RTEMS 5.2-rc1
fsl-mpc556x.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
5 *
6 * embedded brains GmbH
7 * Obere Lagerstr. 30
8 * 82178 Puchheim
9 * Germany
10 * <info@embedded-brains.de>
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
22 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
23 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
24 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
25 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
26 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
27 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
28 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
30 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
31 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/**************************************************************************/
35/* FILE NAME: mpc5567.h COPYRIGHT (c) Freescale 2007 */
36/* VERSION: 1.5 All Rights Reserved */
37/* */
38/* DESCRIPTION: */
39/* This file contain all of the register and bit field definitions for */
40/* MPC5567. */
41/*========================================================================*/
42/* UPDATE HISTORY */
43/* REV AUTHOR DATE DESCRIPTION OF CHANGE */
44/* --- ----------- --------- --------------------- */
45/* 1.0 G. Emerson 03/Jan/06 Initial version. */
46/* 1.1 G. Emerson 27/Mar/06 Fix issue with Flexcan BCC field. */
47/* 1.2 S. Mathieson 28/Jul/06 Change Flexcan BCC bit to MBFEN */
48/* Add Flexcan bits WRNEN, SRXDIS, */
49/* TWRNMSK, RWRNMSK,TWRNINT,RWRNINT */
50/* 1.3 S. Mathieson 30/Aug/06 SPR: L1SCR0, updated bit name from DPP */
51/* to DPB to align with documentation. */
52/* 1.4 S. Mathieson 26/Feb/07 eDMA TCD format updated to include */
53/* alternate configuration. */
54/* INTC, correction to the number of PSR */
55/* registers. */
56/* Updates to bitfield sizes in MBSSUTR, */
57/* MBIVEC, MBIDX & RSBIR. RSBIR, SELEC */
58/* changed to SEL & RFRFCFR, FNUM changed */
59/* to SEL to align with documentation. */
60/* Various register/ bitfield updates to */
61/* correct errors (MCR, TMODE bit removed.*/
62/* PADR register removed. PIER1, DRDIE bit*/
63/* removed & PIFR1, DRDIF removed. PCR1, */
64/* Filter bypass bit removed). */
65/* 1.5 S. Mathieson 25/Apr/07 SRAM size changed from 64K to 80K. */
66/* */
67/**************************************************************************/
68/*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
69
70#ifndef _MPC5567_H_
71#define _MPC5567_H_
72
73#ifndef ASM
74
75#include <stdint.h>
76
77#include <mpc55xx/regs-edma.h>
78
79#ifdef __cplusplus
80extern "C" {
81#endif
82
83#ifdef __MWERKS__
84#pragma push
85#pragma ANSI_strict off
86#endif
87
88/****************************************************************************/
89/* MODULE : PBRIDGE_A Peripheral Bridge */
90/****************************************************************************/
91 struct PBRIDGE_A_tag {
92 union {
93 uint32_t R;
94 struct {
95 uint32_t MBW0:1;
96 uint32_t MTR0:1;
97 uint32_t MTW0:1;
98 uint32_t MPL0:1;
99 uint32_t MBW1:1;
100 uint32_t MTR1:1;
101 uint32_t MTW1:1;
102 uint32_t MPL1:1;
103 uint32_t MBW2:1;
104 uint32_t MTR2:1;
105 uint32_t MTW2:1;
106 uint32_t MPL2:1;
107 uint32_t MBW3:1;
108 uint32_t MTR3:1;
109 uint32_t MTW3:1;
110 uint32_t MPL3:1;
111
112 uint32_t MBW4:1; /* FEC */
113 uint32_t MTR4:1;
114 uint32_t MTW4:1;
115 uint32_t MPL4:1;
116
117 uint32_t:4;
118
119 uint32_t MBW6:1; /* FLEXRAY */
120 uint32_t MTR6:1;
121 uint32_t MTW6:1;
122 uint32_t MPL6:1;
123
124 uint32_t:4;
125 } B;
126 } MPCR; /* Master Privilege Control Register */
127
128 uint32_t pbridge_a_reserved2[7];
129
130 union {
131 uint32_t R;
132 struct {
133 uint32_t BW0:1;
134 uint32_t SP0:1;
135 uint32_t WP0:1;
136 uint32_t TP0:1;
137 uint32_t:28;
138 } B;
139 } PACR0;
140
141 uint32_t pbridge_a_reserved3[7];
142
143 union {
144 uint32_t R;
145 struct {
146 uint32_t BW0:1;
147 uint32_t SP0:1;
148 uint32_t WP0:1;
149 uint32_t TP0:1;
150 uint32_t BW1:1;
151 uint32_t SP1:1;
152 uint32_t WP1:1;
153 uint32_t TP1:1;
154 uint32_t BW2:1;
155 uint32_t SP2:1;
156 uint32_t WP2:1;
157 uint32_t TP2:1;
158 uint32_t:4;
159 uint32_t BW4:1;
160 uint32_t SP4:1;
161 uint32_t WP4:1;
162 uint32_t TP4:1;
163 uint32_t:12;
164 } B;
165 } OPACR0;
166
167 union {
168 uint32_t R;
169 struct {
170
171 uint32_t BW0:1; /* EMIOS */
172 uint32_t SP0:1;
173 uint32_t WP0:1;
174 uint32_t TP0:1;
175
176 uint32_t:28;
177 } B;
178 } OPACR1;
179
180 union {
181 uint32_t R;
182 struct {
183 uint32_t BW0:1;
184 uint32_t SP0:1;
185 uint32_t WP0:1;
186 uint32_t TP0:1;
187 uint32_t:4;
188 uint32_t BW2:1;
189 uint32_t SP2:1;
190 uint32_t WP2:1;
191 uint32_t TP2:1;
192 uint32_t BW3:1;
193 uint32_t SP3:1;
194 uint32_t WP3:1;
195 uint32_t TP3:1;
196 uint32_t BW4:1;
197 uint32_t SP4:1;
198 uint32_t WP4:1;
199 uint32_t TP4:1;
200 uint32_t:12;
201 } B;
202 } OPACR2;
203
204 };
205
206/****************************************************************************/
207/* MODULE : PBRIDGE_B Peripheral Bridge */
208/****************************************************************************/
209 struct PBRIDGE_B_tag {
210 union {
211 uint32_t R;
212 struct {
213 uint32_t MBW0:1;
214 uint32_t MTR0:1;
215 uint32_t MTW0:1;
216 uint32_t MPL0:1;
217 uint32_t MBW1:1;
218 uint32_t MTR1:1;
219 uint32_t MTW1:1;
220 uint32_t MPL1:1;
221 uint32_t MBW2:1;
222 uint32_t MTR2:1;
223 uint32_t MTW2:1;
224 uint32_t MPL2:1;
225 uint32_t MBW3:1;
226 uint32_t MTR3:1;
227 uint32_t MTW3:1;
228 uint32_t MPL3:1;
229
230 uint32_t MBW4:1; /* FEC */
231 uint32_t MTR4:1;
232 uint32_t MTW4:1;
233 uint32_t MPL4:1;
234
235 uint32_t:4;
236
237 uint32_t MBW6:1; /* FLEXRAY */
238 uint32_t MTR6:1;
239 uint32_t MTW6:1;
240 uint32_t MPL6:1;
241
242 uint32_t:4;
243 } B;
244 } MPCR; /* Master Privilege Control Register */
245
246 uint32_t pbridge_b_reserved2[7];
247
248 union {
249 uint32_t R;
250 struct {
251 uint32_t BW0:1;
252 uint32_t SP0:1;
253 uint32_t WP0:1;
254 uint32_t TP0:1;
255 uint32_t BW1:1;
256 uint32_t SP1:1;
257 uint32_t WP1:1;
258 uint32_t TP1:1;
259 uint32_t:24;
260 } B;
261 } PACR0;
262
263 uint32_t pbridge_b_reserved3;
264
265 union {
266 uint32_t R;
267 struct {
268 uint32_t BW0:1;
269 uint32_t SP0:1;
270 uint32_t WP0:1;
271 uint32_t TP0:1;
272 uint32_t BW1:1;
273 uint32_t SP1:1;
274 uint32_t WP1:1;
275 uint32_t TP1:1;
276 uint32_t BW2:1;
277 uint32_t SP2:1;
278 uint32_t WP2:1;
279 uint32_t TP2:1;
280
281 uint32_t BW3:1; /* FEC */
282 uint32_t SP3:1;
283 uint32_t WP3:1;
284 uint32_t TP3:1;
285
286 uint32_t:16;
287
288 } B;
289 } PACR2;
290
291 uint32_t pbridge_b_reserved4[5];
292
293 union {
294 uint32_t R;
295 struct {
296 uint32_t BW0:1;
297 uint32_t SP0:1;
298 uint32_t WP0:1;
299 uint32_t TP0:1;
300 uint32_t:12;
301
302 uint32_t:4;
303
304 uint32_t BW5:1; /* DSPI_B */
305 uint32_t SP5:1;
306 uint32_t WP5:1;
307 uint32_t TP5:1;
308
309 uint32_t BW6:1;
310 uint32_t SP6:1;
311 uint32_t WP6:1;
312 uint32_t TP6:1;
313 uint32_t BW7:1;
314 uint32_t SP7:1;
315 uint32_t WP7:1;
316 uint32_t TP7:1;
317 } B;
318 } OPACR0;
319
320 union {
321 uint32_t R;
322 struct {
323 uint32_t:16;
324 uint32_t BW4:1;
325 uint32_t SP4:1;
326 uint32_t WP4:1;
327 uint32_t TP4:1;
328
329 uint32_t BW5:1; /* ESCI_B */
330 uint32_t SP5:1;
331 uint32_t WP5:1;
332 uint32_t TP5:1;
333
334 uint32_t:8;
335 } B;
336 } OPACR1;
337
338 union {
339 uint32_t R;
340 struct {
341 uint32_t BW0:1;
342 uint32_t SP0:1;
343 uint32_t WP0:1;
344 uint32_t TP0:1;
345
346 uint32_t BW1:1; /* CAN_B */
347 uint32_t SP1:1;
348 uint32_t WP1:1;
349 uint32_t TP1:1;
350
351 uint32_t BW2:1;
352 uint32_t SP2:1;
353 uint32_t WP2:1;
354 uint32_t TP2:1;
355
356 uint32_t BW3:1; /* CAN_D */
357 uint32_t SP3:1;
358 uint32_t WP3:1;
359 uint32_t TP3:1;
360
361 uint32_t BW4:1; /* CAN_E */
362 uint32_t SP4:1;
363 uint32_t WP4:1;
364 uint32_t TP4:1;
365
366 uint32_t:12;
367 } B;
368 } OPACR2;
369
370 union {
371 uint32_t R;
372 struct {
373
374 uint32_t BW0:1; /* FLEXRAY */
375 uint32_t SP0:1;
376 uint32_t WP0:1;
377 uint32_t TP0:1;
378
379 uint32_t:24;
380 uint32_t BW7:1;
381 uint32_t SP7:1;
382 uint32_t WP7:1;
383 uint32_t TP7:1;
384 } B;
385 } OPACR3;
386
387 };
388/****************************************************************************/
389/* MODULE : FMPLL */
390/****************************************************************************/
391 struct FMPLL_tag {
392 union FMPLL_SYNCR_tag {
393 uint32_t R;
394 struct {
395 uint32_t:1;
396 uint32_t PREDIV:3;
397 uint32_t MFD:5;
398 uint32_t:1;
399 uint32_t RFD:3;
400 uint32_t LOCEN:1;
401 uint32_t LOLRE:1;
402 uint32_t LOCRE:1;
403 uint32_t DISCLK:1;
404 uint32_t LOLIRQ:1;
405 uint32_t LOCIRQ:1;
406 uint32_t RATE:1;
407 uint32_t DEPTH:2;
408 uint32_t EXP:10;
409 } B;
410 } SYNCR;
411
412 union FMPLL_SYNSR_tag {
413 uint32_t R;
414 struct {
415 uint32_t:22;
416 uint32_t LOLF:1;
417 uint32_t LOC:1;
418 uint32_t MODE:1;
419 uint32_t PLLSEL:1;
420 uint32_t PLLREF:1;
421 uint32_t LOCKS:1;
422 uint32_t LOCK:1;
423 uint32_t LOCF:1;
424 uint32_t CALDONE:1;
425 uint32_t CALPASS:1;
426 } B;
427 } SYNSR;
428
429 };
430/****************************************************************************/
431/* MODULE : External Bus Interface (EBI) */
432/****************************************************************************/
433 struct EBI_CS_tag {
434 union { /* Base Register Bank */
435 uint32_t R;
436 struct {
437 uint32_t BA:17;
438 uint32_t:3;
439 uint32_t PS:1;
440 uint32_t:4;
441 uint32_t BL:1;
442 uint32_t WEBS:1;
443 uint32_t TBDIP:1;
444 uint32_t:2;
445 uint32_t BI:1;
446 uint32_t V:1;
447 } B;
448 } BR;
449
450 union { /* Option Register Bank */
451 uint32_t R;
452 struct {
453 uint32_t AM:17;
454 uint32_t:7;
455 uint32_t SCY:4;
456 uint32_t:1;
457 uint32_t BSCY:2;
458 uint32_t:1;
459 } B;
460 } OR;
461 };
462
463 struct EBI_CAL_CS_tag {
464 union { /* Calibration Base Register Bank */
465 uint32_t R;
466 struct {
467 uint32_t BA:17;
468 uint32_t:3;
469 uint32_t PS:1;
470 uint32_t:4;
471 uint32_t BL:1;
472 uint32_t WEBS:1;
473 uint32_t TBDIP:1;
474 uint32_t:2;
475 uint32_t BI:1;
476 uint32_t V:1;
477 } B;
478 } BR;
479
480 union { /* Calibration Option Register Bank */
481 uint32_t R;
482 struct {
483 uint32_t AM:17;
484 uint32_t:7;
485 uint32_t SCY:4;
486 uint32_t:1;
487 uint32_t BSCY:2;
488 uint32_t:1;
489 } B;
490 } OR;
491 };
492
493 struct EBI_tag {
494 union EBI_MCR_tag { /* Module Configuration Register */
495 uint32_t R;
496 struct {
497 uint32_t:5;
498 uint32_t SIZEEN:1;
499 uint32_t SIZE:2;
500 uint32_t:8;
501 uint32_t ACGE:1;
502 uint32_t EXTM:1;
503 uint32_t EARB:1;
504 uint32_t EARP:2;
505 uint32_t:4;
506 uint32_t MDIS:1;
507 uint32_t:5;
508 uint32_t DBM:1;
509 } B;
510 } MCR;
511
512 uint32_t EBI_reserved1;
513
514 union { /* Transfer Error Status Register */
515 uint32_t R;
516 struct {
517 uint32_t:30;
518 uint32_t TEAF:1;
519 uint32_t BMTF:1;
520 } B;
521 } TESR;
522
523 union { /* Bus Monitor Control Register */
524 uint32_t R;
525 struct {
526 uint32_t:16;
527 uint32_t BMT:8;
528 uint32_t BME:1;
529 uint32_t:7;
530 } B;
531 } BMCR;
532
533 struct EBI_CS_tag CS[4];
534
535/* Calibration registers */
536 uint32_t EBI_reserved2[4];
537 struct EBI_CAL_CS_tag CAL_CS[4];
538
539 };
540/****************************************************************************/
541/* MODULE : FLASH */
542/****************************************************************************/
543 struct FLASH_tag {
544 union { /* Module Configuration Register */
545 uint32_t R;
546 struct {
547 uint32_t:4;
548 uint32_t SIZE:4;
549 uint32_t:1;
550 uint32_t LAS:3;
551 uint32_t:3;
552 uint32_t MAS:1;
553 uint32_t EER:1;
554 uint32_t RWE:1;
555 uint32_t BBEPE:1;
556 uint32_t EPE:1;
557 uint32_t PEAS:1;
558 uint32_t DONE:1;
559 uint32_t PEG:1;
560
561 uint32_t:2;
562
563 uint32_t STOP:1;
564 uint32_t:1;
565 uint32_t PGM:1;
566 uint32_t PSUS:1;
567 uint32_t ERS:1;
568 uint32_t ESUS:1;
569 uint32_t EHV:1;
570 } B;
571 } MCR;
572
573 union LMLR_tag { /* LML Register */
574 uint32_t R;
575 struct {
576 uint32_t LME:1;
577 uint32_t:10;
578 uint32_t SLOCK:1;
579 uint32_t MLOCK:4;
580 uint32_t LLOCK:16;
581 } B;
582 } LMLR;
583
584 union HLR_tag { /* HL Register */
585 uint32_t R;
586 struct {
587 uint32_t HBE:1;
588 uint32_t:3;
589 uint32_t HBLOCK:28;
590 } B;
591 } HLR;
592
593 union SLMLR_tag { /* SLML Register */
594 uint32_t R;
595 struct {
596 uint32_t SLE:1;
597 uint32_t:10;
598 uint32_t SSLOCK:1;
599 uint32_t SMLOCK:4;
600 uint32_t SLLOCK:16;
601 } B;
602 } SLMLR;
603
604 union { /* LMS Register */
605 uint32_t R;
606 struct {
607 uint32_t:12;
608 uint32_t MSEL:4;
609 uint32_t LSEL:16;
610 } B;
611 } LMSR;
612
613 union {
614 uint32_t R;
615 struct {
616 uint32_t:4;
617 uint32_t HBSEL:28;
618 } B;
619 } HSR;
620
621 union {
622 uint32_t R;
623 struct {
624 uint32_t:10;
625 uint32_t ADDR:19;
626 uint32_t:3;
627 } B;
628 } AR;
629
630 union {
631 uint32_t R;
632 struct {
633
634 uint32_t:9;
635 uint32_t M6PFE:1; /* Flexray */
636 uint32_t:1;
637
638 uint32_t M4PFE:1; /* FEC */
639
640 uint32_t M3PFE:1;
641 uint32_t M2PFE:1;
642 uint32_t M1PFE:1;
643 uint32_t M0PFE:1;
644 uint32_t APC:3;
645 uint32_t WWSC:2;
646 uint32_t RWSC:3;
647
648 uint32_t DPFEN:2;
649 uint32_t IPFEN:2;
650
651 uint32_t PFLIM:3;
652 uint32_t BFEN:1;
653 } B;
654 } BIUCR;
655
656 union {
657 uint32_t R;
658 struct {
659
660 uint32_t:18;
661 uint32_t M6AP:2; /* Flexray */
662 uint32_t:2;
663
664 uint32_t M4AP:2; /* FEC */
665
666 uint32_t M3AP:2;
667 uint32_t M2AP:2;
668 uint32_t M1AP:2;
669 uint32_t M0AP:2;
670 } B;
671 } BIUAPR;
672 };
673/****************************************************************************/
674/* MODULE : SIU */
675/****************************************************************************/
676 struct SIU_tag {
677 int32_t SIU_reserved0;
678
679 union { /* MCU ID Register */
680 uint32_t R;
681 struct {
682 uint32_t PARTNUM:16;
683 uint32_t MASKNUM:16;
684 } B;
685 } MIDR;
686 int32_t SIU_reserved00;
687
688 union { /* Reset Status Register */
689 uint32_t R;
690 struct {
691 uint32_t PORS:1;
692 uint32_t ERS:1;
693 uint32_t LLRS:1;
694 uint32_t LCRS:1;
695 uint32_t WDRS:1;
696 uint32_t CRS:1;
697 uint32_t:8;
698 uint32_t SSRS:1;
699 uint32_t SERF:1;
700 uint32_t WKPCFG:1;
701 uint32_t:12;
702 uint32_t BOOTCFG:2;
703 uint32_t RGF:1;
704 } B;
705 } RSR;
706
707 union { /* System Reset Control Register */
708 uint32_t R;
709 struct {
710 uint32_t SSR:1;
711 uint32_t SER:1;
712 uint32_t:14;
713 uint32_t CRE:1;
714 uint32_t:15;
715 } B;
716 } SRCR;
717
718 union SIU_EISR_tag { /* External Interrupt Status Register */
719 uint32_t R;
720 struct {
721 uint32_t:16;
722 uint32_t EIF15:1;
723 uint32_t EIF14:1;
724 uint32_t EIF13:1;
725 uint32_t EIF12:1;
726 uint32_t EIF11:1;
727 uint32_t EIF10:1;
728 uint32_t EIF9:1;
729 uint32_t EIF8:1;
730 uint32_t EIF7:1;
731 uint32_t EIF6:1;
732 uint32_t EIF5:1;
733 uint32_t EIF4:1;
734 uint32_t EIF3:1;
735 uint32_t EIF2:1;
736 uint32_t EIF1:1;
737 uint32_t EIF0:1;
738 } B;
739 } EISR;
740
741 union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
742 uint32_t R;
743 struct {
744 uint32_t:16;
745 uint32_t EIRE15:1;
746 uint32_t EIRE14:1;
747 uint32_t EIRE13:1;
748 uint32_t EIRE12:1;
749 uint32_t EIRE11:1;
750 uint32_t EIRE10:1;
751 uint32_t EIRE9:1;
752 uint32_t EIRE8:1;
753 uint32_t EIRE7:1;
754 uint32_t EIRE6:1;
755 uint32_t EIRE5:1;
756 uint32_t EIRE4:1;
757 uint32_t EIRE3:1;
758 uint32_t EIRE2:1;
759 uint32_t EIRE1:1;
760 uint32_t EIRE0:1;
761 } B;
762 } DIRER;
763
764 union SIU_DIRSR_tag { /* DMA/Interrupt Select Register */
765 uint32_t R;
766 struct {
767 uint32_t:28;
768 uint32_t DIRS3:1;
