RTEMS 5.2-rc1
fsl-mpc5668.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
5 *
6 * embedded brains GmbH
7 * Dornierstr. 4
8 * 82178 Puchheim
9 * Germany
10 * <info@embedded-brains.de>
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
22 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
23 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
24 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
25 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
26 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
27 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
28 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
30 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
31 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/**************************************************************************
35 * FILE NAME: mpc5668.h COPYRIGHT (c) Freescale 2009 *
36 * REVISION: 1.1 All Rights Reserved *
37 * *
38 * DESCRIPTION: *
39 * This file contain all of the register and bit field definitions for *
40 * MPC5668. *
41 **************************************************************************/
42/*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
43
44/**************************************************************************
45 * Example register & bit field write: *
46 * *
47 * <MODULE>.<REGISTER>.B.<BIT> = 1; *
48 * <MODULE>.<REGISTER>.R = 0x10000000; *
49 * *
50 **************************************************************************/
51
52#ifndef _MPC5668_H_
53#define _MPC5668_H_
54
55#ifndef ASM
56
57#include <stdint.h>
58
59#include <mpc55xx/regs-edma.h>
60
61#ifdef __cplusplus
62extern "C" {
63#endif
64
65#ifdef __MWERKS__
66#pragma push
67#pragma ANSI_strict off
68#endif
69
70/*************************************************************************/
71/* MODULE : ADC */
72/*************************************************************************/
73 struct ADC_tag {
74
75 union {
76 uint32_t R;
77 struct {
78 uint32_t OWREN:1;
79 uint32_t WLSIDE:1;
80 uint32_t MODE:1;
81 uint32_t EDGLEV:1;
82 uint32_t TRGEN:1;
83 uint32_t EDGE:1;
84 uint32_t XSTRTEN:1;
85 uint32_t NSTART:1;
86 uint32_t:1;
87 uint32_t JTRGEN:1;
88 uint32_t JEDGE:1;
89 uint32_t JSTART:1;
90 uint32_t:2;
91 uint32_t CTUEN:1;
92 uint32_t:8;
93 uint32_t ADCLKSEL:1;
94 uint32_t ABORTCHAIN:1;
95 uint32_t ABORT:1;
96 uint32_t ACKO:1;
97 uint32_t OFFREFRESH:1;
98 uint32_t OFFCANC:1;
99 uint32_t:2;
100 uint32_t PWDN:1;
101 } B;
102 } MCR; /* MAIN CONFIGURATION REGISTER */
103
104 union {
105 uint32_t R;
106 struct {
107 uint32_t:7;
108 uint32_t NSTART:1;
109 uint32_t JABORT:1;
110 uint32_t:2;
111 uint32_t JSTART:1;
112 uint32_t:3;
113 uint32_t CTUSTART:1;
114 uint32_t CHADDR:7;
115 uint32_t:3;
116 uint32_t ACKO:1;
117 uint32_t OFFREFRESH:1;
118 uint32_t OFFCANC:1;
119 uint32_t ADCSTATUS:3;
120 } B;
121 } MSR; /* MAIN STATUS REGISTER */
122
123 uint32_t adc_reserved1[2];
124
125 union {
126 uint32_t R;
127 struct {
128 uint32_t:25;
129 uint32_t OFFCANCOVR:1;
130 uint32_t EOFFSET:1;
131 uint32_t EOCTU:1;
132 uint32_t JEOC:1;
133 uint32_t JECH:1;
134 uint32_t EOC:1;
135 uint32_t ECH:1;
136 } B;
137 } ISR; /* INTERRUPT STATUS REGISTER */
138
139 union {
140 uint32_t R;
141 struct {
142 uint32_t EOCCH31:1;
143 uint32_t EOCCH30:1;
144 uint32_t EOCCH29:1;
145 uint32_t EOCCH28:1;
146 uint32_t EOCCH27:1;
147 uint32_t EOCCH26:1;
148 uint32_t EOCCH25:1;
149 uint32_t EOCCH24:1;
150 uint32_t EOCCH23:1;
151 uint32_t EOCCH22:1;
152 uint32_t EOCCH21:1;
153 uint32_t EOCCH20:1;
154 uint32_t EOCCH19:1;
155 uint32_t EOCCH18:1;
156 uint32_t EOCCH17:1;
157 uint32_t EOCCH16:1;
158 uint32_t EOCCH15:1;
159 uint32_t EOCCH14:1;
160 uint32_t EOCCH13:1;
161 uint32_t EOCCH12:1;
162 uint32_t EOCCH11:1;
163 uint32_t EOCCH10:1;
164 uint32_t EOCCH9:1;
165 uint32_t EOCCH8:1;
166 uint32_t EOCCH7:1;
167 uint32_t EOCCH6:1;
168 uint32_t EOCCH5:1;
169 uint32_t EOCCH4:1;
170 uint32_t EOCCH3:1;
171 uint32_t EOCCH2:1;
172 uint32_t EOCCH1:1;
173 uint32_t EOCCH0:1;
174 } B;
175 } CEOCFR0; /* CHANNEL PENDING REGISTER 0 */
176
177 union {
178 uint32_t R;
179 struct {
180 uint32_t EOCCH63:1;
181 uint32_t EOCCH62:1;
182 uint32_t EOCCH61:1;
183 uint32_t EOCCH60:1;
184 uint32_t EOCCH59:1;
185 uint32_t EOCCH58:1;
186 uint32_t EOCCH57:1;
187 uint32_t EOCCH56:1;
188 uint32_t EOCCH55:1;
189 uint32_t EOCCH54:1;
190 uint32_t EOCCH53:1;
191 uint32_t EOCCH52:1;
192 uint32_t EOCCH51:1;
193 uint32_t EOCCH50:1;
194 uint32_t EOCCH49:1;
195 uint32_t EOCCH48:1;
196 uint32_t EOCCH47:1;
197 uint32_t EOCCH46:1;
198 uint32_t EOCCH45:1;
199 uint32_t EOCCH44:1;
200 uint32_t EOCCH43:1;
201 uint32_t EOCCH42:1;
202 uint32_t EOCCH41:1;
203 uint32_t EOCCH40:1;
204 uint32_t EOCCH39:1;
205 uint32_t EOCCH38:1;
206 uint32_t EOCCH37:1;
207 uint32_t EOCCH36:1;
208 uint32_t EOCCH35:1;
209 uint32_t EOCCH34:1;
210 uint32_t EOCCH33:1;
211 uint32_t EOCCH32:1;
212 } B;
213 } CEOCFR1; /* CHANNEL PENDING REGISTER 1 */
214
215 union {
216 uint32_t R;
217 struct {
218 uint32_t EOCCH95:1;
219 uint32_t EOCCH94:1;
220 uint32_t EOCCH93:1;
221 uint32_t EOCCH92:1;
222 uint32_t EOCCH91:1;
223 uint32_t EOCCH90:1;
224 uint32_t EOCCH89:1;
225 uint32_t EOCCH88:1;
226 uint32_t EOCCH87:1;
227 uint32_t EOCCH86:1;
228 uint32_t EOCCH85:1;
229 uint32_t EOCCH84:1;
230 uint32_t EOCCH83:1;
231 uint32_t EOCCH82:1;
232 uint32_t EOCCH81:1;
233 uint32_t EOCCH80:1;
234 uint32_t EOCCH79:1;
235 uint32_t EOCCH78:1;
236 uint32_t EOCCH77:1;
237 uint32_t EOCCH76:1;
238 uint32_t EOCCH75:1;
239 uint32_t EOCCH74:1;
240 uint32_t EOCCH73:1;
241 uint32_t EOCCH72:1;
242 uint32_t EOCCH71:1;
243 uint32_t EOCCH70:1;
244 uint32_t EOCCH69:1;
245 uint32_t EOCCH68:1;
246 uint32_t EOCCH67:1;
247 uint32_t EOCCH66:1;
248 uint32_t EOCCH65:1;
249 uint32_t EOCCH64:1;
250 } B;
251 } CEOCFR2; /* CHANNEL PENDING REGISTER 2 */
252
253 union {
254 uint32_t R;
255 struct {
256 uint32_t:25;
257 uint32_t MSKOFFCANCOVR:1;
258 uint32_t MSKEOFFSET:1;
259 uint32_t MSKEOCTU:1;
260 uint32_t MSKJEOC:1;
261 uint32_t MSKJECH:1;
262 uint32_t MSKEOC:1;
263 uint32_t MSKECH:1;
264 } B;
265 } IMR; /* INTERRUPT MASK REGISTER */
266
267 union {
268 uint32_t R;
269 struct {
270 uint32_t CIM31:1;
271 uint32_t CIM30:1;
272 uint32_t CIM29:1;
273 uint32_t CIM28:1;
274 uint32_t CIM27:1;
275 uint32_t CIM26:1;
276 uint32_t CIM25:1;
277 uint32_t CIM24:1;
278 uint32_t CIM23:1;
279 uint32_t CIM22:1;
280 uint32_t CIM21:1;
281 uint32_t CIM20:1;
282 uint32_t CIM19:1;
283 uint32_t CIM18:1;
284 uint32_t CIM17:1;
285 uint32_t CIM16:1;
286 uint32_t CIM15:1;
287 uint32_t CIM14:1;
288 uint32_t CIM13:1;
289 uint32_t CIM12:1;
290 uint32_t CIM11:1;
291 uint32_t CIM10:1;
292 uint32_t CIM9:1;
293 uint32_t CIM8:1;
294 uint32_t CIM7:1;
295 uint32_t CIM6:1;
296 uint32_t CIM5:1;
297 uint32_t CIM4:1;
298 uint32_t CIM3:1;
299 uint32_t CIM2:1;
300 uint32_t CIM1:1;
301 uint32_t CIM0:1;
302 } B;
303 } CIMR0; /* CHANNEL INTERRUPT MASK REGISTER 0 */
304
305 union {
306 uint32_t R;
307 struct {
308 uint32_t CIM63:1;
309 uint32_t CIM62:1;
310 uint32_t CIM61:1;
311 uint32_t CIM60:1;
312 uint32_t CIM59:1;
313 uint32_t CIM58:1;
314 uint32_t CIM57:1;
315 uint32_t CIM56:1;
316 uint32_t CIM55:1;
317 uint32_t CIM54:1;
318 uint32_t CIM53:1;
319 uint32_t CIM52:1;
320 uint32_t CIM51:1;
321 uint32_t CIM50:1;
322 uint32_t CIM49:1;
323 uint32_t CIM48:1;
324 uint32_t CIM47:1;
325 uint32_t CIM46:1;
326 uint32_t CIM45:1;
327 uint32_t CIM44:1;
328 uint32_t CIM43:1;
329 uint32_t CIM42:1;
330 uint32_t CIM41:1;
331 uint32_t CIM40:1;
332 uint32_t CIM39:1;
333 uint32_t CIM38:1;
334 uint32_t CIM37:1;
335 uint32_t CIM36:1;
336 uint32_t CIM35:1;
337 uint32_t CIM34:1;
338 uint32_t CIM33:1;
339 uint32_t CIM32:1;
340 } B;
341 } CIMR1; /* CHANNEL INTERRUPT MASK REGISTER 1 */
342
343 union {
344 uint32_t R;
345 struct {
346 uint32_t CIM63:1;
347 uint32_t CIM62:1;
348 uint32_t CIM61:1;
349 uint32_t CIM60:1;
350 uint32_t CIM59:1;
351 uint32_t CIM58:1;
352 uint32_t CIM57:1;
353 uint32_t CIM56:1;
354 uint32_t CIM55:1;
355 uint32_t CIM54:1;
356 uint32_t CIM53:1;
357 uint32_t CIM52:1;
358 uint32_t CIM51:1;
359 uint32_t CIM50:1;
360 uint32_t CIM49:1;
361 uint32_t CIM48:1;
362 uint32_t CIM47:1;
363 uint32_t CIM46:1;
364 uint32_t CIM45:1;
365 uint32_t CIM44:1;
366 uint32_t CIM43:1;
367 uint32_t CIM42:1;
368 uint32_t CIM41:1;
369 uint32_t CIM40:1;
370 uint32_t CIM39:1;
371 uint32_t CIM38:1;
372 uint32_t CIM37:1;
373 uint32_t CIM36:1;
374 uint32_t CIM35:1;
375 uint32_t CIM34:1;
376 uint32_t CIM33:1;
377 uint32_t CIM32:1;
378 } B;
379 } CIMR2; /* CHANNEL INTERRUPT MASK REGISTER 2 */
380
381 union {
382 uint32_t R;
383 struct {
384 uint32_t:24;
385 uint32_t WDG3H:1;
386 uint32_t WDG2H:1;
387 uint32_t WDG1H:1;
388 uint32_t WDG0H:1;
389 uint32_t WDG3L:1;
390 uint32_t WDG2L:1;
391 uint32_t WDG1L:1;
392 uint32_t WDG0L:1;
393 } B;
394 } WTISR; /* WATCHDOG INTERRUPT THRESHOLD REGISTER */
395
396 union {
397 uint32_t R;
398 struct {
399 uint32_t:24;
400 uint32_t MSKWDG3H:1;
401 uint32_t MSKWDG2H:1;
402 uint32_t MSKWDG1H:1;
403 uint32_t MSKWDG0H:1;
404 uint32_t MSKWDG3L:1;
405 uint32_t MSKWDG2L:1;
406 uint32_t MSKWDG1L:1;
407 uint32_t MSKWDG0L:1;
408 } B;
409 } WTIMR; /* WATCHDOG INTERRUPT THRESHOLD MASK REGISTER */
410
411 uint32_t adc_reserved2[2];
412
413 union {
414 uint32_t R;
415 struct {
416 uint32_t:30;
417 uint32_t DCLR:1;
418 uint32_t DMAEN:1;
419 } B;
420 } DMAE; /* DMA ENABLE REGISTER */
421
422 union {
423 uint32_t R;
424 struct {
425 uint32_t DMA31:1;
426 uint32_t DMA30:1;
427 uint32_t DMA29:1;
428 uint32_t DMA28:1;
429 uint32_t DMA27:1;
430 uint32_t DMA26:1;
431 uint32_t DMA25:1;
432 uint32_t DMA24:1;
433 uint32_t DMA23:1;
434 uint32_t DMA22:1;
435 uint32_t DMA21:1;
436 uint32_t DMA20:1;
437 uint32_t DMA19:1;
438 uint32_t DMA18:1;
439 uint32_t DMA17:1;
440 uint32_t DMA16:1;
441 uint32_t DMA15:1;
442 uint32_t DMA14:1;
443 uint32_t DMA13:1;
444 uint32_t DMA12:1;
445 uint32_t DMA11:1;
446 uint32_t DMA10:1;
447 uint32_t DMA9:1;
448 uint32_t DMA8:1;
449 uint32_t DMA7:1;
450 uint32_t DMA6:1;
451 uint32_t DMA5:1;
452 uint32_t DMA4:1;
453 uint32_t DMA3:1;
454 uint32_t DMA2:1;
455 uint32_t DMA1:1;
456 uint32_t DMA0:1;
457 } B;
458 } DMAR0; /* DMA CHANNEL SELECT REGISTER 0 */
459
460 union {
461 uint32_t R;
462 struct {
463 uint32_t DMA63:1;
464 uint32_t DMA62:1;
465 uint32_t DMA61:1;
466 uint32_t DMA60:1;
467 uint32_t DMA59:1;
468 uint32_t DMA58:1;
469 uint32_t DMA57:1;
470 uint32_t DMA56:1;
471 uint32_t DMA55:1;
472 uint32_t DMA54:1;
473 uint32_t DMA53:1;
474 uint32_t DMA52:1;
475 uint32_t DMA51:1;
476 uint32_t DMA50:1;
477 uint32_t DMA49:1;
478 uint32_t DMA48:1;
479 uint32_t DMA47:1;
480 uint32_t DMA46:1;
481 uint32_t DMA45:1;
482 uint32_t DMA44:1;
483 uint32_t DMA43:1;
484 uint32_t DMA42:1;
485 uint32_t DMA41:1;
486 uint32_t DMA40:1;
487 uint32_t DMA39:1;
488 uint32_t DMA38:1;
489 uint32_t DMA37:1;
490 uint32_t DMA36:1;
491 uint32_t DMA35:1;
492 uint32_t DMA34:1;
493 uint32_t DMA33:1;
494 uint32_t DMA32:1;
495 } B;
496 } DMAR1; /* DMA CHANNEL SELECT REGISTER 1 */
497
498 union {
499 uint32_t R;
500 struct {
501 uint32_t DMA95:1;
502 uint32_t DMA94:1;
503 uint32_t DMA93:1;
504 uint32_t DMA92:1;
505 uint32_t DMA91:1;
506 uint32_t DMA90:1;
507 uint32_t DMA89:1;
508 uint32_t DMA88:1;
509 uint32_t DMA87:1;
510 uint32_t DMA86:1;
511 uint32_t DMA85:1;
512 uint32_t DMA84:1;
513 uint32_t DMA83:1;
514 uint32_t DMA82:1;
515 uint32_t DMA81:1;
516 uint32_t DMA80:1;
517 uint32_t DMA79:1;
518 uint32_t DMA78:1;
519 uint32_t DMA77:1;
520 uint32_t DMA76:1;
521 uint32_t DMA75:1;
522 uint32_t DMA74:1;
523 uint32_t DMA73:1;
524 uint32_t DMA72:1;
525 uint32_t DMA71:1;
526 uint32_t DMA70:1;
527 uint32_t DMA69:1;
528 uint32_t DMA68:1;
529 uint32_t DMA67:1;
530 uint32_t DMA66:1;
531 uint32_t DMA65:1;
532 uint32_t DMA64:1;
533 } B;
534 } DMAR2; /* DMA CHANNEL SELECT REGISTER 2 */
535
536 union {
537 uint32_t R;
538 struct {
539 uint32_t:16;
540 uint32_t THREN:1;
541 uint32_t THRINV:1;
542 uint32_t THROP:1;
543 uint32_t:6;
544 uint32_t THRCH:7;
545 } B;
546 } TRC[4]; /* THRESHOLD CONTROL REGISTER */
547
548 union {
549 uint32_t R;
550 struct {
551 uint32_t:6;
552 uint32_t THRH:10;
553 uint32_t:6;
554 uint32_t THRL:10;
555 } B;
556 } THRHLR[4]; /* THRESHOLD REGISTER */
557
558 union {
559 uint32_t R;
560 struct {
561 uint32_t:6;
562 uint32_t THRH:10;
563 uint32_t:6;
564 uint32_t THRL:10;
565 } B;
566 } THRALT[4]; /* ALTERNATE THRESHOLD REGISTER */
567
568 union {
569 uint32_t R;
570 struct {
571 uint32_t:25;
572 uint32_t PREVAL2:2;
573 uint32_t PREVAL1:2;
574 uint32_t PREVAL0:2;
575 uint32_t PRECONV:1;
576 } B;
577 } PSCR; /* PRESAMPLING CONTROL REGISTER */
578
579 union {
580 uint32_t R;
581 struct {
582 uint32_t PSR31:1;
583 uint32_t PSR30:1;
584 uint32_t PSR29:1;
585 uint32_t PSR28:1;
586 uint32_t PSR27:1;
587 uint32_t PSR26:1;
588 uint32_t PSR25:1;
589 uint32_t PSR24:1;
590 uint32_t PSR23:1;
591 uint32_t PSR22:1;
592 uint32_t PSR21:1;
593 uint32_t PSR20:1;
594 uint32_t PSR19:1;
595 uint32_t PSR18:1;
596 uint32_t PSR17:1;
597 uint32_t PSR16:1;
598 uint32_t PSR15:1;
599 uint32_t PSR14:1;
600 uint32_t PSR13:1;
601 uint32_t PSR12:1;
602 uint32_t PSR11:1;
603 uint32_t PSR10:1;
604 uint32_t PSR9:1;
605 uint32_t PSR8:1;
606 uint32_t PSR7:1;
607 uint32_t PSR6:1;
608 uint32_t PSR5:1;
609 uint32_t PSR4:1;
610 uint32_t PSR3:1;
611 uint32_t PSR2:1;
612 uint32_t PSR1:1;
613 uint32_t PSR0:1;
614 } B;
615 } PSR0; /* PRESAMPLING REGISTER 0 */
616
617 union {
618 uint32_t R;
619 struct {
620 uint32_t PSR63:1;
621 uint32_t PSR62:1;
622 uint32_t PSR61:1;
623 uint32_t PSR60:1;
624 uint32_t PSR59:1;
625 uint32_t PSR58:1;
626 uint32_t PSR57:1;
627 uint32_t PSR56:1;
628 uint32_t PSR55:1;
629 uint32_t PSR54:1;
630 uint32_t PSR53:1;
631 uint32_t PSR52:1;
632 uint32_t PSR51:1;
633 uint32_t PSR50:1;
634 uint32_t PSR49:1;
635 uint32_t PSR48:1;
636 uint32_t PSR47:1;
637 uint32_t PSR46:1;
638 uint32_t PSR45:1;
639 uint32_t PSR44:1;
640 uint32_t PSR43:1;
641 uint32_t PSR42:1;
642 uint32_t PSR41:1;
643 uint32_t PSR40:1;
644 uint32_t PSR39:1;
645 uint32_t PSR38:1;
646 uint32_t PSR37:1;
647 uint32_t PSR36:1;
648 uint32_t PSR35:1;
649 uint32_t PSR34:1;
650 uint32_t PSR33:1;
651 uint32_t PSR32:1;
652 } B;
653 } PSR1; /* PRESAMPLING REGISTER 1 */
654
655 union {
656 uint32_t R;
657 struct {
658 uint32_t PSR95:1;
659 uint32_t PSR94:1;
660 uint32_t PSR93:1;
661 uint32_t PSR92:1;
662 uint32_t PSR91:1;
663 uint32_t PSR90:1;
664 uint32_t PSR89:1;
665 uint32_t PSR88:1;
666 uint32_t PSR87:1;
667 uint32_t PSR86:1;
668 uint32_t PSR85:1;
669 uint32_t PSR84:1;
670 uint32_t PSR83:1;
671 uint32_t PSR82:1;
672 uint32_t PSR81:1;
673 uint32_t PSR80:1;
674 uint32_t PSR79:1;
675 uint32_t PSR78:1;
676 uint32_t PSR77:1;
677 uint32_t PSR76:1;
678 uint32_t PSR75:1;
679 uint32_t PSR74:1;
680 uint32_t PSR73:1;
681 uint32_t PSR72:1;
682 uint32_t PSR71:1;
683 uint32_t PSR70:1;
684 uint32_t PSR69:1;
685 uint32_t PSR68:1;
686 uint32_t PSR67:1;
687 uint32_t PSR66:1;
688 uint32_t PSR65:1;
689 uint32_t PSR64:1;
690 } B;
691 } PSR2; /* PRESAMPLING REGISTER 2 */
692
693 uint32_t adc_reserved3;
694
695 union {
696 uint32_t R;
697 struct {
698 uint32_t:16;
699 uint32_t INPLATCH:1;
700 uint32_t:1;
701 uint32_t OFFSHIFT:2;
702 uint32_t:1;
703 uint32_t INPCMP:2;
704 uint32_t:1;
705 uint32_t INPSAMP:8;
706 } B;
707 } CTR0; /* CONVERSION TIMING REGISTER 0 */
708
709 union {
710 uint32_t R;
711 struct {
712 uint32_t:16;
713 uint32_t INPLATCH:1;
714 uint32_t:4;
715 uint32_t INPCMP:2;
716 uint32_t:1;
717 uint32_t INPSAMP:8;
718 } B;
719 } CTR1; /* CONVERSION TIMING REGISTER 1 */
720
721 union {
722 uint32_t R;
723 struct {
724 uint32_t:16;
725 uint32_t INPLATCH:1;
726 uint32_t:4;
727 uint32_t INPCMP:2;
728 uint32_t:1;
729 uint32_t INPSAMP:8;
730 } B;
731 } CTR2; /* CONVERSION TIMING REGISTER 2 */
732
733 uint32_t adc_reserved4;
734
735 union {
736 uint32_t R;
737 struct {
738 uint32_t CH31:1;
739 uint32_t CH30:1;
740 uint32_t CH29:1;
741 uint32_t CH28:1;
742 uint32_t CH27:1;
743 uint32_t CH26:1;
744 uint32_t CH25:1;
745 uint32_t CH24:1;
746 uint32_t CH23:1;
747 uint32_t CH22:1;
748 uint32_t CH21:1;
749 uint32_t CH20:1;
750 uint32_t CH19:1;
751 uint32_t CH18:1;
752 uint32_t CH17:1;
753 uint32_t CH16:1;
754 uint32_t CH15:1;
755 uint32_t CH14:1;
756 uint32_t CH13:1;
757 uint32_t CH12:1;
758 uint32_t CH11:1;
759 uint32_t CH10:1;
760 uint32_t CH9:1;
761 uint32_t CH8:1;
762 uint32_t CH7:1;
763 uint32_t CH6:1;
764 uint32_t CH5:1;
765 uint32_t CH4:1;
766 uint32_t CH3:1;
767 uint32_t CH2:1;
768 uint32_t CH1:1;
769 uint32_t CH0:1;
770 } B;
771 } NCMR0; /* NORMAL CONVERSION MASK REGISTER 0 */
772
773 union {
774 uint32_t R;
775 struct {
776 uint32_t CH63:1;
777 uint32_t CH62:1;
778 uint32_t CH61:1;
779 uint32_t CH60:1;
780 uint32_t CH59:1;
781 uint32_t CH58:1;
782 uint32_t CH57:1;
783 uint32_t CH56:1;
784 uint32_t CH55:1;
785 uint32_t CH54:1;
786 uint32_t CH53:1;
787 uint32_t CH52:1;
788 uint32_t CH51:1;
789 uint32_t CH50:1;
790 uint32_t CH49:1;
791 uint32_t CH48:1;
792 uint32_t CH47:1;
793 uint32_t CH46:1;
794 uint32_t CH45:1;
795 uint32_t CH44:1;
796 uint32_t CH43:1;
797 uint32_t CH42:1;
798 uint32_t CH41:1;
799 uint32_t CH40:1;
800 uint32_t CH39:1;
801 uint32_t CH38:1;
802 uint32_t CH37:1;
803 uint32_t CH36:1;
804 uint32_t CH35:1;
805 uint32_t CH34:1;
806 uint32_t CH33:1;
807 uint32_t CH32:1;
808 } B;
809 } NCMR1; /* NORMAL CONVERSION MASK REGISTER 1 */
810
811 union {
812 uint32_t R;
813 struct {
814 uint32_t PSR95:1;
815 uint32_t PSR94:1;
816 uint32_t PSR93:1;
817 uint32_t PSR92:1;
818 uint32_t PSR91:1;
819 uint32_t PSR90:1;
820 uint32_t PSR89:1;
821 uint32_t PSR88:1;
822 uint32_t PSR87:1;
823 uint32_t PSR86:1;
824 uint32_t PSR85:1;
825 uint32_t PSR84:1;
826 uint32_t PSR83:1;
827 uint32_t PSR82:1;
828 uint32_t PSR81:1;
829 uint32_t PSR80:1;
830 uint32_t PSR79:1;
831 uint32_t PSR78:1;
832 uint32_t PSR77:1;
833 uint32_t PSR76:1;
834 uint32_t PSR75:1;
835 uint32_t PSR74:1;
836 uint32_t PSR73:1;
837 uint32_t PSR72:1;
838 uint32_t PSR71:1;
839 uint32_t PSR70:1;
840 uint32_t PSR69:1;
841 uint32_t PSR68:1;
842 uint32_t PSR67:1;
843 uint32_t PSR66:1;
844 uint32_t PSR65:1;
845 uint32_t PSR64:1;
846 } B;
847 } NCMR2; /* NORMAL CONVERSION MASK REGISTER 2 */
848
849 uint32_t adc_reserved5;
850
851 union {
852 uint32_t R;
853 struct {
854 uint32_t CH31:1;
855 uint32_t CH30:1;
856 uint32_t CH29:1;
857 uint32_t CH28:1;
858 uint32_t CH27:1;
859 uint32_t CH26:1;
860 uint32_t CH25:1;
861 uint32_t CH24:1;
862 uint32_t CH23:1;
863 uint32_t CH22:1;
864 uint32_t CH21:1;
865 uint32_t CH20:1;
866 uint32_t CH19:1;
867 uint32_t CH18:1;
868 uint32_t CH17:1;
869 uint32_t CH16:1;
870 uint32_t CH15:1;
871 uint32_t CH14:1;
872 uint32_t CH13:1;
873 uint32_t CH12:1;
874 uint32_t CH11:1;
875 uint32_t CH10:1;
876 uint32_t CH9:1;
877 uint32_t CH8:1;
878 uint32_t CH7:1;
879 uint32_t CH6:1;
880 uint32_t CH5:1;
881 uint32_t CH4:1;
882 uint32_t CH3:1;
883 uint32_t CH2:1;
884 uint32_t CH1:1;
885 uint32_t CH0:1;
886 } B;
887 } JCMR0; /* INJECTED CONVERSION MASK REGISTER 0 */
888
889 union {
890 uint32_t R;
891 struct {
892 uint32_t CH63:1;
893 uint32_t CH62:1;
894 uint32_t CH61:1;
895 uint32_t CH60:1;
896 uint32_t CH59:1;
897 uint32_t CH58:1;
898 uint32_t CH57:1;
899 uint32_t CH56:1;
900 uint32_t CH55:1;
901 uint32_t CH54:1;
902 uint32_t CH53:1;
903 uint32_t CH52:1;
904 uint32_t CH51:1;
905 uint32_t CH50:1;
906 uint32_t CH49:1;
907 uint32_t CH48:1;
908 uint32_t CH47:1;
909 uint32_t CH46:1;
910 uint32_t CH45:1;
911 uint32_t CH44:1;
912 uint32_t CH43:1;
913 uint32_t CH42:1;
914 uint32_t CH41:1;
915 uint32_t CH40:1;
916 uint32_t CH39:1;
917 uint32_t CH38:1;
918 uint32_t CH37:1;
919 uint32_t CH36:1;
920 uint32_t CH35:1;
921 uint32_t CH34:1;
922 uint32_t CH33:1;
923 uint32_t CH32:1;
924 } B;
925 } JCMR1; /* INJECTED CONVERSION MASK REGISTER 1 */
926
927 union {
928 uint32_t R;
929 struct {
930 uint32_t PSR95:1;
931 uint32_t PSR94:1;
932 uint32_t PSR93:1;
933 uint32_t PSR92:1;
934 uint32_t PSR91:1;
935 uint32_t PSR90:1;
936 uint32_t PSR89:1;
937 uint32_t PSR88:1;
938 uint32_t PSR87:1;
939 uint32_t PSR86:1;
940 uint32_t PSR85:1;
941 uint32_t PSR84:1;
942 uint32_t PSR83:1;
943 uint32_t PSR82:1;
944 uint32_t PSR81:1;
945 uint32_t PSR80:1;
946 uint32_t PSR79:1;
947 uint32_t PSR78:1;
948 uint32_t PSR77:1;
949 uint32_t PSR76:1;
950 uint32_t PSR75:1;
951 uint32_t PSR74:1;
952 uint32_t PSR73:1;
953 uint32_t PSR72:1;
954 uint32_t PSR71:1;
955 uint32_t PSR70:1;
956 uint32_t PSR69:1;
957 uint32_t PSR68:1;
