RTEMS 5.2-rc1
gr1553rt.h
1/* GR1553B RT driver
2 *
3 * COPYRIGHT (c) 2010.
4 * Cobham Gaisler AB.
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef __GR1553RT_H__
12#define __GR1553RT_H__
13
14/* CONFIG OPTION: Maximum number of LIST IDs supported.
15 * There are two lists per RT subaddress, one for RX one
16 * for TX.
17 */
18#define RTLISTID_MAX 64
19
20/* CONFIG OPTION: Maximum number of Interrupt handlers per device supported
21 * max is 256 supported, and minimum is 1.
22 */
23#define RTISR_MAX 64
24
25/* CONFIG OPTION: Maximum number of transfer (RX/TX) descriptors supported.
26 *
27 * Set this option to zero to allow flexible number of descriptors,
28 * requires dynamically allocation of driver structures.
29 */
30/*#define RTBD_MAX 4096*/
31#define RTBD_MAX 0
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
37/* Register GR1553B driver needed by RT driver */
38extern void gr1553rt_register(void);
39
40struct gr1553rt_list;
41
42/* Descriptor read/written by hardware.
43 *
44 * Must be aligned to 16 byte boundary
45 */
47 volatile unsigned int ctrl; /* 0x00 Control/Status word */
48 volatile unsigned int dptr; /* 0x04 Data Pointer */
49 volatile unsigned int next; /* 0x08 Next Descriptor in list */
50 volatile unsigned int unused; /* 0x0C UNUSED BY HARDWARE */
51};
52
53/* Sub address table entry, the hardware access */
55 volatile unsigned int ctrl; /* 0x00 SUBADDRESS CONTROL WORD */
56 volatile unsigned int txptr; /* 0x04 TRANSMIT BD POINTER */
57 volatile unsigned int rxptr; /* 0x08 RECEIVE BD POINTER */
58 volatile unsigned int unused; /* 0x0C UNUSED BY HARDWARE */
59};
60
61/* Configuration of a RT-SubAddress-List */
63 unsigned int bd_cnt; /* Number of hw-descriptors in list */
64};
65
66/* A TX or RX subaddress descriptor list */
68 short listid; /* ID/NUMBER of List. -1 unassigned */
69 short subadr; /* SubAddress. -1 when not scheduled */
70 void *rt; /* Scheduled on Device */
71 struct gr1553rt_list_cfg *cfg; /* List configuration */
72 int bd_cnt; /* Number of Descriptors */
73
74 /* !!Must be last in data structure!!
75 * !!Array must at least be of length bd_cnt!!
76 */
77 unsigned short bds[0]; /* Array of BDIDs */
78};
79
80/* GR1553B-RT Driver configuration options used when calling gr1553rt_config().
81 *
82 * Note that if not custom addresses are given the driver will dynamically
83 * allocate memory for buffers.
84 * Note that if custom addresses with the LSB set, the address will be
85 * interpreted as a address accessible by hardware, and translated
86 * into an address used by CPU.
87 */
89 unsigned char rtaddress; /* RT Address 0..30 */
90
91 /*** MODE CODE CONFIG ***/
92 unsigned int modecode; /* Mode codes enable/disable/IRQ/EV-Log.
93 * Each modecode has a 2-bit cfg field.
94 * See Mode Code Control Register in
95 * hardware manual.
96 */
97
98 /*** TIME CONFIG ***/
99 unsigned short time_res; /* Time tag resolution in us */
100
101 /*** SUBADDRESS TABLE CONFIG ***/
102 void *satab_buffer; /* Optional Custom buffer. Must be
103 * At least 16*32 bytes, and be aligned
104 * to 10-bit (1KB) boundary. Set to NULL
105 * to make driver allocate buffer.
106 */
107
108 /*** EVENT LOG CONFIG ***/
109 void *evlog_buffer; /* Optional Custom buffer */
110 int evlog_size; /* Length, must be a multiple of 2.
