RTEMS 5.2-rc1
fsm.h
1/*
2 * fsm.h - {Link, IP} Control Protocol Finite State Machine definitions.
3 *
4 * Copyright (c) 1989 Carnegie Mellon University.
5 * All rights reserved.
6 *
7 * Redistribution and use in source and binary forms are permitted
8 * provided that the above copyright notice and this paragraph are
9 * duplicated in all such forms and that any documentation,
10 * advertising materials, and other materials related to such
11 * distribution and use acknowledge that the software was developed
12 * by Carnegie Mellon University. The name of the
13 * University may not be used to endorse or promote products derived
14 * from this software without specific prior written permission.
15 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16 * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17 * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18 *
19 * $Id$
20 */
21
22/*
23 * Packet header = Code, id, length.
24 */
25#define HEADERLEN 4
26
27
28/*
29 * CP (LCP, IPCP, etc.) codes.
30 */
31#define CONFREQ 1 /* Configuration Request */
32#define CONFACK 2 /* Configuration Ack */
33#define CONFNAK 3 /* Configuration Nak */
34#define CONFREJ 4 /* Configuration Reject */
35#define TERMREQ 5 /* Termination Request */
36#define TERMACK 6 /* Termination Ack */
37#define CODEREJ 7 /* Code Reject */
38
39
40/*
41 * Each FSM is described by an fsm structure and fsm callbacks.
42 */
43typedef struct fsm {
44 int unit; /* Interface unit number */
45 int protocol; /* Data Link Layer Protocol field value */
46 int state; /* State */
47 int flags; /* Contains option bits */
48 u_char id; /* Current id */
49 u_char reqid; /* Current request id */
50 u_char seen_ack; /* Have received valid Ack/Nak/Rej to Req */
51 int timeouttime; /* Timeout time in milliseconds */
52 int maxconfreqtransmits; /* Maximum Configure-Request transmissions */
53 int retransmits; /* Number of retransmissions left */
54 int maxtermtransmits; /* Maximum Terminate-Request transmissions */
55 int nakloops; /* Number of nak loops since last ack */
56 int maxnakloops; /* Maximum number of nak loops tolerated */
57 struct fsm_callbacks *callbacks; /* Callback routines */
58 char *term_reason; /* Reason for closing protocol */
59 int term_reason_len; /* Length of term_reason */
60} fsm;
61
62
63typedef struct fsm_callbacks {
64 void (*resetci) /* Reset our Configuration Information */
65 (fsm *);
66 int (*cilen) /* Length of our Configuration Information */
67 (fsm *);
68 void (*addci) /* Add our Configuration Information */
69 (fsm *, u_char *, int *);
70 int (*ackci) /* ACK our Configuration Information */
71 (fsm *, u_char *, int);
72 int (*nakci) /* NAK our Configuration Information */
73 (fsm *, u_char *, int);
74 int (*rejci) /* Reject our Configuration Information */
75 (fsm *, u_char *, int);
76 int (*reqci) /* Request peer's Configuration Information */
77 (fsm *, u_char *, int *, int);
78 void (*up) /* Called when fsm reaches OPENED state */
79 (fsm *);
80 void (*down) /* Called when fsm leaves OPENED state */
81 (fsm *);
82 void (*starting) /* Called when we want the lower layer */
83 (fsm *);
84 void (*finished) /* Called when we don't want the lower layer */
85 (fsm *);
86 void (*protreject) /* Called when Protocol-Reject received */
87 (int);
88 void (*retransmit) /* Retransmission is necessary */
89 (fsm *);
90 int (*extcode) /* Called when unknown code received */
91 (fsm *, int, int, u_char *, int);
92 char *proto_name; /* String name for protocol (for messages) */
94
95
96/*
97 * Link states.
98 */
99#define INITIAL 0 /* Down, hasn't been opened */
100#define STARTING 1 /* Down, been opened */
101#define CLOSED 2 /* Up, hasn't been opened */
102#define STOPPED 3 /* Open, waiting for down event */
103#define CLOSING 4 /* Terminating the connection, not open */
104#define STOPPING 5 /* Terminating, but open */
105#define REQSENT 6 /* We've sent a Config Request */
106#define ACKRCVD 7 /* We've received a Config Ack */
107#define ACKSENT 8 /* We've sent a Config Ack */
108#define OPENED 9 /* Connection available */
109
110
111/*
112 * Flags - indicate options controlling FSM operation
113 */
114#define OPT_PASSIVE 1 /* Don't die if we don't get a response */
115#define OPT_RESTART 2 /* Treat 2nd OPEN as DOWN, UP */
116#define OPT_SILENT 4 /* Wait for peer to speak first */
117
118
119/*
120 * Timeouts.
121 */
122#define DEFTIMEOUT 5 /* Timeout time in seconds */
123#define DEFMAXTERMREQS 2 /* Maximum Terminate-Request transmissions */
124#define DEFMAXCONFREQS 10 /* Maximum Configure-Request transmissions */
125#define DEFMAXNAKLOOPS 5 /* Maximum number of nak loops */
126
127
128/*
129 * Prototypes
130 */
131void fsm_init(fsm *);
132void fsm_lowerup(fsm *);
133void fsm_lowerdown(fsm *);
134void fsm_open(fsm *);
135void fsm_close(fsm *, char *);
136void fsm_input(fsm *, u_char *, int);
137void fsm_protreject(fsm *);
138void fsm_sdata(fsm *, u_char, u_char, u_char *, int);
139
140
141/*
142 * Variables
143 */
144extern int peer_mru[]; /* currently negotiated peer MRU (per unit) */
Definition: fsm.h:63
Definition: fsm.h:43