958 uint32_t PSR67:1;
959 uint32_t PSR66:1;
960 uint32_t PSR65:1;
961 uint32_t PSR64:1;
962 } B;
963 } JCMR2; /* INJECTED CONVERSION MASK REGISTER 2 */
964
965 union {
966 uint32_t R;
967 struct {
968 uint32_t:15;
969 uint32_t OFFSETLOAD:1;
970 uint32_t:8;
971 uint32_t OFFSET_WORD:8;
972 } B;
973 } OFFWR; /* OFFSET WORD REGISTER */
974
975 union {
976 uint32_t R;
977 struct {
978 uint32_t:24;
979 uint32_t DSD:8;
980 } B;
981 } DSDR; /* DECODE SIGNALS DELAY REGISTER */
982
983 union {
984 uint32_t R;
985 struct {
986 uint32_t:24;
987 uint32_t PDED:8;
988 } B;
989 } PDEDR; /* DECODE SIGNALS DELAY REGISTER */
990
991 uint32_t adc_reserved6[9];
992
993 union {
994 uint32_t R;
995 struct {
996 uint32_t:16;
997 uint32_t TEST_CTL:16;
998 } B;
999 } TCTLR; /* TEST CONTROL REGISTER */
1000
1001 uint32_t adc_reserved7[3];
1002
1003 union {
1004 uint32_t R;
1005 struct {
1006 uint32_t:12;
1007 uint32_t VALID:1;
1008 uint32_t OVERW:1;
1009 uint32_t RESULT:2;
1010 uint32_t:6;
1011 uint32_t CDATA:10;
1012 } B;
1013 } PRECDATAREG[32]; /* PRESISION DATA REGISTER */
1014
1015 union {
1016 uint32_t R;
1017 struct {
1018 uint32_t:12;
1019 uint32_t VALID:1;
1020 uint32_t OVERW:1;
1021 uint32_t RESULT:2;
1022 uint32_t:6;
1023 uint32_t CDATA:10;
1024 } B;
1025 } INTDATAREG[32]; /* PRESISION DATA REGISTER */
1026
1027 union {
1028 uint32_t R;
1029 struct {
1030 uint32_t:12;
1031 uint32_t VALID:1;
1032 uint32_t OVERW:1;
1033 uint32_t RESULT:2;
1034 uint32_t:6;
1035 uint32_t CDATA:10;
1036 } B;
1037 } EXTDATAREG[32]; /* PRESISION DATA REGISTER */
1038
1039 }; /* end of ADC_tag */
1040/**************************************************************************/
1041/* MODULE : AXBS Crossbar Switch (XBAR) */
1042/**************************************************************************/
1043 struct XBAR_tag {
1044
1045 union {
1046 uint32_t R;
1047 struct {
1048 uint32_t:1;
1049 uint32_t MSTR7:3;
1050 uint32_t:1;
1051 uint32_t MSTR6:3;
1052 uint32_t:9;
1053 uint32_t MSTR5:3;
1054 uint32_t:1;
1055 uint32_t MSTR3:3;
1056 uint32_t:1;
1057 uint32_t MSTR2:3;
1058 uint32_t:1;
1059 uint32_t MSTR1:3;
1060 uint32_t:1;
1061 uint32_t MSTR0:1;
1062 } B;
1063 } MPR0; /* Master Priority Register 0 */
1064
1065 uint32_t xbar_reserved1[3];
1066
1067 union {
1068 uint32_t R;
1069 struct {
1070 uint32_t R0:1;
1071 uint32_t:21;
1072 uint32_t ARB:2;
1073 uint32_t:2;
1074 uint32_t PCTL:2;
1075 uint32_t:1;
1076 uint32_t PARK:3;
1077 } B;
1078 } SGPCR0; /* Master Priority Register 0 */
1079
1080 uint32_t xbar_reserved2[58];
1081
1082 union {
1083 uint32_t R;
1084 struct {
1085 uint32_t:1;
1086 uint32_t MSTR7:3;
1087 uint32_t:1;
1088 uint32_t MSTR6:3;
1089 uint32_t:9;
1090 uint32_t MSTR5:3;
1091 uint32_t:1;
1092 uint32_t MSTR3:3;
1093 uint32_t:1;
1094 uint32_t MSTR2:3;
1095 uint32_t:1;
1096 uint32_t MSTR1:3;
1097 uint32_t:1;
1098 uint32_t MSTR0:1;
1099 } B;
1100 } MPR1; /* Master Priority Register 1 */
1101
1102 uint32_t xbar_reserved3[3];
1103
1104 union {
1105 uint32_t R;
1106 struct {
1107 uint32_t R0:1;
1108 uint32_t:21;
1109 uint32_t ARB:2;
1110 uint32_t:2;
1111 uint32_t PCTL:2;
1112 uint32_t:1;
1113 uint32_t PARK:3;
1114 } B;
1115 } SGPCR1; /* Master Priority Register 1 */
1116
1117 uint32_t xbar_reserved4[58];
1118
1119 union {
1120 uint32_t R;
1121 struct {
1122 uint32_t:1;
1123 uint32_t MSTR7:3;
1124 uint32_t:1;
1125 uint32_t MSTR6:3;
1126 uint32_t:9;
1127 uint32_t MSTR5:3;
1128 uint32_t:1;
1129 uint32_t MSTR3:3;
1130 uint32_t:1;
1131 uint32_t MSTR2:3;
1132 uint32_t:1;
1133 uint32_t MSTR1:3;
1134 uint32_t:1;
1135 uint32_t MSTR0:1;
1136 } B;
1137 } MPR2; /* Master Priority Register 2 */
1138
1139 uint32_t xbar_reserved5[3];
1140
1141 union {
1142 uint32_t R;
1143 struct {
1144 uint32_t R0:1;
1145 uint32_t:21;
1146 uint32_t ARB:2;
1147 uint32_t:2;
1148 uint32_t PCTL:2;
1149 uint32_t:1;
1150 uint32_t PARK:3;
1151 } B;
1152 } SGPCR2; /* Master Priority Register 2 */
1153
1154 uint32_t xbar_reserved6[58];
1155
1156 union {
1157 uint32_t R;
1158 struct {
1159 uint32_t:1;
1160 uint32_t MSTR7:3;
1161 uint32_t:1;
1162 uint32_t MSTR6:3;
1163 uint32_t:9;
1164 uint32_t MSTR5:3;
1165 uint32_t:1;
1166 uint32_t MSTR3:3;
1167 uint32_t:1;
1168 uint32_t MSTR2:3;
1169 uint32_t:1;
1170 uint32_t MSTR1:3;
1171 uint32_t:1;
1172 uint32_t MSTR0:1;
1173 } B;
1174 } MPR3; /* Master Priority Register 3 */
1175
1176 uint32_t xbar_reserved7[3];
1177
1178 union {
1179 uint32_t R;
1180 struct {
1181 uint32_t R0:1;
1182 uint32_t:21;
1183 uint32_t ARB:2;
1184 uint32_t:2;
1185 uint32_t PCTL:2;
1186 uint32_t:1;
1187 uint32_t PARK:3;
1188 } B;
1189 } SGPCR3; /* Master Priority Register 3 */
1190
1191 uint32_t xbar_reserved8[186];
1192
1193 union {
1194 uint32_t R;
1195 struct {
1196 uint32_t:1;
1197 uint32_t MSTR7:3;
1198 uint32_t:1;
1199 uint32_t MSTR6:3;
1200 uint32_t:9;
1201 uint32_t MSTR5:3;
1202 uint32_t:1;
1203 uint32_t MSTR3:3;
1204 uint32_t:1;
1205 uint32_t MSTR2:3;
1206 uint32_t:1;
1207 uint32_t MSTR1:3;
1208 uint32_t:1;
1209 uint32_t MSTR0:1;
1210 } B;
1211 } MPR6; /* Master Priority Register 6 */
1212
1213 uint32_t xbar_reserved9[3];
1214
1215 union {
1216 uint32_t R;
1217 struct {
1218 uint32_t R0:1;
1219 uint32_t:21;
1220 uint32_t ARB:2;
1221 uint32_t:2;
1222 uint32_t PCTL:2;
1223 uint32_t:1;
1224 uint32_t PARK:3;
1225 } B;
1226 } SGPCR6; /* Master Priority Register 6 */
1227
1228 uint32_t xbar_reserved10[58];
1229
1230 union {
1231 uint32_t R;
1232 struct {
1233 uint32_t:1;
1234 uint32_t MSTR7:3;
1235 uint32_t:1;
1236 uint32_t MSTR6:3;
1237 uint32_t:9;
1238 uint32_t MSTR5:3;
1239 uint32_t:1;
1240 uint32_t MSTR3:3;
1241 uint32_t:1;
1242 uint32_t MSTR2:3;
1243 uint32_t:1;
1244 uint32_t MSTR1:3;
1245 uint32_t:1;
1246 uint32_t MSTR0:1;
1247 } B;
1248 } MPR7; /* Master Priority Register 7 */
1249
1250 uint32_t xbar_reserved11[3];
1251
1252 union {
1253 uint32_t R;
1254 struct {
1255 uint32_t R0:1;
1256 uint32_t:21;
1257 uint32_t ARB:2;
1258 uint32_t:2;
1259 uint32_t PCTL:2;
1260 uint32_t:1;
1261 uint32_t PARK:3;
1262 } B;
1263 } SGPCR7; /* Master Priority Register 7 */
1264
1265 uint32_t xbar_reserved12[506];
1266
1267 union {
1268 uint32_t R;
1269 struct {
1270 uint32_t R0:1;
1271 uint32_t:21;
1272 uint32_t ARB:2;
1273 uint32_t:2;
1274 uint32_t PCTL:2;
1275 uint32_t:1;
1276 uint32_t PARK:3;
1277 } B;
1278 } MGPCR7; /* Master General Purpose Register 7 */
1279
1280 };
1281/*************************************************************************/
1282/* MODULE : CRP */
1283/*************************************************************************/
1284 struct CRP_tag {
1285
1286 union {
1287 uint32_t R;
1288 struct {
1289 uint32_t IRCTRIMEN:1;
1290 uint32_t:4;
1291 uint32_t PREDIV:3;
1292 uint32_t:4;
1293 uint32_t EN128KIRC:1;
1294 uint32_t EN32KOSC:1;
1295 uint32_t ENLPOSC:1;
1296 uint32_t EN40MOSC:1;
1297 uint32_t:3;
1298 uint32_t TRIM128IRC:5;
1299 uint32_t:2;
1300 uint32_t TRIM16IRC:6;
1301 } B;
1302 } CLKSRC; /* CLOCK SOURCE REGISTER */
1303
1304 uint32_t crp_reserved1[3];
1305
1306 union {
1307 uint32_t R;
1308 struct {
1309 uint32_t CNTEN:1;
1310 uint32_t RTCIE:1;
1311 uint32_t FRZEN:1;
1312 uint32_t ROVREN:1;
1313 uint32_t RTCVAL:12;
1314 uint32_t APIEN:1;
1315 uint32_t APIIE:1;
1316 uint32_t CLKSEL:2;
1317 uint32_t DIV512EN:1;
1318 uint32_t DIV32EN:1;
1319 uint32_t APIVAL:10;
1320 } B;
1321 } RTCC; /* RTC CONTROL REGISTER */
1322
1323 union {
1324 uint32_t R;
1325 struct {
1326 uint32_t:2;
1327 uint32_t RTCF:1;
1328 uint32_t:15;
1329 uint32_t APIF:1;
1330 uint32_t:2;
1331 uint32_t ROVRF:1;
1332 uint32_t:10;
1333 } B;
1334 } RTSC; /* RTC STATUS REGISTER */
1335
1336 union {
1337 uint32_t R;
1338 struct {
1339 uint32_t RTCCNT:32;
1340 } B;
1341 } RTCCNT; /* RTC Counter Register */
1342
1343 uint32_t crp_reserved2[9];
1344
1345 union {
1346 uint32_t R;
1347 struct {
1348 uint32_t PWK31:2;
1349 uint32_t PWK30:2;
1350 uint32_t PWK29:2;
1351 uint32_t PWK28:2;
1352 uint32_t PWK27:2;
1353 uint32_t PWK26:2;
1354 uint32_t PWK25:2;
1355 uint32_t PWK24:2;
1356 uint32_t PWK23:2;
1357 uint32_t PWK22:2;
1358 uint32_t PWK21:2;
1359 uint32_t PWK20:2;
1360 uint32_t PWK19:2;
1361 uint32_t PWK18:2;
1362 uint32_t PWK17:2;
1363 uint32_t PWK16:2;
1364 } B;
1365 } PWKENH; /* PIN WAKEUP ENABLE HIGH REGISTER */
1366
1367 union {
1368 uint32_t R;
1369 struct {
1370 uint32_t PWK15:2;
1371 uint32_t PWK14:2;
1372 uint32_t PWK13:2;
1373 uint32_t PWK12:2;
1374 uint32_t PWK11:2;
1375 uint32_t PWK10:2;
1376 uint32_t PWK9:2;
1377 uint32_t PWK8:2;
1378 uint32_t PWK7:2;
1379 uint32_t PWK6:2;
1380 uint32_t PWK5:2;
1381 uint32_t PWK4:2;
1382 uint32_t PWK3:2;
1383 uint32_t PWK2:2;
1384 uint32_t PWK1:2;
1385 uint32_t PWK0:2;
1386 } B;
1387 } PWKENL; /* PIN WAKEUP ENABLE LOW REGISTER */
1388
1389 union {
1390 uint32_t R;
1391 struct {
1392 uint32_t PWKSRCIE31:1;
1393 uint32_t PWKSRCIE30:1;
1394 uint32_t PWKSRCIE29:1;
1395 uint32_t PWKSRCIE28:1;
1396 uint32_t PWKSRCIE27:1;
1397 uint32_t PWKSRCIE26:1;
1398 uint32_t PWKSRCIE25:1;
1399 uint32_t PWKSRCIE24:1;
1400 uint32_t PWKSRCIE23:1;
1401 uint32_t PWKSRCIE22:1;
1402 uint32_t PWKSRCIE21:1;
1403 uint32_t PWKSRCIE20:1;
1404 uint32_t PWKSRCIE19:1;
1405 uint32_t PWKSRCIE18:1;
1406 uint32_t PWKSRCIE17:1;
1407 uint32_t PWKSRCIE16:1;
1408 uint32_t PWKSRCIE15:1;
1409 uint32_t PWKSRCIE14:1;
1410 uint32_t PWKSRCIE13:1;
1411 uint32_t PWKSRCIE12:1;
1412 uint32_t PWKSRCIE11:1;
1413 uint32_t PWKSRCIE10:1;
1414 uint32_t PWKSRCIE9:1;
1415 uint32_t PWKSRCIE8:1;
1416 uint32_t PWKSRCIE7:1;
1417 uint32_t PWKSRCIE6:1;
1418 uint32_t PWKSRCIE5:1;
1419 uint32_t PWKSRCIE4:1;
1420 uint32_t PWKSRCIE3:1;
1421 uint32_t PWKSRCIE2:1;
1422 uint32_t PWKSRCIE1:1;
1423 uint32_t PWKSRCIE0:1;
1424 } B;
1425 } PWKSRCIE; /* PIN WAKEUP SOURCE INTERRUPT ENABLE REGISTER */
1426
1427 union {
1428 uint32_t R;
1429 struct {
1430 uint32_t PWKSRCIE31:1;
1431 uint32_t PWKSRCIE30:1;
1432 uint32_t PWKSRCIE29:1;
1433 uint32_t PWKSRCIE28:1;
1434 uint32_t PWKSRCIE27:1;
1435 uint32_t PWKSRCIE26:1;
1436 uint32_t PWKSRCIE25:1;
1437 uint32_t PWKSRCIE24:1;
1438 uint32_t PWKSRCIE23:1;
1439 uint32_t PWKSRCIE22:1;
1440 uint32_t PWKSRCIE21:1;
1441 uint32_t PWKSRCIE20:1;
1442 uint32_t PWKSRCIE19:1;
1443 uint32_t PWKSRCIE18:1;
1444 uint32_t PWKSRCIE17:1;
1445 uint32_t PWKSRCIE16:1;
1446 uint32_t PWKSRCIE15:1;
1447 uint32_t PWKSRCIE14:1;
1448 uint32_t PWKSRCIE13:1;
1449 uint32_t PWKSRCIE12:1;
1450 uint32_t PWKSRCIE11:1;
1451 uint32_t PWKSRCIE10:1;
1452 uint32_t PWKSRCIE9:1;
1453 uint32_t PWKSRCIE8:1;
1454 uint32_t PWKSRCIE7:1;
1455 uint32_t PWKSRCIE6:1;
1456 uint32_t PWKSRCIE5:1;
1457 uint32_t PWKSRCIE4:1;
1458 uint32_t PWKSRCIE3:1;
1459 uint32_t PWKSRCIE2:1;
1460 uint32_t PWKSRCIE1:1;
1461 uint32_t PWKSRCIE0:1;
1462 } B;
1463 } PWKSRCF; /* PIN WAKEUP SOURCE FLAG REGISTER */
1464
1465 union {
1466 uint32_t R;
1467 struct {
1468 uint32_t Z6VECB:20;
1469 uint32_t:10;
1470 uint32_t Z6RST:1;
1471 uint32_t VLE:1;
1472 } B;
1473 } Z6VEC; /* Z6 RESET VECTOR REGISTER */
1474
1475 union {
1476 uint32_t R;
1477 struct {
1478 uint32_t Z0VECB:30;
1479 uint32_t Z0RST:1;
1480 uint32_t:1;
1481 } B;
1482 } Z0VEC; /* Z0 RESET VECTOR REGISTER */
1483
1484 union {
1485 uint32_t R;
1486 struct {
1487 uint32_t RECPTR:30;
1488 uint32_t FASTREC:1;
1489 uint32_t:1;
1490 } B;
1491 } RECPTR; /* RESET RECOVERY POINTER REGISTER */
1492
1493 uint32_t crp_reserved3;
1494
1495 union {
1496 uint32_t R;
1497 struct {
1498 uint32_t SLEEPF:1;
1499 uint32_t:12;
1500 uint32_t RTCOVRWKF:1;
1501 uint32_t RTCWKF:1;
1502 uint32_t APIWKF:1;
1503 uint32_t SLEEP:1;
1504 uint32_t:4;
1505 uint32_t RAMSEL:3;
1506 uint32_t:4;
1507 uint32_t WKCLKSEL:1;
1508 uint32_t RTCOVRWKEN:1;
1509 uint32_t RTCWKEN:1;
1510 uint32_t APIWKEN:1;
1511 } B;
1512 } PSCR; /* POWER STATUS AND CONTROL REGISTER */
1513
1514 uint32_t crp_reserved4[3];
1515
1516 union {
1517 uint32_t R;
1518 struct {
1519 uint32_t LVI5LOCK:1;
1520 uint32_t LVI5RE:1;
1521 uint32_t:7;
1522 uint32_t LVI5HIE:1;
1523 uint32_t LVI5NIE:1;
1524 uint32_t LVI5IE:1;
1525 uint32_t:2;
1526 uint32_t FRIE:1;
1527 uint32_t FDIS:1;
1528 uint32_t:9;
1529 uint32_t LVI5HIF:1;
1530 uint32_t LVI5NF:1;
1531 uint32_t LVI5F:1;
1532 uint32_t:2;
1533 uint32_t FRF:1;
1534 uint32_t FRDY:1;
1535 } B;
1536 } SOCSC; /* LVI Status and Control Register */
1537
1538 }; /* end of CRP_tag */
1539/*************************************************************************/
1540/* MODULE : CTU */
1541/*************************************************************************/
1542 struct CTU_tag {
1543
1544 union {
1545 uint32_t R;
1546 struct {
1547 uint32_t:24;
1548 uint32_t TRGIEN:1;
1549 uint32_t TRGI:1;
1550 uint32_t:2;
1551 uint32_t PRESC_CONF:4;
1552 } B;
1553 } CSR; /* Control Status Register */
1554
1555 union {
1556 uint32_t R;
1557 struct {
1558 uint32_t:23;
1559 uint32_t SV:9;
1560 } B;
1561 } SVR[7]; /* Start Value Register */
1562
1563 union {
1564 uint32_t R;
1565 struct {
1566 uint32_t:23;
1567 uint32_t CV:9;
1568 } B;
1569 } CVR[4]; /* Current Value Register */
1570
1571 union {
1572 uint32_t R;
1573 struct {
1574 uint32_t:16;
1575 uint32_t TM:1;
1576 uint32_t:1;
1577 uint32_t COUNT_GROUP:2;
1578 uint32_t:1;
1579 uint32_t DELAY_INDEX:3;
1580 uint32_t CLR_FG:1;
1581 uint32_t:1;
1582 uint32_t CHANNEL_VALUE:6;
1583 } B;
1584 } EVTCFGR[33]; /* Event Configuration Register */
1585
1586 }; /* end of CTU_tag */
1587/*************************************************************************/
1588/* MODULE : DMAMUX */
1589/*************************************************************************/
1590 struct DMAMUX_tag {
1591 union {
1592 uint8_t R;
1593 struct {
1594 uint8_t ENBL:1;
1595 uint8_t TRIG:1;
1596 uint8_t SOURCE:6;
1597 } B;
1598 } CHCONFIG[32]; /* DMA Channel Configuration Register */
1599
1600 }; /* end of DMAMUX_tag */
1601/*************************************************************************/
1602/* MODULE : DSPI */
1603/*************************************************************************/
1604 struct DSPI_tag {
1605 union DSPI_MCR_tag {
1606 uint32_t R;
1607 struct {
1608 uint32_t MSTR:1;
1609 uint32_t CONT_SCKE:1;
1610 uint32_t DCONF:2;
1611 uint32_t FRZ:1;
1612 uint32_t MTFE:1;
1613 uint32_t PCSSE:1;
1614 uint32_t ROOE:1;
1615 uint32_t:2;
1616 uint32_t PCSIS5:1;
1617 uint32_t PCSIS4:1;
1618 uint32_t PCSIS3:1;
1619 uint32_t PCSIS2:1;
1620 uint32_t PCSIS1:1;
1621 uint32_t PCSIS0:1;
1622 uint32_t:1;
1623 uint32_t MDIS:1;
1624 uint32_t DIS_TXF:1;
1625 uint32_t DIS_RXF:1;
1626 uint32_t CLR_TXF:1;
1627 uint32_t CLR_RXF:1;
1628 uint32_t SMPL_PT:2;
1629 uint32_t:7;
1630 uint32_t HALT:1;
1631 } B;
1632 } MCR; /* Module Configuration Register */
1633
1634 uint32_t dspi_reserved1;
1635
1636 union {
1637 uint32_t R;
1638 struct {
1639 uint32_t SPI_TCNT:16;
1640 uint32_t:16;
1641 } B;
1642 } TCR;
1643
1644 union DSPI_CTAR_tag {
1645 uint32_t R;
1646 struct {
1647 uint32_t DBR:1;
1648 uint32_t FMSZ:4;
1649 uint32_t CPOL:1;
1650 uint32_t CPHA:1;
1651 uint32_t LSBFE:1;
1652 uint32_t PCSSCK:2;
1653 uint32_t PASC:2;
1654 uint32_t PDT:2;
1655 uint32_t PBR:2;
1656 uint32_t CSSCK:4;
1657 uint32_t ASC:4;
1658 uint32_t DT:4;
1659 uint32_t BR:4;
1660 } B;
1661 } CTAR[8]; /* Clock and Transfer Attributes Registers */
1662
1663 union DSPI_SR_tag {
1664 uint32_t R;
1665 struct {
1666 uint32_t TCF:1;
1667 uint32_t TXRXS:1;
1668 uint32_t:1;
1669 uint32_t EOQF:1;
1670 uint32_t TFUF:1;
1671 uint32_t:1;
1672 uint32_t TFFF:1;
1673 uint32_t:5;
1674 uint32_t RFOF:1;
1675 uint32_t:1;
1676 uint32_t RFDF:1;
1677 uint32_t:1;
1678 uint32_t TXCTR:4;
1679 uint32_t TXNXTPTR:4;
1680 uint32_t RXCTR:4;
1681 uint32_t POPNXTPTR:4;
1682 } B;
1683 } SR; /* Status Register */
1684
1685 union DSPI_RSER_tag {
1686 uint32_t R;
1687 struct {
1688 uint32_t TCFRE:1;
1689 uint32_t:2;
1690 uint32_t EOQFRE:1;
1691 uint32_t TFUFRE:1;
1692 uint32_t:1;
1693 uint32_t TFFFRE:1;
1694 uint32_t TFFFDIRS:1;
1695 uint32_t:4;
1696 uint32_t RFOFRE:1;
1697 uint32_t:1;
1698 uint32_t RFDFRE:1;
1699 uint32_t RFDFDIRS:1;
1700 uint32_t:16;
1701 } B;
1702 } RSER; /* DMA/Interrupt Request Select and Enable Register */
1703
1704 union DSPI_PUSHR_tag {
1705 uint32_t R;
1706 struct {
1707 uint32_t CONT:1;
1708 uint32_t CTAS:3;
1709 uint32_t EOQ:1;
1710 uint32_t CTCNT:1;
1711 uint32_t:4;
1712 uint32_t PCS5:1;
1713 uint32_t PCS4:1;
1714 uint32_t PCS3:1;
1715 uint32_t PCS2:1;
1716 uint32_t PCS1:1;
1717 uint32_t PCS0:1;
1718 uint32_t TXDATA:16;
1719 } B;
1720 } PUSHR; /* PUSH TX FIFO Register */
1721
1722 union DSPI_POPR_tag {
1723 uint32_t R;
1724 struct {
1725 uint32_t:16;
1726 uint32_t RXDATA:16;
1727 } B;
1728 } POPR; /* POP RX FIFO Register */
1729
1730 union {
1731 uint32_t R;
1732 struct {
1733 uint32_t TXCMD:16;
1734 uint32_t TXDATA:16;
1735 } B;
1736 } TXFR[4]; /* Transmit FIFO Registers */
1737
1738 uint32_t DSPI_reserved_txf[12];
1739
1740 union {
1741 uint32_t R;
1742 struct {
1743 uint32_t:16;
1744 uint32_t RXDATA:16;
1745 } B;
1746 } RXFR[4]; /* Transmit FIFO Registers */
1747
1748 uint32_t DSPI_reserved_rxf[12];
1749
1750 union {
1751 uint32_t R;
1752 struct {
1753 uint32_t:11;
1754 uint32_t TSBC:1;
1755 uint32_t TXSS:1;
1756 uint32_t:2;
1757 uint32_t CID:1;
1758 uint32_t DCONT:1;
1759 uint32_t DSICTAS:3;
1760 uint32_t:6;
1761 uint32_t DPCS5:1;
1762 uint32_t DPCS4:1;
1763 uint32_t DPCS3:1;
1764 uint32_t DPCS2:1;
1765 uint32_t DPCS1:1;
1766 uint32_t DPCS0:1;
1767 } B;
1768 } DSICR; /* DSI Configuration Register */
1769
1770 union {
1771 uint32_t R;
1772 struct {
1773 uint32_t SER_DATA:32;
1774 } B;
1775 } SDR; /* DSI Serialization Data Register */
1776
1777 union {
1778 uint32_t R;
1779 struct {
1780 uint32_t ASER_DATA:32;
1781 } B;
1782 } ASDR; /* DSI Alternate Serialization Data Register */
1783
1784 union {
1785 uint32_t R;
1786 struct {
1787 uint32_t COMP_DATA:32;
1788 } B;
1789 } COMPR; /* DSI Transmit Comparison Register */
1790
1791 union {
1792 uint32_t R;
1793 struct {
1794 uint32_t DESER_DATA:32;
1795 } B;
1796 } DDR; /* DSI deserialization Data Register */
1797
1798 union {
1799 uint32_t R;
1800 struct {
1801 uint32_t:3;
1802 uint32_t TSBCNT:5;
1803 uint32_t:16;
1804 uint32_t DPCS1_7:1;
1805 uint32_t DPCS1_6:1;
1806 uint32_t DPCS1_5:1;
1807 uint32_t DPCS1_4:1;
1808 uint32_t DPCS1_3:1;
1809 uint32_t DPCS1_2:1;
1810 uint32_t DPCS1_1:1;
1811 uint32_t DPCS1_0:1;
1812 } B;
1813 } DSICR1; /* DSI Configuration Register 1 */
1814
1815 }; /* end of DSPI_tag */
1816/*************************************************************************/
1817/* MODULE : ECSM */
1818/*************************************************************************/
1819 struct ECSM_tag {
1820
1821 uint32_t ecsm_reserved1[9];
1822
1823 union {
1824 uint32_t R;
1825 struct {
1826 uint32_t FXSBE0:1;
1827 uint32_t FXSBE1:1;
1828 uint32_t FXSBE2:1;
1829 uint32_t FXSBE3:1;
1830 uint32_t:2;
1831 uint32_t FXSBE6:1;
1832 uint32_t FXSBE7:1;
1833 uint32_t RBEN:1;
1834 uint32_t WBEN:1;
1835 uint32_t ACCERR:1;
1836 uint32_t:21;
1837 } B;
1838 } FBOMCR; /* FEC Burst Optimisation Master Control Register */
1839
1840 uint8_t ecsm_reserved2[27];
1841
1842 union {
1843 uint8_t R;
1844 struct {
1845 uint8_t:2;
1846 uint8_t EPR1BR:1;
1847 uint8_t EPF1BR:1;
1848 uint8_t:2;
1849 uint8_t EPRNCR:1;
1850 uint8_t EPFNCR:1;
1851 } B;
1852 } ECR; /* ECC Configuration Register */
1853
1854 uint8_t ecsm_reserved3[3];
1855
1856 union {
1857 uint8_t R;
1858 struct {
1859 uint8_t:2;
1860 uint8_t PR1BC:1;
1861 uint8_t PF1BC:1;
1862 uint8_t:2;
1863 uint8_t PRNCE:1;
1864 uint8_t PFNCE:1;
1865 } B;
1866 } ESR; /* ECC Status Register */
1867
1868 uint16_t ecsm_reserved4;
1869
1870 union {
1871 uint16_t R;
1872 struct {
1873 uint16_t:2;
1874 uint16_t FRC1BI:1;
1875 uint16_t FR11BI:1;
1876 uint16_t:2;
1877 uint16_t FRCNCI:1;
1878 uint16_t FR1NCI:1;
1879 uint16_t PREI_SEL:1;
1880 uint16_t ERRBIT:7;
1881 } B;
1882 } EEGR; /* ECC Error Generation Register */
1883
1884 uint32_t ecsm_reserved5;
1885
1886 union {
1887 uint32_t R;
1888 struct {
1889 uint32_t PFEAR:32;
1890 } B;
1891 } PFEAR; /* Platform Flash ECC Address Register */
1892
1893 uint16_t ecsm_reserved6;
1894
1895 union {
1896 uint8_t R;
1897 struct {
1898 uint8_t:4;
1899 uint8_t PFEMR:4;
1900 } B;
1901 } PFEMR; /* Platform Flash ECC Address Register */
1902
1903 union {
1904 uint8_t R;
1905 struct {
1906 uint8_t WRITE:1;
1907 uint8_t SIZE:3;
1908 uint8_t PROTECTION:4;
1909 } B;
1910 } PFEAT; /* Flash ECC Attributes Register */
1911
1912 union {
1913 uint32_t R;
1914 struct {