769 uint32_t DIRS2:1;
770 uint32_t DIRS1:1;
771 uint32_t DIRS0:1;
772 } B;
773 } DIRSR;
774
775 union { /* Overrun Status Register */
776 uint32_t R;
777 struct {
778 uint32_t:16;
779 uint32_t OVF15:1;
780 uint32_t OVF14:1;
781 uint32_t OVF13:1;
782 uint32_t OVF12:1;
783 uint32_t OVF11:1;
784 uint32_t OVF10:1;
785 uint32_t OVF9:1;
786 uint32_t OVF8:1;
787 uint32_t OVF7:1;
788 uint32_t OVF6:1;
789 uint32_t OVF5:1;
790 uint32_t OVF4:1;
791 uint32_t OVF3:1;
792 uint32_t OVF2:1;
793 uint32_t OVF1:1;
794 uint32_t OVF0:1;
795 } B;
796 } OSR;
797
798 union SIU_ORER_tag { /* Overrun Request Enable Register */
799 uint32_t R;
800 struct {
801 uint32_t:16;
802 uint32_t ORE15:1;
803 uint32_t ORE14:1;
804 uint32_t ORE13:1;
805 uint32_t ORE12:1;
806 uint32_t ORE11:1;
807 uint32_t ORE10:1;
808 uint32_t ORE9:1;
809 uint32_t ORE8:1;
810 uint32_t ORE7:1;
811 uint32_t ORE6:1;
812 uint32_t ORE5:1;
813 uint32_t ORE4:1;
814 uint32_t ORE3:1;
815 uint32_t ORE2:1;
816 uint32_t ORE1:1;
817 uint32_t ORE0:1;
818 } B;
819 } ORER;
820
821 union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
822 uint32_t R;
823 struct {
824 uint32_t:16;
825 uint32_t IREE15:1;
826 uint32_t IREE14:1;
827 uint32_t IREE13:1;
828 uint32_t IREE12:1;
829 uint32_t IREE11:1;
830 uint32_t IREE10:1;
831 uint32_t IREE9:1;
832 uint32_t IREE8:1;
833 uint32_t IREE7:1;
834 uint32_t IREE6:1;
835 uint32_t IREE5:1;
836 uint32_t IREE4:1;
837 uint32_t IREE3:1;
838 uint32_t IREE2:1;
839 uint32_t IREE1:1;
840 uint32_t IREE0:1;
841 } B;
842 } IREER;
843
844 union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
845 uint32_t R;
846 struct {
847 uint32_t:16;
848 uint32_t IFEE15:1;
849 uint32_t IFEE14:1;
850 uint32_t IFEE13:1;
851 uint32_t IFEE12:1;
852 uint32_t IFEE11:1;
853 uint32_t IFEE10:1;
854 uint32_t IFEE9:1;
855 uint32_t IFEE8:1;
856 uint32_t IFEE7:1;
857 uint32_t IFEE6:1;
858 uint32_t IFEE5:1;
859 uint32_t IFEE4:1;
860 uint32_t IFEE3:1;
861 uint32_t IFEE2:1;
862 uint32_t IFEE1:1;
863 uint32_t IFEE0:1;
864 } B;
865 } IFEER;
866
867 union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
868 uint32_t R;
869 struct {
870 uint32_t:28;
871 uint32_t DFL:4;
872 } B;
873 } IDFR;
874
875 int32_t SIU_reserved1[3];
876
877 union SIU_PCR_tag { /* Pad Configuration Registers */
878 uint16_t R;
879 struct {
880 uint16_t:3;
881 uint16_t PA:3;
882 uint16_t OBE:1;
883 uint16_t IBE:1;
884 uint16_t DSC:2;
885 uint16_t ODE:1;
886 uint16_t HYS:1;
887 uint16_t SRC:2;
888 uint16_t WPE:1;
889 uint16_t WPS:1;
890 } B;
891 } PCR[512];
892
893 int16_t SIU_reserved_0[224];
894
895 union { /* GPIO Pin Data Output Registers */
896 uint8_t R;
897 struct {
898 uint8_t:7;
899 uint8_t PDO:1;
900 } B;
901 } GPDO[256];
902
903 int32_t SIU_reserved_3[64];
904
905 union { /* GPIO Pin Data Input Registers */
906 uint8_t R;
907 struct {
908 uint8_t:7;
909 uint8_t PDI:1;
910 } B;
911 } GPDI[256];
912
913 union { /* IMUX Register */
914 uint32_t R;
915 struct {
916 uint32_t TSEL5:2;
917 uint32_t TSEL4:2;
918 uint32_t TSEL3:2;
919 uint32_t TSEL2:2;
920 uint32_t TSEL1:2;
921 uint32_t TSEL0:2;
922 uint32_t:20;
923 } B;
924 } ETISR;
925
926 union { /* IMUX Register */
927 uint32_t R;
928 struct {
929 uint32_t ESEL15:2;
930 uint32_t ESEL14:2;
931 uint32_t ESEL13:2;
932 uint32_t ESEL12:2;
933 uint32_t ESEL11:2;
934 uint32_t ESEL10:2;
935 uint32_t ESEL9:2;
936 uint32_t ESEL8:2;
937 uint32_t ESEL7:2;
938 uint32_t ESEL6:2;
939 uint32_t ESEL5:2;
940 uint32_t ESEL4:2;
941 uint32_t ESEL3:2;
942 uint32_t ESEL2:2;
943 uint32_t ESEL1:2;
944 uint32_t ESEL0:2;
945 } B;
946 } EIISR;
947
948 union { /* IMUX Register */
949 uint32_t R;
950 struct {
951 uint32_t SINSELA:2;
952 uint32_t SSSELA:2;
953 uint32_t SCKSELA:2;
954 uint32_t TRIGSELA:2;
955 uint32_t SINSELB:2;
956 uint32_t SSSELB:2;
957 uint32_t SCKSELB:2;
958 uint32_t TRIGSELB:2;
959 uint32_t SINSELC:2;
960 uint32_t SSSELC:2;
961 uint32_t SCKSELC:2;
962 uint32_t TRIGSELC:2;
963 uint32_t SINSELD:2;
964 uint32_t SSSELD:2;
965 uint32_t SCKSELD:2;
966 uint32_t TRIGSELD:2;
967 } B;
968 } DISR;
969
970 int32_t SIU_reserved2[29];
971
972 union { /* Chip Configuration Register Register */
973 uint32_t R;
974 struct {
975 uint32_t:14;
976 uint32_t MATCH:1;
977 uint32_t DISNEX:1;
978 uint32_t:16;
979 } B;
980 } CCR;
981
982 union { /* External Clock Configuration Register Register */
983 uint32_t R;
984 struct {
985 uint32_t:18;
986 uint32_t ENGDIV:6;
987 uint32_t:4;
988 uint32_t EBTS:1;
989 uint32_t:1;
990 uint32_t EBDF:2;
991 } B;
992 } ECCR;
993
994 union {
995 uint32_t R;
996 } CARH;
997
998 union {
999 uint32_t R;
1000 } CARL;
1001
1002 union {
1003 uint32_t R;
1004 } CBRH;
1005
1006 union {
1007 uint32_t R;
1008 } CBRL;
1009
1010 };
1011/****************************************************************************/
1012/* MODULE : EMIOS */
1013/****************************************************************************/
1014 struct EMIOS_tag {
1015 union EMIOS_MCR_tag {
1016 uint32_t R;
1017 struct {
1018 uint32_t:1;
1019 uint32_t MDIS:1;
1020 uint32_t FRZ:1;
1021 uint32_t GTBE:1;
1022 uint32_t ETB:1;
1023 uint32_t GPREN:1;
1024 uint32_t:6;
1025 uint32_t SRV:4;
1026 uint32_t GPRE:8;
1027 uint32_t:8;
1028 } B;
1029 } MCR; /* Module Configuration Register */
1030
1031 union {
1032 uint32_t R;
1033 struct {
1034 uint32_t:8;
1035 uint32_t F23:1;
1036 uint32_t F22:1;
1037 uint32_t F21:1;
1038 uint32_t F20:1;
1039 uint32_t F19:1;
1040 uint32_t F18:1;
1041 uint32_t F17:1;
1042 uint32_t F16:1;
1043 uint32_t F15:1;
1044 uint32_t F14:1;
1045 uint32_t F13:1;
1046 uint32_t F12:1;
1047 uint32_t F11:1;
1048 uint32_t F10:1;
1049 uint32_t F9:1;
1050 uint32_t F8:1;
1051 uint32_t F7:1;
1052 uint32_t F6:1;
1053 uint32_t F5:1;
1054 uint32_t F4:1;
1055 uint32_t F3:1;
1056 uint32_t F2:1;
1057 uint32_t F1:1;
1058 uint32_t F0:1;
1059 } B;
1060 } GFR; /* Global FLAG Register */
1061
1062 union {
1063 uint32_t R;
1064 struct {
1065 uint32_t:8;
1066 uint32_t OU23:1;
1067 uint32_t OU22:1;
1068 uint32_t OU21:1;
1069 uint32_t OU20:1;
1070 uint32_t OU19:1;
1071 uint32_t OU18:1;
1072 uint32_t OU17:1;
1073 uint32_t OU16:1;
1074 uint32_t OU15:1;
1075 uint32_t OU14:1;
1076 uint32_t OU13:1;
1077 uint32_t OU12:1;
1078 uint32_t OU11:1;
1079 uint32_t OU10:1;
1080 uint32_t OU9:1;
1081 uint32_t OU8:1;
1082 uint32_t OU7:1;
1083 uint32_t OU6:1;
1084 uint32_t OU5:1;
1085 uint32_t OU4:1;
1086 uint32_t OU3:1;
1087 uint32_t OU2:1;
1088 uint32_t OU1:1;
1089 uint32_t OU0:1;
1090 } B;
1091 } OUDR; /* Output Update Disable Register */
1092
1093 uint32_t emios_reserved[5];
1094
1095 struct EMIOS_CH_tag {
1096 union {
1097 uint32_t R; /* Channel A Data Register */
1098 } CADR;
1099
1100 union {
1101 uint32_t R; /* Channel B Data Register */
1102 } CBDR;
1103
1104 union {
1105 uint32_t R; /* Channel Counter Register */
1106 } CCNTR;
1107
1108 union EMIOS_CCR_tag {
1109 uint32_t R;
1110 struct {
1111 uint32_t FREN:1;
1112 uint32_t ODIS:1;
1113 uint32_t ODISSL:2;
1114 uint32_t UCPRE:2;
1115 uint32_t UCPREN:1;
1116 uint32_t DMA:1;
1117 uint32_t:1;
1118 uint32_t IF:4;
1119 uint32_t FCK:1;
1120 uint32_t FEN:1;
1121 uint32_t:3;
1122 uint32_t FORCMA:1;
1123 uint32_t FORCMB:1;
1124 uint32_t:1;
1125 uint32_t BSL:2;
1126 uint32_t EDSEL:1;
1127 uint32_t EDPOL:1;
1128 uint32_t MODE:7;
1129 } B;
1130 } CCR; /* Channel Control Register */
1131
1132 union EMIOS_CSR_tag {
1133 uint32_t R;
1134 struct {
1135 uint32_t OVR:1;
1136 uint32_t:15;
1137 uint32_t OVFL:1;
1138 uint32_t:12;
1139 uint32_t UCIN:1;
1140 uint32_t UCOUT:1;
1141 uint32_t FLAG:1;
1142 } B;
1143 } CSR; /* Channel Status Register */
1144
1145 union {
1146 uint32_t R; /* Alternate Channel A Data Register */
1147 } ALTCADR;
1148
1149 uint32_t emios_channel_reserved[2];
1150
1151 } CH[24];
1152
1153 };
1154/****************************************************************************/
1155/* MODULE :ETPU */
1156/****************************************************************************/
1157
1158/***************************Configuration Registers**************************/
1159
1160 struct ETPU_tag {
1161 union { /* MODULE CONFIGURATION REGISTER */
1162 uint32_t R;
1163 struct {
1164 uint32_t GEC:1; /* Global Exception Clear */
1165 uint32_t:3;
1166 uint32_t MGE1:1; /* Microcode Global Exception-ETPU_A */
1167
1168 uint32_t:1; /* For single ETPU implementations */
1169
1170 uint32_t ILF1:1; /* Illegal Instruction Flag-ETPU_A */
1171
1172 uint32_t:1; /* For single ETPU implementations */
1173
1174 uint32_t:3;
1175 uint32_t SCMSIZE:5; /* Shared Code Memory size */
1176 uint32_t:5;
1177 uint32_t SCMMISF:1; /* SCM MISC Flag */
1178 uint32_t SCMMISEN:1; /* SCM MISC Enable */
1179 uint32_t:2;
1180 uint32_t VIS:1; /* SCM Visability */
1181 uint32_t:5;
1182 uint32_t GTBE:1; /* Global Time Base Enable */
1183 } B;
1184 } MCR;
1185
1186 union { /* COHERENT DUAL-PARAMETER CONTROL */
1187 uint32_t R;
1188 struct {
1189 uint32_t STS:1; /* Start Status bit */
1190 uint32_t CTBASE:5; /* Channel Transfer Base */
1191 uint32_t PBASE:10; /* Parameter Buffer Base Address */
1192 uint32_t PWIDTH:1; /* Parameter Width */
1193 uint32_t PARAM0:7; /* Channel Parameter 0 */
1194 uint32_t WR:1;
1195 uint32_t PARAM1:7; /* Channel Parameter 1 */
1196 } B;
1197 } CDCR;
1198
1199 uint32_t etpu_reserved1;
1200
1201 union { /* MISC Compare Register */
1202 uint32_t R;
1203 } MISCCMPR;
1204
1205 union { /* SCM off-range Date Register */
1206 uint32_t R;
1207 } SCMOFFDATAR;
1208
1209 union { /* ETPU_A Configuration Register */
1210 uint32_t R;
1211 struct {
1212 uint32_t FEND:1; /* Force END */
1213 uint32_t MDIS:1; /* Low power Stop */
1214 uint32_t:1;
1215 uint32_t STF:1; /* Stop Flag */
1216 uint32_t:4;
1217 uint32_t HLTF:1; /* Halt Mode Flag */
1218 uint32_t:4;
1219 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
1220 uint32_t CDFC:2;
1221 uint32_t:9;
1222 uint32_t ETB:5; /* Entry Table Base */
1223 } B;
1224 } ECR_A;
1225 uint32_t etpu_reserved3; /* For single ETPU implementations */
1226
1227 uint32_t etpu_reserved4;
1228
1229 union { /* ETPU_A Timebase Configuration Register */
1230 uint32_t R;
1231 struct {
1232 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
1233 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
1234 uint32_t:1;
1235 uint32_t AM:1; /* Angle Mode */
1236 uint32_t:3;
1237 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
1238 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
1239 uint32_t:6;
1240 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
1241 } B;
1242 } TBCR_A;
1243
1244 union { /* ETPU_A TCR1 Visibility Register */
1245 uint32_t R;
1246 } TB1R_A;
1247
1248 union { /* ETPU_A TCR2 Visibility Register */
1249 uint32_t R;
1250 } TB2R_A;
1251
1252 union { /* ETPU_A STAC Configuration Register */
1253 uint32_t R;
1254 struct {
1255 uint32_t REN1:1; /* Resource Enable TCR1 */
1256 uint32_t RSC1:1; /* Resource Control TCR1 */
1257 uint32_t:2;
1258 uint32_t SERVER_ID1:4;
1259 uint32_t:4;
1260 uint32_t SRV1:4; /* Resource Server Slot */
1261 uint32_t REN2:1; /* Resource Enable TCR2 */
1262 uint32_t RSC2:1; /* Resource Control TCR2 */
1263 uint32_t:2;
1264 uint32_t SERVER_ID2:4;
1265 uint32_t:4;
1266 uint32_t SRV2:4; /* Resource Server Slot */
1267 } B;
1268 } REDCR_A;
1269
1270 uint32_t etpu_reserved5[4];
1271 uint32_t etpu_reserved6[4]; /* For single ETPU implementations */
1272
1273 uint32_t etpu_reserved7[108];
1274
1275/*****************************Status and Control Registers**************************/
1276
1277 union { /* ETPU_A Channel Interrut Status */
1278 uint32_t R;
1279 struct {
1280 uint32_t CIS31:1; /* Channel 31 Interrut Status */
1281 uint32_t CIS30:1; /* Channel 30 Interrut Status */
1282 uint32_t CIS29:1; /* Channel 29 Interrut Status */
1283 uint32_t CIS28:1; /* Channel 28 Interrut Status */
1284 uint32_t CIS27:1; /* Channel 27 Interrut Status */
1285 uint32_t CIS26:1; /* Channel 26 Interrut Status */
1286 uint32_t CIS25:1; /* Channel 25 Interrut Status */
1287 uint32_t CIS24:1; /* Channel 24 Interrut Status */
1288 uint32_t CIS23:1; /* Channel 23 Interrut Status */
1289 uint32_t CIS22:1; /* Channel 22 Interrut Status */
1290 uint32_t CIS21:1; /* Channel 21 Interrut Status */
1291 uint32_t CIS20:1; /* Channel 20 Interrut Status */
1292 uint32_t CIS19:1; /* Channel 19 Interrut Status */
1293 uint32_t CIS18:1; /* Channel 18 Interrut Status */
1294 uint32_t CIS17:1; /* Channel 17 Interrut Status */
1295 uint32_t CIS16:1; /* Channel 16 Interrut Status */
1296 uint32_t CIS15:1; /* Channel 15 Interrut Status */
1297 uint32_t CIS14:1; /* Channel 14 Interrut Status */
1298 uint32_t CIS13:1; /* Channel 13 Interrut Status */
1299 uint32_t CIS12:1; /* Channel 12 Interrut Status */
1300 uint32_t CIS11:1; /* Channel 11 Interrut Status */
1301 uint32_t CIS10:1; /* Channel 10 Interrut Status */
1302 uint32_t CIS9:1; /* Channel 9 Interrut Status */
1303 uint32_t CIS8:1; /* Channel 8 Interrut Status */
1304 uint32_t CIS7:1; /* Channel 7 Interrut Status */
1305 uint32_t CIS6:1; /* Channel 6 Interrut Status */
1306 uint32_t CIS5:1; /* Channel 5 Interrut Status */
1307 uint32_t CIS4:1; /* Channel 4 Interrut Status */
1308 uint32_t CIS3:1; /* Channel 3 Interrut Status */
1309 uint32_t CIS2:1; /* Channel 2 Interrut Status */
1310 uint32_t CIS1:1; /* Channel 1 Interrut Status */
1311 uint32_t CIS0:1; /* Channel 0 Interrut Status */
1312 } B;
1313 } CISR_A;
1314 uint32_t etpu_reserved8; /* For single ETPU implementations */
1315
1316 uint32_t etpu_reserved9[2];
1317
1318 union { /* ETPU_A Data Transfer Request Status */
1319 uint32_t R;
1320 struct {
1321 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
1322 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
1323 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
1324 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
1325 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
1326 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
1327 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
1328 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
1329 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
1330 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
1331 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
1332 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
1333 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
1334 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
1335 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
1336 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
1337 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
1338 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
1339 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
1340 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
1341 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
1342 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
1343 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
1344 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
1345 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
1346 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
1347 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
1348 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
1349 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
1350 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
1351 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
1352 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
1353 } B;
1354 } CDTRSR_A;
1355 uint32_t etpu_reserved10; /* For single ETPU implementations */
1356
1357 uint32_t etpu_reserved11[2];
1358
1359 union { /* ETPU_A Interruput Overflow Status */
1360 uint32_t R;
