RTEMS 5.2-rc1
emc.h
1
9/*
10 * Copyright (c) 2010-2011 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_LPC32XX_EMC_H
24#define LIBBSP_ARM_LPC32XX_EMC_H
25
26#include <rtems.h>
27
28#include <bsp/lpc-emc.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif /* __cplusplus */
33
48#define SDRAMCLK_CLOCKS_DIS BSP_BIT32(0)
49#define SDRAMCLK_DDR_MODE BSP_BIT32(1)
50#define SDRAMCLK_DDR_DQSIN_DELAY(val) BSP_FLD32(val, 2, 6)
51#define SDRAMCLK_RTC_TICK_EN BSP_BIT32(7)
52#define SDRAMCLK_SW_DDR_CAL BSP_BIT32(8)
53#define SDRAMCLK_CAL_DELAY BSP_BIT32(9)
54#define SDRAMCLK_SENSITIVITY_FACTOR(val) BSP_FLD32(val, 10, 12)
55#define SDRAMCLK_DCA_STATUS BSP_BIT32(13)
56#define SDRAMCLK_COMMAND_DELAY(val) BSP_FLD32(val, 14, 18)
57#define SDRAMCLK_SW_DDR_RESET BSP_BIT32(19)
58#define SDRAMCLK_PIN_1_FAST BSP_BIT32(20)
59#define SDRAMCLK_PIN_2_FAST BSP_BIT32(21)
60#define SDRAMCLK_PIN_3_FAST BSP_BIT32(22)
61
70#define EMC_AHB_PORT_BUFF_EN BSP_BIT32(0)
71
80#define EMC_AHB_TIMEOUT(val) BSP_FLD32(val, 0, 9)
81
90#define SDRAM_ADDR_ROW_16MB(val) ((uint32_t) (val) << 10)
91#define SDRAM_ADDR_ROW_32MB(val) ((uint32_t) (val) << 11)
92#define SDRAM_ADDR_ROW_64MB(val) ((uint32_t) (val) << 11)
93
94#define SDRAM_ADDR_BANK_16MB(ba1, ba0) \
95 (((uint32_t) (ba1) << 23) | ((uint32_t) (ba0) << 22))
96#define SDRAM_ADDR_BANK_32MB(ba1, ba0) \
97 (((uint32_t) (ba1) << 23) | ((uint32_t) (ba0) << 24))
98#define SDRAM_ADDR_BANK_64MB(ba1, ba0) \
99 (((uint32_t) (ba1) << 25) | ((uint32_t) (ba0) << 24))
100
101#define SDRAM_MODE_16MB(mode) \
102 (SDRAM_ADDR_BANK_16MB(0, 0) | SDRAM_ADDR_ROW_16MB(mode))
103#define SDRAM_MODE_32MB(mode) \
104 (SDRAM_ADDR_BANK_32MB(0, 0) | SDRAM_ADDR_ROW_32MB(mode))
105#define SDRAM_MODE_64MB(mode) \
106 (SDRAM_ADDR_BANK_64MB(0, 0) | SDRAM_ADDR_ROW_64MB(mode))
107
108#define SDRAM_EXTMODE_16MB(mode) \
109 (SDRAM_ADDR_BANK_16MB(1, 0) | SDRAM_ADDR_ROW_16MB(mode))
110#define SDRAM_EXTMODE_32MB(mode) \
111 (SDRAM_ADDR_BANK_32MB(1, 0) | SDRAM_ADDR_ROW_32MB(mode))
112#define SDRAM_EXTMODE_64MB(mode) \
113 (SDRAM_ADDR_BANK_64MB(1, 0) | SDRAM_ADDR_ROW_64MB(mode))
114
115#define SDRAM_MODE_BURST_LENGTH(val) BSP_FLD32(val, 0, 2)
116#define SDRAM_MODE_BURST_INTERLEAVE BSP_BIT32(3)
117#define SDRAM_MODE_CAS(val) BSP_FLD32(val, 4, 6)
118#define SDRAM_MODE_TEST_MODE(val) BSP_FLD32(val, 7, 8)
119#define SDRAM_MODE_WRITE_BURST_SINGLE_BIT BSP_BIT32(9)
120
121#define SDRAM_EXTMODE_PASR(val) BSP_FLD32(val, 0, 2)
122#define SDRAM_EXTMODE_DRIVER_STRENGTH(val) BSP_FLD32(val, 5, 6)
123
126typedef struct {
127 uint32_t size;
128 uint32_t config;
129 uint32_t rascas;
130 uint32_t mode;
131 uint32_t extmode;
133
134typedef struct {
135 uint32_t sdramclk_ctrl;
136 uint32_t nop_time_in_us;
137 uint32_t control;
138 uint32_t refresh;
139 uint32_t readconfig;
140 uint32_t trp;
141 uint32_t tras;
142 uint32_t tsrex;
143 uint32_t twr;
144 uint32_t trc;
145 uint32_t trfc;
146 uint32_t txsr;
147 uint32_t trrd;
148 uint32_t tmrd;
149 uint32_t tcdlr;
150 lpc32xx_emc_dynamic_chip_config chip [EMC_DYN_CHIP_COUNT];
152
153void lpc32xx_emc_init(const lpc32xx_emc_dynamic_config *dyn_cfg);
154
157#ifdef __cplusplus
158}
159#endif /* __cplusplus */
160
161#endif /* LIBBSP_ARM_LPC32XX_EMC_H */
EMC support API.
Definition: deflate.c:115
Definition: intercom.c:74
Definition: emc.h:126
Definition: emc.h:134
unsigned size
Definition: tte.h:1