111 * If set to ZERO event log is disabled
112 */
113
114 /*** TRANSFER DESCRIPTOR CONFIG ***/
115 int bd_count; /* Number of transfer descriptors shared
116 * by all RX/TX sub-addresses */
117 void *bd_buffer; /* Optional Custom descriptor area.
118 * Must hold bd_count*32 bytes.
119 * If NULL, descriptors will be
120 * allocated dynamically. */
121};
122
123/* GR1553B-RT status indication, copied from the RT registers and stored
124 * here. Used when calling the gr1553rt_status() function.
125 */
127 unsigned int status; /* RT Status word */
128 unsigned int bus_status; /* BUS Status */
129 unsigned short synctime; /* Time Tag of last sync with data */
130 unsigned short syncword; /* Data of last mode code synchronize
131 * with data. */
132 unsigned short time_res; /* Time resolution (set by config) */
133 unsigned short time; /* Current Time Tag */
134};
135
136/* ISR callback definition for ERRORs detected in the GR1553B-RT interrupt
137 * handler.
138 *
139 * \param err Inidicate Error type. The IRQ flag register bit mask:
140 * Bit 9 - RT DMA ERROR
141 * Bit 10 - RT Table access error
142 * \param data Custom data assigned by user
143 */
144typedef void (*gr1553rt_irqerr_t)(int err, void *data);
145
146/* ISR callback definition for modecodes that are configured to generate
147 * an IRQ. The callback is called from within the GR1553B-RT interrupt
148 * handler.
149 *
150 * \param mcode Mode code that caused this IRQ
151 * \param entry The raw Eventlog Entry
152 * \param data Custom data assigned by user
153 */
154typedef void (*gr1553rt_irqmc_t)(int mcode, unsigned int entry, void *data);
155
156/* Transfer ISR callback definition. Called from GR1553B-RT interrupt handler
157 * when an interrupt has been generated and a event logged due to a 1553
158 * transfer to this RT.
159 *
160 * \param list List (Subaddress/TransferType) that caused IRQ
161 * \param entry The raw Eventlog Entry
162 * \param bd_next Next Descriptor-entry index in the list (Subaddress/tr-type)
163 * This can be used to process all descriptors upto entry_next.
164 * \param data Custom data assigned by user
165 */
166typedef void (*gr1553rt_irq_t)(
167 struct gr1553rt_list *list,
168 unsigned int entry,
169 int bd_next,
170 void *data
171 );
172
173/* Configure a list according to configuration. Assign the list
174 * to a device, however not to a RT sub address yet. The rt
175 * is stored within list.
176 *
177 * \param rt RT Device driver identification, stored within list.
178 * \param list The list to configure
179 * \param cfg Configuration for list. Pointer to configuration is
180 * stored within list for later use.
181 */
182extern int gr1553rt_list_init
183 (
184 void *rt,
185 struct gr1553rt_list **plist,
186 struct gr1553rt_list_cfg *cfg
187 );
188
189/* Assign an Error Interrupt handler. Before the handler is called the
190 * RT hardware is stopped/disabled. The handler is optional, if not assigned
191 * the ISR will still stop the RT upon error.
192 *
193 * Errors detected by the interrupt handler:
194 * - DMA error
195 * - Subaddress table access error
196 *
197 * \param func ISR called when an error causes an interrupt.
198 * \param data Custom data given as an argument when calling ISR
199 */
200extern int gr1553rt_irq_err
201 (
202 void *rt,
203 gr1553rt_irqerr_t func,
204 void *data
205 );
206
207/* Assign a ModeCode Interrupt handler callback. Called when a 1553 modecode
208 * transfer is logged and cause an IRQ. The modecode IRQ generation is
209 * configured from "struct gr1553rt_cfg" when calling gr1553rt_config().
210 *
211 * \param func ISR called when a modecode causes an interrupt.
212 * \param data Custom data given as an argument when calling ISR
213 */
214extern int gr1553rt_irq_mc
215 (
216 void *rt,
217 gr1553rt_irqmc_t func,
218 void *data
219 );
220
221/* Assign transfer interrupt handler callback. Called when a RX or TX
222 * transfer is logged and cause an interrupt, the function is called
223 * from the GR1553B-RT driver's ISR, in interrupt context.