1361 struct {
1362 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
1363 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
1364 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
1365 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
1366 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
1367 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
1368 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
1369 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
1370 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
1371 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
1372 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
1373 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
1374 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
1375 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
1376 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
1377 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
1378 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
1379 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
1380 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
1381 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
1382 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
1383 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
1384 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
1385 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
1386 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
1387 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
1388 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
1389 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
1390 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
1391 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
1392 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
1393 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
1394 } B;
1395 } CIOSR_A;
1396 uint32_t etpu_reserved12; /* For single ETPU implementations */
1397
1398 uint32_t etpu_reserved13[2];
1399
1400 union { /* ETPU_A Data Transfer Overflow Status */
1401 uint32_t R;
1402 struct {
1403 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
1404 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
1405 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
1406 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
1407 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
1408 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
1409 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
1410 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
1411 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
1412 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
1413 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
1414 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
1415 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
1416 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
1417 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
1418 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
1419 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
1420 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
1421 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
1422 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
1423 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
1424 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
1425 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
1426 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
1427 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
1428 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
1429 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
1430 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
1431 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
1432 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
1433 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
1434 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
1435 } B;
1436 } CDTROSR_A;
1437 uint32_t etpu_reserved14; /* For single ETPU implementations */
1438
1439 uint32_t etpu_reserved15[2];
1440
1441 union { /* ETPU_A Channel Interruput Enable */
1442 uint32_t R;
1443 struct {
1444 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
1445 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
1446 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
1447 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
1448 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
1449 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
1450 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
1451 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
1452 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
1453 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
1454 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
1455 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
1456 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
1457 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
1458 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
1459 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
1460 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
1461 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
1462 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
1463 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
1464 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
1465 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
1466 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
1467 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
1468 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
1469 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
1470 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
1471 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
1472 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
1473 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
1474 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
1475 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
1476 } B;
1477 } CIER_A;
1478 uint32_t etpu_reserved16; /* For single ETPU implementations */
1479
1480 uint32_t etpu_reserved17[2];
1481
1482 union { /* ETPU_A Channel Data Transfer Request Enable */
1483 uint32_t R;
1484 struct {
1485 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
1486 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
1487 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
1488 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
1489 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
1490 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
1491 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
1492 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
1493 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
1494 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
1495 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
1496 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
1497 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
1498 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
1499 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
1500 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
1501 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
1502 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
1503 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
1504 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
1505 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
1506 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
1507 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
1508 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
1509 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
1510 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
1511 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
1512 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
1513 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
1514 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
1515 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
1516 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
1517 } B;
1518 } CDTRER_A;
1519 uint32_t etpu_reserved19; /* For single ETPU implementations */
1520
1521 uint32_t etpu_reserved20[10];
1522 union { /* ETPU_A Channel Pending Service Status */
1523 uint32_t R;
1524 struct {
1525 uint32_t SR31:1; /* Channel 31 Pending Service Status */
1526 uint32_t SR30:1; /* Channel 30 Pending Service Status */
1527 uint32_t SR29:1; /* Channel 29 Pending Service Status */
1528 uint32_t SR28:1; /* Channel 28 Pending Service Status */
1529 uint32_t SR27:1; /* Channel 27 Pending Service Status */
1530 uint32_t SR26:1; /* Channel 26 Pending Service Status */
1531 uint32_t SR25:1; /* Channel 25 Pending Service Status */
1532 uint32_t SR24:1; /* Channel 24 Pending Service Status */
1533 uint32_t SR23:1; /* Channel 23 Pending Service Status */
1534 uint32_t SR22:1; /* Channel 22 Pending Service Status */
1535 uint32_t SR21:1; /* Channel 21 Pending Service Status */
1536 uint32_t SR20:1; /* Channel 20 Pending Service Status */
1537 uint32_t SR19:1; /* Channel 19 Pending Service Status */
1538 uint32_t SR18:1; /* Channel 18 Pending Service Status */
1539 uint32_t SR17:1; /* Channel 17 Pending Service Status */
1540 uint32_t SR16:1; /* Channel 16 Pending Service Status */
1541 uint32_t SR15:1; /* Channel 15 Pending Service Status */
1542 uint32_t SR14:1; /* Channel 14 Pending Service Status */
1543 uint32_t SR13:1; /* Channel 13 Pending Service Status */
1544 uint32_t SR12:1; /* Channel 12 Pending Service Status */
1545 uint32_t SR11:1; /* Channel 11 Pending Service Status */
1546 uint32_t SR10:1; /* Channel 10 Pending Service Status */
1547 uint32_t SR9:1; /* Channel 9 Pending Service Status */
1548 uint32_t SR8:1; /* Channel 8 Pending Service Status */
1549 uint32_t SR7:1; /* Channel 7 Pending Service Status */
1550 uint32_t SR6:1; /* Channel 6 Pending Service Status */
1551 uint32_t SR5:1; /* Channel 5 Pending Service Status */
1552 uint32_t SR4:1; /* Channel 4 Pending Service Status */
1553 uint32_t SR3:1; /* Channel 3 Pending Service Status */
1554 uint32_t SR2:1; /* Channel 2 Pending Service Status */
1555 uint32_t SR1:1; /* Channel 1 Pending Service Status */
1556 uint32_t SR0:1; /* Channel 0 Pending Service Status */
1557 } B;
1558 } CPSSR_A;
1559 uint32_t etpu_reserved22; /* For single ETPU implementations */
1560
1561 uint32_t etpu_reserved20a[2];
1562
1563 union { /* ETPU_A Channel Service Status */
1564 uint32_t R;
1565 struct {
1566 uint32_t SS31:1; /* Channel 31 Service Status */
1567 uint32_t SS30:1; /* Channel 30 Service Status */
1568 uint32_t SS29:1; /* Channel 29 Service Status */
1569 uint32_t SS28:1; /* Channel 28 Service Status */
1570 uint32_t SS27:1; /* Channel 27 Service Status */
1571 uint32_t SS26:1; /* Channel 26 Service Status */
1572 uint32_t SS25:1; /* Channel 25 Service Status */
1573 uint32_t SS24:1; /* Channel 24 Service Status */
1574 uint32_t SS23:1; /* Channel 23 Service Status */
1575 uint32_t SS22:1; /* Channel 22 Service Status */
1576 uint32_t SS21:1; /* Channel 21 Service Status */
1577 uint32_t SS20:1; /* Channel 20 Service Status */
1578 uint32_t SS19:1; /* Channel 19 Service Status */
1579 uint32_t SS18:1; /* Channel 18 Service Status */
1580 uint32_t SS17:1; /* Channel 17 Service Status */
1581 uint32_t SS16:1; /* Channel 16 Service Status */
1582 uint32_t SS15:1; /* Channel 15 Service Status */
1583 uint32_t SS14:1; /* Channel 14 Service Status */
1584 uint32_t SS13:1; /* Channel 13 Service Status */
1585 uint32_t SS12:1; /* Channel 12 Service Status */
1586 uint32_t SS11:1; /* Channel 11 Service Status */
1587 uint32_t SS10:1; /* Channel 10 Service Status */
1588 uint32_t SS9:1; /* Channel 9 Service Status */
1589 uint32_t SS8:1; /* Channel 8 Service Status */
1590 uint32_t SS7:1; /* Channel 7 Service Status */
1591 uint32_t SS6:1; /* Channel 6 Service Status */
1592 uint32_t SS5:1; /* Channel 5 Service Status */
1593 uint32_t SS4:1; /* Channel 4 Service Status */
1594 uint32_t SS3:1; /* Channel 3 Service Status */
1595 uint32_t SS2:1; /* Channel 2 Service Status */
1596 uint32_t SS1:1; /* Channel 1 Service Status */
1597 uint32_t SS0:1; /* Channel 0 Service Status */
1598 } B;
1599 } CSSR_A;
1600 uint32_t etpu_reserved22a; /* For single ETPU implementations */
1601
1602 uint32_t etpu_reserved23[90];
1603
1604/*****************************Channels********************************/
1605
1606 struct {
1607 union {
1608 uint32_t R; /* Channel Configuration Register */
1609 struct {
1610 uint32_t CIE:1; /* Channel Interruput Enable */
1611 uint32_t DTRE:1; /* Data Transfer Request Enable */
1612 uint32_t CPR:2; /* Channel Priority */
1613 uint32_t:3;
1614 uint32_t ETCS:1; /* Entry Table Condition Select */
1615 uint32_t:3;
1616 uint32_t CFS:5; /* Channel Function Select */
1617 uint32_t ODIS:1; /* Output disable */
1618 uint32_t OPOL:1; /* output polarity */
1619 uint32_t:3;
1620 uint32_t CPBA:11; /* Channel Parameter Base Address */
1621 } B;
1622 } CR;
1623 union {
1624 uint32_t R; /* Channel Status Control Register */
1625 struct {
1626 uint32_t CIS:1; /* Channel Interruput Status */
1627 uint32_t CIOS:1; /* Channel Interruput Overflow Status */
1628 uint32_t:6;
1629 uint32_t DTRS:1; /* Data Transfer Status */
1630 uint32_t DTROS:1; /* Data Transfer Overflow Status */
1631 uint32_t:6;
1632 uint32_t IPS:1; /* Input Pin State */
1633 uint32_t OPS:1; /* Output Pin State */
1634 uint32_t OBE:1; /* Output Buffer Enable */
1635 uint32_t:11;
1636 uint32_t FM1:1; /* Function mode */
1637 uint32_t FM0:1; /* Function mode */
1638 } B;
1639 } SCR;
1640 union {
1641 uint32_t R; /* Channel Host Service Request Register */
1642 struct {
1643 uint32_t:29; /* Host Service Request */
1644 uint32_t HSR:3;
1645 } B;
1646 } HSRR;
1647 uint32_t etpu_reserved23;
1648 } CHAN[127];
1649
1650 };
1651/****************************************************************************/
1652/* MODULE : XBAR CrossBar */
1653/****************************************************************************/
1654 struct XBAR_tag {
1655 union {
1656 uint32_t R;
1657 struct {
1658 uint32_t:4;
1659
1660 uint32_t:1;
1661 uint32_t MSTR6:3; /* FLEXRAY */
1662
1663 uint32_t:4;
1664
1665 uint32_t:4;
1666
1667 uint32_t:1;
1668 uint32_t MSTR3:3; /* FEC */
1669
1670 uint32_t:1;
1671 uint32_t MSTR2:3;
1672 uint32_t:1;
1673 uint32_t MSTR1:3;
1674 uint32_t:1;
1675 uint32_t MSTR0:3;
1676 } B;
1677 } MPR0; /* Master Priority Register for Slave Port 0 */
1678
1679 uint32_t xbar_reserved1[3];
1680
1681 union {
1682 uint32_t R;
1683 struct {
1684 uint32_t RO:1;
1685 uint32_t:21;
1686 uint32_t ARB:2;
1687 uint32_t:2;
1688 uint32_t PCTL:2;
1689 uint32_t:1;
1690 uint32_t PARK:3;
1691 } B;
1692 } SGPCR0; /* General Purpose Control Register for Slave Port 0 */
1693
1694 uint32_t xbar_reserved2[59];
1695
1696 union {
1697 uint32_t R;
1698 struct {
1699 uint32_t:4;
1700
1701 uint32_t:1;
1702 uint32_t MSTR6:3; /* FLEXRAY */
1703
1704 uint32_t:4;
1705
1706 uint32_t:4;
1707
1708 uint32_t:1;
1709 uint32_t MSTR3:3; /* FEC */
1710
1711 uint32_t:1;
1712 uint32_t MSTR2:3;
1713 uint32_t:1;
1714 uint32_t MSTR1:3;
1715 uint32_t:1;
1716 uint32_t MSTR0:3;
1717 } B;
1718 } MPR1; /* Master Priority Register for Slave Port 1 */
1719
1720 uint32_t xbar_reserved3[3];
1721
1722 union {
1723 uint32_t R;
1724 struct {
1725 uint32_t RO:1;
1726 uint32_t:21;
1727 uint32_t ARB:2;
1728 uint32_t:2;
