descriptors.
241 * (=GRPCI2DMA_OPTIONS_ONE)=Enable interrupt on transfer descriptor
242 * indicated by bdindex.
243 * Returns:
244 * -NOINIT: GRPCI2 DMA not initialized
245 * -WRONGPTR: Wrong input parameters
246 * -ERROR: Inconsistent state found in driver
247 * -OK (=0): Done.
248 */
249#define GRPCI2DMA_OPTIONS_ALL 1
250#define GRPCI2DMA_OPTIONS_ONE 0
251extern int grpci2dma_interrupt_enable(
252 void *databd, int bdindex, int bdmax, int options);
253
254/* Debug function: print dma channel and associated data descriptors.
255 * Only prints if driver internal DEBUG flag is defined. */
256extern int grpci2dma_print(int chan_no);
257extern int grpci2dma_print_bd(void * data);
258
259#ifdef __cplusplus
260}
261#endif
262
263#endif /* __GRPCI2DMA_H__ */
unsigned size
Definition: tte.h:1
