RTEMS 5.2-rc1
gpiolib.h
1/* GPIO Library interface
2 *
3 * COPYRIGHT (c) 2009.
4 * Cobham Gaisler AB.
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef __GPIOLIB_H__
12#define __GPIOLIB_H__
13
14#ifdef __cplusplus
15extern "C" {
16#endif
17
18/* GPIO Config of one GPIO port */
20 char mask; /* 0=Masked/1=Unmasked IRQ */
21 char irq_level; /* Edge or Level triggered IRQ */
22 char irq_polarity; /* Polarity of IRQ */
23};
24
25#define GPIOLIB_IRQ_EDGE 0
26#define GPIOLIB_IRQ_LEVEL 1
27
28#define GPIOLIB_IRQ_POL_LOW 0
29#define GPIOLIB_IRQ_POL_HIGH 1
30
31/* Libarary initialize function must be called befor any other */
32extern int gpiolib_initialize(void);
33
34/*** User Interface ***/
35
36extern void *gpiolib_open(int port);
37extern void *gpiolib_open_by_name(char *devName);
38extern void gpiolib_close(void *handle);
39
40/* Show the current status one or all GPIO ports in the system.
41 * Int port is port nunber, if port = -1 selects all ports.
42 *
43 * If port != -1, handle is used to get port.
44 * If port != -1, handle == NULL, then port is used as port number
45 */
46extern void gpiolib_show(int port, void *handle);
47
48extern int gpiolib_set_config(void *handle, struct gpiolib_config *cfg);
49extern int gpiolib_set(void *handle, int dir, int val);
50extern int gpiolib_get(void *handle, int *inval);
51extern int gpiolib_irq_clear(void *handle);
52extern int gpiolib_irq_enable(void *handle);
53extern int gpiolib_irq_disable(void *handle);
54extern int gpiolib_irq_mask(void *handle);
55extern int gpiolib_irq_unmask(void *handle);
56extern int gpiolib_irq_force(void *handle);
57extern int gpiolib_irq_register(void *handle, void *func, void *arg);
58
59/*** Driver Interface ***/
60
62 char devName[64];
63};
64
66 int (*config)(void *handle, struct gpiolib_config *cfg);
67 int (*get)(void *handle, int *val);
68 int (*irq_opts)(void *handle, unsigned int options);
69 int (*irq_register)(void *handle, void *func, void *arg);
70 int (*open)(void *handle);
71 int (*set)(void *handle, int dir, int outval);
72 int (*show)(void *handle);
73 int (*get_info)(void *handle, struct gpiolib_info *pinfo);
74};
75
76#define GPIOLIB_IRQ_ENABLE 0x01
77#define GPIOLIB_IRQ_DISABLE 0x02
78#define GPIOLIB_IRQ_CLEAR 0x04
79#define GPIOLIB_IRQ_FORCE 0x08
80#define GPIOLIB_IRQ_MASK 0x10
81#define GPIOLIB_IRQ_UNMASK 0x20
82
84 struct gpiolib_drv_ops *ops;
85};
86
87/* Register a GPIO port */
88extern int gpiolib_drv_register(struct gpiolib_drv *drv, void *handle);
89
90#ifdef __cplusplus
91}
92#endif
93
94#endif
int open(const char *path, int oflag,...)
Definition: open.c:149
Definition: deflate.c:115
Definition: gpiolib.h:19
Definition: gpiolib.h:65
Definition: gpiolib.h:83
Definition: gpiolib.h:61