1729 uint32_t PCTL:2;
1730 uint32_t:1;
1731 uint32_t PARK:3;
1732 } B;
1733 } SGPCR1; /* General Purpose Control Register for Slave Port 1 */
1734
1735 uint32_t xbar_reserved4[123];
1736
1737 union {
1738 uint32_t R;
1739 struct {
1740 uint32_t:4;
1741
1742 uint32_t:1;
1743 uint32_t MSTR6:3; /* FLEXRAY */
1744
1745 uint32_t:4;
1746
1747 uint32_t:4;
1748
1749 uint32_t:1;
1750 uint32_t MSTR3:3; /* FEC */
1751
1752 uint32_t:1;
1753 uint32_t MSTR2:3;
1754 uint32_t:1;
1755 uint32_t MSTR1:3;
1756 uint32_t:1;
1757 uint32_t MSTR0:3;
1758 } B;
1759 } MPR3; /* Master Priority Register for Slave Port 3 */
1760
1761 uint32_t xbar_reserved5[3];
1762
1763 union {
1764 uint32_t R;
1765 struct {
1766 uint32_t RO:1;
1767 uint32_t:21;
1768 uint32_t ARB:2;
1769 uint32_t:2;
1770 uint32_t PCTL:2;
1771 uint32_t:1;
1772 uint32_t PARK:3;
1773 } B;
1774 } SGPCR3; /* General Purpose Control Register for Slave Port 3 */
1775 uint32_t xbar_reserved6[187];
1776
1777 union {
1778 uint32_t R;
1779 struct {
1780 uint32_t:4;
1781
1782 uint32_t:1;
1783 uint32_t MSTR6:3; /* FLEXRAY */
1784
1785 uint32_t:4;
1786
1787 uint32_t:4;
1788
1789 uint32_t:1;
1790 uint32_t MSTR3:3; /* FEC */
1791
1792 uint32_t:1;
1793 uint32_t MSTR2:3;
1794 uint32_t:1;
1795 uint32_t MSTR1:3;
1796 uint32_t:1;
1797 uint32_t MSTR0:3;
1798 } B;
1799 } MPR6; /* Master Priority Register for Slave Port 6 */
1800
1801 uint32_t xbar_reserved7[3];
1802
1803 union {
1804 uint32_t R;
1805 struct {
1806 uint32_t RO:1;
1807 uint32_t:21;
1808 uint32_t ARB:2;
1809 uint32_t:2;
1810 uint32_t PCTL:2;
1811 uint32_t:1;
1812 uint32_t PARK:3;
1813 } B;
1814 } SGPCR6; /* General Purpose Control Register for Slave Port 6 */
1815
1816 uint32_t xbar_reserved8[59];
1817
1818 union {
1819 uint32_t R;
1820 struct {
1821 uint32_t:4;
1822
1823 uint32_t:1;
1824 uint32_t MSTR6:3; /* FLEXRAY */
1825
1826 uint32_t:4;
1827
1828 uint32_t:4;
1829
1830 uint32_t:1;
1831 uint32_t MSTR3:3; /* FEC */
1832
1833 uint32_t:1;
1834 uint32_t MSTR2:3;
1835 uint32_t:1;
1836 uint32_t MSTR1:3;
1837 uint32_t:1;
1838 uint32_t MSTR0:3;
1839 } B;
1840 } MPR7; /* Master Priority Register for Slave Port 7 */
1841
1842 uint32_t xbar_reserved9[3];
1843
1844 union {
1845 uint32_t R;
1846 struct {
1847 uint32_t RO:1;
1848 uint32_t:21;
1849 uint32_t ARB:2;
1850 uint32_t:2;
1851 uint32_t PCTL:2;
1852 uint32_t:1;
1853 uint32_t PARK:3;
1854 } B;
1855 } SGPCR7; /* General Purpose Control Register for Slave Port 7 */
1856
1857 };
1858/****************************************************************************/
1859/* MODULE : ECSM */
1860/****************************************************************************/
1861 struct ECSM_tag {
1862
1863 uint32_t ecsm_reserved1[5];
1864
1865 uint16_t ecsm_reserved2;
1866
1867 union {
1868 uint16_t R;
1869 } SWTCR; //Software Watchdog Timer Control
1870
1871 uint8_t ecsm_reserved3[3];
1872
1873 union {
1874 uint8_t R;
1875 } SWTSR; //SWT Service Register
1876
1877 uint8_t ecsm_reserved4[3];
1878
1879 union {
1880 uint8_t R;
1881 } SWTIR; //SWT Interrupt Register
1882
1883 uint32_t ecsm_reserved5a[1];
1884
1885 union {
1886 uint32_t R;
1887 struct {
1888 uint32_t FSBCR0:1;
1889 uint32_t FSBCR1:1;
1890 uint32_t FSBCR2:1;
1891 uint32_t FSBCR3:1;
1892 uint32_t FSBCR4:1;
1893 uint32_t FSBCR5:1;
1894 uint32_t FSBCR6:1;
1895 uint32_t FSBCR7:1;
1896 uint32_t RBEN:1;
1897 uint32_t WBEN:1;
1898 uint32_t ACCERR:1;
1899 uint32_t:21;
1900 } B;
1901 } FSBMCR; /* FEC System Bus Master Control Register */
1902
1903 uint32_t ecsm_reserved5c[6];
1904
1905 uint8_t ecsm_reserved6[3];
1906
1907 union {
1908 uint8_t R;
1909 struct {
1910 uint8_t:6;
1911 uint8_t ERNCR:1;
1912 uint8_t EFNCR:1;
1913 } B;
1914 } ECR; //ECC Configuration Register
1915
1916 uint8_t mcm_reserved8[3];
1917
1918 union {
1919 uint8_t R;
1920 struct {
1921 uint8_t:6;
1922 uint8_t RNCE:1;
1923 uint8_t FNCE:1;
1924 } B;
1925 } ESR; //ECC Status Register
1926
1927 uint16_t ecsm_reserved9;
1928
1929 union {
1930 uint16_t R;
1931 struct {
1932 uint16_t:6;
1933 uint16_t FRCNCI:1;
1934 uint16_t FR1NCI:1;
1935 uint16_t:1;
1936 uint16_t ERRBIT:7;
1937 } B;
1938 } EEGR; //ECC Error Generation Register
1939
1940 uint32_t ecsm_reserved10;
1941
1942 union {
1943 uint32_t R;
1944 struct {
1945 uint32_t FEAR:32;
1946 } B;
1947 } FEAR; //Flash ECC Address Register
1948
1949 uint16_t ecsm_reserved11;
1950
1951 union {
1952 uint8_t R;
1953 struct {
1954 uint8_t:4;
1955 uint8_t FEMR:4;
1956 } B;
1957 } FEMR; //Flash ECC Master Register
1958
1959 union {
1960 uint8_t R;
1961 struct {
1962 uint8_t WRITE:1;
1963 uint8_t SIZE:3;
1964 uint8_t PROT0:1;
1965 uint8_t PROT1:1;
1966 uint8_t PROT2:1;
1967 uint8_t PROT3:1;
1968 } B;
1969 } FEAT; //Flash ECC Attributes Register
1970
1971 union {
1972 uint32_t R;
1973 struct {
1974 uint32_t FEDH:32;
1975 } B;
1976 } FEDRH; //Flash ECC Data High Register
1977
1978 union {
1979 uint32_t R;
1980 struct {
1981 uint32_t FEDL:32;
1982 } B;
1983 } FEDRL; //Flash ECC Data Low Register
1984
1985 union {
1986 uint32_t R;
1987 struct {
1988 uint32_t REAR:32;
1989 } B;
1990 } REAR; //RAM ECC Address
1991
1992 uint8_t ecsm_reserved12[2];
1993
1994 union {
1995 uint8_t R;
1996 struct {
1997 uint8_t:4;
1998 uint8_t REMR:4;
1999 } B;
2000 } REMR; //RAM ECC Master
2001
2002 union {
2003 uint8_t R;
2004 struct {
2005 uint8_t WRITE:1;
2006 uint8_t SIZE:3;
2007 uint8_t PROT0:1;
2008 uint8_t PROT1:1;
2009 uint8_t PROT2:1;
2010 uint8_t PROT3:1;
2011 } B;
2012 } REAT; // RAM ECC Attributes Register
2013
2014 union {
2015 uint32_t R;
2016 struct {
2017 uint32_t REDH:32;
2018 } B;
2019 } REDRH; //RAM ECC Data High Register
2020
2021 union {
2022 uint32_t R;
2023 struct {
2024 uint32_t REDL:32;
2025 } B;
2026 } REDRL; //RAMECC Data Low Register
2027
2028 };
2029/****************************************************************************/
2030/* MODULE : INTC */
2031/****************************************************************************/
2032 struct INTC_tag {
2033 union {
2034 uint32_t R;
2035 struct {
2036 uint32_t:26;
2037 uint32_t VTES:1;
2038 uint32_t:4;
2039 uint32_t HVEN:1;
2040 } B;
2041 } MCR; /* Module Configuration Register */
2042
2043 int32_t INTC_reserved00;
2044
2045 union {
2046 uint32_t R;
2047 struct {
2048 uint32_t:28;
2049 uint32_t PRI:4;
2050 } B;
2051 } CPR; /* Current Priority Register */
2052
2053 uint32_t intc_reserved1;
2054
2055 union {
2056 uint32_t R;
2057 struct {
2058 uint32_t VTBA:21;
2059 uint32_t INTVEC:9;
2060 uint32_t:2;
2061 } B;
2062 } IACKR; /* Interrupt Acknowledge Register */
2063
2064 uint32_t intc_reserved2;
2065
2066 union {
2067 uint32_t R;
2068 struct {
2069 uint32_t:32;
2070 } B;
2071 } EOIR; /* End of Interrupt Register */
2072
2073 uint32_t intc_reserved3;
2074
2075 union {
2076 uint8_t R;
2077 struct {
2078 uint8_t:6;
2079 uint8_t SET:1;
2080 uint8_t CLR:1;
2081 } B;
2082 } SSCIR[8]; /* Software Set/Clear Interruput Register */
2083
2084 uint32_t intc_reserved4[6];
2085
2086 union {
2087 uint8_t R;
2088 struct {
2089 uint8_t:4;
2090 uint8_t PRI:4;
2091 } B;
2092 } PSR[358]; /* Software Set/Clear Interrupt Register */
2093
2094 };
2095/****************************************************************************/
2096/* MODULE : EQADC */
2097/****************************************************************************/
2098 struct EQADC_tag {
2099 union {
2100 uint32_t R;
2101 struct {
2102 uint32_t:27;
2103 uint32_t ESSIE:2;
2104 uint32_t:1;
2105 uint32_t DBG:2;
2106 } B;
2107 } MCR; /* Module Configuration Register */
2108
2109 int32_t EQADC_reserved00;
2110
2111 union {
2112 uint32_t R;
2113 struct {
2114 uint32_t:6;
2115 uint32_t NMF:26;
2116 } B;
2117 } NMSFR; /* Null Message Send Format Register */
2118
2119 union {
2120 uint32_t R;
2121 struct {
2122 uint32_t:28;
2123 uint32_t DFL:4;
2124 } B;
2125 } ETDFR; /* External Trigger Digital Filter Register */
2126
2127 union {
2128 uint32_t R;
2129 struct {
2130 uint32_t CFPUSH:32;
2131 } B;
2132 } CFPR[6]; /* CFIFO Push Registers */
2133
2134 uint32_t eqadc_reserved1;
2135
2136 uint32_t eqadc_reserved2;
2137
2138 union {
2139 uint32_t R;
2140 struct {
2141 uint32_t:16;
2142 uint32_t RFPOP:16;
2143 } B;
2144 } RFPR[6]; /* Result FIFO Pop Registers */
2145
2146 uint32_t eqadc_reserved3;
2147
2148 uint32_t eqadc_reserved4;
2149
2150 union {
2151 uint16_t R;
2152 struct {
2153 uint16_t:5;
2154 uint16_t SSE:1;
2155 uint16_t CFINV:1;
2156 uint16_t:1;
2157 uint16_t MODE:4;
2158 uint16_t:4;
2159 } B;
2160 } CFCR[6]; /* CFIFO Control Registers */
2161
2162 uint32_t eqadc_reserved5;
2163
2164 union {
2165 uint16_t R;
2166 struct {
2167 uint16_t NCIE:1;
2168 uint16_t TORIE:1;
2169 uint16_t PIE:1;
2170 uint16_t EOQIE:1;
2171 uint16_t CFUIE:1;
2172 uint16_t:1;
2173 uint16_t CFFE:1;
2174 uint16_t CFFS:1;
2175 uint16_t:4;
2176 uint16_t RFOIE:1;
2177 uint16_t:1;
2178 uint16_t RFDE:1;
2179 uint16_t RFDS:1;
2180 } B;
2181 } IDCR[6]; /* Interrupt and DMA Control Registers */
2182
2183 uint32_t eqadc_reserved6;
2184
2185 union {
2186 uint32_t R;
2187 struct {
2188 uint32_t NCF:1;
2189 uint32_t TORF:1;
2190 uint32_t PF:1;
2191 uint32_t EOQF:1;
2192 uint32_t CFUF:1;
2193 uint32_t SSS:1;
2194 uint32_t CFFF:1;
2195 uint32_t:5;
2196 uint32_t RFOF:1;
2197 uint32_t:1;
2198 uint32_t RFDF:1;
2199 uint32_t:1;
2200 uint32_t CFCTR:4;
2201 uint32_t TNXTPTR:4;
2202 uint32_t RFCTR:4;
2203 uint32_t POPNXTPTR:4;
2204 } B;
2205 } FISR[6]; /* FIFO and Interrupt Status Registers */
2206
2207 uint32_t eqadc_reserved7;
2208
2209 uint32_t eqadc_reserved8;
2210
2211 union {
2212 uint16_t R;
2213 struct {
2214 uint16_t:5;
2215 uint16_t TCCF:11;
2216 } B;
2217 } CFTCR[6]; /* CFIFO Transfer Counter Registers */
2218
2219 uint32_t eqadc_reserved9;
2220
2221 union {
2222 uint32_t R;
2223 struct {
2224 uint32_t CFS0:2;
2225 uint32_t CFS1:2;
2226 uint32_t CFS2:2;
2227 uint32_t CFS3:2;
2228 uint32_t CFS4:2;
2229 uint32_t CFS5:2;
2230 uint32_t:5;
2231 uint32_t LCFTCB0:4;
2232 uint32_t TC_LCFTCB0:11;
2233 } B;
2234 } CFSSR0; /* CFIFO Status Register 0 */
2235
2236 union {
2237 uint32_t R;
2238 struct {
2239 uint32_t CFS0:2;
2240 uint32_t CFS1:2;
2241 uint32_t CFS2:2;
2242 uint32_t CFS3:2;
2243 uint32_t CFS4:2;
2244 uint32_t CFS5:2;
2245 uint32_t:5;
2246 uint32_t LCFTCB1:4;
2247 uint32_t TC_LCFTCB1:11;
2248 } B;
2249 } CFSSR1; /* CFIFO Status Register 1 */
2250
2251 union {
2252 uint32_t R;
2253 struct {
2254 uint32_t CFS0:2;
2255 uint32_t CFS1:2;
2256 uint32_t CFS2:2;
2257 uint32_t CFS3:2;
2258 uint32_t CFS4:2;
2259 uint32_t CFS5:2;
2260 uint32_t:4;
2261 uint32_t ECBNI:1;
2262 uint32_t LCFTSSI:4;
2263 uint32_t TC_LCFTSSI:11;
2264 } B;
2265 } CFSSR2; /* CFIFO Status Register 2 */
2266
2267 union {
2268 uint32_t R;
2269 struct {
2270 uint32_t CFS0:2;
2271 uint32_t CFS1:2;
2272 uint32_t CFS2:2;
2273 uint32_t CFS3:2;
2274 uint32_t CFS4:2;
2275 uint32_t CFS5:2;
2276 uint32_t:20;
2277 } B;
2278 } CFSR;
2279
2280 uint32_t eqadc_reserved11;
2281
2282 union {
2283 uint32_t R;
2284 struct {
2285 uint32_t:21;
2286 uint32_t MDT:3;
2287 uint32_t:4;
2288 uint32_t BR:4;
2289 } B;
2290 } SSICR; /* SSI Control Register */
2291
2292 union {
2293 uint32_t R;
2294 struct {
2295 uint32_t RDV:1;
2296 uint32_t:5;
2297 uint32_t RDATA:26;
2298 } B;
2299 } SSIRDR; /* SSI Recieve Data Register */
2300
2301 uint32_t eqadc_reserved12[17];
2302
2303 struct {
2304 union {
2305 uint32_t R;
2306 struct {
2307 uint32_t:32;
2308 } B;
2309 } R[4];
2310
2311 uint32_t eqadc_reserved13[12];
2312
2313 } CF[6];
2314
2315 uint32_t eqadc_reserved14[32];
2316
2317 struct {
2318 union {
2319 uint32_t R;
2320 struct {
2321 uint32_t:32;
2322 } B;
2323 } R[4];
2324
2325 uint32_t eqadc_reserved15[12];
2326
2327 } RF[6];
2328
2329 };
2330/****************************************************************************/
2331/* MODULE : DSPI */
2332/****************************************************************************/
2333 struct DSPI_tag {
2334 union DSPI_MCR_tag {
2335 uint32_t R;
2336 struct {
2337 uint32_t MSTR:1;
2338 uint32_t CONT_SCKE:1;
2339 uint32_t DCONF:2;
2340 uint32_t FRZ:1;
2341 uint32_t MTFE:1;
2342 uint32_t PCSSE:1;
2343 uint32_t ROOE:1;
2344 uint32_t:2;
2345 uint32_t PCSIS5:1;
2346 uint32_t PCSIS4:1;
2347 uint32_t PCSIS3:1;
2348 uint32_t PCSIS2:1;
2349 uint32_t PCSIS1:1;
2350 uint32_t PCSIS0:1;
2351 uint32_t DOZE:1;
2352 uint32_t MDIS:1;
2353 uint32_t DIS_TXF:1;
2354 uint32_t DIS_RXF:1;
2355 uint32_t CLR_TXF:1;
2356 uint32_t CLR_RXF:1;
2357 uint32_t SMPL_PT:2;
2358 uint32_t:7;
2359 uint32_t HALT:1;
2360 } B;
2361 } MCR; /* Module Configuration Register */
2362
2363 uint32_t dspi_reserved1;
2364
2365 union {
2366 uint32_t R;
2367 struct {
2368 uint32_t TCNT:16;
2369 uint32_t:16;
2370 } B;
2371 } TCR;
2372
2373 union DSPI_CTAR_tag {
2374 uint32_t R;
2375 struct {
2376 uint32_t DBR:1;
2377 uint32_t FMSZ:4;
2378 uint32_t CPOL:1;
2379 uint32_t CPHA:1;
2380 uint32_t LSBFE:1;
2381 uint32_t PCSSCK:2;
2382 uint32_t PASC:2;
2383 uint32_t PDT:2;
2384 uint32_t PBR:2;
2385 uint32_t CSSCK:4;
2386 uint32_t ASC:4;
2387 uint32_t DT:4;
2388 uint32_t BR:4;
2389 } B;
2390 } CTAR[8]; /* Clock and Transfer Attributes Registers */
2391
2392 union DSPI_SR_tag {
2393 uint32_t R;
2394 struct {
2395 uint32_t TCF:1;
2396 uint32_t TXRXS:1;
2397 uint32_t:1;
2398 uint32_t EOQF:1;
2399 uint32_t TFUF:1;
2400 uint32_t:1;
2401 uint32_t TFFF:1;
2402 uint32_t:5;
2403 uint32_t RFOF:1;
2404 uint32_t:1;
2405 uint32_t RFDF:1;
2406 uint32_t:1;
2407 uint32_t TXCTR:4;
2408 uint32_t TXNXTPTR:4;
2409 uint32_t RXCTR:4;
2410 uint32_t POPNXTPTR:4;
2411 } B;
2412 } SR; /* Status Register */
2413
2414 union DSPI_RSER_tag {
2415 uint32_t R;
2416 struct {
2417 uint32_t TCFRE:1;
2418 uint32_t:2;
2419 uint32_t EOQFRE:1;
2420 uint32_t TFUFRE:1;
2421 uint32_t:1;
2422 uint32_t TFFFRE:1;
2423 uint32_t TFFFDIRS:1;
2424 uint32_t:4;
2425 uint32_t RFOFRE:1;
2426 uint32_t:1;
2427 uint32_t RFDFRE:1;
2428 uint32_t RFDFDIRS:1;
2429 uint32_t:16;
2430 } B;
2431 } RSER; /* DMA/Interrupt Request Select and Enable Register */
2432
2433 union DSPI_PUSHR_tag {
2434 uint32_t R;
2435 struct {
2436 uint32_t CONT:1;
2437 uint32_t CTAS:3;
2438 uint32_t EOQ:1;
2439 uint32_t CTCNT:1;
2440 uint32_t:4;
2441 uint32_t PCS5:1;
2442 uint32_t PCS4:1;
2443 uint32_t PCS3:1;
2444 uint32_t PCS2:1;
2445 uint32_t PCS1:1;
2446 uint32_t PCS0:1;
2447 uint32_t TXDATA:16;
2448 } B;
2449 } PUSHR; /* PUSH TX FIFO Register */
2450
2451 union DSPI_POPR_tag {
2452 uint32_t R;
2453 struct {
2454 uint32_t:16;
2455 uint32_t RXDATA:16;
2456 } B;
2457 } POPR; /* POP RX FIFO Register */
2458
2459 union {
2460 uint32_t R;
2461 struct {
2462 uint32_t TXCMD:16;
2463 uint32_t TXDATA:16;
2464 } B;
2465 } TXFR[4]; /* Transmit FIFO Registers */
2466
2467 uint32_t DSPI_reserved_txf[12];
2468
2469 union {
2470 uint32_t R;
2471 struct {
2472 uint32_t:16;
2473 uint32_t RXDATA:16;
2474 } B;
2475 } RXFR[4]; /* Transmit FIFO Registers */
2476
2477 uint32_t DSPI_reserved_rxf[12];
2478
2479 union {
2480 uint32_t R;
2481 struct {
2482 uint32_t MTOE:1;
2483 uint32_t:1;
2484 uint32_t MTOCNT:6;
2485 uint32_t:4;
2486 uint32_t TXSS:1;
2487 uint32_t TPOL:1;
2488 uint32_t TRRE:1;
2489 uint32_t CID:1;
2490 uint32_t DCONT:1;
2491 uint32_t DSICTAS:3;
2492 uint32_t:6;
2493 uint32_t DPCS5:1;
2494 uint32_t DPCS4:1;
2495 uint32_t DPCS3:1;
2496 uint32_t DPCS2:1;
2497 uint32_t DPCS1:1;
2498 uint32_t DPCS0:1;
2499 } B;
2500 } DSICR; /* DSI Configuration Register */
2501
2502 union {
2503 uint32_t R;
2504 struct {
2505 uint32_t:16;
2506 uint32_t SER_DATA:16;
2507 } B;
2508 } SDR; /* DSI Serialization Data Register */
2509
2510 union {
2511 uint32_t R;
2512 struct {
2513 uint32_t:16;
2514 uint32_t ASER_DATA:16;
2515 } B;
