RTEMS 5.2-rc1
Checks for unsigned characters (unsigned char). More...
| #define | T_eq_uchar(a, e) T_flags_eq_uint(a, e, 0) |
| #define | T_assert_eq_uchar(a, e) T_flags_eq_uint(a, e, T_CHECK_STOP) |
| #define | T_quiet_eq_uchar(a, e) T_flags_eq_uint(a, e, T_CHECK_QUIET) |
| #define | T_step_eq_uchar(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s)) |
| #define | T_step_assert_eq_uchar(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP) |
| #define | T_ne_uchar(a, e) T_flags_ne_uint(a, e, 0) |
| #define | T_assert_ne_uchar(a, e) T_flags_ne_uint(a, e, T_CHECK_STOP) |
| #define | T_quiet_ne_uchar(a, e) T_flags_ne_uint(a, e, T_CHECK_QUIET) |
| #define | T_step_ne_uchar(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s)) |
| #define | T_step_assert_ne_uchar(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP) |
| #define | T_ge_uchar(a, e) T_flags_ge_uint(a, e, 0) |
| #define | T_assert_ge_uchar(a, e) T_flags_ge_uint(a, e, T_CHECK_STOP) |
| #define | T_quiet_ge_uchar(a, e) T_flags_ge_uint(a, e, T_CHECK_QUIET) |
| #define | T_step_ge_uchar(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s)) |
| #define | T_step_assert_ge_uchar(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP) |
| #define | T_gt_uchar(a, e) T_flags_gt_uint(a, e, 0) |
| #define | T_assert_gt_uchar(a, e) T_flags_gt_uint(a, e, T_CHECK_STOP) |
| #define | T_quiet_gt_uchar(a, e) T_flags_gt_uint(a, e, T_CHECK_QUIET) |
| #define | T_step_gt_uchar(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s)) |
| #define | T_step_assert_gt_uchar(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP) |
| #define | T_le_uchar(a, e) T_flags_le_uint(a, e, 0) |
| #define | T_assert_le_uchar(a, e) T_flags_le_uint(a, e, T_CHECK_STOP) |
| #define | T_quiet_le_uchar(a, e) T_flags_le_uint(a, e, T_CHECK_QUIET) |
| #define | T_step_le_uchar(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s)) |
| #define | T_step_assert_le_uchar(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP) |
| #define | T_lt_uchar(a, e) T_flags_lt_uint(a, e, 0) |
| #define | T_assert_lt_uchar(a, e) T_flags_lt_uint(a, e, T_CHECK_STOP) |
| #define | T_quiet_lt_uchar(a, e) T_flags_lt_uint(a, e, T_CHECK_QUIET) |
| #define | T_step_lt_uchar(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s)) |
| #define | T_step_assert_lt_uchar(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP) |
