RTEMS 5.2-rc1
Data Structures | Typedefs | Functions
freechain.h File Reference
Freechain Handler API. More...
struct  Freechain_Control
 The freechain control. More...
typedef void *(* Freechain_Allocator) (size_t size)
 Allocator function.
RTEMS_INLINE_ROUTINE void _Freechain_Initialize (Freechain_Control *freechain, void *initial_nodes, size_t number_nodes, size_t node_size)
 Initializes a freechain. More...
RTEMS_INLINE_ROUTINE bool _Freechain_Is_empty (const Freechain_Control *freechain)
 Return true if the freechain is empty, otherwise false. More...
RTEMS_INLINE_ROUTINE void * _Freechain_Pop (Freechain_Control *freechain)
 Pop an item from the freechain. More...
void * _Freechain_Extend (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size)
 Extend the freechain with new nodes. More...
void * _Freechain_Get (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size)
 Gets a node from the freechain. More...
void _Freechain_Put (Freechain_Control *freechain, void *node)
 Puts a node back onto the freechain. More...
