RTEMS 5.2-rc1
ftpfs.h
1
7/*
8 * Copyright (c) 2009
9 * embedded brains GmbH
10 * Obere Lagerstr. 30
11 * D-82178 Puchheim
12 * Germany
13 * <rtems@embedded-brains.de>
14 *
15 * (c) Copyright 2002
16 * Thomas Doerfler
17 * IMD Ingenieurbuero fuer Microcomputertechnik
18 * Herbststr. 8
19 * 82178 Puchheim, Germany
20 * <Thomas.Doerfler@imd-systems.de>
21 *
22 * Modified by Sebastian Huber <sebastian.huber@embedded-brains.de>.
23 *
24 * This code has been created after closly inspecting "tftpdriver.c" from Eric
25 * Norum.
26 *
27 * The license and distribution terms for this file may be
28 * found in the file LICENSE in this distribution or at
29 * http://www.rtems.org/license/LICENSE.
30 */
31
32#ifndef _RTEMS_FTPFS_H
33#define _RTEMS_FTPFS_H
34
35#include <sys/time.h>
36#include <sys/ioctl.h>
37
38#include <rtems/libio.h>
39
40#ifdef __cplusplus
41extern "C" {
42#endif
43
81#define RTEMS_FTPFS_CTRL_PORT 21
82
86#define RTEMS_FTPFS_MOUNT_POINT_DEFAULT "/FTP"
87
91typedef enum {
92 RTEMS_FTPFS_IOCTL_GET_VERBOSE = _IOR( 'd', 1, bool *),
93 RTEMS_FTPFS_IOCTL_SET_VERBOSE = _IOW( 'd', 1, bool *),
94 RTEMS_FTPFS_IOCTL_GET_TIMEOUT = _IOR( 'd', 2, struct timeval *),
95 RTEMS_FTPFS_IOCTL_SET_TIMEOUT = _IOW( 'd', 2, struct timeval *)
97
105rtems_status_code rtems_ftpfs_get_verbose( const char *mount_point, bool *verbose);
106
117rtems_status_code rtems_ftpfs_set_verbose( const char *mount_point, bool verbose);
118
127 const char *mount_point,
128 struct timeval *timeout
129);
130
143 const char *mount_point,
144 const struct timeval *timeout
145);
146
154 const void *data
155);
156
157#ifdef __cplusplus
158}
159#endif
160
161#endif
int rtems_ftpfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Do not call directly, use mount().
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_status_code rtems_ftpfs_set_verbose(const char *mount_point, bool verbose)
Enables or disables the verbose mode if verbose is true or false respectively for the file system at ...
rtems_status_code rtems_ftpfs_get_timeout(const char *mount_point, struct timeval *timeout)
Returns the current timeout value in timeout for the file system at mount_point.
rtems_ftpfs_ioctl_numbers
FTP file system IO control requests.
Definition: ftpfs.h:91
rtems_status_code rtems_ftpfs_set_timeout(const char *mount_point, const struct timeval *timeout)
Sets the timeout value to timeout for the file system at mount_point.
rtems_status_code rtems_ftpfs_get_verbose(const char *mount_point, bool *verbose)
Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point.
Basic IO API.
Mount table entry.
Definition: libio.h:1604