1915 uint32_t PFEDRH:32;
1916 } B;
1917 } PFEDRH; /* Flash ECC Data High Register */
1918
1919 union {
1920 uint32_t R;
1921 struct {
1922 uint32_t PFEDRL:32;
1923 } B;
1924 } PFEDRL; /* Flash ECC Data Low Register */
1925
1926 union {
1927 uint32_t R;
1928 struct {
1929 uint32_t PREAR:32;
1930 } B;
1931 } PREAR; /* Platform RAM ECC Address Register */
1932
1933 uint16_t ecsm_reserved8;
1934
1935 union {
1936 uint8_t R;
1937 struct {
1938 uint8_t:4;
1939 uint8_t PREMR:4;
1940 } B;
1941 } PREMR; /* RAM ECC Attributes Register */
1942
1943 union {
1944 uint8_t R;
1945 struct {
1946 uint8_t WRITE:1;
1947 uint8_t SIZE:3;
1948 uint8_t PROTECTION:4;
1949 } B;
1950 } PREAT; /* Platform RAM ECC Attributes Register */
1951
1952 union {
1953 uint32_t R;
1954 struct {
1955 uint32_t PREDR:32;
1956 } B;
1957 } PREDRH; /* Platform RAM ECC Data Low Register High */
1958
1959 union {
1960 uint32_t R;
1961 struct {
1962 uint32_t PREDR:32;
1963 } B;
1964 } PREDRL; /* Platform RAM ECC Data Low Register Low */
1965
1966 }; /* end of ECSM_tag */
1967/*************************************************************************/
1968/* MODULE : EMIOS */
1969/*************************************************************************/
1970 struct EMIOS_tag {
1971 union EMIOS_MCR_tag {
1972 uint32_t R;
1973 struct {
1974 uint32_t:1;
1975 uint32_t MDIS:1;
1976 uint32_t FRZ:1;
1977 uint32_t GTBE:1;
1978 uint32_t:1;
1979 uint32_t GPREN:1;
1980 uint32_t:10;
1981 uint32_t GPRE:8;
1982 uint32_t:8;
1983 } B;
1984 } MCR; /* Module Configuration Register */
1985
1986 union {
1987 uint32_t R;
1988 struct {
1989 uint32_t F31:1;
1990 uint32_t F30:1;
1991 uint32_t F29:1;
1992 uint32_t F28:1;
1993 uint32_t F27:1;
1994 uint32_t F26:1;
1995 uint32_t F25:1;
1996 uint32_t F24:1;
1997 uint32_t F23:1;
1998 uint32_t F22:1;
1999 uint32_t F21:1;
2000 uint32_t F20:1;
2001 uint32_t F19:1;
2002 uint32_t F18:1;
2003 uint32_t F17:1;
2004 uint32_t F16:1;
2005 uint32_t F15:1;
2006 uint32_t F14:1;
2007 uint32_t F13:1;
2008 uint32_t F12:1;
2009 uint32_t F11:1;
2010 uint32_t F10:1;
2011 uint32_t F9:1;
2012 uint32_t F8:1;
2013 uint32_t F7:1;
2014 uint32_t F6:1;
2015 uint32_t F5:1;
2016 uint32_t F4:1;
2017 uint32_t F3:1;
2018 uint32_t F2:1;
2019 uint32_t F1:1;
2020 uint32_t F0:1;
2021 } B;
2022 } GFR; /* Global FLAG Register */
2023
2024 union {
2025 uint32_t R;
2026 struct {
2027 uint32_t OU31:1;
2028 uint32_t OU30:1;
2029 uint32_t OU29:1;
2030 uint32_t OU28:1;
2031 uint32_t OU27:1;
2032 uint32_t OU26:1;
2033 uint32_t OU25:1;
2034 uint32_t OU24:1;
2035 uint32_t OU23:1;
2036 uint32_t OU22:1;
2037 uint32_t OU21:1;
2038 uint32_t OU20:1;
2039 uint32_t OU19:1;
2040 uint32_t OU18:1;
2041 uint32_t OU17:1;
2042 uint32_t OU16:1;
2043 uint32_t OU15:1;
2044 uint32_t OU14:1;
2045 uint32_t OU13:1;
2046 uint32_t OU12:1;
2047 uint32_t OU11:1;
2048 uint32_t OU10:1;
2049 uint32_t OU9:1;
2050 uint32_t OU8:1;
2051 uint32_t OU7:1;
2052 uint32_t OU6:1;
2053 uint32_t OU5:1;
2054 uint32_t OU4:1;
2055 uint32_t OU3:1;
2056 uint32_t OU2:1;
2057 uint32_t OU1:1;
2058 uint32_t OU0:1;
2059 } B;
2060 } OUDR; /* Output Update Disable Register */
2061
2062 union {
2063 uint32_t R;
2064 struct {
2065 uint32_t UC31:1;
2066 uint32_t UC30:1;
2067 uint32_t UC29:1;
2068 uint32_t UC28:1;
2069 uint32_t UC27:1;
2070 uint32_t UC26:1;
2071 uint32_t UC25:1;
2072 uint32_t UC24:1;
2073 uint32_t UC23:1;
2074 uint32_t UC22:1;
2075 uint32_t UC21:1;
2076 uint32_t UC20:1;
2077 uint32_t UC19:1;
2078 uint32_t UC18:1;
2079 uint32_t UC17:1;
2080 uint32_t UC16:1;
2081 uint32_t UC15:1;
2082 uint32_t UC14:1;
2083 uint32_t UC13:1;
2084 uint32_t UC12:1;
2085 uint32_t UC11:1;
2086 uint32_t UC10:1;
2087 uint32_t UC9:1;
2088 uint32_t UC8:1;
2089 uint32_t UC7:1;
2090 uint32_t UC6:1;
2091 uint32_t UC5:1;
2092 uint32_t UC4:1;
2093 uint32_t UC3:1;
2094 uint32_t UC2:1;
2095 uint32_t UC1:1;
2096 uint32_t UC0:1;
2097 } B;
2098 } UCDIS; /* Disable Channel Register */
2099
2100 uint32_t emios_reserved1[4];
2101
2102 struct EMIOS_CH_tag {
2103 union {
2104 uint32_t R;
2105 struct {
2106 uint32_t:16;
2107 uint32_t A:16; /* Channel A Data Register */
2108 } B;
2109 } CADR;
2110
2111 union {
2112 uint32_t R;
2113 struct {
2114 uint32_t:16;
2115 uint32_t B:16; /* Channel B Data Register */
2116 } B;
2117 } CBDR;
2118
2119 union {
2120 uint32_t R; /* Channel Counter Register */
2121 struct {
2122 uint32_t:16;
2123 uint32_t C:16; /* Channel C Data Register */
2124 } B;
2125 } CCNTR;
2126
2127 union EMIOS_CCR_tag {
2128 uint32_t R;
2129 struct {
2130 uint32_t FREN:1;
2131 uint32_t ODIS:1;
2132 uint32_t ODISSL:2;
2133 uint32_t UCPRE:2;
2134 uint32_t UCPREN:1;
2135 uint32_t DMA:1;
2136 uint32_t:1;
2137 uint32_t IF:4;
2138 uint32_t FCK:1;
2139 uint32_t FEN:1;
2140 uint32_t:3;
2141 uint32_t FORCMA:1;
2142 uint32_t FORCMB:1;
2143 uint32_t:1;
2144 uint32_t BSL:2;
2145 uint32_t EDSEL:1;
2146 uint32_t EDPOL:1;
2147 uint32_t MODE:7;
2148 } B;
2149 } CCR; /* Channel Control Register */
2150
2151 union EMIOS_CSR_tag {
2152 uint32_t R;
2153 struct {
2154 uint32_t OVR:1;
2155 uint32_t:15;
2156 uint32_t OVFL:1;
2157 uint32_t:12;
2158 uint32_t UCIN:1;
2159 uint32_t UCOUT:1;
2160 uint32_t FLAG:1;
2161 } B;
2162 } CSR; /* Channel Status Register */
2163
2164 union {
2165 uint32_t R; /* Alternate Channel A Data Register */
2166 } ALTA;
2167
2168 uint32_t emios_channel_reserved[2];
2169
2170 } CH[32];
2171
2172 }; /* end of EMIOS_tag */
2173/*************************************************************************/
2174/* MODULE : eSCI */
2175/*************************************************************************/
2176 struct ESCI_tag {
2177 union ESCI_CR1_tag {
2178 uint32_t R;
2179 struct {
2180 uint32_t:3;
2181 uint32_t SBR:13;
2182 uint32_t LOOPS:1;
2183 uint32_t:1;
2184 uint32_t RSRC:1;
2185 uint32_t M:1;
2186 uint32_t WAKE:1;
2187 uint32_t ILT:1;
2188 uint32_t PE:1;
2189 uint32_t PT:1;
2190 uint32_t TIE:1;
2191 uint32_t TCIE:1;
2192 uint32_t RIE:1;
2193 uint32_t ILIE:1;
2194 uint32_t TE:1;
2195 uint32_t RE:1;
2196 uint32_t RWU:1;
2197 uint32_t SBK:1;
2198 } B;
2199 } CR1; /* Control Register 1 */
2200
2201 union ESCI_CR2_tag {
2202 uint16_t R;
2203 struct {
2204 uint16_t MDIS:1;
2205 uint16_t FBR:1;
2206 uint16_t BSTP:1;
2207 uint16_t IEBERR:1;
2208 uint16_t RXDMA:1;
2209 uint16_t TXDMA:1;
2210 uint16_t BRK13:1;
2211 uint16_t TXDIR:1;
2212 uint16_t BESM13:1;
2213 uint16_t SBSTP:1;
2214 uint16_t RXPOL:1;
2215 uint16_t PMSK:1;
2216 uint16_t ORIE:1;
2217 uint16_t NFIE:1;
2218 uint16_t FEIE:1;
2219 uint16_t PFIE:1;
2220 } B;
2221 } CR2; /* Control Register 2 */
2222
2223 union ESCI_DR_tag {
2224 uint16_t R;
2225 struct {
2226 uint16_t RN:1;
2227 uint16_t TN:1;
2228 uint16_t ERR:1;
2229 uint16_t:1;
2230 uint16_t RD_11:4;
2231 uint16_t D:8;
2232 } B;
2233 } DR; /* Data Register */
2234
2235 union ESCI_SR_tag {
2236 uint32_t R;
2237 struct {
2238 uint32_t TDRE:1;
2239 uint32_t TC:1;
2240 uint32_t RDRF:1;
2241 uint32_t IDLE:1;
2242 uint32_t OR:1;
2243 uint32_t NF:1;
2244 uint32_t FE:1;
2245 uint32_t PF:1;
2246 uint32_t:3;
2247 uint32_t BERR:1;
2248 uint32_t:2;
2249 uint32_t TACT:1;
2250 uint32_t RACT:1;
2251 uint32_t RXRDY:1;
2252 uint32_t TXRDY:1;
2253 uint32_t LWAKE:1;
2254 uint32_t STO:1;
2255 uint32_t PBERR:1;
2256 uint32_t CERR:1;
2257 uint32_t CKERR:1;
2258 uint32_t FRC:1;
2259 uint32_t:6;
2260 uint32_t UREQ:1;
2261 uint32_t OVFL:1;
2262 } B;
2263 } SR; /* Status Register */
2264
2265 union {
2266 uint32_t R;
2267 struct {
2268 uint32_t LRES:1;
2269 uint32_t WU:1;
2270 uint32_t WUD0:1;
2271 uint32_t WUD1:1;
2272 uint32_t:2;
2273 uint32_t PRTY:1;
2274 uint32_t LIN:1;
2275 uint32_t RXIE:1;
2276 uint32_t TXIE:1;
2277 uint32_t WUIE:1;
2278 uint32_t STIE:1;
2279 uint32_t PBIE:1;
2280 uint32_t CIE:1;
2281 uint32_t CKIE:1;
2282 uint32_t FCIE:1;
2283 uint32_t:6;
2284 uint32_t UQIE:1;
2285 uint32_t OFIE:1;
2286 uint32_t:8;
2287 } B;
2288 } LCR; /* LIN Control Register */
2289
2290 union {
2291 uint8_t R;
2292 } LTR; /* LIN Transmit Register */
2293
2294 uint8_t eSCI_reserved1[3];
2295
2296 union {
2297 uint8_t R;
2298 } LRR; /* LIN Recieve Register */
2299
2300 uint8_t eSCI_reserved2[3];
2301
2302 union {
2303 uint16_t R;
2304 } LPR; /* LIN CRC Polynom Register */
2305
2306 union {
2307 uint8_t R;
2308 struct {
2309 uint8_t:3;
2310 uint8_t SYNM:1;
2311 uint8_t EROE:1;
2312 uint8_t ERFE:1;
2313 uint8_t ERPE:1;
2314 uint8_t M2:1;
2315 } B;
2316 } CR3; /* Control Register 3 */
2317
2318 uint8_t eSCI_reserved3[5];
2319 }; /* end of ESCI_tag */
2320/*************************************************************************/
2321/* MODULE : FEC */
2322/*************************************************************************/
2323 struct FEC_tag {
2324
2325 uint32_t fec_reserved_start;
2326
2327 union {
2328 uint32_t R;
2329 struct {
2330 uint32_t HBERR:1;
2331 uint32_t BABR:1;
2332 uint32_t BABT:1;
2333 uint32_t GRA:1;
2334 uint32_t TXF:1;
2335 uint32_t TXB:1;
2336 uint32_t RXF:1;
2337 uint32_t RXB:1;
2338 uint32_t MII:1;
2339 uint32_t EBERR:1;
2340 uint32_t LC:1;
2341 uint32_t RL:1;
2342 uint32_t UN:1;
2343 uint32_t:19;
2344 } B;
2345 } EIR; /* Interrupt Event Register */
2346
2347 union {
2348 uint32_t R;
2349 struct {
2350 uint32_t HBERR:1;
2351 uint32_t BABR:1;
2352 uint32_t BABT:1;
2353 uint32_t GRA:1;
2354 uint32_t TXF:1;
2355 uint32_t TXB:1;
2356 uint32_t RXF:1;
2357 uint32_t RXB:1;
2358 uint32_t MII:1;
2359 uint32_t EBERR:1;
2360 uint32_t LC:1;
2361 uint32_t RL:1;
2362 uint32_t UN:1;
2363 uint32_t:19;
2364 } B;
2365 } EIMR; /* Interrupt Mask Register */
2366
2367 uint32_t fec_reserved_eimr;
2368
2369 union {
2370 uint32_t R;
2371 struct {
2372 uint32_t:7;
2373 uint32_t R_DES_ACTIVE:1;
2374 uint32_t:24;
2375 } B;
2376 } RDAR; /* Receive Descriptor Active Register */
2377
2378 union {
2379 uint32_t R;
2380 struct {
2381 uint32_t:7;
2382 uint32_t X_DES_ACTIVE:1;
2383 uint32_t:24;
2384 } B;
2385 } TDAR; /* Transmit Descriptor Active Register */
2386
2387 uint32_t fec_reserved_tdar[3];
2388
2389 union {
2390 uint32_t R;
2391 struct {
2392 uint32_t:30;
2393 uint32_t ETHER_EN:1;
2394 uint32_t RESET:1;
2395 } B;
2396 } ECR; /* Ethernet Control Register */
2397
2398 uint32_t fec_reserved_ecr[6];
2399
2400 union {
2401 uint32_t R;
2402 struct {
2403 uint32_t ST:2;
2404 uint32_t OP:2;
2405 uint32_t PA:5;
2406 uint32_t RA:5;
2407 uint32_t TA:2;
2408 uint32_t DATA:16;
2409 } B;
2410 } MMFR; /* MII Data Register */
2411
2412 union {
2413 uint32_t R;
2414 struct {
2415 uint32_t:24;
2416 uint32_t DIS_PREAMBLE:1;
2417 uint32_t MII_SPEED:6;
2418 uint32_t:1;
2419 } B;
2420 } MSCR; /* MII Speed Control Register */
2421
2422 uint32_t fec_reserved_mscr[7];
2423
2424 union {
2425 uint32_t R;
2426 struct {
2427 uint32_t MIB_DISABLE:1;
2428 uint32_t MIB_IDLE:1;
2429 uint32_t:30;
2430 } B;
2431 } MIBC; /* MIB Control Register */
2432
2433 uint32_t fec_reserved_mibc[7];
2434
2435 union {
2436 uint32_t R;
2437 struct {
2438 uint32_t:5;
2439 uint32_t MAX_FL:11;
2440 uint32_t:10;
2441 uint32_t FCE:1;
2442 uint32_t BC_REJ:1;
2443 uint32_t PROM:1;
2444 uint32_t MII_MODE:1;
2445 uint32_t DRT:1;
2446 uint32_t LOOP:1;
2447 } B;
2448 } RCR; /* Receive Control Register */
2449
2450 uint32_t fec_reserved_rcr[15];
2451
2452 union {
2453 uint32_t R;
2454 struct {
2455 uint32_t:27;
2456 uint32_t RFC_PAUSE:1;
2457 uint32_t TFC_PAUSE:1;
2458 uint32_t FDEN:1;
2459 uint32_t HBC:1;
2460 uint32_t GTS:1;
2461 } B;
2462 } TCR; /* Transmit Control Register */
2463
2464 uint32_t fec_reserved_tcr[7];
2465
2466 union {
2467 uint32_t R;
2468 struct {
2469 uint32_t PADDR1:32;
2470 } B;
2471 } PALR; /* Physical Address Low Register */
2472
2473 union {
2474 uint32_t R;
2475 struct {
2476 uint32_t PADDR2:16;
2477 uint32_t TYPE:16;
2478 } B;
2479 } PAUR; /* Physical Address High + Type Register */
2480
2481 union {
2482 uint32_t R;
2483 struct {
2484 uint32_t OPCODE:16;
2485 uint32_t PAUSE_DUR:16;
2486 } B;
2487 } OPD; /* Opcode/Pause Duration Register */
2488
2489 uint32_t fec_reserved_opd[10];
2490
2491 union {
2492 uint32_t R;
2493 struct {
2494 uint32_t IADDR1:32;
2495 } B;
2496 } IAUR; /* Descriptor Individual Upper Address Register */
2497
2498 union {
2499 uint32_t R;
2500 struct {
2501 uint32_t IADDR2:32;
2502 } B;
2503 } IALR; /* Descriptor Individual Lower Address Register */
2504
2505 union {
2506 uint32_t R;
2507 struct {
2508 uint32_t GADDR1:32;
2509 } B;
2510 } GAUR; /* Descriptor Group Upper Address Register */
2511
2512 union {
2513 uint32_t R;
2514 struct {
2515 uint32_t GADDR2:32;
2516 } B;
2517 } GALR; /* Descriptor Group Lower Address Register */
2518
2519 uint32_t fec_reserved_galr[7];
2520
2521 union {
2522 uint32_t R;
2523 struct {
2524 uint32_t:30;
2525 uint32_t X_WMRK:2;
2526 } B;
2527 } TFWR; /* FIFO Transmit FIFO Watermark Register */
2528
2529 uint32_t fec_reserved_tfwr;
2530
2531 union {
2532 uint32_t R;
2533 struct {
2534 uint32_t:22;
2535 uint32_t R_BOUND:8;
2536 uint32_t:2;
2537 } B;
2538 } FRBR; /* FIFO Receive Bound Register */
2539
2540 union {
2541 uint32_t R;
2542 struct {
2543 uint32_t:22;
2544 uint32_t R_FSTART:8;
2545 uint32_t:2;
2546 } B;
2547 } FRSR; /* FIFO Receive Start Register */
2548
2549 uint32_t fec_reserved_frsr[11];
2550
2551 union {
2552 uint32_t R;
2553 struct {
2554 uint32_t R_DES_START:30;
2555 uint32_t:2;
2556 } B;
2557 } ERDSR; /* Receive Descriptor Ring Start Register */
2558
2559 union {
2560 uint32_t R;
2561 struct {
2562 uint32_t X_DES_START:30;
2563 uint32_t:2;
2564 } B;
2565 } ETDSR; /* Transmit Descriptor Ring Start Register */
2566
2567 union {
2568 uint32_t R;
2569 struct {
2570 uint32_t:21;
2571 uint32_t R_BUF_SIZE:7;
2572 uint32_t:4;
2573 } B;
2574 } EMRBR; /* Receive Buffer Size Register */
2575
2576 uint32_t fec_reserved_emrbr[29];
2577
2578 union {
2579 uint32_t R;
2580 } RMON_T_DROP; /* Count of frames not counted correctly */
2581
2582 union {
2583 uint32_t R;
2584 } RMON_T_PACKETS; /* RMON Tx packet count */
2585
2586 union {
2587 uint32_t R;
2588 } RMON_T_BC_PKT; /* RMON Tx Broadcast Packets */
2589
2590 union {
2591 uint32_t R;
2592 } RMON_T_MC_PKT; /* RMON Tx Multicast Packets */
2593
2594 union {
2595 uint32_t R;
2596 } RMON_T_CRC_ALIGN; /* RMON Tx Packets w CRC/Align error */
2597
2598 union {
2599 uint32_t R;
2600 } RMON_T_UNDERSIZE; /* RMON Tx Packets < 64 bytes, good crc */
2601
2602 union {
2603 uint32_t R;
2604 } RMON_T_OVERSIZE; /* RMON Tx Packets > MAX_FL bytes, good crc */
2605
2606 union {
2607 uint32_t R;
2608 } RMON_T_FRAG; /* RMON Tx Packets < 64 bytes, bad crc */
2609
2610 union {
2611 uint32_t R;
2612 } RMON_T_JAB; /* RMON Tx Packets > MAX_FL bytes, bad crc */
2613
2614 union {
2615 uint32_t R;
2616 } RMON_T_COL; /* RMON Tx collision count */
2617
2618 union {
2619 uint32_t R;
2620 } RMON_T_P64; /* RMON Tx 64 byte packets */
2621
2622 union {
2623 uint32_t R;
2624 } RMON_T_P65TO127; /* RMON Tx 65 to 127 byte packets */
2625
2626 union {
2627 uint32_t R;
2628 } RMON_T_P128TO255; /* RMON Tx 128 to 255 byte packets */
2629
2630 union {
2631 uint32_t R;
2632 } RMON_T_P256TO511; /* RMON Tx 256 to 511 byte packets */
2633
2634 union {
2635 uint32_t R;
2636 } RMON_T_P512TO1023; /* RMON Tx 512 to 1023 byte packets */
2637
2638 union {
2639 uint32_t R;
2640 } RMON_T_P1024TO2047; /* RMON Tx 1024 to 2047 byte packets */
2641
2642 union {
2643 uint32_t R;
2644 } RMON_T_P_GTE2048; /* RMON Tx packets w > 2048 bytes */
2645
2646 union {
2647 uint32_t R;
2648 } RMON_T_OCTETS; /* RMON Tx Octets */
2649
2650 union {
2651 uint32_t R;
2652 } IEEE_T_DROP; /* Count of frames not counted correctly */
2653
2654 union {
2655 uint32_t R;
2656 } IEEE_T_FRAME_OK; /* Frames Transmitted OK */
2657
2658 union {
2659 uint32_t R;
2660 } IEEE_T_1COL; /* Frames Transmitted with Single Collision */
2661
2662 union {
2663 uint32_t R;
2664 } IEEE_T_MCOL; /* Frames Transmitted with Multiple Collisions */
2665
2666 union {
2667 uint32_t R;
2668 } IEEE_T_DEF; /* Frames Transmitted after Deferral Delay */
2669
2670 union {
2671 uint32_t R;
2672 } IEEE_T_LCOL; /* Frames Transmitted with Late Collision */
2673
2674 union {
2675 uint32_t R;
2676 } IEEE_T_EXCOL; /* Frames Transmitted with Excessive Collisions */
2677
2678 union {
2679 uint32_t R;
2680 } IEEE_T_MACERR; /* Frames Transmitted with Tx FIFO Underrun */
2681
2682 union {
2683 uint32_t R;
2684 } IEEE_T_CSERR; /* Frames Transmitted with Carrier Sense Error */
2685
2686 union {
2687 uint32_t R;
2688 } IEEE_T_SQE; /* Frames Transmitted with SQE Error */
2689
2690 union {
2691 uint32_t R;
2692 } IEEE_T_FDXFC; /* Flow Control Pause frames transmitted */
2693
2694 union {
2695 uint32_t R;
2696 } IEEE_T_OCTETS_OK; /* Octet count for Frames Transmitted w/o Error */
2697
2698 uint32_t fec_reserved_rmon_t_octets_ok[2];
2699
2700 union {
2701 uint32_t R;
2702 } RMON_R_DROP; /* Count of frames not counted correctly */
2703
2704 union {
2705 uint32_t R;
2706 } RMON_R_PACKETS; /* RMON Rx packet count */
2707
2708 union {
2709 uint32_t R;
2710 } RMON_R_BC_PKT; /* RMON Rx Broadcast Packets */
2711
2712 union {
2713 uint32_t R;
2714 } RMON_R_MC_PKT; /* RMON Rx Multicast Packets */
2715
2716 union {
2717 uint32_t R;
2718 } RMON_R_CRC_ALIGN; /* RMON Rx Packets w CRC/Align error */
2719
2720 union {
2721 uint32_t R;
2722 } RMON_R_UNDERSIZE; /* RMON Rx Packets < 64 bytes, good crc */
2723
2724 union {
2725 uint32_t R;
2726 } RMON_R_OVERSIZE; /* RMON Rx Packets > MAX_FL bytes, good crc */
2727
2728 union {
2729 uint32_t R;
2730 } RMON_R_FRAG; /* RMON Rx Packets < 64 bytes, bad crc */
2731
2732 union {
2733 uint32_t R;
2734 } RMON_R_JAB; /* RMON Rx Packets > MAX_FL bytes, bad crc */
2735
2736 uint32_t fec_reserved_rmon_r_jab;
2737
2738 union {
2739 uint32_t R;
2740 } RMON_R_P64; /* RMON Rx 64 byte packets */
2741
2742 union {
2743 uint32_t R;
2744 } RMON_R_P65TO127; /* RMON Rx 65 to 127 byte packets */
2745
2746 union {
2747 uint32_t R;
2748 } RMON_R_P128TO255; /* RMON Rx 128 to 255 byte packets */
2749
2750 union {
2751 uint32_t R;
2752 } RMON_R_P256TO511; /* RMON Rx 256 to 511 byte packets */
2753
2754 union {
2755 uint32_t R;
2756 } RMON_R_P512TO1023; /* RMON Rx 512 to 1023 byte packets */
2757
2758 union {
2759 uint32_t R;
2760 } RMON_R_P1024TO2047; /* RMON Rx 1024 to 2047 byte packets */
2761
2762 union {
2763 uint32_t R;
2764 } RMON_R_P_GTE2048; /* RMON Rx packets w > 2048 bytes */
2765
2766 union {
2767 uint32_t R;
2768 } RMON_R_OCTETS; /* RMON Rx Octets */
2769
2770 union {
2771 uint32_t R;
2772 } IEEE_R_DROP; /* Count of frames not counted correctly */
2773
2774 union {
2775 uint32_t R;
2776 } IEEE_R_FRAME_OK; /* Frames Received OK */
2777
2778 union {
2779 uint32_t R;
2780 } IEEE_R_CRC; /* Frames Received with CRC Error */
2781
2782 union {
2783 uint32_t R;
2784 } IEEE_R_ALIGN; /* Frames Received with Alignment Error */
2785
2786 union {
2787 uint32_t R;
2788 } IEEE_R_MACERR; /* Receive Fifo Overflow count */
2789
2790 union {
2791 uint32_t R;
2792 } IEEE_R_FDXFC; /* Flow Control Pause frames received */
2793
2794 union {
2795 uint32_t R;
2796 } IEEE_R_OCTETS_OK; /* Octet count for Frames Rcvd w/o Error */
2797
2798 }; /* end of FEC_tag */
2799/*************************************************************************/
2800/* MODULE : FLASH */
2801/*************************************************************************/
2802 struct FLASH_tag {
2803 union {
2804 uint32_t R;
2805 struct {
2806 uint32_t:5;
2807 uint32_t SIZE:3;
2808 uint32_t:1;
2809 uint32_t LAS:3;
2810 uint32_t:3;
2811 uint32_t MAS:1;
2812 uint32_t EER:1;
2813 uint32_t RWE:1;
2814 uint32_t SBC:1;
2815 uint32_t:1;
2816 uint32_t PEAS:1;
2817 uint32_t DONE:1;
2818 uint32_t PEG:1;
2819 uint32_t:4;
2820 uint32_t PGM:1;
2821 uint32_t PSUS:1;
2822 uint32_t ERS:1;
2823 uint32_t ESUS:1;
2824 uint32_t EHV:1;
2825 } B;
2826 } MCR; /* Module Configuration Register */
2827
2828 union {
2829 uint32_t R;
2830 struct {
2831 uint32_t LME:1;
2832 uint32_t:10;
2833 uint32_t SLOCK:1;
2834 uint32_t:2;
2835 uint32_t MLOCK:2;
2836 uint32_t:6;
2837 uint32_t LLOCK:10;
2838 } B;
2839 } LML; /* Low/Mid-address space block locking Register */
2840
2841 union {
2842 uint32_t R;
2843 struct {
2844 uint32_t HBE:1;
2845 uint32_t:25;
2846 uint32_t HBLOCK:6;
2847 } B;
2848 } HBL; /* High-address space block locking Register */
2849
2850 union {
2851 uint32_t R;
2852 struct {
2853 uint32_t SLE:1;
2854 uint32_t:10;
2855 uint32_t SSLOCK:1;
2856 uint32_t:2;
2857 uint32_t SMLOCK:2;
2858 uint32_t:6;
