RTEMS 5.2-rc1
griommu.h
1/*
2 * GRIOMMU Driver Interface
3 *
4 * COPYRIGHT (c) 2017
5 * Cobham Gaisler AB
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 *
11 * OVERVIEW
12 * ========
13 * This driver controls the GRIOMMU device located
14 * at an on-chip AMBA.
15 */
16
17#ifndef __GRIOMMU_H__
18#define __GRIOMMU_H__
19
20#include <stdint.h>
21#include <stdio.h>
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
27extern void griommu_register_drv(void);
28
29#define GRIOMMU_ERR_OK 0
30#define GRIOMMU_ERR_NOINIT -1
31#define GRIOMMU_ERR_EINVAL -2
32#define GRIOMMU_ERR_IMPLEMENTED -3
33#define GRIOMMU_ERR_NOTFOUND -4
34
35/* Size of APV (has to be divided by page size in bytes) */
36#define GRIOMMU_APV_SIZE 0x20000000
37
38/* Alignment of APV */
39#define GRIOMMU_APV_ALIGN 0x10
40
41/* IOMMU APV allocation helper functions */
42extern void * griommu_apv_new(void);
43extern void griommu_apv_delete(void * apv);
44
45/* IOMMU Master Setup */
46
47/* IOMMU Master find */
48/*
49 * GRIOMMU MASTER register fields
50 */
51#define MASTER_VENDOR (0xff << MASTER_VENDOR_BIT)
52#define MASTER_DEVICE (0xfff << MASTER_DEVICE_BIT)
53#define MASTER_BS (0x1 << MASTER_BS_BIT)
54#define MASTER_GROUP (0xf << MASTER_GROUP_BIT)
55
56#define MASTER_VENDOR_BIT 24
57#define MASTER_DEVICE_BIT 12
58#define MASTER_BS_BIT 4
59#define MASTER_GROUP_BIT 0
60
61#define GRIOMMU_OPTIONS_BUS0 0
62#define GRIOMMU_OPTIONS_BUS1 1
63extern int griommu_master_setup(int master, int group, int options);
64extern int griommu_master_find(int vendor, int device, int instance);
65extern int griommu_master_info(int master, uint32_t * info);
66#define griommu_get_master_vendor(info) \
67 ((info & MASTER_VENDOR) >> MASTER_VENDOR_BIT)
68#define griommu_get_master_device(info) \
69 ((info & MASTER_DEVICE) >> MASTER_DEVICE_BIT)
70#define griommu_get_master_routing(info) \
71 ((info & MASTER_BS) >> MASTER_BS_BIT)
72#define griommu_get_master_group(info) \
73 ((info & MASTER_GROUP) >> MASTER_GROUP_BIT)
74
75/* IOMMU Group Setup */
76#define GRIOMMU_OPTIONS_GROUP_PASSTHROUGH 2
77#define GRIOMMU_OPTIONS_GROUP_ENABLE 1
78#define GRIOMMU_OPTIONS_GROUP_DISABLE 0
79extern int griommu_group_setup(int group, void * apv, int options);
80extern int griommu_group_info(int group, uint32_t * info);
81#define GRIOMMU_OPTIONS_APV_ALLOW 0x1
82#define GRIOMMU_OPTIONS_APV_DONTALLOW 0x0
83extern int griommu_group_apv_init(int group, int options);
84extern int griommu_group_apv_address_set(int group, uint32_t addr, int size,
85 int options);
86extern int griommu_group_apv_page_set(int group, int index, int size,
87 int options);
88extern int griommu_group_apv_flush(int group);
89
90/* IOMMU Setup */
91/*
92 * GRIOMMU CTRL register fields
93 */
94#define CTRL_PGSZ (0x7 << CTRL_PGSZ_BIT)
95#define CTRL_LB (0x1 << CTRL_LB_BIT)
96#define CTRL_SP (0x1 << CTRL_SP_BIT)
97#define CTRL_ITR (0xf << CTRL_ITR_BIT)
98#define CTRL_DP (0x1 << CTRL_DP_BIT)
99#define CTRL_SIV (0x1 << CTRL_SIV_BIT)
100#define CTRL_HPROT (0x3 << CTRL_HPROT_BIT)
101#define CTRL_AU (0x1 << CTRL_AU_BIT)
102#define CTRL_WP (0x1 << CTRL_WP_BIT)
103#define CTRL_DM (0x1 << CTRL_DM_BIT)
104#define CTRL_GS (0x1 << CTRL_GS_BIT)
105#define CTRL_CE (0x1 << CTRL_CE_BIT)