2516 } ASDR; /* DSI Alternate Serialization Data Register */
2517
2518 union {
2519 uint32_t R;
2520 struct {
2521 uint32_t:16;
2522 uint32_t COMP_DATA:16;
2523 } B;
2524 } COMPR; /* DSI Transmit Comparison Register */
2525
2526 union {
2527 uint32_t R;
2528 struct {
2529 uint32_t:16;
2530 uint32_t DESER_DATA:16;
2531 } B;
2532 } DDR; /* DSI deserialization Data Register */
2533
2534 };
2535/****************************************************************************/
2536/* MODULE : eSCI */
2537/****************************************************************************/
2538 struct ESCI_tag {
2539 union ESCI_CR1_tag {
2540 uint32_t R;
2541 struct {
2542 uint32_t:3;
2543 uint32_t SBR:13;
2544 uint32_t LOOPS:1;
2545 uint32_t SCISDOZ:1;
2546 uint32_t RSRC:1;
2547 uint32_t M:1;
2548 uint32_t WAKE:1;
2549 uint32_t ILT:1;
2550 uint32_t PE:1;
2551 uint32_t PT:1;
2552 uint32_t TIE:1;
2553 uint32_t TCIE:1;
2554 uint32_t RIE:1;
2555 uint32_t ILIE:1;
2556 uint32_t TE:1;
2557 uint32_t RE:1;
2558 uint32_t RWU:1;
2559 uint32_t SBK:1;
2560 } B;
2561 } CR1; /* Control Register 1 */
2562
2563 union ESCI_CR2_tag {
2564 uint16_t R;
2565 struct {
2566 uint16_t MDIS:1;
2567 uint16_t FBR:1;
2568 uint16_t BSTP:1;
2569 uint16_t IEBERR:1;
2570 uint16_t RXDMA:1;
2571 uint16_t TXDMA:1;
2572 uint16_t BRK13:1;
2573 uint16_t:1;
2574 uint16_t BESM13:1;
2575 uint16_t SBSTP:1;
2576 uint16_t:2;
2577 uint16_t ORIE:1;
2578 uint16_t NFIE:1;
2579 uint16_t FEIE:1;
2580 uint16_t PFIE:1;
2581 } B;
2582 } CR2; /* Control Register 2 */
2583
2584 union ESCI_DR_tag {
2585 uint16_t R;
2586 struct {
2587 uint16_t R8:1;
2588 uint16_t T8:1;
2589 uint16_t:6;
2590 uint8_t D;
2591 } B;
2592 } DR; /* Data Register */
2593
2594 union ESCI_SR_tag {
2595 uint32_t R;
2596 struct {
2597 uint32_t TDRE:1;
2598 uint32_t TC:1;
2599 uint32_t RDRF:1;
2600 uint32_t IDLE:1;
2601 uint32_t OR:1;
2602 uint32_t NF:1;
2603 uint32_t FE:1;
2604 uint32_t PF:1;
2605 uint32_t:3;
2606 uint32_t BERR:1;
2607 uint32_t:3;
2608 uint32_t RAF:1;
2609 uint32_t RXRDY:1;
2610 uint32_t TXRDY:1;
2611 uint32_t LWAKE:1;
2612 uint32_t STO:1;
2613 uint32_t PBERR:1;
2614 uint32_t CERR:1;
2615 uint32_t CKERR:1;
2616 uint32_t FRC:1;
2617 uint32_t:7;
2618 uint32_t OVFL:1;
2619 } B;
2620 } SR; /* Status Register */
2621
2622 union {
2623 uint32_t R;
2624 struct {
2625 uint32_t LRES:1;
2626 uint32_t WU:1;
2627 uint32_t WUD0:1;
2628 uint32_t WUD1:1;
2629 uint32_t LDBG:1;
2630 uint32_t DSF:1;
2631 uint32_t PRTY:1;
2632 uint32_t LIN:1;
2633 uint32_t RXIE:1;
2634 uint32_t TXIE:1;
2635 uint32_t WUIE:1;
2636 uint32_t STIE:1;
2637 uint32_t PBIE:1;
2638 uint32_t CIE:1;
2639 uint32_t CKIE:1;
2640 uint32_t FCIE:1;
2641 uint32_t:7;
2642 uint32_t OFIE:1;
2643 uint32_t:8;
2644 } B;
2645 } LCR; /* LIN Control Register */
2646
2647 union {
2648 uint32_t R;
2649 } LTR; /* LIN Transmit Register */
2650
2651 union {
2652 uint32_t R;
2653 } LRR; /* LIN Recieve Register */
2654
2655 union {
2656 uint32_t R;
2657 } LPR; /* LIN CRC Polynom Register */
2658
2659 };
2660/****************************************************************************/
2661/* MODULE : FlexCAN */
2662/****************************************************************************/
2663 struct FLEXCAN2_tag {
2664 union {
2665 uint32_t R;
2666 struct {
2667 uint32_t MDIS:1;
2668 uint32_t FRZ:1;
2669 uint32_t:1;
2670 uint32_t HALT:1;
2671 uint32_t NOTRDY:1;
2672 uint32_t:1;
2673 uint32_t SOFTRST:1;
2674 uint32_t FRZACK:1;
2675 uint32_t:1;
2676 uint32_t:1;
2677
2678 uint32_t WRNEN:1;
2679
2680 uint32_t MDISACK:1;
2681 uint32_t:1;
2682 uint32_t:1;
2683
2684 uint32_t SRXDIS:1;
2685 uint32_t MBFEN:1;
2686 uint32_t:10;
2687
2688 uint32_t MAXMB:6;
2689 } B;
2690 } MCR; /* Module Configuration Register */
2691
2692 union {
2693 uint32_t R;
2694 struct {
2695 uint32_t PRESDIV:8;
2696 uint32_t RJW:2;
2697 uint32_t PSEG1:3;
2698 uint32_t PSEG2:3;
2699 uint32_t BOFFMSK:1;
2700 uint32_t ERRMSK:1;
2701 uint32_t CLKSRC:1;
2702 uint32_t LPB:1;
2703
2704 uint32_t TWRNMSK:1;
2705 uint32_t RWRNMSK:1;
2706 uint32_t:2;
2707
2708 uint32_t SMP:1;
2709 uint32_t BOFFREC:1;
2710 uint32_t TSYN:1;
2711 uint32_t LBUF:1;
2712 uint32_t LOM:1;
2713 uint32_t PROPSEG:3;
2714 } B;
2715 } CR; /* Control Register */
2716
2717 union {
2718 uint32_t R;
2719 } TIMER; /* Free Running Timer */
2720 int32_t FLEXCAN_reserved00;
2721
2722 union {
2723 uint32_t R;
2724 struct {
2725 uint32_t:3;
2726 uint32_t MI:29;
2727 } B;
2728 } RXGMASK; /* RX Global Mask */
2729
2730 union {
2731 uint32_t R;
2732 struct {
2733 uint32_t:3;
2734 uint32_t MI:29;
2735 } B;
2736 } RX14MASK; /* RX 14 Mask */
2737
2738 union {
2739 uint32_t R;
2740 struct {
2741 uint32_t:3;
2742 uint32_t MI:29;
2743 } B;
2744 } RX15MASK; /* RX 15 Mask */
2745
2746 union {
2747 uint32_t R;
2748 struct {
2749 uint32_t:16;
2750 uint32_t RXECNT:8;
2751 uint32_t TXECNT:8;
2752 } B;
2753 } ECR; /* Error Counter Register */
2754
2755 union {
2756 uint32_t R;
2757 struct {
2758 uint32_t:14;
2759
2760 uint32_t TWRNINT:1;
2761 uint32_t RWRNINT:1;
2762
2763 uint32_t BIT1ERR:1;
2764 uint32_t BIT0ERR:1;
2765 uint32_t ACKERR:1;
2766 uint32_t CRCERR:1;
2767 uint32_t FRMERR:1;
2768 uint32_t STFERR:1;
2769 uint32_t TXWRN:1;
2770 uint32_t RXWRN:1;
2771 uint32_t IDLE:1;
2772 uint32_t TXRX:1;
2773 uint32_t FLTCONF:2;
2774 uint32_t:1;
2775 uint32_t BOFFINT:1;
2776 uint32_t ERRINT:1;
2777 uint32_t:1;
2778 } B;
2779 } ESR; /* Error and Status Register */
2780
2781 union {
2782 uint32_t R;
2783 struct {
2784 uint32_t BUF63M:1;
2785 uint32_t BUF62M:1;
2786 uint32_t BUF61M:1;
2787 uint32_t BUF60M:1;
2788 uint32_t BUF59M:1;
2789 uint32_t BUF58M:1;
2790 uint32_t BUF57M:1;
2791 uint32_t BUF56M:1;
2792 uint32_t BUF55M:1;
2793 uint32_t BUF54M:1;
2794 uint32_t BUF53M:1;
2795 uint32_t BUF52M:1;
2796 uint32_t BUF51M:1;
2797 uint32_t BUF50M:1;
2798 uint32_t BUF49M:1;
2799 uint32_t BUF48M:1;
2800 uint32_t BUF47M:1;
2801 uint32_t BUF46M:1;
2802 uint32_t BUF45M:1;
2803 uint32_t BUF44M:1;
2804 uint32_t BUF43M:1;
2805 uint32_t BUF42M:1;
2806 uint32_t BUF41M:1;
2807 uint32_t BUF40M:1;
2808 uint32_t BUF39M:1;
2809 uint32_t BUF38M:1;
2810 uint32_t BUF37M:1;
2811 uint32_t BUF36M:1;
2812 uint32_t BUF35M:1;
2813 uint32_t BUF34M:1;
2814 uint32_t BUF33M:1;
2815 uint32_t BUF32M:1;
2816 } B;
2817 } IMRH; /* Interruput Masks Register */
2818
2819 union {
2820 uint32_t R;
2821 struct {
2822 uint32_t BUF31M:1;
2823 uint32_t BUF30M:1;
2824 uint32_t BUF29M:1;
2825 uint32_t BUF28M:1;
2826 uint32_t BUF27M:1;
2827 uint32_t BUF26M:1;
2828 uint32_t BUF25M:1;
2829 uint32_t BUF24M:1;
2830 uint32_t BUF23M:1;
2831 uint32_t BUF22M:1;
2832 uint32_t BUF21M:1;
2833 uint32_t BUF20M:1;
2834 uint32_t BUF19M:1;
2835 uint32_t BUF18M:1;
2836 uint32_t BUF17M:1;
2837 uint32_t BUF16M:1;
2838 uint32_t BUF15M:1;
2839 uint32_t BUF14M:1;
2840 uint32_t BUF13M:1;
2841 uint32_t BUF12M:1;
2842 uint32_t BUF11M:1;
2843 uint32_t BUF10M:1;
2844 uint32_t BUF09M:1;
2845 uint32_t BUF08M:1;
2846 uint32_t BUF07M:1;
2847 uint32_t BUF06M:1;
2848 uint32_t BUF05M:1;
2849 uint32_t BUF04M:1;
2850 uint32_t BUF03M:1;
2851 uint32_t BUF02M:1;
2852 uint32_t BUF01M:1;
2853 uint32_t BUF00M:1;
2854 } B;
2855 } IMRL; /* Interruput Masks Register */
2856
2857 union {
2858 uint32_t R;
2859 struct {
2860 uint32_t BUF63I:1;
2861 uint32_t BUF62I:1;
2862 uint32_t BUF61I:1;
2863 uint32_t BUF60I:1;
2864 uint32_t BUF59I:1;
2865 uint32_t BUF58I:1;
2866 uint32_t BUF57I:1;
2867 uint32_t BUF56I:1;
2868 uint32_t BUF55I:1;
2869 uint32_t BUF54I:1;
2870 uint32_t BUF53I:1;
2871 uint32_t BUF52I:1;
2872 uint32_t BUF51I:1;
2873 uint32_t BUF50I:1;
2874 uint32_t BUF49I:1;
2875 uint32_t BUF48I:1;
2876 uint32_t BUF47I:1;
2877 uint32_t BUF46I:1;
2878 uint32_t BUF45I:1;
2879 uint32_t BUF44I:1;
2880 uint32_t BUF43I:1;
2881 uint32_t BUF42I:1;
2882 uint32_t BUF41I:1;
2883 uint32_t BUF40I:1;
2884 uint32_t BUF39I:1;
2885 uint32_t BUF38I:1;
2886 uint32_t BUF37I:1;
2887 uint32_t BUF36I:1;
2888 uint32_t BUF35I:1;
2889 uint32_t BUF34I:1;
2890 uint32_t BUF33I:1;
2891 uint32_t BUF32I:1;
2892 } B;
2893 } IFRH; /* Interruput Flag Register */
2894
2895 union {
2896 uint32_t R;
2897 struct {
2898 uint32_t BUF31I:1;
2899 uint32_t BUF30I:1;
2900 uint32_t BUF29I:1;
2901 uint32_t BUF28I:1;
2902 uint32_t BUF27I:1;
2903 uint32_t BUF26I:1;
2904 uint32_t BUF25I:1;
2905 uint32_t BUF24I:1;
2906 uint32_t BUF23I:1;
2907 uint32_t BUF22I:1;
2908 uint32_t BUF21I:1;
2909 uint32_t BUF20I:1;
2910 uint32_t BUF19I:1;
2911 uint32_t BUF18I:1;
2912 uint32_t BUF17I:1;
2913 uint32_t BUF16I:1;
2914 uint32_t BUF15I:1;
2915 uint32_t BUF14I:1;
2916 uint32_t BUF13I:1;
2917 uint32_t BUF12I:1;
2918 uint32_t BUF11I:1;
2919 uint32_t BUF10I:1;
2920 uint32_t BUF09I:1;
2921 uint32_t BUF08I:1;
2922 uint32_t BUF07I:1;
2923 uint32_t BUF06I:1;
2924 uint32_t BUF05I:1;
2925 uint32_t BUF04I:1;
2926 uint32_t BUF03I:1;
2927 uint32_t BUF02I:1;
2928 uint32_t BUF01I:1;
2929 uint32_t BUF00I:1;
2930 } B;
2931 } IFRL; /* Interruput Flag Register */
2932
2933 uint32_t flexcan2_reserved2[19];
2934
2935 struct canbuf_t {
2936 union {
2937 uint32_t R;
2938 struct {
2939 uint32_t:4;
2940 uint32_t CODE:4;
2941 uint32_t:1;
2942 uint32_t SRR:1;
2943 uint32_t IDE:1;
2944 uint32_t RTR:1;
2945 uint32_t LENGTH:4;
2946 uint32_t TIMESTAMP:16;
2947 } B;
2948 } CS;
2949
2950 union {
2951 uint32_t R;
2952 struct {
2953 uint32_t:3;
2954 uint32_t STD_ID:11;
2955 uint32_t EXT_ID:18;
2956 } B;
2957 } ID;
2958
2959 union {
2960 uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
2961 uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
2962 uint32_t W[2]; /* Data buffer in words (32 bits) */
2963 uint32_t R[2]; /* Data buffer in words (32 bits) */
2964 } DATA;
2965
2966 } BUF[64];
2967
2968 uint32_t flexcan2_reserved3[256];
2969
2970 union {
2971 uint32_t R;
2972 struct {
2973 uint32_t:3;
2974 uint32_t MI:29;
2975 } B;
2976 } RXIMR[64]; /* RX Individual Mask Registers */
2977
2978 };
2979/****************************************************************************/
2980/* MODULE : FEC */
2981/****************************************************************************/
2982 struct FEC_tag {
2983
2984 uint32_t fec_reserved_start[0x1];
2985
2986 union {
2987 uint32_t R;
2988 struct {
2989 uint32_t HBERR:1;
2990 uint32_t BABR:1;
2991 uint32_t BABT:1;
2992 uint32_t GRA:1;
2993 uint32_t TXF:1;
2994 uint32_t TXB:1;
2995 uint32_t RXF:1;
2996 uint32_t RXB:1;
2997 uint32_t MII:1;
2998 uint32_t EBERR:1;
2999 uint32_t LC:1;
3000 uint32_t RL:1;
3001 uint32_t UN:1;
3002 uint32_t:19;
3003 } B;
3004 } EIR; /* Interrupt Event Register */
3005
3006 union {
3007 uint32_t R;
3008 struct {
3009 uint32_t HBERRM:1;
3010 uint32_t BABRM:1;
3011 uint32_t BABTM:1;
3012 uint32_t GRAM:1;
3013 uint32_t TXFM:1;
3014 uint32_t TXBM:1;
3015 uint32_t RXFM:1;
3016 uint32_t RXBM:1;
3017 uint32_t MIIM:1;
3018 uint32_t EBERRM:1;
3019 uint32_t LCM:1;
3020 uint32_t RLM:1;
3021 uint32_t UNM:1;
3022 uint32_t:19;
3023 } B;
3024 } EIMR; /* Interrupt Mask Register */
3025
3026 uint32_t fec_reserved_eimr;
3027
3028 union {
3029 uint32_t R;
3030 struct {
3031 uint32_t:7;
3032 uint32_t R_DES_ACTIVE:1;
3033 uint32_t:24;
3034 } B;
3035 } RDAR; /* Receive Descriptor Active Register */
3036
3037 union {
3038 uint32_t R;
3039 struct {
3040 uint32_t:7;
3041 uint32_t X_DES_ACTIVE:1;
3042 uint32_t:24;
3043 } B;
3044 } TDAR; /* Transmit Descriptor Active Register */
3045
3046 uint32_t fec_reserved_tdar[3];
3047
3048 union {
3049 uint32_t R;
3050 struct {
3051 uint32_t:30;
3052 uint32_t ETHER_EN:1;
3053 uint32_t RESET:1;
3054 } B;
3055 } ECR; /* Ethernet Control Register */
3056
3057 uint32_t fec_reserved_ecr[6];
3058
3059 union {
3060 uint32_t R;
3061 struct {
3062 uint32_t ST:2;
3063 uint32_t CP:2;
3064 uint32_t PA:5;
3065 uint32_t RA:5;
3066 uint32_t TA:2;
3067 uint32_t DATA:16;
3068 } B;
3069 } MDATA; /* MII Data Register */
3070
3071 union {
3072 uint32_t R;
3073 struct {
3074 uint32_t:24;
3075 uint32_t DIS_PREAMBLE:1;
3076 uint32_t MII_SPEED:6;
3077 uint32_t:1;
3078 } B;
3079 } MSCR; /* MII Speed Control Register */
3080
3081 uint32_t fec_reserved_mscr[7];
3082
3083 union {
3084 uint32_t R;
3085 struct {
3086 uint32_t MIB_DISABLE:1;
3087 uint32_t MIB_IDLE:1;
3088 uint32_t:30;
3089 } B;
3090 } MIBC; /* MIB Control Register */
3091
3092 uint32_t fec_reserved_mibc[7];
3093
3094 union {
3095 uint32_t R;
3096 struct {
3097 uint32_t:5;
3098 uint32_t MAX_FL:11;
3099 uint32_t:10;
3100 uint32_t FCE:1;
3101 uint32_t BC_REJ:1;
3102 uint32_t PROM:1;
3103 uint32_t MII_MODE:1;
3104 uint32_t DRT:1;
3105 uint32_t LOOP:1;
3106 } B;
3107 } RCR; /* Receive Control Register */
3108
3109 uint32_t fec_reserved_rcr[15];
3110
3111 union {
3112 uint32_t R;
3113 struct {
3114 uint32_t:27;
3115 uint32_t RFC_PAUSE:1;
3116 uint32_t TFC_PAUSE:1;
3117 uint32_t FDEN:1;
3118 uint32_t HBC:1;
3119 uint32_t GTS:1;
3120 } B;
3121 } TCR; /* Transmit Control Register */
3122
3123 uint32_t fec_reserved_tcr[7];
3124
3125 union {
3126 uint32_t R;
3127 struct {
3128 uint32_t PADDR1:32;
3129 } B;
3130 } PALR; /* Physical Address Low Register */
3131
3132 union {
3133 uint32_t R;
3134 struct {
3135 uint32_t PADDR2:16;
3136 uint32_t TYPE:16;
3137 } B;
3138 } PAUR; /* Physical Address High + Type Register */
3139
3140 union {
3141 uint32_t R;
3142 struct {
3143 uint32_t OPCODE:16;
3144 uint32_t PAUSE_DUR:16;
3145 } B;
3146 } OPD; /* Opcode/Pause Duration Register */
3147
3148 uint32_t fec_reserved_opd[10];
3149
3150 union {
3151 uint32_t R;
3152 struct {
3153 uint32_t IADDR1:32;
3154 } B;
3155 } IAUR; /* Descriptor Individual Upper Address Register */
3156
3157 union {
3158 uint32_t R;
3159 struct {
3160 uint32_t IADDR2:32;
3161 } B;
3162 } IALR; /* Descriptor Individual Lower Address Register */
3163
3164 union {
3165 uint32_t R;
3166 struct {
3167 uint32_t GADDR1:32;
3168 } B;
3169 } GAUR; /* Descriptor Group Upper Address Register */
3170
3171 union {
3172 uint32_t R;
3173 struct {
3174 uint32_t GADDR2:32;
3175 } B;
3176 } GALR; /* Descriptor Group Lower Address Register */
3177
3178 uint32_t fec_reserved_galr[7];
3179
3180 union {
3181 uint32_t R;
3182 struct {
3183 uint32_t:30;
3184 uint32_t X_WMRK:2;
3185 } B;
3186 } TFWR; /* FIFO Transmit FIFO Watermark Register */
3187
3188 uint32_t fec_reserved_tfwr;
3189
3190 union {
3191 uint32_t R;
3192 struct {
3193 uint32_t:22;
3194 uint32_t R_BOUND:8;
3195 uint32_t:2;
3196 } B;
3197 } FRBR; /* FIFO Receive Bound Register */
3198
3199 union {
3200 uint32_t R;
3201 struct {
3202 uint32_t:22;
3203 uint32_t R_FSTART:8;
3204 uint32_t:2;
3205 } B;
3206 } FRSR; /* FIFO Receive Start Register */
3207
3208 uint32_t fec_reserved_frsr[11];
3209
3210 union {
3211 uint32_t R;
3212 struct {
3213 uint32_t R_DES_START:30;
3214 uint32_t:2;
3215 } B;
3216 } ERDSR; /* Receive Descriptor Ring Start Register */
3217
3218 union {
3219 uint32_t R;
3220 struct {
3221 uint32_t X_DES_START:30;
3222 uint32_t:2;
3223 } B;
3224 } ETDSR; /* Transmit Descriptor Ring Start Register */
3225
3226 union {
3227 uint32_t R;
3228 struct {
3229 uint32_t:21;
3230 uint32_t R_BUF_SIZE:7;
3231 uint32_t:4;
3232 } B;
3233 } EMRBR; /* Receive Buffer Size Register */
3234
3235 uint32_t fec_reserved_emrbr[29];
3236
3237 union {
3238 uint32_t R;
3239 } RMON_T_DROP; /* Count of frames not counted correctly */
3240
3241 union {
3242 uint32_t R;
3243 } RMON_T_PACKETS; /* RMON Tx packet count */
3244
3245 union {
3246 uint32_t R;
3247 } RMON_T_BC_PKT; /* RMON Tx Broadcast Packets */
3248
3249 union {
3250 uint32_t R;
3251 } RMON_T_MC_PKT; /* RMON Tx Multicast Packets */
3252
3253 union {
3254 uint32_t R;
3255 } RMON_T_CRC_ALIGN; /* RMON Tx Packets w CRC/Align error */
3256
3257 union {
3258 uint32_t R;