2859 uint32_t SLLOCK:10;
2860 } B;
2861 } SLL; /* Secondary low/mid-address space block locking Register */
2862
2863 union {
2864 uint32_t R;
2865 struct {
2866 uint32_t:14;
2867 uint32_t MSEL:2;
2868 uint32_t:6;
2869 uint32_t LSEL:10;
2870 } B;
2871 } LMS; /* Low/Mid-address space block locking Register */
2872
2873 union {
2874 uint32_t R;
2875 struct {
2876 uint32_t:26;
2877 uint32_t HBSEL:6;
2878 } B;
2879 } HBS; /* High-address space block locking Register */
2880
2881 union {
2882 uint32_t R;
2883 struct {
2884 uint32_t SAD:1;
2885 uint32_t:10;
2886 uint32_t ADDR:18;
2887 uint32_t:3;
2888 } B;
2889 } ADR; /* Address Register */
2890
2891 union {
2892 uint32_t R;
2893 struct {
2894 uint32_t LBCFG:4;
2895 uint32_t ARB:1;
2896 uint32_t PRI:1;
2897 uint32_t:1;
2898 uint32_t M8PFE:1;
2899 uint32_t:1;
2900 uint32_t M6PFE:1;
2901 uint32_t M5PFE:1;
2902 uint32_t M4PFE:1;
2903 uint32_t:1;
2904 uint32_t M2PFE:1;
2905 uint32_t M1PFE:1;
2906 uint32_t M0PFE:1;
2907 uint32_t APC:3;
2908 uint32_t WWSC:2;
2909 uint32_t RWSC:3;
2910 uint32_t:1;
2911 uint32_t DPFEN:1;
2912 uint32_t:1;
2913 uint32_t IPFEN:1;
2914 uint32_t:1;
2915 uint32_t PFLIM:2;
2916 uint32_t BFEN:1;
2917 } B;
2918 } PFCRP0; /* Platform Flash Configuration Register for Port 0 */
2919
2920 union {
2921 uint32_t R;
2922 struct {
2923 uint32_t LBCFG:4;
2924 uint32_t:3;
2925 uint32_t M8PFE:1;
2926 uint32_t:1;
2927 uint32_t M6PFE:1;
2928 uint32_t M5PFE:1;
2929 uint32_t M4PFE:1;
2930 uint32_t:1;
2931 uint32_t M2PFE:1;
2932 uint32_t M1PFE:1;
2933 uint32_t M0PFE:1;
2934 uint32_t APC:3;
2935 uint32_t WWSC:2;
2936 uint32_t RWSC:3;
2937 uint32_t:1;
2938 uint32_t DPFEN:1;
2939 uint32_t:1;
2940 uint32_t IPFEN:1;
2941 uint32_t:1;
2942 uint32_t PFLIM:2;
2943 uint32_t BFEN:1;
2944 } B;
2945 } PFCRP1; /* Platform Flash Configuration Register for Port 1 */
2946
2947 union {
2948 uint32_t R;
2949 struct {
2950 uint32_t M7AP:2;
2951 uint32_t M6AP:2;
2952 uint32_t M5AP:2;
2953 uint32_t M4AP:2;
2954 uint32_t M3AP:2;
2955 uint32_t M2AP:2;
2956 uint32_t M1AP:2;
2957 uint32_t M0AP:2;
2958 uint32_t SHSACC:4;
2959 uint32_t:4;
2960 uint32_t SHDACC:4;
2961 uint32_t:4;
2962 } B;
2963 } PFAPR; /* Platform Flash access protection Register */
2964
2965 union {
2966 uint32_t R;
2967 struct {
2968 uint32_t:1;
2969 uint32_t SACC:31;
2970 } B;
2971 } PFSACC; /* PFlash Supervisor Access Control Register */
2972
2973 union {
2974 uint32_t R;
2975 struct {
2976 uint32_t:1;
2977 uint32_t DACC:31;
2978 } B;
2979 } PFDACC; /* PFlash Data Access Control Register */
2980
2981 uint32_t FLASH_reserved1[3];
2982
2983 union {
2984 uint32_t R;
2985 struct {
2986 uint32_t UTE:1;
2987 uint32_t SCBE:1;
2988 uint32_t:6;
2989 uint32_t DSI:8;
2990 uint32_t:10;
2991 uint32_t MRE:1;
2992 uint32_t MRV:1;
2993 uint32_t EIE:1;
2994 uint32_t AIS:1;
2995 uint32_t AIE:1;
2996 uint32_t AID:1;
2997 } B;
2998 } UT0; /* User Test Register 0 */
2999
3000 union {
3001 uint32_t R;
3002 struct {
3003 uint32_t DAI:32;
3004 } B;
3005 } UT1; /* User Test Register 1 */
3006
3007 union {
3008 uint32_t R;
3009 struct {
3010 uint32_t DAI:32;
3011 } B;
3012 } UT2; /* User Test Register 2 */
3013
3014 union {
3015 uint32_t R;
3016 struct {
3017 uint32_t MISR:32;
3018 } B;
3019 } MISR[5]; /* Multiple Input Signature Register */
3020
3021 }; /* end of FLASH_tag */
3022/*************************************************************************/
3023/* MODULE : FlexCAN */
3024/*************************************************************************/
3025 struct FLEXCAN_tag {
3026 union {
3027 uint32_t R;
3028 struct {
3029 uint32_t MDIS:1;
3030 uint32_t FRZ:1;
3031 uint32_t FEN:1;
3032 uint32_t HALT:1;
3033 uint32_t NOTRDY:1;
3034 uint32_t WAKMSK:1;
3035 uint32_t SOFTRST:1;
3036 uint32_t FRZACK:1;
3037 uint32_t SUPV:1;
3038 uint32_t SLFWAK:1;
3039 uint32_t WRNEN:1;
3040 uint32_t LPMACK:1;
3041 uint32_t WAKSRC:1;
3042 uint32_t DOZE:1;
3043 uint32_t SRXDIS:1;
3044 uint32_t BCC:1;
3045 uint32_t:2;
3046 uint32_t LPRIO_EN:1;
3047 uint32_t AEN:1;
3048 uint32_t:2;
3049 uint32_t IDAM:2;
3050 uint32_t:2;
3051 uint32_t MAXMB:6;
3052 } B;
3053 } MCR; /* Module Configuration Register */
3054
3055 union {
3056 uint32_t R;
3057 struct {
3058 uint32_t PRESDIV:8;
3059 uint32_t RJW:2;
3060 uint32_t PSEG1:3;
3061 uint32_t PSEG2:3;
3062 uint32_t BOFFMSK:1;
3063 uint32_t ERRMSK:1;
3064 uint32_t CLKSRC:1;
3065 uint32_t LPB:1;
3066 uint32_t TWRNMSK:1;
3067 uint32_t RWRNMSK:1;
3068 uint32_t:2;
3069 uint32_t SMP:1;
3070 uint32_t BOFFREC:1;
3071 uint32_t TSYN:1;
3072 uint32_t LBUF:1;
3073 uint32_t LOM:1;
3074 uint32_t PROPSEG:3;
3075 } B;
3076 } CTRL; /* Control Register */
3077
3078 union {
3079 uint32_t R;
3080 } TIMER; /* Free Running Timer */
3081
3082 uint32_t FLEXCAN_reserved1;
3083
3084 union {
3085 uint32_t R;
3086 struct {
3087 uint32_t MI:32;
3088 } B;
3089 } RXGMASK; /* RX Global Mask */
3090
3091 union {
3092 uint32_t R;
3093 struct {
3094 uint32_t MI:32;
3095 } B;
3096 } RX14MASK; /* RX 14 Mask */
3097
3098 union {
3099 uint32_t R;
3100 struct {
3101 uint32_t MI:32;
3102 } B;
3103 } RX15MASK; /* RX 15 Mask */
3104
3105 union {
3106 uint32_t R;
3107 struct {
3108 uint32_t:16;
3109 uint32_t RXECNT:8;
3110 uint32_t TXECNT:8;
3111 } B;
3112 } ECR; /* Error Counter Register */
3113
3114 union {
3115 uint32_t R;
3116 struct {
3117 uint32_t:14;
3118 uint32_t TWRNINT:1;
3119 uint32_t RWRNINT:1;
3120 uint32_t BIT1ERR:1;
3121 uint32_t BIT0ERR:1;
3122 uint32_t ACKERR:1;
3123 uint32_t CRCERR:1;
3124 uint32_t FRMERR:1;
3125 uint32_t STFERR:1;
3126 uint32_t TXWRN:1;
3127 uint32_t RXWRN:1;
3128 uint32_t IDLE:1;
3129 uint32_t TXRX:1;
3130 uint32_t FLTCONF:2;
3131 uint32_t:1;
3132 uint32_t BOFFINT:1;
3133 uint32_t ERRINT:1;
3134 uint32_t WAKINT:1;
3135 } B;
3136 } ESR; /* Error and Status Register */
3137
3138 union {
3139 uint32_t R;
3140 struct {
3141 uint32_t BUF63M:1;
3142 uint32_t BUF62M:1;
3143 uint32_t BUF61M:1;
3144 uint32_t BUF60M:1;
3145 uint32_t BUF59M:1;
3146 uint32_t BUF58M:1;
3147 uint32_t BUF57M:1;
3148 uint32_t BUF56M:1;
3149 uint32_t BUF55M:1;
3150 uint32_t BUF54M:1;
3151 uint32_t BUF53M:1;
3152 uint32_t BUF52M:1;
3153 uint32_t BUF51M:1;
3154 uint32_t BUF50M:1;
3155 uint32_t BUF49M:1;
3156 uint32_t BUF48M:1;
3157 uint32_t BUF47M:1;
3158 uint32_t BUF46M:1;
3159 uint32_t BUF45M:1;
3160 uint32_t BUF44M:1;
3161 uint32_t BUF43M:1;
3162 uint32_t BUF42M:1;
3163 uint32_t BUF41M:1;
3164 uint32_t BUF40M:1;
3165 uint32_t BUF39M:1;
3166 uint32_t BUF38M:1;
3167 uint32_t BUF37M:1;
3168 uint32_t BUF36M:1;
3169 uint32_t BUF35M:1;
3170 uint32_t BUF34M:1;
3171 uint32_t BUF33M:1;
3172 uint32_t BUF32M:1;
3173 } B;
3174 } IMASK2; /* Interruput Masks Register */
3175
3176 union {
3177 uint32_t R;
3178 struct {
3179 uint32_t BUF31M:1;
3180 uint32_t BUF30M:1;
3181 uint32_t BUF29M:1;
3182 uint32_t BUF28M:1;
3183 uint32_t BUF27M:1;
3184 uint32_t BUF26M:1;
3185 uint32_t BUF25M:1;
3186 uint32_t BUF24M:1;
3187 uint32_t BUF23M:1;
3188 uint32_t BUF22M:1;
3189 uint32_t BUF21M:1;
3190 uint32_t BUF20M:1;
3191 uint32_t BUF19M:1;
3192 uint32_t BUF18M:1;
3193 uint32_t BUF17M:1;
3194 uint32_t BUF16M:1;
3195 uint32_t BUF15M:1;
3196 uint32_t BUF14M:1;
3197 uint32_t BUF13M:1;
3198 uint32_t BUF12M:1;
3199 uint32_t BUF11M:1;
3200 uint32_t BUF10M:1;
3201 uint32_t BUF09M:1;
3202 uint32_t BUF08M:1;
3203 uint32_t BUF07M:1;
3204 uint32_t BUF06M:1;
3205 uint32_t BUF05M:1;
3206 uint32_t BUF04M:1;
3207 uint32_t BUF03M:1;
3208 uint32_t BUF02M:1;
3209 uint32_t BUF01M:1;
3210 uint32_t BUF00M:1;
3211 } B;
3212 } IMASK1; /* Interruput Masks Register */
3213
3214 union {
3215 uint32_t R;
3216 struct {
3217 uint32_t BUF63I:1;
3218 uint32_t BUF62I:1;
3219 uint32_t BUF61I:1;
3220 uint32_t BUF60I:1;
3221 uint32_t BUF59I:1;
3222 uint32_t BUF58I:1;
3223 uint32_t BUF57I:1;
3224 uint32_t BUF56I:1;
3225 uint32_t BUF55I:1;
3226 uint32_t BUF54I:1;
3227 uint32_t BUF53I:1;
3228 uint32_t BUF52I:1;
3229 uint32_t BUF51I:1;
3230 uint32_t BUF50I:1;
3231 uint32_t BUF49I:1;
3232 uint32_t BUF48I:1;
3233 uint32_t BUF47I:1;
3234 uint32_t BUF46I:1;
3235 uint32_t BUF45I:1;
3236 uint32_t BUF44I:1;
3237 uint32_t BUF43I:1;
3238 uint32_t BUF42I:1;
3239 uint32_t BUF41I:1;
3240 uint32_t BUF40I:1;
3241 uint32_t BUF39I:1;
3242 uint32_t BUF38I:1;
3243 uint32_t BUF37I:1;
3244 uint32_t BUF36I:1;
3245 uint32_t BUF35I:1;
3246 uint32_t BUF34I:1;
3247 uint32_t BUF33I:1;
3248 uint32_t BUF32I:1;
3249 } B;
3250 } IFLAG2; /* Interruput Flag Register */
3251
3252 union {
3253 uint32_t R;
3254 struct {
3255 uint32_t BUF31I:1;
3256 uint32_t BUF30I:1;
3257 uint32_t BUF29I:1;
3258 uint32_t BUF28I:1;
3259 uint32_t BUF27I:1;
3260 uint32_t BUF26I:1;
3261 uint32_t BUF25I:1;
3262 uint32_t BUF24I:1;
3263 uint32_t BUF23I:1;
3264 uint32_t BUF22I:1;
3265 uint32_t BUF21I:1;
3266 uint32_t BUF20I:1;
3267 uint32_t BUF19I:1;
3268 uint32_t BUF18I:1;
3269 uint32_t BUF17I:1;
3270 uint32_t BUF16I:1;
3271 uint32_t BUF15I:1;
3272 uint32_t BUF14I:1;
3273 uint32_t BUF13I:1;
3274 uint32_t BUF12I:1;
3275 uint32_t BUF11I:1;
3276 uint32_t BUF10I:1;
3277 uint32_t BUF09I:1;
3278 uint32_t BUF08I:1;
3279 uint32_t BUF07I:1;
3280 uint32_t BUF06I:1;
3281 uint32_t BUF05I:1;
3282 uint32_t BUF04I:1;
3283 uint32_t BUF03I:1;
3284 uint32_t BUF02I:1;
3285 uint32_t BUF01I:1;
3286 uint32_t BUF00I:1;
3287 } B;
3288 } IFLAG1; /* Interruput Flag Register */
3289
3290 uint32_t FLEXCAN_reserved2[19];
3291
3292 struct canbuf_t {
3293 union {
3294 uint32_t R;
3295 struct {
3296 uint32_t:4;
3297 uint32_t CODE:4;
3298 uint32_t:1;
3299 uint32_t SRR:1;
3300 uint32_t IDE:1;
3301 uint32_t RTR:1;
3302 uint32_t LENGTH:4;
3303 uint32_t TIMESTAMP:16;
3304 } B;
3305 } CS;
3306
3307 union {
3308 uint32_t R;
3309 struct {
3310 uint32_t PRIO:3;
3311 uint32_t STD_ID:11;
3312 uint32_t EXT_ID:18;
3313 } B;
3314 } ID;
3315
3316 union {
3317 /* uint8_t B[8]; Data buffer in Bytes (8 bits) */
3318 /* uint16_t H[4]; Data buffer in Half-words (16 bits) */
3319 uint32_t W[2]; /* Data buffer in words (32 bits) */
3320 /* uint32_t R[2]; Data buffer in words (32 bits) */
3321 } DATA;
3322
3323 } BUF[64];
3324
3325 uint32_t FLEXCAN_reserved3[256];
3326
3327 union {
3328 uint32_t R;
3329 struct {
3330 uint32_t MI:32;
3331 } B;
3332 } RXIMR[64]; /* RX Individual Mask Registers */
3333
3334 }; /* end of CTU_tag */
3335/**************************************************************************/
3336/* MODULE : FlexRay */
3337/**************************************************************************/
3338
3339 typedef union uMVR {
3340 uint16_t R;
3341 struct {
3342 uint16_t CHIVER:8; /* CHI Version Number */
3343 uint16_t PEVER:8; /* PE Version Number */
3344 } B;
3345 } MVR_t;
3346
3347 typedef union uMCR {
3348 uint16_t R;
3349 struct {
3350 uint16_t MEN:1; /* module enable */
3351 uint16_t:1;
3352 uint16_t SCMD:1; /* single channel mode */
3353 uint16_t CHB:1; /* channel B enable */
3354 uint16_t CHA:1; /* channel A enable */
3355 uint16_t SFFE:1; /* synchronization frame filter enable */
3356 uint16_t:5;
3357 uint16_t CLKSEL:1; /* protocol engine clock source select */
3358 uint16_t PRESCALE:3; /* protocol engine clock prescaler */
3359 uint16_t:1;
3360 } B;
3361 } MCR_t;
3362 typedef union uSTBSCR {
3363 uint16_t R;
3364 struct {
3365 uint16_t WMD:1; /* write mode */
3366 uint16_t STBSSEL:7; /* strobe signal select */
3367 uint16_t:3;
3368 uint16_t ENB:1; /* strobe signal enable */
3369 uint16_t:2;
3370 uint16_t STBPSEL:2; /* strobe port select */
3371 } B;
3372 } STBSCR_t;
3373 typedef union uMBDSR {
3374 uint16_t R;
3375 struct {
3376 uint16_t:1;
3377 uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
3378 uint16_t:1;
3379 uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
3380 } B;
3381 } MBDSR_t;
3382
3383 typedef union uMBSSUTR {
3384 uint16_t R;
3385 struct {
3386
3387 uint16_t:2;
3388 uint16_t LAST_MB_SEG1:6; /* last message buffer control register for message buffer segment 1 */
3389 uint16_t:2;
3390 uint16_t LAST_MB_UTIL:6; /* last message buffer utilized */
3391 } B;
3392 } MBSSUTR_t;
3393
3394 typedef union uPOCR {
3395 uint16_t R;
3396 uint8_t byte[2];
3397 struct {
3398 uint16_t WME:1; /* write mode external correction command */
3399 uint16_t:3;
3400 uint16_t EOC_AP:2; /* external offset correction application */
3401 uint16_t ERC_AP:2; /* external rate correction application */
3402 uint16_t BSY:1; /* command write busy / write mode command */
3403 uint16_t:3;
3404 uint16_t POCCMD:4; /* protocol command */
3405 } B;
3406 } POCR_t;
3407/* protocol commands */
3408 typedef union uGIFER {
3409 uint16_t R;
3410 struct {
3411 uint16_t MIF:1; /* module interrupt flag */
3412 uint16_t PRIF:1; /* protocol interrupt flag */
3413 uint16_t CHIF:1; /* CHI interrupt flag */
3414 uint16_t WKUPIF:1; /* wakeup interrupt flag */
3415 uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
3416 uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
3417 uint16_t RBIF:1; /* receive message buffer interrupt flag */
3418 uint16_t TBIF:1; /* transmit buffer interrupt flag */
3419 uint16_t MIE:1; /* module interrupt enable */
3420 uint16_t PRIE:1; /* protocol interrupt enable */
3421 uint16_t CHIE:1; /* CHI interrupt enable */
3422 uint16_t WKUPIE:1; /* wakeup interrupt enable */
3423 uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
3424 uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
3425 uint16_t RBIE:1; /* receive message buffer interrupt enable */
3426 uint16_t TBIE:1; /* transmit buffer interrupt enable */
3427 } B;
3428 } GIFER_t;
3429 typedef union uPIFR0 {
3430 uint16_t R;
3431 struct {
3432 uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
3433 uint16_t INTLIF:1; /* internal protocol error interrupt flag */
3434 uint16_t ILCFIF:1; /* illegal protocol configuration flag */
3435 uint16_t CSAIF:1; /* cold start abort interrupt flag */
3436 uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
3437 uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
3438 uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
3439 uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
3440 uint16_t MTXIF:1; /* media access test symbol received flag */
3441 uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
3442 uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
3443 uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
3444 uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
3445 uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
3446 uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
3447 uint16_t CYSIF:1; /* cycle start interrupt flag */
3448 } B;
3449 } PIFR0_t;
3450 typedef union uPIFR1 {
3451 uint16_t R;
3452 struct {
3453 uint16_t EMCIF:1; /* error mode changed interrupt flag */
3454 uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
3455 uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
3456 uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
3457 uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
3458 uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
3459 uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
3460 uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
3461 uint16_t:2;
3462 uint16_t EVTIF:1; /* even cycle table written interrupt flag */
3463 uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
3464 uint16_t:4;
3465 } B;
3466 } PIFR1_t;
3467 typedef union uPIER0 {
3468 uint16_t R;
3469 struct {
3470 uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
3471 uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
3472 uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
3473 uint16_t CSAIE:1; /* cold start abort interrupt enable */
3474 uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
3475 uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
3476 uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
3477 uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
3478 uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
3479 uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
3480 uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
3481 uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
3482 uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
3483 uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
3484 uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
3485 uint16_t CYSIE:1; /* cycle start interrupt enable */
3486 } B;
3487 } PIER0_t;
3488 typedef union uPIER1 {
3489 uint16_t R;
3490 struct {
3491 uint16_t EMCIE:1; /* error mode changed interrupt enable */
3492 uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
3493 uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
3494 uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
3495 uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
3496 uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
3497 uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
3498 uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
3499 uint16_t:2;
3500 uint16_t EVTIE:1; /* even cycle table written interrupt enable */
3501 uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
3502 uint16_t:4;
3503 } B;
3504 } PIER1_t;
3505 typedef union uCHIERFR {
3506 uint16_t R;
3507 struct {
3508 uint16_t FRLBEF:1; /* flame lost channel B error flag */
3509 uint16_t FRLAEF:1; /* frame lost channel A error flag */
3510 uint16_t PCMIEF:1; /* command ignored error flag */
3511 uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
3512 uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
3513 uint16_t MSBEF:1; /* message buffer search error flag */
3514 uint16_t MBUEF:1; /* message buffer utilization error flag */
3515 uint16_t LCKEF:1; /* lock error flag */
3516 uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
3517 uint16_t SBCFEF:1; /* system bus communication failure error flag */
3518 uint16_t FIDEF:1; /* frame ID error flag */
3519 uint16_t DPLEF:1; /* dynamic payload length error flag */
3520 uint16_t SPLEF:1; /* static payload length error flag */
3521 uint16_t NMLEF:1; /* network management length error flag */
3522 uint16_t NMFEF:1; /* network management frame error flag */
3523 uint16_t ILSAEF:1; /* illegal access error flag */
3524 } B;
3525 } CHIERFR_t;
3526 typedef union uMBIVEC {
3527 uint16_t R;
3528 struct {
3529
3530 uint16_t:2;
3531 uint16_t TBIVEC:6; /* transmit buffer interrupt vector */
3532 uint16_t:2;
3533 uint16_t RBIVEC:6; /* receive buffer interrupt vector */
3534 } B;
3535 } MBIVEC_t;
3536
3537 typedef union uPSR0 {
3538 uint16_t R;
3539 struct {
3540 uint16_t ERRMODE:2; /* error mode */
3541 uint16_t SLOTMODE:2; /* slot mode */
3542 uint16_t:1;
3543 uint16_t PROTSTATE:3; /* protocol state */
3544 uint16_t SUBSTATE:4; /* protocol sub state */
3545 uint16_t:1;
3546 uint16_t WAKEUPSTATUS:3; /* wakeup status */
3547 } B;
3548 } PSR0_t;
3549
3550/* protocol states */
3551/* protocol sub-states */
3552/* wakeup status */
3553 typedef union uPSR1 {
3554 uint16_t R;
3555 struct {
3556 uint16_t CSAA:1; /* cold start attempt abort flag */
3557 uint16_t SCP:1; /* cold start path */
3558 uint16_t:1;
3559 uint16_t REMCSAT:5; /* remanining coldstart attempts */
3560 uint16_t CPN:1; /* cold start noise path */
3561 uint16_t HHR:1; /* host halt request pending */
3562 uint16_t FRZ:1; /* freeze occured */
3563 uint16_t APTAC:5; /* allow passive to active counter */
3564 } B;
3565 } PSR1_t;
3566 typedef union uPSR2 {
3567 uint16_t R;
3568 struct {
3569 uint16_t NBVB:1; /* NIT boundary violation on channel B */
3570 uint16_t NSEB:1; /* NIT syntax error on channel B */
3571 uint16_t STCB:1; /* symbol window transmit conflict on channel B */
3572 uint16_t SBVB:1; /* symbol window boundary violation on channel B */
3573 uint16_t SSEB:1; /* symbol window syntax error on channel B */
3574 uint16_t MTB:1; /* media access test symbol MTS received on channel B */
3575 uint16_t NBVA:1; /* NIT boundary violation on channel A */
3576 uint16_t NSEA:1; /* NIT syntax error on channel A */
3577 uint16_t STCA:1; /* symbol window transmit conflict on channel A */
3578 uint16_t SBVA:1; /* symbol window boundary violation on channel A */
3579 uint16_t SSEA:1; /* symbol window syntax error on channel A */
3580 uint16_t MTA:1; /* media access test symbol MTS received on channel A */
3581 uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
3582 } B;
3583 } PSR2_t;
3584 typedef union uPSR3 {
3585 uint16_t R;
3586 struct {
3587 uint16_t:2;
3588 uint16_t WUB:1; /* wakeup symbol received on channel B */
