RTEMS 5.2-rc1
genirq.h
1/* General Shared Interrupt handling function interface
2 *
3 * The functions does not manipulate the IRQ controller or the
4 * interrupt level of the CPU. It simply helps the caller with
5 * managing shared interrupts where multiple interrupt routines
6 * share on interrupt vector/number.
7 *
8 * COPYRIGHT (c) 2008.
9 * Cobham Gaisler AB.
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef __GENIRQ_H__
17#define __GENIRQ_H__
18
19#ifdef __cplusplus
20extern "C" {
21#endif
22
23typedef void (*genirq_handler)(void *arg);
24typedef void* genirq_t;
25
27 unsigned int irq_cnt;
28};
29
30/* Initialize the genirq interface. Must be the first function
31 * called.
32 *
33 * Returns zero on success, otherwise failure.
34 */
35extern genirq_t genirq_init(int number_of_irqs);
36
37/* Free the dynamically allocated memory that the genirq interface has
38 * allocated. Also the handlers will be freed.
39 *
40 * Returns zero on success, otherwise failure.
41 */
42extern void genirq_destroy(genirq_t d);
43
44/* Check IRQ number validity
45 *
46 * Returns zero for valid IRQ numbers, -1 of invalid IRQ numbers.
47 */
48extern int genirq_check(genirq_t d, int irq);
49
50/* Allocate one ISR handler and initialize it. Input to genirq_register().
51 *
52 * \param isr The interrupt service routine called upon IRQ
53 * \param arg The argument given to isr() when called.
54 *
55 * Returns a pointer on success, on failure NULL is returned.
56 */
57extern void *genirq_alloc_handler(genirq_handler isr, void *arg);
58
59/* Free handler memory */
60#define genirq_free_handler(handler) free(handler)
61
62/* Register shared interrupt handler previously initialized with
63 * genirq_alloc_handler().
64 *
65 * NOTE: internal list structures are accessed and needs to be protected by
66 * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
67 *
68 * \param irq The interrupt number to register ISR on
69 * \param handler Install the pre- allocated and initialized handler.
70 *
71 * Return Values
72 * -1 = Failed
73 * 0 = Handler registered Successfully, first handler on this IRQ
74 * 1 = Handler registered Successfully, _not_ first handler on this IRQ
75 */
76extern int genirq_register(genirq_t d, int irq, void *handler);
77
78/* Unregister an previous registered interrupt handler. It is the user's
79 * responsibility to free the handler returned by genirq_unregister().
80 *
81 * NOTE: internal list structures are accessed and needs to be protected by
82 * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
83 *
84 * Return Values
85 * NULL = ISR not registered before or unable to unregister enabled ISR
86 * Pointer = ISR sucessfully unregistered. Returned is the handler pointer
87 * previously allocated with genirq_alloc_handler().
88 */
89extern void *genirq_unregister(genirq_t d, int irq,
90 genirq_handler isr, void *arg);
91
92/* Enables IRQ only for this isr[arg] combination. Records if this
93 * is the first interrupt enable, only then must interrupts be enabled
94 * on the interrupt controller.
95 *
96 * NOTE: internal list structures are accessed and needs to be protected by
97 * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
98 *
99 * Return values
100 * -1 = Failure, for example isr[arg] not registered on this irq
101 * 0 = IRQ must be enabled, it is the first IRQ handler to be enabled
102 * 1 = IRQ has already been enabled, either by isr[arg] or by another handler
103 */
104extern int genirq_enable(genirq_t d, int irq, genirq_handler isr, void *arg);
105
106/* Disables IRQ only for this isr[arg] combination. Records if this
107 * is the only interrupt handler that is enabled on this IRQ, only then
108 * must interrupts be disabled on the interrupt controller.
109 *
110 * NOTE: internal list structures are accessed and needs to be protected by
111 * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
112 *
113 * Return values
114 * -1 = Failure, for example isr[arg] not registered on this irq
115 * 0 = IRQ must be disabled, no ISR are enabled for this IRQ
116 * 1 = ISR has already been disabled, or other ISRs are still enabled
117 */
118extern int genirq_disable(genirq_t d, int irq, genirq_handler isr, void *arg);
119
120/* Must be called by user when an IRQ has fired, the argument 'irq'
121 * is the IRQ number of the IRQ which was fired.
122 *
123 * NOTE: internal list structures are accessed and needs to be protected by
124 * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
125 */
126extern void genirq_doirq(genirq_t d, int irq);
127
128#ifdef __cplusplus
129}
130#endif
131
132#endif
Definition: genirq.h:26
