RTEMS 5.2-rc1
flashdisk.h
1
11/*
12 * Copyright (C) 2007 Chris Johns
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#if !defined (_RTEMS_FLASHDISK_H_)
20#define _RTEMS_FLASHDISK_H_
21
22#include <stdint.h>
23#include <sys/ioctl.h>
24
25#include <rtems.h>
26
27#ifdef __cplusplus
28extern "C" {
29#endif /* __cplusplus */
30
131#define RTEMS_FLASHDISK_DEVICE_BASE_NAME "/dev/fdd"
132
133#define RTEMS_FDISK_IOCTL_ERASE_DISK _IO('B', 128)
134#define RTEMS_FDISK_IOCTL_COMPACT _IO('B', 129)
135#define RTEMS_FDISK_IOCTL_ERASE_USED _IO('B', 130)
136#define RTEMS_FDISK_IOCTL_MONITORING _IO('B', 131)
137#define RTEMS_FDISK_IOCTL_INFO_LEVEL _IO('B', 132)
138#define RTEMS_FDISK_IOCTL_PRINT_STATUS _IO('B', 133)
139
145{
146 uint32_t block_size;
147 uint32_t block_count;
148 uint32_t unavail_blocks;
149 uint32_t device_count;
150 uint32_t segment_count;
151 uint32_t page_count;
152 uint32_t blocks_used;
153 uint32_t segs_available;
154 uint32_t segs_used;
155 uint32_t segs_failed;
156 uint32_t seg_erases;
157 uint32_t pages_desc;
158 uint32_t pages_active;
159 uint32_t pages_used;
160 uint32_t pages_bad;
161 uint32_t info_level;
163
175{
176 uint16_t count;
177 uint16_t segment;
178 uint32_t offset;
179 uint32_t size;
181
185#define RTEMS_FDISK_KBYTES(_k) (UINT32_C(1024) * (_k))
186
191
201{
221 uint32_t device,
222 uint32_t segment,
223 uint32_t offset,
224 void* buffer,
225 uint32_t size);
226
246 uint32_t device,
247 uint32_t segment,
248 uint32_t offset,
249 const void* buffer,
250 uint32_t size);
251
270 uint32_t device,
271 uint32_t segment,
272 uint32_t offset,
273 uint32_t size);
274
294 uint32_t device,
295 uint32_t segment,
296 uint32_t offset,
297 const void* buffer,
298 uint32_t size);
299
314 uint32_t device,
315 uint32_t segment);
316
329 int (*erase_device) (const struct rtems_fdisk_device_desc* dd,
330 uint32_t device);
331
333
346{
347 uint32_t segment_count;
351
382{
383 uint32_t block_size;
384 uint32_t device_count;
386 uint32_t flags;
394
395 uint32_t compact_segs;
404 uint32_t info_level;
406
407/*
408 * Driver flags.
409 */
410
414#define RTEMS_FDISK_BACKGROUND_ERASE (1 << 0)
415
419#define RTEMS_FDISK_BACKGROUND_COMPACT (1 << 1)
420
426#define RTEMS_FDISK_CHECK_PAGES (1 << 2)
427
432#define RTEMS_FDISK_BLANK_CHECK_BEFORE_WRITE (1 << 3)
433
446rtems_fdisk_initialize (rtems_device_major_number major,
447 rtems_device_minor_number minor,
448 void* arg);
449
455
461
464#ifdef __cplusplus
465}
466#endif /* __cplusplus */
467
468#endif
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_device_driver rtems_fdisk_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
struct rtems_fdisk_driver_handlers rtems_fdisk_driver_handlers
Flash Low Level driver handlers.
struct rtems_flashdisk_config rtems_flashdisk_config
RTEMS Flash Disk configuration table used to initialise the driver.
const rtems_flashdisk_config rtems_flashdisk_configuration[]
External reference to the configuration. Please supply. Support is present in confdefs....
uint32_t rtems_flashdisk_configuration_size
External reference to the number of configurations. Please supply. Support is present in confdefs....
struct rtems_fdisk_segment_desc rtems_fdisk_segment_desc
Flash Segment Descriptor holds, number of continuous segments in the device of this type,...
struct rtems_fdisk_monitor_data rtems_fdisk_monitor_data
Flash Disk Monitoring Data allows a user to obtain the current status of the disk.
struct rtems_fdisk_device_desc rtems_fdisk_device_desc
Flash Device Descriptor holds the segments in a device.
Definition: rtemscompat1.h:15
Definition: flashdisk.h:346
const rtems_fdisk_driver_handlers * flash_ops
Definition: flashdisk.h:349
const rtems_fdisk_segment_desc * segments
Definition: flashdisk.h:348
Definition: flashdisk.h:347
Definition: flashdisk.h:201
int(* write)(const rtems_fdisk_segment_desc *sd, uint32_t device, uint32_t segment, uint32_t offset, const void *buffer, uint32_t size)
Definition: flashdisk.h:245
int(* erase_device)(const struct rtems_fdisk_device_desc *dd, uint32_t device)
Definition: flashdisk.h:329
int(* verify)(const rtems_fdisk_segment_desc *sd, uint32_t device, uint32_t segment, uint32_t offset, const void *buffer, uint32_t size)
Definition: flashdisk.h:293
int(* erase)(const rtems_fdisk_segment_desc *sd, uint32_t device, uint32_t segment)
Definition: flashdisk.h:313
int(* read)(const rtems_fdisk_segment_desc *sd, uint32_t device, uint32_t segment, uint32_t offset, void *buffer, uint32_t size)
Definition: flashdisk.h:220
int(* blank)(const rtems_fdisk_segment_desc *sd, uint32_t device, uint32_t segment, uint32_t offset, uint32_t size)
Definition: flashdisk.h:269
Definition: flashdisk.h:145
Definition: flashdisk.h:175
uint32_t size
Definition: flashdisk.h:179
uint16_t segment
Definition: flashdisk.h:177
uint32_t offset
Definition: flashdisk.h:178
uint16_t count
Definition: flashdisk.h:176
Definition: flashdisk.h:382
uint32_t flags
Definition: flashdisk.h:386
uint32_t avail_compact_segs
Definition: flashdisk.h:403
uint32_t info_level
Definition: flashdisk.h:404
uint32_t block_size
Definition: flashdisk.h:383
const rtems_fdisk_device_desc * devices
Definition: flashdisk.h:385
Definition: flashdisk.h:395
Definition: flashdisk.h:384
Definition: flashdisk.h:393
unsigned size
Definition: tte.h:1