3589 uint16_t ABVB:1; /* aggregated boundary violation on channel B */
3590 uint16_t AACB:1; /* aggregated additional communication on channel B */
3591 uint16_t ACEB:1; /* aggregated content error on channel B */
3592 uint16_t ASEB:1; /* aggregated syntax error on channel B */
3593 uint16_t AVFB:1; /* aggregated valid frame on channel B */
3594 uint16_t:2;
3595 uint16_t WUA:1; /* wakeup symbol received on channel A */
3596 uint16_t ABVA:1; /* aggregated boundary violation on channel A */
3597 uint16_t AACA:1; /* aggregated additional communication on channel A */
3598 uint16_t ACEA:1; /* aggregated content error on channel A */
3599 uint16_t ASEA:1; /* aggregated syntax error on channel A */
3600 uint16_t AVFA:1; /* aggregated valid frame on channel A */
3601 } B;
3602 } PSR3_t;
3603 typedef union uCIFRR {
3604 uint16_t R;
3605 struct {
3606 uint16_t:8;
3607 uint16_t MIFR:1; /* module interrupt flag */
3608 uint16_t PRIFR:1; /* protocol interrupt flag */
3609 uint16_t CHIFR:1; /* CHI interrupt flag */
3610 uint16_t WUPIFR:1; /* wakeup interrupt flag */
3611 uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
3612 uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
3613 uint16_t RBIFR:1; /* receive message buffer interrupt flag */
3614 uint16_t TBIFR:1; /* transmit buffer interrupt flag */
3615 } B;
3616 } CIFRR_t;
3617 typedef union uSYMATOR {
3618 uint16_t R;
3619 struct {
3620 uint16_t:11;
3621 uint16_t TIMEOUT:5; /* system memory time out value */
3622 } B;
3623 } SYMATOR_t;
3624
3625 typedef union uSFCNTR {
3626 uint16_t R;
3627 struct {
3628 uint16_t SFEVB:4; /* sync frames channel B, even cycle */
3629 uint16_t SFEVA:4; /* sync frames channel A, even cycle */
3630 uint16_t SFODB:4; /* sync frames channel B, odd cycle */
3631 uint16_t SFODA:4; /* sync frames channel A, odd cycle */
3632 } B;
3633 } SFCNTR_t;
3634
3635 typedef union uSFTCCSR {
3636 uint16_t R;
3637 struct {
3638 uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
3639 uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
3640 uint16_t CYCNUM:6; /* cycle number */
3641 uint16_t ELKS:1; /* even cycle tables lock status */
3642 uint16_t OLKS:1; /* odd cycle tables lock status */
3643 uint16_t EVAL:1; /* even cycle tables valid */
3644 uint16_t OVAL:1; /* odd cycle tables valid */
3645 uint16_t:1;
3646 uint16_t OPT:1; /*one pair trigger */
3647 uint16_t SDVEN:1; /* sync frame deviation table enable */
3648 uint16_t SIDEN:1; /* sync frame ID table enable */
3649 } B;
3650 } SFTCCSR_t;
3651 typedef union uSFIDRFR {
3652 uint16_t R;
3653 struct {
3654 uint16_t:6;
3655 uint16_t SYNFRID:10; /* sync frame rejection ID */
3656 } B;
3657 } SFIDRFR_t;
3658
3659 typedef union uTICCR {
3660 uint16_t R;
3661 struct {
3662 uint16_t:2;
3663 uint16_t T2CFG:1; /* timer 2 configuration */
3664 uint16_t T2REP:1; /* timer 2 repetitive mode */
3665 uint16_t:1;
3666 uint16_t T2SP:1; /* timer 2 stop */
3667 uint16_t T2TR:1; /* timer 2 trigger */
3668 uint16_t T2ST:1; /* timer 2 state */
3669 uint16_t:3;
3670 uint16_t T1REP:1; /* timer 1 repetitive mode */
3671 uint16_t:1;
3672 uint16_t T1SP:1; /* timer 1 stop */
3673 uint16_t T1TR:1; /* timer 1 trigger */
3674 uint16_t T1ST:1; /* timer 1 state */
3675
3676 } B;
3677 } TICCR_t;
3678 typedef union uTI1CYSR {
3679 uint16_t R;
3680 struct {
3681 uint16_t:2;
3682 uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
3683 uint16_t:2;
3684 uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
3685
3686 } B;
3687 } TI1CYSR_t;
3688
3689 typedef union uSSSR {
3690 uint16_t R;
3691 struct {
3692 uint16_t WMD:1; /* write mode */
3693 uint16_t:1;
3694 uint16_t SEL:2; /* static slot number */
3695 uint16_t:1;
3696 uint16_t SLOTNUMBER:11; /* selector */
3697 } B;
3698 } SSSR_t;
3699
3700 typedef union uSSCCR {
3701 uint16_t R;
3702 struct {
3703 uint16_t WMD:1; /* write mode */
3704 uint16_t:1;
3705 uint16_t SEL:2; /* selector */
3706 uint16_t:1;
3707 uint16_t CNTCFG:2; /* counter configuration */
3708 uint16_t MCY:1; /* multi cycle selection */
3709 uint16_t VFR:1; /* valid frame selection */
3710 uint16_t SYF:1; /* sync frame selection */
3711 uint16_t NUF:1; /* null frame selection */
3712 uint16_t SUF:1; /* startup frame selection */
3713 uint16_t STATUSMASK:4; /* slot status mask */
3714 } B;
3715 } SSCCR_t;
3716 typedef union uSSR {
3717 uint16_t R;
3718 struct {
3719 uint16_t VFB:1; /* valid frame on channel B */
3720 uint16_t SYB:1; /* valid sync frame on channel B */
3721 uint16_t NFB:1; /* valid null frame on channel B */
3722 uint16_t SUB:1; /* valid startup frame on channel B */
3723 uint16_t SEB:1; /* syntax error on channel B */
3724 uint16_t CEB:1; /* content error on channel B */
3725 uint16_t BVB:1; /* boundary violation on channel B */
3726 uint16_t TCB:1; /* tx conflict on channel B */
3727 uint16_t VFA:1; /* valid frame on channel A */
3728 uint16_t SYA:1; /* valid sync frame on channel A */
3729 uint16_t NFA:1; /* valid null frame on channel A */
3730 uint16_t SUA:1; /* valid startup frame on channel A */
3731 uint16_t SEA:1; /* syntax error on channel A */
3732 uint16_t CEA:1; /* content error on channel A */
3733 uint16_t BVA:1; /* boundary violation on channel A */
3734 uint16_t TCA:1; /* tx conflict on channel A */
3735 } B;
3736 } SSR_t;
3737 typedef union uMTSCFR {
3738 uint16_t R;
3739 struct {
3740 uint16_t MTE:1; /* media access test symbol transmission enable */
3741 uint16_t:1;
3742 uint16_t CYCCNTMSK:6; /* cycle counter mask */
3743 uint16_t:2;
3744 uint16_t CYCCNTVAL:6; /* cycle counter value */
3745 } B;
3746 } MTSCFR_t;
3747
3748 typedef union uRSBIR {
3749 uint16_t R;
3750 struct {
3751 uint16_t WMD:1; /* write mode */
3752 uint16_t:1;
3753 uint16_t SEL:2; /* selector */
3754 uint16_t:5;
3755 uint16_t RSBIDX:7; /* receive shadow buffer index */
3756 } B;
3757 } RSBIR_t;
3758
3759 typedef union uRFDSR {
3760 uint16_t R;
3761 struct {
3762 uint16_t FIFODEPTH:8; /* fifo depth */
3763 uint16_t:1;
3764 uint16_t ENTRYSIZE:7; /* entry size */
3765 } B;
3766 } RFDSR_t;
3767
3768 typedef union uRFRFCFR {
3769 uint16_t R;
3770 struct {
3771 uint16_t WMD:1; /* write mode */
3772 uint16_t IBD:1; /* interval boundary */
3773 uint16_t SEL:2; /* filter number */
3774 uint16_t:1;
3775 uint16_t SID:11; /* slot ID */
3776 } B;
3777 } RFRFCFR_t;
3778
3779 typedef union uRFRFCTR {
3780 uint16_t R;
3781 struct {
3782 uint16_t:4;
3783 uint16_t F3MD:1; /* filter mode */
3784 uint16_t F2MD:1; /* filter mode */
3785 uint16_t F1MD:1; /* filter mode */
3786 uint16_t F0MD:1; /* filter mode */
3787 uint16_t:4;
3788 uint16_t F3EN:1; /* filter enable */
3789 uint16_t F2EN:1; /* filter enable */
3790 uint16_t F1EN:1; /* filter enable */
3791 uint16_t F0EN:1; /* filter enable */
3792 } B;
3793 } RFRFCTR_t;
3794 typedef union uPCR0 {
3795 uint16_t R;
3796 struct {
3797 uint16_t ACTION_POINT_OFFSET:6;
3798 uint16_t STATIC_SLOT_LENGTH:10;
3799 } B;
3800 } PCR0_t;
3801
3802 typedef union uPCR1 {
3803 uint16_t R;
3804 struct {
3805 uint16_t:2;
3806 uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
3807 } B;
3808 } PCR1_t;
3809
3810 typedef union uPCR2 {
3811 uint16_t R;
3812 struct {
3813 uint16_t MINISLOT_AFTER_ACTION_POINT:6;
3814 uint16_t NUMBER_OF_STATIC_SLOTS:10;
3815 } B;
3816 } PCR2_t;
3817
3818 typedef union uPCR3 {
3819 uint16_t R;
3820 struct {
3821 uint16_t WAKEUP_SYMBOL_RX_LOW:6;
3822 uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
3823 uint16_t COLDSTART_ATTEMPTS:5;
3824 } B;
3825 } PCR3_t;
3826
3827 typedef union uPCR4 {
3828 uint16_t R;
3829 struct {
3830 uint16_t CAS_RX_LOW_MAX:7;
3831 uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
3832 } B;
3833 } PCR4_t;
3834
3835 typedef union uPCR5 {
3836 uint16_t R;
3837 struct {
3838 uint16_t TSS_TRANSMITTER:4;
3839 uint16_t WAKEUP_SYMBOL_TX_LOW:6;
3840 uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
3841 } B;
3842 } PCR5_t;
3843
3844 typedef union uPCR6 {
3845 uint16_t R;
3846 struct {
3847 uint16_t:1;
3848 uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
3849 uint16_t MACRO_INITIAL_OFFSET_A:7;
3850 } B;
3851 } PCR6_t;
3852
3853 typedef union uPCR7 {
3854 uint16_t R;
3855 struct {
3856 uint16_t DECODING_CORRECTION_B:9;
3857 uint16_t MICRO_PER_MACRO_NOM_HALF:7;
3858 } B;
3859 } PCR7_t;
3860
3861 typedef union uPCR8 {
3862 uint16_t R;
3863 struct {
3864 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
3865 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
3866 uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
3867 } B;
3868 } PCR8_t;
3869
3870 typedef union uPCR9 {
3871 uint16_t R;
3872 struct {
3873 uint16_t MINISLOT_EXISTS:1;
3874 uint16_t SYMBOL_WINDOW_EXISTS:1;
3875 uint16_t OFFSET_CORRECTION_OUT:14;
3876 } B;
3877 } PCR9_t;
3878
3879 typedef union uPCR10 {
3880 uint16_t R;
3881 struct {
3882 uint16_t SINGLE_SLOT_ENABLED:1;
3883 uint16_t WAKEUP_CHANNEL:1;
3884 uint16_t MACRO_PER_CYCLE:14;
3885 } B;
3886 } PCR10_t;
3887
3888 typedef union uPCR11 {
3889 uint16_t R;
3890 struct {
3891 uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
3892 uint16_t KEY_SLOT_USED_FOR_SYNC:1;
3893 uint16_t OFFSET_CORRECTION_START:14;
3894 } B;
3895 } PCR11_t;
3896
3897 typedef union uPCR12 {
3898 uint16_t R;
3899 struct {
3900 uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
3901 uint16_t KEY_SLOT_HEADER_CRC:11;
3902 } B;
3903 } PCR12_t;
3904
3905 typedef union uPCR13 {
3906 uint16_t R;
3907 struct {
3908 uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
3909 uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
3910 } B;
3911 } PCR13_t;
3912
3913 typedef union uPCR14 {
3914 uint16_t R;
3915 struct {
3916 uint16_t RATE_CORRECTION_OUT:11;
3917 uint16_t LISTEN_TIMEOUT_H:5;
3918 } B;
3919 } PCR14_t;
3920
3921 typedef union uPCR15 {
3922 uint16_t R;
3923 struct {
3924 uint16_t LISTEN_TIMEOUT_L:16;
3925 } B;
3926 } PCR15_t;
3927
3928 typedef union uPCR16 {
3929 uint16_t R;
3930 struct {
3931 uint16_t MACRO_INITIAL_OFFSET_B:7;
3932 uint16_t NOISE_LISTEN_TIMEOUT_H:9;
3933 } B;
3934 } PCR16_t;
3935
3936 typedef union uPCR17 {
3937 uint16_t R;
3938 struct {
3939 uint16_t NOISE_LISTEN_TIMEOUT_L:16;
3940 } B;
3941 } PCR17_t;
3942
3943 typedef union uPCR18 {
3944 uint16_t R;
3945 struct {
3946 uint16_t WAKEUP_PATTERN:6;
3947 uint16_t KEY_SLOT_ID:10;
3948 } B;
3949 } PCR18_t;
3950
3951 typedef union uPCR19 {
3952 uint16_t R;
3953 struct {
3954 uint16_t DECODING_CORRECTION_A:9;
3955 uint16_t PAYLOAD_LENGTH_STATIC:7;
3956 } B;
3957 } PCR19_t;
3958
3959 typedef union uPCR20 {
3960 uint16_t R;
3961 struct {
3962 uint16_t MICRO_INITIAL_OFFSET_B:8;
3963 uint16_t MICRO_INITIAL_OFFSET_A:8;
3964 } B;
3965 } PCR20_t;
3966
3967 typedef union uPCR21 {
3968 uint16_t R;
3969 struct {
3970 uint16_t EXTERN_RATE_CORRECTION:3;
3971 uint16_t LATEST_TX:13;
3972 } B;
3973 } PCR21_t;
3974
3975 typedef union uPCR22 {
3976 uint16_t R;
3977 struct {
3978 uint16_t:1;
3979 uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
3980 uint16_t MICRO_PER_CYCLE_H:4;
3981 } B;
3982 } PCR22_t;
3983
3984 typedef union uPCR23 {
3985 uint16_t R;
3986 struct {
3987 uint16_t micro_per_cycle_l:16;
3988 } B;
3989 } PCR23_t;
3990
3991 typedef union uPCR24 {
3992 uint16_t R;
3993 struct {
3994 uint16_t CLUSTER_DRIFT_DAMPING:5;
3995 uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
3996 uint16_t MICRO_PER_CYCLE_MIN_H:4;
3997 } B;
3998 } PCR24_t;
3999
4000 typedef union uPCR25 {
4001 uint16_t R;
4002 struct {
4003 uint16_t MICRO_PER_CYCLE_MIN_L:16;
4004 } B;
4005 } PCR25_t;
4006
4007 typedef union uPCR26 {
4008 uint16_t R;
4009 struct {
4010 uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
4011 uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
4012 uint16_t MICRO_PER_CYCLE_MAX_H:4;
4013 } B;
4014 } PCR26_t;
4015
4016 typedef union uPCR27 {
4017 uint16_t R;
4018 struct {
4019 uint16_t MICRO_PER_CYCLE_MAX_L:16;
4020 } B;
4021 } PCR27_t;
4022
4023 typedef union uPCR28 {
4024 uint16_t R;
4025 struct {
4026 uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
4027 uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
4028 } B;
4029 } PCR28_t;
4030
4031 typedef union uPCR29 {
4032 uint16_t R;
4033 struct {
4034 uint16_t EXTERN_OFFSET_CORRECTION:3;
4035 uint16_t MINISLOTS_MAX:13;
4036 } B;
4037 } PCR29_t;
4038
4039 typedef union uPCR30 {
4040 uint16_t R;
4041 struct {
4042 uint16_t:12;
4043 uint16_t SYNC_NODE_MAX:4;
4044 } B;
4045 } PCR30_t;
4046
4047 typedef struct uMSG_BUFF_CCS {
4048 union {
4049 uint16_t R;
4050 struct {
4051 uint16_t:1;
4052 uint16_t MCM:1; /* message buffer commit mode */
4053 uint16_t MBT:1; /* message buffer type */
4054 uint16_t MTD:1; /* message buffer direction */
4055 uint16_t CMT:1; /* commit for transmission */
4056 uint16_t EDT:1; /* enable / disable trigger */
4057 uint16_t LCKT:1; /* lock request trigger */
4058 uint16_t MBIE:1; /* message buffer interrupt enable */
4059 uint16_t:3;
4060 uint16_t DUP:1; /* data updated */
4061 uint16_t DVAL:1; /* data valid */
4062 uint16_t EDS:1; /* lock status */
4063 uint16_t LCKS:1; /* enable / disable status */
4064 uint16_t MBIF:1; /* message buffer interrupt flag */
4065 } B;
4066 } MBCCSR;
4067 union {
4068 uint16_t R;
4069 struct {
4070 uint16_t MTM:1; /* message buffer transmission mode */
4071 uint16_t CHNLA:1; /* channel assignement */
4072 uint16_t CHNLB:1; /* channel assignement */
4073 uint16_t CCFE:1; /* cycle counter filter enable */
4074 uint16_t CCFMSK:6; /* cycle counter filter mask */
4075 uint16_t CCFVAL:6; /* cycle counter filter value */
4076 } B;
4077 } MBCCFR;
4078 union {
4079 uint16_t R;
4080 struct {
4081 uint16_t:5;
4082 uint16_t FID:11; /* frame ID */
4083 } B;
4084 } MBFIDR;
4085
4086 union {
4087 uint16_t R;
4088 struct {
4089 uint16_t:9;
4090 uint16_t MBIDX:7; /* message buffer index */
4091 } B;
4092 } MBIDXR;
4094 typedef union uSYSBADHR {
4095 uint16_t R;
4096 } SYSBADHR_t;
4097 typedef union uSYSBADLR {
4098 uint16_t R;
4099 } SYSBADLR_t;
4100 typedef union uPADR {
4101 uint16_t R;
4102 } PADR_t;
4103 typedef union uPDAR {
4104 uint16_t R;
4105 } PDAR_t;
4106 typedef union uCASERCR {
4107 uint16_t R;
4108 } CASERCR_t;
4109 typedef union uCBSERCR {
4110 uint16_t R;
4111 } CBSERCR_t;
4112 typedef union uCYCTR {
4113 uint16_t R;
4114 } CYCTR_t;
4115 typedef union uMTCTR {
4116 uint16_t R;
4117 } MTCTR_t;
4118 typedef union uSLTCTAR {
4119 uint16_t R;
4120 } SLTCTAR_t;
4121 typedef union uSLTCTBR {
4122 uint16_t R;
4123 } SLTCTBR_t;
4124 typedef union uRTCORVR {
4125 uint16_t R;
4126 } RTCORVR_t;
4127 typedef union uOFCORVR {
4128 uint16_t R;
4129 } OFCORVR_t;
4130 typedef union uSFTOR {
4131 uint16_t R;
4132 } SFTOR_t;
4133 typedef union uSFIDAFVR {
4134 uint16_t R;
4135 } SFIDAFVR_t;
4136 typedef union uSFIDAFMR {
4137 uint16_t R;
4138 } SFIDAFMR_t;
4139 typedef union uNMVR {
4140 uint16_t R;
4141 } NMVR_t;
4142 typedef union uNMVLR {
4143 uint16_t R;
4144 } NMVLR_t;
4145 typedef union uT1MTOR {
4146 uint16_t R;
4147 } T1MTOR_t;
4148 typedef union uTI2CR0 {
4149 uint16_t R;
4150 } TI2CR0_t;
4151 typedef union uTI2CR1 {
4152 uint16_t R;
4153 } TI2CR1_t;
4154 typedef union uSSCR {
4155 uint16_t R;
4156 } SSCR_t;
4157 typedef union uRFSR {
4158 uint16_t R;
4159 } RFSR_t;
4160 typedef union uRFSIR {
4161 uint16_t R;
4162 } RFSIR_t;
4163 typedef union uRFARIR {
4164 uint16_t R;
4165 } RFARIR_t;
4166 typedef union uRFBRIR {
4167 uint16_t R;
4168 } RFBRIR_t;
4169 typedef union uRFMIDAFVR {
4170 uint16_t R;
4171 } RFMIDAFVR_t;
4172 typedef union uRFMIAFMR {
4173 uint16_t R;
4174 } RFMIAFMR_t;
4175 typedef union uRFFIDRFVR {
4176 uint16_t R;
4177 } RFFIDRFVR_t;
4178 typedef union uRFFIDRFMR {
4179 uint16_t R;
4180 } RFFIDRFMR_t;
4181 typedef union uLDTXSLAR {
4182 uint16_t R;
4183 } LDTXSLAR_t;
4184 typedef union uLDTXSLBR {
4185 uint16_t R;
4186 } LDTXSLBR_t;
4187
4188 typedef struct FR_tag {
4189 volatile MVR_t MVR; /*module version register *//*0 */
4190 volatile MCR_t MCR; /*module configuration register *//*2 */
4191 volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
4192 volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
4193 volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
4194 uint16_t reserved0[1]; /*A */
4195 volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
4196 volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
4197 uint16_t reserved1[1]; /*10 */
4198 uint16_t reserved2[1]; /*12 */
4199 volatile POCR_t POCR; /*Protocol operation control register *//*14 */
4200 volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
4201 volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
4202 volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
4203 volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
4204 volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
4205 volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
4206 volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
4207 volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
4208 volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
4209 volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
4210 volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
4211 volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
4212 volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
4213 volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
4214 volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
4215 volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
4216 volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
4217 volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
4218 volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
4219 volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
4220 volatile SYMATOR_t SYMATOR; /*system memory acess time-out register *//*3E */
4221 volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
4222 volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
4223 volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
4224 volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
4225 volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
4226 volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
4227 volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
4228 volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
4229 volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
4230 volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
4231 volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
4232 volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
4233 volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
4234 volatile SSSR_t SSSR; /*slot status selection register *//*64 */
4235 volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
4236 volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
4237 volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
4238 volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
4239 volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
4240 volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
4241 volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
4242 volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
4243 volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
4244 volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
4245 volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
4246 volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
4247 volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
4248 volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
4249 volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
4250 volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
4251 volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
4252 volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
4253 volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
4254 volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
4255 volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
4256 volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
4257 volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
4258 volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
4259 volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
4260 volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
4261 volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
4262 volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
