RTEMS 5.2-rc1
greth.h
1/*
2 * Cobham Gaisler ethernet MAC driver
3 * adapted from Opencores driver by Marko Isomaki
4 *
5 * The license and distribution terms for this file may be
6 * found in found in the file LICENSE in this distribution or at
7 * http://www.rtems.org/license/LICENSE.
8 */
9
10#ifndef __GRETH_H__
11#define __GRETH_H__
12
13#ifdef __cplusplus
14extern "C" {
15#endif
16
17/* Ethernet configuration registers */
18
19typedef struct _greth_regs {
20 volatile uint32_t ctrl; /* Ctrl Register */
21 volatile uint32_t status; /* Status Register */
22 volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
23 volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
24 volatile uint32_t mdio_ctrl; /* MDIO control and status */
25 volatile uint32_t txdesc; /* Transmit descriptor pointer */
26 volatile uint32_t rxdesc; /* Receive descriptor pointer */
27 volatile uint32_t edcl; /* EDCL IP register */
28 volatile uint32_t ht_msb; /* Multicast MSB hash */
29 volatile uint32_t ht_lsb; /* Multicast LSB hash */
31
32#define GRETH_TOTAL_BD 128
33#define GRETH_MAXBUF_LEN 1520
34
35/* Tx BD */
36#define GRETH_TXD_ENABLE 0x0800 /* Tx BD Enable */
37#define GRETH_TXD_WRAP 0x1000 /* Tx BD Wrap (last BD) */
38#define GRETH_TXD_IRQ 0x2000 /* Tx BD IRQ Enable */
39#define GRETH_TXD_MORE 0x20000 /* Tx BD More (more descs for packet) */
40#define GRETH_TXD_IPCS 0x40000 /* Tx BD insert ip chksum */
41#define GRETH_TXD_TCPCS 0x80000 /* Tx BD insert tcp chksum */
42#define GRETH_TXD_UDPCS 0x100000 /* Tx BD insert udp chksum */
43
44#define GRETH_TXD_UNDERRUN 0x4000 /* Tx BD Underrun Status */
45#define GRETH_TXD_RETLIM 0x8000 /* Tx BD Retransmission Limit Status */
46#define GRETH_TXD_LATECOL 0x10000 /* Tx BD Late Collision */
47
48#define GRETH_TXD_STATS (GRETH_TXD_UNDERRUN | \
49 GRETH_TXD_RETLIM | \
50 GRETH_TXD_LATECOL)
51
52#define GRETH_TXD_CS (GRETH_TXD_IPCS | \
53 GRETH_TXD_TCPCS | \
54 GRETH_TXD_UDPCS)
55
56/* Rx BD */
57#define GRETH_RXD_ENABLE 0x0800 /* Rx BD Enable */
58#define GRETH_RXD_WRAP 0x1000 /* Rx BD Wrap (last BD) */
59#define GRETH_RXD_IRQ 0x2000 /* Rx BD IRQ Enable */
60
61#define GRETH_RXD_DRIBBLE 0x4000 /* Rx BD Dribble Nibble Status */
62#define GRETH_RXD_TOOLONG 0x8000 /* Rx BD Too Long Status */
63#define GRETH_RXD_CRCERR 0x10000 /* Rx BD CRC Error Status */
64#define GRETH_RXD_OVERRUN 0x20000 /* Rx BD Overrun Status */
65#define GRETH_RXD_LENERR 0x40000 /* Rx BD Length Error */
66#define GRETH_RXD_ID 0x40000 /* Rx BD IP Detected */
67#define GRETH_RXD_IR 0x40000 /* Rx BD IP Chksum Error */
68#define GRETH_RXD_UD 0x40000 /* Rx BD UDP Detected*/
69#define GRETH_RXD_UR 0x40000 /* Rx BD UDP Chksum Error */
70#define GRETH_RXD_TD 0x40000 /* Rx BD TCP Detected */
71#define GRETH_RXD_TR 0x40000 /* Rx BD TCP Chksum Error */
72
73
74#define GRETH_RXD_STATS (GRETH_RXD_OVERRUN | \
75 GRETH_RXD_DRIBBLE | \
76 GRETH_RXD_TOOLONG | \
77 GRETH_RXD_CRCERR)
78
79/* CTRL Register */
