RTEMS 5.2-rc1
Files | Macros | Enumerations
UART (Universal Asynchronous Reciever/Transmitter) Support. More...
file  lpc22xx_uart.h
 UART support.
#define FIFODEEP   16
#define BD115200   115200
#define BD38400   38400
#define BD9600   9600
#define U0_PINSEL   (0x00000005)
 PINSEL0 Value for UART0.
#define U0_PINMASK   (0x0000000F)
 PINSEL0 Mask for UART0.
#define U1_PINSEL   (0x00050000)
 PINSEL0 Value for UART1.
#define U1_PINMASK   (0x000F0000)
 PINSEL0 Mask for UART1.
enum  LPC_UartChanel_t { UART0 = 0 , UART1 }
Uart line control register bit descriptions
#define LCR_WORDLENTH_BIT   0
#define LCR_STOPBITSEL_BIT   2
#define LCR_PARITYENBALE_BIT   3
#define LCR_PARITYSEL_BIT   4
#define LCR_BREAKCONTROL_BIT   6
#define LCR_DLAB_BIT   7
Line Control Register bit definitions
#define ULCR_CHAR_5   (0 << 0)
 5-bit character length
#define ULCR_CHAR_6   (1 << 0)
 6-bit character length
#define ULCR_CHAR_7   (2 << 0)
 7-bit character length
#define ULCR_CHAR_8   (3 << 0)
 8-bit character length
#define ULCR_STOP_0   (0 << 2)
 no stop bits
#define ULCR_STOP_1   (1 << 2)
 1 stop bit
#define ULCR_PAR_NO   (0 << 3)
 No Parity.
#define ULCR_PAR_ODD   (1 << 3)
 Odd Parity.
#define ULCR_PAR_EVEN   (3 << 3)
 Even Parity.
#define ULCR_PAR_MARK   (5 << 3)
 MARK "1" Parity.
#define ULCR_PAR_SPACE   (7 << 3)
 SPACE "0" Paruty.
#define ULCR_BREAK_ENABLE   (1 << 6)
 Output BREAK line condition.
#define ULCR_DLAB_ENABLE   (1 << 7)
 Enable Divisor Latch Access.
Modem Control Register bit definitions
#define UMCR_DTR   (1 << 0)
 Data Terminal Ready.
#define UMCR_RTS   (1 << 1)
 Request To Send.
#define UMCR_LB   (1 << 4)
 Loopback.
Line Status Register bit definitions
#define ULSR_RDR   (1 << 0)
 Receive Data Ready.
#define ULSR_OE   (1 << 1)
 Overrun Error.
#define ULSR_PE   (1 << 2)
 Parity Error.
#define ULSR_FE   (1 << 3)
 Framing Error.
#define ULSR_BI   (1 << 4)
 Break Interrupt.
#define ULSR_THRE   (1 << 5)
 Transmit Holding Register Empty.
#define ULSR_TEMT   (1 << 6)
 Transmitter Empty.
#define ULSR_RXFE   (1 << 7)
 Error in Receive FIFO.
#define ULSR_ERR_MASK   0x1E
Modem Status Register bit definitions
#define UMSR_DCTS   (1 << 0)
 Delta Clear To Send.
#define UMSR_DDSR   (1 << 1)
 Delta Data Set Ready.
#define UMSR_TERI   (1 << 2)
 Trailing Edge Ring Indicator.
#define UMSR_DDCD   (1 << 3)
 Delta Data Carrier Detect.
#define UMSR_CTS   (1 << 4)
 Clear To Send.
#define UMSR_DSR   (1 << 5)
 Data Set Ready.
#define UMSR_RI   (1 << 6)
 Ring Indicator.
#define UMSR_DCD   (1 << 7)
Uart Interrupt Identification
#define IIR_RSL   0x3
#define IIR_RDA   0x2
#define IIR_CTI   0x6
#define IIR_THRE   0x1
Uart Interrupt Enable Type
#define IER_RBR   0x1
#define IER_THRE   0x2
#define IER_RLS   0x4
Uart Receiver Errors
#define RC_FIFO_OVERRUN_ERR   0x1
#define RC_OVERRUN_ERR   0x2
#define RC_PARITY_ERR   0x4
#define RC_FRAMING_ERR   0x8
#define RC_BREAK_IND   0x10