106#define CTRL_PM (0x3 << CTRL_PM_BIT)
107#define CTRL_PM_APV (0x0 << CTRL_PM_BIT)
108#define CTRL_PM_IOMMU (0x1 << CTRL_PM_BIT)
109#define CTRL_EN (0x1 << CTRL_EN_BIT)
110
111#define CTRL_PGSZ_BIT 18
112#define CTRL_LB_BIT 17
113#define CTRL_SP_BIT 16
114#define CTRL_ITR_BIT 12
115#define CTRL_DP_BIT 11
116#define CTRL_SIV_BIT 10
117#define CTRL_HPROT_BIT 8
118#define CTRL_AU_BIT 7
119#define CTRL_WP_BIT 6
120#define CTRL_DM_BIT 5
121#define CTRL_GS_BIT 4
122#define CTRL_CE_BIT 3
123#define CTRL_PM_BIT 1
124#define CTRL_EN_BIT 0
125
126#define GRIOMMU_OPTIONS_LOOKUPBUS_BUS0 0
127#define GRIOMMU_OPTIONS_LOOKUPBUS_BUS1 CTRL_LB
128#define GRIOMMU_OPTIONS_CACHE_DISABLE 0
129#define GRIOMMU_OPTIONS_CACHE_ENABLE CTRL_CE
130#define GRIOMMU_OPTIONS_GROUPADDRESSING_DISABLE 0
131#define GRIOMMU_OPTIONS_GROUPADDRESSING_ENABLE CTRL_GS
132#define GRIOMMU_OPTIONS_WPROTONLY_DISABLE 0
133#define GRIOMMU_OPTIONS_WPROTONLY_ENABLE CTRL_WP
134#define GRIOMMU_OPTIONS_AHBUPDATE_DISABLE 0
135#define GRIOMMU_OPTIONS_AHBUPDATE_ENABLE CTRL_AU
136#define GRIOMMU_OPTIONS_PREFETCH_DISABLE CTRL_DP
137#define GRIOMMU_OPTIONS_PREFETCH_ENABLE 0
138#define GRIOMMU_OPTIONS_PAGESIZE_4KIB 0
139#define GRIOMMU_OPTIONS_PAGESIZE_8KIB (0x1 << CTRL_PGSZ_BIT)
140#define GRIOMMU_OPTIONS_PAGESIZE_16KIB (0x2 << CTRL_PGSZ_BIT)
141#define GRIOMMU_OPTIONS_PAGESIZE_32KIB (0x3 << CTRL_PGSZ_BIT)
142#define GRIOMMU_OPTIONS_PAGESIZE_64KIB (0x4 << CTRL_PGSZ_BIT)
143#define GRIOMMU_OPTIONS_PAGESIZE_128KIB (0x5 << CTRL_PGSZ_BIT)
144#define GRIOMMU_OPTIONS_PAGESIZE_256KIB (0x6 << CTRL_PGSZ_BIT)
145#define GRIOMMU_OPTIONS_PAGESIZE_512KIB (0x7 << CTRL_PGSZ_BIT)
146extern int griommu_setup(int options);
147extern int griommu_status(void);
148
149#define GRIOMMU_MODE_IOMMU 1
150#define GRIOMMU_MODE_GROUPAPV 0
151extern int griommu_enable(int mode);
152extern int griommu_disable(void);
153
154/* IOMMU APV setup */
155extern int griommu_apv_flush(void);
156extern int griommu_apv_init(void * apv, int options);
157extern int griommu_apv_address_set(void * apv, uint32_t addr, int size,
158 int options);
159extern int griommu_apv_page_set(void * apv, int index, int size, int options);
160
161/* GRIOMMU Interrupts */
162/* Function Interrupt-Code ISR callback prototype.
163 * arg - Custom arg provided by user
164 * access - AHB Access that failed
165 * status - Error status register of the GRIOMMU core
166 */
167typedef void (*griommu_isr_t)(void *arg, uint32_t access, uint32_t status);
168#define GRIOMMU_INTERRUPT_ALL (0x2f << 0)
169#define GRIOMMU_INTERRUPT_PARITY_ERROR (0x1 << 5)
170#define GRIOMMU_INTERRUPT_FLUSH_COMPLETED (0x1 << 3)
171#define GRIOMMU_INTERRUPT_FLUSH_START (0x1 << 2)
172#define GRIOMMU_INTERRUPT_ACCESS_DENIED (0x1 << 1)
173#define GRIOMMU_INTERRUPT_TRANSLATION_ERROR (0x1 << 0)
174extern int griommu_isr_register(griommu_isr_t isr, void * arg, int options);
175extern int griommu_isr_unregister(void);
176extern int griommu_interrupt_unmask(int options);
177extern int griommu_interrupt_mask(int options);
178
179extern int griommu_error_status(uint32_t * access);
180
181extern int griommu_print(void);
182
183#ifdef __cplusplus
184}
185#endif
186
187#endif /* __GRIOMMU_H__ */
Definition: rtemscompat1.h:15
unsigned size
Definition: tte.h:1