224 *
225 * The callback can be installed per subaddress and transfer type.
226 * Subaddress 0 and 31 are not valid (gr1553rt_irq_mc() for modecodes).
227 *
228 * \param subadr Select subaddress (1-30)
229 * \param tx 1=TX subaddress, 0=RX subaddress
230 * \param func ISR called when subaddress of spcified transfer type
231 * causes an interrupt.
232 * \param data Custom data given as an argument when calling ISR
233 */
234extern int gr1553rt_irq_sa
235 (
236 void *rt,
237 int subadr,
238 int tx,
239 gr1553rt_irq_t func,
240 void *data
241 );
242
243#define GR1553RT_BD_FLAGS_IRQEN (1<<30)
244/* Initialize a descriptor entry in a list. This is typically done
245 * prior to scheduling the list.
246 *
247 * \param entry_no Entry number in list (descriptor index in list)
248 * \param flags Enable IRQ when descriptor is accessed by setting
249 * argument GR1553RT_BD_FLAGS_IRQEN. Enabling IRQ on a
250 * descriptor basis will override SA-table IRQ config.
251 * \param dptr Data Pointer to RX or TX operation. The LSB indicate
252 * if the address must be translated into Hardware address
253 * - this is useful when a buffer close to CPU is used
254 * as a data pointer and the RT core is located over PCI.
255 * \param next Next Entry in list. Set to 0xffff for end of list. Set
256 * 0xfffe for next entry in list, wrap around to entry
257 * zero if entry_no is last descriptor in list (circular).
258 */
259extern int gr1553rt_bd_init(
260 struct gr1553rt_list *list,
261 unsigned short entry_no,
262 unsigned int flags,
263 uint16_t *dptr,
264 unsigned short next
265 );
266
267/* Manipulate/Read Control/Status and Data Pointer words of a buffer descriptor.
268 * If status is zero, the control/status word is accessed. If dptr is non-zero
269 * the data pointer word is accessed.
270 *
271 * \param list The list that the descriptor is located at
272 *
273 * \param entry_no The descriptor number accessed
274 *
275 * \param status IN/OUT. If zero no effect. If pointer is non-zero the
276 * value pointed to:
277 * IN: Written to Control/Status
278 * OUT: the value of the Control/Status word before writing.
279 *
280 * \param dptr IN/OUT. If zero no effect. If pointer is non-zero, the
281 * value pointed to:
282 * IN: non-zero: Descriptor data pointer will be updated with
283 * this value. Note that the LSB indicate if the address
284 * must be translated into hardware-aware address.
285 * OUT: The old data pointer is stored here.
286 */
287extern int gr1553rt_bd_update(
288 struct gr1553rt_list *list,
289 int entry_no,
290 unsigned int *status,
291 uint16_t **dptr
292 );
293
294/* Get the next/current descriptor processed of a RT sub-address.
295 *
296 * \param subadr RT Subaddress
297 * \param txeno Pointer to where TX descriptor number is stored.
298 * \param rxeno Pointer to where RX descriptor number is stored.
299 */
300extern int gr1553rt_indication(void *rt, int subadr, int *txeno, int *rxeno);
301
302/* Take a GR1553RT hardware device identified by minor.
303 * A pointer is returned that is used internally by the GR1553RT
304 * driver, it is used as an input parameter 'rt' to all other
305 * functions that manipulate the hardware.
306 *
307 * This function initializes the RT hardware to a stopped/disable level.
308 */
309extern void *gr1553rt_open(int minor);
310
311/* Close and stop/disable the RT hardware. */
312extern void gr1553rt_close(void *rt);
313
314/* Configure the RT. The RT device must be configured once before
315 * started. A started RT device can not be configured.
316 *
317 * \param rt The RT to configure
318 * \param cfg Configuration parameters
319 */
320extern int gr1553rt_config(void *rt, struct gr1553rt_cfg *cfg);
321
322/* Schedule a RX or TX list on a sub address. If a list has already been
323 * schduled on the subaddress and on the same transfer type (RX/TX), the
324 * old list is replaced with the list given here.