4263 volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
4264 volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
4265 volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
4266 volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
4267 volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
4268 volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
4269 volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
4270 volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
4271 volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
4272 volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
4273 volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
4274 volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
4275 volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
4276 volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
4277 volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
4278 volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
4279 volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
4280 volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
4281 volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
4282 volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
4283 volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
4284 volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
4285 uint16_t reserved3[17];
4286 volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
4287 } FR_tag_t;
4288
4289 typedef union uF_HEADER /* frame header */
4290 {
4291 struct {
4292 uint16_t:5;
4293 uint16_t HDCRC:11; /* Header CRC */
4294 uint16_t:2;
4295 uint16_t CYCCNT:6; /* Cycle Count */
4296 uint16_t:1;
4297 uint16_t PLDLEN:7; /* Payload Length */
4298 uint16_t:1;
4299 uint16_t PPI:1; /* Payload Preamble Indicator */
4300 uint16_t NUF:1; /* Null Frame Indicator */
4301 uint16_t SYF:1; /* Sync Frame Indicator */
4302 uint16_t SUF:1; /* Startup Frame Indicator */
4303 uint16_t FID:11; /* Frame ID */
4304 } B;
4305 uint16_t WORDS[3];
4306 } F_HEADER_t;
4307 typedef union uS_STSTUS /* slot status */
4308 {
4309 struct {
4310 uint16_t VFB:1; /* Valid Frame on channel B */
4311 uint16_t SYB:1; /* Sync Frame Indicator channel B */
4312 uint16_t NFB:1; /* Null Frame Indicator channel B */
4313 uint16_t SUB:1; /* Startup Frame Indicator channel B */
4314 uint16_t SEB:1; /* Syntax Error on channel B */
4315 uint16_t CEB:1; /* Content Error on channel B */
4316 uint16_t BVB:1; /* Boundary Violation on channel B */
4317 uint16_t CH:1; /* Channel */
4318 uint16_t VFA:1; /* Valid Frame on channel A */
4319 uint16_t SYA:1; /* Sync Frame Indicator channel A */
4320 uint16_t NFA:1; /* Null Frame Indicator channel A */
4321 uint16_t SUA:1; /* Startup Frame Indicator channel A */
4322 uint16_t SEA:1; /* Syntax Error on channel A */
4323 uint16_t CEA:1; /* Content Error on channel A */
4324 uint16_t BVA:1; /* Boundary Violation on channel A */
4325 uint16_t:1;
4326 } RX;
4327 struct {
4328 uint16_t VFB:1; /* Valid Frame on channel B */
4329 uint16_t SYB:1; /* Sync Frame Indicator channel B */
4330 uint16_t NFB:1; /* Null Frame Indicator channel B */
4331 uint16_t SUB:1; /* Startup Frame Indicator channel B */
4332 uint16_t SEB:1; /* Syntax Error on channel B */
4333 uint16_t CEB:1; /* Content Error on channel B */
4334 uint16_t BVB:1; /* Boundary Violation on channel B */
4335 uint16_t TCB:1; /* Tx Conflict on channel B */
4336 uint16_t VFA:1; /* Valid Frame on channel A */
4337 uint16_t SYA:1; /* Sync Frame Indicator channel A */
4338 uint16_t NFA:1; /* Null Frame Indicator channel A */
4339 uint16_t SUA:1; /* Startup Frame Indicator channel A */
4340 uint16_t SEA:1; /* Syntax Error on channel A */
4341 uint16_t CEA:1; /* Content Error on channel A */
4342 uint16_t BVA:1; /* Boundary Violation on channel A */
4343 uint16_t TCA:1; /* Tx Conflict on channel A */
4344 } TX;
4345 uint16_t R;
4346 } S_STATUS_t;
4347
4348 typedef struct uMB_HEADER /* message buffer header */
4349 {
4350 F_HEADER_t FRAME_HEADER;
4351 uint16_t DATA_OFFSET;
4352 S_STATUS_t SLOT_STATUS;
4353 } MB_HEADER_t;
4354/**************************************************************************/
4355/* MODULE : FMPLL */
4356/**************************************************************************/
4357 struct FMPLL_tag {
4358
4359 uint32_t FMPLL_reserved0;
4360
4361 union FMPLL_SYNSR_tag { /* Synthesiser Status Register */
4362 uint32_t R;
4363 struct {
4364 uint32_t:22;
4365 uint32_t LOLF:1;
4366 uint32_t LOC:1;
4367 uint32_t MODE:1;
4368 uint32_t PLLSEL:1;
4369 uint32_t PLLREF:1;
4370 uint32_t LOCKS:1;
4371 uint32_t LOCK:1;
4372 uint32_t LOCF:1;
4373 uint32_t CALDONE:1;
4374 uint32_t CALPASS:1;
4375 } B;
4376 } SYNSR;
4377
4378 union FMPLL_ESYNCR1_tag {
4379 uint32_t R;
4380 struct {
4381 uint32_t:1;
4382 uint32_t CLKCFG:3;
4383 uint32_t:8;
4384 uint32_t EPREDIV:4;
4385 uint32_t:8;
4386 uint32_t EMFD:8;
4387 } B;
4388 } ESYNCR1;
4389
4390 union FMPLL_ESYNCR2_tag {
4391 uint32_t R;
4392 struct {
4393 uint32_t:8;
4394 uint32_t LOCEN:1;
4395 uint32_t LOLRE:1;
4396 uint32_t LOCRE:1;
4397 uint32_t LOLIRQ:1;
4398 uint32_t LOCIRQ:1;
4399 uint32_t:1;
4400 uint32_t ERATE:2;
4401 uint32_t:5;
4402 uint32_t EDEPTH:3;
4403 uint32_t:2;
4404 uint32_t ERFD:6;
4405 } B;
4406 } ESYNCR2;
4407
4408 };
4409/*************************************************************************/
4410/* MODULE : i2c */
4411/*************************************************************************/
4412 struct I2C_tag {
4413 union {
4414 uint8_t R;
4415 struct {
4416 uint8_t AD:7;
4417 uint8_t:1;
4418 } B;
4419 } IBAD; /* Module Bus Address Register */
4420
4421 union {
4422 uint8_t R;
4423 struct {
4424 uint8_t MULT:2;
4425 uint8_t ICR:6;
4426 } B;
4427 } IBFD; /* Module Bus Frequency Register */
4428
4429 union {
4430 uint8_t R;
4431 struct {
4432 uint8_t MDIS:1;
4433 uint8_t IBIE:1;
4434 uint8_t MS:1;
4435 uint8_t TX:1;
4436 uint8_t NOACK:1;
4437 uint8_t RSTA:1;
4438 uint8_t DMAEN:1;
4439 uint8_t:1;
4440 } B;
4441 } IBCR; /* Module Bus Control Register */
4442
4443 union {
4444 uint8_t R;
4445 struct {
4446 uint8_t TCF:1;
4447 uint8_t IAAS:1;
4448 uint8_t IBB:1;
4449 uint8_t IBAL:1;
4450 uint8_t:1;
4451 uint8_t SRW:1;
4452 uint8_t IBIF:1;
4453 uint8_t RXAK:1;
4454 } B;
4455 } IBSR; /* Module Status Register */
4456
4457 union {
4458 uint8_t R;
4459 struct {
4460 uint8_t DATA:8;
4461 } B;
4462 } IBDR; /* Module Data Register */
4463
4464 union {
4465 uint8_t R;
4466 struct {
4467 uint8_t BIIE:1;
4468 uint8_t:7;
4469 } B;
4470 } IBIC; /* Module Interrupt Configuration Register */
4471
4472 }; /* end of i2c_tag */
4473/*************************************************************************/
4474/* MODULE : INTC */
4475/*************************************************************************/
4476 struct INTC_tag {
4477 union {
4478 uint32_t R;
4479 struct {
4480 uint32_t:18;
4481 uint32_t VTES_PRC1:1;
4482 uint32_t:4;
4483 uint32_t HVEN_PRC1:1;
4484 uint32_t:2;
4485 uint32_t VTES:1;
4486 uint32_t:4;
4487 uint32_t HVEN:1;
4488 } B;
4489 } MCR; /* Module Configuration Register */
4490
4491 int32_t INTC_reserved1;
4492
4493 union {
4494 uint32_t R;
4495 struct {
4496 uint32_t:28;
4497 uint32_t PRI:4;
4498 } B;
4499 } CPR; /* Processor 0 (Z6) Current Priority Register */
4500
4501 union {
4502 uint32_t R;
4503 struct {
4504 uint32_t:28;
4505 uint32_t PRI:4;
4506 } B;
4507 } CPR_PRC1; /* Processor 1 (Z0) Current Priority Register */
4508
4509 union {
4510 uint32_t R;
4511 struct {
4512 uint32_t VTBA:21;
4513 uint32_t INTVEC:9;
4514 uint32_t:2;
4515 } B;
4516 } IACKR; /* Processor 0 (Z6) Interrupt Acknowledge Register */
4517
4518 union {
4519 uint32_t R;
4520 struct {
4521 uint32_t VTBA_PRC1:21;
4522 uint32_t INTVEC_PRC1:9;
4523 uint32_t:2;
4524 } B;
4525 } IACKR_PRC1; /* Processor 1 (Z0) Interrupt Acknowledge Register */
4526
4527 union {
4528 uint32_t R;
4529 struct {
4530 uint32_t:32;
4531 } B;
4532 } EOIR; /* Processor 0 End of Interrupt Register */
4533
4534 union {
4535 uint32_t R;
4536 struct {
4537 uint32_t:32;
4538 } B;
4539 } EOIR_PRC1; /* Processor 1 End of Interrupt Register */
4540
4541 union {
4542 uint8_t R;
4543 struct {
4544 uint8_t:6;
4545 uint8_t SET:1;
4546 uint8_t CLR:1;
4547 } B;
4548 } SSCIR[8]; /* Software Set/Clear Interruput Register */
4549
4550 uint32_t intc_reserved2[6];
4551
4552 union {
4553 uint8_t R;
4554 struct {
4555 uint8_t PRC_SEL:2;
4556 uint8_t:2;
4557 uint8_t PRI:4;
4558 } B;
4559 } PSR[316]; /* Software Set/Clear Interrupt Register */
4560
4561 }; /* end of INTC_tag */
4562/*************************************************************************/
4563/* MODULE : MLB */
4564/*************************************************************************/
4565 struct MLB_tag {
4566
4567 union {
4568 uint32_t R;
4569 struct {
4570 uint32_t MDE:1;
4571 uint32_t LBM:1;
4572 uint32_t MCS:2;
4573 uint32_t:1;
4574 uint32_t MLK:1;
4575 uint32_t MLE:1;
4576 uint32_t MHRE:1;
4577 uint32_t MRS:1;
4578 uint32_t:15;
4579 uint32_t MDA:8;
4580 } B;
4581 } DCCR; /* Device Control Configuration Register */
4582
4583 union {
4584 uint32_t R;
4585 struct {
4586 uint32_t:24;
4587 uint32_t SSRE:1;
4588 uint32_t SDMU:1;
4589 uint32_t SDML:1;
4590 uint32_t SDSC:1;
4591 uint32_t SDCS:1;
4592 uint32_t SDNU:1;
4593 uint32_t SDNL:1;
4594 uint32_t SDR:1;
4595 } B;
4596 } SSCR; /* MLB Blank Register */
4597
4598 union {
4599 uint32_t R;
4600 struct {
4601 uint32_t MSD:32;
4602 } B;
4603 } SDCR; /* MLB Status Register */
4604
4605 union {
4606 uint32_t R;
4607 struct {
4608 uint32_t:25;
4609 uint32_t SMMU:1;
4610 uint32_t SMML:1;
4611 uint32_t SMSC:1;
4612 uint32_t SMCS:1;
4613 uint32_t SMNU:1;
4614 uint32_t SMNL:1;
4615 uint32_t SMR:1;
4616 } B;
4617 } SMCR; /* RX Control Channel Address Register */
4618
4619 uint32_t MLB_reserved1[3];
4620
4621 union {
4622 uint32_t R;
4623 struct {
4624 uint32_t UMA:8;
4625 uint32_t UMI:8;
4626 uint32_t MMA:8;
4627 uint32_t MMI:8;
4628 } B;
4629 } VCCR; /* Version Control Configuration Register */
4630
4631 union {
4632 uint32_t R;
4633 struct {
4634 uint32_t SRBA:16;
4635 uint32_t STBA:16;
4636 } B;
4637 } SBCR; /* Sync Base Address Config Register */
4638
4639 union {
4640 uint32_t R;
4641 struct {
4642 uint32_t ARBA:16;
4643 uint32_t ATBA:16;
4644 } B;
4645 } ABCR; /* Async Base Address Channel Config Register */
4646
4647 union {
4648 uint32_t R;
4649 struct {
4650 uint32_t CRBA:16;
4651 uint32_t CTBA:16;
4652 } B;
4653 } CBCR; /* Control Base Address Config Register */
4654
4655 union {
4656 uint32_t R;
4657 struct {
4658 uint32_t IRBA:16;
4659 uint32_t ITBA:16;
4660 } B;
4661 } IBCR; /* Isochronous Base Address Config Register */
4662
4663 union {
4664 uint32_t R;
4665 struct {
4666 uint32_t:16;
4667 uint32_t CSU:16;
4668 } B;
4669 } CICR; /* Channel Interrupt Config Register */
4670
4671 uint32_t MLB_reserved2[3];
4672
4673 struct mlbch_t {
4674
4675 union {
4676 uint32_t R;
4677 struct {
4678 uint32_t CE:1;
4679 uint32_t TR:1;
4680 uint32_t CT:2;
4681 uint32_t FSE_FCE:1;
4682 uint32_t MDS:2;
4683 uint32_t:2;
4684 uint32_t MLFS:1;
4685 uint32_t:1;
4686 uint32_t MBE:1;
4687 uint32_t MBS:1;
4688 uint32_t MBD:1;
4689 uint32_t MDB:1;
4690 uint32_t MPE:1;
4691 uint32_t FSCD_IPL:1;
4692 uint32_t IPL:2;
4693 uint32_t FSPC_IPL:5;
4694 uint32_t CA:8;
4695 } B;
4696 } CECR; /* Channel Entry Config Register */
4697
4698 union {
4699 uint32_t R;
4700 struct {
4701 uint32_t BM:1;
4702 uint32_t BF:1;
4703 uint32_t:10;
4704 uint32_t IVB:2;
4705 uint32_t GIRB_GB:1;
4706 uint32_t RDY:1;
4707 uint32_t:4;
4708 uint32_t PBS:1;
4709 uint32_t PBD:1;
4710 uint32_t PBDB:1;
4711 uint32_t PBPE:1;
4712 uint32_t:1;
4713 uint32_t LFS:1;
4714 uint32_t HBE:1;
4715 uint32_t BE:1;
4716 uint32_t CBS:1;
4717 uint32_t CBD:1;
4718 uint32_t CBDB:1;
4719 uint32_t CBPE:1;
4720 } B;
4721 } CSCR; /* Channel Status Config Register */
4722
4723 union {
4724 uint32_t R;
4725 struct {
4726 uint32_t BCA:16;
4727 uint32_t BFA:16;
4728 } B;
4729 } CCBCR; /* Channel Current Buffer Config Register */
4730
4731 union {
4732 uint32_t R;
4733 struct {
4734 uint32_t BSA:16;
4735 uint32_t BEA:16;
4736 } B;
4737 } CNBCR; /* Channel Next Buffer Config Register */
4738
4739 } CH[16];
4740
4741 uint32_t MLB_reserved3[80];
4742
4743 union {
4744 uint32_t R;
4745 struct {
4746 uint32_t BSA:16;
4747 uint32_t BEA:16;
4748 } B;
4749 } LCBCR[16]; /* Local Channel Buffer Config Register */
4750
4751 }; /* end of MLB_tag */
4752/*************************************************************************/
4753/* MODULE : MPU */
4754/*************************************************************************/
4755 struct MPU_tag {
4756 union {
4757 uint32_t R;
4758 struct {
4759 uint32_t MPERR:8;
4760 uint32_t:4;
4761 uint32_t HRL:4;
4762 uint32_t NSP:4;
4763 uint32_t NGRD:4;
4764 uint32_t:7;
4765 uint32_t VLD:1;
4766 } B;
4767 } CESR; /* Module Control/Error Status Register */
4768
4769 uint32_t mpu_reserved1[3];
4770
4771 union {
4772 uint32_t R;
4773 struct {
4774 uint32_t EADDR:32;
4775 } B;
4776 } EAR0; /* Error Address Register */
4777
4778 union {
4779 uint32_t R;
4780 struct {
4781 uint32_t EACD:16;
4782 uint32_t EPID:8;
4783 uint32_t EMN:4;
4784 uint32_t EATTR:3;
4785 uint32_t ERW:1;
4786 } B;
4787 } EDR0; /* Error Detail Register */
4788
4789 union {
4790 uint32_t R;
4791 struct {
4792 uint32_t EADDR:32;
4793 } B;
4794 } EAR1;
4795
4796 union {
4797 uint32_t R;
4798 struct {
4799 uint32_t EACD:16;
4800 uint32_t EPID:8;
4801 uint32_t EMN:4;
4802 uint32_t EATTR:3;
4803 uint32_t ERW:1;
4804 } B;
4805 } EDR1;
4806
4807 union {
4808 uint32_t R;
4809 struct {
4810 uint32_t EADDR:32;
4811 } B;
4812 } EAR2;
4813
4814 union {
4815 uint32_t R;
4816 struct {
4817 uint32_t EACD:16;
4818 uint32_t EPID:8;
4819 uint32_t EMN:4;
4820 uint32_t EATTR:3;
4821 uint32_t ERW:1;
4822 } B;
4823 } EDR3;
4824
4825 union {
4826 uint32_t R;
4827 struct {
4828 uint32_t EADDR:32;
4829 } B;
4830 } EAR3;
4831
4832 union {
4833 uint32_t R;
4834 struct {
4835 uint32_t EACD:16;
4836 uint32_t EPID:8;
4837 uint32_t EMN:4;
4838 uint32_t EATTR:3;
4839 uint32_t ERW:1;
4840 } B;
4841 } EDR2;
4842
4843 uint32_t mpu_reserved2[244];
4844
4845 struct {
4846 union {
4847 uint32_t R;
4848 struct {
4849 uint32_t SRTADDR:27;
4850 uint32_t:5;
4851 } B;
4852 } WORD0; /* Region Descriptor n Word 0 */
4853
4854 union {
4855 uint32_t R;
4856 struct {
4857 uint32_t ENDADDR:27;
4858 uint32_t:5;
4859 } B;
4860 } WORD1; /* Region Descriptor n Word 1 */
4861
4862 union {
4863 uint32_t R;
4864 struct {
4865 uint32_t:2;
4866 uint32_t M6RE:1;
4867 uint32_t M6WE:1;
4868 uint32_t M5RE:1;
4869 uint32_t M5WE:1;
4870 uint32_t M4RE:1;
4871 uint32_t M4WE:1;
4872 uint32_t:6;
4873 uint32_t M2PE:1;
4874 uint32_t M2SM:2;
4875 uint32_t M2UM:3;
4876 uint32_t M1PE:1;
4877 uint32_t M1SM:2;
4878 uint32_t M1UM:3;
4879 uint32_t M0PE:1;
4880 uint32_t M0SM:2;
4881 uint32_t M0UM:3;
4882 } B;
4883 } WORD2; /* Region Descriptor n Word 2 */
4884
4885 union {
4886 uint32_t R;
4887 struct {
4888 uint32_t PID:8;
4889 uint32_t PIDMASK:8;
4890 uint32_t:15;
4891 uint32_t VLD:1;
4892 } B;
4893 } WORD3; /* Region Descriptor n Word 3 */
4894
4895 } RGD[16];
4896
4897 uint32_t mpu_reserved3[192];
4898
4899 union {
4900 uint32_t R;
4901 struct {
4902 uint32_t:2;
4903 uint32_t M6RE:1;
4904 uint32_t M6WE:1;
4905 uint32_t M5RE:1;
4906 uint32_t M5WE:1;
4907 uint32_t M4RE:1;
4908 uint32_t M4WE:1;
4909 uint32_t:6;
4910 uint32_t M2PE:1;
4911 uint32_t M2SM:2;
4912 uint32_t M2UM:3;
4913 uint32_t M1PE:1;
4914 uint32_t M1SM:2;
4915 uint32_t M1UM:3;
4916 uint32_t M0PE:1;
4917 uint32_t M0SM:2;
4918 uint32_t M0UM:3;
4919 } B;
4920 } RGDAAC[16]; /* Region Descriptor Alternate Access Control n */
4921 };
4922/**************************************************************************/
4923/* MODULE : pit */
4924/**************************************************************************/
4925 struct PIT_tag {
4926
4928 uint32_t R;
4929 struct {
4930 uint32_t:30;
4931 uint32_t MDIS:1;
4932 uint32_t FRZ:1;
4933 } B;
4934 } PITMCR;
4935
4936 uint32_t pit_reserved1[59];
4937
4939 union {
4940 uint32_t R;
4941 struct {
4942 uint32_t TSV:32;
4943 } B;
4944 } LDVAL;
4945
4946 union {
4947 uint32_t R;
4948 struct {
4949 uint32_t TVL:32;
4950 } B;
4951 } CVAL;
4952
4954 uint32_t R;
4955 struct {
4956 uint32_t:30;
4957 uint32_t TIE:1;
4958 uint32_t TEN:1;
4959 } B;
4960 } TCTRL;
4961
4963 uint32_t R;
4964 struct {
4965 uint32_t:31;
4966 uint32_t TIF:1;
4967 } B;
4968 } TFLG;
4969 } CHANNEL[9];
4970 };
4971
4972 /* Compatibility with MPC5643L */
4973 typedef struct PIT_CHANNEL_tag PIT_RTI_CHANNEL_tag;
4974 typedef union PIT_MCR_tag PIT_RTI_PITMCR_32B_tag;
4975 typedef union PIT_TCTRL_tag PIT_RTI_TCTRL_32B_tag;
4976 typedef union PIT_TFLG_tag PIT_RTI_TFLG_32B_tag;
4977/**************************************************************************/
4978/* MODULE : sem4 */
4979/**************************************************************************/
4980 struct SEMA4_tag {
4981 union {
4982 uint8_t R;
4983 struct {
4984 uint8_t:6;
4985 uint8_t GTFSM:2;
4986 } B;
4987 } GATE[16]; /* Gate n Register */
4988
4989 uint32_t sema4_reserved1[12]; /* {0x40-0x10}/4 = 0x0C */
4990
4991 union {
4992 uint16_t R;
4993 struct {
4994 uint16_t INE0:1;
4995 uint16_t INE1:1;
4996 uint16_t INE2:1;
4997 uint16_t INE3:1;
4998 uint16_t INE4:1;
4999 uint16_t INE5:1;
5000 uint16_t INE6:1;
5001 uint16_t INE7:1;
5002 uint16_t INE8:1;
5003 uint16_t INE9:1;
5004 uint16_t INE10:1;
5005 uint16_t INE11:1;
5006 uint16_t INE12:1;
5007 uint16_t INE13:1;
5008 uint16_t INE14:1;
5009 uint16_t INE15:1;
5010 } B;
5011 } CP0INE;
5012
5013 uint16_t sema4_reserved2[3]; /* {0x48-0x42}/2 = 0x03 */
5014
5015 union {
5016 uint16_t R;
5017 struct {
5018 uint16_t INE0:1;
5019 uint16_t INE1:1;
5020 uint16_t INE2:1;
5021 uint16_t INE3:1;
5022 uint16_t INE4:1;
5023 uint16_t INE5:1;
5024 uint16_t INE6:1;
5025 uint16_t INE7:1;
5026 uint16_t INE8:1;
5027 uint16_t INE9:1;
5028 uint16_t INE10:1;
5029 uint16_t INE11:1;
5030 uint16_t INE12:1;
5031 uint16_t INE13:1;
5032 uint16_t INE14:1;
5033 uint16_t INE15:1;
5034 } B;
5035 } CP1INE;
5036
5037 uint16_t sema4_reserved3[27]; /* {0x80-0x4A}/2 = 0x1B */
5038
5039 union {
5040 uint16_t R;
5041 struct {
5042 uint16_t GN0:1;
5043 uint16_t GN1:1;
5044 uint16_t GN2:1;
5045 uint16_t GN3:1;
5046 uint16_t GN4:1;
5047 uint16_t GN5:1;
5048 uint16_t GN6:1;
5049 uint16_t GN7:1;
5050 uint16_t GN8:1;
5051 uint16_t GN9:1;
5052 uint16_t GN10:1;
5053 uint16_t GN11:1;
5054 uint16_t GN12:1;
5055 uint16_t GN13:1;
5056 uint16_t GN14:1;
5057 uint16_t GN15:1;
5058 } B;
5059 } CP0NTF;
5060
5061 uint16_t sema4_reserved4[3]; /* {0x88-0x82}/2 = 0x03 */
5062
5063 union {
5064 uint16_t R;
5065 struct {
5066 uint16_t GN0:1;
5067 uint16_t GN1:1;
5068 uint16_t GN2:1;
5069 uint16_t GN3:1;
5070 uint16_t GN4:1;
5071 uint16_t GN5:1;
5072 uint16_t GN6:1;
5073 uint16_t GN7:1;
5074 uint16_t GN8:1;
5075 uint16_t GN9:1;
5076 uint16_t GN10:1;
5077 uint16_t GN11:1;
5078 uint16_t GN12:1;
5079 uint16_t GN13:1;
5080 uint16_t GN14:1;
5081 uint16_t GN15:1;
5082 } B;
5083 } CP1NTF;
5084
5085 uint16_t sema4_reserved5[59]; /* {0x100-0x8A}/2 = 0x3B */
5086
5087 union {
5088 uint16_t R;
5089 struct {
5090 uint16_t:2;
5091 uint16_t RSTGSM:2;
5092 uint16_t:1;
5093 uint16_t RSTGMS:3;
5094 uint16_t RSTGTN:8;
5095 } B;
5096 } RSTGT;
5097
5098 uint16_t sema4_reserved6;
5099
5100 union {
5101 uint16_t R;
5102 struct {
5103 uint16_t:2;
5104 uint16_t RSTNSM:2;
5105 uint16_t:1;
5106 uint16_t RSTNMS:3;
5107 uint16_t RSTNTN:8;
5108 } B;
5109 } RSTNTF;
5110 };
5111/*************************************************************************/
5112/* MODULE : SIU */
5113/*************************************************************************/
5114 struct SIU_tag {
5115
5116 int32_t SIU_reserved0;
5117
5118 union {
5119 uint32_t R;
5120 struct {
5121 uint32_t PARTNUM:16;
5122 uint32_t CSP:1;
5123 uint32_t PKG:5;
5124 uint32_t:2;
5125 uint32_t MASKNUM_MAJOR:4;
5126 uint32_t MASKNUM_MINOR:4;
5127 } B;
5128 } MIDR; /* MCU ID Register */
5129
5130 int32_t SIU_reserved1;
5131
5132 union {
5133 uint32_t R;
5134 struct {
5135 uint32_t PORS:1;
5136 uint32_t ERS:1;
5137 uint32_t LLRS:1;
5138 uint32_t LCRS:1;
5139 uint32_t WDRS:1;
5140 uint32_t CRS:1;
5141 uint32_t:8;
5142 uint32_t SSRS:1;
5143 uint32_t:15;
5144 uint32_t BOOTCFG:1;