3259 } RMON_T_UNDERSIZE; /* RMON Tx Packets < 64 bytes, good crc */
3260
3261 union {
3262 uint32_t R;
3263 } RMON_T_OVERSIZE; /* RMON Tx Packets > MAX_FL bytes, good crc */
3264
3265 union {
3266 uint32_t R;
3267 } RMON_T_FRAG; /* RMON Tx Packets < 64 bytes, bad crc */
3268
3269 union {
3270 uint32_t R;
3271 } RMON_T_JAB; /* RMON Tx Packets > MAX_FL bytes, bad crc */
3272
3273 union {
3274 uint32_t R;
3275 } RMON_T_COL; /* RMON Tx collision count */
3276
3277 union {
3278 uint32_t R;
3279 } RMON_T_P64; /* RMON Tx 64 byte packets */
3280
3281 union {
3282 uint32_t R;
3283 } RMON_T_P65TO127; /* RMON Tx 65 to 127 byte packets */
3284
3285 union {
3286 uint32_t R;
3287 } RMON_T_P128TO255; /* RMON Tx 128 to 255 byte packets */
3288
3289 union {
3290 uint32_t R;
3291 } RMON_T_P256TO511; /* RMON Tx 256 to 511 byte packets */
3292
3293 union {
3294 uint32_t R;
3295 } RMON_T_P512TO1023; /* RMON Tx 512 to 1023 byte packets */
3296
3297 union {
3298 uint32_t R;
3299 } RMON_T_P1024TO2047; /* RMON Tx 1024 to 2047 byte packets */
3300
3301 union {
3302 uint32_t R;
3303 } RMON_T_P_GTE2048; /* RMON Tx packets w > 2048 bytes */
3304
3305 union {
3306 uint32_t R;
3307 } RMON_T_OCTETS; /* RMON Tx Octets */
3308
3309 union {
3310 uint32_t R;
3311 } IEEE_T_DROP; /* Count of frames not counted correctly */
3312
3313 union {
3314 uint32_t R;
3315 } IEEE_T_FRAME_OK; /* Frames Transmitted OK */
3316
3317 union {
3318 uint32_t R;
3319 } IEEE_T_1COL; /* Frames Transmitted with Single Collision */
3320
3321 union {
3322 uint32_t R;
3323 } IEEE_T_MCOL; /* Frames Transmitted with Multiple Collisions */
3324
3325 union {
3326 uint32_t R;
3327 } IEEE_T_DEF; /* Frames Transmitted after Deferral Delay */
3328
3329 union {
3330 uint32_t R;
3331 } IEEE_T_LCOL; /* Frames Transmitted with Late Collision */
3332
3333 union {
3334 uint32_t R;
3335 } IEEE_T_EXCOL; /* Frames Transmitted with Excessive Collisions */
3336
3337 union {
3338 uint32_t R;
3339 } IEEE_T_MACERR; /* Frames Transmitted with Tx FIFO Underrun */
3340
3341 union {
3342 uint32_t R;
3343 } IEEE_T_CSERR; /* Frames Transmitted with Carrier Sense Error */
3344
3345 union {
3346 uint32_t R;
3347 } IEEE_T_SQE; /* Frames Transmitted with SQE Error */
3348
3349 union {
3350 uint32_t R;
3351 } IEEE_T_FDXFC; /* Flow Control Pause frames transmitted */
3352
3353 union {
3354 uint32_t R;
3355 } IEEE_T_OCTETS_OK; /* Octet count for Frames Transmitted w/o Error */
3356
3357 uint32_t fec_reserved_rmon_t_octets_ok[2];
3358
3359 union {
3360 uint32_t R;
3361 } RMON_R_DROP; /* Count of frames not counted correctly */
3362
3363 union {
3364 uint32_t R;
3365 } RMON_R_PACKETS; /* RMON Rx packet count */
3366
3367 union {
3368 uint32_t R;
3369 } RMON_R_BC_PKT; /* RMON Rx Broadcast Packets */
3370
3371 union {
3372 uint32_t R;
3373 } RMON_R_MC_PKT; /* RMON Rx Multicast Packets */
3374
3375 union {
3376 uint32_t R;
3377 } RMON_R_CRC_ALIGN; /* RMON Rx Packets w CRC/Align error */
3378
3379 union {
3380 uint32_t R;
3381 } RMON_R_UNDERSIZE; /* RMON Rx Packets < 64 bytes, good crc */
3382
3383 union {
3384 uint32_t R;
3385 } RMON_R_OVERSIZE; /* RMON Rx Packets > MAX_FL bytes, good crc */
3386
3387 union {
3388 uint32_t R;
3389 } RMON_R_FRAG; /* RMON Rx Packets < 64 bytes, bad crc */
3390
3391 union {
3392 uint32_t R;
3393 } RMON_R_JAB; /* RMON Rx Packets > MAX_FL bytes, bad crc */
3394
3395 uint32_t fec_reserved_rmon_r_jab;
3396
3397 union {
3398 uint32_t R;
3399 } RMON_R_P64; /* RMON Rx 64 byte packets */
3400
3401 union {
3402 uint32_t R;
3403 } RMON_R_P65TO127; /* RMON Rx 65 to 127 byte packets */
3404
3405 union {
3406 uint32_t R;
3407 } RMON_R_P128TO255; /* RMON Rx 128 to 255 byte packets */
3408
3409 union {
3410 uint32_t R;
3411 } RMON_R_P256TO511; /* RMON Rx 256 to 511 byte packets */
3412
3413 union {
3414 uint32_t R;
3415 } RMON_R_P512TO1023; /* RMON Rx 512 to 1023 byte packets */
3416
3417 union {
3418 uint32_t R;
3419 } RMON_R_P1024TO2047; /* RMON Rx 1024 to 2047 byte packets */
3420
3421 union {
3422 uint32_t R;
3423 } RMON_R_P_GTE2048; /* RMON Rx packets w > 2048 bytes */
3424
3425 union {
3426 uint32_t R;
3427 } RMON_R_OCTETS; /* RMON Rx Octets */
3428
3429 union {
3430 uint32_t R;
3431 } IEEE_R_DROP; /* Count of frames not counted correctly */
3432
3433 union {
3434 uint32_t R;
3435 } IEEE_R_FRAME_OK; /* Frames Received OK */
3436
3437 union {
3438 uint32_t R;
3439 } IEEE_R_CRC; /* Frames Received with CRC Error */
3440
3441 union {
3442 uint32_t R;
3443 } IEEE_R_ALIGN; /* Frames Received with Alignment Error */
3444
3445 union {
3446 uint32_t R;
3447 } IEEE_R_MACERR; /* Receive Fifo Overflow count */
3448
3449 union {
3450 uint32_t R;
3451 } IEEE_R_FDXFC; /* Flow Control Pause frames received */
3452
3453 union {
3454 uint32_t R;
3455 } IEEE_R_OCTETS_OK; /* Octet count for Frames Rcvd w/o Error */
3456
3457 };
3458/****************************************************************************/
3459/* MODULE : FlexRay */
3460/****************************************************************************/
3461
3462 typedef union uMVR {
3463 uint16_t R;
3464 struct {
3465 uint16_t CHIVER:8; /* CHI Version Number */
3466 uint16_t PEVER:8; /* PE Version Number */
3467 } B;
3468 } MVR_t;
3469
3470 typedef union uMCR {
3471 uint16_t R;
3472 struct {
3473 uint16_t MEN:1; /* module enable */
3474 uint16_t:1;
3475 uint16_t SCMD:1; /* single channel mode */
3476 uint16_t CHB:1; /* channel B enable */
3477 uint16_t CHA:1; /* channel A enable */
3478 uint16_t SFFE:1; /* synchronization frame filter enable */
3479 uint16_t:5;
3480 uint16_t CLKSEL:1; /* protocol engine clock source select */
3481 uint16_t PRESCALE:3; /* protocol engine clock prescaler */
3482 uint16_t:1;
3483 } B;
3484 } MCR_t;
3485 typedef union uSTBSCR {
3486 uint16_t R;
3487 struct {
3488 uint16_t WMD:1; /* write mode */
3489 uint16_t STBSSEL:7; /* strobe signal select */
3490 uint16_t:3;
3491 uint16_t ENB:1; /* strobe signal enable */
3492 uint16_t:2;
3493 uint16_t STBPSEL:2; /* strobe port select */
3494 } B;
3495 } STBSCR_t;
3496 typedef union uSTBPCR {
3497 uint16_t R;
3498 struct {
3499 uint16_t:12;
3500 uint16_t STB3EN:1; /* strobe port enable */
3501 uint16_t STB2EN:1; /* strobe port enable */
3502 uint16_t STB1EN:1; /* strobe port enable */
3503 uint16_t STB0EN:1; /* strobe port enable */
3504 } B;
3505 } STBPCR_t;
3506
3507 typedef union uMBDSR {
3508 uint16_t R;
3509 struct {
3510 uint16_t:1;
3511 uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
3512 uint16_t:1;
3513 uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
3514 } B;
3515 } MBDSR_t;
3516 typedef union uMBSSUTR {
3517 uint16_t R;
3518 struct {
3519
3520 uint16_t:1;
3521 uint16_t LAST_MB_SEG1:7; /* last message buffer control register for message buffer segment 1 */
3522 uint16_t:1;
3523 uint16_t LAST_MB_UTIL:7; /* last message buffer utilized */
3524 } B;
3525 } MBSSUTR_t;
3526
3527 typedef union uPOCR {
3528 uint16_t R;
3529 uint8_t byte[2];
3530 struct {
3531 uint16_t WME:1; /* write mode external correction command */
3532 uint16_t:3;
3533 uint16_t EOC_AP:2; /* external offset correction application */
3534 uint16_t ERC_AP:2; /* external rate correction application */
3535 uint16_t BSY:1; /* command write busy / write mode command */
3536 uint16_t:3;
3537 uint16_t POCCMD:4; /* protocol command */
3538 } B;
3539 } POCR_t;
3540/* protocol commands */
3541 typedef union uGIFER {
3542 uint16_t R;
3543 struct {
3544 uint16_t MIF:1; /* module interrupt flag */
3545 uint16_t PRIF:1; /* protocol interrupt flag */
3546 uint16_t CHIF:1; /* CHI interrupt flag */
3547 uint16_t WKUPIF:1; /* wakeup interrupt flag */
3548 uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
3549 uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
3550 uint16_t RBIF:1; /* receive message buffer interrupt flag */
3551 uint16_t TBIF:1; /* transmit buffer interrupt flag */
3552 uint16_t MIE:1; /* module interrupt enable */
3553 uint16_t PRIE:1; /* protocol interrupt enable */
3554 uint16_t CHIE:1; /* CHI interrupt enable */
3555 uint16_t WKUPIE:1; /* wakeup interrupt enable */
3556 uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
3557 uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
3558 uint16_t RBIE:1; /* receive message buffer interrupt enable */
3559 uint16_t TBIE:1; /* transmit buffer interrupt enable */
3560 } B;
3561 } GIFER_t;
3562 typedef union uPIFR0 {
3563 uint16_t R;
3564 struct {
3565 uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
3566 uint16_t INTLIF:1; /* internal protocol error interrupt flag */
3567 uint16_t ILCFIF:1; /* illegal protocol configuration flag */
3568 uint16_t CSAIF:1; /* cold start abort interrupt flag */
3569 uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
3570 uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
3571 uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
3572 uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
3573 uint16_t MTXIF:1; /* media access test symbol received flag */
3574 uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
3575 uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
3576 uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
3577 uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
3578 uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
3579 uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
3580 uint16_t CYSIF:1; /* cycle start interrupt flag */
3581 } B;
3582 } PIFR0_t;
3583 typedef union uPIFR1 {
3584 uint16_t R;
3585 struct {
3586 uint16_t EMCIF:1; /* error mode changed interrupt flag */
3587 uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
3588 uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
3589 uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
3590 uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
3591 uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
3592 uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
3593 uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
3594 uint16_t:2;
3595 uint16_t EVTIF:1; /* even cycle table written interrupt flag */
3596 uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
3597 uint16_t:4;
3598 } B;
3599 } PIFR1_t;
3600 typedef union uPIER0 {
3601 uint16_t R;
3602 struct {
3603 uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
3604 uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
3605 uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
3606 uint16_t CSAIE:1; /* cold start abort interrupt enable */
3607 uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
3608 uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
3609 uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
3610 uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
3611 uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
3612 uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
3613 uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
3614 uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
3615 uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
3616 uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
3617 uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
3618 uint16_t CYSIE:1; /* cycle start interrupt enable */
3619 } B;
3620 } PIER0_t;
3621 typedef union uPIER1 {
3622 uint16_t R;
3623 struct {
3624 uint16_t EMCIE:1; /* error mode changed interrupt enable */
3625 uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
3626 uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
3627 uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
3628 uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
3629 uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
3630 uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
3631 uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
3632 uint16_t:2;
3633 uint16_t EVTIE:1; /* even cycle table written interrupt enable */
3634 uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
3635 uint16_t:4;
3636 } B;
3637 } PIER1_t;
3638 typedef union uCHIERFR {
3639 uint16_t R;
3640 struct {
3641 uint16_t FRLBEF:1; /* flame lost channel B error flag */
3642 uint16_t FRLAEF:1; /* frame lost channel A error flag */
3643 uint16_t PCMIEF:1; /* command ignored error flag */
3644 uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
3645 uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
3646 uint16_t MSBEF:1; /* message buffer search error flag */
3647 uint16_t MBUEF:1; /* message buffer utilization error flag */
3648 uint16_t LCKEF:1; /* lock error flag */
3649 uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
3650 uint16_t SBCFEF:1; /* system bus communication failure error flag */
3651 uint16_t FIDEF:1; /* frame ID error flag */
3652 uint16_t DPLEF:1; /* dynamic payload length error flag */
3653 uint16_t SPLEF:1; /* static payload length error flag */
3654 uint16_t NMLEF:1; /* network management length error flag */
3655 uint16_t NMFEF:1; /* network management frame error flag */
3656 uint16_t ILSAEF:1; /* illegal access error flag */
3657 } B;
3658 } CHIERFR_t;
3659 typedef union uMBIVEC {
3660 uint16_t R;
3661 struct {
3662
3663 uint16_t:1;
3664 uint16_t TBIVEC:7; /* transmit buffer interrupt vector */
3665 uint16_t:1;
3666 uint16_t RBIVEC:7; /* receive buffer interrupt vector */
3667 } B;
3668 } MBIVEC_t;
3669
3670 typedef union uPSR0 {
3671 uint16_t R;
3672 struct {
3673 uint16_t ERRMODE:2; /* error mode */
3674 uint16_t SLOTMODE:2; /* slot mode */
3675 uint16_t:1;
3676 uint16_t PROTSTATE:3; /* protocol state */
3677 uint16_t SUBSTATE:4; /* protocol sub state */
3678 uint16_t:1;
3679 uint16_t WAKEUPSTATUS:3; /* wakeup status */
3680 } B;
3681 } PSR0_t;
3682
3683/* protocol states */
3684/* protocol sub-states */
3685/* wakeup status */
3686 typedef union uPSR1 {
3687 uint16_t R;
3688 struct {
3689 uint16_t CSAA:1; /* cold start attempt abort flag */
3690 uint16_t SCP:1; /* cold start path */
3691 uint16_t:1;
3692 uint16_t REMCSAT:5; /* remanining coldstart attempts */
3693 uint16_t CPN:1; /* cold start noise path */
3694 uint16_t HHR:1; /* host halt request pending */
3695 uint16_t FRZ:1; /* freeze occured */
3696 uint16_t APTAC:5; /* allow passive to active counter */
3697 } B;
3698 } PSR1_t;
3699 typedef union uPSR2 {
3700 uint16_t R;
3701 struct {
3702 uint16_t NBVB:1; /* NIT boundary violation on channel B */
3703 uint16_t NSEB:1; /* NIT syntax error on channel B */
3704 uint16_t STCB:1; /* symbol window transmit conflict on channel B */
3705 uint16_t SBVB:1; /* symbol window boundary violation on channel B */
3706 uint16_t SSEB:1; /* symbol window syntax error on channel B */
3707 uint16_t MTB:1; /* media access test symbol MTS received on channel B */
3708 uint16_t NBVA:1; /* NIT boundary violation on channel A */
3709 uint16_t NSEA:1; /* NIT syntax error on channel A */
3710 uint16_t STCA:1; /* symbol window transmit conflict on channel A */
3711 uint16_t SBVA:1; /* symbol window boundary violation on channel A */
3712 uint16_t SSEA:1; /* symbol window syntax error on channel A */
3713 uint16_t MTA:1; /* media access test symbol MTS received on channel A */
3714 uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
3715 } B;
3716 } PSR2_t;
3717 typedef union uPSR3 {
3718 uint16_t R;
3719 struct {
3720 uint16_t:2;
3721 uint16_t WUB:1; /* wakeup symbol received on channel B */
3722 uint16_t ABVB:1; /* aggregated boundary violation on channel B */
3723 uint16_t AACB:1; /* aggregated additional communication on channel B */
3724 uint16_t ACEB:1; /* aggregated content error on channel B */
3725 uint16_t ASEB:1; /* aggregated syntax error on channel B */
3726 uint16_t AVFB:1; /* aggregated valid frame on channel B */
