RTEMS 5.2-rc1
grlib_impl.h
1/*
2 * Copyright (C) 2017 Cobham Gaisler AB
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
8
9#ifndef GRLIB_IMPL_H
10#define GRLIB_IMPL_H
11
13#include <rtems/malloc.h>
14
15/*
16 * Use interrupt lock primitives compatible with SMP defined in RTEMS 4.11.99
17 * and higher.
18 */
19#if (((__RTEMS_MAJOR__ << 16) | (__RTEMS_MINOR__ << 8) | __RTEMS_REVISION__) >= 0x040b63)
20
21#include <rtems/score/isrlock.h>
22
23/* map via rtems_interrupt_lock_* API: */
24#define SPIN_DECLARE(lock) RTEMS_INTERRUPT_LOCK_MEMBER(lock)
25#define SPIN_INIT(lock, name) rtems_interrupt_lock_initialize(lock, name)
26#define SPIN_LOCK(lock, level) rtems_interrupt_lock_acquire_isr(lock, &level)
27#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_lock_acquire(lock, &level)
28#define SPIN_UNLOCK(lock, level) rtems_interrupt_lock_release_isr(lock, &level)
29#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_lock_release(lock, &level)
30#define SPIN_IRQFLAGS(k) rtems_interrupt_lock_context k
31#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
32#define SPIN_FREE(lock) rtems_interrupt_lock_destroy(lock)
33
34/* turn on/off local CPU's interrupt to ensure HW timing - not SMP safe. */
35#define IRQ_LOCAL_DECLARE(_level) rtems_interrupt_level _level
36#define IRQ_LOCAL_DISABLE(_level) rtems_interrupt_local_disable(_level)
37#define IRQ_LOCAL_ENABLE(_level) rtems_interrupt_local_enable(_level)
38
39#else
40
41#ifdef RTEMS_SMP
42#error SMP mode not compatible with these interrupt lock primitives
43#endif
44
45/* maintain single-core compatibility with older versions of RTEMS: */
46#define SPIN_DECLARE(name)
47#define SPIN_INIT(lock, name)
48#define SPIN_LOCK(lock, level)
49#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_disable(level)
50#define SPIN_UNLOCK(lock, level)
51#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_enable(level)
52#define SPIN_IRQFLAGS(k) rtems_interrupt_level k
53#define SPIN_ISR_IRQFLAGS(k)
54#define SPIN_FREE(lock)
55
56/* turn on/off local CPU's interrupt to ensure HW timing - not SMP safe. */
57#define IRQ_LOCAL_DECLARE(_level) rtems_interrupt_level _level
58#define IRQ_LOCAL_DISABLE(_level) rtems_interrupt_disable(_level)
59#define IRQ_LOCAL_ENABLE(_level) rtems_interrupt_enable(_level)
60
61#endif
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67#if (((__RTEMS_MAJOR__ << 16) | (__RTEMS_MINOR__ << 8) | __RTEMS_REVISION__) >= 0x050000)
68
69RTEMS_INLINE_ROUTINE void *grlib_malloc(size_t size)
70{
71 return rtems_malloc(size);
72}
73
74RTEMS_INLINE_ROUTINE void *grlib_calloc(size_t nelem, size_t elsize)
75{
76 return rtems_calloc(nelem, elsize);
77}
78
79#else
80
81RTEMS_INLINE_ROUTINE void *grlib_malloc(size_t size)
82{
83 return malloc(size);
84}
85
86RTEMS_INLINE_ROUTINE void *grlib_calloc(size_t nelem, size_t elsize)
87{
88 return calloc(nelem, elsize);
89}
90
91#endif
92
93#ifdef __sparc__
94
95RTEMS_INLINE_ROUTINE unsigned char grlib_read_uncached8(unsigned int address)
96{
97 unsigned char tmp;
98 __asm__ (" lduba [%1]1, %0 "
99 : "=r"(tmp)
100 : "r"(address)
101 );
102 return tmp;
103}
104
105RTEMS_INLINE_ROUTINE unsigned short grlib_read_uncached16(unsigned int addr) {
106 unsigned short tmp;
107 __asm__ (" lduha [%1]1, %0 "
108 : "=r"(tmp)
109 : "r"(addr)
110 );
111 return tmp;
112}
113
114
115RTEMS_INLINE_ROUTINE unsigned int grlib_read_uncached32(unsigned int address)
116{
117 unsigned int tmp;
118 __asm__ (" lda [%1]1, %0 "
119 : "=r"(tmp)
120 : "r"(address)
121 );
122 return tmp;
123}
124
125RTEMS_INLINE_ROUTINE uint64_t grlib_read_uncached64(uint64_t *address)
126{
127 uint64_t tmp;
128 __asm__ (" ldda [%1]1, %0 "
129 : "=r"(tmp)
130 : "r"(address)
131 );
132 return tmp;
133}
134
135#define GRLIB_DMA_IS_CACHE_COHERENT CPU_SPARC_HAS_SNOOPING
136
137#else
138
139static unsigned char __inline__ grlib_read_uncached8(unsigned int address)
140{
141 unsigned char tmp = (*(volatile unsigned char *)(address));
142 return tmp;
143}
144
145static __inline__ unsigned short grlib_read_uncached16(unsigned int address) {
146 unsigned short tmp = (*(volatile unsigned short *)(address));
147 return tmp;
148}
149
150RTEMS_INLINE_ROUTINE unsigned int grlib_read_uncached32(unsigned int address)
151{
152 unsigned int tmp = (*(volatile unsigned int *)(address));
153 return tmp;
154}
155
156#define GRLIB_DMA_IS_CACHE_COHERENT 1
157
158#endif
159
160extern struct ambapp_bus ambapp_plb;
161
162#ifdef __cplusplus
163}
164#endif
165
166#endif /* GRLIB_IMPL_H */
Basic Definitions.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
ISR Locks.
void * rtems_malloc(size_t size) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_WARN_UNUSED_RESULT
Allocates a memory area of the specified size from the heap.
void * rtems_calloc(size_t nelem, size_t elsize) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE_2(1
Allocates a memory area for the specified count of elements from the heap.
Definition: ambapp.h:126
unsigned size
Definition: tte.h:1