325 *
326 * \param subadr Subaddress to schedule list on
327 * \param tx Subaddress transfer type: 1=TX, 0=RX
328 * \param list Preconfigued RT list scheduled
329 */
330extern void gr1553rt_sa_schedule(
331 void *rt,
332 int subadr,
333 int tx,
334 struct gr1553rt_list *list
335 );
336
337/* Set SubAdress options. One may for example Enable or Disable a sub
338 * address RX and/or TX. See hardware manual for SA-Table configuration
339 * options.
340 *
341 * \param subadr SubAddress to configure
342 * \param mask Bit mask of option-bits written to subaddress config
343 * \param options The new options written to subaddress config.
344 *
345 */
346extern void gr1553rt_sa_setopts(
347 void *rt,
348 int subadr,
349 unsigned int mask,
350 unsigned int options
351 );
352
353/* Get The Subaddress and transfer type of a scheduled list. Normally the
354 * application knows which subaddress the list is for.
355 *
356 * \param list List to lookup information for
357 * \param subadr Pointer to where the subaddress is stored
358 * \param tx Transfer type is stored here. 1=TX, 0=RX.
359 */
360extern void gr1553rt_list_sa(
361 struct gr1553rt_list *list,
362 int *subadr,
363 int *tx
364 );
365
366/* Start RT Communication
367 *
368 * Interrupts will be enabled. The RT enabled and the "RT-run-time"
369 * part of the API will be opened for the user and parts that need the
370 * RT to be stopped are no longer available. After the RT has been
371 * started the configuration function can not be called.
372 */
373extern int gr1553rt_start(void *rt);
374
375/* Get Status of the RT core. See data structure gr1553rt_status for more
376 * information about the result. It can be used to read out:
377 * - time information
378 * - sync information
379 * - bus & RT status
380 *
381 * \param status Pointer to where the status words will be stored. They
382 * are stored according to the gr1553rt_status data structure.
383 */
384extern void gr1553rt_status(void *rt, struct gr1553rt_status *status);
385
386/* Stop RT communication. Only possible to stop an already started RT device.
387 * Interrupts are disabled and the RT Enable bit cleared.
388 */
389extern void gr1553rt_stop(void *rt);
390
391/* Set RT vector and/or bit word.
392 *
393 * - Vector Word is used in response to "Transmit vector word" BC commands
394 * - Bit Word is used in response to "Transmit bit word" BC commands
395 *
396 *
397 * \param mask Bit-Mask, bits that are 1 will result in that bit in the
398 * words register being overwritten with the value of words
399 * \param words Bits 31..16: Bit Word. Bits 15..0: Vector Word.
400 *
401 * Operation:
402 * hw_words = (hw_words & ~mask) | (words & mask)
403 */
404extern void gr1553rt_set_vecword(
405 void *rt,
406 unsigned int mask,
407 unsigned int words
408 );
409
410/* Set selectable bits of the "Bus Status Register". The bits written
411 * is determined by the "mask" bit-mask. Operation:
412 *
413 * bus_status = (bus_status & ~mask) | (sts & mask)
414 *
415 */
416extern void gr1553rt_set_bussts(void *rt, unsigned int mask, unsigned int sts);
417
418/* Read up to MAX number of entries in eventlog log.
419 *
420 * \param dst Destination address for event log entries
421 * \param max Maximal number of event log entries that an be stored into dst
422 *
423 * Return
424 * negative Failure
425 * zero No entries available at the moment
426 * positive Number of entries copied into dst
427 */
428extern int gr1553rt_evlog_read(void *rt, unsigned int *dst, int max);
429
430#ifdef __cplusplus
431}
432#endif
433
434#endif
Definition: mmu-config.c:40
Definition: gr1553rt.h:46
Definition: gr1553rt.h:88
Definition: gr1553rt.h:62
Definition: gr1553rt.h:67
Definition: gr1553rt.h:54
Definition: gr1553rt.h:126