3727 uint16_t:2;
3728 uint16_t WUA:1; /* wakeup symbol received on channel A */
3729 uint16_t ABVA:1; /* aggregated boundary violation on channel A */
3730 uint16_t AACA:1; /* aggregated additional communication on channel A */
3731 uint16_t ACEA:1; /* aggregated content error on channel A */
3732 uint16_t ASEA:1; /* aggregated syntax error on channel A */
3733 uint16_t AVFA:1; /* aggregated valid frame on channel A */
3734 } B;
3735 } PSR3_t;
3736 typedef union uCIFRR {
3737 uint16_t R;
3738 struct {
3739 uint16_t:8;
3740 uint16_t MIFR:1; /* module interrupt flag */
3741 uint16_t PRIFR:1; /* protocol interrupt flag */
3742 uint16_t CHIFR:1; /* CHI interrupt flag */
3743 uint16_t WUPIFR:1; /* wakeup interrupt flag */
3744 uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
3745 uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
3746 uint16_t RBIFR:1; /* receive message buffer interrupt flag */
3747 uint16_t TBIFR:1; /* transmit buffer interrupt flag */
3748 } B;
3749 } CIFRR_t;
3750 typedef union uSFCNTR {
3751 uint16_t R;
3752 struct {
3753 uint16_t SFEVB:4; /* sync frames channel B, even cycle */
3754 uint16_t SFEVA:4; /* sync frames channel A, even cycle */
3755 uint16_t SFODB:4; /* sync frames channel B, odd cycle */
3756 uint16_t SFODA:4; /* sync frames channel A, odd cycle */
3757 } B;
3758 } SFCNTR_t;
3759
3760 typedef union uSFTCCSR {
3761 uint16_t R;
3762 struct {
3763 uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
3764 uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
3765 uint16_t CYCNUM:6; /* cycle number */
3766 uint16_t ELKS:1; /* even cycle tables lock status */
3767 uint16_t OLKS:1; /* odd cycle tables lock status */
3768 uint16_t EVAL:1; /* even cycle tables valid */
3769 uint16_t OVAL:1; /* odd cycle tables valid */
3770 uint16_t:1;
3771 uint16_t OPT:1; /*one pair trigger */
3772 uint16_t SDVEN:1; /* sync frame deviation table enable */
3773 uint16_t SIDEN:1; /* sync frame ID table enable */
3774 } B;
3775 } SFTCCSR_t;
3776 typedef union uSFIDRFR {
3777 uint16_t R;
3778 struct {
3779 uint16_t:6;
3780 uint16_t SYNFRID:10; /* sync frame rejection ID */
3781 } B;
3782 } SFIDRFR_t;
3783
3784 typedef union uTICCR {
3785 uint16_t R;
3786 struct {
3787 uint16_t:2;
3788 uint16_t T2CFG:1; /* timer 2 configuration */
3789 uint16_t T2REP:1; /* timer 2 repetitive mode */
3790 uint16_t:1;
3791 uint16_t T2SP:1; /* timer 2 stop */
3792 uint16_t T2TR:1; /* timer 2 trigger */
3793 uint16_t T2ST:1; /* timer 2 state */
3794 uint16_t:3;
3795 uint16_t T1REP:1; /* timer 1 repetitive mode */
3796 uint16_t:1;
3797 uint16_t T1SP:1; /* timer 1 stop */
3798 uint16_t T1TR:1; /* timer 1 trigger */
3799 uint16_t T1ST:1; /* timer 1 state */
3800
3801 } B;
3802 } TICCR_t;
3803 typedef union uTI1CYSR {
3804 uint16_t R;
3805 struct {
3806 uint16_t:2;
3807 uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
3808 uint16_t:2;
3809 uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
3810
3811 } B;
3812 } TI1CYSR_t;
3813
3814 typedef union uSSSR {
3815 uint16_t R;
3816 struct {
3817 uint16_t WMD:1; /* write mode */
3818 uint16_t:1;
3819 uint16_t SEL:2; /* static slot number */
3820 uint16_t:1;
3821 uint16_t SLOTNUMBER:11; /* selector */
3822 } B;
3823 } SSSR_t;
3824
3825 typedef union uSSCCR {
3826 uint16_t R;
3827 struct {
3828 uint16_t WMD:1; /* write mode */
3829 uint16_t:1;
3830 uint16_t SEL:2; /* selector */
3831 uint16_t:1;
3832 uint16_t CNTCFG:2; /* counter configuration */
3833 uint16_t MCY:1; /* multi cycle selection */
3834 uint16_t VFR:1; /* valid frame selection */
3835 uint16_t SYF:1; /* sync frame selection */
3836 uint16_t NUF:1; /* null frame selection */
3837 uint16_t SUF:1; /* startup frame selection */
3838 uint16_t STATUSMASK:4; /* slot status mask */
3839 } B;
3840 } SSCCR_t;
3841 typedef union uSSR {
3842 uint16_t R;
3843 struct {
3844 uint16_t VFB:1; /* valid frame on channel B */
3845 uint16_t SYB:1; /* valid sync frame on channel B */
3846 uint16_t NFB:1; /* valid null frame on channel B */
3847 uint16_t SUB:1; /* valid startup frame on channel B */
3848 uint16_t SEB:1; /* syntax error on channel B */
3849 uint16_t CEB:1; /* content error on channel B */
3850 uint16_t BVB:1; /* boundary violation on channel B */
3851 uint16_t TCB:1; /* tx conflict on channel B */
3852 uint16_t VFA:1; /* valid frame on channel A */
3853 uint16_t SYA:1; /* valid sync frame on channel A */
3854 uint16_t NFA:1; /* valid null frame on channel A */
3855 uint16_t SUA:1; /* valid startup frame on channel A */
3856 uint16_t SEA:1; /* syntax error on channel A */
3857 uint16_t CEA:1; /* content error on channel A */
3858 uint16_t BVA:1; /* boundary violation on channel A */
3859 uint16_t TCA:1; /* tx conflict on channel A */
3860 } B;
3861 } SSR_t;
3862 typedef union uMTSCFR {
3863 uint16_t R;
3864 struct {
3865 uint16_t MTE:1; /* media access test symbol transmission enable */
3866 uint16_t:1;
3867 uint16_t CYCCNTMSK:6; /* cycle counter mask */
3868 uint16_t:2;
3869 uint16_t CYCCNTVAL:6; /* cycle counter value */
3870 } B;
3871 } MTSCFR_t;
3872 typedef union uRSBIR {
3873 uint16_t R;
3874 struct {
3875 uint16_t WMD:1; /* write mode */
3876 uint16_t:1;
3877 uint16_t SEL:2; /* selector */
3878 uint16_t:4;
3879 uint16_t RSBIDX:8; /* receive shadow buffer index */
3880 } B;
3881 } RSBIR_t;
3882 typedef union uRFDSR {
3883 uint16_t R;
3884 struct {
3885 uint16_t FIFODEPTH:8; /* fifo depth */
3886 uint16_t:1;
3887 uint16_t ENTRYSIZE:7; /* entry size */
3888 } B;
3889 } RFDSR_t;
3890
3891 typedef union uRFRFCFR {
3892 uint16_t R;
3893 struct {
3894 uint16_t WMD:1; /* write mode */
3895 uint16_t IBD:1; /* interval boundary */
3896 uint16_t SEL:2; /* filter number */
3897 uint16_t:1;
3898 uint16_t SID:11; /* slot ID */
3899 } B;
3900 } RFRFCFR_t;
3901
3902 typedef union uRFRFCTR {
3903 uint16_t R;
3904 struct {
3905 uint16_t:4;
3906 uint16_t F3MD:1; /* filter mode */
3907 uint16_t F2MD:1; /* filter mode */
3908 uint16_t F1MD:1; /* filter mode */
3909 uint16_t F0MD:1; /* filter mode */
3910 uint16_t:4;
3911 uint16_t F3EN:1; /* filter enable */
3912 uint16_t F2EN:1; /* filter enable */
3913 uint16_t F1EN:1; /* filter enable */
3914 uint16_t F0EN:1; /* filter enable */
3915 } B;
3916 } RFRFCTR_t;
3917 typedef union uPCR0 {
3918 uint16_t R;
3919 struct {
3920 uint16_t ACTION_POINT_OFFSET:6;
3921 uint16_t STATIC_SLOT_LENGTH:10;
3922 } B;
3923 } PCR0_t;
3924
3925 typedef union uPCR1 {
3926 uint16_t R;
3927 struct {
3928 uint16_t:2;
3929 uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
3930 } B;
3931 } PCR1_t;
3932
3933 typedef union uPCR2 {
3934 uint16_t R;
3935 struct {
3936 uint16_t MINISLOT_AFTER_ACTION_POINT:6;
3937 uint16_t NUMBER_OF_STATIC_SLOTS:10;
3938 } B;
3939 } PCR2_t;
3940
3941 typedef union uPCR3 {
3942 uint16_t R;
3943 struct {
3944 uint16_t WAKEUP_SYMBOL_RX_LOW:6;
3945 uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
3946 uint16_t COLDSTART_ATTEMPTS:5;
3947 } B;
3948 } PCR3_t;
3949
3950 typedef union uPCR4 {
3951 uint16_t R;
3952 struct {
3953 uint16_t CAS_RX_LOW_MAX:7;
3954 uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
3955 } B;
3956 } PCR4_t;
3957
3958 typedef union uPCR5 {
3959 uint16_t R;
3960 struct {
3961 uint16_t TSS_TRANSMITTER:4;
3962 uint16_t WAKEUP_SYMBOL_TX_LOW:6;
3963 uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
3964 } B;
3965 } PCR5_t;
3966
3967 typedef union uPCR6 {
3968 uint16_t R;
3969 struct {
3970 uint16_t:1;
3971 uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
3972 uint16_t MACRO_INITIAL_OFFSET_A:7;
3973 } B;
3974 } PCR6_t;
3975
3976 typedef union uPCR7 {
3977 uint16_t R;
3978 struct {
3979 uint16_t DECODING_CORRECTION_B:9;
3980 uint16_t MICRO_PER_MACRO_NOM_HALF:7;
3981 } B;
3982 } PCR7_t;
3983
3984 typedef union uPCR8 {
3985 uint16_t R;
3986 struct {
3987 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
3988 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
3989 uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
3990 } B;
3991 } PCR8_t;
3992
3993 typedef union uPCR9 {
3994 uint16_t R;
3995 struct {
3996 uint16_t MINISLOT_EXISTS:1;
3997 uint16_t SYMBOL_WINDOW_EXISTS:1;
3998 uint16_t OFFSET_CORRECTION_OUT:14;
3999 } B;
4000 } PCR9_t;
4001
4002 typedef union uPCR10 {
4003 uint16_t R;
4004 struct {
4005 uint16_t SINGLE_SLOT_ENABLED:1;
4006 uint16_t WAKEUP_CHANNEL:1;
4007 uint16_t MACRO_PER_CYCLE:14;
4008 } B;
4009 } PCR10_t;
4010
4011 typedef union uPCR11 {
4012 uint16_t R;
4013 struct {
4014 uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
4015 uint16_t KEY_SLOT_USED_FOR_SYNC:1;
4016 uint16_t OFFSET_CORRECTION_START:14;
4017 } B;
4018 } PCR11_t;
4019
4020 typedef union uPCR12 {
4021 uint16_t R;
4022 struct {
4023 uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
4024 uint16_t KEY_SLOT_HEADER_CRC:11;
4025 } B;
4026 } PCR12_t;
4027
4028 typedef union uPCR13 {
4029 uint16_t R;
4030 struct {
4031 uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
4032 uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
4033 } B;
4034 } PCR13_t;
4035
4036 typedef union uPCR14 {
4037 uint16_t R;
4038 struct {
4039 uint16_t RATE_CORRECTION_OUT:11;
4040 uint16_t LISTEN_TIMEOUT_H:5;
4041 } B;
4042 } PCR14_t;
4043
4044 typedef union uPCR15 {
4045 uint16_t R;
4046 struct {
4047 uint16_t LISTEN_TIMEOUT_L:16;
4048 } B;
4049 } PCR15_t;
4050
4051 typedef union uPCR16 {
4052 uint16_t R;
4053 struct {
4054 uint16_t MACRO_INITIAL_OFFSET_B:7;
4055 uint16_t NOISE_LISTEN_TIMEOUT_H:9;
4056 } B;
4057 } PCR16_t;
4058
4059 typedef union uPCR17 {
4060 uint16_t R;
4061 struct {
4062 uint16_t NOISE_LISTEN_TIMEOUT_L:16;
4063 } B;
4064 } PCR17_t;
4065
4066 typedef union uPCR18 {
4067 uint16_t R;
4068 struct {
4069 uint16_t WAKEUP_PATTERN:6;
4070 uint16_t KEY_SLOT_ID:10;
4071 } B;
4072 } PCR18_t;
4073
4074 typedef union uPCR19 {
4075 uint16_t R;
4076 struct {
4077 uint16_t DECODING_CORRECTION_A:9;
4078 uint16_t PAYLOAD_LENGTH_STATIC:7;
4079 } B;
4080 } PCR19_t;
4081
4082 typedef union uPCR20 {
4083 uint16_t R;
4084 struct {
4085 uint16_t MICRO_INITIAL_OFFSET_B:8;
4086 uint16_t MICRO_INITIAL_OFFSET_A:8;
4087 } B;
4088 } PCR20_t;
4089
4090 typedef union uPCR21 {
4091 uint16_t R;
4092 struct {
4093 uint16_t EXTERN_RATE_CORRECTION:3;
4094 uint16_t LATEST_TX:13;
4095 } B;
4096 } PCR21_t;
4097
4098 typedef union uPCR22 {
4099 uint16_t R;
4100 struct {
4101 uint16_t:1;
4102 uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
4103 uint16_t MICRO_PER_CYCLE_H:4;
4104 } B;
4105 } PCR22_t;
4106
4107 typedef union uPCR23 {
4108 uint16_t R;
4109 struct {
4110 uint16_t micro_per_cycle_l:16;
4111 } B;
4112 } PCR23_t;
4113
4114 typedef union uPCR24 {
4115 uint16_t R;
4116 struct {
4117 uint16_t CLUSTER_DRIFT_DAMPING:5;
4118 uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
4119 uint16_t MICRO_PER_CYCLE_MIN_H:4;
4120 } B;
4121 } PCR24_t;
4122
4123 typedef union uPCR25 {
4124 uint16_t R;
4125 struct {
4126 uint16_t MICRO_PER_CYCLE_MIN_L:16;
4127 } B;
4128 } PCR25_t;
4129
4130 typedef union uPCR26 {
4131 uint16_t R;
4132 struct {
4133 uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
4134 uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
4135 uint16_t MICRO_PER_CYCLE_MAX_H:4;
4136 } B;
4137 } PCR26_t;
4138
4139 typedef union uPCR27 {
4140 uint16_t R;
4141 struct {
4142 uint16_t MICRO_PER_CYCLE_MAX_L:16;
4143 } B;
4144 } PCR27_t;
4145
4146 typedef union uPCR28 {
4147 uint16_t R;
4148 struct {
4149 uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
4150 uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
4151 } B;
4152 } PCR28_t;
4153
4154 typedef union uPCR29 {
4155 uint16_t R;
4156 struct {
4157 uint16_t EXTERN_OFFSET_CORRECTION:3;
4158 uint16_t MINISLOTS_MAX:13;
4159 } B;
4160 } PCR29_t;
4161
4162 typedef union uPCR30 {
4163 uint16_t R;
4164 struct {
4165 uint16_t:12;
4166 uint16_t SYNC_NODE_MAX:4;
4167 } B;
4168 } PCR30_t;
4169
4170 typedef struct uMSG_BUFF_CCS {
4171 union {
4172 uint16_t R;
4173 struct {
4174 uint16_t:1;
4175 uint16_t MCM:1; /* message buffer commit mode */
4176 uint16_t MBT:1; /* message buffer type */
4177 uint16_t MTD:1; /* message buffer direction */
4178 uint16_t CMT:1; /* commit for transmission */
4179 uint16_t EDT:1; /* enable / disable trigger */
4180 uint16_t LCKT:1; /* lock request trigger */
4181 uint16_t MBIE:1; /* message buffer interrupt enable */
4182 uint16_t:3;
4183 uint16_t DUP:1; /* data updated */
4184 uint16_t DVAL:1; /* data valid */
4185 uint16_t EDS:1; /* lock status */
4186 uint16_t LCKS:1; /* enable / disable status */
4187 uint16_t MBIF:1; /* message buffer interrupt flag */
4188 } B;
4189 } MBCCSR;
4190 union {
4191 uint16_t R;
4192 struct {
4193 uint16_t MTM:1; /* message buffer transmission mode */
4194 uint16_t CHNLA:1; /* channel assignement */
4195 uint16_t CHNLB:1; /* channel assignement */
4196 uint16_t CCFE:1; /* cycle counter filter enable */
4197 uint16_t CCFMSK:6; /* cycle counter filter mask */
4198 uint16_t CCFVAL:6; /* cycle counter filter value */
4199 } B;
4200 } MBCCFR;
4201 union {
4202 uint16_t R;
4203 struct {
4204 uint16_t:5;
4205 uint16_t FID:11; /* frame ID */
4206 } B;
4207 } MBFIDR;
4208 union {
4209 uint16_t R;
4210 struct {
4211 uint16_t:8;
4212 uint16_t MBIDX:8; /* message buffer index */
4213 } B;
4214 } MBIDXR;
4216 typedef union uSYSBADHR {
4217 uint16_t R;
4218 } SYSBADHR_t;
4219 typedef union uSYSBADLR {
4220 uint16_t R;
4221 } SYSBADLR_t;
4222 typedef union uPDAR {
4223 uint16_t R;
4224 } PDAR_t;
4225 typedef union uCASERCR {
4226 uint16_t R;
4227 } CASERCR_t;
4228 typedef union uCBSERCR {
4229 uint16_t R;
4230 } CBSERCR_t;
4231 typedef union uCYCTR {
4232 uint16_t R;
4233 } CYCTR_t;
4234 typedef union uMTCTR {
4235 uint16_t R;
4236 } MTCTR_t;
4237 typedef union uSLTCTAR {
4238 uint16_t R;
4239 } SLTCTAR_t;
4240 typedef union uSLTCTBR {
4241 uint16_t R;
4242 } SLTCTBR_t;
4243 typedef union uRTCORVR {
4244 uint16_t R;
4245 } RTCORVR_t;
4246 typedef union uOFCORVR {
4247 uint16_t R;
4248 } OFCORVR_t;
4249 typedef union uSFTOR {
4250 uint16_t R;
4251 } SFTOR_t;
4252 typedef union uSFIDAFVR {
4253 uint16_t R;
4254 } SFIDAFVR_t;
4255 typedef union uSFIDAFMR {
4256 uint16_t R;
4257 } SFIDAFMR_t;
4258 typedef union uNMVR {
4259 uint16_t R;
4260 } NMVR_t;
4261 typedef union uNMVLR {
4262 uint16_t R;
4263 } NMVLR_t;
4264 typedef union uT1MTOR {
4265 uint16_t R;
4266 } T1MTOR_t;
4267 typedef union uTI2CR0 {
4268 uint16_t R;
4269 } TI2CR0_t;
4270 typedef union uTI2CR1 {
4271 uint16_t R;
4272 } TI2CR1_t;
4273 typedef union uSSCR {
4274 uint16_t R;
4275 } SSCR_t;
4276 typedef union uRFSR {
4277 uint16_t R;
4278 } RFSR_t;
4279 typedef union uRFSIR {
4280 uint16_t R;
4281 } RFSIR_t;
4282 typedef union uRFARIR {
4283 uint16_t R;
4284 } RFARIR_t;
4285 typedef union uRFBRIR {
4286 uint16_t R;
4287 } RFBRIR_t;
4288 typedef union uRFMIDAFVR {
4289 uint16_t R;
4290 } RFMIDAFVR_t;
4291 typedef union uRFMIAFMR {
4292 uint16_t R;
4293 } RFMIAFMR_t;
4294 typedef union uRFFIDRFVR {
4295 uint16_t R;
4296 } RFFIDRFVR_t;
4297 typedef union uRFFIDRFMR {
4298 uint16_t R;
4299 } RFFIDRFMR_t;
4300 typedef union uLDTXSLAR {
4301 uint16_t R;
4302 } LDTXSLAR_t;
4303 typedef union uLDTXSLBR {
4304 uint16_t R;
4305 } LDTXSLBR_t;
4306
4307 typedef struct FR_tag {
4308 volatile MVR_t MVR; /*module version register *//*0 */
4309 volatile MCR_t MCR; /*module configuration register *//*2 */
4310 volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
4311 volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
4312 volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
4313 volatile STBPCR_t STBPCR; /*strobe port control register *//*A */