80#define GRETH_CTRL_TXEN 0x00000001 /* Transmit Enable */
81#define GRETH_CTRL_RXEN 0x00000002 /* Receive Enable */
82#define GRETH_CTRL_TXIRQ 0x00000004 /* Transmit Enable */
83#define GRETH_CTRL_RXIRQ 0x00000008 /* Receive Enable */
84#define GRETH_CTRL_FULLD 0x00000010 /* Full Duplex */
85#define GRETH_CTRL_PRO 0x00000020 /* Promiscuous (receive all) */
86#define GRETH_CTRL_RST 0x00000040 /* Reset MAC */
87#define GRETH_CTRL_SP 0x00000080 /* 100MBit speed mode */
88#define GRETH_CTRL_GB 0x00000100 /* 1GBit speed mode */
89#define GRETH_CTRL_MCE 0x00000800 /* Multicast Enable */
90#define GRETH_CTRL_DD 0x00001000 /* Disable EDCL Duplex Detection */
91#define GRETH_CTRL_ED 0x00004000 /* EDCL Disable */
92#define GRETH_CTRL_MC 0x02000000 /* Multicast available */
93#define GRETH_CTRL_ME 0x04000000 /* MDIO interrupts enabled */
94#define GRETH_CTRL_GA 0x08000000 /* Gigabit MAC available */
95
96/* Status Register */
97#define GRETH_STATUS_RXERR 0x00000001 /* Receive Error */
98#define GRETH_STATUS_TXERR 0x00000002 /* Transmit Error IRQ */
99#define GRETH_STATUS_RXIRQ 0x00000004 /* Receive Frame IRQ */
100#define GRETH_STATUS_TXIRQ 0x00000008 /* Transmit Error IRQ */
101#define GRETH_STATUS_RXAHBERR 0x00000010 /* Receiver AHB Error */
102#define GRETH_STATUS_TXAHBERR 0x00000020 /* Transmitter AHB Error */
103#define GRETH_STATUS_NRD 0x0f000000 /* Number of descriptors */
104
105/* MDIO Control */
106#define GRETH_MDIO_WRITE 0x00000001 /* MDIO Write */
107#define GRETH_MDIO_READ 0x00000002 /* MDIO Read */
108#define GRETH_MDIO_LINKFAIL 0x00000004 /* MDIO Link failed */
109#define GRETH_MDIO_BUSY 0x00000008 /* MDIO Link Busy */
110#define GRETH_MDIO_REGADR 0x000007C0 /* Register Address */
111#define GRETH_MDIO_PHYADR 0x0000F800 /* PHY address */
112#define GRETH_MDIO_DATA 0xFFFF0000 /* MDIO DATA */
113
114
115/* MII registers */
116#define GRETH_MII_EXTADV_1000FD 0x00000200
117#define GRETH_MII_EXTADV_1000HD 0x00000100
118#define GRETH_MII_EXTPRT_1000FD 0x00000800
119#define GRETH_MII_EXTPRT_1000HD 0x00000400
120
121#define GRETH_MII_100T4 0x00000200
122#define GRETH_MII_100TXFD 0x00000100
123#define GRETH_MII_100TXHD 0x00000080
124#define GRETH_MII_10FD 0x00000040
125#define GRETH_MII_10HD 0x00000020
126
127
128/* Attach routine */
129
130void greth_register_drv(void);
131
132/* PHY data */
134{
135 int vendor;
136 int device;
137 int rev;
138
139 int adv;
140 int part;
141
142 int extadv;
143 int extpart;
144};
145
146/* Limit speed modes advertised during auto-negotiation */
147#define GRETH_ADV_10_HD 0x0001
148#define GRETH_ADV_10_FD 0x0002
149#define GRETH_ADV_100_HD 0x0004
150#define GRETH_ADV_100_FD 0x0008
151#define GRETH_ADV_1000_HD 0x0010
152#define GRETH_ADV_1000_FD 0x0020
153#define GRETH_ADV_ALL 0x003f
154/*
155#ifdef CPU_U32_FIX
156void ipalign(struct mbuf *m);
157#endif
158
159*/
160#ifdef __cplusplus
161}
162#endif
163
164#endif
165
Definition: greth.h:19
Definition: rtemscompat1.h:15
Definition: greth.h:134
