RTEMS 5.2-rc1
eventdata.h
1
9/* COPYRIGHT (c) 1989-2008.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef _RTEMS_RTEMS_EVENTDATA_H
18#define _RTEMS_RTEMS_EVENTDATA_H
19
20#include <rtems/rtems/event.h>
21
22#ifdef __cplusplus
23extern "C" {
24#endif
25
32typedef struct {
33 rtems_event_set pending_events;
35
38#ifdef __cplusplus
39}
40#endif
41
42#endif
43/* end of include file */
uint32_t rtems_event_set
Integer type to hold an event set of up to 32 events represented as a bit field.
Definition: event.h:40
Classic Event Manager API.
Definition: eventdata.h:32