4314 volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
4315 volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
4316 uint16_t reserved3a[1]; /*10 */
4317 volatile PDAR_t PDAR; /*PE data register *//*12 */
4318 volatile POCR_t POCR; /*Protocol operation control register *//*14 */
4319 volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
4320 volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
4321 volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
4322 volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
4323 volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
4324 volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
4325 volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
4326 volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
4327 volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
4328 volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
4329 volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
4330 volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
4331 volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
4332 volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
4333 volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
4334 volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
4335 volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
4336 volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
4337 volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
4338 volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
4339 uint16_t reserved3[1]; /*3E */
4340 volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
4341 volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
4342 volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
4343 volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
4344 volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
4345 volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
4346 volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
4347 volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
4348 volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
4349 volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
4350 volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
4351 volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
4352 volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
4353 volatile SSSR_t SSSR; /*slot status selection register *//*64 */
4354 volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
4355 volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
4356 volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
4357 volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
4358 volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
4359 volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
4360 volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
4361 volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
4362 volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
4363 volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
4364 volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
4365 volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
4366 volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
4367 volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
4368 volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
4369 volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
4370 volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
4371 volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
4372 volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
4373 volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
4374 volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
4375 volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
4376 volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
4377 volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
4378 volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
4379 volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
4380 volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
4381 volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
4382 volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
4383 volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
4384 volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
4385 volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
4386 volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
4387 volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
4388 volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
4389 volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
4390 volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
4391 volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
4392 volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
4393 volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
4394 volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
4395 volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
4396 volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
4397 volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
4398 volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
4399 volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
4400 volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
4401 volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
4402 volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
4403 volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
4404 uint16_t reserved2[17];
4405 volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
4406 } FR_tag_t;
4407
4408 typedef union uF_HEADER /* frame header */
4409 {
4410 struct {
4411 uint16_t:5;
4412 uint16_t HDCRC:11; /* Header CRC */
4413 uint16_t:2;
4414 uint16_t CYCCNT:6; /* Cycle Count */
4415 uint16_t:1;
4416 uint16_t PLDLEN:7; /* Payload Length */
4417 uint16_t:1;
4418 uint16_t PPI:1; /* Payload Preamble Indicator */
4419 uint16_t NUF:1; /* Null Frame Indicator */
4420 uint16_t SYF:1; /* Sync Frame Indicator */
4421 uint16_t SUF:1; /* Startup Frame Indicator */
4422 uint16_t FID:11; /* Frame ID */
4423 } B;
4424 uint16_t WORDS[3];
4425 } F_HEADER_t;
4426 typedef union uS_STSTUS /* slot status */
4427 {
4428 struct {
4429 uint16_t VFB:1; /* Valid Frame on channel B */
4430 uint16_t SYB:1; /* Sync Frame Indicator channel B */
4431 uint16_t NFB:1; /* Null Frame Indicator channel B */
4432 uint16_t SUB:1; /* Startup Frame Indicator channel B */
4433 uint16_t SEB:1; /* Syntax Error on channel B */
4434 uint16_t CEB:1; /* Content Error on channel B */
4435 uint16_t BVB:1; /* Boundary Violation on channel B */
4436 uint16_t CH:1; /* Channel */
4437 uint16_t VFA:1; /* Valid Frame on channel A */
4438 uint16_t SYA:1; /* Sync Frame Indicator channel A */
4439 uint16_t NFA:1; /* Null Frame Indicator channel A */
4440 uint16_t SUA:1; /* Startup Frame Indicator channel A */
4441 uint16_t SEA:1; /* Syntax Error on channel A */
4442 uint16_t CEA:1; /* Content Error on channel A */
4443 uint16_t BVA:1; /* Boundary Violation on channel A */
4444 uint16_t:1;
4445 } RX;
4446 struct {
4447 uint16_t VFB:1; /* Valid Frame on channel B */
4448 uint16_t SYB:1; /* Sync Frame Indicator channel B */
4449 uint16_t NFB:1; /* Null Frame Indicator channel B */
4450 uint16_t SUB:1; /* Startup Frame Indicator channel B */
4451 uint16_t SEB:1; /* Syntax Error on channel B */
4452 uint16_t CEB:1; /* Content Error on channel B */
4453 uint16_t BVB:1; /* Boundary Violation on channel B */
4454 uint16_t TCB:1; /* Tx Conflict on channel B */
4455 uint16_t VFA:1; /* Valid Frame on channel A */
4456 uint16_t SYA:1; /* Sync Frame Indicator channel A */
4457 uint16_t NFA:1; /* Null Frame Indicator channel A */
4458 uint16_t SUA:1; /* Startup Frame Indicator channel A */
4459 uint16_t SEA:1; /* Syntax Error on channel A */
4460 uint16_t CEA:1; /* Content Error on channel A */
4461 uint16_t BVA:1; /* Boundary Violation on channel A */
4462 uint16_t TCA:1; /* Tx Conflict on channel A */
4463 } TX;
4464 uint16_t R;
4465 } S_STATUS_t;
4466
4467 typedef struct uMB_HEADER /* message buffer header */
4468 {
4469 F_HEADER_t FRAME_HEADER;
4470 uint16_t DATA_OFFSET;
4471 S_STATUS_t SLOT_STATUS;
4472 } MB_HEADER_t;
4473
4474/* Define memories */
4475
4476#define SRAM_START 0x40000000
4477#define SRAM_SIZE 0x14000
4478#define SRAM_END 0x40013FFF
4479
4480#define FLASH_START 0x0
4481#define FLASH_SIZE 0x200000
4482#define FLASH_END 0x1FFFFF
4483
4484/* Define instances of modules */
4485#define PBRIDGE_A (*(volatile struct PBRIDGE_A_tag *) 0xC3F00000)
4486#define FMPLL (*(volatile struct FMPLL_tag *) 0xC3F80000)
4487#define EBI (*(volatile struct EBI_tag *) 0xC3F84000)
4488#define FLASH (*(volatile struct FLASH_tag *) 0xC3F88000)
4489#define SIU (*(volatile struct SIU_tag *) 0xC3F90000)
4490
4491#define EMIOS (*(volatile struct EMIOS_tag *) 0xC3FA0000)
4492#define ETPU (*(volatile struct ETPU_tag *) 0xC3FC0000)
4493#define ETPU_DATA_RAM (*( uint32_t *) 0xC3FC8000)
4494#define ETPU_DATA_RAM_EXT (*( uint32_t *) 0xC3FCC000)
4495#define ETPU_DATA_RAM_END 0xC3FC89FC
4496#define CODE_RAM (*( uint32_t *) 0xC3FD0000)
4497#define ETPU_CODE_RAM (*( uint32_t *) 0xC3FD0000)
4498
4499#define PBRIDGE_B (*(volatile struct PBRIDGE_B_tag *) 0xFFF00000)
4500#define XBAR (*(volatile struct XBAR_tag *) 0xFFF04000)
4501#define ECSM (*(volatile struct ECSM_tag *) 0xFFF40000)
4502#define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000)
4503#define INTC (*(volatile struct INTC_tag *) 0xFFF48000)
4504
4505#define EQADC (*(volatile struct EQADC_tag *) 0xFFF80000)
4506
4507#define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000)
4508#define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000)
4509#define DSPI_C (*(volatile struct DSPI_tag *) 0xFFF98000)
4510#define DSPI_D (*(volatile struct DSPI_tag *) 0xFFF9C000)
4511
4512#define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFB0000)
4513#define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFB4000)
4514
4515#define CAN_A (*(volatile struct FLEXCAN2_tag *) 0xFFFC0000)
4516#define CAN_B (*(volatile struct FLEXCAN2_tag *) 0xFFFC4000)
4517#define CAN_C (*(volatile struct FLEXCAN2_tag *) 0xFFFC8000)
4518#define CAN_D (*(volatile struct FLEXCAN2_tag *) 0xFFFCC000)
4519#define CAN_E (*(volatile struct FLEXCAN2_tag *) 0xFFFD0000)
4520
4521#define FEC (*(volatile struct FEC_tag *) 0xFFF4C000)
4522
4523#define FR (*(volatile struct FR_tag *) 0xFFFE0000)
4524
4525#ifdef __MWERKS__
4526#pragma pop
4527#endif
4528
4529#ifdef __cplusplus
4530}
4531#endif
4532#endif /* ASM */
4533#endif /* ifdef _MPC5567_H */
4534/*********************************************************************
4535 *
4536 * Copyright:
4537 * Freescale Semiconductor, INC. All Rights Reserved.
4538 * You are hereby granted a copyright license to use, modify, and
4539 * distribute the SOFTWARE so long as this entire notice is
4540 * retained without alteration in any modified and/or redistributed
4541 * versions, and that such modified versions are clearly identified
4542 * as such. No licenses are granted by implication, estoppel or
4543 * otherwise under any patents or trademarks of Freescale
4544 * Semiconductor, Inc. This software is provided on an "AS IS"
4545 * basis and without warranty.
4546 *
4547 * To the maximum extent permitted by applicable law, Freescale
4548 * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
4549 * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
4550 * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
4551 * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
4552 * AND ANY ACCOMPANYING WRITTEN MATERIALS.
4553 *
4554 * To the maximum extent permitted by applicable law, IN NO EVENT
4555 * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
4556 * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
4557 * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
4558 * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
4559 *
4560 * Freescale Semiconductor assumes no responsibility for the
4561 * maintenance and support of this software
4562 *
4563 ********************************************************************/
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc551x.h:479
Definition: fsl-mpc551x.h:447
Definition: fsl-mpc551x.h:483
Definition: fsl-mpc555x.h:2179
Definition: fsl-mpc551x.h:531
Definition: fsl-mpc551x.h:716
Definition: fsl-mpc551x.h:899
Definition: fsl-mpc555x.h:1136
Definition: fsl-mpc556x.h:2982
Definition: fsl-mpc551x.h:1027
Definition: fsl-mpc555x.h:2999
Definition: fsl-mpc551x.h:1484
Definition: fsl-mpc551x.h:3622
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc555x.h:124
Definition: fsl-mpc555x.h:236
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc555x.h:1982
Definition: fsl-mpc551x.h:3783
Definition: fsl-mpc551x.h:3481
Definition: fsl-mpc564xL.h:16586
Definition: fsl-mpc564xL.h:16541
Definition: fsl-mpc564xL.h:16698
Definition: fsl-mpc564xL.h:16678
Definition: fsl-mpc564xL.h:16627
Definition: fsl-mpc564xL.h:16605
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:2939
Definition: fsl-mpc551x.h:3037
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc551x.h:3724
Definition: fsl-mpc551x.h:2842
Definition: fsl-mpc551x.h:3615
Definition: fsl-mpc551x.h:3618
Definition: fsl-mpc551x.h:2807
Definition: fsl-mpc551x.h:2960
Definition: fsl-mpc551x.h:2817
Definition: fsl-mpc551x.h:2781
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3171
Definition: fsl-mpc551x.h:2773
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3228
Definition: fsl-mpc551x.h:3313
Definition: fsl-mpc551x.h:3322
Definition: fsl-mpc551x.h:3331
Definition: fsl-mpc551x.h:3339
Definition: fsl-mpc551x.h:3347
Definition: fsl-mpc551x.h:3355
Definition: fsl-mpc551x.h:3362
Definition: fsl-mpc551x.h:3370
Definition: fsl-mpc551x.h:3377
Definition: fsl-mpc551x.h:3385
Definition: fsl-mpc551x.h:3236
Definition: fsl-mpc551x.h:3393
Definition: fsl-mpc551x.h:3401
Definition: fsl-mpc551x.h:3409
Definition: fsl-mpc551x.h:3418
Definition: fsl-mpc551x.h:3425
Definition: fsl-mpc551x.h:3434
Definition: fsl-mpc551x.h:3441
Definition: fsl-mpc551x.h:3450
Definition: fsl-mpc551x.h:3457
Definition: fsl-mpc551x.h:3465
Definition: fsl-mpc551x.h:3244
Definition: fsl-mpc551x.h:3473
Definition: fsl-mpc551x.h:3252
Definition: fsl-mpc551x.h:3261
Definition: fsl-mpc551x.h:3269
Definition: fsl-mpc551x.h:3278
Definition: fsl-mpc551x.h:3287
Definition: fsl-mpc551x.h:3295
Definition: fsl-mpc551x.h:3304
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2901
Definition: fsl-mpc551x.h:2922
Definition: fsl-mpc551x.h:2863
Definition: fsl-mpc551x.h:2884
Definition: fsl-mpc551x.h:2828
Definition: fsl-mpc551x.h:2971
Definition: fsl-mpc551x.h:2987
Definition: fsl-mpc551x.h:3000
Definition: fsl-mpc551x.h:3018
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:3193
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc551x.h:3202
Definition: fsl-mpc551x.h:3213
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:3182
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3059
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3085
Definition: fsl-mpc551x.h:3069
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3134
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3150
Definition: fsl-mpc551x.h:3123
Definition: fsl-mpc556x.h:3496
Definition: fsl-mpc551x.h:2796
Definition: fsl-mpc551x.h:3528
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:3742
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc551x.h:3112
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:3093