5145 uint32_t:1;
5146 } B;
5147 } RSR; /* Reset Status Register */
5148
5149 union {
5150 uint32_t R;
5151 struct {
5152 uint32_t SSR:1;
5153 uint32_t:15;
5154 uint32_t CRE0:1;
5155 uint32_t CRE1:1;
5156 uint32_t:6;
5157 uint32_t SSRL:1;
5158 uint32_t:7;
5159 } B;
5160 } SRCR; /* System Reset Control Register */
5161
5162 union {
5163 uint32_t R;
5164 struct {
5165 uint32_t NMI0:1;
5166 uint32_t NMI1:1;
5167 uint32_t:14;
5168 uint32_t EIF15:1;
5169 uint32_t EIF14:1;
5170 uint32_t EIF13:1;
5171 uint32_t EIF12:1;
5172 uint32_t EIF11:1;
5173 uint32_t EIF10:1;
5174 uint32_t EIF9:1;
5175 uint32_t EIF8:1;
5176 uint32_t EIF7:1;
5177 uint32_t EIF6:1;
5178 uint32_t EIF5:1;
5179 uint32_t EIF4:1;
5180 uint32_t EIF3:1;
5181 uint32_t EIF2:1;
5182 uint32_t EIF1:1;
5183 uint32_t EIF0:1;
5184 } B;
5185 } EISR; /* External Interrupt Status Register */
5186
5187 union SIU_DIRER_tag {
5188 uint32_t R;
5189 struct {
5190 uint32_t:16;
5191 uint32_t EIRE15:1;
5192 uint32_t EIRE14:1;
5193 uint32_t EIRE13:1;
5194 uint32_t EIRE12:1;
5195 uint32_t EIRE11:1;
5196 uint32_t EIRE10:1;
5197 uint32_t EIRE9:1;
5198 uint32_t EIRE8:1;
5199 uint32_t EIRE7:1;
5200 uint32_t EIRE6:1;
5201 uint32_t EIRE5:1;
5202 uint32_t EIRE4:1;
5203 uint32_t EIRE3:1;
5204 uint32_t EIRE2:1;
5205 uint32_t EIRE1:1;
5206 uint32_t EIRE0:1;
5207 } B;
5208 } DIRER; /* DMA/Interrupt Request Enable Register */
5209
5210 union SIU_DIRSR_tag {
5211 uint32_t R;
5212 struct {
5213 uint32_t:30;
5214 uint32_t DIRS1:1;
5215 uint32_t DIRS0:1;
5216 } B;
5217 } DIRSR; /* DMA/Interrupt Select Register */
5218
5219 union {
5220 uint32_t R;
5221 struct {
5222 uint32_t:16;
5223 uint32_t OVF15:1;
5224 uint32_t OVF14:1;
5225 uint32_t OVF13:1;
5226 uint32_t OVF12:1;
5227 uint32_t OVF11:1;
5228 uint32_t OVF10:1;
5229 uint32_t OVF9:1;
5230 uint32_t OVF8:1;
5231 uint32_t OVF7:1;
5232 uint32_t OVF6:1;
5233 uint32_t OVF5:1;
5234 uint32_t OVF4:1;
5235 uint32_t OVF3:1;
5236 uint32_t OVF2:1;
5237 uint32_t OVF1:1;
5238 uint32_t OVF0:1;
5239 } B;
5240 } OSR; /* Overrun Status Register */
5241
5242 union SIU_ORER_tag {
5243 uint32_t R;
5244 struct {
5245 uint32_t:16;
5246 uint32_t ORE15:1;
5247 uint32_t ORE14:1;
5248 uint32_t ORE13:1;
5249 uint32_t ORE12:1;
5250 uint32_t ORE11:1;
5251 uint32_t ORE10:1;
5252 uint32_t ORE9:1;
5253 uint32_t ORE8:1;
5254 uint32_t ORE7:1;
5255 uint32_t ORE6:1;
5256 uint32_t ORE5:1;
5257 uint32_t ORE4:1;
5258 uint32_t ORE3:1;
5259 uint32_t ORE2:1;
5260 uint32_t ORE1:1;
5261 uint32_t ORE0:1;
5262 } B;
5263 } ORER; /* Overrun Request Enable Register */
5264
5265 union SIU_IREER_tag {
5266 uint32_t R;
5267 struct {
5268 uint32_t NREE0:1;
5269 uint32_t NREE1:1;
5270 uint32_t:14;
5271 uint32_t IREE15:1;
5272 uint32_t IREE14:1;
5273 uint32_t IREE13:1;
5274 uint32_t IREE12:1;
5275 uint32_t IREE11:1;
5276 uint32_t IREE10:1;
5277 uint32_t IREE9:1;
5278 uint32_t IREE8:1;
5279 uint32_t IREE7:1;
5280 uint32_t IREE6:1;
5281 uint32_t IREE5:1;
5282 uint32_t IREE4:1;
5283 uint32_t IREE3:1;
5284 uint32_t IREE2:1;
5285 uint32_t IREE1:1;
5286 uint32_t IREE0:1;
5287 } B;
5288 } IREER; /* External IRQ Rising-Edge Event Enable Register */
5289
5290 union SIU_IFEER_tag {
5291 uint32_t R;
5292 struct {
5293 uint32_t NFEE0:1;
5294 uint32_t NFEE1:1;
5295 uint32_t:14;
5296 uint32_t IFEE15:1;
5297 uint32_t IFEE14:1;
5298 uint32_t IFEE13:1;
5299 uint32_t IFEE12:1;
5300 uint32_t IFEE11:1;
5301 uint32_t IFEE10:1;
5302 uint32_t IFEE9:1;
5303 uint32_t IFEE8:1;
5304 uint32_t IFEE7:1;
5305 uint32_t IFEE6:1;
5306 uint32_t IFEE5:1;
5307 uint32_t IFEE4:1;
5308 uint32_t IFEE3:1;
5309 uint32_t IFEE2:1;
5310 uint32_t IFEE1:1;
5311 uint32_t IFEE0:1;
5312 } B;
5313 } IFEER; /* External IRQ Falling-Edge Event Enable Register */
5314
5315 union SIU_IDFR_tag {
5316 uint32_t R;
5317 struct {
5318 uint32_t:28;
5319 uint32_t DFL:4;
5320 } B;
5321 } IDFR; /* External IRQ Digital Filter Register */
5322
5323 union {
5324 uint32_t R;
5325 struct {
5326 uint32_t FNMI0:1;
5327 uint32_t FNMI1:1;
5328 uint32_t:14;
5329 uint32_t FI15:1;
5330 uint32_t FI14:1;
5331 uint32_t FI13:1;
5332 uint32_t FI12:1;
5333 uint32_t FI11:1;
5334 uint32_t FI10:1;
5335 uint32_t FI9:1;
5336 uint32_t FI8:1;
5337 uint32_t FI7:1;
5338 uint32_t FI6:1;
5339 uint32_t FI5:1;
5340 uint32_t FI4:1;
5341 uint32_t FI3:1;
5342 uint32_t FI2:1;
5343 uint32_t FI1:1;
5344 uint32_t FI0:1;
5345 } B;
5346 } IFIR; /* External IRQ Filtered Input Register */
5347
5348 int32_t SIU_reserved2[2];
5349
5350 union SIU_PCR_tag {
5351 uint16_t R;
5352 struct {
5353 uint16_t:4;
5354 uint16_t PA:2;
5355 uint16_t OBE:1;
5356 uint16_t IBE:1;
5357 uint16_t DSC:2;
5358 uint16_t ODE:1;
5359 uint16_t HYS:1;
5360 uint16_t SRC:2;
5361 uint16_t WPE:1;
5362 uint16_t WPS:1;
5363 } B;
5364 } PCR[155]; /* Pad Configuration Registers */
5365
5366 int32_t SIU_reserved3[290];
5367
5368 union {
5369 uint8_t R;
5370 struct {
5371 uint8_t:7;
5372 uint8_t PDO:1;
5373 } B;
5374 } GPDO[155]; /* GPIO Pin Data Output Registers */
5375
5376 int8_t SIU_reserved4[357];
5377
5378 union {
5379 uint8_t R;
5380 struct {
5381 uint8_t:7;
5382 uint8_t PDI:1;
5383 } B;
5384 } GPDI[155]; /* GPIO Pin Data Input Registers */
5385
5386 int32_t SIU_reserved5[26];
5387
5388 union {
5389 uint32_t R;
5390 struct {
5391 uint32_t ESEL15:2;
5392 uint32_t ESEL14:2;
5393 uint32_t ESEL13:2;
5394 uint32_t ESEL12:2;
5395 uint32_t ESEL11:2;
5396 uint32_t ESEL10:2;
5397 uint32_t ESEL9:2;
5398 uint32_t ESEL8:2;
5399 uint32_t ESEL7:2;
5400 uint32_t ESEL6:2;
5401 uint32_t ESEL5:2;
5402 uint32_t ESEL4:2;
5403 uint32_t ESEL3:2;
5404 uint32_t ESEL2:2;
5405 uint32_t ESEL1:2;
5406 uint32_t ESEL0:2;
5407 } B;
5408 } ISEL1; /* IMUX Register */
5409
5410 union {
5411 uint32_t R;
5412 struct {
5413 uint32_t ESEL15:2;
5414 uint32_t ESEL14:2;
5415 uint32_t ESEL13:2;
5416 uint32_t ESEL12:2;
5417 uint32_t ESEL11:2;
5418 uint32_t ESEL10:2;
5419 uint32_t ESEL9:2;
5420 uint32_t ESEL8:2;
5421 uint32_t ESEL7:2;
5422 uint32_t ESEL6:2;
5423 uint32_t ESEL5:2;
5424 uint32_t ESEL4:2;
5425 uint32_t ESEL3:2;
5426 uint32_t ESEL2:2;
5427 uint32_t ESEL1:2;
5428 uint32_t ESEL0:2;
5429 } B;
5430 } ISEL2; /* IMUX Register */
5431
5432 int32_t SIU_reserved6;
5433
5434 union {
5435 uint32_t R;
5436 struct {
5437 uint32_t:17;
5438 uint32_t TSEL1:7;
5439 uint32_t:1;
5440 uint32_t TSEL0:7;
5441 } B;
5442 } ISEL4; /* IMUX Register */
5443
5444 int32_t SIU_reserved7[27];
5445
5446 union {
5447 uint32_t R;
5448 struct {
5449 uint32_t:14;
5450 uint32_t MATCH:1;
5451 uint32_t DISNEX:1;
5452 uint32_t:8;
5453 uint32_t TESTLOCK:1;
5454 uint32_t:7;
5455 } B;
5456 } CCR; /* Chip Configuration Register Register */
5457
5458 union {
5459 uint32_t R;
5460 struct {
5461 uint32_t:28;
5462 uint32_t ECEN:1;
5463 uint32_t:1;
5464 uint32_t ECDF:2;
5465 } B;
5466 } ECCR; /* External Clock Configuration Register Register */
5467
5468 union {
5469 uint32_t R;
5470 } GPR0; /* General Purpose Register 0 */
5471
5472 union {
5473 uint32_t R;
5474 } GPR1; /* General Purpose Register 1 */
5475
5476 union {
5477 uint32_t R;
5478 } GPR2; /* General Purpose Register 2 */
5479
5480 union {
5481 uint32_t R;
5482 } GPR3; /* General Purpose Register 3 */
5483
5484 int32_t SIU_reserved8[2];
5485
5486 union {
5487 uint32_t R;
5488 struct {
5489 uint32_t SYSCLKSEL:2;
5490 uint32_t SYSCLKDIV:3;
5491 uint32_t:19;
5492 uint32_t LPCLKDIV3:2;
5493 uint32_t LPCLKDIV2:2;
5494 uint32_t LPCLKDIV1:2;
5495 uint32_t LPCLKDIV0:2;
5496 } B;
5497 } SYSCLK; /* System CLock Register */
5498
5499 union {
5500 uint32_t R;
5501 struct {
5502 uint32_t:6;
5503 uint32_t HLT6:1;
5504 uint32_t HLT7:1;
5505 uint32_t:1;
5506 uint32_t HLT9:1;
5507 uint32_t HLT10:1;
5508 uint32_t HLT11:1;
5509 uint32_t HLT12:1;
5510 uint32_t HLT13:1;
5511 uint32_t HLT14:1;
5512 uint32_t HLT15:1;
5513 uint32_t HLT16:1;
5514 uint32_t HLT17:1;
5515 uint32_t HLT18:1;
5516 uint32_t HLT19:1;
5517 uint32_t HLT20:1;
5518 uint32_t HLT21:1;
5519 uint32_t HLT22:1;
5520 uint32_t HLT23:1;
5521 uint32_t:2;
5522 uint32_t HLT26:1;
5523 uint32_t HLT27:1;
5524 uint32_t HLT28:1;
5525 uint32_t HLT29:1;
5526 uint32_t:1;
5527 uint32_t HLT31:1;
5528 } B;
5529 } HLT0; /* Halt Register 0 */
5530
5531 union {
5532 uint32_t R;
5533 struct {
5534 uint32_t:3;
5535 uint32_t HLT3:1;
5536 uint32_t HLT4:1;
5537 uint32_t:15;
5538 uint32_t HLT20:1;
5539 uint32_t HLT21:1;
5540 uint32_t HLT22:1;
5541 uint32_t HLT23:1;
5542 uint32_t:2;
5543 uint32_t HLT26:1;
5544 uint32_t HLT27:1;
5545 uint32_t HLT28:1;
5546 uint32_t HLT29:1;
5547 uint32_t:2;
5548 } B;
5549 } HLT1; /* Halt Register 1 */
5550
5551 union {
5552 uint32_t R;
5553 struct {
5554 uint32_t:6;
5555 uint32_t HLTACK6:1;
5556 uint32_t HLTACK7:1;
5557 uint32_t:1;
5558 uint32_t HLTACK9:1;
5559 uint32_t HLTACK10:1;
5560 uint32_t HLTACK11:1;
5561 uint32_t HLTACK12:1;
5562 uint32_t HLTACK13:1;
5563 uint32_t HLTACK14:1;
5564 uint32_t HLTACK15:1;
5565 uint32_t HLTACK16:1;
5566 uint32_t HLTACK17:1;
5567 uint32_t HLTACK18:1;
5568 uint32_t HLTACK19:1;
5569 uint32_t HLTACK20:1;
5570 uint32_t HLTACK21:1;
5571 uint32_t HLTACK22:1;
5572 uint32_t HLTACK23:1;
5573 uint32_t:2;
5574 uint32_t HLTACK26:1;
5575 uint32_t HLTACK27:1;
5576 uint32_t HLTACK28:1;
5577 uint32_t HLTACK29:1;
5578 uint32_t:1;
5579 uint32_t HLTACK31:1;
5580 } B;
5581 } HLTACK0; /* Halt Acknowledge Register 0 */
5582
5583 union {
5584 uint32_t R;
5585 struct {
5586 uint32_t HLTACK0:1;
5587 uint32_t HLTACK1:1;
5588 uint32_t:1;
5589 uint32_t HLTACK3:1;
5590 uint32_t HLTACK4:1;
5591 uint32_t:11;
5592 uint32_t HLTACK20:1;
5593 uint32_t HLTACK21:1;
5594 uint32_t HLTACK22:1;
5595 uint32_t HLTACK23:1;
5596 uint32_t:2;
5597 uint32_t HLTACK26:1;
5598 uint32_t HLTACK27:1;
5599 uint32_t HLTACK28:1;
5600 uint32_t HLTACK29:1;
5601 uint32_t:2;
5602 } B;
5603 } HLTACK1; /* Halt Acknowledge Register 0 */
5604
5605 union {
5606 uint32_t R;
5607 struct {
5608 uint32_t EMIOSSEL31:4;
5609 uint32_t EMIOSSEL30:4;
5610 uint32_t EMIOSSEL29:4;
5611 uint32_t EMIOSSEL28:4;
5612 uint32_t EMIOSSEL27:4;
5613 uint32_t EMIOSSEL26:4;
5614 uint32_t EMIOSSEL25:4;
5615 uint32_t EMIOSSEL24:4;
5616 } B;
5617 } EMIOS_SEL0; /* eMIOS Select Register 0 */
5618
5619 union {
5620 uint32_t R;
5621 struct {
5622 uint32_t EMIOSSEL23:4;
5623 uint32_t EMIOSSEL22:4;
5624 uint32_t EMIOSSEL21:4;
5625 uint32_t EMIOSSEL20:4;
5626 uint32_t EMIOSSEL19:4;
5627 uint32_t EMIOSSEL18:4;
5628 uint32_t EMIOSSEL17:4;
5629 uint32_t EMIOSSEL16:4;
5630 } B;
5631 } EMIOS_SEL1; /* eMIOS Select Register 1 */
5632
5633 union {
5634 uint32_t R;
5635 struct {
5636 uint32_t EMIOSSEL15:4;
5637 uint32_t EMIOSSEL14:4;
5638 uint32_t EMIOSSEL13:4;
5639 uint32_t EMIOSSEL12:4;
5640 uint32_t EMIOSSEL11:4;
5641 uint32_t EMIOSSEL10:4;
5642 uint32_t EMIOSSEL9:4;
5643 uint32_t EMIOSSEL8:4;
5644 } B;
5645 } EMIOS_SEL2; /* eMIOS Select Register 2 */
5646
5647 union {
5648 uint32_t R;
5649 struct {
5650 uint32_t EMIOSSEL7:4;
5651 uint32_t EMIOSSEL6:4;
5652 uint32_t EMIOSSEL5:4;
5653 uint32_t EMIOSSEL4:4;
5654 uint32_t EMIOSSEL3:4;
5655 uint32_t EMIOSSEL2:4;
5656 uint32_t EMIOSSEL1:4;
5657 uint32_t EMIOSSEL0:4;
5658 } B;
5659 } EMIOS_SEL3; /* eMIOS Select Register 3 */
5660
5661 union {
5662 uint32_t R;
5663 struct {
5664 uint32_t ESEL15:2;
5665 uint32_t ESEL14:2;
5666 uint32_t ESEL13:2;
5667 uint32_t ESEL12:2;
5668 uint32_t ESEL11:2;
5669 uint32_t ESEL10:2;
5670 uint32_t ESEL9:2;
5671 uint32_t ESEL8:2;
5672 uint32_t ESEL7:2;
5673 uint32_t ESEL6:2;
5674 uint32_t ESEL5:2;
5675 uint32_t ESEL4:2;
5676 uint32_t ESEL3:2;
5677 uint32_t ESEL2:2;
5678 uint32_t ESEL1:2;
5679 uint32_t ESEL0:2;
5680 } B;
5681 } ISEL2A; /* External Interrupt Select Register 2A */
5682
5683 int32_t SIU_reserved9[142];
5684
5685 union {
5686 uint32_t R;
5687 struct {
5688 uint32_t:16;
5689 uint32_t PB:16;
5690 } B;
5691 } PGPDO0; /* Parallel GPIO Pin Data Output Register */
5692
5693 union {
5694 uint32_t R;
5695 struct {
5696 uint32_t PC:16;
5697 uint32_t PD:16;
5698 } B;
5699 } PGPDO1; /* Parallel GPIO Pin Data Output Register */
5700
5701 union {
5702 uint32_t R;
5703 struct {
5704 uint32_t PE:16;
5705 uint32_t PF:16;
5706 } B;
5707 } PGPDO2; /* Parallel GPIO Pin Data Output Register */
5708
5709 union {
5710 uint32_t R;
5711 struct {
5712 uint32_t PG:16;
5713 uint32_t PH:16;
5714 } B;
5715 } PGPDO3; /* Parallel GPIO Pin Data Output Register */
5716
5717 union {
5718 uint32_t R;
5719 struct {
5720 uint32_t PJ:16;
5721 uint32_t PK:11;
5722 uint32_t:5;
5723 } B;
5724 } PGPDO4; /* Parallel GPIO Pin Data Output Register */
5725
5726 int32_t SIU_reserved10[11];
5727
5728 union {
5729 uint32_t R;
5730 struct {
5731 uint32_t PA:16;
5732 uint32_t PB:16;
5733 } B;
5734 } PGPDI0; /* Parallel GPIO Pin Data Input Register */
5735
5736 union {
5737 uint32_t R;
5738 struct {
5739 uint32_t PC:16;
5740 uint32_t PD:16;
5741 } B;
5742 } PGPDI1; /* Parallel GPIO Pin Data Input Register */
5743
5744 union {
5745 uint32_t R;
5746 struct {
5747 uint32_t PE:16;
5748 uint32_t PF:16;
5749 } B;
5750 } PGPDI2; /* Parallel GPIO Pin Data Input Register */
5751
5752 union {
5753 uint32_t R;
5754 struct {
5755 uint32_t PG:16;
5756 uint32_t PH:16;
5757 } B;
5758 } PGPDI3; /* Parallel GPIO Pin Data Input Register */
5759
5760 union {
5761 uint32_t R;
5762 struct {
5763 uint32_t PJ:16;
5764 uint32_t PK:11;
5765 uint32_t:5;
5766 } B;
5767 } PGPDI4; /* Parallel GPIO Pin Data Input Register */
5768
5769 int32_t SIU_reserved11[12];
5770
5771 union {
5772 uint32_t R;
5773 struct {
5774 uint32_t PB_MASK:16;
5775 uint32_t PB:16;
5776 } B;
5777 } MPGPDO1; /* Masked Parallel GPIO Pin Data Input Register */
5778
5779 union {
5780 uint32_t R;
5781 struct {
5782 uint32_t PC_MASK:16;
5783 uint32_t PC:16;
5784 } B;
5785 } MPGPDO2; /* Masked Parallel GPIO Pin Data Input Register */
5786
5787 union {
5788 uint32_t R;
5789 struct {
5790 uint32_t PD_MASK:16;
5791 uint32_t PD:16;
5792 } B;
5793 } MPGPDO3; /* Masked Parallel GPIO Pin Data Input Register */
5794
5795 union {
5796 uint32_t R;
5797 struct {
5798 uint32_t PE_MASK:16;
5799 uint32_t PE:16;
5800 } B;
5801 } MPGPDO4; /* Masked Parallel GPIO Pin Data Input Register */
5802
5803 union {
5804 uint32_t R;
5805 struct {
5806 uint32_t PF_MASK:16;
5807 uint32_t PF:16;
5808 } B;
5809 } MPGPDO5; /* Masked Parallel GPIO Pin Data Input Register */
5810
5811 union {
5812 uint32_t R;
5813 struct {
5814 uint32_t PG_MASK:16;
5815 uint32_t PG:16;
5816 } B;
5817 } MPGPDO6; /* Masked Parallel GPIO Pin Data Input Register */
5818
5819 union {
5820 uint32_t R;
5821 struct {
5822 uint32_t PH_MASK:16;
5823 uint32_t PH:16;
5824 } B;
5825 } MPGPDO7; /* Masked Parallel GPIO Pin Data Input Register */
5826
5827 union {
5828 uint32_t R;
5829 struct {
5830 uint32_t PJ_MASK:16;
5831 uint32_t PJ:16;
5832 } B;
5833 } MPGPDO8; /* Masked Parallel GPIO Pin Data Input Register */
5834
5835 union {
5836 uint32_t R;
5837 struct {
5838 uint32_t PK_MASK:11;
5839 uint32_t:5;
5840 uint32_t PK:11;
5841 uint32_t:5;
5842 } B;
5843 } MPGPDO9; /* Masked Parallel GPIO Pin Data Input Register */
5844
5845 int32_t SIU_reserved12[22];
5846
5847 union {
5848 uint32_t R;
5849 struct {
5850 uint32_t MASK31:1;
5851 uint32_t MASK30:1;
5852 uint32_t MASK29:1;
5853 uint32_t MASK28:1;
5854 uint32_t MASK27:1;
5855 uint32_t MASK26:1;
5856 uint32_t MASK25:1;
5857 uint32_t MASK24:1;
5858 uint32_t MASK23:1;
5859 uint32_t MASK22:1;
5860 uint32_t MASK21:1;
5861 uint32_t MASK20:1;
5862 uint32_t MASK19:1;
5863 uint32_t MASK18:1;
5864 uint32_t MASK17:1;
5865 uint32_t MASK16:1;
5866 uint32_t DATA31:1;
5867 uint32_t DATA30:1;
5868 uint32_t DATA29:1;
5869 uint32_t DATA28:1;
5870 uint32_t DATA27:1;
5871 uint32_t DATA26:1;
5872 uint32_t DATA25:1;
5873 uint32_t DATA24:1;
5874 uint32_t DATA23:1;
5875 uint32_t DATA22:1;
5876 uint32_t DATA21:1;
5877 uint32_t DATA20:1;
5878 uint32_t DATA19:1;
5879 uint32_t DATA18:1;
5880 uint32_t DATA17:1;
5881 uint32_t DATA16:1;
5882 } B;
5883 } DSPIAH; /* Masked Serial GPO for DSPI_A High Register */
5884
5885 union {
5886 uint32_t R;
5887 struct {
5888 uint32_t MASK15:1;
5889 uint32_t MASK14:1;
5890 uint32_t MASK13:1;
5891 uint32_t MASK12:1;
5892 uint32_t MASK11:1;
5893 uint32_t MASK10:1;
5894 uint32_t MASK9:1;
5895 uint32_t MASK8:1;
5896 uint32_t MASK7:1;
5897 uint32_t MASK6:1;
5898 uint32_t MASK5:1;
5899 uint32_t MASK4:1;
5900 uint32_t MASK3:1;
5901 uint32_t MASK2:1;
5902 uint32_t MASK1:1;
5903 uint32_t MASK0:1;
5904 uint32_t DATA15:1;
5905 uint32_t DATA14:1;
5906 uint32_t DATA13:1;
5907 uint32_t DATA12:1;
5908 uint32_t DATA11:1;
5909 uint32_t DATA10:1;
5910 uint32_t DATA9:1;
5911 uint32_t DATA8:1;
5912 uint32_t DATA7:1;
5913 uint32_t DATA6:1;
5914 uint32_t DATA5:1;
5915 uint32_t DATA4:1;
5916 uint32_t DATA3:1;
5917 uint32_t DATA2:1;
5918 uint32_t DATA1:1;
5919 uint32_t DATA0:1;
5920 } B;
5921 } DSPIAL; /* Masked Serial GPO for DSPI_A Low Register */
5922
5923 union {
5924 uint32_t R;
5925 struct {
5926 uint32_t MASK31:1;
5927 uint32_t MASK30:1;
5928 uint32_t MASK29:1;
5929 uint32_t MASK28:1;
5930 uint32_t MASK27:1;
5931 uint32_t MASK26:1;
5932 uint32_t MASK25:1;
5933 uint32_t MASK24:1;
5934 uint32_t MASK23:1;
5935 uint32_t MASK22:1;
5936 uint32_t MASK21:1;
5937 uint32_t MASK20:1;
5938 uint32_t MASK19:1;
5939 uint32_t MASK18:1;
5940 uint32_t MASK17:1;
5941 uint32_t MASK16:1;
5942 uint32_t DATA31:1;
5943 uint32_t DATA30:1;
5944 uint32_t DATA29:1;
5945 uint32_t DATA28:1;
5946 uint32_t DATA27:1;
5947 uint32_t DATA26:1;
5948 uint32_t DATA25:1;
5949 uint32_t DATA24:1;
5950 uint32_t DATA23:1;
5951 uint32_t DATA22:1;
5952 uint32_t DATA21:1;
5953 uint32_t DATA20:1;
5954 uint32_t DATA19:1;
5955 uint32_t DATA18:1;
5956 uint32_t DATA17:1;
5957 uint32_t DATA16:1;
5958 } B;
5959 } DSPIBH; /* Masked Serial GPO for DSPI_B High Register */
5960
5961 union {
5962 uint32_t R;
5963 struct {
5964 uint32_t MASK15:1;
5965 uint32_t MASK14:1;
5966 uint32_t MASK13:1;
5967 uint32_t MASK12:1;
5968 uint32_t MASK11:1;
5969 uint32_t MASK10:1;
5970 uint32_t MASK9:1;
5971 uint32_t MASK8:1;
5972 uint32_t MASK7:1;
5973 uint32_t MASK6:1;
5974 uint32_t MASK5:1;
5975 uint32_t MASK4:1;
5976 uint32_t MASK3:1;
5977 uint32_t MASK2:1;
5978 uint32_t MASK1:1;
5979 uint32_t MASK0:1;
5980 uint32_t DATA15:1;
5981 uint32_t DATA14:1;
5982 uint32_t DATA13:1;
5983 uint32_t DATA12:1;
5984 uint32_t DATA11:1;
5985 uint32_t DATA10:1;
5986 uint32_t DATA9:1;
5987 uint32_t DATA8:1;
5988 uint32_t DATA7:1;
5989 uint32_t DATA6:1;
5990 uint32_t DATA5:1;
5991 uint32_t DATA4:1;
5992 uint32_t DATA3:1;
5993 uint32_t DATA2:1;
5994 uint32_t DATA1:1;
5995 uint32_t DATA0:1;
5996 } B;
5997 } DSPIBL; /* Masked Serial GPO for DSPI_B Low Register */
5998
5999 union {
6000 uint32_t R;
6001 struct {
6002 uint32_t MASK31:1;
6003 uint32_t MASK30:1;
6004 uint32_t MASK29:1;
6005 uint32_t MASK28:1;
6006 uint32_t MASK27:1;
6007 uint32_t MASK26:1;
6008 uint32_t MASK25:1;
6009 uint32_t MASK24:1;
6010 uint32_t MASK23:1;
6011 uint32_t MASK22:1;
6012 uint32_t MASK21:1;
6013 uint32_t MASK20:1;
6014 uint32_t MASK19:1;
6015 uint32_t MASK18:1;
6016 uint32_t MASK17:1;
6017 uint32_t MASK16:1;
6018 uint32_t DATA31:1;
6019 uint32_t DATA30:1;
6020 uint32_t DATA29:1;
6021 uint32_t DATA28:1;
6022 uint32_t DATA27:1;
6023 uint32_t DATA26:1;
6024 uint32_t DATA25:1;
6025 uint32_t DATA24:1;
6026 uint32_t DATA23:1;
6027 uint32_t DATA22:1;
6028 uint32_t DATA21:1;
6029 uint32_t DATA20:1;
6030 uint32_t DATA19:1;
6031 uint32_t DATA18:1;
6032 uint32_t DATA17:1;
6033 uint32_t DATA16:1;
6034 } B;
6035 } DSPICH; /* Masked Serial GPO for DSPI_C High Register */
6036
6037 union {
6038 uint32_t R;
6039 struct {
6040 uint32_t MASK15:1;
6041 uint32_t MASK14:1;
6042 uint32_t MASK13:1;
6043 uint32_t MASK12:1;
6044 uint32_t MASK11:1;
6045 uint32_t MASK10:1;
6046 uint32_t MASK9:1;
6047 uint32_t MASK8:1;
6048 uint32_t MASK7:1;
6049 uint32_t MASK6:1;
6050 uint32_t MASK5:1;
6051 uint32_t MASK4:1;
6052 uint32_t MASK3:1;
6053 uint32_t MASK2:1;
6054 uint32_t MASK1:1;
6055 uint32_t MASK0:1;
6056 uint32_t DATA15:1;
6057 uint32_t DATA14:1;
6058 uint32_t DATA13:1;
6059 uint32_t DATA12:1;
6060 uint32_t DATA11:1;
6061 uint32_t DATA10:1;
6062 uint32_t DATA9:1;
6063 uint32_t DATA8:1;
6064 uint32_t DATA7:1;
6065 uint32_t DATA6:1;
6066 uint32_t DATA5:1;
6067 uint32_t DATA4:1;
6068 uint32_t DATA3:1;
6069 uint32_t DATA2:1;
6070 uint32_t DATA1:1;
6071 uint32_t DATA0:1;
6072 } B;
6073 } DSPICL; /* Masked Serial GPO for DSPI_C Low Register */
6074
6075 union {
6076 uint32_t R;
6077 struct {
6078 uint32_t MASK31:1;
6079 uint32_t MASK30:1;
6080 uint32_t MASK29:1;
6081 uint32_t MASK28:1;
6082 uint32_t MASK27:1;
6083 uint32_t MASK26:1;
6084 uint32_t MASK25:1;
6085 uint32_t MASK24:1;
6086 uint32_t MASK23:1;
6087 uint32_t MASK22:1;
6088 uint32_t MASK21:1;
6089 uint32_t MASK20:1;
6090 uint32_t MASK19:1;
6091 uint32_t MASK18:1;
6092 uint32_t MASK17:1;
6093 uint32_t MASK16:1;
6094 uint32_t DATA31:1;
6095 uint32_t DATA30:1;
6096 uint32_t DATA29:1;
6097 uint32_t DATA28:1;
6098 uint32_t DATA27:1;
6099 uint32_t DATA26:1;
6100 uint32_t DATA25:1;
6101 uint32_t DATA24:1;
6102 uint32_t DATA23:1;
6103 uint32_t DATA22:1;
6104 uint32_t DATA21:1;
6105 uint32_t DATA20:1;
6106 uint32_t DATA19:1;
6107 uint32_t DATA18:1;
6108 uint32_t DATA17:1;
6109 uint32_t DATA16:1;
6110 } B;
6111 } DSPIDH; /* Masked Serial GPO for DSPI_D High Register */
6112
6113 union {
6114 uint32_t R;
6115 struct {
6116 uint32_t MASK15:1;
6117 uint32_t MASK14:1;
6118 uint32_t MASK13:1;
6119 uint32_t MASK12:1;
6120 uint32_t MASK11:1;
6121 uint32_t MASK10:1;
6122 uint32_t MASK9:1;
6123 uint32_t MASK8:1;
6124 uint32_t MASK7:1;
6125 uint32_t MASK6:1;
6126 uint32_t MASK5:1;
6127 uint32_t MASK4:1;
6128 uint32_t MASK3:1;
6129 uint32_t MASK2:1;
6130 uint32_t MASK1:1;
6131 uint32_t MASK0:1;
6132 uint32_t DATA15:1;
6133 uint32_t DATA14:1;
6134 uint32_t DATA13:1;
6135 uint32_t DATA12:1;
6136 uint32_t DATA11:1;
6137 uint32_t DATA10:1;
6138 uint32_t DATA9:1;
6139 uint32_t DATA8:1;
6140 uint32_t DATA7:1;
6141 uint32_t DATA6:1;
6142 uint32_t DATA5:1;
6143 uint32_t DATA4:1;
6144 uint32_t DATA3:1;
6145 uint32_t DATA2:1;
6146 uint32_t DATA1:1;
6147 uint32_t DATA0:1;
6148 } B;
6149 } DSPIDL; /* Masked Serial GPO for DSPI_D Low Register */
6150
6151 int32_t SIU_reserved13[9];
6152
6153 union {
6154 uint32_t R;
6155 struct {
6156 uint32_t EMIOS31:1;
6157 uint32_t EMIOS30:1;
6158 uint32_t EMIOS29:1;
6159 uint32_t EMIOS28:1;
6160 uint32_t EMIOS27:1;
6161 uint32_t EMIOS26:1;
6162 uint32_t EMIOS25:1;
6163 uint32_t EMIOS24:1;
6164 uint32_t EMIOS23:1;
6165 uint32_t EMIOS22:1;
6166 uint32_t EMIOS21:1;
6167 uint32_t EMIOS20:1;
6168 uint32_t EMIOS19:1;
6169 uint32_t EMIOS18:1;
6170 uint32_t EMIOS17:1;
6171 uint32_t EMIOS16:1;
6172 uint32_t EMIOS15:1;
6173 uint32_t EMIOS14:1;
6174 uint32_t EMIOS13:1;
6175 uint32_t EMIOS12:1;
6176 uint32_t EMIOS11:1;
6177 uint32_t EMIOS10:1;
6178 uint32_t EMIOS9:1;
6179 uint32_t EMIOS8:1;
6180 uint32_t EMIOS7:1;
6181 uint32_t EMIOS6:1;
6182 uint32_t EMIOS5:1;
6183 uint32_t EMIOS4:1;
6184 uint32_t EMIOS3:1;
6185 uint32_t EMIOS2:1;
6186 uint32_t EMIOS1:1;
6187 uint32_t EMIOS0:1;
6188 } B;
6189 } EMIOSA; /* EMIOS A Select Register */
6190
6191 union {
6192 uint32_t R;
6193 struct {
6194 uint32_t DSPIAH31:1;
6195 uint32_t DSPIAH30:1;
6196 uint32_t DSPIAH29:1;
6197 uint32_t DSPIAH28:1;
6198 uint32_t DSPIAH27:1;
6199 uint32_t DSPIAH26:1;
6200 uint32_t DSPIAH25:1;
6201 uint32_t DSPIAH24:1;
6202 uint32_t DSPIAH23:1;
6203 uint32_t DSPIAH22:1;
6204 uint32_t DSPIAH21:1;
6205 uint32_t DSPIAH20:1;
6206 uint32_t DSPIAH19:1;
6207 uint32_t DSPIAH18:1;
6208 uint32_t DSPIAH17:1;
6209 uint32_t DSPIAH16:1;
6210 uint32_t DSPIAL15:1;
6211 uint32_t DSPIAL14:1;
6212 uint32_t DSPIAL13:1;
6213 uint32_t DSPIAL12:1;
6214 uint32_t DSPIAL11:1;
6215 uint32_t DSPIAL10:1;
6216 uint32_t DSPIAL9:1;
6217 uint32_t DSPIAL8:1;
6218 uint32_t DSPIAL7:1;
6219 uint32_t DSPIAL6:1;
6220 uint32_t DSPIAL5:1;
6221 uint32_t DSPIAL4:1;
6222 uint32_t DSPIAL3:1;
6223 uint32_t DSPIAL2:1;
6224 uint32_t DSPIAL1:1;
6225 uint32_t DSPIAL0:1;
6226 } B;
6227 } DSPIAHLA; /* DSPIAH/L Select Register for DSPI A */
6228
6229 int32_t SIU_reserved14[2];
6230
6231 union {
6232 uint32_t R;
6233 struct {
6234 uint32_t EMIOS31:1;
6235 uint32_t EMIOS30:1;
6236 uint32_t EMIOS29:1;
6237 uint32_t EMIOS28:1;
6238 uint32_t EMIOS27:1;
6239 uint32_t EMIOS26:1;
6240 uint32_t EMIOS25:1;
6241 uint32_t EMIOS24:1;
6242 uint32_t EMIOS23:1;
6243 uint32_t EMIOS22:1;
6244 uint32_t EMIOS21:1;
6245 uint32_t EMIOS20:1;
6246 uint32_t EMIOS19:1;
6247 uint32_t EMIOS18:1;
6248 uint32_t EMIOS17:1;
6249 uint32_t EMIOS16:1;
6250 uint32_t EMIOS15:1;
6251 uint32_t EMIOS14:1;
6252 uint32_t EMIOS13:1;
6253 uint32_t EMIOS12:1;
6254 uint32_t EMIOS11:1;
6255 uint32_t EMIOS10:1;
6256 uint32_t EMIOS9:1;
6257 uint32_t EMIOS8:1;
6258 uint32_t EMIOS7:1;
6259 uint32_t EMIOS6:1;
6260 uint32_t EMIOS5:1;
6261 uint32_t EMIOS4:1;
6262 uint32_t EMIOS3:1;
6263 uint32_t EMIOS2:1;
6264 uint32_t EMIOS1:1;
6265 uint32_t EMIOS0:1;
6266 } B;
6267 } EMIOSB; /* EMIOS B Select Register */
6268
6269 union {
6270 uint32_t R;
6271 struct {
6272 uint32_t DSPIBH31:1;
6273 uint32_t DSPIBH30:1;
6274 uint32_t DSPIBH29:1;
6275 uint32_t DSPIBH28:1;
6276 uint32_t DSPIBH27:1;
6277 uint32_t DSPIBH26:1;
6278 uint32_t DSPIBH25:1;
6279 uint32_t DSPIBH24:1;
6280 uint32_t DSPIBH23:1;
6281 uint32_t DSPIBH22:1;
6282 uint32_t DSPIBH21:1;
6283 uint32_t DSPIBH20:1;
6284 uint32_t DSPIBH19:1;
6285 uint32_t DSPIBH18:1;
6286 uint32_t DSPIBH17:1;
6287 uint32_t DSPIBH16:1;
6288 uint32_t DSPIBL15:1;
6289 uint32_t DSPIBL14:1;
6290 uint32_t DSPIBL13:1;
6291 uint32_t DSPIBL12:1;
6292 uint32_t DSPIBL11:1;
6293 uint32_t DSPIBL10:1;
6294 uint32_t DSPIBL9:1;
6295 uint32_t DSPIBL8:1;
6296 uint32_t DSPIBL7:1;
6297 uint32_t DSPIBL6:1;
6298 uint32_t DSPIBL5:1;
6299 uint32_t DSPIBL4:1;
6300 uint32_t DSPIBL3:1;
6301 uint32_t DSPIBL2:1;
6302 uint32_t DSPIBL1:1;
6303 uint32_t DSPIBL0:1;
6304 } B;
6305 } DSPIBHLB; /* DSPIBH/L Select Register for DSPI B */
6306
6307 int32_t SIU_reserved115[2];
6308
6309 union {
6310 uint32_t R;
6311 struct {
6312 uint32_t EMIOS31:1;
6313 uint32_t EMIOS30:1;
6314 uint32_t EMIOS29:1;
6315 uint32_t EMIOS28:1;
6316 uint32_t EMIOS27:1;
6317 uint32_t EMIOS26:1;
6318 uint32_t EMIOS25:1;
6319 uint32_t EMIOS24:1;
6320 uint32_t EMIOS23:1;
6321 uint32_t EMIOS22:1;
6322 uint32_t EMIOS21:1;
6323 uint32_t EMIOS20:1;
6324 uint32_t EMIOS19:1;
6325 uint32_t EMIOS18:1;
6326 uint32_t EMIOS17:1;
6327 uint32_t EMIOS16:1;
6328 uint32_t EMIOS15:1;
6329 uint32_t EMIOS14:1;
6330 uint32_t EMIOS13:1;
6331 uint32_t EMIOS12:1;
6332 uint32_t EMIOS11:1;
6333 uint32_t EMIOS10:1;
6334 uint32_t EMIOS9:1;
6335 uint32_t EMIOS8:1;
6336 uint32_t EMIOS7:1;
6337 uint32_t EMIOS6:1;
6338 uint32_t EMIOS5:1;
6339 uint32_t EMIOS4:1;
6340 uint32_t EMIOS3:1;
6341 uint32_t EMIOS2:1;
6342 uint32_t EMIOS1:1;
6343 uint32_t EMIOS0:1;
6344 } B;
6345 } EMIOSC; /* EMIOS C Select Register */
6346
6347 union {
6348 uint32_t R;
6349 struct {
6350 uint32_t DSPICH31:1;
6351 uint32_t DSPICH30:1;
6352 uint32_t DSPICH29:1;
6353 uint32_t DSPICH28:1;
6354 uint32_t DSPICH27:1;
6355 uint32_t DSPICH26:1;
6356 uint32_t DSPICH25:1;
6357 uint32_t DSPICH24:1;
6358 uint32_t DSPICH23:1;
6359 uint32_t DSPICH22:1;
6360 uint32_t DSPICH21:1;
6361 uint32_t DSPICH20:1;
6362 uint32_t DSPICH19:1;
6363 uint32_t DSPICH18:1;
6364 uint32_t DSPICH17:1;
6365 uint32_t DSPICH16:1;
6366 uint32_t DSPICL15:1;
6367 uint32_t DSPICL14:1;
6368 uint32_t DSPICL13:1;
6369 uint32_t DSPICL12:1;
6370 uint32_t DSPICL11:1;
6371 uint32_t DSPICL10:1;
6372 uint32_t DSPICL9:1;
6373 uint32_t DSPICL8:1;
6374 uint32_t DSPICL7:1;
6375 uint32_t DSPICL6:1;
6376 uint32_t DSPICL5:1;
6377 uint32_t DSPICL4:1;
6378 uint32_t DSPICL3:1;
6379 uint32_t DSPICL2:1;
6380 uint32_t DSPICL1:1;
6381 uint32_t DSPICL0:1;
6382 } B;
6383 } DSPICHLC; /* DSPIAH/L Select Register for DSPI C */
6384
6385 int32_t SIU_reserved16[2];
6386
6387 union {
6388 uint32_t R;
6389 struct {
6390 uint32_t EMIOS31:1;
6391 uint32_t EMIOS30:1;
6392 uint32_t EMIOS29:1;
6393 uint32_t EMIOS28:1;
6394 uint32_t EMIOS27:1;
6395 uint32_t EMIOS26:1;
6396 uint32_t EMIOS25:1;
6397 uint32_t EMIOS24:1;
6398 uint32_t EMIOS23:1;
6399 uint32_t EMIOS22:1;
6400 uint32_t EMIOS21:1;
6401 uint32_t EMIOS20:1;
6402 uint32_t EMIOS19:1;
6403 uint32_t EMIOS18:1;
6404 uint32_t EMIOS17:1;
6405 uint32_t EMIOS16:1;
6406 uint32_t EMIOS15:1;
6407 uint32_t EMIOS14:1;
6408 uint32_t EMIOS13:1;
6409 uint32_t EMIOS12:1;
6410 uint32_t EMIOS11:1;
6411 uint32_t EMIOS10:1;
6412 uint32_t EMIOS9:1;
6413 uint32_t EMIOS8:1;
6414 uint32_t EMIOS7:1;
6415 uint32_t EMIOS6:1;
6416 uint32_t EMIOS5:1;
6417 uint32_t EMIOS4:1;
6418 uint32_t EMIOS3:1;
6419 uint32_t EMIOS2:1;
6420 uint32_t EMIOS1:1;
6421 uint32_t EMIOS0:1;
6422 } B;
6423 } EMIOSD; /* EMIOS D Select Register */
6424
6425 union {
6426 uint32_t R;
6427 struct {
6428 uint32_t DSPIDH31:1;
6429 uint32_t DSPIDH30:1;
6430 uint32_t DSPIDH29:1;
6431 uint32_t DSPIDH28:1;
6432 uint32_t DSPIDH27:1;
6433 uint32_t DSPIDH26:1;
6434 uint32_t DSPIDH25:1;
6435 uint32_t DSPIDH24:1;
6436 uint32_t DSPIDH23:1;
6437 uint32_t DSPIDH22:1;
6438 uint32_t DSPIDH21:1;
6439 uint32_t DSPIDH20:1;
6440 uint32_t DSPIDH19:1;
6441 uint32_t DSPIDH18:1;
6442 uint32_t DSPIDH17:1;
6443 uint32_t DSPIDH16:1;
6444 uint32_t DSPIDL15:1;
6445 uint32_t DSPIDL14:1;
6446 uint32_t DSPIDL13:1;
6447 uint32_t DSPIDL12:1;
6448 uint32_t DSPIDL11:1;
6449 uint32_t DSPIDL10:1;
6450 uint32_t DSPIDL9:1;
6451 uint32_t DSPIDL8:1;
6452 uint32_t DSPIDL7:1;
6453 uint32_t DSPIDL6:1;
6454 uint32_t DSPIDL5:1;
6455 uint32_t DSPIDL4:1;
6456 uint32_t DSPIDL3:1;
6457 uint32_t DSPIDL2:1;
6458 uint32_t DSPIDL1:1;
6459 uint32_t DSPIDL0:1;
6460 } B;
6461 } DSPIDHLD; /* DSPIAH/L Select Register for DSPI D */
6462
6463 }; /* end of SIU_tag */
6464/**************************************************************************/
6465/* MODULE : STM */
6466/**************************************************************************/
6467 struct STM_tag {
6468
6469 union {
6470 uint32_t R;
6471 struct {
6472 uint32_t:16;
6473 uint32_t CPS:8;
6474 uint32_t:6;
6475 uint32_t FRZ:1;
6476 uint32_t TEN:1;
6477 } B;
6478 } CR; /* STM Control Register */
6479
6480 union {
6481 uint32_t R;
6482 } CNT; /* STM Count Register */
6483
6484 int32_t STM_reserved[2];
6485
6486 union {
6487 uint32_t R;
6488 struct {
6489 uint32_t:31;
6490 uint32_t CEN:1;
6491 } B;
6492 } CCR0; /* STM Channel Control Register 0 */
6493
6494 union {
6495 uint32_t R;
6496 struct {
6497 uint32_t:31;
6498 uint32_t CIF:1;
6499 } B;
6500 } CIR0; /* STM Channel Interrupt Register 0 */
6501
6502 union {
6503 uint32_t R;
6504 } CMP0; /* STM Channel Compare Register 0 */
6505
6506 int32_t STM_reserved1;
6507
6508 union {
6509 uint32_t R;
6510 struct {
6511 uint32_t:31;
6512 uint32_t CEN:1;
6513 } B;
6514 } CCR1; /* STM Channel Control Register 1 */
6515
6516 union {
6517 uint32_t R;
6518 struct {
6519 uint32_t:31;
6520 uint32_t CIF:1;
6521 } B;
6522 } CIR1; /* STM Channel Interrupt Register 1 */
6523
6524 union {
6525 uint32_t R;
6526 } CMP1; /* STM Channel Compare Register 1 */
6527
6528 int32_t STM_reserved2;
6529
6530 union {
6531 uint32_t R;
6532 struct {
6533 uint32_t:31;
6534 uint32_t CEN:1;
6535 } B;
6536 } CCR2; /* STM Channel Control Register 2 */
6537
6538 union {
6539 uint32_t R;
6540 struct {
6541 uint32_t:31;
6542 uint32_t CIF:1;
6543 } B;
6544 } CIR2; /* STM Channel Interrupt Register 2 */
6545
6546 union {
6547 uint32_t R;
6548 } CMP2; /* STM Channel Compare Register 2 */
6549
6550 int32_t STM_reserved3;
6551
6552 union {
6553 uint32_t R;
6554 struct {
6555 uint32_t:31;
6556 uint32_t CEN:1;
6557 } B;
6558 } CCR3; /* STM Channel Control Register 3 */
6559
6560 union {
6561 uint32_t R;
6562 struct {
6563 uint32_t:31;
6564 uint32_t CIF:1;
6565 } B;
6566 } CIR3; /* STM Channel Interrupt Register 3 */
6567
6568 union {
6569 uint32_t R;
6570 } CMP3; /* STM Channel Compare Register 3 */
6571
6572 }; /* end of STM_tag */
6573/**************************************************************************/
6574/* MODULE : SWT */
6575/**************************************************************************/
6576 struct SWT_tag {
6577 union {
6578 uint32_t R;
6579 struct {
6580 uint32_t MAP0:1;
6581 uint32_t MAP1:1;
6582 uint32_t MAP2:1;
6583 uint32_t MAP3:1;
6584 uint32_t MAP4:1;
6585 uint32_t MAP5:1;
6586 uint32_t MAP6:1;
6587 uint32_t MAP7:1;
6588 uint32_t:14;
6589 uint32_t KEY:1;
6590 uint32_t RIA:1;
6591 uint32_t WND:1;
6592 uint32_t ITR:1;
6593 uint32_t HLK:1;
6594 uint32_t SLK:1;
6595 uint32_t:2;
6596 uint32_t FRZ:1;
6597 uint32_t WEN:1;
6598 } B;
6599 } CR; /* SWT Control Register */
6600
6601 union {
6602 uint32_t R;
6603 struct {
6604 uint32_t:31;
6605 uint32_t TIF:1;
6606 } B;
6607 } IR; /* SWT Interrupt Register */
6608
6609 union {
6610 uint32_t R;
6611 struct {
6612 uint32_t WTO:32;
6613 } B;
6614 } TO; /* SWT Time-Out Register */
6615
6616 union {
6617 uint32_t R;
6618 struct {
6619 uint32_t WST:32;
6620 } B;
6621 } WN; /* SWT Window Register */
6622
6623 union {
6624 uint32_t R;
6625 struct {
6626 uint32_t:16;
6627 uint32_t WSC:16;
6628 } B;
6629 } SR; /* SWT Service Register */
6630
6631 union {
6632 uint32_t R;
6633 struct {
6634 uint32_t CNT:32;
6635 } B;
6636 } CO; /* SWT Counter Output Register */
6637
6638 union {
6639 uint32_t R;
6640 struct {
6641 uint32_t:16;
6642 uint32_t SK:16;
6643 } B;
6644 } SK; /* SWT Service Key Register */
6645
6646 }; /* end of SWT_tag */
6647
6648/* Define memories */
6649
6650#define SRAM0_START 0x40000000UL
6651#define SRAM0_SIZE 0x80000UL
6652#define SRAM0_END 0x4007FFFFUL
6653
6654#define SRAM1_START 0x40080000UL
6655#define SRAM1_SIZE 0x14000UL
6656#define SRAM1_END 0x40093FFFUL
6657
6658#define FLASH_START 0x0UL
6659#define FLASH_SIZE 0x200000UL
6660#define FLASH_END 0x1FFFFFUL
6661
6662/* Define instances of modules AIPS_A */
6663#define MLB (*(volatile struct MLB_tag *) 0xC3F84000UL)
6664#define I2C_C (*(volatile struct I2C_tag *) 0xC3F88000UL)
6665#define I2C_D (*(volatile struct I2C_tag *) 0xC3F8C000UL)
6666#define DSPI_C (*(volatile struct DSPI_tag *) 0xC3F90000UL)
6667#define DSPI_D (*(volatile struct DSPI_tag *) 0xC3F94000UL)
6668#define ESCI_J (*(volatile struct ESCI_tag *) 0xC3FA0000UL)
6669#define ESCI_K (*(volatile struct ESCI_tag *) 0xC3FA4000UL)
6670#define ESCI_L (*(volatile struct ESCI_tag *) 0xC3FA8000UL)
6671#define ESCI_M (*(volatile struct ESCI_tag *) 0xC3FAC000UL)
6672#define FR (*(volatile struct FR_tag *) 0xC3FDC000UL)
6673
6674/* Define instances of modules AIPS_B */
6675#define XBAR (*(volatile struct XBAR_tag *) 0xFFF04000UL)
6676#define SEMA4 (*(volatile struct SEMA4_tag *) 0xFFF10000UL)
6677#define MPU (*(volatile struct MPU_tag *) 0xFFF14000UL)
6678#define SWT (*(volatile struct SWT_tag *) 0xFFF38000UL)
6679#define STM (*(volatile struct STM_tag *) 0xFFF3C000UL)
6680#define ECSM (*(volatile struct ECSM_tag *) 0xFFF40000UL)
6681#define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000UL)
6682#define INTC (*(volatile struct INTC_tag *) 0xFFF48000UL)
6683#define FEC (*(volatile struct FEC_tag *) 0xFFF4C000UL)
6684#define ADC (*(volatile struct ADC_tag *) 0xFFF80000UL)
6685#define I2C_A (*(volatile struct I2C_tag *) 0xFFF88000UL)
6686#define I2C_B (*(volatile struct I2C_tag *) 0xFFF8C000UL)
6687#define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000UL)
6688#define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000UL)
6689#define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFA0000UL)
6690#define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFA4000UL)
6691#define ESCI_C (*(volatile struct ESCI_tag *) 0xFFFA8000UL)
6692#define ESCI_D (*(volatile struct ESCI_tag *) 0xFFFAC000UL)
6693#define ESCI_E (*(volatile struct ESCI_tag *) 0xFFFB0000UL)
6694#define ESCI_F (*(volatile struct ESCI_tag *) 0xFFFB4000UL)
6695#define ESCI_G (*(volatile struct ESCI_tag *) 0xFFFB8000UL)
6696#define ESCI_H (*(volatile struct ESCI_tag *) 0xFFFBC000UL)
6697#define CAN_A (*(volatile struct FLEXCAN_tag *) 0xFFFC0000UL)
6698#define CAN_B (*(volatile struct FLEXCAN_tag *) 0xFFFC4000UL)
6699#define CAN_C (*(volatile struct FLEXCAN_tag *) 0xFFFC8000UL)
6700#define CAN_D (*(volatile struct FLEXCAN_tag *) 0xFFFCC000UL)
6701#define CAN_E (*(volatile struct FLEXCAN_tag *) 0xFFFD0000UL)
6702#define CAN_F (*(volatile struct FLEXCAN_tag *) 0xFFFD4000UL)
6703#define CTU (*(volatile struct CTU_tag *) 0xFFFD8000UL)
6704#define DMAMUX (*(volatile struct DMAMUX_tag *) 0xFFFDC000UL)
6705#define PIT (*(volatile struct PIT_tag *) 0xFFFE0000UL)
6706#define PIT_RTI (*(volatile struct PIT_tag *) 0xFFFE0000UL)
6707#define EMIOS (*(volatile struct EMIOS_tag *) 0xFFFE4000UL)
6708#define SIU (*(volatile struct SIU_tag *) 0xFFFE8000UL)
6709#define CRP (*(volatile struct CRP_tag *) 0xFFFEC000UL)
6710#define FMPLL (*(volatile struct FMPLL_tag *) 0xFFFF0000UL)
6711#define FLASH (*(volatile struct FLASH_tag *) 0xFFFF8000UL)
6712
6713#ifdef __MWERKS__
6714#pragma pop
6715#endif
6716
6717#ifdef __cplusplus
6718}
6719#endif
6720#endif /* ASM */
6721#endif /* ifdef _MPC5668_H */
Definition: fsl-mpc5668.h:73
Definition: fsl-mpc551x.h:73
Definition: fsl-mpc5668.h:1542
Definition: fsl-mpc551x.h:230
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc555x.h:2179
Definition: fsl-mpc551x.h:531
Definition: fsl-mpc551x.h:899
Definition: fsl-mpc556x.h:2982
Definition: fsl-mpc551x.h:1027
Definition: fsl-mpc551x.h:1171
Definition: fsl-mpc551x.h:1484
Definition: fsl-mpc551x.h:3622
Definition: fsl-mpc551x.h:1539
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc5668.h:4673
Definition: fsl-mpc551x.h:3791
Definition: fsl-mpc551x.h:1843
Definition: fsl-mpc564xL.h:5597
Definition: fsl-mpc5668.h:4938
Definition: fsl-mpc551x.h:1991
Definition: fsl-mpc551x.h:2087
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc5668.h:6467
Definition: fsl-mpc5668.h:6576
Definition: fsl-mpc555x.h:1982
Definition: fsl-mpc551x.h:3783
Definition: fsl-mpc551x.h:3481
Definition: fsl-mpc564xL.h:16586
Definition: fsl-mpc564xL.h:16541
Definition: fsl-mpc564xL.h:16698
Definition: fsl-mpc564xL.h:16678
Definition: fsl-mpc564xL.h:16627
Definition: fsl-mpc564xL.h:16605
Definition: fsl-mpc564xL.h:5544
Definition: fsl-mpc564xL.h:5576
Definition: fsl-mpc564xL.h:5588
Definition: fsl-mpc5668.h:4953
Definition: fsl-mpc5668.h:4962
Definition: fsl-mpc5668.h:4927
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:2939
Definition: fsl-mpc551x.h:3037
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc551x.h:3724
Definition: fsl-mpc551x.h:2842
Definition: fsl-mpc551x.h:3615
Definition: fsl-mpc551x.h:3618
Definition: fsl-mpc551x.h:2807
Definition: fsl-mpc551x.h:2960
Definition: fsl-mpc551x.h:2817
Definition: fsl-mpc551x.h:2781
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3171
Definition: fsl-mpc551x.h:2773
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3534
Definition: fsl-mpc551x.h:3228
Definition: fsl-mpc551x.h:3313
Definition: fsl-mpc551x.h:3322
Definition: fsl-mpc551x.h:3331
Definition: fsl-mpc551x.h:3339
Definition: fsl-mpc551x.h:3347
Definition: fsl-mpc551x.h:3355
Definition: fsl-mpc551x.h:3362
Definition: fsl-mpc551x.h:3370
Definition: fsl-mpc551x.h:3377
Definition: fsl-mpc551x.h:3385
Definition: fsl-mpc551x.h:3236
Definition: fsl-mpc551x.h:3393
Definition: fsl-mpc551x.h:3401
Definition: fsl-mpc551x.h:3409
Definition: fsl-mpc551x.h:3418
Definition: fsl-mpc551x.h:3425
Definition: fsl-mpc551x.h:3434
Definition: fsl-mpc551x.h:3441
Definition: fsl-mpc551x.h:3450
Definition: fsl-mpc551x.h:3457
Definition: fsl-mpc551x.h:3465
Definition: fsl-mpc551x.h:3244
Definition: fsl-mpc551x.h:3473
Definition: fsl-mpc551x.h:3252
Definition: fsl-mpc551x.h:3261
Definition: fsl-mpc551x.h:3269
Definition: fsl-mpc551x.h:3278
Definition: fsl-mpc551x.h:3287
Definition: fsl-mpc551x.h:3295
Definition: fsl-mpc551x.h:3304
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2901
Definition: fsl-mpc551x.h:2922
Definition: fsl-mpc551x.h:2863
Definition: fsl-mpc551x.h:2884
Definition: fsl-mpc551x.h:2828
Definition: fsl-mpc551x.h:2971
Definition: fsl-mpc551x.h:2987
Definition: fsl-mpc551x.h:3000
Definition: fsl-mpc551x.h:3018
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:3193
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc551x.h:3202
Definition: fsl-mpc551x.h:3213
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:3182
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3059
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3085
Definition: fsl-mpc551x.h:3069
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3134
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3150
Definition: fsl-mpc551x.h:3123
Definition: fsl-mpc551x.h:2796
Definition: fsl-mpc551x.h:3051
Definition: fsl-mpc551x.h:3528
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:3742
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc551x.h:3112
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:3093
